- H3C S12500R Switch Router Series Installation Guide-5W100
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Device
- 03-Chapter 3 Installing FRUs
- 04-Chapter 4 Connecting Your Device to the Network
- 05-Chapter 5 Troubleshooting
- 06-Chapter 6 Replacement Procedures
- 07-Appendix A Engineering labels
- 08-Appendix B Cabling Recommendations
- 09-Appendix C Repackaging the Device
00-Preface | 81.22 KB |
Preface
This installation guides you through installation of your S12500R switch router, including preparing for installation, installing the device, installing FRUs, connecting the device to the network, troubleshooting, and replacement procedures.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S12500R switch routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
