03-H3C_Samplers_and_IPv4_NetStream_Configuration_Examples | 73.09 KB |
H3C Samplers and IPv4 NetStream Configuration Examples |
Software version: Release 7951P01
Document version: 6W100-20200625
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides configuration examples of collaborating samplers with IPv4 NetStream.
This document assumes that you have basic knowledge of samplers and IPv4 NetStream.
General restrictions and guidelines
To configure NetStream flow mirroring, follow the rules:
· The device supports inbound, outbound, and sampled NetStream flow mirroring for interfaces on CSPC-GE24L-E cards, CSPC-GP24GE8XP2L-E cards, CSPC-GE16XP4L-E cards, CSPEX cards, and CEPC cards.
For NetStream sampling to operate correctly for NetStream flow mirroring on a device, the samplers used by NetStream flow mirroring must use the same sampling rate calculation method.
· The device supports inbound NetStream flow mirroring but does not support outbound or sampled NetStream flow mirroring for interfaces on CSPC cards (except for CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPC-GE16XP4L-E cards), and CMPE-1104 cards.
· To mirror inbound or outbound traffic on CSPC-GE24L-E cards, CSPC-GP24GE8XP2L-E cards, CSPC-GE16XP4L-E cards, CSPEX cards, and CEPC cards to a card, you must specify the sampler keyword in the mirror-to command.
· NetStream cannot collect statistics of traffic on a subinterface of a Layer 3 aggregate interface that contains member ports on CSPC cards (except for CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPC-GE16XP4L-E cards) and CMPE-1104 cards.
· NetStream collects statistics of traffic on a subinterface of a Layer 2 aggregate interface that contains member ports on CSPC cards (except for CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPC-GE16XP4L-E cards) and CMPE-1104 cards.
¡ If NetStream flow mirroring is enabled both on the inbound and oubound directions, NetStream only collects statistics of inbound traffic.
¡ If only outbound NetStream flow mirroring is enabled, NetStream collects statistics of outbound traffic.
· NetStream flow mirroring supports mirroring traffic only to the current interface module.
Example: Configuring Samplers and IPv4 NetStream
As shown in Figure 1, configure a sampler and IPv4 NetStream as follows:
· Configure IPv4 NetStream on the router to collect statistics on incoming traffic.
· Configure the router to send IPv4 NetStream data to port 5000 on the NetStream server.
· Configure fixed sampling in the inbound direction to select the first packet out of 1001 packets on GigabitEthernet 3/1/1.
Procedures
1. Configure a sampler:
# Create sampler samperin in fixed sampling mode, and set the rate to 1001. The first packet out of 1001 packets is selected.
[Device] sampler samplerin mode fixed packet-interval 1001
2. Configure NetStream:
# Assign an IP address to GigabitEthernet 3/1/1.
[Device] interface gigabitethernet 3/1/1
[Device-GigabitEthernet3/1/1] ip address 192.168.0.1 24
[Device-GigabitEthernet3/1/1] quit
# Assign an IP address to interface GigabitEthernet 3/1/2.
[Device] interface gigabitethernet 3/1/2
[Device-GigabitEthernet3/1/2] ip address 10.0.0.1 24
[Device-GigabitEthernet3/1/2] quit
# Assign an IP address to interface GigabitEthernet 3/1/3.
[Device] interface gigabitethernet 3/1/3
[Device-GigabitEthernet3/1/3] ip address 192.168.1.1 24
[Device-GigabitEthernet3/1/3] quit
[Device] ip netstream
# Configure QoS policy ns_ipv4_in with a flow mirroring action that uses sampler samperin.
[Device] acl advanced 3000
[Device-acl-ipv4-adv-3000] rule 0 permit ip
[Device] traffic classifier ns_ipv4
[Device-classifier-ns_ipv4] if-match acl 3000
[Device-classifier-ns_ipv4] quit
[Device] traffic behavior ns_ipv4_in
[Device-behavior-ns_ipv4] mirror-to slot 3 sampler samplerin
[Device-behavior-ns_ipv4] quit
[Device] qos policy ns_ipv4_in
[Device-qospolicy-ns_ipv4] classifier ns_ipv4 behavior ns_ipv4_in
[Device-qospolicy-ns_ipv4] quit
# Apply QoS policy ns_ipv4_in to the inbound direction of GigabitEthernet 3/1/1.
[Device] interface GigabitEthernet 3/1/1
[Device-GigabitEthernet3/1/1] qos apply policy ns_ipv4_in inbound
# Specify 192.168.1.2 as the IP address of the destination host and UDP port 5000 as the export destination port number.
[Device] ip netstream export host 192.168.1.2 5000
1. Display configuration information for sampler samperin.
[Device] display sampler
Sampler name: samplerin
Mode: fixed; Packet-interval: 1001; IsNpower : N
2. Display the statistics about NetStream data:
# Display NetStream entry information.
[Device] display ip netstream cache verbose
IP NetStream cache information:
Active flow timeout : 30 min
Inactive flow timeout : 30 sec
Max number of entries : 819200
IP active flow entries : 1
MPLS active flow entries : 0
L2 active flow entries : 0
IPL2 active flow entries : 0
IP flow entries counted : 22
MPLS flow entries counted : 0
L2 flow entries counted : 0
IPL2 flow entries counted : 0
Last statistics resetting time : 06/30/2014 at 16:02:43
IP packet size distribution (300 packets in total):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .000 1.00 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
Protocol Total Packets Flows Packets Active(sec) Idle(sec)
Flows /sec /sec /flow /flow /flow
ICMP 22 0 0 13 1 30
Type DstIP(Port) SrcIP(Port) Pro ToS If(Direct) Pkts
DstMAC(VLAN) SrcMAC(VLAN)
TopLblType(IP/MASK) Lbl-Exp-S-List
IP 10.0.0.2(2048) 192.168.0.2(0) 1 0 GE3/1/1(I) 5
TCPFlag: 0
DstMask: 32 SrcMask: 32 NextHop: 10.0.0.2
DstAS: 0 SrcAS: 0 BGPNextHop: 0.0.0.0
InVRF: 0
SamplerMode: 1 SamplerInt: 1001
Active: 0 Bytes/Pkt: 84
# Display information about the NetStream data export.
[Device] display ip netstream export
IP export information:
Flow source interface : Not specified
Flow destination VPN instance : Not specified
Flow destination IP address (UDP) : 192.168.1.2 (5000)
Version 5 exported flow number : 0
Version 5 exported UDP datagram number (failed) : 0 (0)
Version 9 exported flow number : 1
Version 9 exported UDP datagram number (failed) : 0 (0)
Version 10 exported flow number : 0
Version 10 exported UDP datagram number (failed): 0 (0)
IPL2 export information:
Version 9 exported flow number : 0
Configuration files
ip netstream
traffic classifier ns_ipv4 operator and
if-match acl 3000
interface GigabitEthernet3/1/1
port link-mode route
ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet3/1/2
ip address 10.0.0.1 255.255.255.0
interface GigabitEthernet3/1/3
acl advanced 3000
rule 0 permit ip
Related documentation
· H3C CR16000-F Routers Network Management and Monitoring Configuration Guide-R7951P01
· H3C CR16000-F Routers Network Management and Monitoring Command Reference-R7951P01
