H3C S10500X Switch Series Installation Guide-6W106
HomeSupportResource CenterSwitchesH3C S10500X Switch SeriesH3C S10500X Switch SeriesTechnical DocumentsInstallInstallation GuidesH3C S10500X Switch Series Installation Guide-6W106
07-Appendix B FRUs and Compatibility Matrixes
07-Appendix B FRUs and Compatibility Matrixes 140.27 KB
7 Appendix B FRUs and compatibility matrixes
For the compatibility between cards and the system software, see the release notes.
For the compatibility between cards and transceiver modules, see H3C S10500X Switch Series Cards and Transceiver Modules Compatibility Matrixes.
MPUs
You can install one MPU, or two MPUs for redundancy on the switch. When you install two MPUs, the two MPUs must be the same model.
Table 7-1 MPU specifications
MPU model
Specifications
Flash memory
NVRAM
SDRAM
Ports
Compatible device models
LSUM1SUPXD0
2 GB
1 MB
8 GB
·     1 × console port
·     1 × USB console port
·     4 × network management ports (two RJ-45 ports and two SFP ports)
·     1 × USB port
S10508X
S10508X-V
S10516X
LSUM1SUPXES0
4 GB
1 MB
8 GB
·     1 × console port
·     1 × USB port
·     2 × SMB coaxial clock output ports
·     2 × SMB coaxial clock input ports
·     2 × high-precision time synchronization ports (Both ports are used for input by default. When both the ports are used for input, only port 1 is valid.)
S10508X
S10508X-V
S10516X
LSUM1MPUS06XEC0
2 GB
1 MB
8 GB
·     1 × console port
·     1 × USB port
S10506X
LSUM1MPUS06XEB0
2 GB
1 MB
4 GB
·     1 × console port
·     1 × USB port
S10506X
LSUM1MPUS10XE0
2 GB
1 MB
8 GB
·     1 × console port
·     1 × USB port
S10510X
LSUM1MPUS10XEA0
4 GB
1 MB
4 GB
·     1 × console port
·     1 × USB port
S10510X
·     Among the network management ports on an MPU, only port 0 is available during the startup of the switch.
·     To connect an SFP network management port on the MPUs, make sure the peer port operates at 1000 Mbps in full-duplex mode.
·     Do not use USB extension cables to connect the USB ports on the MPUs.
Service modules
Follow these restrictions and guidelines to use the service modules:
·     The fiber ports cannot automatically negotiate or be configured to operate in half-duplex mode. For information about the duplex mode of Ethernet interfaces, see Ethernet interface commands in H3C S10500X Interface Command Reference.
·     When you use the using hundredgige-from-fortygige interface command to convert 40-GE ports on the LSUM2CQGS12SG0 and LSUM1CQGS12XSG0 interface modules to 100-GE ports, only ports 1, 4, 7, and 10 are available.
·     When you use the using hundredgige-from-fortygige interface command to convert 40-GE ports on an LSUM1CQGS32SF0 interface module to 100-GE ports, only odd-numbered ports are available.
·     Slot 15 on an S10516X switch does not support the LSUM1CGS32XSH0 or LSUM1CGS20XSH0 interface module.
·     An S10510X switch does not support the LSUM1CGS32XSH0 or LSUM1CGS20XSH0 interface module when it uses the LSUM1MPUS10XEA0 MPUs.
·     An S10506X switch does not support the LSUM1CGS32XSH0 or LSUM1CGS20XSH0 interface module in slot 4 or 5 when it uses the LSUM1MPUS06XEB0 MPUs.
Ethernet interface modules
Table 7-2 Ethernet interface module specifications
Model
Port quantity
Port type
Compatible transceiver modules and network cables
LSUM1YGS24CSSH0
28
·     4 × 100GBASE-R-QSFP28 fiber ports
·     24 × 25GBASE-R-SFP28 fiber ports
·     QSFP28 transceiver module
·     QSFP28 DAC cable
·     QSFP28 AOC cable
·     QSFP+ transceiver module
·     QSFP+ DAC cable
·     QSFP+ AOC cable
·     SFP28 transceiver module
·     SFP28 DAC cable
·     SFP28 AOC cable
·     10-GE SFP+ transceiver module
·     10-GE SFP+ DAC cable
LSUM1CGS20XSH0
20
20 × 100GBASE-R-QSFP28 fiber ports
·     QSFP28 DAC cable
·     QSFP28 to SFP28 DAC cable
·     QSFP+ DAC cable
·     QSFP28 AOC cable
·     QSFP+ to SFP+ DAC cable
LSUM1CGS8QSSH0
16
·     8 × 100GBASE-R-QSFP28 fiber ports
·     8 × 40GBASE-R-QSFP+ fiber ports
·     QSFP28 DAC cable
·     QSFP28 AOC cable
·     QSFP+ DAC cable
·     QSFP+ AOC cable
LSUM1CGS8SH0
8
·     QSFP28 DAC cable
·     QSFP28 AOC cable
·     QSFP+ DAC cable
·     QSFP+ AOC cable
LSUM1CGS32XSH0
32
32 × 100GBASE-R-QSFP28 fiber ports
·     QSFP28 DAC cable
·     QSFP28 AOC cable
·     QSFP+ DAC cable
·     QSFP+ AOC cable
LSUM2CQGS12SG0
12
12 × 40G QSFP+ fiber ports or 4 × 100G QSFP28 fiber ports
·     QSFP+ DAC cable
LSUM1CQGS12XSG0
12
·     QSFP+ DAC cable
LSUM1CQGS32SF0
32
32 × 40GBASE-R-QSFP+ fiber ports or 16 × 100GBASE-R-QSFP28 fiber ports
·     QSFP+ DAC cable
LSUM1CGS2FE0
2
LSUM2TGS32QSSG0
36
·     4 × 40GBASE-R-QSFP+ fiber ports
·     32 × 10GBASE-R-SFP+ fiber ports
·     QSFP+ DAC cable
·     FE/GE SFP transceiver module
LSUM2QGS24RSG0
24
24 × 40G QSFP+ fiber ports
·     QSFP+ DAC cable
LSUM2QGS12SG0
12
12 × 40GBASE-R-QSFP+ fiber ports
·     QSFP+ DAC cable
LSUM1QGS6EC0
6
6 × 40GBASE-R-QSFP+ fiber ports
LSUM1YGS48XSH0
48
48 × 25GBASE-R-SFP28 fiber ports
·     GE SFP transceiver module
·     SFP28 DAC cable
·     SFP28 AOC cable
LSUM2GT24PTSSE0
48
·     4 × 10GBASE-R SFP+/LC fiber ports
·     20 × 1000BASE-X-SFP/LC fiber ports
·     24 × 10/100/1000BASE-T-RJ-45 copper ports
·     Category 5 twisted pair cable
LSUM2GT24TSSE0
28
LSUM1TGS48SH0
48
48 × 10GBASE-R-SFP+ fiber ports
LSUM1TGS48RSH0
48
LSUM1TGS48XSG0
48
LSUM2TGS48SG0
48
LSUM1GP40TS8FD0
48
·     8 × 10GBASE-R-SFP+ fiber ports
·     40 × 1000BASE-X-SFP fiber ports
LSUM2GP40TS8FD0
48
LSUM2GP44TSSE0
48
·     44 × 1000BASE-X-SFP/LC fiber ports
LSUM2GP24TSSE0
28
·     24 × 1000BASE-X-SFP/LC fiber ports
LSUM1TGS24FD0
24
24 × 10GBASE-R-SFP+ fiber ports
LSUM1TGS16FD0
16
16 × 10GBASE-R-SFP+ fiber ports
LSUM1TGS24EC0
24
LSUM1GP48FD0
48
LSUM1TGT24FD0
24
10GBASE-T-RJ-45 copper port
Category 6A/7 twisted pair cable
LSUM1GT48FD0
48
48 × 10/100/1000BASE-T-RJ-45 copper ports
LSUM2GT48SE0
48
OAA modules
Table 7-3 OAA module specifications
Model
Ports
LSUM1WCMX20RT
Access controller module
·     1 × console port
·     1 × 100/1000BASE-T out-of-band management Ethernet port
LSUM1WCMX40RT
·     1 × console port
LSUM1FWDEC0
Firewall module
·     1 × console port
·     1 × USB port (reserved)
·     1 × GE copper port
·     1 × hard disk slot
LSUM1NSDEC0
NetStream module
·     1 × console port
LSUM1ACGDEC0
Application control gateway module
·     1 × console port
·     1 × 10/100/1000BASE-T copper port
LSUM1EPSB0
EPS endpoint security module
·     3 × USB 2.0 ports (used only by technical personnel for debugging)
·     1 × VGA connector
·     1 × 10/100/1000BASE-T management Ethernet port
·     1 × console port (used only by technical personnel for debugging)
Category 5 twisted-pair cable
LSUM1SDNB0
SDN automation module
·     1 × VGA connector
LSUM1WBCZ720XRT
Multiservice access controller module
·     3 × USB 2.0 ports (only for debugging use)
·     1 × VGA connector
·     1 × 1000BASE-T management Ethernet port
·     1 × console port
Switching fabric modules
CAUTION
CAUTION:
·     The console port on a switching fabric module is only for maintenance by H3C Support. Do not use the port if you have not been trained for that.
·     You must install switching fabric modules of the same model on the switch.
IMPORTANT
IMPORTANT:
Follow these restrictions and guidelines when you install switching fabric modules:
·     On an S10506X switch, populate switching fabric module slots 9 and 10 prior to slot 7. Populate slot 7 only when the switch requires three switching fabric modules.
·     On an S10508X or S10508X-V switch, populate switching fabric module slots 10 and 12 prior to other switching fabric module slots. Populate slot 11 only when the switch requires five switching fabric modules.
·     On an S10510X switch, populate switching fabric module slots 13 and 14 prior to slot 11. Populate slot 11 only when the switch requires three switching fabric modules.
·     On an S10516X switch, populate switching fabric module slots 18 and 20 prior to other switching fabric module slots. Populate slot 19 only when the switch requires five switching fabric modules.
Table 7-4 Compatibility between switching fabric modules and switch models
Switch model
Compatible switching fabric modules
Quantity
S10506X
·     LSUM1FAB06XEC0
·     LSUM1FAB06XEB0
0 to 3
S10508X
·     LSUM1FAB08XE0
·     LSUM1FAB08XEB0
2 to 5
S10508X-V
·     LSUM1FAB08XE0
·     LSUM1FAB08XEB0
2 to 5
S10510X
·     LSUM1FAB10XE0
·     LSUM1FAB10XEA0
0 to 3
S10516X
LSUM1FAB16XD0
2 to 5
All the switching fabric modules in Table 7-4 except the LSUM1FAB16XD0 each provide an RJ-45 console port.
Power system
Power modules
CAUTION
CAUTION:
Do not install power modules of different models on the same switch.
The LSUM1AC1200 and LSUM2AC2500 AC power modules and the LSUM1DC2400 DC power module are available for the switch.
Table 7-5 Power module specifications
Item
LSUM1AC1200
LSUM1AC2500
LSUM1DC2400
Rated input voltage range
100 VAC to 240 VAC @ 50/60 Hz
–48 VDC to –60 VDC
Rated output voltage
12 VDC
12 VDC
12 VDC
Maximum input current
16 A
16 A
60 A
Maximum output current
100 A
·     208 A (220 VAC)
·     100 A (110 VAC)
200 A
Maximum output power
1200 W
·     1200 W (110 VAC)
·     2500 W (220 VAC)
2400 W
Temperature requirements
·     Operating temperature: –10°C to +50°C (14°F to 122°F)
·     Storage temperature: –40°C to +70°C (–40°F to +185°F)
Applicable switch models
·     S10506X
·     S10508X
·     S10508X-V
·     S10510X
All S10500X models
All S10500X models
Quantity
·     S10506X: 1 to 4
·     S10508X/S10508X-V/S10510X: 1 to 6
·     S10506X: 1 to 4
·     S10516X: 1 to 16
·     S10506X: 1 to 4
·     S10516X: 1 to 16
Make sure the total maximum output power of the ordered power modules is greater than the system power consumption. As a best practice, reserve 20% of the maximum output power.
When the temperature of a power module exceeds the acceptable temperature range, the power module is automatically powered off. When the temperature returns to the acceptable temperature range, the power module is automatically powered on.
Power cords
DC power cords
DC power cords are used for connecting DC power modules of the switch to the external DC power source.
Table 7-6 DC power cords available for S10500X switches
Chassis model
DC power cord quantity
Cord code and length
Remarks
S10506X
1 to 4 pairs
·     0404A0E1, 3 m (9.84 ft)
·     0404A0E2, 15 m (49.21 ft)
S10508X
1 to 6 pairs
Used for connecting the LSUM1DC2400 power module to a DC power source
S10508X-V
1 to 6 pairs
S10510X
1 to 6 pairs
S10508X-V
1 to 16 pairs
AC power cords
An AC power cord is used to connect an AC power module of the switch to the external AC power supply system.
To select an AC power cord for an AC power module, consider the following items:
·     Power capacity of the power module.
·     Current-carrying capacity of the power cord.
·     Region-and country-specific plug type.
The AC power modules available for the switch require a 16A AC power cord. Table 7-7 describes the region-and country-specific plug types for 16A AC power cords.
Table 7-7 16A AC power cords used in different countries or regions
1
Plug type
Code (Length)
Countries or regions where the type of power cords conforms to local safety regulations and can be used legally
Other countries or regions using this type of power cords
Countries or regions seldom using this type of power cords
I type
04043396 (3 m, or 9.8 ft)
Mainland China
N/A
N/A
Plug outline
Power cord outline
Connector outline
040433961WX_VD
2
Plug type
Code (Length)
C20 type
0404A0C2 (3 m, or 9.8 ft)
Mainland China
N/A
N/A
Plug outline
Power cord outline
Connector outline
3
Plug type
Code (Length)
B type
0404A063 (3 m, or 9.8 ft)
Canada and U.S.A
Mexico, Argentina, Brazil, Columbia, Venezuela, Thailand, Peru, Philippine, and A6 countries or regions
N/A
Plug outline
Power cord outline
Connector outline
4
Plug type
Code (Length)
F type
0404A061 (3 m, or 9.8 ft)
Holland, Denmark, Sweden, Finland, Norway, Germany, France, Austria, Belgium, and Italy
Indonesia, Turkey, Russia, and CIS
N/A
Plug outline
Power cord outline
Connector outline
0404A0611WX_V00
0404A061WX_V00
040433961WX_VD
5
Plug type
Code (Length)
B type
0404A062 (3 m, or 9.8 ft)
Japan
N/A
N/A
Plug outline
Power cord outline
Connector outline
0404A062WX_V00
040433961WX_VD
6
Plug type
Code (Length)
I type
0404A01A (3 m, or 9.8 ft)
Australia
N/A
N/A
Plug outline
Power cord outline
Connector outline
0404A01AWX_V00
0404A01A1WX_V00
040433961WX_VD
The connector outline figures shown in the table are C19 straight connectors.
Fan trays
The S10506X, S10508X, S10508X-V, and S10510X switches come with a fan tray installed in the FAN0 slot. You can install a fan tray in the FAN1 slot as required. The S10516X switch comes with a fan tray installed in each fan tray slot.
If a fan tray fails, purchase a fan tray compatible with the switch to replace the failed one.
Table 7-8 Fan tray specifications
Fan tray
Number of fans
Fan diameter
Maximum air flow rate
S10506X master fan tray
6
120 mm (4.72 in)
680 CFM
S10506X standby fan tray
2
120 mm (4.72 in)
200 CFM
S10508X master fan tray
8
120 mm (4.72 in)
920 CFM
S10508X standby fan tray
2
120 mm (4.72 in)
200 CFM
S10508X-V fan tray
12
120 mm (4.72 in)
840 CFM
S10510X master fan tray
10
120 mm (4.72 in)
980 CFM
S10510X standby fan tray
2
120 mm (4.72 in)
260 CFM
S10516X fan tray
2
80 mm (3.15 in)
350 CFM
