01-Text | 183.64 KB |
Preprovisioning basic configuration
Configuration tasks at a glance
Physical device configuration tasks at a glance
Manually added firewall configuration tasks at a glance
Manually added load balancer configuration tasks at a glance
Configuring local users and enabling the NETCONF service
Configuring a routing protocol
Configuring the management interface
Configuring the interface where the VTEP IP address resides
Configuring the interface where the DCI VTEP IP address resides on the border device
Configuring the external network VPN and the external network outgoing Reth interface
Creating the interface where the vLB's virtual server IP resides
Configuring the firewall to permit traffic by default
Configuring the OVSDB VTEP function and site-facing interface
Reserving VLAN interface resources
Assigning the physical interfaces connecting to the security devices to the same VLAN
Activating the DPI feature on physical security devices
Configuring the IRF bridge MAC address to be permanent
Associating Track with NQA to monitor the primary and backup static routes
Physical device preprovisioning
VNFM and NGFWM template configuration
Preprovisioning manually added devices
Manually adding a firewall as a service chain node
Manually adding a load balancer as a service chain node
Manually adding a VNF firewall as a VNF gateway
Overview
The devices mentioned in this document refer to devices managed by the controller. To ensure the devices can correctly access the underlay network and the devices and the controller are reachable at Layer 3, you must preprovision the devices. This document describes how to preprovision devices in different scenarios. Then, you can manually preprovision devices by device type.
Depending on the carriers of devices, devices include the following types:
· Physical device—Devices carried on physical devices, for example, physical switches. Depending on the type of services provided, physical devices include physical access devices (L2VTEPs) and physical gateways. You must preprovision physical devices.
· Virtual device—Devices (for example, VNF devices and NGFW devices) virtualized on a physical server or physical network device (for example, M9000). Depending on the type of services provided, virtual devices include virtual gateway, virtual firewall, and virtual load balancer. Depending on how virtual devices are created, virtual devices include the following types:
¡ Manually added device—Devices that are manually created and then manually added to the controller for management. You must preprovision this type of devices.
¡ Devices allocated by a resource pool—Virtual devices allocated by the NGFW
resource pool or VNF resource pool. When creating this type of devices, you
must use the related template. Preprovisioned configuration is generated when
the template is created. You do not need to preprovision this type of devices.
You can learn the preprovisioned functions in the template through the
configuration items described in "Configuration items." Also, you can modify the preprovisioned configuration in the
template as needed.
This chapter describes the configuration items and configuration tasks for devices of different types. The Configuration items section describes all possible functions for devices of different types. You can preprovision devices of the specified type according to the corresponding part in the Configuration tasks at a glance section. Also, you can learn which configuration items are preprovisioned in the templates for devices of different types.
Task |
Border devices |
Y |
Y |
Y |
Y |
Y |
Configuring the interface where the DCI VTEP IP address resides on the border device |
Y |
Configuring the OVSDB VTEP function and site-facing interface |
N |
Y |
Assigning the physical interfaces connecting to the security devices to the same VLAN |
Required only for border devices that are members of a service gateway group. |
Required only for border devices in IRF mode. |
Task |
Service-chain firewalls |
Service gateway firewalls |
N |
N |
Y |
Y |
Y |
Y |
Y |
Y |
N |
N |
Required only for service-chain firewalls in IRF mode. |
Required only for service gateway firewalls in IRF mode. |
Y |
Y |
Associating Track with NQA to monitor the primary and backup static routes |
N |
Required when multiple egresses are configured and SNAT is enabled. |
Task |
Service-chain load balancers |
N |
Y |
Y |
Y |
N |
Required only for service-chain load balancers in IRF mode. |
Creating the interface where the vLB's virtual server IP resides |
Y |
Configuration items
Enabling L2VPN
# Enable L2VPN on the device.
[Device] l2vpn enable
# Create a local user named sdn and set the password to 123.
To ensure security, the device needs to perform authentication and authorization for the connections initiated by the controller. Typically, local authentication and authorization are used in the current solution. Therefore, you need to create a local user and configure properties for the user.
[Device] local-user sdn
[Device-luser-manage-sdn] password simple 123
[Device-luser-manage-sdn] service-type ssh https
[Device-luser-manage-sdn] authorization-attribute user-role network-admin
# Configure the device to communicate with the controller by using NETCONF over SSH channels.
[Device] ssh server enable
[Device] netconf ssh server enable
# Configure the device to communicate with the controller by using NETCONF over HTTPS channels.
[Device] ip https enable
[Device] netconf soap https enable
# Enable scheme authentication for VTY lines 0 through 63.
[Device] line vty 0 63
[Device-line-vty0-63] authentication-mode scheme
IMPORTANT: · You can select a routing protocol as needed. As a best practice, use OSPF. · You must configure OSPF processes before enabling OSPF on an interface. · When the device is a VNF device, IS-IS cannot be used. |
# Configure OSPF processes.
One process (for example, process 1) is used as the area for advertising the underlay network routes. The other process (for example, process 10) is used as the area for advertising the management network routes.
[Device] ospf 1
[Device] ospf 10
IMPORTANT: Reth 999 is reserved as the management interface of a device. Do not use this interface for any other purposes. |
· For devices allocated by the resource pool (for example, VNF devices):
¡ When the VNF operates in IRF mode: Create interface Reth 999 on the VNF in IRF mode. The IP address of the interface is allocated by the VNF manager. Add management interfaces on the two VNFs forming the IRF fabric (for example, GigabitEthernet 1/1/0 and GigabitEthernet 2/1/0) to Reth 999 as member interfaces. Add Reth 999 to the area for advertising the management network routes, for example, area 0 of OSPF process 10.
[Device] interface Reth 999
[Device-Reth999] member interface GigabitEthernet 1/1/0 priority 100
[Device-Reth999] member interface GigabitEthernet 2/1/0 priority 80
[Device-Reth999] ospf 10 area 0
¡ When the VNF operates in standalone mode: The IP address of the management interface (for example, GigabitEthernet 1/1/0) is assigned by the VNF manager. Add the management interface to the area for advertising management network routes (for example, area 0 of OSPF process 10).
[Device] interface GigabitEthernet 1/1/0
[Device-GigabitEthernet1/1/0] ospf 10 area 0
· For physical devices and manually added virtual devices: Create the management interface (LoopBack 0 or another interface as needed) and configure an IP address for the interface. Add the interface to the area for advertising the management network routes (for example, area 0 of OSPF process 10).
[Device] interface LoopBack 0
[Device-LoopBack0] ip address 31.0.7.126 255.255.255.255
[Device-LoopBack0] ospf 10 area 0
IMPORTANT: · Loopback 1 is reserved as the interface for configuring the VTEP IP address. Do not use this interface for any other purposes. · The packets sent out of VMs are large and might be dropped because the MTU of an interface is too small during the forwarding process. As a practice, set a greater MTU size for the interface. |
Perform this task to create the interface where the VTEP IP address resides. The VTEP IP address is deployed by the controller rather than manually configured. To ensure VTEP IPs are reachable at Layer 3, advertise the VTEP IP addresses and the addresses of underlay network interconnecting interfaces to the area for advertising underlay network routes.
# Create Loopback 1 as the interface where the VTEP IP address resides. Add the interface to the area for advertising underlay network routes (for example, area 0 of OSPF process 1).
[Device] interface LoopBack 1
[Device-LoopBack1] ospf 1 area 0
# Add all underlay network interconnecting interfaces (for example, Reth 2) to the area for advertising the underlay network routes (for example, area 0 of OSPF process 1). When the underlay network interconnecting interface is a physical interface, the configuration is similar.
On a device, the interface connected to the TOR switch or another device is an underlay network interconnecting interface. The IP addresses of the underlay network interconnecting interfaces are deployed by the VNF manager.
[Device] interface Reth 2
[Device-Reth2] member interface GigabitEthernet 1/4/0 priority 100
[Device-Reth2] member interface GigabitEthernet 2/4/0 priority 80
[Device-Reth2] mtu 9216
[Device-Reth2] ospf 1 area 0
IMPORTANT: Perform this task before the border device comes online. After the border device comes online, the interface where the DCI VTEP IP addresses reside cannot be deleted or modified. |
The DCI VTEP IP addresses are used for creating DCIs. You must manually create the interface where the DCI VTEP IP address resides and assign an IP address to the interface.
# Create Loopback 2 as the interface where the DCI VTEP IP address resides, and assign an IP address to the interface.
[Device] interface LoopBack 2
[Device-LoopBack2] ip address 101.10.1.1 255.255.0.0
IMPORTANT: · The VPN external_vpn is reserved as the external network VPN. Do not use this VPN for any other purposes. · The interface Reth 1 is reserved as the external network outgoing interface. Do not use this interface for any other purposes. |
(Applicable to VNF gateways and NGFW gateways.) The internal network traffic of the network managed by the controller is forwarded in a VPN. To make the internal network and external network communicate, you must create an external network VPN and add the external network outgoing interface to the VPN.
# Create an external network VPN.
[Device] ip vpn-instance external_vpn
# Configure the external network outgoing interface Reth1.
· When Reth1 connects to TOR switches through interfaces sending VLAN-tagged (for example, VLAN tag 2) packets, perform the following tasks:
¡ Configure VLAN termination on the physical subinterfaces on the device.
¡ Configure the physical subinterfaces (for example, GigabitEthernet 1/5/0.2 and GigabitEthernet 2/5/0.2) as the member interfaces of Reth1.
[Device] interface GigabitEthernet 1/5/0.2
[Device-GigabitEthernet1/5/0.2] vlan-type dot1q vid 2
[Device-GigabitEthernet1/5/0.2] interface GigabitEthernet 2/5/0.2
[Device-GigabitEthernet2/5/0.2] vlan-type dot1q vid 2
[Device-GigabitEthernet2/5/0.2] interface Reth 1
[Device-Reth1] member interface GigabitEthernet 1/5/0.2 priority 100
[Device-Reth1] member interface GigabitEthernet 2/5/0.2 priority 80
[Device-Reth1] ip binding vpn-instance external_vpn
· When Reth1 connects to a TOR switch through an interface sending untagged packets, configure the physical interfaces (for example, GigabitEthernet 1/5/0 and GigabitEthernet 2/5/0) as the member interfaces of Reth1.
[Device] interface Reth 1
[Device-Reth1] member interface GigabitEthernet 1/5/0 priority 100
[Device-Reth1] member interface GigabitEthernet 2/5/0 priority 80
Configuring an IRF fabric
(Applicable to VNF devices in IRF mode.) To improve availability for devices, you configure devices to operate in IRF mode.
# Specify member IDs, priorities, and bind IRF ports to IRF physical interfaces for devices.
The data channel and the control channel must use different IRF physical interfaces.
[DeviceA] irf member 1
[DeviceA] irf member 1 priority 32
[DeviceA] irf-port 1
[DeviceA-irf-port1] port group interface GigabitEthernet1/2/0 type data
[DeviceA-irf-port1] port group interface GigabitEthernet1/3/0 type control
[DeviceB] irf member 2
[DeviceB] irf member 2 priority 31
[DeviceB] irf-port 2
[DeviceB-irf-port2] port group interface GigabitEthernet2/2/0 type data
[DeviceB-irf-port2] port group interface GigabitEthernet2/3/0 type control
Configuring track entries
Track entries are used for monitoring the status of the external network outgoing interfaces, downlink interfaces, and management interfaces.
NOTE: You can modify interface names as needed. In this configuration example, GigabitEthernet 1/1/0 and GigabitEthernet 2/1/0 are used as the member interfaces of the management interface Reth 999, GigabitEthernet 1/4/0 and GigabitEthernet 2/4/0 are used as member interfaces of the downlink interface Reth2, and GigabitEthernet 1/5/0 and GigabitEthernet 2/5/0 are used as the member interfaces of the uplink interface Reth1. |
# (Applicable to VNF gateways and NGFW gateways.) Configure track entries to monitor the three types of interfaces on the virtual gateway.
The virtual gateway forwards internal network traffic at Layer 3 and implements communication between the internal network and external network.
[Device] track 1 interface GigabitEthernet 1/1/0
[Device] track 2 interface GigabitEthernet 1/4/0
[Device] track 3 interface GigabitEthernet 1/5/0
[Device] track 4 interface GigabitEthernet 2/1/0
[Device] track 5 interface GigabitEthernet 2/4/0
[Device] track 6 interface GigabitEthernet 2/5/0
# (Applicable to service-chain vFWs and service-chain vLBs.) Configure track entries to monitor management interfaces and downlink interfaces.
The service-chain nodes forward traffic of the current service chain, and is not used for implementing communication between the internal network and external network. You do not need to monitor the external network outgoing interfaces.
[Device] track 2 interface GigabitEthernet 1/5/0
[Device] track 3 interface GigabitEthernet 2/1/0
[Device] track 4 interface GigabitEthernet 2/5/0
Configuring redundancy groups
Redundancy groups are supported only in IRF mode. A redundancy group must contain two nodes, each of which is bound to an IRF member device. The two nodes implement device-level backup and ensure service packets are received, processed, and sent out on the same IRF member device.
NOTE: The redundancy group names, interface names, and IRF member IDs can be modified as needed. For information about interfaces used in this example, see the note in "Configuring track entries." |
# (Applicable to VNF gateways and NGFW gateways.) Create node 1 as the primary node, bind the node to IRF member device 1, and associate it with track entries 1, 2, and 3. Create node 2 as the secondary node, bind the node to IRF member device 2, and associate it with track entries 4, 5, and 6.
When the uplink interface, downlink interface, or management interface of member device 1 fails or member device 1 fails, traffic is switched to member device 2. When the failure recovers, traffic is switched back to member device 1.
[Device] redundancy group reth
[Device-redundancy-group-reth] member interface Reth1
[Device-redundancy-group-reth] member interface Reth2
[Device-redundancy-group-reth] member interface Reth999
[Device-redundancy-group-reth] node 1
[Device-redundancy-group-right-node1] bind slot 1
[Device-redundancy-group-right-node1] priority 100
[Device-redundancy-group-right-node1] track 1 interface GigabitEthernet1/1/0
[Device-redundancy-group-right-node1] track 2 interface GigabitEthernet1/4/0
[Device-redundancy-group-right-node1] track 3 interface GigabitEthernet1/5/0
[Device-redundancy-group-right-node1] quit
[Device-redundancy-group-reth] node 2
[Device-redundancy-group-right-node2] bind slot 2
[Device-redundancy-group-right-node2] priority 80
[Device-redundancy-group-right-node2] track 4 interface GigabitEthernet2/1/0
[Device-redundancy-group-right-node2] track 5 interface GigabitEthernet2/4/0
[Device-redundancy-group-right-node2] track 6 interface GigabitEthernet2/5/0
# (Applicable to service-chain vFWs and service-chain vLBs.) Create node 1 as the primary node, bind the node to IRF member device 1, and associate it with track entries 1 and 2. Create node 2 as the secondary node, bind the node to IRF member device 2, and associate it with track entries 3 and 4.
When the downlink interface or management interface of member device 1 fails or member device 1 fails, traffic is switched to member device 2. When the failure recovers, traffic is switched back to member device 1.
[Device-redundancy-group-right-node2] track 3 interface GigabitEthernet2/1/0
[Device-redundancy-group-right-node2] track 4 interface GigabitEthernet2/4/0
Configuring stateful failover
When devices operate in IRF mode, you must configure stateful failover-related functions on the two virtual devices.
# (Applicable to vFWs, vLBs, VNF gateways, and NGFW gateways.) Enable session synchronization.
[Device] session synchronization enable
# (Applicable to VNF gateways and NGFW gateways.) Enable dynamic NAT444 service synchronization.
[Device] nat port-block synchronization enable
# (Applicable to VNF gateways and NGFW gateways.) Enable IPsec redundancy.
[Device] ipsec redundancy enable
IMPORTANT: Loopback 127 is reserved as the interface where the virtual server IP resides. Do not use this interface for any other purposes. |
The virtual server is a virtual carrier for user services on the load balancer. Only packets matching the virtual server can be processed by the load balancer.
# (Applicable to vLBs.) Create interface Loopback 127, and use this interface to carry the virtual server IP address.
The virtual server IP address configured on the controller will be automatically deployed to the interface.
[Device] interface LoopBack 127
IMPORTANT: · The security zone SDN_ZONE_DEFAULT is reserved as the default SDN permit zone. Do not use this zone for any other purposes. · The object policy SDN_POLICY_DEFAULT is reserved as the default SDN permit policy. Do not use this object policy for any other purposes. |
Some firewalls (for example, vFWs created by the VNF manager or the vFWs virtualized on the M9K device) drop packets matching no security policies by default. As a result, the underlay network or management network might be unreachable.
# Add the interfaces that permit traffic to the default SDN security zone, configure an object policy to permit traffic to pass through, and set the default action to permit for packets exchanged between interfaces in the same security zone.
Then, underlay data link packets and management packets are permitted, and the network is reachable.
[Device] security-zone name SDN_ZONE_DEFAULT
[Device-security-zone-SDN_ZONE_DEFAULT] import interface GigabitEthernet1/0
[Device-security-zone-SDN_ZONE_DEFAULT] import interface GigabitEthernet2/0
[Device-security-zone-SDN_ZONE_DEFAULT] import interface GigabitEthernet3/0
[Device-security-zone-SDN_ZONE_DEFAULT] import interface GigabitEthernet3/0.2
[Device-security-zone-SDN_ZONE_DEFAULT] quit
[Device] object-policy ip SDN_POLICY_DEFAULT
[Device-object-policy-ip-SDN_POLICY_DEFAULT] rule 0 pass
[Device-object-policy-ip-SDN_POLICY_DEFAULT] quit
[Device] security-zone intra-zone default permit
[Device] zone-pair security source any destination any
[Device-zone-pair-security-Any-Any] object-policy apply ip SDN_POLICY_DEFAULT
# Configure the OVSDB VTEP function on the physical access device (L2VTEP).
Then, the controller can automatically sense the online events of VMs or physical servers and learn ARP entries, so that the physical access device (L2VTEP) can run like a vSwitch.
[Device] ovsdb server ptcp port 6632
[Device] ovsdb server enable
[Device] vtep enable
# Specify the site-facing interface as a VTEP access port.
The interface that connects the physical access device (L2VTEP) to a VM or physical server is a site-facing interface, for example, Ten-GigabitEthernet 2/0/5:1. To display and control the site-facing interface on the controller, you must specify the interface as a VTEP access port on the physical access device (L2VTEP).
[Device] interface Ten-GigabitEthernet2/0/5
[Device-Ten-GigabitEthernet2/0/5] vtep access port
Because of the restrictions of the chips used in products (for example, the F series chips used in S12500-X switches), you must reserve VLAN interface resources before creating Layer 3 interfaces or subinterfaces other than VLAN interfaces or configuring features that use Layer 3 interface hardware resources.
# Reserve global VLAN interface resources before creating VXLANs in VSI view when VXLAN tunnels operate in Layer 3 forwarding mode.
One global VLAN interface resource must be reserved for one VXLAN.
[Sysname] reserve-vlan-interface 3400 to 3500 global
Perform this task when a service gateway group is used in the networking scheme,
# Assign the physical interfaces (for example, GigabitEthernet 11/0/13) connecting service gateway group member devices to security devices (for example, firewalls and load balancers) to the same VLAN.
This configuration ensure the member devices and security devices can communicate at Layer 2.
[Device] interface GigabitEthernet 11/0/13
[Device-GigabitEthernet11/0/13] port link-mode bridge
[Device-GigabitEthernet11/0/13] port link-type trunk
[Device-GigabitEthernet11/0/13] port trunk permit vlan all
To deploy DPI services (for example, IPS, antivirus, and URL filtering) on firewall resources (contexts) virtualized from physical security devices, you must activate the DPI feature on these physical security devices. Otherwise, the controller cannot successfully deploy DPI service configurations to contexts on these devices.
# Activate the DPI feature on physical security devices.
[Device] inspect activate
# Configure the IRF bridge MAC address to be permanent.
Perform this task when a device operates in IRF mode. The IRF bridge MAC address does not change after the address owner leaves the fabric.
[Device] irf mac-address persistent always
Associate Track with NQA to monitor static routes and enable automatic switchover between the primary and backup static routes.
# Create an NQA operation with administrator name admin and operation tag test1, and specify ICMP echo as the NQA operation type.
[Device] nqa entry admin test1
[Device-nqa-test-test] type icmp-echo
[Device-nqa-test-test-icmp-echo] destination ip 10.2.2.2
[Device-nqa-test-test-icmp-echo] frequency 1000
[Device-nqa-test-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trap-only
[Device-nqa-test-test-icmp-echo] vpn-instance external_vpn_22
[Device-nqa-test-test-icmp-echo] quit
[Device] nqa schedule test test start-time now lifetime forever
# Create track entry 1 and associate it with reaction entry 1 of NQA operation admin-test.
[Device] track 1 nqa entry admin test reaction 1
Configuration examples
Border device
Local user and NETCONF configuration
Underlay network configuration
[Device] ospf 1
[Device] ospf 10
[Device-LoopBack0] quit
[Device] interface GigabitEthernet 1/0/1
[Device-GigabitEthernet1/0/1] ip address 97.0.6.126 255.255.0.0
[Device-GigabitEthernet1/0/1] ospf 10 area 0
[Device-LoopBack1] quit
[Device] interface GigabitEthernet 2/0/1
[Device-GigabitEthernet2/0/1] ip address 111.0.9.126 255.255.0.0
[Device-GigabitEthernet2/0/1] mtu 9216
[Device-GigabitEthernet2/0/1] ospf 1 area 0
[Device-GigabitEthernet2/0/1] ospf cost 1
When you use the VNF manager or NGFW manager to create devices of the specified type, the controller will deploy the preprovisioned configuration to devices according to the type of template used for creating the devices. This section describes the configuration deployed by the controller.
This section describes only the simplest configuration for devices to function. The deployed configuration might vary with the interfaces used for configuring templates.
VNFM 3.0 template
VNF gateway in standalone mode
interface GigabitEthernet 3/0.2
interface Reth 1
member interface GigabitEthernet 3/0.2 priority 100
ospf 1
ospf 10
ospf 10 area 0
ospf 10 area 0
ospf 1 area 0
mtu 9216
ospf 1 area 0
VNF gateway in IRF mode
interface Reth 1
interface Reth2
preempt-delay 0
node 1
bind slot 1
priority 100
node 2
bind slot 2
priority 80
ospf 1
non-stop-routing
interface Reth2
ospf 1 area 0
ospf 1 area 0
interface Reth 2
mtu 9216
Service-chain vFW in standalone mode
ospf 1
ospf 10
ospf 10 area 0
ospf 1 area 0
mtu 9216
ospf 1 area 0
Object-policy ip SDN_POLICY_DEFAULT
rule 0 pass
zone-pair security source Any destination Any
Service-chain vFW in IRF mode
interface Reth2
track 4 interface GigabitEthernet 2/4/0
preempt-delay 0
node 1
bind slot 1
priority 100
node 2
bind slot 2
priority 80
ospf 1
non-stop-routing
interface Reth2
ospf 1 area 0
ospf 1 area 0
interface Reth2
mtu 9216
import interface Reth2
import interface Reth999
rule 0 pass
Service-chain vLB in IRF mode
interface Reth2
preempt-delay 0
node 1
bind slot 1
priority 100
node 2
bind slot 2
priority 80
ospf 1
non-stop-routing
interface Reth2
ospf 1 area 0
ospf 1 area 0
interface Reth2
mtu 9216
Service-chain vLB in standalone mode
ospf 1
ospf 10
ospf 10 area 0
ospf 1 area 0
mtu 9216
ospf 1 area 0
NGFWM template
NGFW gateway
interface Reth 1
ospf 1
ospf 10
ospf 10 area 0
ospf 1 area 0
mtu 9216
ospf 1 area 0
ospf cost 1
rule 0 pass
Service-chain vFW
ospf 1
ospf 10
ospf 10 area 0
ospf 1 area 0
mtu 9216
ospf 1 area 0
rule 0 pass
Gateway service-type vFW
ospf 1 vpn-instance external_vpn
import-route direct
import-route static
area 0.0.0.0
interface LoopBack2
interface Ten-GigabitEthernet2/0/4
description internal
interface Ten-GigabitEthernet2/0/9
description external
ospf 1 area 0.0.0.0
interface Ten-GigabitEthernet2/0/15
description management
security-zone name SEC_ZONE_DEFAULT
import interface Ten-GigabitEthernet2/0/15
object-policy ip SEC_POLICY_DEFAULT
rule 0 pass
object-policy apply ip SEC_POLICY_DEFAULT
ip route-static 0.0.0.0 0 192.168.67.254
Service-chain vLB
session synchronization http
ospf 1
ospf 10
ospf 10 area 0
ospf 1 area 0
mtu 9216
ospf 1 area 0
ospf cost 1
Gateway service-type vLB
interface LoopBack127
interface Ten-GigabitEthernet1/0/26
interface Ten-GigabitEthernet1/0/27
[Device] ospf 1
[Device] ospf 10
[Device]interface LoopBack 0
[Device-LoopBack0] ip address 31.0.7.123 255.255.255.255
[Device-LoopBack0] interface GigabitEthernet 1/0
[Device-GigabitEthernet1/0] ip address 97.0.6.126 255.255.0.0
[Device-GigabitEthernet1/0] ospf 10 area 0
[Device-GigabitEthernet1/0] interface LoopBack 1
[Device-LoopBack1] ip address 21.0.6.126 255.255.255.255
[Device-LoopBack1] interface GigabitEthernet 2/0
[Device-GigabitEthernet2/0] ip address 111.0.9.125 255.255.0.0
[Device-GigabitEthernet2/0] mtu 9216
[Device-GigabitEthernet2/0] ospf 1 area 0
[Device-GigabitEthernet2/0] ospf cost 1
Security configuration
[Device] Object-policy ip SDN_POLICY_DEFAULT
[Device] ospf 1
[Device] ospf 10
Configuring the interface where the virtual server IP resides
[Device] interface GigabitEthernet 3/0.2
[Device-GigabitEthernet3/0.2] vlan-type dot1q vid 2
[Device-GigabitEthernet3/0.2] interface Reth 1
[Device-Reth1] member interface GigabitEthernet 3/0.2 priority 100
[Device-Reth1] quit
[Device] ospf 1
[Device] ospf 10
Manually adding a VSR as a VNF gateway
[Device-Reth1] quit
[Device] ospf 1
[Device] ospf 10
Manually adding bare-metal devices managed by NGFW manager
Management interface and route configuration
Configure an IP address for the management interface, and configure a route to ensure the IP address and the controller IP address are reachable. (Details not shown.)
