01-OAP module configuration | 52.57 KB |
Restrictions: Hardware compatibility with OAP modules
Logging in through the console port on the OAP module
Logging in from the CLI of the device
Configuring the OAP module
About OAP modules
OAP is a hardware platform based on OAA. OAP uses a manager/client model. The OAP client can be a network device or an OAP module. An OAP module can be an expansion card installed in a network device or an integrated part of a network device.
OAP modules have their own operating systems. You can log in to the operating system of an OAP module to install features. For example, you can install security features and voice features on the OAP module operating system to provide security and voice services for users.
OAP modules exchange data, status information, and control information with hosting devices through internal interfaces.
OAP provides an open interface for third-party vendors to develop and integrate value-added applications into H3C products.
The device supports this feature only when HMIM-OAP interface modules are installed.
Logging in to an OAP module
1. Connect one end of the console cable to the serial port of the configuration terminal (for example, a PC).
2. Connect the other end of the console cable to the console port of the OAP module.
3. Start the PC and run a terminal emulation program, such as HyperTerminal.
4. Select the COM connection mode and set the terminal parameters as follows:
¡ Bits per second—9600.
¡ Data bits—8.
¡ Parity check mode—None.
¡ Stop bits—1.
¡ Flow control—None.
5. Follow the OAP module user guide to log in to the operating system of the OAP module through the terminal emulation program.
From the CLI of the device, you can log in to the CLI of the OAP module. To return to the CLI of the device, press Ctrl+K.
To log in to an OAP module from the CLI of the device, execute one of the following commands in user view:
In standalone mode:
oap connect slot slot-number [ system system-name ]
In IRF mode:
oap connect chassis chassis-number slot slot-number [ system system-name ]
Resetting OAP modules
You can reset an OAP module to restore it to normal operation in the following situations:
· The OAP module fails.
· The OAP module is not operating correctly. For example, the OAP module does not respond to your operation.
Pressing the reset button of the OAP module has the same effect. The device can still identify and control the OAP module after the module starts up again.
Resetting an OAP module might cause a service outage. To avoid service data loss, close the operating system of an OAP module before resetting the module.
To reset an OAP module, execute one of the following commands in user view:
In standalone mode:
oap reboot slot slot-number [ system system-name ]
In IRF mode:
oap reboot chassis chassis-number slot slot-number [ system system-name ]
