- 04-Layer 3-IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-IP forwarding basics commands
- 06-Fast forwarding commands
- 07-Adjacency table commands
- 08-IRDP commands
- 09-IP performance optimization commands
- 10-UDP helper commands
- 11-IPv6 basics commands
- 12-DHCPv6 commands
- 13-IPv6 fast forwarding commands
- 14-Tunneling commands
- 15-GRE commands
02-IP addressing commands | 67.28 KB |
display ip interface
Use display ip interface to display IP configuration and statistics for Layer 3 interfaces.
display ip interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IP configuration and statistics for all Layer 3 interfaces.
Use the display ip interface command to display IP configuration and statistics for the specified Layer 3 interface. The statistics include the following information:
· The number of unicast packets, bytes, and multicast packets the interface has sent and received.
· The number of TTL-invalid packets and ICMP packets the interface has received.
The packet statistics helps you locate a possible attack on the network.
# Display IP configuration and statistics for VLAN-interface 10.
<Sysname> display ip interface vlan-interface 10
Vlan-interface10 current state : DOWN
Line protocol current state : DOWN
Internet Address is 1.1.1.1/8 Primary
Broadcast address : 1.255.255.255
The Maximum Transmit Unit : 1500 bytes
input packets : 0, bytes : 0, multicasts : 0
output packets : 0, bytes : 0, multicasts : 0
TTL invalid packet number: 0
Echo reply: 0
Unreachable: 0
Source quench: 0
Routing redirect: 0
Echo request: 0
Router advert: 0
Router solicit: 0
Time exceed: 0
IP header bad: 0
Timestamp request: 0
Timestamp reply: 0
Information request: 0
Information reply: 0
Netmask request: 0
Netmask reply: 0
Unknown type: 0
current state |
Physical link state of the interface: · Administrative DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
Line protocol current state |
Data link layer state of the interface. · DOWN—The data link layer protocol is down. · UP—The data link layer protocol is up. · UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. |
Internet Address |
IP address of an interface followed by: · Primary—A primary IP address. · Sub—A secondary IP address. · MTunnel—An MTunnel interface IP address. · SSLVPN—An SSL VPN interface IP address. · Unnumbered—An unnumbered IP address. · DHCP-Allocated—An IP address obtained through DHCP. · BOOTP-Allocated—An IP address obtained through BOOTP. · Mad—A MAD IP address. · IRF-Member—IP address of the management Ethernet port of an IRF member device. |
Broadcast address |
Broadcast address of the subnet attached to an interface. |
The Maximum Transmit Unit |
MTU of the interface, in bytes. |
input packets, bytes, multicasts output packets, bytes, multicasts |
All received and sent packets and bytes, and received and sent multicast packets on an interface (statistics start at the device startup). |
TTL invalid packet number |
Number of TTL-invalid packets received on the interface (statistics start at the device startup). |
ICMP packet input number: Echo reply: Unreachable: Source quench: Routing redirect: Echo request: Router advert: Router solicit: Time exceed: IP header bad: Timestamp request: Timestamp reply: Information request: Information reply: Netmask request: Netmask reply: Unknown type: |
Total number of ICMP packets received on the interface (statistics start at the device startup): · Echo reply packets. · Unreachable packets. · Source quench packets. · Routing redirect packets. · Echo request packets. · Router advertisement packets. · Router solicitation packets. · Time exceeded packets. · IP header bad packets. · Timestamp request packets. · Timestamp reply packets. · Information request packets. · Information reply packets. · Netmask request packets. · Netmask reply packets. · Unknown type packets. |
display ip interface brief
ip address
Use display ip interface brief to display brief IP configuration for Layer 3 interfaces.
display ip interface [ interface-type [ interface-number ] ] brief [ description ]
interface-type: Specifies an interface type. If you do not specify an interface type, this command displays brief IP configuration for all Layer 3 interfaces.
interface-number: Specifies an interface number. If you do not specify an interface number, this command displays brief IP configuration for all Layer 3 interfaces of the specified type.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays a maximum of 13 characters for each interface description. If the description is longer than 13 characters, the first 10 characters are displayed, followed by an ellipsis (...).
Information displayed by the command includes the state of the physical and link layer protocols, IP address, and interface descriptions.
# Display brief IP configuration for VLAN interfaces.
<Sysname> display ip interface vlan-interface brief
*down: administratively down
(s): spoofing (l): loopback
Interface Physical Protocol IP address VPN instance Description
Vlan10 down down 6.6.6.1 -- Link to Co...
Vlan2 down down 7.7.7.1 vpn-first... --
<Sysname> display ip interface vlan-interface brief description
Vlan10 down down 6.6.6.1 -- Link to CoreR
Outer
Vlan2 down down 7.7.7.1 vpn-first-in --
stance
*down: administratively down |
The interface is administratively shut down by using the shutdown command. |
(s) : spoofing |
Spoofing attribute of the interface. The link protocol state of the interface is up, but the link is temporarily established on demand or does not exist. |
Interface name. |
Physical |
Physical state of the interface: · *down—The interface is administratively shut down by using the shutdown command. · down—The interface is administratively up but its physical state is down, possibly because of a connection or link failure. · up—Both the administrative and physical states of the interface are up. |
Protocol |
Link layer protocol state of the interface: · down—The protocol state of the interface is down. · down(l)—The protocol state of the interface is down (loopback). · up—The protocol state of the interface is up. · up(l)—The protocol state of the interface is up (loopback). · up(s)—The protocol state of the interface is up (spoofing). |
IP address |
IP address of the interface. If no IP address is configured, this field displays hyphens (--). |
VPN instance |
Name of the VPN instance to which the interface belongs. This field displays a maximum of 12 characters. If the VPN instance name is longer than 12 characters, the first 9 characters are displayed, followed by an ellipsis (...). If the interface does not belong to any VPN instance, this field displays hyphens (--). |
Description of the interface. This field displays a maximum of 13 characters. If the description is longer than 13 characters, the first 10 characters are displayed, followed by an ellipsis (...). If no description is configured, this field displays hyphens (--). |
ip address
ip address
Use ip address to assign an IP address to the interface.
Use undo ip address to remove the IP address from the interface.
ip address ip-address { mask-length | mask } [ irf-member member-id | sub ]
undo ip address ip-address { mask-length | mask } [ irf-member member-id | sub ]
No IP address is assigned to an interface.
Interface view
ip-address: Specifies the IP address of the interface, in dotted decimal notation.
mask-length: Specifies the subnet mask length in the range of 1 to 31. For a loopback interface, the value range is 1 to 32.
mask: Specifies the subnet mask in dotted decimal notation.
irf-member member-id: Assigns an IP address to the management Ethernet port of the specified IRF member device. The member-id argument specifies an IRF member device by its member ID. The value range for the member-id argument is 1 to 8.
sub: Assigns a secondary IP address to the interface.
Use the command to assign a primary or secondary IP address to an interface.
An interface can have only one primary IP address. A newly configured primary IP address overwrites the previous address. If the interface connects to multiple subnets, configure primary and secondary IP addresses on the interface so the subnets can communicate with each other through the interface.
You cannot assign secondary IP addresses to an interface that obtains an IP address through BOOTP IP unnumbered, or DHCP.
If you do not specify any parameters, the undo ip address command removes all IP addresses from the interface. The undo ip address ip-address { mask | mask-length } command removes the primary IP address. The undo ip address ip-address { mask | mask-length } sub command removes a secondary IP address.
The primary and secondary IP addresses assigned to the interface can be located on the same network segment. Different interfaces on your device must reside on different network segments.
If you assign IP addresses to the management Ethernet ports of IRF member devices, make sure the following requirements are met:
· The IP addresses must be in the same subnet if you assign them through the same management Ethernet port of the master device.
· The IP addresses must be in different subnets if you assign them through different management Ethernet ports of the master device.
In an IRF fabric, only the IP address assigned to the management Ethernet port of the master takes effect. Make sure no IP address conflict exists when you assign IP addresses to the management Ethernet ports of subordinates. The system does not warn of an IP address conflict because the IP addresses assigned to the management Ethernet ports of subordinates do not take effect. After an IRF fabric split, the IP addresses assigned to the management Ethernet ports of the new masters (original subordinates) take effect.
# Assign VLAN-interface 10 a primary IP address 129.12.0.1 and a secondary IP address 202.38.160.1, with subnet masks both 255.255.255.0.
[Sysname-Vlan-interface10] ip address 129.12.0.1 255.255.255.0
[Sysname-Vlan-interface10] ip address 202.38.160.1 255.255.255.0 sub
ip address unnumbered
Use ip address unnumbered to configure the current interface as IP unnumbered to borrow an IP address from the specified interface.
Use undo ip address unnumbered to restore the default.
The interface does not borrow IP addresses from other interfaces.
Interface view
interface interface-type interface-number: Specifies an interface from which the current interface can borrow an IP address.
Typically, you assign an IP address to an interface either manually or through DHCP. If the IP addresses are not enough, or the interface is used only occasionally, you can configure an interface to borrow an IP address from other interfaces. This is called IP unnumbered, and the interface borrowing the IP address is called IP unnumbered interface.
Loopback interfaces cannot borrow IP addresses of other interfaces, but other interfaces can borrow IP addresses of loopback interfaces.
Multiple interfaces can use the same unnumbered IP address. If an interface has multiple manually configured IP addresses, only the primary IP address manually configured can be borrowed.
You cannot enable a dynamic routing protocol on the interface that has no IP address configured. To enable the interface to communicate with other devices, you must configure a static route to the peer device on the interface.
# Configure the interface Tunnel 1 to borrow the IP address of VLAN-interface 10.
[Sysname-Vlan-interface10] ip address unnumbered interface vlan-interface 100
