01-Text | 85.32 KB |
Configuring the Kubernetes nodes
Configuring a node in host-based overlay model
Configuring a node in network-based overlay model
Installing the VCF Kubernetes plug-in
Loading the plug-in Docker image
Overview
Kubernetes is an open-source container orchestration platform for automated deployment, scaling, and management of containerized applications.
Pods are the smallest deployable units of computing in Kubernetes. A Pod is a group of one or more tightly coupled containers. The containers share the networking resources, file system, and specifications for how to run the containers.
Installation of the VCF Kubernetes plug-in allows interconnection between the Kubernetes platform and the SeerEngine-DC controller. The SeerEngine-DC controller can monitor traffic, deploy security policies, and provide networking services for Pods in Kubernetes.
Preparing for installation
Hardware requirements
Table 1 shows the minimum hardware requirements for installing the VCF Kubernetes plug-in on a physical server or virtual machine.
Table 1 Minimum hardware requirements
CPU |
Memory size |
Disk size |
Quad-core |
8 GB |
50 GB |
Software requirements
Table 2 shows the software requirements for installing the VCF Kubernetes plug-in.
Item |
Supported versions |
Kubernetes |
Kubernetes 1.9/1.10 |
vSwitch |
· Host-based overlay—For the vSwitch version information, see the release notes for the SeerEngine-DC controller · Network-based overlay—Open vSwitch 2.9 and later |
You must configure basic settings for Kubernetes nodes before installing the VCF Kubernetes plug-in.
1. Install the S1020V vSwitch. For the installation procedure, see H3C S1020V Installation Guide.
2. Configure a VDS on the SeerEngine-DC controller and add the VDS configuration to the node.
In the following example, vds1-br is the vSwitch name, eth1 is the uplink interface of the vSwitch, vxlan_vds1-br is the VXLAN tunnel name, and 100.0.100.100 is the VTEP's IP.
$ ovs-vsctl add-br vds1-br
$ ovs-vsctl add-port vds1-br eth1
$ ovs-vsctl add-port vds1-br vxlan_vds1-br -- set interface vxlan_vds1-br type=vxlan options:remote_ip=flow options:local_ip=100.0.100.100 options:key=flow
3. Configure a KVM-type compute domain on the controller and associate the domain with the VDS.
4. Add the node to the hosts in the compute domain.
1. Install the Open vSwitch.
$ yum install -y openvswitch
$ systemctl enable openvswitch.service
$ systemctl start openvswitch.service
2. Install and start lldpad
$ yum install -y lldpad
$ systemctl enable lldpad.service
$ systemctl start lldpad.service
3. Enable LLDP message sending on the uplink interface (eno2 for example).
$ lldptool set-lldp -i eno2 adminStatus=rxtx;
$ lldptool -T -i eno2 -V sysName enableTx=yes;
$ lldptool -T -i eno2 -V portDesc enableTx=yes;
$ lldptool -T -i eno2 -V sysDesc enableTx=yes;
$ lldptool -T -i eno2 -V sysCap enableTx=yes;
4. Add an Open vSwitch bridge (br-eno2 for example) on the node, specify the OpenFlow version, and set the fail mode to secure.
$ ovs-vsctl add-br br-eno2
$ ovs-vsctl set bridge br-eno2 protocols=OpenFlow13
$ ovs-vsctl set-fail-mode br-eno2 secure
5. Add an uplink interface (eno2 for example) to the Open vSwitch bridge and configure the interface settings.
$ ovs-vsctl add-port br-eno2 eno2
$ ovs-vsctl br-set-external-id br-eno2 uplinkInterface eno2
Follow these steps to load the plug-in Docker image on the master and nodes, respectively:
1. Obtain the VCF Kubernetes plug-in Docker image. Then copy the image to the installation directory on the server or virtual machine, or upload it to the installation directory through FTP, TFTP, or SFTP.
The name of the image is in the SeerEngine_DC_NET_PLUGIN-version.tar format, where version represents the image version number.
CAUTION: To avoid damaging the image, use the binary mode when you upload the image through FTP or TFTP. |
2. Load the Docker image.
$ docker load -i SeerEngine_DC_NET_PLUGIN-E3108.tar
Installing the plug-in
You must install the plug-in on the master.
To install the plug-in:
1. Obtain the configuration file of the VCF Kubernetes plug-in. The configuration file name is in the SeerEngine_DC_NET_PLUGIN-version.yaml format, where version represents the version number.
2. Copy the file to the installation directory of the master, or upload it to the installation directory through FTP, TFTP, or SFTP.
3. Modify the configuration file.
a. Use the vi editor to open the configuration file.
$ vi SeerEngine_DC_NET_PLUGIN-E3108.yaml
b. Press I to switch to insert mode, and then modify the configuration file. For information about the parameters, see Table 3.
kind: ConfigMap
apiVersion: v1
metadata:
namespace: kube-system
data:
etcd_servers: "http://192.168.0.10:2379"
k8s_api_server: "https://192.168.0.20:6443"
k8s_ca: "/etc/vcfc-net-plugin/ca.crt"
k8s_key: "/etc/vcfc-net-plugin/client.key"
k8s_cert: "/etc/vcfc-net-plugin/client.crt"
k8s_token: ""
kind: ConfigMap
apiVersion: v1
metadata:
data:
vcfc_url: http://192.168.0.32:10080
vcfc_username: "admin"
vcfc_password: "admin@123"
vcfc_domain: "sdn"
vcfc_client_timeout: "1800"
vcfc_client_retry: "10"
netoverlay_vlan_ranges: "node01:1:100,node02:101:200"
log_dir: "/var/log/vcfc-net-plugin/"
log_level: "1"
bind_host: "0.0.0.0"
bind_port: "9797"
protocol: "http"
kind: ConfigMap
apiVersion: v1
metadata:
data:
net_masters: "auto"
net_master_app_name: "vcfc-net-master"
net_master_app_namespace: "kube-system"
net_master_protocol: "http"
net_master_port: "9797"
overlay_mode: "auto"
log_level: "1"
default_security_policy: "permit"
4. Install the plug-in.
$ kubectl create -f SeerEngine_DC_NET_PLUGIN-E3108.yaml
5. Verify the installation. If the Pods are in Running state, the plug-in is installed correctly.
$ kubectl get pods -n
kube-system | grep vcfc
vcfc-net-agent-mtwkl 1/1 Running 0 5d7h
vcfc-net-agent-rt2s6 1/1 Running 0 5d7h
vcfc-net-master-79bc68885c-2s9jm 1/1 Running 0 5d7h
The following table describes parameters in the configuration file of the VCF Kubernetes plug-in.
Table 3 Parameters in the configuration file of the VCF Kubernetes plug-in
Parameter |
etcd_servers |
etcd service API address. |
k8s_api_server |
K8s API server interface address. |
k8s_ca |
Client CA file of the K8s API server. This parameter is valid only when the value of the k8s_api_server parameter is an HTTPS address. |
k8s_key |
Client X.509 certificate private key file of the K8s API server. This parameter is valid only when the value of the k8s_api_server parameter is an HTTPS address. It is used together with k8s_cert. This parameter is not required when k8s_token authentication is used. |
k8s_cert |
Client X.509 certificate file of the K8s API server. This parameter is valid only when the value of the k8s_api_server parameter is an HTTPS address. This parameter is not required when k8s_key and k8s_cert authentication is used. |
k8s_token |
Client authentication token of the K8s API server. This parameter is valid only when the value of the k8s_api_server parameter is an HTTPS address. This parameter is not required when k8s_key and k8s_cert authentication is used. |
vcfc_url |
URL address for logging in to SNA Center |
vcfc_username |
Username for logging in to SNA Center. |
vcfc_password |
Password for logging in to SNA Center. |
vcfc_domain |
Name of the domain where the SeerEngine-DC controller resides. |
vcfc_client_timeout |
The amount of time waiting for a response from the SeerEngine-DC controller, in seconds. |
vcfc_client_retry |
Maximum transmissions of connection requests to the SeerEngine-DC controller. |
netoverlay_vlan_ranges |
VLAN range for the node in network-based overlay mode, in the format of VLAN_min:VLAN_max. For more than one VLAN range, use a comma to separate them. |
log_dir |
Log directory. |
log_level |
Log level. |
bind_host |
API-bound address. |
bind_port |
API-bound port number. As a best practice, bind the API to the net_master_port. |
protocol |
API protocol. Only HTTP is supported. |
net_masters |
IP address of the VCFC network master. auto means automatically obtaining the IP address. |
net_master_app_name |
Application name of the VCFC network master. |
net_master_app_namespace |
Application namespace of the VCFC network master. |
net_master_protocol |
API protocol of the VCFC network master. |
net_master_port |
API port number of the VCFC network master. |
overlay_mode |
Overlay mode of the node: · net—Network-based overlay · host—Host-based overly · auto—Automatic selection of overlay mode based on the open vSwitch configuration |
default_security_policy |
Default security policy. This parameter takes effect only in network-based overlay mode. · permit · deny |
Removing the plug-in
To remove the plug-in, execute the following command:
$ kubectl delete -f SeerEngine_DC_NET_PLUGIN-E3108.yaml
Upgrading the plug-in
1. Install the plug-in Docker image. For the installation procedure, see "Loading the plug-in Docker image."
2. Upload and modify the plug-in configuration file. For the procedure, see "Installing the plug-in."
3. Upgrade the plug-in.
$ kubectl apply -f SeerEngine_DC_NET_PLUGIN-E3108.yaml
Configuration example
Installation of the VCF Kubernetes plug-in allows interconnection between the SeerEngine-DC controller and the Kubernetes platform. The following example describes the configuration procedure for Pods to be managed by the SeerEngine-DC controller.
For the Pods to be managed by the SeerEngine-DC controller:
1. Create tenants, virtual link layer networks, subnets, security policies, and network policies on the controller.
2. Create and modify a Pod configuration file, postgres-pod.yaml for example.
$ vi postgres-pod.yaml
apiVersion: v1
kind: Pod
metadata:
labels:
h3c.io/network_id: 9e9af886-e038-4c94-8573-11b89079196d
h3c.io/tenant_id: 14ac7fc1-50d4-409a-ad76-4a0c35f429f3
h3c.io/qos_policy_id: 38b51db9-cc1d-4b07-872e-cf2644bfc057
h3c.io/security_group_id: 39b70d60-8bfd-4b27-bb4d-4b8f8955a2e6
spec:
containers:
- name: postgres
image: postgres
Parameter description:
¡ h3c.io/network_id—UUID of the SeerEngine-DC virtual network. This parameter is required.
¡ h3c.io/tenant_id—UUID of the SeerEngine-DC tenants. This parameter is required.
¡ h3c.io/qos_policy_id—UUID of the SeerEngine-DC network policy. This parameter is optional.
¡ h3c.io/security_group_id—UUID of the SeerEngine-DC security policy. This parameter is optional.
3. Use the configuration file to create a Pod.
$ kubectl create -f postgres-pod.yaml
4. Verify that the Pod is displayed and manageable on the Virtual Port page on the SeerEngine-DC controller.
