- 12-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-IP forwarding basics commands
- 06-Fast forwarding commands
- 07-Multi-CPU packet distribution commands
- 08-Adjacency table commands
- 09-IP performance optimization commands
- 10-IPv6 basics commands
- 11-DHCPv6 commands
- 12-IPv6 fast forwarding commands
07-Multi-CPU packet distribution commands | 40.14 KB |
forwarding policy
Use forwarding policy to specify a multi-CPU packet distribution policy.
Use undo forwarding policy to restore the default.
forwarding policy { per-flow [ three-tuple ] | per-packet }
The device uses the flow-based policy, which identifies a flow by source IP address, destination IP address, source port number, destination port number, and protocol number.
context-admin
per-flow: Specifies the flow-based forwarding. The device identifies a data flow by the five-tuple, and forwards packets of the same flow to one CPU. The CPU processes flow packets by following the first-in first-out rule.
mode: Specifies a flow-based forwarding mode.
destination-ip: Identifies a flow by destination IP address.
destination-port: Identifies a flow by destination port.
source-ip: Identifies a flow by source IP address.
source-port: Identifies a flow by source port.
three-tuple: Identifies a data flow by the three-tuple (source IP address, destination IP address, and protocol number).
The following compatibility matrix shows the support of hardware platforms for this keyword:
Hardware |
Parameter compatibility |
F1000-A-G3, F1000-C-G3, F1000-E-G3, F1000-S-G3 |
Yes |
F100-C-G3, F100-M-G3, F100-S-G3 |
Yes |
F100-A-G3, F100-E-G3 |
No |
F1000-S-VG |
Yes |
F1000-E-VG |
No |
F1000-A-G2, F1000-C-G2, F1000-E-G2, F1000-S-G2 |
No |
F100-C-G2, F100-M-G2, F100-S-G2 |
Yes |
F100-A-G2, F100-E-G2 |
No |
F100-C-EI |
Yes |
F1000-C-EI, F100-A-EI, F100-A-SI, F100-E-EI |
No |
F100-C80-WiNet, F100-C60-WiNet, F100-C50-WiNet, F100-S80-WiNet |
Yes |
F100-A80-WiNet |
No |
F1000-C8150, F1000-C8130, F1000-C8120, F1000-C8110 |
Yes |
F1000-C8180, F1000-C8170, F1000-C8160 |
No |
F100-C-A6, F100-C-A5, F100-C-A3 |
Yes |
F100-C-A6-WL, F100-C-A5-W, F100-C-A3-W |
Yes |
F100-C-HI, F100-S-HI |
Yes |
F1000-C-HI, F100-A-HI |
No |
F1000-990-AI, F1000-980-AI, F1000-970-AI, F1000-960-AI, F1000-950-AI, F1000-930-AI, F1000-920-AI |
No |
LSPM6FWD8, LSQM2FWDSC8 |
Yes |
per-packet: Specifies the packet-based forwarding. The device forwards packets in sequence to different CPUs, even though they are the same flow. This policy does not ensure packet order.
If you do not specify any keyword for flow identification, the device identifies a flow by source IP address, destination IP address, source port number, destination port number, and protocol number.
# Specify the three-tuple flow-based policy.
[Sysname] forwarding policy per-flow three-tuple
