08-ACL and QoS Command Reference
HomeSupportResource CenterSwitchesH3C S6861 Switch SeriesH3C S6861 Switch SeriesTechnical DocumentsCommandCommand ReferencesH3C S6861 Switch Series Command References-Release 26xx-6W10108-ACL and QoS Command Reference
04-Data buffer commands
04-Data buffer commands 82.46 KB
Inappropriate data buffer changes can cause system problems. Before manually changing data buffer settings, make sure you understand its impact on your device. As a best practice, use the burst-mode enable command if the system requires large buffer spaces. The burst-mode enable command and the buffer apply command are mutually exclusive. If you have configured the data buffer by using one command, you must execute the undo form of the command before using the other command.
buffer apply
Use buffer apply to apply manually configured data buffer settings.
Use undo buffer apply to restore the default.
buffer apply
undo buffer apply
For data buffer settings to take effect, you must execute this command after configuring data buffer settings.
After applying manually configured data buffer settings, you cannot directly modify the applied settings. To modify them, you must cancel the application, reconfigure data buffer settings, and reapply the new settings.
# Apply manually configured data buffer settings.
[Sysname] buffer apply
buffer queue guaranteed
Use buffer queue guaranteed to set the fixed-area space for a queue.
Use undo buffer queue guaranteed to delete the fixed-area space setting of a queue.
buffer egress [ slot slot-number ] cell queue queue-id guaranteed ratio ratio
undo buffer egress [ slot slot-number ] cell queue queue-id guaranteed
The fixed-area ratio for a queue is 13%.
egress: Specifies the egress buffer.
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command applies to all IRF member devices.
cell: Specifies cell resources.
queue-id: Specifies a queue by its ID in the range of 0 to 7.
ratio ratio: Specifies the fixed-area space ratio, in percentage. The value range for ratio is 1 to 100.
By default, all queues have an equal share of the fixed area. You can set the fixed-area ratio for a queue. The other queues equally share the remaining part.
The fixed-area space for a queue cannot be used by other queues. Therefore, it is also called the minimum guaranteed buffer for the queue. The sum of fixed-area space configured for all queues cannot exceed the total fixed-area space. Otherwise, the configuration fails.
# Configure queue 0 to use 20% fixed-area space of cell resources in the egress buffer.
[Sysname] buffer egress cell queue 0 guaranteed ratio 20
buffer queue shared
Use buffer queue shared to set the maximum shared-area ratio for a queue.
Use undo buffer queue shared to delete the maximum shared-area ratio setting of a queue.
buffer egress [ slot slot-number ] cell queue queue-id shared ratio ratio
undo buffer egress [ slot slot-number ] cell queue queue-id shared
The maximum shared-area ratio for a queue is 33%.
ratio ratio: Specifies the maximum shared-area space ratio, in percentage. The value range for ratio is 0 to 100.
By default, all queues have an equal share of the shared area. You can set the shared-area space for a queue. The unconfigured queues use the default setting. The shared-area space for each queue is finally determined by the chip based on your configuration and the number of packets to be received and sent.
# Configure queue 0 to use up to 10% shared-area space of cell resources in the egress buffer.
[Sysname] buffer egress cell queue 0 shared ratio 10
buffer total-shared
Use buffer total-shared to set the total shared-area ratio.
Use undo buffer total-shared to delete the total shared-area ratio setting.
buffer egress [ slot slot-number ] cell total-shared ratio ratio
undo buffer egress [ slot slot-number ] cell total-shared
The total shared-area ratio is 99%.
ratio ratio: Specifies the ratio of the shared area, in percentage. The value range for ratio is 0 to 100.
After you set the shared-area space, the remaining buffer space is automatically assigned to the fixed area.
# Configure the shared area to use 50% space of cell resources in the egress buffer.
[Sysname] buffer egress cell total-shared ratio 50
burst-mode enable
Use burst-mode enable to enable the Burst feature.
Use undo burst-mode enable to disable the Burst feature.
burst-mode enable
The Burst feature is disabled.
The S5830V2-24S switch does not support QCN when it is enabled with the Burst feature. For information about QCN, see ACL and QoS Configuration Guide.
The Burst feature is especially useful for reducing packet losses under the following circumstances:
·          Broadcast or multicast traffic is intensive, resulting in bursts of traffic.
·          Traffic enters a device from a high-speed interface and goes out of a low-speed interface.
·          Traffic enters a device from multiple same-rate interfaces and goes out of an interface with the same rate.
# Enable the Burst feature.
[Sysname] burst-mode enable
display buffer
Use display buffer to display buffer size settings.
display buffer [ slot slot-number ] [ queue [ queue-id ] ]
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays buffer size settings for all IRF member devices.
queue queue-id: Specifies a queue by its number in the range of 0 to 7. If you specify a queue, this command displays the fixed-area ratio and shared-area ratio for the specified queue. If you specify the queue keyword without the queue-id argument, this command displays the fixed-area ratio and shared-area ratio for each queue. If you do not specify the queue keyword, this command displays the total shared-area ratio.
# Display buffer ratio settings.
<Sysname> display buffer
Slot  Type    Eg(Total-shared)
1     cell    100
          Eg: Size of the sending buffer
Total-shared: Size of the shared buffer for all ports
        Unit: Ratio
# Display the fixed-area ratio and shared-area ratio for the queues.
<Sysname> display buffer queue
Slot  Queue        Type    Eg(Guaranteed , Shared)
1     0-7          cell    13 , 88
  Guaranteed: Size of the minimum guaranteed buffer per queue
      Shared: Size of the maximum shared buffer per queue
        Unit: Ratio
Resource type.
Queue
Queue ID in the range of 0 to 7.
Eg
Egress buffer.
(Total-shared , Shared)
Total-shared indicates the total shared-area ratio.
If the device does not support a resource type, this field displays two hyphens (--).
·         Guaranteed indicates the fixed-area ratio of a queue.
·         Shared indicates the shared-area ratio of a queue.
display buffer usage
Use display buffer usage to display buffer usage.
display buffer usage [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays buffer usage for all IRF member devices.
# Display buffer usage.
<Sysname> display buffer usage
Egress total-shared cell buffer usage on slot 1 :
Total:   16061 KB
Used:       0 KB
Free:   16061 KB
                     5sec    1min    5min
Block 1                0%      0%      0%
FGE9/0/1               0%      0%      0%
FGE9/0/2               0%      0%      0%
FGE9/0/3               0%      0%      0%
FGE9/0/4               0%      0%      0%
FGE9/0/5               0%      0%      0%
FGE9/0/6               0%      0%      0%
FGE9/0/7               0%      0%      0%
Usage of cell resources in the shared area on an IRF member device.
Block
Block where the port resides. The block where the ports on the front panel of the device reside is fixed to Block 1.
Total
Total size of the data buffer.
Used
Size of used data buffer.
Free
Size of free data buffer.
5sec
Percentage of the buffer that the port uses for the last 5 seconds.
1min
Percentage of the buffer that the port uses for the last 1 minute.
5min
Percentage of the buffer that the port uses for the last 5 minutes.
display buffer usage interface
Use display buffer usage interface to display buffer usage statistics for interfaces.
display buffer usage interface [ interface-type [ interface-number ] ]
interface-type [ interface-number ]: Specifies an interface by its type and number. If you do not specify the interface-type argument, this command displays buffer usage statistics for all Ethernet interfaces. If you specify the interface-type argument without the interface-number argument, this command displays buffer usage statistics for all Ethernet interfaces of the specified type.
# Display buffer usage statistics for Ten-GigabitEthernet 1/0/1.
<Sysname> display buffer usage interface ten-gigabitethernet 1/0/1
Interface              QueueID Total       Used        Threshold(%) Violations
XGE1/0/1               0       4132336     0           30           0
                       1       4132336     0           30           0
                       2       4132336     0           30           0
                       3       4132336     0           30           0
                       4       4132336     0           30           0
                       5       4132336     0           30           0
                       6       4132336     0           30           0
                       7       4132336     0           30           0
Total
Data buffer size in bytes allowed for a queue.
Used
Data buffer size in bytes that has been used by a queue.
Threshold(%)
Buffer usage threshold for a queue. The threshold value is the same as the per-interface threshold value.
Violations
Number of threshold violations for a queue.
The value of this field is reset upon a switch reboot.
fma agent-ip
Use fma agent-ip to configure the agent's IP address.
fma agent-ip agent-ip
No IP address is configured for an agent.
agent-ip: Specifies the IP address.
# Configure the agent's IP address as 1.1.1.1.
[Sysname] fma agent-ip 1.1.1.1
fma agent-mac
Use fma agent-mac to configure the agent's MAC address.
fma agent-mac agent-mac
No MAC address is configured for an agent.
agent-mac: Specifies the MAC address.
# Configure the agent's MAC address as 0000-0001-0002.
[Sysname] fma agent-mac 0000-0001-0002
fma agent-port
Use fma agent-port to configure the agent's port number.
fma agent-port agent-port
No port number is configured for an agent.
agent-port: Specifies the port number in the range of 1 to 65535.
# Configure the agent's port number as 8080.
[Sysname] fma agent-port 8080
fma client-ip
Use fma client-ip to specify the client's IP address.
fma client-ip client-ip
The client's IP address is not specified.
The specified IP address must be the IP address actually used by the client.
# Specify the client's IP address as 1.1.1.1.
[Sysname] fma client-ip 1.1.1.1
fma client-port
Use fma client-port to specify the client's port number.
fma client-port client-port
The client's port number is not specified.
The specified port number must be the port number actually used by the client.
# Specify the client's port number as 8080.
[Sysname] fma client-port 8080
fma enable
Use fma enable to enable the FMA feature.
Use undo fma enable to disable the FMA feature.
fma enable
undo fma enable
The FMA feature is disabled.
The Fabric Monitor and Analyzer (FMA) feature works with IMC to perform device monitoring and analysis. The switch acts as an FMA agent, and the IMC server acts as an FMA client. The FMA-related commands do not take effect after you configure them on the FMA agent. You must configure the following settings on the FMA client:
·          Agent's IP address, MAC address, and port number.
·          Client's IP address and port number.
After you configure these settings and enable the Microburst feature on the FMA client, the FMA agent automatically receives these settings from the FMA client.
After the FMA agent receives these settings, it can exchange device monitoring and analysis information with the FMA client.
In the current software version, this feature supports only data buffer statistics and detection. Data buffer statistics are buffer usage statistics for queues. Data buffer detection information is the buffer usage threshold for queues.
# Enable the FMA feature.
[Sysname] fma enable
