00-Preface | 100.67 KB |
Preface
This configuration guide describes how to classify traffic with ACLs, and allocate network resources and manage congestions with QoS technologies to improve network performance and network use efficiency. You can use ACLs to help other function modules (such as QoS and IP routing) classify or filter traffic.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S7500E switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
WARNING! |
CAUTION: |
IMPORTANT: |
NOTE: |
TIP: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
