10-Security Configuration Guide
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration GuidesH3C S7500E Switch Series Configuration Guides-Release758X-6W10010-Security Configuration Guide
05-Port security configuration
05-Port security configuration 231.68 KB
Configuring port security· 1
Overview· 1
Port security features· 1
Port security modes· 1
General guidelines and restrictions· 4
Configuration task list 4
Enabling port security· 5
Setting port security's limit on the number of secure MAC addresses on a port 6
Setting the port security mode· 6
Configuring port security features· 7
Configuring NTK· 7
Configuring intrusion protection· 8
Configuring secure MAC addresses· 9
Configuration prerequisites· 10
Configuration procedure· 10
Setting port security's limit on the number of MAC addresses for specific VLANs on a port 10
Overview· 10
Configuration restrictions and guidelines· 11
Configuration procedure· 11
Ignoring authorization information from the server 11
Enabling MAC move· 11
Enabling the authorization-fail-offline feature· 12
Overview· 12
Configuration prerequisites· 13
Configuration procedure· 13
Enabling open authentication mode· 13
Overview· 13
Configuration restrictions and guidelines· 13
Configuration procedure· 14
Configuring free VLANs for port security· 14
Applying a NAS-ID profile to port security· 15
Enabling the escape critical VSI feature for 802.1X and MAC authentication users· 15
Overview· 15
Configuration restrictions and guidelines· 16
Configuration prerequisites· 16
Enabling the escape critical VSI feature globally· 16
Enabling the escape critical VSI feature on a port 16
Enabling SNMP notifications for port security· 17
Enabling port security user logging· 17
Overview· 17
Configuration restrictions and guidelines· 17
Configuration procedure· 17
Displaying and maintaining port security· 18
Port security configuration examples· 18
autoLearn configuration example· 18
userLoginWithOUI configuration example· 20
macAddressElseUserLoginSecure configuration example· 23
Troubleshooting port security· 27
Cannot set the port security mode· 27
Cannot configure secure MAC addresses· 27
Overview
Port security combines and extends 802.1X and MAC authentication to provide MAC-based network access control. This feature applies to networks, such as a WLAN, that require different authentication methods for different users on a port.
Port security provides the following functions:
·     Prevents unauthorized access to a network by checking the source MAC address of inbound traffic.
·     Prevents access to unauthorized devices or hosts by checking the destination MAC address of outbound traffic.
·     Controls MAC address learning and authentication on a port to make sure the port learns only source trusted MAC addresses.
A frame is illegal if its source MAC address cannot be learned in a port security mode or it is from a client that has failed 802.1X or MAC authentication. The port security feature automatically takes a predefined action on illegal frames. This automatic mechanism enhances network security and reduces human intervention.
As a best practice, use the 802.1X authentication or MAC authentication feature rather than port security for scenarios that require only 802.1X authentication or MAC authentication. For more information about 802.1X and MAC authentication, see "Configuring 802.1X" and "Configuring MAC authentication."
NTK
The need to know (NTK) feature prevents traffic interception by checking the destination MAC address in the outbound frames. The feature ensures that frames are sent only to the following hosts:
·     Hosts that have passed authentication.
·     Hosts whose MAC addresses have been learned or configured on the access device.
Intrusion protection
The intrusion protection feature checks the source MAC address in inbound frames for illegal frames, and takes a predefined action on each detected illegal frame. The action can be disabling the port temporarily, disabling the port permanently, or blocking frames from the illegal MAC address for a period set by the MAC block timer.
Port security modes
Port security supports the following categories of security modes:
·     MAC learning control—Includes two modes: autoLearn and secure. MAC address learning is permitted on a port in autoLearn mode and disabled in secure mode.
·     Authentication—Security modes in this category implement MAC authentication, 802.1X authentication, or a combination of these two authentication methods.
Upon receiving a frame, the port in a security mode searches the MAC address table for the source MAC address. If a match is found, the port forwards the frame. If no match is found, the port learns the MAC address or performs authentication, depending on the security mode. If the frame is illegal, the port takes the predefined NTK or intrusion protection action, or sends SNMP notifications. Outgoing frames are not restricted by port security's NTK action unless they trigger the NTK feature.
The maximum number of users a port supports equals the smaller value from the following values:
·     The maximum number of secure MAC addresses that port security allows.
·     The maximum number of concurrent users the authentication mode in use allows.
For example, if 802.1X allows more concurrent users than port security's limit on the number of MAC addresses on the port in userLoginSecureExt mode, port security's limit takes effect.
Table 1 describes the port security modes and the security features.
Table 1 Port security modes
Purpose
Security mode
Features that can be triggered
Turning off the port security feature
noRestrictions (the default mode)
In this mode, port security is disabled on the port and access to the port is not restricted.
N/A
Controlling MAC address learning
autoLearn
NTK/intrusion protection
secure
Performing 802.1X authentication
userLogin
N/A
userLoginSecure
userLoginSecureExt
userLoginWithOUI
Performing MAC authentication
macAddressWithRadius
Performing a combination of MAC authentication and 802.1X authentication
Or
macAddressOrUserLoginSecure
macAddressOrUserLoginSecureExt
Else
macAddressElseUserLoginSecureExt
TIP
TIP:
·     userLogin specifies 802.1X authentication and port-based access control. userLogin with Secure specifies 802.1X authentication and MAC-based access control. Ext indicates allowing multiple 802.1X users to be authenticated and serviced at the same time. A security mode without Ext allows only one user to pass 802.1X authentication.
·     macAddress specifies MAC authentication.
·     Else specifies that the authentication method before Else is applied first. If the authentication fails, whether to turn to the authentication method following Else depends on the protocol type of the authentication request.
·     Or specifies that the authentication method following Or is applied first. If the authentication fails, the authentication method before Or is applied.
·     autoLearn.
A port in this mode can learn MAC addresses. The automatically learned MAC addresses are not added to the MAC address table as dynamic MAC address. Instead, these MAC addresses are added to the secure MAC address table as secure MAC addresses. You can also configure secure MAC addresses by using the port-security mac-address security command.
A port in autoLearn mode allows frames sourced from the following MAC addresses to pass:
¡     Secure MAC addresses.
¡     MAC addresses configured by using the mac-address dynamic and mac-address static commands.
When the number of secure MAC addresses reaches the upper limit, the port transitions to secure mode.
·     secure.
MAC address learning is disabled on a port in secure mode. You configure MAC addresses by using the mac-address static and mac-address dynamic commands. For more information about configuring MAC address table entries, see Layer 2—LAN Switching Configuration Guide.
A port in secure mode allows only frames sourced from the following MAC addresses to pass:
·     userLogin.
A port in this mode performs 802.1X authentication and implements port-based access control. The port can service multiple 802.1X users. Once an 802.1X user passes authentication on the port, any subsequent 802.1X users can access the network through the port without authentication.
·     userLoginSecure.
A port in this mode performs 802.1X authentication and implements MAC-based access control. The port services only one user passing 802.1X authentication.
·     userLoginSecureExt.
This mode is similar to the userLoginSecure mode except that this mode supports multiple online 802.1X users.
·     userLoginWithOUI.
This mode is similar to the userLoginSecure mode. The difference is that a port in this mode also permits frames from one user whose MAC address contains a specific OUI.
In this mode, the port performs OUI check at first. If the OUI check fails, the port performs 802.1X authentication. The port permits frames that pass OUI check or 802.1X authentication.
An OUI is a 24-bit number that uniquely identifies a vendor, manufacturer, or organization. In MAC addresses, the first three octets are the OUI.
macAddressWithRadius: A port in this mode performs MAC authentication, and services multiple users.
·     macAddressOrUserLoginSecure.
This mode is the combination of the macAddressWithRadius and userLoginSecure modes. The mode allows one 802.1X authentication user and multiple MAC authentication users to log in.
In this mode, the port performs 802.1X authentication first. By default, if 802.1X authentication fails, MAC authentication is performed.
However, the port in this mode processes authentication differently when the following conditions exist:
¡     The port is enabled with parallel processing of MAC authentication and 802.1X authentication.
¡     The port performs MAC-based access control for 802.1X authentication.
¡     The port is enabled with the 802.1X unicast trigger.
¡     The port receives a packet from a unknown MAC address.
Under such conditions, the port sends a unicast EAP-Request/Identity packet to the MAC address to initiate 802.1X authentication. After that, the port immediately processes MAC authentication without waiting for the 802.1X authentication result.
·     macAddressOrUserLoginSecureExt.
This mode is similar to the macAddressOrUserLoginSecure mode, except that this mode supports multiple 802.1X and MAC authentication users.
·     macAddressElseUserLoginSecure.
This mode is the combination of the macAddressWithRadius and userLoginSecure modes, with MAC authentication having a higher priority as the Else keyword implies. The mode allows one 802.1X authentication user and multiple MAC authentication users to log in.
In this mode, the port performs MAC authentication upon receiving non-802.1X frames. Upon receiving 802.1X frames, the port performs MAC authentication and then, if the authentication fails, 802.1X authentication.
·     macAddressElseUserLoginSecureExt.
This mode is similar to the macAddressElseUserLoginSecure mode except that this mode supports multiple 802.1X and MAC authentication users as the Ext keyword implies.
When you configure port security, follow these restrictions and guidelines:
·     A Layer 2 Ethernet interface supports all port security settings in this chapter. A Layer 2 aggregate interface does not support the following port security settings:
¡     The port security mode of autolearn, secure, or userlogin-withoui.
¡     The secure MAC address configuration.
·     After a Layer 2 Ethernet interface is added to an aggregation group, the port security configuration on the port does not take effect.
·     Do not delete a Layer 2 aggregate interface if the interface has online 802.1X or MAC authentication users.
In this chapter, the term "port" refers to a Layer 2 Ethernet interface or a Layer 2 aggregate interface.
Tasks at a glance
Remarks
(Required.) Enabling port security
N/A
(Optional.) Setting port security's limit on the number of secure MAC addresses on a port
N/A
(Required.) Setting the port security mode
N/A
(Required.) Configuring port security features:
·     Configuring NTK
·     Configuring intrusion protection
Configure one or more port security features according to the network requirements.
(Optional.) Configuring secure MAC addresses
N/A
(Optional.) Setting port security's limit on the number of MAC addresses for specific VLANs on a port
N/A
(Optional.) Configuring extended port security features:
·     Ignoring authorization information from the server
·     Enabling MAC move
·     Enabling the authorization-fail-offline feature
·     Enabling open authentication mode
·     Configuring free VLANs for port security
·     Applying a NAS-ID profile to port security
The extended port security features can also take effect when port security is disabled but 802.1X or MAC authentication is enabled.
(Optional.) Enabling the escape critical VSI feature for 802.1X and MAC authentication users
Perform this task to enable 802.1X and MAC authentication users to bypass authentication and access the network when the RADIUS server is malfunctioning or unreachable.
(Optional.) Enabling SNMP notifications for port security
N/A
(Optional.) Enabling port security user logging
N/A
Before you enable port security, disable 802.1X and MAC authentication globally.
When port security is enabled, you cannot enable 802.1X or MAC authentication, or change the access control mode or port authorization state. Port security automatically modifies these settings in different security modes.
To enable port security:
Step
Remarks
N/A
2.     Enable port security.
port-security enable
By default, port security is disabled.
You can use the undo port-security enable command to disable port security. Because the command logs off the online users, make sure no online users are present.
Enabling or disabling port security resets the following security settings to the default:
·     802.1X access control mode is MAC-based.
·     Port authorization state is auto.
For more information about 802.1X authentication and MAC authentication configuration, see "Configuring 802.1X" and "Configuring MAC authentication."
You can set the maximum number of secure MAC addresses that port security allows on a port for the following purposes:
·     Controlling the number of concurrent users on the port.
For a port operating in a security mode (except for autoLearn and secure), the upper limit equals the smaller of the following values:
¡     The limit of the secure MAC addresses that port security allows.
¡     The limit of concurrent users allowed by the authentication mode in use.
·     Controlling the number of secure MAC addresses on the port in autoLearn mode.
For a port operating in autoLearn mode, you can set the maximum number of secure MAC addresses for all or specific VLANs. When the number of MAC addresses in a VLAN reaches the upper limit, intrusion detection is triggered.
Port security's limit on the number of secure MAC addresses on a port is independent of the MAC learning limit described in MAC address table configuration. For more information about MAC address table configuration, see Layer 2—LAN Switching Configuration Guide.
To set the maximum number of secure MAC addresses allowed on a port:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Set the maximum number of secure MAC addresses allowed on a port.
port-security max-mac-count max-count  [ vlan [ vlan-id-list ] ]
By default, port security does not limit the number of secure MAC addresses on a port.
Before you set a port security mode for a port, complete the following tasks:
·     Disable 802.1X and MAC authentication.
·     Verify that the port does not belong to an aggregation group or service loopback group.
·     If you are configuring the autoLearn mode, set port security's limit on the number of secure MAC addresses. You cannot change the setting when the port is operating in autoLearn mode.
When you set the port security mode, follow these guidelines:
·     You can specify a port security mode when port security is disabled, but your configuration cannot take effect.
·     Changing the port security mode of a port logs off the online users of the port.
·     Do not enable 802.1X authentication or MAC authentication on a port where port security is configured.
·     The device supports the URL attribute assigned by a RADIUS server in the following port security modes:
¡     mac-authentication.
¡     mac-else-userlogin-secure.
¡     mac-else-userlogin-secure-ext.
¡     userlogin-secure.
¡     userlogin-secure-ext.
¡     userlogin-secure-or-mac.
¡     userlogin-secure-or-mac-ext.
¡     userlogin-withoui.
During authentication, the HTTP or HTTPS requests of a user are redirected to the Web interface specified by the server-assigned URL attribute. After the user passes the Web authentication, the RADIUS server records the MAC address of the user and uses a DM (Disconnect Message) to log off the user. When the user initiates 802.1X or MAC authentication again, it will pass the authentication and come online successfully.
To redirect the HTTPS requests of port security users, specify the HTTPS redirect listening port on the device. For more information, see HTTP redirect in Layer 3—IP Services Configuration Guide.
·     For the userlogin-withoui mode, OUIs specified for user authentication are not supported if authorization VSI information is used.
To set the port security mode:
Step
Remarks
N/A
2.     (Optional.) Set an OUI value for user authentication.
port-security oui index index-value mac-address oui-value
By default, no OUI values are configured for user authentication.
This command is required for the userlogin-withoui mode.
You can set multiple OUIs, but when the port security mode is userlogin-withoui, the port allows one 802.1X user and only one user that matches one of the specified OUIs.
3.     Enter interface view.
To specify the autoLearn, secure, or userLoginWithOUI mode, you must enter Layer 2 Ethernet interface view.
4.     Set the port security mode.
port-security port-mode { autolearn | mac-authentication | mac-else-userlogin-secure | mac-else-userlogin-secure-ext | secure | userlogin | userlogin-secure | userlogin-secure-ext | userlogin-secure-or-mac | userlogin-secure-or-mac-ext | userlogin-withoui }
By default, a port operates in noRestrictions mode.
After enabling port security, you can change the port security mode of a port only when the port is operating in noRestrictions (the default) mode. To change the port security mode for a port in any other mode, first use the undo port-security port-mode command to restore the default port security mode.
Configuring NTK
The NTK feature checks the destination MAC address in outbound frames to make sure frames are forwarded only to trustworthy devices.
The NTK feature supports the following modes:
·     ntkonly—Forwards only unicast frames with an authenticated destination MAC address.
·     ntk-withbroadcasts—Forwards only broadcast and unicast frames with an authenticated destination MAC address.
·     ntk-withmulticasts—Forwards only broadcast, multicast, and unicast frames with an authenticated destination MAC address.
·     ntkauto—Forwards only broadcast, multicast, and unicast frames with an authenticated destination MAC address, and only when the port has online users.
The NTK feature drops any unicast frame with an unknown destination MAC address. Not all port security modes support triggering the NTK feature. For more information, see Table 1.
To configure the NTK feature:
Step
Remarks
N/A
N/A
3.     Configure the NTK feature.
port-security ntk-mode { ntk-withbroadcasts | ntk-withmulticasts | ntkauto | ntkonly }
By default, NTK is disabled on a port and all frames are allowed to be sent.
Intrusion protection takes one of the following actions on a port in response to illegal frames:
·     blockmac—Adds the source MAC addresses of illegal frames to the blocked MAC address list, and then discards frames sourced from blocked MAC addresses for a period set by the block timer. A blocked MAC address will be unblocked when the block timer expires.
·     disableport—Disables the port until you bring it up manually.
·     disableport-temporarily—Disables the port for a period of time. The period can be configured with the port-security timer disableport command.
To configure the intrusion protection feature:
Step
Remarks
N/A
N/A
3.     Configure the intrusion protection feature.
port-security intrusion-mode { blockmac | disableport | disableport-temporarily }
By default, intrusion protection is disabled.
4.     Return to system view.
N/A
5.     (Optional.) Set the silence timeout period during which a port remains disabled.
port-security timer disableport time-value
By default, the port silence timeout is 20 seconds.
6.     (Optional.) Set the block timer for blocked MAC addresses.
port-security timer blockmac time-value
By default, the block timer is 180 seconds.
On a port operating in either macAddressElseUserLoginSecure mode or macAddressElseUserLoginSecureExt mode, intrusion protection is triggered only after both MAC authentication and 802.1X authentication fail for the same frame.
Secure MAC addresses are configured or learned in autoLearn mode. If the secure MAC addresses are saved, they can survive a device reboot. You can bind a secure MAC address only to one port in a VLAN.
Secure MAC addresses include static, sticky, and dynamic secure MAC addresses.
Table 2 Comparison of static, sticky, and dynamic secure MAC addresses
Address sources
Aging mechanism
Can be saved and survive a device reboot?
Static
Manually added (by using the port-security mac-address security command without the sticky keyword).
Not available.
The static secure MAC addresses never age out unless you perform any of the following tasks:
·     Manually remove these MAC addresses.
·     Change the port security mode.
·     Disable the port security feature.
Yes.
Sticky
·     Manually added (by using the port-security mac-address security command with the sticky keyword).
·     Converted from dynamic secure MAC addresses.
·     Automatically learned when the dynamic secure MAC feature is disabled.
By default, sticky MAC addresses do not age out. However, you can configure an aging timer or use the aging timer together with the inactivity aging feature to remove old sticky MAC addresses.
·     If only the aging timer is configured, the aging timer counts up regardless of whether traffic data has been sent from the sticky MAC addresses.
·     If both the aging timer and the inactivity aging feature are configured, the aging timer restarts once traffic data is detected from the sticky MAC addresses.
Yes.
The secure MAC aging timer restarts at a reboot.
Dynamic
·     Converted from sticky MAC addresses.
·     Automatically learned after the dynamic secure MAC feature is enabled.
Same as sticky MAC addresses.
No.
All dynamic secure MAC addresses are lost at reboot.
When the maximum number of secure MAC address entries is reached, the port changes to secure mode. In secure mode, the port cannot add or learn any more secure MAC addresses. The port allows only frames sourced from secure MAC addresses or MAC addresses configured by using the mac-address dynamic or mac-address static command to pass through.
Before you configure secure MAC addresses, complete the following tasks:
·     Enable port security.
·     Set port security's limit on the number of MAC addresses on the port. Perform this task before you enable autoLearn mode.
·     Set the port security mode to autoLearn.
·     Configure the port to permit packets of the specified VLAN to pass or add the port to the VLAN. Make sure the VLAN already exists.
To configure a secure MAC address:
Step
Remarks
N/A
2.     (Optional.) Set the secure MAC aging timer.
port-security timer autolearn aging [ second ] time-value
By default, secure MAC addresses do not age out.
3.     Configure a secure MAC address.
·     In system view:
port-security mac-address security [ sticky ] mac-address interface interface-type interface-number vlan vlan-id
·     In Layer 2 Ethernet interface view:
a.     interface interface-type interface-number
b.     port-security mac-address security [ sticky ] mac-address vlan vlan-id
c.     quit
By default, no manually configured secure MAC addresses exist.
In a VLAN, a MAC address cannot be specified as both a static secure MAC address and a sticky MAC address.
4.     Enter Layer 2 Ethernet interface view.
N/A
5.     (Optional.) Enable inactivity aging.
port-security mac-address aging-type inactivity
By default, the inactivity aging feature is disabled.
6.     (Optional.) Enable the dynamic secure MAC feature.
port-security mac-address dynamic
By default, the dynamic secure MAC feature is disabled. Sticky MAC addresses can be saved to the configuration file. Once saved, they can survive a device reboot.
Overview
Typically, port security allows the access of the following types of MAC addresses:
·     MAC addresses that pass MAC authentication, MAC addresses in the MAC authentication guest VLAN or MAC authentication critical VLAN, and MAC addresses in the MAC authentication guest VSI or MAC authentication critical VSI.
·     MAC addresses that pass 802.1X authentication, MAC addresses in the 802.1X guest VLAN, 802.1X Auth-Fail VLAN, or 802.1X critical VLAN, and MAC addresses in the 802.1X guest VSI, 802.1X Auth-Fail VSI, or 802.1X critical VSI.
This feature limits the number of MAC addresses that port security allows to access a port through specific VLANs. Use this feature to prevent resource contentions among MAC addresses and ensure reliable performance for each access user on the port. When the number of MAC addresses in a VLAN on the port reaches the upper limit, the device denies any subsequent MAC addresses in the VLAN on the port.
On a port, the maximum number of MAC addresses in a VLAN cannot be smaller than the number of existing MAC addresses in the VLAN. If the specified maximum number is smaller, the setting does not take effect.
To set port security's limit on the number of MAC addresses for specific VLANs on a port:
Step
Remarks
N/A
N/A
3.     Set port security's limit on the number of MAC addresses for specific VLANs on the port.
port-security mac-limit max-number per-vlan vlan-id-list
The default setting is 2147483647.
You can configure a port to ignore the authorization information received from the server (local or remote) after an 802.1X or MAC authentication user passes authentication.
To configure a port to ignore authorization information from the server:
Step
Remarks
N/A
N/A
3.     Ignore the authorization information received from the authentication server.
port-security authorization ignore
By default, a port uses the authorization information received from the authentication server.
Enabling MAC move
Port security MAC move takes effect in the following scenarios:
·     Port move on a device—An online user authenticated through 802.1X or MAC authentication moves between ports on the device. The user VLAN or authentication method might change or stay unchanged after the move.
·     VLAN move on a port—An online user authenticated through 802.1X or MAC authentication moves between VLANs on a trunk or hybrid port in a VXLAN network. In addition, the packets that trigger authentication have VLAN tags.
Port security MAC move allows an online user authenticated through 802.1X or MAC authentication on one port or VLAN to be reauthenticated and come online on another port or VLAN without going offline first. After the user passes authentication on the new port or VLAN, the system removes the authentication session of the user on the original port or VLAN.
For MAC authentication, the MAC move feature applies only when MAC authentication single-VLAN mode is used. The MAC move feature does not apply to MAC authentication users that move between VLANs on a port with MAC authentication multi-VLAN mode enabled.
If this feature is disabled, 802.1X or MAC authenticated users must go offline first before they can be reauthenticated successfully on a new port or VLAN to come online.
As a best practice to minimize security risks, enable MAC move only if user roaming between ports is required.
802.1X or MAC authenticated users cannot move between ports on a device or between VLANs on a port if the maximum number of online users on the authentication server has been reached.
The MAC move for a user between two ports on the device will fail if all of the following conditions exist:
·     Both source and destination ports are enabled with MAC-based VLAN.
·     The user has been assigned an authorization VLAN on the source port.
·     The destination port does not permit the authorization VLAN to pass through.
MAC authentication multi-VLAN mode has higher priority than MAC move for users moving between VLANs on a port. If MAC authentication multi-VLAN mode is enabled, these users can come online in the new VLAN without being reauthenticated. To enable MAC authentication multi-VLAN mode, use the mac-authentication host-mode multi-vlan command. For more information about MAC authentication multi-VLAN mode, see "Configuring MAC authentication."
To enable MAC move:
Step
Remarks
N/A
2.     Enable MAC move.
port-security mac-move permit
By default, MAC move is disabled.
Overview
The authorization-fail-offline feature logs off port security users that fail ACL authorization.
A user fails ACL authorization in the following situations:
·     The device fails to authorize the specified ACL to the user.
·     The server assigns a nonexistent ACL to the user.
This feature does not apply to users that fail VLAN authorization. The device logs off these users directly.
You can also enable the quiet timer feature for 802.1X or MAC authentication users that are logged off by the authorization-fail-offline feature. The device adds these users to the 802.1X or MAC authentication quiet queue. Within the quiet timer, the device does not process packets from these users or authenticate them. If you do not enable the quiet timer feature, the device immediately authenticates these users upon receiving packets from them.
For the quiet timer feature to take effect, complete the following tasks:
·     For 802.1X users, use the dot1x quiet-period command to enable the quiet timer and use the dot1x timer quiet-period command to set the timer.
·     For MAC authentication users, use the mac-authentication timer quiet command to set the quiet timer for MAC authentication.
To enable the authorization-fail-offline feature:
Step
Remarks
N/A
2.     Enable the authorization-fail-offline feature.
port-security authorization-fail offline [ quiet-period ]
By default, this feature is disabled, and the device does not log off users that fail ACL authorization.
Overview
This feature enables access users (802.1X or MAC authentication users) of a port to come online and access the network even if they use nonexistent usernames or incorrect passwords.
Access users that come online in open authentication mode are called open users. Authorization and accounting are not available for open users. To display open user information, use the following commands:
·     display dot1x connection open.
·     display mac-authentication connection open.
This feature does not affect the access of users that use correct user information.
When you configure open authentication mode, follow these restrictions and guidelines:
·     If global open authentication mode is enabled, all ports are enabled with open authentication mode regardless of the port-specific open authentication mode setting. If global open authentication mode is disabled, whether a port is enabled with open authentication mode depends on the port-specific open authentication mode setting.
·     The open authentication mode setting has lower priority than the 802.1X Auth-Fail VLAN and the MAC authentication guest VLAN. Open authentication mode does not take effect on a port if the port is also configured with the 802.1X Auth-Fail VLAN or the MAC authentication guest VLAN. The open authentication mode setting has lower priority than the 802.1X Auth-Fail VSI and the MAC authentication guest VSI. Open authentication mode does not take effect on a port if the port is also configured with the 802.1X Auth-Fail VSI or the MAC authentication guest VSI.
For information about 802.1X authentication and MAC authentication, see "802.1X overview," "Configuring 802.1X," and "Configuring MAC authentication."
To enable open authentication mode:
Step
Remarks
N/A
2.     Enable global open authentication mode.
port-security authentication open global
By default, global open authentication mode is disabled.
N/A
4.     Enable open authentication mode on the port.
By default, open authentication mode is disabled on a port.
This feature allows packets from the specified VLANs to not trigger 802.1X or MAC authentication on a port configured with any of the following features:
·     802.1X.
·     MAC authentication.
·     One of the following port security modes:
¡     userLogin.
¡     userLoginSecure.
¡     userLoginWithOUI.
¡     userLoginSecureExt.
¡     macAddressWithRadius.
¡     macAddressOrUserLoginSecure.
¡     macAddressElseUserLoginSecure.
¡     macAddressOrUserLoginSecureExt.
¡     macAddressElseUserLoginSecureExt.
Do not configure free VLANs together with the feature of including user IP addresses in MAC authentication requests on a port. For information about including user IP addresses in MAC authentication requests, see "Configuring MAC authentication."
To configure free VLANs for port security:
Step
Remarks
N/A
N/A
3.     Configure free VLANs for port security.
port-security free-vlan vlan-id-list
By default, no free VLANs for port security exist on a port.
By default, the device sends its device name in the NAS-Identifier attribute of all RADIUS requests.
A NAS-ID profile enables you to send different NAS-Identifier attribute strings in RADIUS requests from different VLANs. The strings can be organization names, service names, or any user categorization criteria, depending on the administrative requirements.
For example, map the NAS-ID companyA to all VLANs of company A. The device will send companyA in the NAS-Identifier attribute for the RADIUS server to identify requests from any Company A users.
You can apply a NAS-ID profile to port security globally or on a port. On a port, the device selects a NAS-ID profile in the following order:
1.     The port-specific NAS-ID profile.
2.     The NAS-ID profile applied globally.
If no NAS-ID profile is applied or no matching binding is found in the selected profile, the device uses the device name as the NAS-ID.
For more information about the NAS-ID profile configuration, see "Configuring AAA."
To apply a NAS-ID profile to port security:
Step
Remarks
N/A
2.     Apply a NAS-ID profile.
·     In system view:
port-security nas-id-profile profile-name
·     In interface view:
b.     port-security nas-id-profile profile-name
By default, no NAS-ID profile is applied in system view or in interface view.
Overview
The escape critical VSI feature operates on VXLAN networks. It enables 802.1X and MAC authentication users to escape the authentication failure that occurs because the RADIUS server is malfunctioning.
You can enable this feature temporarily to prevent 802.1X and MAC authentication service interruption while you are troubleshooting a malfunctioning RADIUS server.
After the escape critical VSI feature is enabled on a port, the device performs the following operations when 802.1X or MAC authentication is triggered for a user:
1.     Dynamically creates an Ethernet service instance that matches the user's access VLAN and MAC address on the access port.
2.     Maps the Ethernet service instance to the 802.1X or MAC authentication critical VSI on the port.
The user can then come online without authentication and access resources in the VXLAN associated with the critical VSI.
The escape critical VSI feature does not affect 802.1X or MAC authentication users that have been online before this feature is enabled.
For the escape critical VSI feature to work correctly on a port, make sure the port does not have the following settings:
·     Web authentication.
·     Guest, Auth-Fail, or critical VLAN for 802.1X authentication.
·     Guest or critical VLAN for MAC authentication.
You can enable or disable this feature globally on all ports or on a per-port basis.
If the mac-authentication critical vsi critical-vsi-name url-user-logoff command is used in conjunction with this feature, MAC authentication users that have been assigned authorization URLs on the port will be logged off. For more information, see "Configuring MAC authentication."
When you disable the escape critical VSI both globally and on a port, the device logs off the users in the critical VSIs for 802.1X and MAC authentication on that port. The users must perform authentication to come online again on that port.
The escape critical VSI feature does not take effect on a new 802.1X or MAC authentication user if any of the following conditions exists:
·     The 802.1X client and the device use different EAP message handling methods.
·     802.1X MAC address binding is enabled on the user's access port, but the MAC address of the 802.1X user is not bound to that port.
·     The user's MAC address is an all-zero, all-F, or multicast MAC address.
Before you enable the escape critical VSI feature on a port, configure an 802.1X critical VSI and a MAC authentication critical VSI on that port. For more information about critical VSI configuration, see "Configuring 802.1X" and "Configuring MAC authentication."
Step
Remarks
N/A
2.     Enable the escape critical VSI feature globally.
port-security global escape critical-vsi
By default, the escape critical VSI feature is disabled globally.
Step
Remarks
N/A
N/A
3.     Enable the escape critical VSI feature on the port.
port-security escape critical-vsi
By default, the escape critical VSI feature is disabled on a port.
Use this feature to report critical port security events to an NMS. For port security event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
To enable SNMP notifications for port security:
Step
Remarks
N/A
2.     Enable SNMP notifications for port security.
snmp-agent trap enable port-security [ address-learned | dot1x-failure | dot1x-logoff | dot1x-logon | intrusion | mac-auth-failure | mac-auth-logoff | mac-auth-logon ] *
By default, SNMP notifications are disabled for port security.
Overview
This feature enables the device to generate logs about port security users and send the logs to the information center. For the logs to be output correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
To prevent excessive port security user log entries, use this feature only if you need to analyze abnormal port security user events.
To enable port security user logging:
Step
Remarks
N/A
2.     Enable port security user logging.
port-security access-user log enable [ failed-authorization | mac-learning | violation | vlan-mac-limit ] *
By default, port security user logging is disabled.
If you do not specify any parameters, this command enables all types of port security user logs.
Execute display commands in any view:
Display the port security configuration, operation information, and statistics.
display port-security [ interface interface-type interface-number ]
Display information about secure MAC addresses.
display port-security mac-address security [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
Display information about blocked MAC addresses.
display port-security mac-address block [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
Network requirements
As shown in Figure 1, configure GigabitEthernet 1/0/1 on the device to meet the following requirements:
·     Accept up to 64 users without authentication.
·     Be permitted to learn and add MAC addresses as sticky MAC addresses, and set the secure MAC aging timer to 30 minutes.
·     Stop learning MAC addresses after the number of secure MAC addresses reaches 64. If any frame with an unknown MAC address arrives, intrusion protection starts, and the port shuts down and stays silent for 30 seconds.
Figure 1 Network diagram
# Enable port security.
[Device] port-security enable
# Set the secure MAC aging timer to 30 minutes.
[Device] port-security timer autolearn aging 30
# Set port security's limit on the number of secure MAC addresses to 64 on GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] port-security max-mac-count 64
# Set the port security mode to autoLearn.
[Device-GigabitEthernet1/0/1] port-security port-mode autolearn
# Configure the port to be silent for 30 seconds after the intrusion protection feature is triggered.
[Device-GigabitEthernet1/0/1] port-security intrusion-mode disableport-temporarily
[Device] port-security timer disableport 30
# Verify the port security configuration.
[Device] display port-security interface gigabitethernet 1/0/1
Global port security parameters:
   Port security          : Enabled
   AutoLearn aging time   : 30 min
   Disableport timeout    : 30 s
   Blockmac timeout       : 180 s
   MAC move               : Denied
   Authorization fail     : Online
   NAS-ID profile         : Not configured
   Dot1x-failure trap     : Disabled
   Dot1x-logon trap       : Disabled
   Dot1x-logoff trap      : Disabled
   Intrusion trap         : Disabled
   Address-learned trap   : Disabled
   Mac-auth-failure trap  : Disabled
   Mac-auth-logon trap    : Disabled
   Mac-auth-logoff trap   : Disabled
   Open authentication    : Disabled
   OUI value list         :
    Index :  1           Value : 123401
 GigabitEthernet1/0/1 is link-up
   Port mode                      : autoLearn
   NeedToKnow mode                : Disabled
   Intrusion protection mode      : DisablePortTemporarily
   Security MAC address attribute
       Learning mode              : Sticky
       Aging type                 : Periodical
   Max secure MAC addresses       : 64
   Current secure MAC addresses   : 0
   Authorization                  : Permitted
   Free VLANs                     : Not configured
The port allows for MAC address learning, and you can view the number of learned MAC addresses in the Current secure MAC addresses field.
# Display additional information about the learned MAC addresses.
[Device-GigabitEthernet1/0/1] display this
 port-security mac-address security sticky 0002-0000-0015 vlan 1
 port-security mac-address security sticky 0002-0000-0014 vlan 1
 port-security mac-address security sticky 0002-0000-0013 vlan 1
 port-security mac-address security sticky 0002-0000-0012 vlan 1
 port-security mac-address security sticky 0002-0000-0011 vlan 1
# Verify that the port security mode changes to secure after the number of MAC addresses learned by the port reaches 64.
# Verify that the port will be disabled for 30 seconds after it receives a frame with an unknown MAC address. (Details not shown.)
# After the port is re-enabled, delete several secure MAC addresses.
[Device] undo port-security mac-address security sticky 0002-0000-0015 vlan 1
[Device] undo port-security mac-address security sticky 0002-0000-0014 vlan 1
# Verify that the port security mode of the port changes to autoLearn, and the port can learn MAC addresses again. (Details not shown.)
As shown in Figure 2, a client is connected to the device through GigabitEthernet 1/0/1. The device authenticates the client with a RADIUS server in ISP domain sun. If the authentication succeeds, the client is authorized to access the Internet.
·     The RADIUS server at 192.168.1.2 acts as the primary authentication server and the secondary accounting server. The RADIUS server at 192.168.1.3 acts as the secondary authentication server and the primary accounting server. The shared key for authentication is name, and the shared key for accounting is money.
·     All users use the authentication, authorization, and accounting methods of ISP domain sun.
·     The RADIUS server response timeout time is 5 seconds. The maximum number of RADIUS packet retransmission attempts is 5. The device sends real-time accounting packets to the RADIUS server at 15-minute intervals, and sends usernames without domain names to the RADIUS server.
Configure GigabitEthernet 1/0/1 to allow only one 802.1X user and a user that uses one of the specified OUI values to be authenticated.
Figure 2 Network diagram
The following configuration steps cover some AAA/RADIUS configuration commands. For more information about the commands, see Security Command Reference.
Make sure the host and the RADIUS server can reach each other.
1.     Configure AAA:
# Configure a RADIUS scheme named radsun.
[Device] radius scheme radsun
[Device-radius-radsun] primary authentication 192.168.1.2
[Device-radius-radsun] primary accounting 192.168.1.3
[Device-radius-radsun] secondary authentication 192.168.1.3
[Device-radius-radsun] secondary accounting 192.168.1.2
[Device-radius-radsun] key authentication simple name
[Device-radius-radsun] key accounting simple money
[Device-radius-radsun] timer response-timeout 5
[Device-radius-radsun] retry 5
[Device-radius-radsun] timer realtime-accounting 15
[Device-radius-radsun] user-name-format without-domain
[Device-radius-radsun] quit
# Configure ISP domain sun.
[Device] domain sun
[Device-isp-sun] authentication lan-access radius-scheme radsun
[Device-isp-sun] authorization lan-access radius-scheme radsun
[Device-isp-sun] accounting lan-access radius-scheme radsun
[Device-isp-sun] quit
2.     Configure 802.1X:
# Set the 802.1X authentication method to CHAP. By default, the authentication method for 802.1X is CHAP.
[Device] dot1x authentication-method chap
# Specify ISP domain sun as the mandatory authentication domain for 802.1X users on GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] dot1x mandatory-domain sun
3.     Configure port security:
# Add five OUI values. (You can add up to 16 OUI values. The port permits only one user matching one of the OUIs to pass authentication.)
[Device] port-security oui index 1 mac-address 1234-0100-1111
[Device] port-security oui index 2 mac-address 1234-0200-1111
[Device] port-security oui index 3 mac-address 1234-0300-1111
[Device] port-security oui index 4 mac-address 1234-0400-1111
[Device] port-security oui index 5 mac-address 1234-0500-1111
# Set the port security mode to userLoginWithOUI.
[Device-GigabitEthernet1/0/1] port-security port-mode userlogin-withoui
# Verify that GigabitEthernet 1/0/1 allows only one 802.1X user to be authenticated.
   MAC move               : Denied
   OUI value list         :
       Index :  2       Value : 123402
       Index :  3       Value : 123403
       Index :  4       Value : 123404
       Index :  5       Value : 123405
   Port mode                      : userLoginWithOUI
   Intrusion protection mode      : NoAction
   Max secure MAC addresses       : Not configured
   Current secure MAC addresses   : 1
   Authorization                  :Permitted
# Display information about the online 802.1X user to verify 802.1X configuration.
[Device] display dot1x
# Verify that the port also allows one user whose MAC address has an OUI among the specified OUIs to pass authentication.
[Device] display mac-address interface gigabitethernet 1/0/1
MAC Address     VLAN ID   State          Port/NickName            Aging
1234-0300-0011  1         Learned        GE1/0/1                  Y
As shown in Figure 3, a client is connected to the device through GigabitEthernet 1/0/1. The device authenticates the client by a RADIUS server in ISP domain sun. If the authentication succeeds, the client is authorized to access the Internet.
Configure GigabitEthernet 1/0/1 of the device to meet the following requirements:
·     Allow more than one MAC authenticated user to log on.
·     For 802.1X users, perform MAC authentication first and then, if MAC authentication fails, 802.1X authentication. Allow only one 802.1X user to log on.
·     Use the MAC address of each user as both the username and password for MAC authentication. The MAC addresses are in hexadecimal notation with hyphens, and letters are in upper case.
·     Set the total number of MAC authenticated users and 802.1X authenticated users to 64.
·     Enable NTK (ntkonly mode) to prevent frames from being sent to unknown MAC addresses.
Figure 3 Network diagram
1.     Configure RADIUS authentication/accounting and ISP domain settings. (See "userLoginWithOUI configuration example.")
2.     Configure port security:
# Use the MAC address of each user as both the username and password for MAC authentication. The MAC addresses are in hexadecimal notation with hyphens, and letters are in upper case.
[Device] mac-authentication user-name-format mac-address with-hyphen uppercase
# Specify the MAC authentication domain.
[Device] mac-authentication domain sun
# Set port security's limit on the number of MAC addresses to 64 on the port.
# Set the port security mode to macAddressElseUserLoginSecure.
[Device-GigabitEthernet1/0/1] port-security port-mode mac-else-userlogin-secure
# Specify ISP domain sun as the mandatory authentication domain for 802.1X users.
# Set the NTK mode of the port to ntkonly.
[Device-GigabitEthernet1/0/1] port-security ntk-mode ntkonly
   MAC move               : Denied
   OUI value list
   Port mode                      : macAddressElseUserLoginSecure
   NeedToKnow mode                : NeedToKnowOnly
# After users pass authentication, display MAC authentication information. Verify that GigabitEthernet 1/0/1 allows multiple MAC authentication users to be authenticated.
[Device] display mac-authentication interface gigabitethernet 1/0/1
   MAC authenticaiton                  : Enabled
   Authentication method               : PAP
   User name format                    : MAC address in uppercase(XX-XX-XX-XX-XX-XX)
           Username                    : mac
           Password                    : Not configured
   Offline detect period               : 300 s
   Quiet period                        : 180 s
   Server timeout                      : 100 s
   Reauth period                       : 3600 s
   User aging period for critical VLAN : 1000 s
   User aging period for critical VSI  : 1000 s
   User aging period for guest VLAN    : 1000 s
   User aging period for guest VSI     : 1000 s
   Authentication domain               : sun
 Online MAC-auth wired users           : 3
 Silent MAC users:
          MAC address       VLAN ID  From port               Port index
   MAC authentication               : Enabled
   Carry User-IP                    : Disabled
   Authentication domain            : Not configured
   Auth-delay timer                 : Disabled
   Periodic reauth                  : Disabled
   Re-auth server-unreachable       : Logoff
   Guest VLAN                       : Not configured
   Guest VLAN auth-period           : 30 s
   Critical VLAN                    : Not configured
   Critical voice VLAN              : Disabled
   Host mode                        : Single VLAN
   Offline detection                : Enabled
   Authentication order             : Default
   User aging                       : Enabled
   Server-recovery online-user-sync : Enabled
   Guest VSI                        : Not configured
   Guest VSI auth-period            : 30 s
   Critical VSI                     : Not configured
   Max online users                 : 4294967295
   Authentication attempts          : successful 3, failed 7
   Current online users             : 3
          MAC address       Auth state
          1234-0300-0011    Authenticated
          1234-0300-0012    Authenticated
          1234-0300-0013    Authenticated
# Display 802.1X authentication information. Verify that GigabitEthernet 1/0/1 allows only one 802.1X user to be authenticated.
[Device] display dot1x interface gigabitethernet 1/0/1
 Global 802.1X parameters:
   802.1X authentication                : Enabled
   CHAP authentication                  : Enabled
   Max-tx period                        : 30 s
   Handshake period                     : 15 s
   Quiet timer                          : Disabled
       Quiet period                     : 60 s
   Supp timeout                         : 30 s
   Max auth requests                    : 2
   User aging period for Auth-Fail VLAN : 1000 s
   User aging period for Auth-Fail VSI  : 1000 s
   EAD assistant function               : Disabled
       EAD timeout                      : 30 min
   Domain delimiter                     : @
   Max EAP-TLS fragment (to-server)     : N/A
 Online 802.1X wired users              : 1
   Handshake                        : Enabled
   Handshake reply                  : Disabled
   Handshake security               : Disabled
   Offline detection                : Disabled
   Unicast trigger                  : Disabled
   Port role                        : Authenticator
   Authorization mode               : Auto
   Port access control              : MAC-based
   Multicast trigger                : Enabled
   Mandatory auth domain            : sun
   Auth-Fail VLAN                   : Not configured
   Add Guest VLAN delay             : Disabled
   User IP freezing                 : Disabled
   Reauth period                    : 0 s
   Send Packets Without Tag         : Disabled
   Max Attempts Fail Number         : 0
   Auth-Fail VSI                    : Not configured
   Add Guest VSI delay              : Disabled
   Auth-Fail EAPOL                  : Disabled
   Critical EAPOL                   : Disabled
   EAPOL packets: Tx 16331, Rx 102
   Sent EAP Request/Identity packets : 16316
        EAP Request/Challenge packets: 6
        EAP Success packets: 4
        EAP Failure packets: 5
   Received EAPOL Start packets : 6
            EAPOL LogOff packets: 2
            EAP Response/Identity packets : 80
            EAP Response/Challenge packets: 6
            Error packets: 0
   Online 802.1X users: 1
          0002-0000-0011      Authenticated
# Verify that frames with an unknown destination MAC address, multicast address, or broadcast address are discarded. (Details not shown.)
Symptom
Cannot set the port security mode for a port.
Analysis
For a port operating in a port security mode other than noRestrictions, you cannot change the port security mode by using the port-security port-mode command.
Solution
To resolve the issue:
1.     Set the port security mode to noRestrictions.
[Device-GigabitEthernet1/0/1] undo port-security port-mode
2.     Set a new port security mode for the port (for example, autoLearn).
3.     If the issue persists, contact H3C Support.
Symptom
Cannot configure secure MAC addresses.
Analysis
No secure MAC address can be configured on a port operating in a port security mode other than autoLearn.
Solution
1.     Set the port security mode to autoLearn.
[Device-GigabitEthernet1/0/1] port-security mac-address security 1-1-2 vlan 1
2.     If the issue persists, contact H3C Support.
