09-MPLS Configuration Examples
HomeSupportRoutersH3C SR8800-F Router SeriesConfigure & DeployConfiguration ExamplesH3C SR8800-F Routers Configuration Examples-R7951P01-6W10009-MPLS Configuration Examples
05-H3C_VPLS_Configuration_Examples
05-H3C_VPLS_Configuration_Examples 459.70 KB
H3C VPLS Configuration Examples
Software version: Release 7951P01
Document version: 6W100-20200625
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides Virtual Private LAN Service (VPLS) configuration examples.
VPLS delivers point-to-multipoint L2VPN services over an MPLS or IP backbone. The provider backbone emulates a switch to connect all geographically dispersed sites for each customer network. The backbone is transparent to the customer sites, which can communicate with each other as if they were on the same LAN.
VPLS has two networking models: full mesh and H-VPLS. The full mesh model requires a full mesh of PWs among all PEs and applies to networks that have a small number of PEs. The H-VPLS model classifies PEs to User facing-Provider Edge (UPE) devices and Network Provider Edge (NPE) devices. NPEs are fully meshed and UPEs establish PWs only with the neighbor NPEs. H-VPLS applies to complicated networks that have a large number of PEs.
The following table shows the VPLS networking models and their application scenarios:
Networking model
Application scenario
Full-mesh VPLS using LDP signaling
A few sites exist and no new sites will be added.
Full-mesh VPLS using BGP auto-discovery and LDP signaling
A large number of sites exist and no new sites will be added.
Full-mesh VPLS using BGP signaling
A large number of sites exist and new sites will be added.
H-VPLS with LSP access
UPEs support MPLS.
In this mode, MPLS LSP is used at the access layer.
H-VPLS with QinQ access
UPEs do not support MPLS.
In this mode, Ethernet QinQ tunneling is used at the access layer.
This document assumes that you have basic knowledge of VPLS.
·     SPC, CSPC, and CMPE-1104 cards support only full-mesh LDP VPLS.
·     Layer 3 Ethernet interfaces on SPC, CSPC, and CMPE-1104 cards cannot be associated with VSIs. Please create Layer 3 subinterfaces on these interface cards to associate with VSIs.
·     After you bind a subinterface of a Layer 3 Ethernet interface to a VSI, the Layer 3 Ethernet interface does not support Layer 3 forwarding.
Example: Configuring full-mesh LDP VPLS
As shown in Figure 1, the MPLS network provides L2VPN services for a company. The company has a headquarters and two branches, and it will not add sites in the future.
Configure full-mesh VPLS using LDP signaling to allow communication among the three sites at Layer 2.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     To implement LDP VPLS over the MPLS backbone, you must perform the following tasks:
¡     Establish LDP LSPs on the MPLS backbone as public tunnels to deliver the private data over the MPLS network.
¡     Configure an LDP PW between any two PEs to forward data among the branches.
¡     Configure Layer 3 subinterfaces of the CE-facing interfaces on PEs to identify packets to be transported by VPLS.
·     To implement VLAN isolation among the sites, create VSIs user_a and user_b. Bind VSI user_a to the subinterface that matches packets of VLAN 100, and bind VSI user_b to the subinterface that matches packets of VLAN 200.
Procedures
1.     Configure an IGP on the MPLS backbone to ensure IP connectivity within the backbone:
# On PE 1, configure an IP address for Loopback 0.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
# Configure an IP address for GigabitEthernet 3/1/2.
[PE1] interface gigabitethernet 3/1/2
[PE1-GigabitEthernet3/1/2] ip address 10.1.1.1 24
[PE1-GigabitEthernet3/1/2] quit
# On PE 1, configure OSPF.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# On PE 2, configure an IP address for Loopback 0.
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
# Configure an IP address for GigabitEthernet 3/1/1.
[PE2] interface gigabitethernet 3/1/1
[PE2-GigabitEthernet3/1/1] ip address 10.1.2.2 24
[PE2-GigabitEthernet3/1/1] quit
# On PE 2, configure OSPF.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
# On PE 3, configure an IP address for Loopback 0.
<PE3> system-view
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 4.4.4.9 32
[PE3-LoopBack0] quit
[PE3] interface gigabitethernet 3/1/1
[PE3-GigabitEthernet3/1/1] ip address 10.1.3.2 24
[PE3-GigabitEthernet3/1/1] quit
# On PE 3, configure OSPF.
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1-area-0.0.0.0] network 10.1.3.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[PE3-ospf-1] quit
# On P, configure an IP address for Loopback 0.
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] interface gigabitethernet 3/1/2
[P-GigabitEthernet3/1/2] ip address 10.1.1.2 24
[P-GigabitEthernet3/1/2] quit
# Configure an IP address for GigabitEthernet 3/1/3.
[P] interface gigabitethernet 3/1/3
[P-GigabitEthernet3/1/3] ip address 10.1.2.1 24
[P-GigabitEthernet3/1/3] quit
# Configure an IP address for GigabitEthernet 3/1/4.
[P] interface gigabitethernet 3/1/4
[P-GigabitEthernet3/1/4] ip address 10.1.3.1 24
[P-GigabitEthernet3/1/4] quit
# On P, configure OSPF.
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 10.1.3.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
2.     Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs:
# On PE 1, configure an LSR ID.
[PE1] mpls lsr-id 1.1.1.9
# On PE 1, enable LDP globally.
[PE1] mpls ldp
[PE1-ldp] quit
# On PE 1, enable MPLS and LDP on GigabitEthernet 3/1/2.
[PE1-GigabitEthernet3/1/2] mpls enable
[PE1-GigabitEthernet3/1/2] mpls ldp enable
# On PE 2, configure an LSR ID.
[PE2] mpls lsr-id 3.3.3.9
# On PE 2, enable LDP globally.
[PE2] mpls ldp
[PE2-ldp] quit
# On PE 2, enable MPLS and LDP on GigabitEthernet 3/1/1.
[PE2-GigabitEthernet3/1/1] mpls enable
[PE2-GigabitEthernet3/1/1] mpls ldp enable
# On PE 3, configure an LSR ID.
[PE3] mpls lsr-id 4.4.4.9
# On PE 3, enable LDP globally.
[PE3] mpls ldp
[PE3-ldp] quit
# On PE 3, enable MPLS and LDP on GigabitEthernet 3/1/1.
[PE3-GigabitEthernet3/1/1] mpls enable
[PE3-GigabitEthernet3/1/1] mpls ldp enable
# On P, configure an LSR ID.
[P] mpls lsr-id 2.2.2.9
# On P, enable LDP globally.
[P] mpls ldp
[P-ldp] quit
# On P, enable MPLS and LDP on GigabitEthernet 3/1/2.
[P-GigabitEthernet3/1/2] mpls enable
[P-GigabitEthernet3/1/2] mpls ldp enable
# On P, enable MPLS and LDP on GigabitEthernet 3/1/3.
[P-GigabitEthernet3/1/3] mpls enable
[P-GigabitEthernet3/1/3] mpls ldp enable
# On P, enable MPLS and LDP on GigabitEthernet 3/1/4.
[P-GigabitEthernet3/1/4] mpls enable
[P-GigabitEthernet3/1/4] mpls ldp enable
3.     Configure VSIs and LDP PWs:
# On PE 1, enable MPLS L2VPN globally.
[PE1] l2vpn enable
# On PE 1, create VSI user_a and configure the VSI to use LDP as the PW signaling protocol.
[PE1] vsi user_a
[PE1-vsi-user_a] pwsignaling ldp
# On PE 1, specify PE 2 and PE 3 as the peer PEs, and set the PW ID to 500.
[PE1-vsi-user_a-ldp] peer 3.3.3.9 pw-id 500
[PE1-vsi-user_a-ldp-3.3.3.9-500] quit
[PE1-vsi-user_a-ldp] peer 4.4.4.9 pw-id 500
[PE1-vsi-user_a-ldp-4.4.4.9-500] quit
[PE1-vsi-user_a-ldp] quit
[PE1-vsi-user_a] quit
# On PE 1, create VSI user_b and configure the VSI to use LDP as the PW signaling protocol.
[PE1] vsi user_b
[PE1-vsi-user_b] pwsignaling ldp
# On PE 1, specify PE 2 and PE 3 as the peer PEs, and set the PW ID to 600.
[PE1-vsi-user_b-ldp] peer 3.3.3.9 pw-id 600
[PE1-vsi-user_b-ldp-3.3.3.9-600] quit
[PE1-vsi-user_b-ldp] peer 4.4.4.9 pw-id 600
[PE1-vsi-user_b-ldp-4.4.4.9-600] quit
[PE1-vsi-user_b-ldp] quit
[PE1-vsi-user_b] quit
# On PE 2, enable MPLS L2VPN globally.
[PE2] l2vpn enable
# On PE 2, create VSI user_a and configure the VSI to use LDP as the PW signaling protocol.
[PE2] vsi user_a
[PE2-vsi-user_a] pwsignaling ldp
# On PE 2, specify PE 1 and PE 3 as the peer PEs, and set the PW ID to 500.
[PE2-vsi-user_a-ldp] peer 1.1.1.9 pw-id 500
[PE2-vsi-user_a-ldp-1.1.1.9-500] quit
[PE2-vsi-user_a-ldp] peer 4.4.4.9 pw-id 500
[PE2-vsi-user_a-ldp-4.4.4.9-500] quit
[PE2-vsi-user_a-ldp] quit
[PE2-vsi-user_a] quit
# On PE 2, create VSI user_b and configure the VSI to use LDP as the PW signaling protocol.
[PE2] vsi user_b
[PE2-vsi-user_b] pwsignaling ldp
# On PE 2, specify PE 1 and PE 3 as the peer PEs, and set the PW ID to 600.
[PE2-vsi-user_b-ldp] peer 1.1.1.9 pw-id 600
[PE2-vsi-user_b-ldp-1.1.1.9-600] quit
[PE2-vsi-user_b-ldp] peer 4.4.4.9 pw-id 600
[PE2-vsi-user_b-ldp-4.4.4.9-600] quit
[PE2-vsi-user_b-ldp] quit
[PE2-vsi-user_b] quit
# On PE 3, enable MPLS L2VPN globally.
[PE3] l2vpn enable
# On PE 3, create VSI user_a and configure the VSI to use LDP as the PW signaling protocol.
[PE3] vsi user_a
[PE3-vsi-user_a] pwsignaling ldp
# On PE 3, specify PE 1 and PE 2 as the peer PEs, and set the PW ID to 500.
[PE3-vsi-user_a-ldp] peer 1.1.1.9 pw-id 500
[PE3-vsi-user_a-ldp-1.1.1.9-500] quit
[PE3-vsi-user_a-ldp] peer 3.3.3.9 pw-id 500
[PE3-vsi-user_a-ldp-3.3.3.9-500] quit
[PE3-vsi-user_a-ldp] quit
[PE3-vsi-user_a] quit
# On PE 3, create VSI user_b and configure the VSI to use LDP as the PW signaling protocol.
[PE3] vsi user_b
[PE3-vsi-user_b] pwsignaling ldp
# On PE 3, specify PE 1 and PE 2 as the peer PEs, and set the PW ID to 600.
[PE3-vsi-user_b-ldp] peer 1.1.1.9 pw-id 600
[PE3-vsi-user_b-ldp-1.1.1.9-600] quit
[PE3-vsi-user_b-ldp] peer 3.3.3.9 pw-id 600
[PE3-vsi-user_b-ldp-3.3.3.9-600] quit
[PE3-vsi-user_b-ldp] quit
[PE3-vsi-user_b] quit
4.     Configure Layer 3 subinterfaces for different VLANs and bind the subinterfaces to VSIs:
# On PE 1, create subinterface GigabitEthernet3/1/1.100, configure the subinterface to terminate packets whose outermost VLAN ID is 100, and bind the subinterface to VSI user_a.
[PE1] interface gigabitethernet 3/1/1.100
[PE1-GigabitEthernet3/1/1.100] vlan-type dot1q vid 100
[PE1-GigabitEthernet3/1/1.100] xconnect vsi user_a
[PE1-GigabitEthernet3/1/1.100] quit
# On PE 1, create subinterface GigabitEthernet3/1/1.200, configure the subinterface to terminate packets whose outermost VLAN ID is 200, and bind the subinterface to VSI user_b.
[PE1] interface gigabitethernet 3/1/1.200
[PE1-GigabitEthernet3/1/1.200] vlan-type dot1q vid 200
[PE1-GigabitEthernet3/1/1.200] xconnect vsi user_b
[PE1-GigabitEthernet3/1/1.200] quit
# On PE 2, create subinterface GigabitEthernet3/1/2.100, configure the subinterface to terminate packets whose outermost VLAN ID is 100, and bind the subinterface to VSI user_a.
[PE2] interface gigabitethernet 3/1/2.100
[PE2-GigabitEthernet3/1/2.100] vlan-type dot1q vid 100
[PE2-GigabitEthernet3/1/2.100] xconnect vsi user_a
[PE2-GigabitEthernet3/1/2.100] quit
# On PE 2, create subinterface GigabitEthernet 3/1/2.200, configure the subinterface to terminate packets whose outermost VLAN ID is 200, and bind the subinterface to VSI user_b.
[PE2] interface gigabitethernet 3/1/2.200
[PE2-GigabitEthernet3/1/1.200] vlan-type dot1q vid 200
[PE2-GigabitEthernet3/1/2.200] xconnect vsi user_b
[PE2-GigabitEthernet3/1/2.200] quit
# On PE 3, create subinterface GigabitEthernet3/1/2.100, configure the subinterface to terminate packets whose outermost VLAN ID is 100, and bind the subinterface to VSI user_a.
[PE3] interface gigabitethernet 3/1/2.100
[PE3-GigabitEthernet3/1/2.100] vlan-type dot1q vid 100
[PE3-GigabitEthernet3/1/2.100] xconnect vsi user_a
[PE3-GigabitEthernet3/1/2.100] quit
# On PE 3, create subinterface GigabitEthernet3/1/2.200, configure the subinterface to terminate packets whose outermost VLAN ID is 200, and bind the subinterface to VSI user_b.
[PE3] interface gigabitethernet 3/1/2.200
[PE3-GigabitEthernet3/1/2.200] vlan-type dot1q vid 200
[PE3-GigabitEthernet3/1/2.200] xconnect vsi user_b
[PE3-GigabitEthernet3/1/2.200] quit
5.     Allow CE access to PEs:
# On CE 1, configure the interface connected to the PE to permit tagged packets from the customer VLANs.
<CE1> system-view
[CE1] vlan 100
[CE1-vlan100] quit
[CE1] vlan 200
[CE1-vlan200] quit
[CE1] interface gigabitethernet 3/1/1
[CE1-GigabitEthernet3/1/1] port link-type trunk
[CE1-GigabitEthernet3/1/1] port trunk permit vlan 100 200
# Configure other CEs in the same way that CE 1 is configured. (Details not shown.)
# Verify that LDP LSPs have been established on each switch in the MPLS network. This example uses PE 1.
[PE1] display mpls ldp lsp
Status Flags: * - stale, L - liberal
Statistics:
  FECs: 4      Ingress LSPs: 3     Transit LSPs: 3     Egress LSPs: 1
FEC                In/Out Label    Nexthop         OutInterface
1.1.1.9/32         3/-
                   -/1151(L)
                   -/1151(L)
                   -/1151(L)
2.2.2.9/32         -/3             10.1.1.2        GE3/1/2
                   1151/3          10.1.1.2        GE3/1/2
                   -/1150(L)
                   -/1150(L)
3.3.3.9/32         -/1150          10.1.1.2        GE3/1/2
                   1150/1150       10.1.1.2        GE3/1/2
                   -/3(L)
                   -/1149(L)
4.4.4.9/32         -/1149          10.1.1.2        GE3/1/2
                   1149/1149       10.1.1.2        GE3/1/2
                   -/1149(L)
                   -/3(L)
# Verify that LDP PWs in up state have been established on each PE. This example uses PE 1.
[PE1] display l2vpn pw
Flags: M - main, B - backup, H - hub link, S - spoke link, N - no split horizon
Total number of PWs: 4
4 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
VSI Name: user_a
Peer            PW ID/Rmt Site    In/Out Label    Proto   Flag  Link ID  State
3.3.3.9         500               131198/131198   LDP     M     64       Up
4.4.4.9         500               131199/1150     LDP     M     65       Up
VSI Name: user_b
3.3.3.9         600               131196/131196   LDP     M     64       Up
4.4.4.9         600               131197/1147     LDP     M     65       Up
# Verify that hosts in the same VLAN but different sites can ping each other. (Details not shown.)
Configuration files
·     PE 1:
ospf 1
 area 0.0.0.0
 mpls lsr-id 1.1.1.9
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
vsi user_b
 pwsignaling ldp
interface LoopBack0
 ip address 1.1.1.9 255.255.255.255
 port link-mode route
 xconnect vsi user_a
 xconnect vsi user_b
 mpls enable
 mpls ldp enable
·     PE 2:
ospf 1
 area 0.0.0.0
 mpls lsr-id 3.3.3.9
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
vsi user_a
 pwsignaling ldp
interface LoopBack0
 ip address 3.3.3.9 255.255.255.255
 ip address 10.1.2.2 255.255.255.0
 mpls enable
 mpls ldp enable
 xconnect vsi user_a
 xconnect vsi user_b
·     PE 3:
ospf 1
 area 0.0.0.0
 mpls lsr-id 4.4.4.9
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
vsi user_b
 pwsignaling ldp
interface LoopBack0
 ip address 4.4.4.9 255.255.255.255
 ip address 10.1.3.2 255.255.255.0
 mpls enable
 mpls ldp enable
 xconnect vsi user_a
 xconnect vsi user_b
·     P:
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
 ip address 2.2.2.9 255.255.255.255
 mpls enable
 mpls ldp enable
interface GigabitEthernet3/1/3
 ip address 10.1.2.1 255.255.255.0
 mpls enable
 mpls ldp enable
 ip address 10.1.3.1 255.255.255.0
 mpls enable
 mpls ldp enable
·     CE 1 through CE 3:
vlan 100
vlan 200
 port link-mode bridge
Example: Configuring full-mesh LDP VPLS using BGP auto-discovery
As shown in Figure 2, the MPLS network provides L2VPN services for a company. The company has a headquarters and a large number of branches, and it will not add sites in the future.
Configure full-mesh VPLS using BGP auto-discovery and LDP signaling to allow communication among all the sites at Layer 2.
Figure 2 Network diagram
Analysis
·     To implement LDP VPLS using BGP auto-discovery over the MPLS backbone, you must perform the following tasks:
¡     Configure a BGP auto-discovery LDP PW between any two PEs to forward data among the branches.
Procedures
<PE1> system-view
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
<PE2> system-view
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
<PE3> system-view
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1] quit
<P> system-view
[P-LoopBack0] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
[PE1] mpls ldp
[PE1-ldp] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE3] mpls ldp
[PE3-ldp] quit
[P] mpls ldp
[P-ldp] quit
3.     Configure VSIs and BGP auto-discovery LDP PWs:
# On PE 1, establish IBGP connections to PE 2 and PE 3.
[PE1] bgp 100
[PE1-bgp-default] peer 4.4.4.9 as-number 100
[PE1-bgp-default] peer 4.4.4.9 connect-interface loopback 0
# On PE 1, enable BGP to exchange L2VPN information with the peers.
[PE1-bgp-default] address-family l2vpn
[PE1-bgp-default-l2vpn] peer 3.3.3.9 enable
[PE1-bgp-default-l2vpn] peer 4.4.4.9 enable
[PE1-bgp-default-l2vpn] quit
[PE1-bgp-default] quit
[PE1] l2vpn enable
# On PE 1, create VSI user_a and enable the VSI to automatically discover neighbors through BGP.
[PE1] vsi user_a
[PE1-vsi-user_a] auto-discovery bgp
# On PE 1, configure an RD and route targets for the VSI.
[PE1-vsi-user_a-auto] route-distinguisher 100:1
[PE1-vsi-user_a-auto] vpn-target 111:1
# On PE 1, use LDP to establish a PW to a remote PE discovered by BGP.
[PE1-vsi-user_a-auto] signaling-protocol ldp
# On PE 1, configure the VPLS ID as 100:100 for the VSI.
[PE1-vsi-user_a-auto-ldp] vpls-id 100:100
[PE1-vsi-user_a-auto-ldp] quit
[PE1-vsi-user_a-auto] quit
# On PE 1, create VSI user_b and enable the VSI to automatically discover neighbors through BGP.
[PE1] vsi user_b
[PE1-vsi-user_b] auto-discovery bgp
[PE1-vsi-user_b-auto] route-distinguisher 200:1
[PE1-vsi-user_b-auto] vpn-target 222:1
[PE1-vsi-user_b-auto] signaling-protocol ldp
# On PE 1, configure the VPLS ID as 200:200 for the VSI.
[PE1-vsi-user_b-auto-ldp] vpls-id 200:200
[PE1-vsi-user_b-auto-ldp] quit
[PE1-vsi-user_b-auto] quit
# On PE 2, establish IBGP connections to PE 1 and PE 3.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default] peer 4.4.4.9 as-number 100
[PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
# On PE 2, enable BGP to exchange L2VPN information with the peers.
[PE2-bgp] address-family l2vpn
[PE2-bgp-default-l2vpn] peer 1.1.1.9 enable
[PE2-bgp-default-l2vpn] peer 4.4.4.9 enable
[PE2-bgp-default-l2vpn] quit
[PE2-bgp-default] quit
[PE2] l2vpn enable
# On PE 2, create VSI user_a and enable the VSI to automatically discover neighbors through BGP.
[PE2] vsi user_a
[PE2-vsi-user_a] auto-discovery bgp
# On PE 2, configure an RD and route targets for the VSI.
[PE2-vsi-user_a-auto] route-distinguisher 100:1
[PE2-vsi-user_a-auto] vpn-target 111:1
# On PE 2, use LDP to establish a PW to a remote PE discovered by BGP.
[PE2-vsi-user_a-auto] signaling-protocol ldp
# On PE 2, configure the VPLS ID as 100:100 for the VSI.
[PE2-vsi-user_a-auto-ldp] vpls-id 100:100
[PE2-vsi-user_a-auto-ldp] quit
[PE2-vsi-user_a-auto] quit
# On PE 2, create VSI user_b and enable the VSI to automatically discover neighbors through BGP.
[PE2] vsi user_b
[PE2-vsi-user_b] auto-discovery bgp
[PE2-vsi-user_b-auto] route-distinguisher 200:1
[PE2-vsi-user_b-auto] vpn-target 222:1
[PE2-vsi-user_b-auto] signaling-protocol ldp
# On PE 2, configure the VPLS ID as 200:200 for the VSI.
[PE2-vsi-user_b-auto-ldp] vpls-id 200:200
[PE2-vsi-user_b-auto-ldp] quit
[PE2-vsi-user_b-auto] quit
# On PE 3, establish IBGP connections to PE 1 and PE 2.
[PE3] bgp 100
[PE3-bgp-default] peer 1.1.1.9 as-number 100
[PE3-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE3-bgp-default] peer 3.3.3.9 as-number 100
[PE3-bgp-default] peer 3.3.3.9 connect-interface loopback 0
# On PE 3, enable BGP to exchange L2VPN information with the peers.
[PE3-bgp] address-family l2vpn
[PE3-bgp-default-l2vpn] peer 1.1.1.9 enable
[PE3-bgp-default-l2vpn] peer 3.3.3.9 enable
[PE3-bgp-default-l2vpn] quit
[PE3-bgp-default] quit
[PE3] l2vpn enable
# On PE 3, create VSI user_a and enable the VSI to automatically discover neighbors through BGP.
[PE3] vsi user_a
[PE3-vsi-user_a] auto-discovery bgp
# On PE 3, configure an RD and route targets for the VSI.
[PE3-vsi-user_a-auto] route-distinguisher 100:1
[PE3-vsi-user_a-auto] vpn-target 111:1
# On PE 3, use LDP to establish a PW to a remote PE discovered by BGP.
[PE3-vsi-user_a-auto] signaling-protocol ldp
# On PE 3, configure the VPLS ID as 100:100 for the VSI.
[PE3-vsi-user_a-auto-ldp] vpls-id 100:100
[PE3-vsi-user_a-auto-ldp] quit
[PE3-vsi-user_a-auto] quit
# On PE 3, create VSI user_b and enable the VSI to automatically discover neighbors through BGP.
[PE3] vsi user_b
[PE3-vsi-user_b] auto-discovery bgp
[PE3-vsi-user_b-auto] route-distinguisher 200:1
[PE3-vsi-user_b-auto] vpn-target 222:1
[PE3-vsi-user_b-auto] signaling-protocol ldp
# On PE 3, configure the VPLS ID as 200:200 for the VSI.
[PE3-vsi-user_b-auto-ldp] vpls-id 200:200
[PE3-vsi-user_b-auto-ldp] quit
[PE3-vsi-user_b-auto] quit
# On PE 2, create subinterface GigabitEthernet3/1/2.200, configure the subinterface to terminate packets whose outermost VLAN ID is 200, and bind the subinterface to VSI user_b.
# On PE 3, configure other CE-facing interfaces in the same way that GigabitEthernet3/1/2 is configured. (Details not shown.)
<CE1> system-view
[CE1] vlan 100
[CE1-vlan100] quit
[CE1] vlan 200
[CE1-vlan200] quit
Statistics:
1.1.1.9/32         3/-
                   -/1148(L)
                   -/1151(L)
                   -/1151(L)
                   -/1150(L)
                   -/1150(L)
3.3.3.9/32         -/1146          10.1.1.2        GE3/1/2
                   1149/1146       10.1.1.2        GE3/1/2
                   -/1149(L)
                   -/3(L)
4.4.4.9/32         -/1147          10.1.1.2        GE3/1/2
                   1150/1147       10.1.1.2        GE3/1/2
                   -/3(L)
                   -/1149(L)
VSI Name: user_a
3.3.3.9         -                 131195/131195   LDP     M     64       Up
4.4.4.9         -                 131194/1145     LDP     M     65       Up
VSI Name: user_b
4.4.4.9         -                 131193/1143     LDP     M     64       Up
3.3.3.9         -                 131192/131192   LDP     M     65       Up
Configuration files
·     PE 1:
ospf 1
 area 0.0.0.0
 mpls lsr-id 1.1.1.9
mpls ldp
 l2vpn enable
vsi user_a
 auto-discovery bgp
  vpn-target 111:1 export-extcommunity
  vpn-target 111:1 import-extcommunity
   vpls-id 100:100
vsi user_b
 auto-discovery bgp
  vpn-target 222:1 export-extcommunity
  vpn-target 222:1 import-extcommunity
   vpls-id 200:200
interface LoopBack0
 xconnect vsi user_a
 xconnect vsi user_b
 mpls enable
 mpls ldp enable
bgp 100
 peer 3.3.3.9 connect-interface LoopBack0
 peer 4.4.4.9 connect-interface LoopBack0
  peer 3.3.3.9 enable
  peer 4.4.4.9 enable
·     PE 2:
ospf 1
 area 0.0.0.0
 mpls lsr-id 3.3.3.9
mpls ldp
 l2vpn enable
vsi user_a
 auto-discovery bgp
   vpls-id 100:100
vsi user_b
 auto-discovery bgp
   vpls-id 200:200
interface LoopBack0
 mpls enable
 mpls ldp enable
 xconnect vsi user_a
 xconnect vsi user_b
bgp 100
 peer 1.1.1.9 connect-interface LoopBack0
  peer 1.1.1.9 enable
  peer 4.4.4.9 enable
·     PE 3:
ospf 1
 area 0.0.0.0
 mpls lsr-id 4.4.4.9
mpls ldp
 l2vpn enable
vsi user_a
 auto-discovery bgp
   vpls-id 100:100
vsi user_b
 auto-discovery bgp
   vpls-id 200:200
interface LoopBack0
 mpls enable
 mpls ldp enable
 xconnect vsi user_a
 xconnect vsi user_b
bgp 100
  peer 1.1.1.9 enable
  peer 3.3.3.9 enable
·     P:
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
·     CE 1 through CE n:
vlan 100
vlan 200
Example: Configuring full-mesh BGP VPLS
As shown in Figure 3, the MPLS network provides L2VPN services for a company. The company has 10 data centers and will add 15 data centers in the future.
Configure full-mesh VPLS using BGP signaling to allow communication among the data centers at Layer 2.
Figure 3 Network diagram
Analysis
·     To implement BGP VPLS over the MPLS backbone, you must perform the following tasks:
¡     Configure a BGP PW between any two PEs to forward data among the data centers.
¡     Configure subinterfaces and match criteria of the CE-facing interfaces on PEs to identify packets to be transported by VPLS.
·     For future expansion of the customer network, set the maximum number of sites in the VPN to 25.
Procedures
<PE1> system-view
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
<PE2> system-view
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
<PE3> system-view
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1] quit
<P> system-view
[P-LoopBack0] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
[PE1] mpls ldp
[PE1-ldp] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE3] mpls ldp
[PE3-ldp] quit
[P] mpls ldp
[P-ldp] quit
3.     Configure VSIs and BGP PWs:
[PE1] bgp 100
[PE1-bgp] peer 3.3.3.9 as-number 100
[PE1-bgp] peer 3.3.3.9 connect-interface loopback 0
[PE1-bgp] peer 4.4.4.9 as-number 100
[PE1-bgp] peer 4.4.4.9 connect-interface loopback 0
[PE1-bgp] address-family l2vpn
[PE1-bgp-l2vpn] peer 3.3.3.9 enable
[PE1-bgp-l2vpn] peer 4.4.4.9 enable
[PE1-bgp-l2vpn] quit
[PE1-bgp] quit
[PE1] l2vpn enable
[PE1] vsi user_a
# On PE 1, use BGP to establish a PW to a remote PE discovered by BGP.
[PE1-vsi-user_a-auto] signaling-protocol bgp
# On PE 1, set the site number in the VSI to 1 and the maximum number of sites in the VSI to 25.
[PE1-vsi-user_a-auto-bgp] site 1 range 25
[PE1-vsi-user_a-auto-bgp] quit
[PE1] vsi user_b
[PE1-vsi-user_b-auto] route-distinguisher 100:1
[PE1-vsi-user_b-auto] vpn-target 111:1
[PE1-vsi-user_b-auto] signaling-protocol bgp
[PE1-vsi-user_b-auto-bgp] site 1 range 25
[PE1-vsi-user_b-auto-bgp] quit
[PE2] bgp 100
[PE2-bgp] peer 1.1.1.9 as-number 100
[PE2-bgp] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp] peer 4.4.4.9 as-number 100
[PE2-bgp] peer 4.4.4.9 connect-interface loopback 0
[PE2-bgp-l2vpn] peer 1.1.1.9 enable
[PE2-bgp-l2vpn] peer 4.4.4.9 enable
[PE2-bgp-l2vpn] quit
[PE2-bgp] quit
[PE2] l2vpn enable
[PE2] vsi user_a
# On PE 2, use BGP to establish a PW to a remote PE discovered by BGP.
[PE2-vsi-user_a-auto] signaling-protocol bgp
# On PE 2, set the site number in the VSI to 2 and the maximum number of sites in the VSI to 25.
[PE2-vsi-user_a-auto-bgp] site 2 range 25
[PE2-vsi-user_a-auto-bgp] quit
[PE2] vsi user_b
[PE2-vsi-user_b-auto] signaling-protocol bgp
[PE2-vsi-user_b-auto-bgp] site 2 range 25
[PE2-vsi-user_b-auto-bgp] quit
[PE3] bgp 100
[PE3-bgp] peer 1.1.1.9 as-number 100
[PE3-bgp] peer 1.1.1.9 connect-interface loopback 0
[PE3-bgp] peer 3.3.3.9 as-number 100
[PE3-bgp] peer 3.3.3.9 connect-interface loopback 0
[PE3-bgp-l2vpn] peer 1.1.1.9 enable
[PE3-bgp-l2vpn] peer 3.3.3.9 enable
[PE3-bgp-l2vpn] quit
[PE3-bgp] quit
[PE3] l2vpn enable
[PE3] vsi user_a
# On PE 3, use BGP to establish a PW to a remote PE discovered by BGP.
[PE3-vsi-user_a-auto] signaling-protocol bgp
# On PE 3, set the site number in the VSI to 3 and the maximum number of sites in the VSI to 25.
[PE3-vsi-user_a-auto-bgp] site 3 range 25
[PE3-vsi-user_a-auto-bgp] quit
# Enable MPLS L2VPN globally.
[PE3] l2vpn enable
[PE3] vsi user_b
[PE3-vsi-user_b-auto] signaling-protocol bgp
[PE3-vsi-user_b-auto-bgp] site 3 range 25
[PE3-vsi-user_b-auto-bgp] quit
<CE1> system-view
[CE1] vlan 100
[CE1-vlan100] quit
[CE1] vlan 200
[CE1-vlan200] quit
Statistics:
1.1.1.9/32         3/-
                   -/1151(L)
# Verify BGP PWs in up state have been established on each PE. This example uses PE 1.
Total number of PWs: 2, 2 up, 0 blocked, 0 down, 0 defect
VSI Name: user_a
3.3.3.9         2                 131074/131073   BGP     M     257      Up
4.4.4.9         3                 131075/131073   BGP     M     258      Up
VSI Name: user_b
3.3.3.9         2                 131071/131070   BGP     M     257      Up
4.4.4.9         3                 131072/131070   BGP     M     258      Up
Configuration files
·     PE 1:
ospf 1
 area 0.0.0.0
 mpls lsr-id 1.1.1.9
mpls ldp
 l2vpn enable
vsi user_a
 auto-discovery bgp
   site 1 range 25 default-offset 0
vsi user_b
 auto-discovery bgp
interface LoopBack0
 xconnect vsi user_a
 xconnect vsi user_b
 mpls enable
 mpls ldp enable
bgp 100
  peer 3.3.3.9 enable
  peer 4.4.4.9 enable
·     PE 2:
ospf 1
 area 0.0.0.0
 mpls lsr-id 3.3.3.9
mpls ldp
 l2vpn enable
vsi user_a
 auto-discovery bgp
   site 2 range 25 default-offset 0
vsi user_b
 auto-discovery bgp
interface LoopBack0
 mpls enable
 mpls ldp enable
 xconnect vsi user_a
 xconnect vsi user_b
bgp 100
  peer 1.1.1.9 enable
  peer 4.4.4.9 enable
·     PE 3:
ospf 1
 area 0.0.0.0
 mpls lsr-id 4.4.4.9
mpls ldp
 l2vpn enable
vsi user_a
 auto-discovery bgp
   site 3 range 25 default-offset 0
vsi user_b
 auto-discovery bgp
interface LoopBack0
 mpls enable
 mpls ldp enable
 xconnect vsi user_a
 xconnect vsi user_b
bgp 100
  peer 1.1.1.9 enable
  peer 3.3.3.9 enable
·     P:
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
·     CE 1 through CE 10:
vlan 100
vlan 200
Example: Configuring H-VPLS with LSP access
As shown in Figure 4, a customer's branches are connected to the MPLS backbone through UPEs that support MPLS L2VPN.
Configure H-VPLS to allow communication among the branches at Layer 2.
·     Connect the UPEs to the NPEs through LSPs.
·     Configure UPE dual homing to achieve redundancy.
Figure 4 Network diagram
Device
IP address
Device
IP address
UPE 1
Loop0
11.1.1.1/32
UPE 2
Loop0
14.1.1.1/32
GE3/1/3
11.1.2.1/24
GE3/1/3
20.1.2.1/24
GE3/1/4
11.1.3.1/24
GE3/1/4
20.1.1.1/24
NPE 1
Loop0
1.1.1.1/32
NPE 3
Loop0
3.3.3.3/32
GE3/1/3
11.1.2.2/24
GE3/1/3
20.1.2.2/24
NPE 2
Loop0
2.2.2.2/32
NPE 4
Loop0
4.4.4.4/32
GE3/1/4
11.1.3.2/24
GE3/1/4
20.1.1.2/24
Analysis
·     To negotiate inner labels, perform the following tasks:
¡     Configure each UPE and all the NPEs connected to the UPE as LDP peers.
¡     Configure any two NPEs as LDP peers.
·     To achieve NPE redundancy, configure the NPEs that are connected to each UPE as primary and backup peers.
·     To identify packets to be transported by VPLS, configure Layer 3 subinterfaces of the CE-facing interfaces on UPEs.
Procedures
Configuring basic settings
# Create interfaces on UPEs and NPEs and configure IP addresses for the interfaces as shown in Figure 4. (Details not shown.)
# Configure an IGP on the MPLS backbone to ensure that the interfaces of NPEs and UPEs are reachable to each other. (Details not shown.)
# Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs. (Details not shown.)
# Configure the ports of CEs connecting the UPEs as trunk ports that permit tagged packets from VLAN 100 and VLAN 200. (Details not shown.)
Configuring UPE 1
# Configure basic MPLS.
<UPE1> system-view
[UPE1] mpls lsr-id 11.1.1.1
[UPE1] mpls ldp
[UPE1-ldp] quit
# Configure basic MPLS on the interface connected to NPE 1.
[UPE1] interface gigabitethernet 3/1/3
[UPE1-GigabitEthernet3/1/3] mpls enable
[UPE1-GigabitEthernet3/1/3] mpls ldp enable
[UPE1-GigabitEthernet3/1/3] quit
# Configure basic MPLS on the interface connected to NPE 2.
[UPE1] interface gigabitethernet 3/1/4
[UPE1-GigabitEthernet3/1/4] mpls enable
[UPE1-GigabitEthernet3/1/4] mpls ldp enable
[UPE1-GigabitEthernet3/1/4] quit
# Enable MPLS L2VPN.
[UPE1] l2vpn enable
# Create VSI user_a and configure the VSI to use LDP as the PW signaling protocol.
[UPE1] vsi user_a
[UPE1-vsi-user_a] pwsignaling ldp
# Specify the switchover wait time as 120 seconds. When the primary PW recovers, the device waits for 120 seconds before it switches traffic from the backup PW to the primary PW.
[UPE1-vsi-user_a-ldp] revertive wtr 120
# Establish the primary PW (the PW to NPE 1) and the backup PW (the PW to NPE 2).
[UPE1-vsi-user_a-ldp] peer 1.1.1.1 pw-id 500
[UPE1-vsi-user_a-ldp-1.1.1.1-500] backup-peer 2.2.2.2 pw-id 500
[UPE1-vsi-user_a-ldp-1.1.1.1-500-backup] quit
[UPE1-vsi-user_a-ldp-1.1.1.1-500] quit
[UPE1-vsi-user_a-ldp] quit
[UPE1-vsi-user_a] quit
# Create VSI user_b and configure the VSI to use LDP as the PW signaling protocol.
[UPE1] vsi user_b
[UPE1-vsi-user_b] pwsignaling ldp
[UPE1-vsi-user_b-ldp] revertive wtr 120
[UPE1-vsi-user_b-ldp] peer 1.1.1.1 pw-id 600
[UPE1-vsi-user_b-ldp-1.1.1.1-600] backup-peer 2.2.2.2 pw-id 600
[UPE1-vsi-user_b-ldp-1.1.1.1-600-backup] quit
[UPE1-vsi-user_b-ldp-1.1.1.1-600] quit
[UPE1-vsi-user_b-ldp] quit
[UPE1-vsi-user_b] quit
# Create subinterface GigabitEthernet3/1/1.100 on GigabitEthernet3/1/1 (the interface connected to Site A), configure the subinterface to terminate packets whose outermost VLAN ID is 100, and bind the subinterface to VSI user_a.
[UPE1] interface gigabitethernet 3/1/1.100
[UPE1-GigabitEthernet3/1/1.100] vlan-type dot1q vid 100
[UPE1-GigabitEthernet3/1/1.100] xconnect vsi user_a
[UPE1-GigabitEthernet3/1/1.100] quit
# Create subinterface GigabitEthernet3/1/1.200, configure the subinterface to terminate packets whose outermost VLAN ID is 200, and bind the subinterface to VSI user_b.
[UPE1] interface gigabitethernet 3/1/1.200
[UPE1-GigabitEthernet3/1/1.200] vlan-type dot1q vid 200
[UPE1-GigabitEthernet3/1/1.200] xconnect vsi user_b
[UPE1-GigabitEthernet3/1/1.200] quit
# Create subinterface GigabitEthernet3/1/2.100 on GigabitEthernet3/1/2 (the interface connected to Site B), configure the subinterface to terminate packets whose outermost VLAN ID is 100, and bind the subinterface to VSI user_a.
[UPE1] interface gigabitethernet 3/1/2.100
[UPE1-GigabitEthernet3/1/2.100] vlan-type dot1q vid 100
[UPE1-GigabitEthernet3/1/2.100] xconnect vsi user_a
[UPE1-GigabitEthernet3/1/2.100] quit
# Create subinterface GigabitEthernet3/1/2.200, configure the subinterface to terminate packets whose outermost VLAN ID is 200, and bind the subinterface to VSI user_b.
[UPE1] interface gigabitethernet 3/1/2.200
[UPE1-GigabitEthernet3/1/2.200] vlan-type dot1q vid 200
[UPE1-GigabitEthernet3/1/2.200] xconnect vsi user_b
[UPE1-GigabitEthernet3/1/2.200] quit
Configuring NPE 1
# Configure basic MPLS on the interface connected to UPE 1.
<NPE1> system-view
[NPE1] interface gigabitethernet 3/1/3
[NPE1-GigabitEthernet 3/1/3] mpls enable
[NPE1-GigabitEthernet 3/1/3] mpls ldp enable
[NPE1-GigabitEthernet 3/1/3] quit
[NPE1] l2vpn enable
[NPE1] vsi user_a
[NPE1-vsi-user_a] pwsignaling ldp
# Establish a PW to UPE 1.
[NPE1-vsi-user_a-ldp] peer 11.1.1.1 pw-id 500 no-split-horizon
[NPE1-vsi-user_a-ldp-11.1.1.1-500] quit
# Establish a PW to NPE 2.
[NPE1-vsi-user_a-ldp] peer 2.2.2.2 pw-id 500
[NPE1-vsi-user_a-ldp-2.2.2.2-500] quit
# Establish a PW to NPE 3.
[NPE1-vsi-user_a-ldp] peer 3.3.3.3 pw-id 500
[NPE1-vsi-user_a-ldp-3.3.3.3-500] quit
# Establish a PW to NPE 4.
[NPE1-vsi-user_a-ldp] peer 4.4.4.4 pw-id 500
[NPE1-vsi-user_a-ldp-4.4.4.4-500] quit
[NPE1-vsi-user_a-ldp] quit
[NPE1-vsi-user_a] quit
[NPE1] vsi user_b
[NPE1-vsi-user_b] pwsignaling ldp
[NPE1-vsi-user_b-ldp] peer 11.1.1.1 pw-id 600 no-split-horizon
[NPE1-vsi-user_b-ldp-11.1.1.1-500] quit
[NPE1-vsi-user_b-ldp] peer 2.2.2.2 pw-id 600
[NPE1-vsi-user_b-ldp-2.2.2.2-600] quit
[NPE1-vsi-user_b-ldp] peer 3.3.3.3 pw-id 600
[NPE1-vsi-user_b-ldp-3.3.3.3-600] quit
[NPE1-vsi-user_b-ldp] peer 4.4.4.4 pw-id 600
[NPE1-vsi-user_b-ldp-4.4.4.4-600] quit
[NPE1-vsi-user_b-ldp] quit
[NPE1-vsi-user_b] quit
Configuring NPE 2
# Configure NPE 2 in the same way that NPE 1 is configured. (Details not shown.)
Configuring UPE 2
<UPE2> system-view
[UPE2] mpls lsr-id 14.1.1.1
[UPE2] mpls ldp
[UPE2-ldp] quit
# Configure basic MPLS on the interface connected to NPE 3.
[UPE2] interface gigabitethernet 3/1/3
[UPE2-GigabitEthernet3/1/3] mpls enable
[UPE2-GigabitEthernet3/1/3] mpls ldp enable
[UPE2-GigabitEthernet3/1/3] quit
# Configure basic MPLS on the interface connected to NPE 4.
[UPE2] interface gigabitethernet 3/1/4
[UPE2-GigabitEthernet3/1/4] mpls enable
[UPE2-GigabitEthernet3/1/4] mpls ldp enable
[UPE2-GigabitEthernet3/1/4] quit
[UPE2] l2vpn enable
[UPE2] vsi user_a
[UPE2-vsi-user_a] pwsignaling ldp
[UPE2-vsi-user_a-ldp] revertive wtr 120
# Establish the primary PW (the PW to NPE 3) and the backup PW (the PW to NPE 4).
[UPE2-vsi-user_a-ldp] peer 3.3.3.3 pw-id 500
[UPE2-vsi-user_a-ldp-3.3.3.3-500] backup-peer 4.4.4.4 pw-id 500
[UPE2-vsi-user_a-ldp-3.3.3.3-500-backup] quit
[UPE2-vsi-user_a-ldp-3.3.3.3-500] quit
[UPE2-vsi-user_a-ldp] quit
[UPE2-vsi-user_a] quit
[UPE2] vsi user_b
[UPE2-vsi-user_b] pwsignaling ldp
[UPE2-vsi-user_b-ldp] revertive wtr 120
[UPE2-vsi-user_b-ldp] peer 3.3.3.3 pw-id 600
[UPE2-vsi-user_b-ldp-3.3.3.3-600] backup-peer 4.4.4.4 pw-id 600
[UPE2-vsi-user_b-ldp-3.3.3.3-600-backup] quit
[UPE2-vsi-user_b-ldp-3.3.3.3-600] quit
[UPE2-vsi-user_b-ldp] quit
[UPE2-vsi-user_b] quit
# Create subinterface GigabitEthernet3/1/1.100 on GigabitEthernet3/1/1 (the interface connected to Site E), configure the subinterface to terminate packets whose outermost VLAN ID is 100, and bind the subinterface to VSI user_a.
[UPE2] interface gigabitethernet 3/1/1.100
[UPE2-GigabitEthernet3/1/1.100] vlan-type dot1q vid 100
[UPE2-GigabitEthernet3/1/1.100] xconnect vsi user_a
[UPE2-GigabitEthernet3/1/1.100] quit
[UPE2] interface gigabitethernet 3/1/1.200
[UPE2-GigabitEthernet3/1/1.200] vlan-type dot1q vid 200
[UPE2-GigabitEthernet3/1/1.200] xconnect vsi user_b
[UPE2-GigabitEthernet3/1/1.200] quit
Configuring NPE 3
# Configure basic MPLS on the interface connected to UPE 2.
[NPE3] interface gigabitethernet 3/1/3
[NPE3-GigabitEthernet3/1/3] mpls enable
[NPE3-GigabitEthernet3/1/3] mpls ldp enable
[NPE3-GigabitEthernet3/1/3] quit
[NPE3] l2vpn enable
[NPE3] vsi user_a
[NPE3-vsi-user_a] pwsignaling ldp
# Establish a PW to UPE 2.
[NPE3-vsi-user_a-ldp] peer 14.1.1.1 pw-id 500 no-split-horizon
[NPE3-vsi-user_a-ldp-14.1.1.1-500] quit
# Establish a PW to NPE 1.
[NPE3-vsi-user_a-ldp] peer 1.1.1.1 pw-id 500
[NPE3-vsi-user_a-ldp-1.1.1.1-500] quit
[NPE3-vsi-user_a-ldp] peer 2.2.2.2 pw-id 500
[NPE3-vsi-user_a-ldp-2.2.2.2-500] quit
[NPE3-vsi-user_a-ldp] peer 4.4.4.4 pw-id 500
[NPE3-vsi-user_a-ldp-4.4.4.4-500] quit
[NPE3-vsi-user_a-ldp] quit
[NPE3-vsi-user_a] quit
[NPE3] vsi user_b
[NPE3-vsi-user_b] pwsignaling ldp
[NPE3-vsi-user_b-ldp] peer 14.1.1.1 pw-id 600 no-split-horizon
[NPE3-vsi-user_b-ldp-14.1.1.1-600] quit
[NPE3-vsi-user_b-ldp] peer 1.1.1.1 pw-id 600
[NPE3-vsi-user_b-ldp-1.1.1.1-600] quit
[NPE3-vsi-user_b-ldp] peer 2.2.2.2 pw-id 600
[NPE3-vsi-user_b-ldp-2.2.2.2-600] quit
[NPE3-vsi-user_b-ldp] peer 4.4.4.4 pw-id 600
[NPE3-vsi-user_b-ldp-4.4.4.4-600] quit
[NPE3-vsi-user_b-ldp] quit
[NPE3-vsi-user_b] quit
Configuring NPE 4
# Configure NPE 4 in the same way that NPE 3 is configured. (Details not shown.)
# Verify that LDP PWs in up state have been established on each UPE. This example uses UPE 1.
[UPE1] display l2vpn pw
Total number of PWs: 4, 4 up, 0 blocked, 0 down, 0 defect
VSI Name: user_a
1.1.1.1         500               131199/131199   LDP     M     256      Up
2.2.2.2         500               131198/131199   LDP     B     257      Blocked
VSI Name: user_b
1.1.1.1         600               131195/131195   LDP     M     256      Up
2.2.2.2         600               131194/131195   LDP     B     257      Blocked
# Verify that LDP PWs in up state have been established on each NPE. This example uses NPE 1.
[NPE1] display l2vpn pw
VSI Name: user_a
2.2.2.2         500               131199/131199   LDP     M     256      Up
3.3.3.3         500               131198/131198   LDP     M     257      Up
4.4.4.4         500               131197/131197   LDP     M     258      Up
11.1.1.1        500               131196/131196   LDP     MN    259      Up
VSI Name: user_b
2.2.2.2         600               131195/131195   LDP     M     256      Up
3.3.3.3         600               131194/131194   LDP     M     257      Up
4.4.4.4         600               131193/131193   LDP     M     258      Up
11.1.1.1        600               131192/131192   LDP     MN    259      Up
Configuration files
The following lists only the H-VPLS-related configuration files. CE configuration and PE routing configuration are not shown.
·     UPE 1:
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
  revertive wtr 120
vsi user_b
 pwsignaling ldp
  revertive wtr 120
interface LoopBack0
 ip address 11.1.1.1 255.255.255.255
 xconnect vsi user_a
 xconnect vsi user_b
 xconnect vsi user_a
 xconnect vsi user_b
 ip address 11.1.2.1 255.255.255.0
 mpls enable
 mpls ldp enable
interface GigabitEthernet3/1/4
 ip address 11.1.3.1 255.255.255.0
 mpls enable
 mpls ldp enable
·     NPE 1:
 mpls lsr-id 1.1.1.1
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
vsi user_b
 pwsignaling ldp
interface LoopBack0
 ip address 1.1.1.1 255.255.255.255
 ip address 11.1.2.2 255.255.255.0
 mpls enable
 mpls ldp enable
·     NPE 2:
 mpls lsr-id 2.2.2.2
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
vsi user_b
 pwsignaling ldp
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
 ip address 11.1.3.2 255.255.255.0
 mpls enable
 mpls ldp enable
·     UPE 2:
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
  revertive wtr 120
vsi user_b
 pwsignaling ldp
  revertive wtr 120
interface LoopBack0
 ip address 14.1.1.1 255.255.255.255
 ip address 20.1.2.1 255.255.255.0
 mpls enable
 mpls ldp enable
 ip address 20.1.1.1 255.255.255.0
 mpls enable
 mpls ldp enable
 xconnect vsi user_a
 xconnect vsi user_b
·     NPE 3:
 mpls lsr-id 3.3.3.3
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
vsi user_a
 pwsignaling ldp
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
 ip address 20.1.2.2 255.255.255.0
 mpls enable
 mpls ldp enable
·     NPE 4:
 mpls lsr-id 4.4.4.4
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
interface LoopBack0
 ip address 4.4.4.4 255.255.255.255
 ip address 20.1.1.2 255.255.255.0
 mpls enable
 mpls ldp enable
Example: Configuring H-VPLS with QinQ access
As shown in Figure 5, a customer's branches are connected to the MPLS backbone through UPEs that do not support MPLS L2VPN.
·     Connect the UPEs to the NPEs through QinQ tunnels.
Figure 5 Network diagram
Analysis
·     For NPEs to identify user traffic, enable QinQ and add an outer tag (the provider VLAN tag) to upstream packets on the downlink port of each UPE.
·     To forward packets from a UPE through the bound PW, configure Layer 3 subinterfaces to match the outer provider tag of packets on the downlink port of each NPE.
·     To negotiate inner labels, configure any two NPEs as LDP peers.
·     To retain the VLAN information for each site, you can configure both the AC access mode and the PW type as VLAN. By default, the AC access mode and the PW type are VLAN.
Procedures
# Configure an IGP on the MPLS backbone to ensure that the interfaces of NPEs are reachable to each other. (Details not shown.)
Configuring UPE 1
# Configure GigabitEthernet 3/1/1 to operate in bridge mode, enable QinQ on GigabitEthernet 3/1/1, and add an outer provider VLAN tag of 1000 to packets.
<UPE1> system-view
[UPE1] vlan 1000
[UPE1-vlan1000] quit
[UPE1-GigabitEthernet3/1/1] port link-mode bridge
[UPE1-GigabitEthernet3/1/1] port access vlan 1000
[UPE1-GigabitEthernet3/1/1] qinq enable
[UPE1-GigabitEthernet3/1/1] quit
# Configure GigabitEthernet 3/1/2 to operate in bridge mode, enable QinQ on GigabitEthernet 3/1/2, and add an outer provider VLAN tag of 1000 to packets.
[UPE1-GigabitEthernet3/1/2] port link-mode bridge
[UPE1-GigabitEthernet3/1/2] port access vlan 1000
[UPE1-GigabitEthernet3/1/2] qinq enable
[UPE1-GigabitEthernet3/1/2] quit
# Configure GigabitEthernet 3/1/3 to operate in bridge mode and configure the interface as a trunk port that allows forwarding packets tagged with VLAN 1000 to NPE 1.
[UPE1-GigabitEthernet3/1/3] port link-mode bridge
[UPE1-GigabitEthernet3/1/3] port link-type trunk
[UPE1-GigabitEthernet3/1/3] port trunk permit vlan 1000
# Configure GigabitEthernet 3/1/4 to operate in bridge mode and configure the interface as a trunk port that allows forwarding packets tagged with VLAN 1000 to NPE 2.
[UPE1-GigabitEthernet3/1/4] port link-mode bridge
[UPE1-GigabitEthernet3/1/4] port link-type trunk
[UPE1-GigabitEthernet3/1/4] port trunk permit vlan 1000
Configuring NPE 1
[NPE1] l2vpn enable
[NPE1] vsi user_a
# Create subinterface GigabitEthernet3/1/1.1000, and configure the subinterface to terminate packets whose outermost VLAN ID is 1000. Bind the subinterface with VSI user_a.
[NPE1] interface gigabitethernet 3/1/1.1000
[NPE1-GigabitEthernet3/1/1.1000] vlan-type dot1q vid 1000
[NPE1-GigabitEthernet3/1/1.1000] xconnect vsi user_a
[NPE1-GigabitEthernet3/1/1.1000] quit
Configuring NPE 2
Configuring UPE 2
# Enable QinQ on GigabitEthernet3/1/1 and add an outer provider VLAN tag of 1000 to packets. The VLAN tag must be the same as that configured on UPE 1.
<UPE2> system-view
[UPE2] vlan 1000
[UPE2-vlan1000] quit
[UPE2-GigabitEthernet3/1/1] port link-mode bridge
[UPE2-GigabitEthernet3/1/1] port access vlan 1000
[UPE2-GigabitEthernet3/1/1] qinq enable
[UPE2-GigabitEthernet3/1/1] quit
# Configure GigabitEthernet3/1/3 to operate in bridge mode and configure the interface as a trunk port that allows forwarding packets tagged with VLAN 1000 to NPE 3.
[UPE2-GigabitEthernet3/1/3] port link-type trunk
[UPE2-GigabitEthernet3/1/3] port trunk permit vlan 1000
# Configure GigabitEthernet3/1/4 to operate in bridge mode and configure the interface as a trunk port that allows forwarding packets tagged with VLAN 1000 to NPE 4.
[UPE2-GigabitEthernet3/1/4] port link-type trunk
[UPE2-GigabitEthernet3/1/4] port trunk permit vlan 1000
Configuring NPE 3
[NPE3] l2vpn enable
[NPE3] vsi user_a
[NPE3] interface gigabitethernet 3/1/1.1000
[NPE3-GigabitEthernet3/1/1.1000] vlan-type dot1q vid 1000
[NPE3-GigabitEthernet3/1/1.1000] xconnect vsi user_a
[NPE3-GigabitEthernet3/1/1.1000] quit
Configuring NPE 4
Total number of PWs: 3, 3 up, 0 blocked, 0 down, 0 defect
VSI Name: user_a
Configuration files
·     UPE 1:
vlan 1000
 qinq enable
 qinq enable
 port trunk permit vlan 1 1000
·     NPE 1:
 mpls lsr-id 1.1.1.1
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
 xconnect vsi user_a
·     NPE 2:
 mpls lsr-id 2.2.2.2
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
 xconnect vsi user_a
·     UPE 2:
vlan 1000
 qinq enable
·     NPE 3:
 mpls lsr-id 3.3.3.3
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
 xconnect vsi user_a
·     NPE 4:
 mpls lsr-id 4.4.4.4
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
 xconnect vsi user_a
Related documentation
·     H3C SR8800-F Routers MPLS Configuration Guide-R7951P01
·     H3C SR8800-F Routers MPLS Command Reference-R7951P01
