01-Fundamentals Command Reference
HomeSupportResource CenterSwitchesH3C S6890 Switch SeriesH3C S6890 Switch SeriesTechnical DocumentsCommandCommand ReferencesH3C S6890 Switch Series Command References(R27xx)-6W10301-Fundamentals Command Reference
00-Preface
00-Preface 100.85 KB
Preface
This command reference describes commands that help you get started with the switch, including:
·     CLI and emergency shell.
·     RBAC, switch login, and switch access control.
·     Management of the switch, file systems, configuration files, and licenses.
·     FTP and TFTP.
·     Tcl and Python.
·     ISSU and common software upgrade.
·     Preprovisioning.
·     Audience
·     Conventions
·     Documentation feedback
Audience
·     Network planners.
·     Network administrators working with the S6890 switch series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
