H3C S10500X Switch Series Installation Guide-6W106
HomeSupportResource CenterSwitchesH3C S10500X Switch SeriesH3C S10500X Switch SeriesTechnical DocumentsInstallInstallation GuidesH3C S10500X Switch Series Installation Guide-6W106
06-Appendix A Chassis Views and Technical Specifications
6 Appendix A Chassis views and technical specifications
Chassis views
The chassis views in the following figures are for illustration only.
S10506X
Figure 6-1 S10506X front and rear panels
(1) Service module slots 0 through 5
(2) Power module slots
(3) Fan tray slots
(4) MPU slots 6 and 8
(5) Switching fabric module slots 7, 9, and 10 (slot 7 can be used only when three switching fabric modules are required)
S10508X
Figure 6-2 S10508X front and rear panels
(1) MPU slots 0 and 1
(2) Service module slots 2 through 9
(3) Power module slots
(4) Fan tray slots
(5) Switching fabric module slots 10 through 14 (slot 11 can be used only when five switching fabric modules are required)
S10508X-V
Figure 6-3 S10508X-V front and rear panels
(4) Fan tray slots
S10510X
Figure 6-4 S10510X front and rear panels
(1) Service module slots 0 through 9
(3) Fan tray slots
(4) MPU slots 10 and 12
(5) Switching fabric module slots 11, 13, and 14 (slot 11 can be used only when three switching fabric module are required)
S10516X
Figure 6-5 S10516X front and rear panels
(1) Service module slots 0 through 15
(2) MPU slots 16 and 17
(4) Power switch
(5) Fan tray slots
(6) Switching fabric module slots 18 through 22 (slot 19 can be used only when five switching fabric modules are required)
Weights and dimensions
Table 6-1 Chassis weights and dimensions
Model
Weight (fully configured)
Height
Width
Depth
S10506X
< 85 kg (187.39 lb)
397 mm (15.63 in)/9 RU
440 mm (17.32 in)
660 mm (25.98 in)
S10508X
< 120 kg (264.55 lb)
620 mm (24.41 in)/14 RU
440 mm (17.32 in)
660 mm (25.98 in)
S10508X-V
< 145 kg (319.66 lb)
930 mm (36.61 in)/21 RU
440 mm (17.32 in)
660 mm (25.98 in)
S10510X
< 130 kg (286.60 lb)
664 mm (26.14 in)/15 RU
440 mm (17.32 in)
660 mm (25.98 in)
S10516X
< 340 kg (749.56 lb)
1686 mm (66.38 in)/38 RU
440 mm (17.32 in)
640 mm (25.20 in)
The switch uses a modular design. The chassis weight in full configuration includes the weights of the chassis, cards, power modules, interface modules, and other removable modules.
The chassis dimensions in Table 6-1 exclude the FRUs and accessories such as mounting brackets, cable management brackets, cards, and power modules.
Rack Unit (RU) is a measurement for rack height. One RU is 44.45 mm (1.75 in).
Table 6-2 Card weights and dimensions
Card model
Weight
Height
Width
Depth
LSUM1SUPXD0
2.80 kg (6.17 lb)
40 mm (1.57 in)
399 mm (15.71 in)
352 mm (13.86 in)
LSUM1SUPXES0
3.00 kg (6.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
352 mm (13.86 in)
LSUM1MPUS06XEC0
2.20 kg (4.85 lb)
40 mm (1.57 in)
292 mm (11.50 in)
318 mm (12.52 in)
LSUM1MPUS06XEB0
2.05 kg (4.52 lb)
40 mm (1.57 in)
292 mm (11.50 in)
318 mm (12.52 in)
LSUM1MPUS10XE0
3.75 kg (8.27 lb)
40 mm (1.57 in)
463 mm (18.23 in)
318 mm (12.52 in)
LSUM1MPUS10XEA0
2.95 kg (6.50 lb)
40 mm (1.57 in)
463 mm (18.23 in)
318 mm (12.52 in)
LSUM1FAB06XEC0
2.10 kg (4.63 lb)
40 mm (1.57 in)
292 mm (11.50 in)
318 mm (12.52 in)
LSUM1FAB06XEB0
1.95 kg (4.30 lb)
40 mm (1.57 in)
292 mm (11.50 in)
318 mm (12.52 in)
LSUM1FAB08XE0
2.73 kg (6.02 lb)
40 mm (1.57 in)
433 mm (17.05 in)
318 mm (12.52 in)
LSUM1FAB08XEB0
2.70 kg (5.95 lb)
40 mm (1.57 in)
433 mm (17.05 in)
318 mm (12.52 in)
LSUM1FAB10XE0
3.55 kg (7.83 lb)
40 mm (1.57 in)
463 mm (18.23 in)
318 mm (12.52 in)
LSUM1FAB10XEA0
2.80 kg (6.17 lb)
40 mm (1.57 in)
463 mm (18.23 in)
318 mm (12.52 in)
LSUM1FAB16XD0
9.15 kg (20.17 lb)
40 mm (1.57 in)
961 mm (37.83 in)
298 mm (11.73 in)
LSUM1YGS24CSSH0
3.45 kg (7.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1CGS20XSH0
3.75 kg (8.27 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1CGS8QSSH0
3.30 kg (7.28 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1CGS8SH0
3.10 kg (6.83 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1CGS32XSH0
4.45 kg (9.81 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM2CQGS12SG0
3.20 kg (7.05 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1CQGS12XSG0
3.20 kg (7.05 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1CQGS32SF0
3.83 kg (8.44 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1CGS2FE0
2.82 kg (6.22 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM2TGS32QSSG0
3.50 kg (7.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM2QGS24RSG0
3.40 kg (7.50 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM2QGS12SG0
3.40 kg (7.50 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1QGS6EC0
3.95 kg (8.71 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1YGS48XSH0
3.75 kg (8.27 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM2GT24PTSSE0
2.80 kg (6.17 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM2GT24TSSE0
2.60 kg (5.73 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1TGS48SH0
3.55 kg (7.83 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1TGS48RSH0
3.55 kg (7.83 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1TGS48XSG0
3.29 kg (7.25 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM2TGS48SG0
3.55 kg (7.83 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1GP40TS8FD0
3.20 kg (7.05 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM2GP40TS8FD0
3.20 kg (7.05 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM2GP44TSSE0
3.00 kg (6.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM2GP24TSSE0
2.85 kg (6.28 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1TGS24FD0
3.05 kg (6.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1TGS16FD0
2.91 kg (6.42 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1TGS24EC0
4.15 kg (9.15 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1GP48FD0
3.10 kg (6.83 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1TGT24FD0
3.40 kg (7.50 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1GT48FD0
3.45 kg (7.61 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM2GT48SE0
2.71 kg (5.97 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1FWDEC0
3.80 kg (8.38 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1NSDEC0
3.80 kg (8.38 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1WCMX20RT
4.00 kg (8.82 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1WCMX40RT
4.00 kg (8.82 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1ACGDEC0
3.80 kg (8.38 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1EPSB0
3.25 kg (7.16 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1SDNB0
3.25 kg (7.16 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
LSUM1WBCZ720XRT
3. 5 kg (7.72 lb)
40 mm (1.57 in)
399 mm (15.71 in)
355 mm (13.98 in)
Card dimensions are expressed as follows:
·     H—Height of the front panel of the card.
·     W—Width of the front panel of the card.
·     D—Depth from the front panel of the card to the connector.
Table 6-3 Power module weights and dimensions
Model
Weight
Height
Width
Depth
LSUM1AC1200
2.27 kg (5.00 lb)
41 mm (1.61 in)
102 mm (4.02 in)
400 mm (15.75 in)
LSUM2AC2500
2.50 kg (5.51 lb)
41 mm (1.61 in)
102 mm (4.02 in)
400 mm (15.75 in)
LSUM1DC2400
2.40 kg (5.29 lb)
41 mm (1.61 in)
102 mm (4.02 in)
400 mm (15.75 in)
Table 6-4 Fan tray weights and dimensions
Fan tray
Weight
Height
Width
Depth
S10506X master fan tray
3.95 kg (8.71 lb)
66 mm (2.60 in)
291 mm (11.46 in)
643 mm (25.32 in)
S10506X standby fan tray
1.60 kg (3.53 lb)
40 mm (1.57 in)
291 mm (11.46 in)
300 mm (11.81 in)
S10508X master fan tray
6.85 kg (15.10 lb)
66 mm (2.60 in)
433 mm (17.05 in)
645 mm (25.39 in)
S10508X standby fan tray
1.85 kg (4.08 lb)
40 mm (1.57 in)
432 mm (17.01 in)
300 mm (11.81 in)
S10508X-V fan tray
7.40 kg (16.31 lb)
49 mm (1.93 in)
440 mm (17.32 in)
618 mm (24.33 in)
S10510X master fan tray
6.55 kg (14.44 lb)
66 mm (2.60 in)
463 mm (18.23 in)
645 mm (25.39 in)
S10510X standby fan tray
2.25 kg (4.96 lb)
40 mm (1.57 in)
463 mm (18.23 in)
301 mm (11.85 in)
S10516X fan tray
1.35 kg (2.98 lb)
81 mm (3.19 in)
191 mm (7.52 in)
159 mm (6.26 in)
Module power consumption and system power consumption
Card power consumption
The power consumption of the cards depends on the card model and state.
·     Static power consumption (min)—Power consumed by the card when the card is running but all ports on the card are down and when no transceiver module is available on the optical interface of the card.
·     Dynamic power consumption (max)—Power consumed by the card when all the ports on the card are link up and send broadcasts.
Table 6-5 Card power consumption
Model
LSUM1SUPXD0
32 W
47 W
LSUM1SUPXES0
28 W
42 W
LSUM1MPUS06XEC0
74 W
135 W
LSUM1MPUS06XEB0
66 W
109 W
LSUM1MPUS10XE0
139 W
240 W
LSUM1MPUS10XEA0
73 W
111 W
LSUM1FAB06XEC0
69 W
119 W
LSUM1FAB06XEB0
56 W
95 W
LSUM1FAB08XE0
123 W
183 W
LSUM1FAB08XEB0
65 W
122 W
LSUM1FAB10XE0
112 W
216 W
LSUM1FAB10XEA0
69 W
95 W
LSUM1FAB16XD0
121 W
207 W
LSUM1YGS24CSSH0
68 W
161 W
LSUM1CGS20XSH0
126 W
285 W
LSUM1CGS8QSSH0
72 W
183 W
LSUM1CGS8SH0
58 W
138 W
LSUM1CGS32XSH0
200 W
530 W
LSUM2CQGS12SG0
55 W
147 W
LSUM1CQGS12XSG0
75 W
153 W
LSUM1CQGS32SF0
115 W
320 W
LSUM1CGS2FE0
55 W
77 W
LSUM2TGS32QSSG0
60 W
147 W
LSUM2QGS24RSG0
65 W
198 W
LSUM2QGS12SG0
76 W
163 W
LSUM1QGS6EC0
142 W
183 W
LSUM1YGS48XSH0
152 W
251 W
LSUM2GT24PTSSE0
38 W
60 W
LSUM2GT24TSSE0
35 W
45 W
LSUM1TGS48SH0
54 W
130 W
LSUM1TGS48RSH0
47 W
109 W
LSUM1TGS48XSG0
63 W
155 W
LSUM2TGS48SG0
82 W
173 W
LSUM1GP40TS8FD0
47 W
96 W
LSUM2GP40TS8FD0
45 W
84 W
LSUM2GP44TSSE0
39 W
70 W
LSUM2GP24TSSE0
36 W
55 W
LSUM1TGS24FD0
50 W
104 W
LSUM1TGS16FD0
54 W
96 W
LSUM1TGS24EC0
153 W
209 W
LSUM1GP48FD0
49 W
78 W
LSUM1TGT24FD0
60 W
112 W
LSUM1GT48FD0
48 W
65 W
LSUM2GT48SE0
37 W
51 W
LSUM1FWDEC0
156 W
170 W
LSUM1NSDEC0
156 W
170 W
LSUM1WCMX20RT
125 W
180 W
LSUM1WCMX40RT
125 W
180 W
LSUM1ACGDEC0
157 W
170 W
LSUM1EPSB0
106 W
126 W
LSUM1SDNB0
106 W
126 W
LSUM1WBCZ720XRT
160 W
210 W
Fan tray power consumption
The switch uses fan trays that can automatically adjust the fan speed based on the heat dissipation condition of the switch. The power consumed by a fan tray depends on the fan speed. Table 6-6 shows the power consumption of different fan trays.
Table 6-6 Fan tray power consumption
Model
Minimum fan tray power consumption
Maximum fan tray power consumption
20 W
193 W
10 W
61 W
21 W
255 W
16 W
55 W
S10508X-V
18 W
320 W
26 W
303 W
10 W
61 W
S10516X
5 W
155 W
Power consumption
The total power consumption of the switch equals its system power consumption.
System power consumption
The system power consumption of the switch depends on the type and number of cards and the fan tray power consumption.
·     The minimum system power consumption is the total static power consumption of all cards plus the minimum fan tray power consumption. For example, for an S10508X-V switch that has two LSUM1SUPXD0 MPUs, two LSUM1CGS2FE0 service modules, two LSUM1FAB08XE0 switching fabric modules, and one S10508X-V fan tray, the minimum system power consumption of the switch is 2 × 32 + 2 × 55 + 2 × 123 + 18 = 438 W.
·     The maximum system power consumption is the total dynamic power consumption of all cards plus the maximum fan tray power consumption. For example, for an S10508X-V switch that has two LSUM1SUPXD0 MPUs, two LSUM1CGS2FE0 service modules, two LSUM1FAB08XE0 switching fabric modules, and one S10508X-V fan tray, the maximum system power consumption of the switch is 2 × 47 + 2 × 77 + 2 × 183 + 320 = 934 W.
Table 6-7 lists the max power consumption for an S10500X switch in full and max configuration.
·     Max system power consumption (full and max configuration)Max system power consumption when the switch is fully configured with cards and fan trays that have the highest power consumptions.
·     Max card and fan tray power consumption (full and max configuration)Max card and fan tray power consumption when the switch is fully configured with cards and fan trays that have the highest power consumptions.
Table 6-7 Max system/Max card and fan tray power consumption in full and max configuration
Model
S10506X-AC
4580 W
4061 W
S10506X-DC
4560 W
4061 W
S10508X-AC
6270 W
5559 W
S10508X-DC
6240 W
5559 W
S10508X-V-AC
6650 W
5889 W
S10508X-V-DC
6610 W
5889 W
S10510X-AC
7670 W
6792 W
S10510X-DC
7630 W
6792 W
S10516X-AC
13470 W
11934 W
S10516X-DC
13400 W
11934 W
Heat dissipation
Heat dissipation is measured in BTU/h, and 1 W equals 3.4121 BTU/h.
The heat dissipation of a switch depends on its power consumption. To calculate heat dissipation of the switch, assume 90% power consumption is converted to heat, and the efficiency of the power module is 90%. Heat dissipation/hour of the switch is 0.9 × (total power consumption of the cards plus power consumption of the fan tray)/0.9 × 3.4121.
Table 6-8 Heat dissipation
Model
Heat dissipation (BTU/h)
S10506X
13857
S10508X
18969
S10508X-V
20095
S10510X
23177
S10516X
40723
For the power consumption of the cards and fan trays of the H3C S10500X Switch Series, see "Module power consumption and system power consumption."
Environmental specifications
Table 6-9 Environmental specifications
Item
Operating environment
Storage environment
Temperature
0°C to 45°C (32°F to 113°F)
–40°C to +70°C (–40°F to +158°F)
Relative humidity
5% to 95% (non-condensing)
Noise
The switch uses fan trays that can adjust the fan speed automatically based on the device temperature. The sound pressure levels vary by fan speed. For more information, see Table 6-10.
Table 6-10 Sound pressure levels
Model
Sound pressure level in the acceptable temperature range
Sound pressure level when the fan tray operates at full speed
S10506X
56.1 dBA
73.3 dBA
S10508X
67.5 dBA
72.9 dBA
S10508X-V
65.6 dBA
73.1 dBA
S10510X
66.2 dBA
75.5 dBA
S10516X
67.0 dBA
91.0 dBA
