01-VXLAN commands | 243.18 KB |
selective-flooding mac-address
vxlan invalid-udp-checksum discard
arp distributed-gateway dynamic-entry synchronize
display interface vsi-interface
VXLAN commands
Basic VXLAN commands
arp suppression enable
Use arp suppression enable to enable ARP flood suppression.
Use undo arp suppression enable to disable ARP flood suppression.
ARP flood suppression is disabled.
VSI view
ARP flood suppression reduces ARP request broadcasts by enabling the VTEP to reply to ARP requests on behalf of VMs.
This feature snoops ARP packets to populate the ARP flood suppression table with local and remote MAC addresses. If an ARP request has a matching entry, the VTEP replies to the request on behalf of the VM. If no match is found, the VTEP floods the request to both local and remote sites.
# Enable ARP flood suppression for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression enable
display arp suppression vsi
reset arp suppression vsi
description
Use description to configure a description for a VSI.
A VSI does not have a description.
VSI view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
display l2vpn vsi
Use display arp suppression vsi to display ARP flood suppression entries.
In standalone mode:
display arp suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
In IRF mode:
display arp suppression vsi [ name vsi-name ] [ chassis chassis-number slot slot-number ] [ count ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays entries for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays entries on the global active MPU. (In IRF mode.)
count: Displays the number of ARP flood suppression entries that match the command.
# Display ARP flood suppression entries.
<Sysname> display arp suppression vsi
IP address MAC address Vsi Name Link ID Aging
1.1.1.2 000f-e201-0101 vsi1 0x70000 14
1.1.1.3 000f-e201-0202 vsi1 0x80000 18
1.1.1.4 000f-e201-0203 vsi2 0x90000 10
# Display the number of ARP flood suppression entries.
<Sysname> display arp suppression vsi count
Total entries: 3
Link ID |
Link ID that uniquely identifies an AC or a VXLAN tunnel on a VSI. |
Aging |
Remaining lifetime (in minutes) of the ARP flood suppression entry. When the timer expires, the entry is deleted. |
display l2vpn interface
Use display l2vpn interface to display L2VPN information for Layer 3 interfaces that are mapped to VSIs.
display l2vpn interface [ vsi vsi-name | interface-type interface-number ] [ verbose ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters.
verbose: Displays detailed information about Layer 3 interfaces. If you do not specify this keyword, the command displays brief information about Layer 3 interfaces.
If you do not specify any parameters, this command displays brief L2VPN information for all Layer 3 interfaces that are mapped to VSIs.
# Display brief L2VPN information for all Layer 3 interfaces that are mapped to VSIs.
<Sysname> display l2vpn interface
Total number of interfaces: 2, 1 up, 1 down
Interface Owner Link ID State Type
GE1/0/1 vxlan3 1 Up VSI
GE1/0/2 vxlan4 2 Down VSI
Layer 3 interface name. |
Owner |
VSI name. |
Link ID |
The interface's link ID on the VSI. |
State |
Physical state of the interface: · Up—The interface is physically up. · Down—The interface is physically down. |
Type |
L2VPN type of the interface. This field displays VSI for the VXLAN feature. |
# Display detailed L2VPN information for all Layer 3 interfaces that are mapped to VSIs.
<Sysname> display l2vpn interface verbose
Interface: GE1/0/1
Owner : vsi1
Link ID : 0
State : Up
Type : VSI
Interface: GE1/0/2
Owner : vsi2
Link ID : 0
State : Down
Type : VSI
Owner |
VSI name. |
Link ID |
State |
Type |
display l2vpn mac-address
Use display l2vpn mac-address to display MAC address entries for VSIs.
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC address entries for all VSIs.
dynamic: Specifies dynamic MAC address entries learned in the data plane. If you do not specify this keyword, the command displays all MAC address entries, including:
· Dynamic remote- and local-MAC entries.
· Remote-MAC entries advertised through BGP EVPN.
· Manually added static remote-MAC entries.
· Remote-MAC entries issued through OpenFlow.
VXLAN does not support static local-MAC entries.
count: Displays the number of MAC address entries. If you do not specify this keyword, the command displays detailed information about MAC address entries.
# Display MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address
MAC Address State VSI Name Link ID/Name Aging
0000-0000-000b Static vpn1 Tunnel10 NotAging
0000-0000-000c Dynamic vpn1 Tunnel60 Aging
0000-0000-000d Dynamic vpn1 Tunnel99 Aging
--- 3 mac address(es) found ---
# Display the total number of MAC address entries in all VSIs.
<Sysname> display l2vpn mac-address count
State |
Entry state: · Dynamic—Local- or remote-MAC entry dynamically learned in the data plane. · Static—Static remote-MAC entry. · EVPN—Remote-MAC entry advertised through BGP EVPN. · OpenFlow—Remote-MAC entry issued by a remote controller through OpenFlow. |
Link ID/Name |
For a local MAC address, this field displays the AC's link ID on the VSI. For a remote MAC address, this field displays the tunnel interface name. |
Aging |
Entry aging state: · Aging. · NotAging. |
reset l2vpn mac-address
display l2vpn vsi
Use display l2vpn vsi to display information about VSIs.
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about all VSIs.
verbose: Displays detailed information about VSIs. If you do not specify this keyword, the command displays brief information about VSIs.
# Display brief information about all VSIs.
<Sysname> display l2vpn vsi
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name VSI Index MTU State
vpna 0 1500 Up
Table 5 Command output
MTU |
MTU on the VSI. |
State |
VSI state: · Up—The VSI is up. · Down—The VSI is down. · Admin down—The VSI has been manually shut down by using the shutdown command. |
# Display detailed information about all VSIs.
<Sysname> display l2vpn vsi verbose
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
Broadcast Restrain : 5120 kbps
Multicast Restrain : 5120 kbps
Unknown Unicast Restrain: 5120 kbps
MAC Learning : Enabled
MAC Table Limit : -
Drop Unknown : Disabled
PW Redundancy : Slave
Flooding : Enabled
Service Class : -
Gateway Interface : VSI-interface 100
VXLAN ID : 10
Tunnel Statistics : Disabled
Tunnels:
Tunnel Name Link ID State Type Flood Proxy Split horizon
Tunnel1 0x5000001 Up Manual Disabled Enabled
Tunnel2 0x5000002 Up Manual Disabled Enabled
ACs:
AC Link ID State
GE1/0/1 0 Up
Table 6 Command output
VSI Description |
Description of the VSI. If the VSI does not have a description, the command does not display this field. |
VSI State |
VSI state: · Up—The VSI is up. · Down—The VSI is down. · Administratively down—The VSI has been manually shut down by using the shutdown command. |
MTU |
MTU on the VSI. |
Bandwidth |
Maximum bandwidth (in kbps) for known unicast traffic on the VSI. This field displays a hyphen (-) if it is not available in the current software version. |
Broadcast Restrain |
Broadcast restraint bandwidth (in kbps). This field displays a hyphen (-) if it is not available in the current software version. |
Multicast Restrain |
Multicast restraint bandwidth (in kbps). This field displays a hyphen (-) if it is not available in the current software version. |
Unknown Unicast Restrain |
Unknown unicast restraint bandwidth (in kbps). This field displays a hyphen (-) if it is not available in the current software version. |
MAC Learning |
State of the MAC learning feature. |
MAC Table Limit |
Maximum number of MAC address entries on the VSI. This field displays a hyphen (-) if it is not available in the current software version. |
Drop Unknown |
Action on source MAC-unknown frames received after the maximum number of MAC entries is reached. · Enabled—Drops the frames. · Disabled—Forwards the frames without learning the source MAC address. |
Flooding |
State of the VSI's flooding feature: · Enabled—Flooding is enabled on the VSI. The VTEP floods unknown unicast frames to both local and remote sites. · Disabled—Flooding is disabled on the VSI. The VTEP floods unknown unicast frames only to local sites. |
Service Class |
Service class value of outgoing VXLAN packets. This field displays a hyphen (-) if it is not available in the current software version. |
Gateway Interface |
VSI interface name. |
Tunnel Statistics |
Packet statistics state: · Enabled—The packet statistics feature is enabled for the VXLAN tunnels of the VSI. · Disabled—The packet statistics feature is disabled for the VXLAN tunnels of the VSI. |
State |
Tunnel state: · Up—The tunnel is operating correctly. · Blocked—The tunnel is a backup proxy tunnel. Its tunnel interface is up, but the tunnel is blocked because the primary proxy tunnel is operating correctly. · Defect—The tunnel interface is up, but BFD cannot detect the remote VTEP. This state is not supported in the current software version. · Down—The tunnel interface is down. |
Type |
Tunnel assignment method: · Auto—The tunnel was automatically assigned to the VXLAN through EVPN. · Manual—The tunnel was manually assigned to the VXLAN. |
Flood Proxy |
Flood proxy state: · Enabled—Flood proxy is enabled. The VTEP sends broadcast, multicast, and unknown unicast traffic to a flood proxy server through the tunnel. The flood proxy server replicates and forwards flood traffic to remote VTEPs. · Disabled—Flood proxy is disabled. |
Split horizon |
State of split horizon: · Enabled—Split horizon is enabled on the VXLAN tunnel. The VXLAN tunnel does not forward the traffic that is received on other VXLAN tunnels. · Disabled—Split horizon is disabled on the VXLAN tunnel. The VXLAN tunnel forwards the traffic that is received on ACs and other VXLAN tunnels. |
ACs |
ACs that are bound to the VSI. |
Link ID |
AC's link ID on the VSI. |
State |
AC state: · Up. · Down. |
display vxlan tunnel
Use display vxlan tunnel to display VXLAN tunnel information for VXLANs.
display vxlan tunnel [ vxlan-id vxlan-id [ tunnel tunnel-number ] ]
vxlan-id: Specifies a VXLAN ID in the range of 0 to 16777215. If you do not specify a VXLAN, this command displays VXLAN tunnel information for all VXLANs.
tunnel tunnel-number: Specifies a VXLAN tunnel. The tunnel-number argument represents the tunnel interface number. The value range for the tunnel-number argument is 0 to 10239. If you do not specify a VXLAN tunnel, this command displays information about all VXLAN tunnels associated with the specified VXLAN.
# Display VXLAN tunnel information for all VXLANs.
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
VXLAN ID: 10, VSI name: vpna, Total tunnels: 3 (3 up, 0 down, 0 defect, 0 blocked)
Tunnel name Link ID State Type Flood proxy Split horizon
# Display VXLAN tunnel information for VXLAN 10.
<Sysname> display vxlan tunnel vxlan-id 10
# Display information about VXLAN tunnel 0 for VXLAN 10.
<Sysname> display vxlan tunnel vxlan-id 10 tunnel 0
Interface: Tunnel0
Link ID : 0x5000000
State : Up
Type : Auto
Flood Proxy: Disabled
Statistics : Enabled
Input statistics:
Octets : 994496
Packets: 15539
Output statistics:
Octets : 0
Packets: 0
Table 7 Command output
Link ID |
Tunnel's link ID in the VXLAN. |
State |
Type |
Flood proxy |
Split horizon |
Statistics |
Packet statistics state: · Enabled—The packet statistics feature is enabled for the VXLAN tunnel. · Disabled—The packet statistics feature is disabled for the VXLAN tunnel. |
Input statistics |
Incoming traffic statistics: · Octets—Number of incoming bytes. · Packets—Number of incoming packets. |
Output statistics |
Outgoing traffic statistics: · Octets—Number of outgoing bytes. · Packets—Number of outgoing packets. |
tunnel
vxlan
flooding disable
Use flooding disable to disable flooding for a VSI.
Use undo flooding disable to enable flooding for a VSI.
flooding disable
Flooding is enabled for a VSI.
VSI view
By default, the device floods unknown unicast frames received from the local site to the following interfaces in the frame's VXLAN:
· All site-facing interfaces except for the incoming interface.
· All VXLAN tunnel interfaces.
To confine unknown unicast traffic to the site-facing interfaces, use this command to disable flooding for the VSI bound to the VXLAN. The VSI will not flood unknown unicast frames to VXLAN tunnel interfaces.
# Disable flooding for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] flooding disable
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
You must enable L2VPN before you can configure L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
l2vpn statistics interval
Use l2vpn statistics interval to set the VXLAN statistics collection interval.
Use undo l2vpn statistics interval to restore the default.
l2vpn statistics interval interval
The VXLAN statistics collection interval is 15 minutes.
interval: Specifies an interval value in the range of 30 to 65535 seconds.
# Set the VXLAN statistics collection interval to 30 seconds.
[Sysname] l2vpn statistics interval 30
mac-address static vsi
Use mac-address static vsi to add a static remote-MAC address entry for a VXLAN VSI.
Use undo mac-address static vsi to remove static remote-MAC address entries for a VXLAN VSI.
mac-address static mac-address interface tunnel tunnel-number vsi vsi-name
undo mac-address static [ mac-address ] [ interface tunnel tunnel-number ] vsi vsi-name
VXLAN VSIs do not have static remote-MAC address entries.
mac-address: Specifies a MAC address in H-H-H format. Do not specify a multicast MAC address or an all-zeros MAC address. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001.
interface tunnel tunnel-number: Specifies a VXLAN tunnel interface by its tunnel interface number. The value range for the tunnel-number argument is 0 to 10239.
A remote MAC address is the MAC address of a VM in a remote site. Remote MAC entries include manually added MAC entries, dynamically learned MAC entries, and MAC entries advertised through a protocol, for example, BGP EVPN.
When you add a remote MAC address entry, make sure the specified VSI's VXLAN has been assigned the specified VXLAN tunnel.
The undo mac-address static vsi vsi-name command removes all static MAC address entries for a VSI.
Do not configure static remote-MAC entries for tunnels that are automatically established by using EVPN.
· EVPN re-establishes tunnels if the transport-facing interface goes down and then comes up. If you have configured static remote-MAC entries, the entries are deleted when the tunnels are re-established.
· EVPN re-establishes tunnels if you perform configuration rollback. If the tunnel IDs change during tunnel re-establishment, configuration rollback fails, and static remote-MAC entries on the tunnels cannot be restored.
# Add MAC address 000f-e201-0101 to VSI vsi1. Specify Tunnel-interface 1 as the outgoing interface.
[Sysname] mac-address static 000f-e201-0101 interface tunnel 1 vsi vsi1
mtu
Use mtu to set the MTU for a VSI.
mtu size
undo mtu
The default MTU of a VSI is 1500 bytes.
VSI view
size: Specifies an MTU value. The value range for this argument is 300 to 65535.
The MTU set by using this command limits the maximum length of the packets that a VSI receives from ACs and forwards through VXLAN tunnels. The MTU does not limit the maximum length of other packets in the VXLAN VSI.
Fragmentation is disabled for a VSI that uses the default MTU. If you set a MTU for a VSI, the packets longer than the MTU are fragmented.
# Set the MTU to 1400 bytes for VSI vxlan1.
[Sysname] vsi vxlan1
[Sysname-vsi-vxlan1] mtu 1400
display l2vpn vsi
reserved vxlan
Use reserved vxlan to specify a reserved VXLAN.
Use undo reserved vxlan to restore the default.
reserved vxlan vxlan-id
undo reserved vxlan
No VXLAN has been reserved.
You can specify only one reserved VXLAN on the VTEP. The reserved VXLAN cannot be the VXLAN created on any VSI.
The reserved VXLAN ID cannot be the same as the remote VXLAN ID specified by using the mapping vni command.
# Specify VXLAN 10000 as the reserved VXLAN.
[Sysname] reserved vxlan 10000
mapping vni (EVPN Command Reference)
Use reset arp suppression vsi to clear ARP flood suppression entries on VSIs.
reset arp suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ARP flood suppression entries on all VSIs.
# Clear ARP flood suppression entries on all VSIs.
<Sysname> reset arp suppression vsi
This command will delete all entries. Continue? [Y/N]:y
Use reset l2vpn mac-address to clear dynamic MAC address entries on VSIs.
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears all dynamic MAC address entries on all VSIs.
Use this command when the number of dynamic MAC address entries reaches the limit or the device learns incorrect MAC addresses.
# Clear the dynamic MAC address entries on VSI vpn1.
<Sysname> reset l2vpn mac-address vsi vpn1
display l2vpn mac-address vsi
reset l2vpn statistics tunnel
Use reset l2vpn statistics tunnel to clear packet statistics on VXLAN tunnel interfaces.
reset l2vpn statistics tunnel [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears packet statistics on VXLAN tunnel interfaces of all VSIs.
# Clear packet statistics on VXLAN tunnel interfaces of all VSIs.
<Sysname> reset l2vpn statistics tunnel
tunnel statistics enable
Use selective-flooding mac-address to enable selective flood for a MAC address.
Use undo selective-flooding mac-address to disable selective flood for a MAC address.
selective-flooding mac-address mac-address
undo selective-flooding mac-address mac-address
Selective flood is disabled for all MAC addresses.
VSI view
mac-address: Specifies a MAC address. The MAC address cannot be all Fs.
This command excludes a remote MAC address from the flood suppression done by using the flooding disable command. The VTEP will flood the frames destined for the specified MAC address to remote sites when unknown-unicast floods are confined to the local site.
# Enable selective flood for 000f-e201-0101 on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] selective-flooding mac-address 000f-e201-0101
flooding disable
service-class
Use service-class to set a service class value for outgoing VXLAN packets.
Use undo service-class to restore the default.
service-class service-class-value
undo service-class
No service class value is set for outgoing VXLAN packets.
VSI view
service-class-value: Specifies a service class value. The value range for this argument is 0 to 15.
Class Based Tunnel Selection (CBTS) compares the service class value of VXLAN packets with the service class values of MPLS TE tunnels. CBTS uses the following rules to select a tunnel to forward the traffic:
· If the packets match only one MPLS TE tunnel, CBTS uses this tunnel.
· If the packets match multiple MPLS TE tunnels, CBTS randomly selects one tunnel from them.
· If the packets do not match any MPLS TE tunnel, CBTS selects the MPLS TE tunnel that meets the following requirements:
¡ Its service class value is smaller than the service class value of the traffic.
¡ Its service class value is the nearest to the service class value of the traffic.
If multiple qualified tunnels exist, CBTS randomly selects one of them to forward the packets. If an MPLS TE tunnel is not configured with a service class value, this tunnel has the smallest service class value.
The service class value is used only when MPLS TE tunnels are used to forward the VXLAN packets. This value is meaningless if any other tunnel is used to forward the VXLAN packets.
To set the service class value for an MPLS TE tunnel, use the mpls te service-class command. For more information about this command, see MPLS TE commands in MPLS Command Reference.
If you execute the service-class command multiple times for a VSI, the most recent configuration takes effect.
# Set the service class value to 2 for outgoing VXLAN packets.
[Sysname] vsi vpna
[Sysname-vsi-vpna] service-class 2
display l2vpn vsi
shutdown
Use shutdown to shut down a VSI.
Use undo shutdown to bring up a VSI.
shutdown
VSIs are not manually shut down.
VSI view
Use this command to temporarily disable a VSI to provide Layer 2 switching services. The shutdown action does not change settings on the VSI. You can continue to configure the VSI. After you bring up the VSI again, the VSI provides services based on the latest settings.
# Shut down VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
display l2vpn vsi
tunnel
Use tunnel to assign a VXLAN tunnel to a VXLAN.
Use undo tunnel to remove a VXLAN tunnel from a VXLAN.
tunnel tunnel-number { flooding-proxy | no-split-horizon }
undo tunnel tunnel-number
A VXLAN does not contain VXLAN tunnels.
VXLAN view
tunnel-number: Specifies a tunnel interface number. The value range for this argument is 0 to 10239.The tunnel must be a VXLAN tunnel.
flooding-proxy: Enables flood proxy on the tunnel for the VTEP to send flood traffic to the flood proxy server. The flood proxy server replicates and forwards flood traffic to remote VTEPs. If you do not specify this keyword, flood proxy is disabled on the tunnel.
no-split-horizon: Disables split horizon on the tunnel. The tunnel can forward the traffic that is received on ACs and other VXLAN tunnels. If you do not specify this keyword, split horizon is enabled on the tunnel, and it does not forward the traffic that is received on other VXLAN tunnels. You cannot disable split horizon on VXLAN-DCI tunnels.
This command assigns a VXLAN tunnel to a VXLAN to provide Layer 2 connectivity for the VXLAN between two sites. In unicast mode, the system floods unknown unicast, multicast, and broadcast traffic to each tunnel in the VXLAN.
You can assign multiple VXLAN tunnels to a VXLAN, and configure a VXLAN tunnel to trunk multiple VXLANs.
On a VSI, you can enable flood proxy on multiple VXLAN tunnels. The first tunnel that is enabled with flood proxy works as the primary proxy tunnel to forward broadcast, multicast, and unknown unicast traffic. Other proxy tunnels are backups that do not forward traffic when the primary proxy tunnel is operating correctly.
If you disable split horizon on a VXLAN tunnel, make sure the corresponding VXLAN does not have another VXLAN tunnel that is destined for the same remote VTEP.
To modify the flood proxy or split horizon setting on a VXLAN tunnel, you must first use the undo tunnel command to remove the tunnel.
# Assign VXLAN tunnels 1 and 2 to VXLAN 10000.
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
[Sysname-vsi-vpna-vxlan-10000] tunnel 2
tunnel bfd enable
Use tunnel bfd enable to enable BFD on a VXLAN tunnel interface.
Use undo tunnel bfd enable to disable BFD on a VXLAN tunnel interface.
tunnel bfd enable destination-mac mac-address
BFD is disabled on a VXLAN tunnel interface.
VXLAN tunnel interface view
destination-mac mac-address: Specifies a destination MAC address in H-H-H format for BFD control packets. The MAC address can be a remote VTEP address or a multicast address. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001.
Enable BFD on both ends of a VXLAN tunnel for quick link connectivity detection. The VTEPs periodically send BFD single-hop control packets to each other through the VXLAN tunnel. A VTEP sets the tunnel state to Defect if it has not received control packets from the remote end for 5 seconds. In this situation, the tunnel interface state is still Up. The tunnel state will change from Defect to Up if the VTEP can receive BFD control packets again.
# Enable BFD on VXLAN tunnel interface Tunnel 9, and specify 1-1-1 as the destination MAC address for BFD control packets.
[Sysname] interface tunnel 9 mode vxlan
[Sysname-Tunnel9] tunnel bfd enable destination-mac 1-1-1
tunnel global source-address
Use tunnel global source-address to specify a global source address for VXLAN tunnels.
Use undo tunnel global source-address to restore the default.
tunnel global source-address { ipv4-address | ipv6 ipv6-address }
undo tunnel global source-address [ ipv6 ]
No global source address is specified for VXLAN tunnels.
ipv4-address: Specifies an IPv4 address.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify the ipv6 keyword when executing the undo tunnel global source-address command, the command deletes the global source IPv4 address for VXLAN tunnels.
A VXLAN tunnel uses the global source address if you do not specify a source interface or source address for the tunnel.
The global source address takes effect only on VXLAN tunnels (excluding VXLAN-DCI tunnels).
IPv4 VXLAN tunnels use the global source IPv4 address, and IPv6 VXLAN tunnels use the global source IPv6 address.
# Specify 1.1.1.1 as the global source address for VXLAN tunnels.
[Sysname] tunnel global source-address 1.1.1.1
Use tunnel statistics enable to enable packet statistics for all VXLAN tunnels associated with a VSI.
Use undo tunnel statistics enable to disable packet statistics for all VXLAN tunnels associated with a VSI.
The packet statistics feature is disabled for the VXLAN tunnels associated with a VSI.
VSI view
This command enables packet statistics only for VXLAN tunnels. It does not take effect on VXLAN-DCI tunnels.
# Enable packet statistics for all VXLAN tunnels associated with VSI vpna.
[Sysname] vsi vpna
[Sysname-vsi-vpna] tunnel statistics enable
vsi
Use vsi to create a VSI and enter its view, or enter the view of an existing VSI.
Use undo vsi to delete a VSI.
vsi vsi-name
undo vsi vsi-name
No VSIs exist.
A VSI acts as a virtual switch to provide Layer 2 switching services for a VXLAN on a VTEP. A VSI has all functions of a physical Ethernet switch, including source MAC address learning, MAC address aging, and flooding.
A VSI can provide services only for one VXLAN.
# Create VSI vxlan10 and enter VSI view.
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
display l2vpn vsi
vxlan
Use vxlan to create a VXLAN and enter its view, or enter the view of an existing VXLAN.
Use undo vxlan to restore the default.
vxlan vxlan-id
undo vxlan
No VXLANs exist.
VSI view
You can create only one VXLAN for a VSI. The VXLAN ID for each VSI must be unique.
# Create VXLAN 10000 for VSI vpna and enter VXLAN view.
[Sysname] vsi vpna
vsi
vxlan fast-forwarding enable
Use vxlan fast-forwarding enable to enable VXLAN fast forwarding.
Use undo vxlan fast-forwarding enable to disable VXLAN fast forwarding.
VXLAN fast forwarding is disabled.
VXLAN fast forwarding enables the device to bypass QoS and security services when the device forwards data traffic over VXLAN tunnels based on the software. As a best practice, enable this feature to improve forwarding speed only when QoS and security services are not configured on the following interfaces:
· VSI interfaces.
· Traffic outgoing interfaces for VXLAN tunnels.
When VXLAN fast forwarding is enabled, a VXLAN tunnel cannot use ECMP routes to load share traffic. Instead, it selects one route from the ECMP routes to forward VXLAN packets.
# Enable VXLAN fast forwarding.
<Sysname> system
[Sysname] vxlan fast-forwarding enable
Use vxlan invalid-udp-checksum discard to enable the device to drop the VXLAN packets that fail UDP checksum check.
Use undo vxlan invalid-udp-checksum discard to restore the default.
The device does not check the UDP checksum of VXLAN packets.
This command enables the device to check the UDP checksum of VXLAN packets.
The device always sets the UDP checksum of VXLAN packets to 0. For compatibility with third-party devices, a VXLAN packet can pass the check if its UDP checksum is 0 or correct. If its UDP checksum is incorrect, the VXLAN packet fails the check and is dropped.
# Enable the device to drop the VXLAN packets that fail UDP checksum check.
[Sysname] vxlan invalid-udp-checksum discard
vxlan invalid-vlan-tag discard
vxlan ip-forwarding
Use vxlan ip-forwarding to enable Layer 3 forwarding for all VXLANs.
Use undo vxlan ip-forwarding to enable Layer 2 forwarding for all VXLANs.
vxlan ip-forwarding
Layer 3 forwarding is enabled for all VXLANs.
Views.
If the device is a VTEP, enable Layer 2 forwarding for VXLANs. If the device is a VXLAN IP gateway, enable Layer 3 forwarding for VXLANs.
In Layer 3 forwarding mode, the VTEP uses the ARP table (IPv4 network) or ND table (IPv6 network) to forward traffic for VXLANs. In Layer 2 forwarding mode, the VTEP uses the MAC address table to forward traffic for VXLANs.
You must delete all VSIs, VSI interfaces, and VXLAN tunnel interfaces before you can change the forwarding mode.
# Enable Layer 3 forwarding for all VXLANs.
<Sysname>system-view
[Sysname] vxlan ip-forwarding
vxlan local-mac report
Use vxlan local-mac report to enable local-MAC logging.
Use undo vxlan local-mac report to disable local-MAC logging.
Local-MAC logging is disabled.
When the local-MAC logging feature is enabled, the VXLAN module immediately sends a log message with its local MAC addresses to the information center. When a local MAC address is added or removed, a log message is also sent to the information center to notify the local-MAC change.
With the information center, you can set log message filtering and output rules, including output destinations. For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
# Enable local-MAC logging.
[Sysname] vxlan local-mac report
Use vxlan tunnel mac-learning disable to disable remote-MAC address learning.
Use undo vxlan tunnel mac-learning disable to enable remote-MAC address learning.
Remote-MAC address learning is enabled.
When network attacks occur, use this command to prevent the device from learning incorrect remote MAC addresses in the data plane.
# Disable remote-MAC address learning.
[Sysname] vxlan tunnel mac-learning disable
vxlan udp-port
Use vxlan udp-port to set the destination UDP port number for VXLAN packets.
Use undo vxlan udp-port to restore the default.
vxlan udp-port port-number
undo vxlan udp-port
The destination UDP port number is 4789 for VXLAN packets.
port-number: Specifies a UDP port number in the range of 1 to 65535. As a best practice, specify a port number in the range of 1024 to 65535 to avoid conflict with well-known ports.
You must configure the same destination UDP port number on all VTEPs in a VXLAN.
# Set the destination UDP port number to 6666 for VXLAN packets.
[Sysname] vxlan udp-port 6666
xconnect vsi
Use xconnect vsi to map an AC to a VSI.
Use undo xconnect vsi to restore the default.
xconnect vsi vsi-name [ track track-entry-number&<1-3> ]
undo xconnect vsi
An AC is not mapped to any VSI.
Interface view
vsi-name: Specifies the VSI name, a case-sensitive string of 1 to 31 characters.
track track-entry-number&<1-3>: Specifies a space-separated list of up to three track entry numbers in the range of 1 to 1024. The AC is up only if a minimum of one associated track entry is in positive state.
For traffic that matches a Layer 3 interface, the system uses the VSI's MAC address table to make a forwarding decision.
The access mode determines how a VTEP processes the 802.1Q VLAN tags in the inner Ethernet frames assigned to the VSI.
· VLAN access mode—Ethernet frames received from or sent to the local site must contain 802.1Q VLAN tags.
¡ For an Ethernet frame received from the local site, the VTEP removes all its 802.1Q VLAN tags before forwarding the frame.
¡ For an Ethernet frame destined for the local site, the VTEP adds 802.1Q VLAN tags to the frame before forwarding the frame.
In VLAN access mode, VXLAN packets sent between VXLAN sites do not contain 802.1Q VLAN tags. VXLAN can provide Layer 2 connectivity for different 802.1Q VLANs between sites. You can use different 802.1Q VLANs to provide the same service in different sites.
· Ethernet access mode—The VTEP does not process the 802.1Q VLAN tags of Ethernet frames received from or sent to the local site.
¡ For an Ethernet frame received from the local site, the VTEP forwards the frame with the 802.1Q VLAN tags intact.
¡ For an Ethernet frame destined for the local site, the VTEP forwards the frame without adding 802.1Q VLAN tags.
In Ethernet access mode, VXLAN packets sent between VXLAN sites contain 802.1Q VLAN tags. VXLAN cannot provide Layer 2 connectivity for different 802.1Q VLANs between sites. You must use the same 802.1Q VLAN to provide the same service between sites.
After you modify the access mode on a Layer 3 subinterface AC, local VMs that access the VXLAN network through the subinterface cannot communicate with remote VMs. To resolve this issue, you must clear the ARP entries on the local VMs or configure them to periodically send gratuitous ARP packets.
# Map GigabitEthernet 1/0/1 to VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname-GigabitEthernet1/0/1] xconnect vsi vpn1
display l2vpn service-instance
encapsulation
vsi
VXLAN IP gateway commands
Use arp distributed-gateway dynamic-entry synchronize to enable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
Use undo arp distributed-gateway dynamic-entry synchronize to disable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
Dynamic ARP entry synchronization is disabled for distributed VXLAN IP gateways.
When local proxy ARP is enabled on distributed VXLAN IP gateways, each gateway learns ARP information independently. A gateway does not forward ARP packets destined for its local VSI interfaces to other gateways. For distributed VXLAN IP gateways to have the same ARP entries, you must enable dynamic ARP entry synchronization.
A controller or the EVPN feature can also synchronize ARP entries among distributed VXLAN IP gateways. When you use a controller or the EVPN feature, do not enable dynamic ARP entry synchronization.
# Enable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
[Sysname] arp distributed-gateway dynamic-entry synchronize
distributed-gateway local
local-proxy-arp enable (Layer 3—IP Services Command Reference)
bandwidth
Use bandwidth to set the expected bandwidth for a VSI interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth (in kbps) equals the interface baudrate divided by 1000.
VSI interface view
bandwidth-value: Specifies the expected bandwidth, in the range of 1 to 400000000 kbps.
# Set the expected bandwidth to 10000 kbps for VSI-interface 100.
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] bandwidth 10000
default
Use default to restore the default settings for a VSI interface.
default
VSI interface view
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions.
To resolve this problem:
1. Use the display this command in interface view to identify these commands.
2. Use their undo forms or follow the command reference to restore their default settings.
3. If the restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for VSI-interface 100.
[Sysname-Vsi-interface100] default
This command will restore the default settings. Continue? [Y/N]:y
description
Use description to configure the description of a VSI interface.
The description of a VSI interface is interface-name plus Interface (for example, Vsi-interface100 Interface).
VSI interface view
VSI subinterface view
# Configure the description as gateway for VXLAN 10 for VSI-interface 100.
[Sysname-Vsi-interface100] description gateway for VXLAN 10
Use display interface vsi-interface to display information about VSI interfaces.
display interface [ vsi-interface [ vsi-interface-id ] ] [ brief [ description | down ] ]
vsi-interface [ vsi-interface-id ]: Specifies a VSI interface by its number. Make sure the specified VSI interface has been created on the device. If you do not specify the vsi-interface [ vsi-interface-id ] option, this command displays information about all interfaces except for VA interfaces. If you specify only the vsi-interface keyword, this command displays information about all VSI interfaces. If you specify a VSI interface, this command displays information about the specified interface. For more information about VA interfaces, see PPPoE configuration in Layer 2—WAN Access Configuration Guide.
brief: Display brief interface information. If you do not specify this keyword, the command displays detailed interface information.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays interfaces that are physically down as well as the down reason. If you do not specify this keyword, the command does not filter output by physical interface state.
# Display information about VSI-interface 100.
<Sysname> display interface vsi-interface 100
Vsi-interface100
Current state: UP
Line protocol state: UP
Description: Vsi-interface100 Interface
Bandwidth: 1000000 kbps
IP packet frame type: Ethernet II, hardware address: 0011-2200-0102
IPv6 packet frame type: Ethernet II, hardware address: 0011-2200-0102
Table 8 Command output
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down. · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface: · UP—The data link layer protocol is up. · UP(spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. · DOWN—The data link layer protocol is down. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface. |
Maximum transmission unit |
MTU of the interface. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · DHCP-Allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide. · BOOTP-Allocated—BOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3—IP Services Configuration Guide. · PPP-Negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2—WAN Access Configuration Guide. · Unnumbered—IP address borrowed from another interface. · Cellular-Allocated—IP address allocated through the modem manufacturer's proprietary protocol. For more information, see 3G/4G modem management in Layer 2—WAN Access Configuration Guide. · MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide. |
IP packet frame type |
IPv4 packet framing format. |
hardware address |
MAC address. |
IPv6 packet frame type |
IPv6 packet framing format. |
Physical |
Physical type of the interface, which is fixed at Unknown. |
baudrate |
Interface baudrate in kbps. |
Last clearing of counters |
Last time when the reset counters interface vsi-interface command was used to clear interface statistics. This field displays Never if the reset counters interface vsi-interface command has never been used on the interface since the device startup. |
Last 300 seconds input rate |
Average input rate for the last 300 seconds. |
Last 300 seconds output rate |
Average output rate for the last 300 seconds. |
Input: 0 packets, 0 bytes, 0 drops |
Incoming traffic statistics on the interface: · Number of incoming packets. · Number of incoming bytes. · Number of dropped incoming packets. |
Output: 0 packets, 0 bytes, 0 drops |
Outgoing traffic statistics on the interface: · Number of outgoing packets. · Number of outgoing bytes. · Number of dropped outgoing packets. |
# Display brief information about all VSI interfaces.
<Sysname> display interface vsi-interface brief
Protocol: (s) - spoofing
Vsi100 DOWN DOWN --
# Display brief information and complete description for VSI-interface 100.
<Sysname> display interface vsi-interface 100 brief description
Vsi100 UP UP 1.1.1.1 VSI-interface100
# Displays interfaces that are physically down and the down reason.
Interface Link Cause
Vsi100 DOWN Administratively
Vsi200 DOWN Administratively
Table 9 Command output
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · UP (s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. · DOWN—The data link layer protocol of the interface is down. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Cause |
Cause for the physical link state of an interface to be DOWN: · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Not connected—The interface is not mapped to any VSI, or the mapped VSI does not have any AC or VXLAN tunnel. |
Use distributed-gateway local to specify a VSI interface as a distributed gateway to provide services for the local site.
Use undo distributed-gateway local to restore the default.
A VSI interface is not a distributed gateway.
VSI interface view
If a VXLAN uses distributed gateway services, you must assign the same IP address to the VXLAN's VSI interfaces on different VTEPs. To avoid IP address conflicts, you must specify the VSI interface on each VTEP as a distributed gateway.
# Specify VSI-interface 100 as a distributed gateway.
[Sysname-Vsi-interface100] distributed-gateway local
gateway subnet
Use gateway subnet to assign a subnet to a VSI.
Use undo gateway subnet to remove a subnet from a VSI.
gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
undo gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
No subnet is assigned to a VSI.
VSI view
ipv4-address: Specifies an IPv4 subnet address in dotted-decimal notation.
wildcard-mask: Specifies a wildcard mask in dotted decimal notation. In contrast to a network mask, the 0 bits in a wildcard mask represent "do care" bits, and the 1 bits represent "don't care" bits. If the "do care" bits in a packet's IP address are identical to the "do care" bits in the specified subnet address, the packet is assigned to the VSI. All "don't care" bits are ignored. The 0s and 1s in a wildcard mask can be noncontiguous. For example, 0.255.0.255 is a valid wildcard mask.
ipv6-address prefix-length: Specifies an IPv6 subnet address and the address prefix length in the range of 1 to 128.
You must configure this command on VSIs that share a gateway interface. This command enables the VSI interface to identify the VSI of a packet.
You can assign a maximum of eight IPv4 and IPv6 subnets to a VSI.
You must specify a gateway interface for a VSI before you can assign subnets to the VSI. If you remove the gateway interface from the VSI, the VSI's subnet settings are automatically deleted.
For VSIs that share a gateway interface, the subnets must be unique.
# Assign subnet 100.0.10.0/24 to VSI vxlan.
[Sysname] vsi vxlan
[Sysname-vsi-vxlan] gateway subnet 100.0.10.0 0.0.0.255
gateway vsi-interface
Use gateway vsi-interface to specify a gateway interface for a VSI.
Use undo gateway vsi-interface to restore the default.
gateway vsi-interface vsi-interface-id
No gateway interface is specified for a VSI.
VSI view
vsi-interface-id: Specifies a VSI interface by its number. The value range for this argument is 0 to 8191.
A VSI can have only one gateway interface. Multiple VSIs can share a gateway interface.
# Specify VSI-interface 100 as the gateway interface for VSI vpna.
[Sysname] vsi vpna
[Sysname-vsi-vpna] gateway vsi-interface 100
Use interface vsi-interface to create a VSI interface and enter its view, or enter the view of an existing VSI interface.
Use undo interface vsi-interface to delete a VSI interface.
interface vsi-interface vsi-interface-id
undo interface vsi-interface vsi-interface-id
No VSI interfaces exist.
vsi-interface-id: Specifies a VSI interface number. The value range for this argument is 0 to 8191.
# Create VSI-interface 100 and enter VSI interface view.
mac-address
Use mac-address to assign a MAC address to a VSI interface.
Use undo mac-address to restore the default.
undo mac-address
The MAC address of a VSI interface is the bridge MAC address.
VSI interface view
# Assign MAC address 0001-0001-0001 to VSI-interface 100.
[Sysname-Vsi-interface100] mac-address 1-1-1
mtu
Use mtu to set the MTU for a VSI interface.
mtu size
undo mtu
The MTU is 1500 bytes.
VSI interface view
size: Specifies an MTU value in the range of 46 to 1560 bytes.
# Set the MTU to 1430 bytes for VSI-interface 100.
[Sysname-Vsi-interface100] mtu 1430
Use reset counters interface vsi-interface to clear packet statistics on VSI interfaces.
reset counters interface [ vsi-interface [ vsi-interface-id ] ]
vsi-interface [ vsi-interface-id ]: Specifies a VSI interface by its number. Make sure the specified VSI interface has been created on the device. If you do not specify the vsi-interface [ vsi-interface-id ] option, this command clears packet statistics on all interfaces except for VA interfaces. If you specify only the vsi-interface keyword, this command clears packet statistics on all VSI interfaces. If you specify a VSI interface, this command clears packet statistics on the specified interface.
Use this command to clear history statistics before you collect traffic statistics for a time period.
# Clear packet statistics on VSI-interface 100.
<Sysname> reset counters interface vsi-interface 100
shutdown
Use shutdown to shut down a VSI interface.
Use undo shutdown to bring up a VSI interface.
shutdown
A VSI interface is not manually shut down.
VSI interface view
# Shut down VSI-interface 100.
[Sysname-Vsi-interface100] shutdown
vtep group member local
Use vtep group member local to assign the local VTEP to a VTEP group.
Use undo vtep group member local to remove the local VTEP from a VTEP group.
vtep group group-ip member local member-ip
undo vtep group group-ip member local
A VTEP is not assigned to any VTEP group.
group-ip: Specifies a VTEP group by its group IP address. The IP address must already exist on the local VTEP.
member-ip: Specifies the member VTEP IP address for the local VTEP. The IP address must already exist on the local VTEP.
Member VTEPs in a VTEP group cannot use the group IP address or share an IP address.
# Assign the local VTEP to VTEP group 1.1.1.1, and specify 2.2.2.2 as the member VTEP IP address of the local VTEP.
[Sysname] vtep group 1.1.1.1 member local 2.2.2.2
vtep group member remote
Use vtep group member remote to specify a VTEP group and its member VTEPs.
Use undo vtep group member remote to remove a VTEP group and its member VTEPs.
vtep group group-ip member remote member-ip&<1-8>
undo vtep group group-ip member remote
No VTEP group is specified.
member-ip&<1-8>: Specifies a space-separated list of up to eight member VTEP IP addresses.
# Specify VTEP group 1.1.1.1 and its member VTEPs at 2.2.2.2, 3.3.3.3, and 4.4.4.4.
[Sysname] vtep group 1.1.1.1 member remote 2.2.2.2 3.3.3.3 4.4.4.4
vxlan tunnel arp-learning disable
Use vxlan tunnel arp-learning disable to disable remote ARP learning for VXLANs.
Use undo vxlan tunnel arp-learning disable to enable remote ARP learning for VXLANs.
Remote ARP learning is enabled for VXLANs.
By default, the device learns ARP information of remote VMs from packets received on VXLAN tunnel interfaces. To save resources on VTEPs in an SDN transport network, you can temporarily disable remote ARP learning when the controller and VTEPs are synchronizing entries. After the entry synchronization is completed, use the undo vxlan tunnel arp-learning disable command to enable remote ARP learning.
As a best practice, disable remote ARP learning for VXLANs only when the controller and VTEPs are synchronizing entries.
# Disable remote ARP learning for VXLANs.
<Sysname> system
[Sysname] vxlan tunnel arp-learning disable
