02-QoS commands | 437.99 KB |
mac-address mac-learning enable·
display qos policy control-plane
display qos policy control-plane pre-defined
display qos policy diagnosis control-plane
display qos policy diagnosis global
display qos policy diagnosis interface·
display qos policy diagnosis l2vpn-ac
display qos policy diagnosis user-profile
display qos policy diagnosis vsi
display qos policy user-profile
display qos vlan-policy diagnosis
qos apply policy (Ethernet service instance view, interface view, control plane view, VSI view)
qos apply policy (user profile view)
reset qos policy control-plane
Congestion management commands
display qos queue sp interface
display qos queue wrr interface
qos wrr { byte-count | weight }
display qos queue wfq interface
qos wfq { byte-count | weight }
Queue scheduling profile commands
display qos qmprofile configuration
display qos qmprofile interface
Queue-based accounting commands·
QoS policy commands
Traffic class commands
description
Use description to configure a description for a traffic class.
Use undo description to delete the description of a traffic class.
No description is configured for a traffic class.
Traffic class view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as classifier for traffic class class1.
[Sysname-classifier-class1] description classifier
display traffic classifier
Use display traffic classifier to display traffic classes.
user-defined: Specifies user-defined traffic classes.
classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the traffic classes for the master device.
# Display all user-defined traffic classes.
User-defined classifier information:
Classifier: 1 (ID 100)
Operator: AND
Rule(s) :
If-match acl 2000
Classifier: 2 (ID 101)
Operator: AND
Rule(s) :
If-match protocol ipv6
Classifier: 3 (ID 102)
Operator: AND
Rule(s) :
-none-
Classifier |
Traffic class name and its match criteria. |
Operator |
Match operator you set for the traffic class. If the operator is AND, the traffic class matches the packets that match all its match criteria. If the operator is OR, the traffic class matches the packets that match any of its match criteria. |
Rule(s) |
Match criteria. |
if-match
Use if-match to define a match criterion.
Use undo if-match to delete a match criterion.
if-match match-criteria
undo if-match match-criteria
No match criterion is configured.
Traffic class view
match-criteria: Specifies a match criterion. Table 2 shows the available match criteria.
Table 2 Available match criteria
Option |
acl [ ipv6 ] { acl-number | name acl-name } [ inner ] |
Matches an ACL. The value range for the acl-number argument is as follows: · 2000 to 3999 for IPv4 ACLs. · 2000 to 3999 for IPv6 ACLs. · 4000 to 4999 for Layer 2 MAC ACLs. The acl-name argument is a case-insensitive string of 1 to 63 characters, which must start with an English letter. To avoid confusion, make sure the argument is not all. You can use the inner keyword to match the inner header information of VXLAN packets. For example, a rule permit ip source 10.0.0.0 0.255.255.255 statement matches the inner source IP address of VXLAN packets if the inner keyword is specified in the if-match acl command. The statement matches the source IP address of non-VXLAN packets or the outer source IP address of VXLAN packets if the inner keyword is not specified. If you specify the inner keyword in the if-match acl command, you must also specify it when executing the undo if-match acl command. |
any |
Matches all packets. |
control-plane protocol protocol-name&<1-8> |
Matches control plane protocols. The protocol-name&<1-8> argument specifies a space-separated list of up to eight system-defined control plane protocols. For available system-defined control plane protocols, see Table 3. |
control-plane protocol-group protocol-group-name |
Matches a control plane protocol group. The protocol-group-name argument can be critical, important, management, monitor, normal, or redirect. |
Matches 802.1p priority values in inner VLAN tags of double-tagged packets. The dot1p-value&<1-8> argument specifies a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7. |
customer-vlan-id vlan-id-list |
Matches VLAN IDs in inner VLAN tags of double-tagged packets. The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094. This option takes effect only if the QoS policy is applied to an interface. |
destination-mac mac-address |
Matches a destination MAC address. This option takes effect only on Ethernet interfaces. |
dscp dscp-value&<1-8> |
Matches DSCP values. The dscp-value&<1-8> argument specifies a space-separated list of up to eight DSCP values. The value range for the dscp-value argument is 0 to 63 or keywords shown in Table 5. |
ip-precedence ip-precedence-value&<1-8> |
Matches IP precedence values. The ip-precedence-value&<1-8> argument specifies a space-separated list of up to eight IP precedence values. The value range for the ip-precedence-value argument is 0 to 7. |
protocol protocol-name |
Matches a protocol. The protocol-name argument can be ipv6 or ip. |
qos-local-id local-id-value |
Matches a local QoS ID in the range of 1 to 3999. For a QoS policy applied to the inbound direction, the supported value range for the local-id-value argument is 1 to 3999. For a QoS policy applied to the outbound direction, the supported value range for the local-id-value argument is 1 to 511. In an IRF fabric, you cannot match the packets on a member device by using the local QoS ID marked on another member device. In a VXLAN network, you cannot match the packets by using the local QoS ID marked on the remote VTEP or VXLAN IP gateway. |
service-dot1p dot1p-value&<1-8> |
Matches 802.1p priority values in outer VLAN tags. The dot1p-value&<1-8> argument specifies a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7. |
service-vlan-id vlan-id-list |
Matches VLAN IDs in outer VLAN tags. The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094. You can use this option to match single-tagged packets. |
source-mac mac-address |
Matches a source MAC address. This option takes effect only on Ethernet interfaces. |
traffic-type { unicast | unknown-unicast | broadcast | multicast } |
Matches the packet type: · unicast—Matches known Layer 2 unicast packets. · unknown-unicast—Matches unknown Layer 2 unicast packets. · broadcast—Matches broadcast packets. · multicast—Matches known Layer 2 multicast packets. For a traffic class to match multiple packet types, you must specify the OR operator when creating the class. |
tunnel-id tunnel-id |
Matches a VXLAN tunnel ID. For the traffic class to take effect, the tunnel must be a VXLAN tunnel. |
vxlan { any | vxlan-id } |
Matches a VXLAN ID. In the inbound direction, only VXLAN packets received by the VTEP can be matched. In the outbound direction, the VXLAN packets sent to the remote VTEP and packets sent to the user network after decapsulation can be matched. In this case, the criterion matches the packets of the VXLAN with the VXLAN ID as its corresponding VSI ID. For example, if VXLAN 10 corresponds to VSI 0, you must configure VXLAN 0 as the match criterion to match the packets of VXLAN 10. To identify the mappings among VXLAN IDs, VSI names, and VSI indexes, use the display l2vpn vsi command (see VXLAN Command Reference). |
Table 3 Available system-defined control plane protocols
Protocol |
default |
Protocol packets other than the following packet types |
arp |
ARP packets |
arp-snooping |
ARP snooping packets |
bfd |
BFD packets |
bgp |
BGP packets |
bgp4+ |
IPv6 BGP packets |
dhcp |
DHCP packets |
dhcp-snooping |
DHCP snooping packets |
dhcpv6 |
IPv6 DHCP packets |
dldp |
DLDP packets |
dot1x |
802.1X packets |
ftp |
FTP packets |
hoplimit-expires |
Hop-limit expire packets |
http |
HTTP packets |
https |
HTTPS packets |
icmp |
ICMP packets |
icmpv6 |
ICMPv6 packets |
igmp |
IGMP packets |
ip-option |
IPv4 packets with the Options field |
ipv6-option |
IPv6 packets with the Options field |
isis |
IS-IS packets |
lacp |
LACP packets |
lldp |
LLDP packets |
mvrp |
MVRP packets (including GVRP packets) |
ospf-multicast |
OSPF multicast packets |
ospf-unicast |
OSPF unicast packets |
ospf3-multicast |
OSPFv3 multicast packets |
ospf3-unicast |
OSPFv3 unicast packets |
pim-multicast |
PIM multicast packets |
pim-unicast |
PIM unicast packets |
pim6-multicast |
IPv6 PIM multicast packets |
pim6-unicast |
IPv6 PIM unicast packets |
radius |
RADIUS packets |
snmp |
SNMP packets |
ssh |
SSH packets |
stp |
STP packets |
tacacs |
TACACS packets |
telnet |
Telnet packets |
ttl-expires |
TTL expire packets |
vrrp |
VRRP packets |
vrrp6 |
IPv6 VRRP packets |
In a traffic class with the logical OR operator, you can configure multiple if match commands for any of the available match criteria.
When you configure a match criterion that can have multiple values in one if-match command, follow these restrictions and guidelines:
· You can specify up to eight values for any of the following match criteria in one if-match command:
¡ Control plane protocol.
¡ 802.1p priority.
¡ DSCP.
¡ IP precedence.
¡ VLAN ID.
· If a packet matches one of the specified values, it matches the if-match command.
· To delete a criterion that has multiple values, the specified values in the undo if-match command must be the same as those specified in the if-match command. The order of the values can be different.
When you configure ACL-based match criteria, follow these restrictions and guidelines:
· If the ACL used as a match criterion does not exist, the traffic class cannot be applied to hardware.
· In a traffic class, you can add two if-match statements that use the same ACL as the match criterion. In one statement, specify the ACL by its name. In the other statement, specify the ACL by its number.
· The ACL is used for classification only and the permit/deny actions in ACL rules are ignored. Actions taken on matching packets are defined in traffic behaviors.
You can use both AND and OR operators to define the match relationships between the criteria for a class. For example, you can define relationships among three match criteria in traffic class classA as follows:
traffic classifier classB operator and
if-match criterion 1
if-match criterion 2
traffic classifier classA operator or
if-match criterion 3
# Define a match criterion for traffic class class1 to match the packets with a destination MAC address of 0050-ba27-bed3.
# Define a match criterion for traffic class class2 to match the packets with a source MAC address of 0050-ba27-bed2.
# Define a match criterion for traffic class class1 to match the double-tagged packets with 802.1p priority 3 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with 802.1p priority 5 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-dot1p 5
# Define a match criterion for traffic class class1 to match advanced ACL 3101.
# Define a match criterion for traffic class class1 to match the ACL named flow.
# Define a match criterion for traffic class class1 to match advanced IPv6 ACL 3101.
# Define a match criterion for traffic class class1 to match the IPv6 ACL named flow.
# Define a match criterion for traffic class class1 to match all packets.
# Define a match criterion for traffic class class1 to match the packets with a DSCP value of 1, 6, or 9.
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# Define a match criterion for traffic class class1 to match the packets with an IP precedence value of 1 or 6.
[Sysname-classifier-class1] if-match ip-precedence 1 6
# Define a match criterion for traffic class class1 to match IP packets.
# Define a match criterion for traffic class class1 to match double-tagged packets with VLAN ID 1, 6, or 9 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with VLAN ID 2, 7, or 10 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# Define a match criterion for traffic class class1 to match the packets with a local QoS ID of 3.
[Sysname-classifier-class1] if-match qos-local-id 3
# Define a match criterion for traffic class class1 to match ARP protocol packets.
[Sysname-classifier-class1] if-match control-plane protocol arp
# Define a match criterion for traffic class class1 to match packets of the protocols in protocol group normal.
[Sysname-classifier-class1] if-match control-plane protocol-group normal
# Define a match criterion for traffic class class1 to match multicast packets.
[Sysname-classifier-class1] if-match traffic-type multicast
# Define a match criterion for traffic class class1 to match the VXLAN packets with tunnel ID 2.
[Sysname-classifier-class1] if-match tunnel-id 2
# Define a match criterion for traffic class class1 to match the packets with VXLAN 10.
[Sysname-classifier-class1] if-match vxlan 10
traffic classifier
Use traffic classifier to create a traffic class and enter its view, or enter the view of an existing traffic class.
Use undo traffic classifier to delete a traffic class.
No traffic classes exist.
classifier-name: Specifies a name for the traffic class, a case-sensitive string of 1 to 31 characters.
operator: Sets the operator to logic AND (the default) or OR for the traffic class.
and: Specifies the logic AND operator. The traffic class matches the packets that match all its criteria.
or: Specifies the logic OR operator. The traffic class matches the packets that match any of its criteria.
# Create a traffic class named class1.
Traffic behavior commands
accounting
Use accounting to configure a traffic accounting action in a traffic behavior.
Use undo accounting to restore the default.
accounting [ byte | packet ] *
undo accounting
No traffic accounting action is configured.
Traffic behavior view
byte: Counts traffic in bytes.
packet: Counts traffic in packets.
If you do not specify the byte or packet keyword, the switch collects statistics in packets. If you specify both the byte and packet keywords in one command line, the switch collects statistics in both packets and bytes.
# Configure a traffic accounting action in traffic behavior database to count traffic in bytes.
[Sysname-behavior-database] accounting byte
car
Use car to configure a CAR action in absolute value in a traffic behavior.
Use undo car to restore the default.
car cir [ pps ] committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir [ pps ] committed-information-rate [ cbs committed-burst-size ] pir [ pps ] peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
No CAR action is configured.
cir committed-information-rate: Specifies the committed information rate (CIR) in kbps or pps, which is an average traffic rate. If you specify the pps keyword, the CIR is specified in pps, and the value range is 1 to 160000000. If you do not specify the pps keyword, the CIR is specified in kbps, and the value range is 8 to 4294967288, in increments of 8.
cbs committed-burst-size: Specifies the committed burst size (CBS) in bytes. The value range for committed-burst-size is 512 to 256000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the excess burst size (EBS) in bytes. The value range for excess-burst-size is 0 to 256000000, in increments of 512. If the PIR is configured, the default EBS is the product of 62.5 and the PIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
pir peak-information-rate: Specifies the peak information rate (PIR) in kbps or pps. If you specify the pps keyword, the PIR is specified in pps, and the value range is 1 to 160000000. If you do not specify the pps keyword, the PIR is specified in kbps, and the value range is 8 to 4294967288, in increments of 8. The PIR must be specified in the same unit as the CIR.
green action: Specifies the action to take on packets that conform to the CIR. The default setting is pass.
red action: Specifies the action to take on packets that conform to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to the PIR but not to the CIR. The default setting is pass.
action: Sets the action to take on the packet:
· discard: Drops the packet.
· pass: Permits the packet to pass through.
· remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
· remark-dscp-pass new-dscp: Sets the DSCP value of the packet to new-dscp and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63.
· remark-lp-pass new-local-precedence: Sets the local precedence value of the packet to new-local-precedence and permits the packet to pass through. The new-local-precedence argument is in the range of 0 to 7.
To use two rates for traffic policing, configure the car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the car command without the pir peak-information-rate option.
If you execute the car command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure a CAR action in traffic behavior database:
· Set the CIR to 200 kbps, CBS to 51200 bytes, and EBS to 0.
· Transmit the conforming packets, and mark the excess packets with DSCP value 0 and transmit them.
[Sysname-behavior-database] car cir 200 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
display traffic behavior
Use display traffic behavior to display traffic behaviors.
user-defined: Specifies user-defined traffic behaviors.
behavior-name: Specifies a behavior by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic behavior, this command displays all traffic behaviors.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the traffic behaviors for the master device.
# Display all user-defined traffic behaviors.
User-defined behavior information:
Behavior: 1 (ID 100)
Marking:
Remark dscp 3
Committed Access Rate:
CIR 200 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Behavior: 2 (ID 101)
Accounting enable: Packet
Filter enable: Permit
Marking:
Remark dscp 4
Redirecting:
Redirect to the CPU
Behavior |
Name and contents of a traffic behavior. |
Marking |
Information about priority marking. |
Remark dscp |
Action of setting the DSCP value for packets. |
Committed Access Rate |
Information about the CAR action. |
Green action |
Action to take on green packets. |
Yellow action |
Action to take on yellow packets. |
Red action |
Action to take on red packets. |
Accounting enable |
Class-based accounting action. |
Filter enable |
Traffic filtering action. |
Redirecting |
Information about traffic redirecting. |
Mirroring |
Information about traffic mirroring. |
Pre |
IP precedence. |
filter
Use filter to configure a traffic filtering action in a traffic behavior.
Use undo filter to restore the default.
filter { deny | permit }
undo filter
No traffic filtering action is configured.
deny: Drops packets.
permit: Transmits packets.
# Configure a traffic filtering action as deny in traffic behavior database.
Use mac-address mac-learning enable to enable MAC address learning for a traffic behavior.
Use undo mac-address mac-learning enable to disable MAC address learning for a traffic behavior.
MAC address learning is enabled for a traffic behavior.
To prevent the MAC address table from being saturated when the device is experiencing attacks, disable MAC address learning. For example, you can disable MAC address learning to prevent the device from being attacked by a large number of frames with different source MAC addresses.
Disabling MAC address learning in a traffic behavior takes effect only if the QoS policy is applied to the inbound direction of an interface or globally.
Disabling MAC address learning has the following impacts:
· The device does not learn new MAC addresses of packets that match the QoS policy and therefore cannot update MAC address changes in real time.
· The device floods packets that do not match an entry in the MAC address table.
As a best practice, configure broadcast storm suppression on the interface that has the QoS policy applied. For information about broadcast storm suppression, see Layer 2—LAN Switching Configuration Guide.
· The device does not delete existing MAC addresses until the aging timer expires.
To delete the existing MAC addresses, delete them manually or wait for the aging timer to expire.
# Disable MAC address learning in traffic behavior data.
[Sysname-behavior-data] undo mac-address mac-learning enable
nest top-most
Use nest top-most to configure an outer VLAN tag adding action in a traffic behavior.
Use undo nest top-most to restore the default.
nest top-most vlan vlan-id
undo nest top-most
No outer VLAN tag adding action is configured.
vlan-id vlan-id: Specifies the VLAN ID to be added in the outer VLAN tag, in the range of 1 to 4094.
If a QoS policy contains an outer VLAN tag adding action, apply it only to the incoming traffic of an interface.
If you execute the nest top-most command multiple times in the same traffic behavior, the most recent configuration takes effect.
This action does not take effect on packets sent to or received from a VXLAN overlay network.
If an Ethernet service instance is configured with the encapsulation untag command, the Layer 2 Ethernet interface or Layer 2 aggregate interface where it resides does not support outer VLAN tag adding actions. For information about the encapsulation untag command, see MPLS L2VPN commands or VPLS commands in MPLS Command Reference, or see VXLAN Command Reference.
# Configure traffic behavior b1 to add an outer VLAN tag with VLAN ID 123.
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
redirect
Use redirect to configure a traffic redirecting action in a traffic behavior.
Use undo redirect to restore the default.
redirect { cpu | interface interface-type interface-number }
undo redirect { cpu | interface interface-type interface-number }
No traffic redirecting action is configured.
cpu: Redirects traffic to the CPU.
interface interface-type interface-number: Redirects traffic to an interface specified by its type and number.
slot slot-number: Redirects traffic to an IRF member device specified by its member ID.
If you execute the redirect command multiple times in the same traffic behavior, the most recent configuration takes effect.
A traffic redirecting action takes effect only when the QoS policy is applied to the inbound direction.
If a QoS policy applied to a user profile contains the redirect interface action, make sure the interface and the incoming interface of packets are in the same VLAN.
# Configure redirecting traffic to Ten-GigabitEthernet 1/0/1 in traffic behavior database.
[Sysname-behavior-database] redirect interface ten-gigabitethernet 1/0/1
classifier behavior
qos policy
traffic behavior
remark customer-vlan-id
Use remark customer-vlan-id to configure a CVLAN marking action in a traffic behavior.
Use undo remark customer-vlan-id to restore the default.
No CVLAN marking action is configured.
vlan-id: Specifies a CVLAN ID in the range of 1 to 4094.
# Configure traffic behavior b1 to mark matching packets with CVLAN 111.
[Sysname-behavior-b1] remark customer-vlan-id 111
remark dot1p
Use remark dot1p to configure an 802.1p priority marking action or an inner-to-outer tag priority copying action in a traffic behavior.
Use undo remark dot1p to restore the default.
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
No 802.1p priority marking action or inner-to-outer tag priority copying action is configured.
green: Specifies green packets.
red: Specifies red packets.
yellow: Specifies yellow packets.
dot1p-value: Specifies the 802.1p priority to be marked for packets, in the range of 0 to 7.
customer-dot1p-trust: Copies the 802.1p priority value in the inner VLAN tag to the outer VLAN tag.
The remark dot1p dot1p-value and remark dot1p customer-dot1p-trust commands override each other in the same traffic behavior. The remark dot1p customer-dot1p-trust command does not take effect on single-tagged packets.
If you execute the remark dot1p dot1p-value command multiple times for the same color, the most recent configuration takes effect.
# Configure traffic behavior database to mark matching traffic with 802.1p 2.
[Sysname-behavior-database] remark dot1p 2
# Configure an inner-to-outer tag priority copying action in traffic behavior database.
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
remark drop-precedence
Use remark drop-precedence to configure a drop priority marking action in a traffic behavior.
Use undo remark drop-precedence to restore the default.
remark drop-precedence drop-precedence-value
No drop priority marking action is configured.
drop-precedence-value: Specifies the drop priority to be marked for packets, in the range of 0 to 2.
A traffic behavior that includes a drop priority marking action can be applied only to the inbound direction.
If you execute the remark drop-precedence command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior database to mark matching traffic with drop priority 2.
[Sysname-behavior-database] remark drop-precedence 2
remark dscp
Use remark dscp to configure a DSCP marking action in a traffic behavior.
Use undo remark dscp to delete the action.
undo remark [ green | red | yellow ] dscp
No DSCP marking action is configured.
dscp-value: Specifies a DSCP value, which can be a number from 0 to 63 or a keyword in Table 5.
Table 5 DSCP keywords and values
Keyword |
DSCP value (binary) |
DSCP value (decimal) |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
default |
000000 |
0 |
ef |
101110 |
46 |
# Configure traffic behavior database to mark matching traffic with DSCP 6.
remark ip-precedence
Use remark ip-precedence to configure an IP precedence marking action in a traffic behavior.
Use undo remark ip-precedence to delete the action.
remark ip-precedence ip-precedence-value
No IP precedence marking action is configured.
ip-precedence-value: Specifies the IP precedence value to be marked for packets, in the range of 0 to 7.
# Set the IP precedence to 6 for packets.
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence
Use remark local-precedence to configure a local precedence marking action in a traffic behavior.
Use undo remark local-precedence to delete the action.
remark [ green | red | yellow ] local-precedence local-precedence-value
undo remark [ green | red | yellow ] local-precedence
No local precedence marking action is configured.
local-precedence-value: Specifies the local precedence to be marked for packets, in the range of 0 to 7.
On an IRF fabric, this command takes effect only on the member device where the input interface resides.
# Configure traffic behavior database to mark matching traffic with local precedence 2.
remark qos-local-id
Use remark qos-local-id to configure a local QoS ID marking action in a traffic behavior.
Use undo remark qos-local-id to restore the default.
remark qos-local-id local-id-value
No local QoS ID marking action is configured.
local-id-value: Specifies the local QoS ID to be marked for packets, in the range of 1 to 4095. The switch supports the range 1 to 3999.
To save QoS and ACL resources, you can use one QoS policy to mark the local QoS ID for incoming packets and to apply other QoS features based on the marked local QoS ID.
If you execute the remark qos-local-id command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure the action of marking packets with local QoS ID 2.
[Sysname-behavior-database] remark qos-local-id 2
remark service-vlan-id
Use remark service-vlan-id to configure an SVLAN marking action in a traffic behavior.
Use undo remark service-vlan-id to restore the default.
No SVLAN marking action is configured.
vlan-id: Specifies an SVLAN ID in the range of 1 to 4094.
# Configure traffic behavior b1 to mark matching packets with SVLAN 222.
[Sysname-behavior-b1] remark service-vlan-id 222
traffic behavior
Use traffic behavior to create a traffic behavior and enter its view, or enter the view of an existing traffic behavior.
Use undo traffic behavior to delete a traffic behavior.
No traffic behaviors exist.
behavior-name: Specifies a name for the traffic behavior, a case-sensitive string of 1 to 31 characters.
# Create a traffic behavior named behavior1.
[Sysname-behavior-behavior1]
QoS policy commands
classifier behavior
Use classifier behavior to associate a traffic behavior with a traffic class in a QoS policy.
Use undo classifier to delete a class-behavior association from a QoS policy.
classifier classifier-name behavior behavior-name [ mode { dcbx | qppb-manipulation } | insert-before before-classifier-name ]
No traffic behavior is associated with a traffic class.
QoS policy view
behavior-name: Specifies a traffic behavior by its name, a case-sensitive string of 1 to 31 characters.
mode dcbx: Specifies that the class-behavior association applies only to the DCBX. For more information about DCBX, see Layer 2—LAN Switching Configuration Guide.
mode qppb-manipulation: Specifies that a class-behavior association applies only to matching the apply qos-local-id command configuration in a BGP routing policy. For more information, see Layer 3—IP Routing Configuration Guide. This keyword is available only on HF cards. Before using this keyword, you must set the TCAM operating mode to routing by using the hardware-resource tcam command. For information about this command, see device management commands in Fundamentals Command Reference.
insert-before before-classifier-name: Inserts the new traffic class before an existing traffic class in the QoS policy. The before-classifier-name argument specifies an existing traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the insert-before before-classifier-name option, the new traffic class is placed at the end of the QoS policy.
A traffic class can be associated only with one traffic behavior in a QoS policy.
If the specified traffic class or traffic behavior does not exist, the system defines a null traffic class or traffic behavior.
# Associate traffic class database with traffic behavior test in QoS policy user1.
[Sysname] qos policy user1
# Associate traffic class database with traffic behavior test in QoS policy user1, and insert traffic class database before an existing traffic class named class-a.
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
qos policy
control-plane
Use control-plane to enter control plane view.
A QoS policy applied in control plane view takes effect on all packets to the control plane except the packets sent from the management interface.
# Enter the control plane view of slot 3.
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
display qos policy
Use display qos policy to display QoS policies.
display qos policy user-defined [ accounting | remarking ] [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
user-defined: Specifies user-defined QoS policies.
accounting: Specifies accounting-type QoS policies.
remarking: Specifies marking-type QoS policies.
policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a QoS policy, this command displays all user-defined QoS policies.
classifier classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the QoS policies for the master device.
If you do not specify the accounting or remarking keyword, this command displays generic QoS policies.
# Display all user-defined generic QoS policies.
User-defined QoS policy information:
Policy: 1 (ID 100)
Behavior: 1
Marking:
Remark dscp 3
CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
Green action : pass
Behavior: 2
Marking:
Remark dot1p 4
Behavior: 3
-none-
# Display user-defined accounting-type QoS policies.
<Sysname> display qos policy user-defined accounting
Accounting policy: 1 (ID 100)
Behavior: 1
# Display user-defined marking-type QoS policies.
<Sysname> display qos policy user-defined remarking
Marking policy: 1 (ID 100)
Behavior: 1
Marking:
Remark dscp 3
Accounting policy |
User-defined accounting-type QoS policy name. |
Marking policy |
User-defined marking-type QoS policy name. |
For the description of other fields, see Table 1 and Table 4.
Use display qos policy control-plane to display QoS policies applied to a control plane.
# Display the QoS policy applied to the control plane of slot 2.
<Sysname> display qos policy control-plane slot 2
Control plane slot 2
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
Table 7 Command output
Direction |
Inbound direction on the control plane. |
Green packets |
Statistics about green packets. |
Red packets |
Statistics about red packets. |
Use display qos policy control-plane pre-defined to display predefined control plane QoS policies.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays predefined control plane QoS policies for all member devices.
# Display the predefined control plane QoS policy of slot 1.
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
Protocol Priority Bandwidth Group
Default N/A 1000 (pps) N/A
IS-IS 18 1000 (pps) critical
VRRP 19 1000 (pps) important
OSPF Multicast 18 1000 (pps) critical
OSPF Unicast 18 1000 (pps) critical
IGMP 11 500 (pps) important
OSPFv3 Unicast 18 1000 (pps) critical
OSPFv3 Multicast 18 1000 (pps) critical
VRRPv6 19 1000 (pps) important
ARP 2 1000 (pps) normal
DHCP Snooping 10 300 (pps) redirect
DHCP 10 300 (pps) normal
802.1x 3 500 (pps) important
STP 17 300 (pps) critical
LACP 22 300 (pps) critical
MVRP 15 300 (pps) critical
BGP 16 1000 (pps) critical
ICMP 3 500 (pps) monitor
TTL Expires 5 300 (pps) monitor
IPOPTION 5 300 (pps) normal
BGPv6 16 1000 (pps) critical
Hop Limit Expires 5 300 (pps) monitor
IPOPTIONv6 5 300 (pps) normal
LLDP 14 300 (pps) important
DLDP 16 300 (pps) critical
TELNET 1 800 (pps) management
SSH 1 800 (pps) management
TACACS 1 800 (pps) management
RADIUS 1 800 (pps) management
HTTP 3 500 (pps) management
HTTPS 3 500 (pps) management
SNMP 4 800 (pps) management
ARP Snooping 2 1000 (pps) redirect
ICMPv6 3 300 (pps) monitor
DHCPv6 10 300 (pps) normal
BFD 21 1000 (pps) critical
Table 8 Command output
Pre-defined control plane policy |
Contents of the predefined control plane QoS policy. |
Default |
Protocols other than those listed. |
Group |
Protocol group of the protocol. |
For descriptions of other fields, see Table 3.
Use display qos policy diagnosis control-plane to display diagnostic information about QoS policies applied to a control plane.
display qos policy diagnosis control-plane slot slot-number
# Display diagnostic information about the QoS policy applied to the control plane of slot 2.
<Sysname> display qos policy diagnosis control-plane slot 2
Direction: Inbound
Policy: 1
Classifier: 1 (Incomplete)
Operator: AND
Rule(s) :
If-match acl 2000 (Incomplete)
Failed Rule ID: 0, 3, 5, 50
Behavior: 1
Marking:
Remark dscp 3
CIR 112 (kbps), CBS 7000 (Bytes), EBS 512 (Bytes)
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
If-match not protocol ipv6
Behavior: 2
Accounting enable:
Marking:
Remark mpls-exp 4
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
Direction |
Direction in which the QoS policy is applied. |
Classifier: 1 (Incomplete) |
Traffic class application result: · Incomplete—Some contents of the traffic class were applied successfully. · Failed—All contents of the traffic class failed to be applied. |
If-match acl 2000 (Incomplete) |
Match criterion application result: · Incomplete—Some contents of the match criterion were applied successfully. · Failed—All contents of the match criterion failed to be applied. |
Failed rule ID |
ACL rules that failed to be applied. |
Use display qos policy diagnosis global to display diagnostic information about QoS policies applied globally.
display qos policy diagnosis global [ slot slot-number ] [ inbound | outbound ]
inbound: Specifies the QoS policy applied in the inbound direction.
outbound: Specifies the QoS policy applied in the outbound direction.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays diagnostic information about globally applied QoS policies for the master device.
If you do not specify a direction, this command displays diagnostic information about both QoS policies.
# Display diagnostic information about QoS policies applied globally.
<Sysname> display qos policy diagnosis global
Direction: Inbound
Operator: AND
Rule(s) :
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
Marking:
Remark mpls-exp 4
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
For information about the command output, see Table 1, Table 4, and Table 9.
Use display qos policy diagnosis interface to display diagnostic information about the QoS policies applied to interfaces.
display [ accounting | remarking ] qos policy diagnosis interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays diagnostic information about QoS policies on all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, this command displays diagnostic information about QoS policies for the master device. This option is available only if you have specified an aggregate interface.
inbound: Specifies the QoS policy applied to incoming traffic.
outbound: Specifies the QoS policy applied to outgoing traffic.
If you do not specify the accounting or remarking keyword, this command displays diagnostic information about generic QoS policies.
If you do not specify a direction, this command displays diagnostic information about the QoS policy applied to incoming traffic and the QoS policy applied to outgoing traffic.
# Display diagnostic information about the generic QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos policy diagnosis interface ten-gigabitethernet 1/0/1 inbound
Direction: Inbound
Policy: 1
Operator: AND
Rule(s) :
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Marking:
Remark mpls-exp 4
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
# Display diagnostic information about the accounting-type QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/2.
<Sysname> display qos accounting policy diagnosis interface ten-gigabitethernet 1/0/2 inbound
Interface: Ten-GigabitEthernet 1/0/2
Direction: Inbound
Operator: AND
Rule(s) :
Behavior: 1
# Display diagnostic information about the marking-type QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/3.
<Sysname> display qos remarking policy diagnosis interface ten-gigabitethernet 1/0/3 inbound
Interface: Ten-GigabitEthernet 1/0/3
Direction: Inbound
Marking policy: 1
Operator: AND
Rule(s) :
Behavior: 1
Marking:
Remark dscp 3
For information about the command output, see Table 1, Table 4, Table 6, and Table 9.
Use display qos policy diagnosis l2vpn-ac to display diagnostic information about the QoS policies applied to Ethernet service instances.
display qos policy diagnosis l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays diagnostic information about QoS policies applied to Ethernet service instances on all interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays diagnostic information about QoS policies applied to all Ethernet service instances on an interface.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays QoS policy diagnostic information for all member devices. This option is available only if you have specified a Layer 2 aggregate interface.
inbound: Specifies the QoS policies applied to incoming traffic. If you do not specify this keyword, the command execution results are the same.
# Display diagnostic information about the QoS policy applied to the incoming traffic of Ethernet service instance 1 on Ten-GigabitEthernet 1/0/1.
<Sysname> display qos policy diagnosis interface ten-gigabitethernet 1/0/1 service-instance 1 inbound
Interface: Ten-GigabitEthernet1/0/1 Service instance ID: 1
Direction: Inbound
Policy: 1
Operator: AND
Rule(s) :
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Marking:
Remark mpls-exp 4
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
Table 10 Command output
Direction |
Failed rule ID |
Use display qos policy diagnosis user-profile to display diagnostic information about QoS policies applied to user profiles.
display qos policy diagnosis user-profile [ name profile-name ] [ user-id user-id ] [ slot slot-number ] [ inbound | outbound ]
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, and underscores (_). The name must start with an English letter and must be unique. If you do not specify a user profile, this command displays diagnostic information about QoS policies applied to all user profiles.
user-id user-id: Specifies an online user by a system-assigned, hexadecimal ID in the range of 0 to fffffffe. If you do not specify an online user, this command displays diagnostic information about QoS policies applied to user profiles for all online users.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays diagnostic information about QoS policies applied to user profiles for all member devices.
inbound: Specifies QoS policies applied to incoming traffic.
outbound: Specifies QoS policies applied to outgoing traffic.
If you do not specify a direction, this command displays diagnostic information about QoS policies applied in the inbound direction and QoS policies applied in the outbound direction.
# Display diagnostic information about the QoS policy applied to user profile abc for a global user.
<Sysname> display qos policy user-profile name abc user-id 30000000 inbound
User-Profile: abc
User ID: 0x30000000(global)
Direction: Inbound
Policy: 1
Operator: AND
Rule(s) :
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Marking:
Remark mpls-exp 4
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
Use display qos policy diagnosis vsi to display diagnostic information about the QoS policies applied to VSIs.
display qos policy diagnosis vsi [ name vsi-name ] [ inbound ] [ slot slot-number ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays diagnostic information about QoS policies applied to all VSIs.
inbound: Specifies the QoS policy applied to incoming traffic. Because a VSI does not support a QoS policy in the outbound direction, the command execution result is the same no matter whether you specify this keyword.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays diagnostic information about QoS policies applied to VSIs on all IRF member devices.
# Display diagnostic information about QoS policies applied to all VSIs.
<Sysname> display qos policy diagnosis vsi
VSI: vsi1
Direction: Inbound
Policy: p
Classifier: c (Incomplete)
Operator: AND
Rule(s) :
If-match any (Incomplete)
Behavior: b
CIR 88 (kbps), CBS 5632 (Bytes), EBS 0 (Bytes)
Green action : pass
Table 11 Command output
VSI |
VSI name. |
Direction |
Policy |
QoS policy name. |
Classifier: c (Incomplete) |
Operator |
Operator for match criteria in the traffic class. |
Behavior |
Behavior name. |
Green action |
Yellow action |
Red action |
Failed rule ID |
qos apply policy (VSI view)
display qos policy global
Use display qos policy global to display global QoS policies.
inbound: Displays inbound global QoS policies. An inbound global QoS policy applies to the incoming traffic globally.
outbound: Displays outbound global QoS policies. An outbound global QoS policy applies to the outgoing traffic globally.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays global QoS policies for the master device.
If you do not specify a direction, this command displays both inbound and outbound global QoS policies.
# Display QoS policies applied globally.
<Sysname> display qos policy global
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Red packets : 0 (Packets) 0 (Bytes)
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
Table 12 Command output
Direction |
Direction (inbound or outbound ) in which the QoS policy is applied. |
Green packets |
Red packets |
display qos policy interface
Use display qos policy interface to display the QoS policies applied to interfaces.
display qos [ accounting | remarking ] policy interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, this command displays QoS policies on the master device. Only virtual interfaces such as VLAN interfaces and aggregate interfaces support this option.
inbound: Displays the QoS policy applied to the incoming traffic of the specified interface.
outbound: Displays the QoS policy applied to the outgoing traffic of the specified interface.
If you do not specify the accounting or remarking keyword, this command displays generic QoS policies applied.
If you do not specify a direction, this command displays the QoS policy applied to incoming traffic and the QoS policy applied to outgoing traffic.
# Display the generic QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos policy interface ten-gigabitethernet 1/0/1 inbound
Direction: Inbound
Policy: 1
Classifier: 1
Matched : 0 (Packets) 0 (Bytes)
5-minute statistics:
Forwarded: 0/0 (pps/bps)
Dropped : 0/0 (pps/bps)
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
# Display diagnostic information about the accounting-type QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos accounting policy interface ten-gigabitethernet 1/0/1 inbound
Direction: Inbound
Accounting Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Accounting enable:
0 (Packets)
# Display diagnostic information about the marking-type QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos remarking policy interface ten-gigabitethernet 1/0/1 inbound
Direction: Inbound
Marking policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
# Display the QoS policies applied to all interfaces.
Direction: Inbound
Mode : Share
Policy: a
Classifier: a
Operator: AND
Rule(s) :
If-match any
Behavior: a
Mirroring:
Mirror to the interface: Ten-GigabitEthernet1/0/2
CIR 112 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
Green action : pass
Interface: Ten-GigabitEthernet1/0/3
Direction: Inbound
Policy: b
Classifier: b
Operator: AND
Rule(s) :
If-match any
Behavior: b
Green action : pass
Green packets : 0(Packets)
Direction: Inbound
Mode : Share
Policy: a
Classifier: a
Operator: AND
Rule(s) :
If-match any
Behavior: a
Mirroring:
Mirror to the interface: Ten-GigabitEthernet1/0/4
Green action : pass
Table 13 Command output
Direction |
Direction in which the QoS policy is applied to the interface. |
Mode |
Sharing mode for QoS and ACL resources. This field appears only if a QoS policy is applied with the share-mode keyword. |
Matched |
Number of matching packets. |
Forwarded |
Average rate of successfully forwarded matching packets in a statistics collection period. |
Dropped |
Average rate of dropped matching packets in a statistics collection period. |
Green packets |
Traffic statistics for green packets. |
Red packets |
Traffic statistics for red packets. |
For the description of other fields, see Table 1, Table 4, and Table 6.
display qos policy l2vpn-ac
Use display qos policy l2vpn-ac to display the QoS policies applied to Ethernet service instances.
display qos policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays QoS policies applied to Ethernet service instances on all interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays QoS policies applied to all Ethernet service instances on an interface.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, this command displays QoS policy information for all member devices Only aggregate interfaces support this option.
inbound: Displays the QoS policies applied to the incoming traffic of Ethernet service instances. If you do not specify this keyword, the command execution results are the same.
# Display the QoS policy applied to the incoming traffic of Ethernet service instance 1 on Ten-GigabitEthernet 1/0/1.
<Sysname> display qos policy l2vpn-ac interface Ten-GigabitEthernet 1/0/1 service-instance 1 inbound
Direction: Inbound
Policy: p
Classifier: c
Operator: AND
Rule(s) :
If-match any
Behavior: b
Green action : pass
Table 14 Command output
Direction |
Green packets |
Red packets |
For the description of fields, see Table 1 and Table 4.
Use display qos policy user-profile to display QoS policies applied to user profiles.
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ slot slot-number ] [ inbound | outbound ]
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, and underscores (_). The name must start with an English letter and must be unique. If you do not specify a user profile, this command displays QoS policies applied to all user profiles.
user-id user-id: Specifies an online user by a system-assigned, hexadecimal ID in the range of 0 to fffffffe. If you do not specify an online user, this command displays QoS policies applied to user profiles for all online users.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays QoS policies applied to user profiles for all member devices.
If you do not specify a direction, this command displays QoS policies applied in the inbound direction and QoS policies applied in the outbound direction.
# Display the QoS policy applied to user profile abc for a global user.
User-Profile: abc
Direction: Inbound
Policy: p1
Classifier: default-class
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
# Display the QoS policy applied to user profile abc for a local user.
<Sysname> display qos policy user-profile name abc user-id 30000001 inbound
User-Profile: abc
slot 2:
User ID: 0x30000001(local)
Direction: Inbound
Policy: p1
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
Table 15 Command output
global |
Indicates a global user, who comes online from a global interface such as an aggregate interface. |
local |
Indicates a local user, who comes online from a physical interface. |
Matched |
Number of packets that meet match criteria. |
Green packets |
Red packets |
display qos policy vsi
Use display qos policy vsi to display QoS policies applied to VSIs.
display qos policy vsi [ name vsi-name ] [ inbound ] [ slot slot-number ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays QoS policies applied to all VSIs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays QoS policies applied to VSIs on all IRF member devices.
# Display QoS policies applied to all VSIs.
<Sysname> display qos policy vsi
VSI: vsi1
Direction: Inbound
Policy: p
Classifier: c
Operator: AND
Rule(s) :
If-match any
Behavior: b
Green action : pass
Table 16 Command output
VSI |
VSI name. |
Direction |
Policy |
QoS policy name. |
Classifier |
Traffic class name. |
Operator |
Behavior |
Behavior name. |
Green action |
Red action |
Green packets |
Number of green packets. |
Yellow packets |
Number of yellow packets. |
Red packets |
Number of red packets. |
display qos vlan-policy
Use display qos vlan-policy to display QoS policies applied to VLANs.
name policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
inbound: Displays QoS policies applied to incoming traffic.
outbound: Displays QoS policies applied to outgoing traffic.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays QoS policies applied to VLANs for the master device.
If you do not specify a direction, this command displays QoS policies applied to VLANs in both the inbound and outbound directions.
# Display QoS policies applied to VLAN 2.
<Sysname> display qos vlan-policy vlan 2
Vlan 2
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
If-match protocol ipv6
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
Table 17 Command output
Direction |
Direction in which the QoS policy is applied for the VLAN. |
Green packets |
Red packets |
display qos vlan-policy diagnosis
Use display qos vlan-policy diagnosis to display diagnostic information about QoS policies applied to VLANs.
display qos vlan-policy diagnosis { name policy-name | vlan [ vlan-id ] } [ slot slot-number ] [ inbound | outbound ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays diagnostic information about QoS policies applied to VLANs for the master device.
If you do not specify a direction, this command displays diagnostic information about QoS policies applied to VLANs in both the inbound and outbound directions.
# Display diagnostic information about QoS policies applied to VLAN 2.
<Sysname> display qos vlan-policy diagnosis vlan 2
Vlan 2
Direction: Outbound
Type : Extension
Policy: 1
Operator: AND
Rule(s) :
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
Marking:
Remark mpls-exp 4
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
qos apply policy (Ethernet service instance view, interface view, control plane view, VSI view)
Use qos apply policy to apply a QoS policy to an Ethernet service instance, interface, control plane, or VSI.
Use undo qos apply policy to remove an applied QoS policy.
qos apply [ accounting | remarking ] policy policy-name { inbound | outbound } [ share-mode ]
undo qos apply [ accounting | remarking ] policy policy-name { inbound | outbound }
No QoS policy is applied.
Control plane view
Layer 2/Layer 3 Ethernet interface view
Layer 2/Layer 3 aggregate interface view
VSI interface view
VSI view
accounting: Specifies an accounting-type QoS policy. This keyword is supported only in interface view.
remarking: Specifies a marking-type QoS policy. This keyword is supported only in interface view.
inbound: Applies the QoS policy to incoming traffic.
outbound: Applies the QoS policy to outgoing traffic. This keyword is not supported in control plane view, Ethernet service instance view, or VSI view.
share-mode: Applies the QoS policy in sharing mode to a Layer 2 or Layer 3 Ethernet interface. In this mode, all interfaces on the device with the same QoS policy applied in one direction share one QoS and ACL resource. In the inbound direction, this mode is used by default.
A maximum of three QoS policies (one generic, one accounting type, and one marking type) can be applied to one direction of an interface.
The switch does not support accounting-type or marking-type QoS policies when acting as a PEX in an IRF 3.1 system.
If you specify the share-mode keyword when applying a QoS policy to the outbound direction of an interface, follow these restrictions and guidelines:
· The switch supports a maximum of seven QoS policies in sharing mode.
· The CAR and class-based accounting actions are not supported in the QoS policy.
You cannot change the sharing mode dynamically after a QoS policy is applied to an interface. To change the sharing mode for an applied QoS policy, perform the following tasks:
1. Remove the QoS policy from the interface.
2. Reapply the QoS policy with or without the share-mode keyword specified.
For information about VSI interfaces, see VXLAN Configuration Guide.
The switch supports applying a QoS policy only to the traffic received on an Ethernet service instance. For configuration commands for Ethernet service instances, see MPLS L2VPN or VPLS in MPLS Command Reference or see VXLAN Command Reference.
For VSI configuration commands, see VXLAN Command Reference.
You cannot apply a QoS policy to the outbound direction of a Layer 2 or Layer 3 aggregate interface.
# Apply generic QoS policy USER1 to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply policy USER1 outbound
# Apply accounting-type QoS policy USER1 to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply accounting policy USER1 outbound
# Apply marking-type QoS policy aaa to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply remarking policy aaa outbound
# Apply generic QoS policy aaa to the incoming traffic of the control plane of slot 3.
[Sysname-cp-slot3] qos apply policy aaa inbound
# Apply generic QoS policy test to the incoming traffic of Ethernet service instance 200.
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 200
[Sysname-Ten-GigabitEthernet1/0/1-srv200] qos apply policy test inbound
# Apply generic QoS policy aaa in sharing mode to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply policy aaa outbound share-mode
# Apply generic QoS policy test to the incoming traffic of VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] qos apply policy test inbound
vsi (VXLAN Command Reference)
qos apply policy (user profile view)
Use qos apply policy to apply a QoS policy to a user profile.
Use undo qos apply policy to remove a QoS policy applied to a user profile.
undo qos apply policy policy-name { inbound | outbound }
No QoS policy is applied to a user profile.
User profile view
inbound: Applies the QoS policy to the incoming traffic of the device (traffic sent by online users).
outbound: Applies the QoS policy to the outgoing traffic of the device (traffic received by online users).
Deleting a user profile also removes the QoS policies applied to the user profile.
# Apply QoS policy test to incoming traffic of user profile user.
[Sysname] user-profile user
[Sysname-user-profile-user] qos apply policy test outbound
qos apply policy global
Use qos apply policy global to apply a QoS policy globally.
Use undo qos apply policy global to remove a globally applied QoS policy.
undo qos apply policy policy-name global { inbound | outbound }
No QoS policy is applied globally.
inbound: Applies the QoS policy to the incoming packets on all interfaces.
outbound: Applies the QoS policy to the outgoing packets on all interfaces.
A global QoS policy takes effect on all incoming or outgoing traffic depending on the direction in which the QoS policy is applied.
# Globally apply QoS policy user1 to the incoming traffic.
[Sysname] qos apply policy user1 global inbound
qos policy
Use qos policy to create a QoS policy and enter its view, or enter the view of an existing QoS policy.
Use undo qos policy to delete a QoS policy.
qos [ accounting | remarking ] policy policy-name
undo qos [ accounting | remarking ] policy policy-name
No QoS policies exist.
policy-name: Specifies a name for the QoS policy, a case-sensitive string of 1 to 31 characters.
accounting: Identifies the QoS policy as an accounting-type QoS policy.
remarking: Identifies the QoS policy as a marking-type QoS policy.
The switch supports three QoS policy types: accounting, marking, and generic.
If you do not specify the accounting or remarking keyword when creating a QoS policy, a generic QoS policy is created.
A generic QoS policy can be applied to all supported destinations and can contain all actions. An accounting-type QoS policy can be applied to only interfaces and can contain only class-based accounting actions. A marking-type QoS policy can be applied to only interfaces and can contain only marking actions.
QoS policies of different types cannot use the same policy name.
To delete a QoS policy that has been applied to an object, you must first remove the QoS policy from the object.
# Create a generic QoS policy named user1.
# Create an accounting-type QoS policy named user2.
[Sysname] qos accounting policy user2
[Sysname-qospolicy-user2]
# Create a marking-type QoS policy named user3.
[Sysname] qos remarking policy user3
[Sysname-qospolicy-user3]
classifier behavior
qos apply policy
qos vlan-policy
qos vlan-policy
Use qos vlan-policy to apply a QoS policy to the specified VLANs.
Use undo qos vlan-policy to remove a QoS policy from the specified VLANs.
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
No QoS policy is applied to a VLAN.
vlan vlan-id-list: Specifies a space-separated list of up to eight VLAN IDs or a VLAN ID range in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
inbound: Applies the QoS policy to incoming packets.
outbound: Applies the QoS policy to outgoing packets.
# Apply QoS policy test to the incoming traffic of VLAN 200, VLAN 300, VLAN 400, and VLAN 500.
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy control-plane
Use reset qos policy control-plane to clear the statistics of the QoS policy applied to a control plane.
# Clear the statistics of the QoS policy applied to the control plane of slot 3.
<Sysname> reset qos policy control-plane slot 3
reset qos policy global
Use reset qos policy global to clear the statistics of a global QoS policy.
inbound: Clears the statistics of the global QoS policy applied to incoming traffic globally.
outbound: Clears the statistics of the global QoS policy applied to outgoing traffic globally.
If you do not specify a direction, this command clears the statistics of the global QoS policies in both directions.
# Clear the statistics of the global QoS policy applied to the incoming traffic globally.
<Sysname> reset qos policy global inbound
reset qos vlan-policy
Use reset qos vlan-policy to clear the statistics of the QoS policy applied in a certain direction of a VLAN.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
inbound: Clears the statistics of the QoS policy applied to the incoming traffic of the specified VLAN.
outbound: Clears the statistics of the QoS policy applied to the incoming traffic of the specified VLAN.
If you do not specify a direction, this command clears the statistics of the QoS policies in both directions of the VLAN.
# Clear the statistics of QoS policies applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
Priority mapping commands
Priority map commands
display qos map-table
Use display qos map-table to display the configuration of priority maps.
display qos map-table [ dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | exp-dot1p | exp-dp ]
The device provides the following types of priority map.
Priority mapping |
dot1p-dp |
802.1p-drop priority map. |
dot1p-exp |
802.1p-EXP priority map. |
dot1p-lp |
802.1p-local priority map. |
dscp-dot1p |
DSCP-802.1p priority map. |
dscp-dp |
DSCP-drop priority map. |
dscp-dscp |
DSCP-DSCP priority map. |
exp-dot1p |
EXP-802.1p priority map. |
exp-dp |
EXP-drop priority map. |
If you do not specify a priority map, this command displays the configuration of all priority maps.
# Display the configuration of the 802.1p-local priority map.
MAP-TABLE NAME: dot1p-lp TYPE: pre-define
IMPORT : EXPORT
0 : 2
1 : 0
2 : 1
3 : 3
4 : 4
5 : 5
6 : 6
7 : 7
Table 19 Command output
MAP-TABLE NAME |
Name of the priority map. |
TYPE |
Type of the priority map. |
IMPORT |
Input values of the priority map. |
EXPORT |
Output values of the priority map. |
import
Use import to configure mappings for a priority map.
Use undo import to restore the specified or all mappings to the default for a priority map.
The default priority maps are used. For more information, see ACL and QoS Configuration Guide.
Priority map view
import-value-list: Specifies a list of input values.
export-value: Specifies the output value.
all: Restores all mappings in the priority map to the default.
# Configure the 802.1p-local priority map to map 802.1p priority values 4 and 5 to local priority 1.
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
qos map-table
Use qos map-table to enter the specified priority map view.
qos map-table { dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | exp-dot1p | exp-dp }
For the description of keywords, see Table 18.
In a VXLAN IP gateway deployment, an interface that trusts the DSCP priority uses the dscp-dot1p priority map to modify the 802.1p priority of packets.
· If the switch is configured with the border mode, the interface modifies the 802.1p priority of both non-encapsulated packets and VXLAN-encapsulated packets.
· If the switch is configured with Layer 2 or Layer 3 gateway mode, the interface modifies the 802.1p priority of only VXLAN-encapsulated packets.
# Enter 802.1p-local priority map view.
import
Priority trust mode commands
display qos trust interface
Use display qos trust interface to display the priority trust mode and port priorities of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the priority trust mode and port priorities of all interfaces.
# Display the priority trust mode and port priority of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos trust interface ten-gigabitethernet 1/0/1
Port priority trust information
Port priority:4
Port dscp priority: -
Port priority trust type: dscp
Table 20 Command output
Interface type and interface number. |
Port priority |
Port priority set for the interface. |
Port dscp priority |
DSCP value rewritten for packets. If you have not rewritten the DSCP value of packets, this field displays a hyphen (-). |
Port priority trust type |
Priority trust mode on the interface: dot1p, dscp, or none. If the trust mode is none, the port priority is used for priority mapping. |
qos trust
Use qos trust to configure the priority trust mode for an interface.
Use undo qos trust to restore the default.
qos trust { dot1p | dscp }
undo qos trust
An interface does not trust any packet priority and uses the port priority as the 802.1p priority for mapping.
dot1p: Uses the 802.1p priority in incoming packets for priority mapping.
dscp: Uses the DSCP value in incoming packets for priority mapping.
For a VXLAN tunnel interface to trust the DSCP priority in the inner IP header of VXLAN packets, configure the qos trust dscp command on its physical interface.
The qos trust command and the qos priority dscp priority-value command are mutually exclusive. Do not configure both of them.
# Set the priority trust mode to 802.1p priority on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos trust dot1p
qos trust tunnel-dot1p
Use qos trust tunnel-dot1p to configure the switch to trust the 802.1p priority in the outer IP header of VXLAN packets.
Use undo qos trust tunnel-dot1p to restore the default.
The switch is not configured to trust the 802.1p priority in the outer IP header of VXLAN packets.
For PFC to take effect on an overlay network, configure this command on all VTEPs.
For a VXLAN tunnel interface to trust the 802.1p priority in the outer IP header of VXLAN packets, you must also configure the qos trust dot1p command on its physical interface.
# Configure the switch to trust the 802.1p priority in the outer IP header of VXLAN packets.
[Sysname] qos trust tunnel-dot1p
Port priority commands
qos priority
Use qos priority to change the port priority of an interface.
Use undo qos priority to restore the default.
qos priority [ dscp ] priority-value
undo qos priority [ dscp ]
The port priority is 0, and the DSCP value of packets is not modified.
priority-value: Specifies a priority value. If the dscp keyword is not specified, this argument specifies the port priority in the range of 0 to 7. If the dscp keyword is specified, this argument specifies the DSCP value to be set for packets, in the range of 0 to 63.
When no priority trust mode is configured for an interface, the interface uses the port priority as the 802.1p priority for priority mapping. If the qos priority dscp priority-value command is configured, the interface modifies the DSCP value of Layer 3 packets in addition to performing priority mapping.
The qos priority dscp priority-value command and the qos trust command are mutually exclusive. Do not configure both of them.
# Set the port priority of Ten-GigabitEthernet 1/0/1 to 2, and modify the DSCP value of Layer 3 packets to 20.
[Sysname-Ten-GigabitEthernet1/0/1] qos priority 2
[Sysname-Ten-GigabitEthernet1/0/1] qos priority dscp 20
GTS and rate limit commands
GTS commands
display qos gts interface
Use display qos gts interface to display the GTS information for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the GTS information for all interfaces.
# Display the GTS information for all interfaces.
Rule: If-match acl 2001
CIR 512 (kbps), CBS 51200 (Bytes), PIR 5120 (kbps), EBS 0 (Bytes)
Queue Length: 100 (Packets)
Queue Size: 70 (Packets)
Passed : 0 (Packets) 0 (Bytes)
Discarded: 0 (Packets) 0 (Bytes)
Delayed : 0 (Packets) 0 (Bytes)
Interface: Ten-GigabitEthernet1/0/2
CIR 64 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
Table 21 Command output
Interface name, including the interface type and interface number. |
Rule |
Match criteria. |
CIR |
CIR in kbps. |
CBS |
CBS in bytes. |
EBS |
EBS in bytes. |
PIR |
PIR in kbps. |
Queue Length |
Number of packets that the buffer can hold. |
Queue Size |
Number of packets in the buffer. |
Passed |
Number and bytes of packets that have been forwarded. |
Discarded |
Number and bytes of dropped packets. |
Delayed |
Number and bytes of delayed packets. |
qos gts
Use qos gts to set GTS parameters on an interface.
Use undo qos gts to delete the GTS configuration on an interface.
undo qos gts queue queue-id
No GTS parameters are configured on an interface.
queue queue-id: Shapes the packets in a queue specified by its ID. The value range for queue-id is 0 to 7.
cir committed-information-rate: Specifies the CIR in kbps. The committed-information-rate argument has the following value ranges:
· 8 to 10485760 for 10-GE interfaces.
· 8 to 41943040 for 40-GE interfaces.
The specified value must be an integral multiple of 8.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 16777216, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 16777216 is converted to 16777216.
# Shape the packets of queue 1 on Ten-GigabitEthernet 1/0/1 (CIR 6400 kbps and CBS 51200 bytes).
[Sysname-Ten-GigabitEthernet1/0/1] qos gts queue 1 cir 6400 cbs 51200
Rate limit commands
display qos lr interface
Use display qos lr interface to display the rate limit information for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the rate limit information for all interfaces.
# Display the rate limit information for all interfaces.
Direction: Inbound
CIR 2000 (kbps), CBS 20480 (Bytes)
Table 22 Command output
Direction |
Direction to which the rate limit configuration is applied: inbound or outbound. |
CIR |
CIR in kbps. |
CBS |
CBS in bytes. |
EBS |
EBS in bytes. |
Passed |
Number and bytes of packets that have passed. |
Discarded |
Delayed |
qos lr
Use qos lr to configure rate limiting on an interface.
Use undo qos lr to delete the rate limit configuration.
undo qos lr { inbound | outbound }
No rate limit is configured on an interface.
inbound: Limits the rate of incoming packets.
outbound: Limits the rate of outgoing packets.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 134217728, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 134217728 is converted to 134217728.
# Limit the rate of outgoing packets on Ten-GigabitEthernet 1/0/1, with CIR 256 kbps and CBS 51200 bytes.
[Sysname-Ten-GigabitEthernet1/0/1] qos lr outbound cir 256 cbs 51200
Congestion management commands
Common commands
display qos queue interface
Use display qos queue interface to display the queuing information for interfaces.
display qos queue interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queuing information for all interfaces.
# Display the queuing information for all interfaces.
<Sysname> display qos queue interface
Output queue: Strict Priority queuing
Interface: GigabitEthernet1/0/3
Interface: GigabitEthernet1/0/4
Interface: GigabitEthernet1/0/5
Interface: GigabitEthernet1/0/6
Table 23 Command output
Output queue |
Type of the current output queue. |
Group |
Number of the group that holds the queue. The group number can only be 1. |
Weight |
Packet-count scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
Byte-count |
Byte-count scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
SP commands
display qos queue sp interface
Use display qos queue sp interface to display the SP queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the SP queuing configuration of all interfaces.
# Display the SP queuing configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue sp interface ten-gigabitethernet 1/0/1
Table 24 Command output
Output queue |
qos sp
Use qos sp to enable SP queuing on an interface.
Use undo qos sp to restore the default.
qos sp
undo qos sp
An interface uses byte-count WRR queuing.
# Enable SP queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos sp
WRR commands
display qos queue wrr interface
Use display qos queue wrr interface to display the WRR queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRR queuing configuration of all interfaces.
# Display the WRR queuing configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue wrr interface ten-gigabitethernet 1/0/1
Output queue: Weighted Round Robin queuing
Queue ID Queue name Group Weight
0 be 1 1
1 af1 1 1
2 af2 1 1
3 af3 1 1
4 af4 1 1
5 ef 1 1
6 cs6 1 1
7 cs7 sp N/A
Table 25 Command output
Output queue |
Group |
Number of the group a queue is assigned to. By default, all queues belong to group 1. |
Weight |
Packet-count queue scheduling weight of a queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
Byte count |
Byte-count scheduling weight of a queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
qos wrr
Use qos wrr to enable WRR queuing on an interface.
Use undo qos wrr to restore the default.
qos wrr { byte-count | weight }
undo qos wrr { byte-count | weight }
byte-count: Allocates bandwidth to queues in bytes.
weight: Allocates bandwidth to queues in packets.
You must use the qos wrr command to enable WRR queuing before you can configure WRR queuing parameters for a queue on an interface.
# Enable packet-count WRR queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr weight
# Enable byte-count WRR queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr byte-count
Use qos wrr { byte-count | weight } to configure the WRR queuing parameters for a queue on an interface.
Use undo qos wrr to delete the WRR queuing parameters of a queue on an interface.
qos wrr queue-id group 1 { byte-count | weight } schedule-value
undo qos wrr queue-id
All queues on a WRR-enabled interface are in WRR group 1, and queues 0 through 7 have a weight of 1, 2, 3, 4, 5, 9, 13, and 15, respectively.
queue-id: Specifies a queue by its ID. The value range for this argument is 0 to 7 or keywords in Table 26.
Table 26 The number-keyword map for the queue-id argument
Number |
Keyword |
0 |
be |
1 |
af1 |
2 |
af2 |
3 |
af3 |
4 |
af4 |
5 |
ef |
6 |
cs6 |
7 |
cs7 |
group 1: Specifies WRR group 1. Only WRR group 1 is supported in the current software version.
schedule-value: Specifies a scheduling weight for the specified queue in WRR queuing. The value range for this argument is 1 to 15.
# Enable packet-based WRR queuing on Ten-GigabitEthernet 1/0/1, assign queue 0 to WRR group 1, and specify scheduling weight 10 for queue 0.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group 1 weight 10
qos wrr
qos wrr group sp
Use qos wrr group sp to assign a queue to the SP group.
Use undo qos wrr group sp to remove a queue from the SP group.
qos wrr queue-id group sp
All queues on a WRR-enabled interface are in WRR group 1.
This command is available only on a WRR-enabled interface. Queues in the SP group are scheduled with SP. The SP group has higher scheduling priority than the WRR groups.
You must use the qos wrr command to enable WRR queuing before you can configure this command on an interface.
# Enable WRR queuing on Ten-GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group sp
qos wrr
WFQ commands
display qos queue wfq interface
Use display qos queue wfq interface to display the WFQ configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WFQ configuration of all interfaces.
# Display the WFQ configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos wfq interface ten-gigabitethernet 1/0/1
Output queue: Hardware Weighted Fair Queuing
Queue ID Queue name Group Byte count Min Bandwidth
0 be 1 1 64
1 af1 1 1 64
2 af2 1 1 64
3 af3 1 1 64
4 af4 1 1 64
5 ef 1 1 64
6 cs6 1 1 64
7 cs7 1 1 64
Table 27 Command output
Output queue |
Group |
Number of the group that holds the queue. By default, all queues are in group 1. |
Byte-count |
Weight |
Packet-count queue scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
Min Bandwidth |
Minimum guaranteed bandwidth for the queue. |
qos bandwidth queue
Use qos bandwidth queue to set the minimum guaranteed bandwidth for a queue on an interface.
Use undo qos bandwidth queue to restore the default.
undo qos bandwidth queue queue-id
The minimum guaranteed bandwidth for a queue is 0 kbps.
min bandwidth-value: Sets the minimum guaranteed bandwidth in kbps. The bandwidth-value argument has the following value ranges:
· 8 to 10000000 for 10-GE interfaces.
· 8 to 40000000 for 40-GE interfaces.
The minimum guaranteed bandwidth is the amount of bandwidth guaranteed for a queue when the interface is congested.
You must use the qos wfq command to enable WFQ before you can configure this command on an interface.
# Set the minimum guaranteed bandwidth to 100 kbps for queue 0 on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq weight
[Sysname-Ten-GigabitEthernet1/0/1] qos bandwidth queue 0 min 100
qos wfq
qos wfq
Use qos wfq to enable WFQ on an interface.
Use undo qos wfq to restore the default.
qos wfq { byte-count | weight }
undo qos wfq { byte-count | weight }
You must use the qos wfq command to enable WFQ before you can configure WFQ queuing parameters for a queue on an interface.
# Enable packet-count WFQ on Ten-GigabitEthernet 1/0/1.
# Enable byte-count WFQ on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq byte-count
Use qos wfq { byte-count | weight } to assign a queue to a WFQ group with a certain scheduling weight.
Use undo qos wfq to delete the WFQ queuing parameters of a queue on an interface.
qos wfq queue-id group 1 { byte-count | weight } schedule-value
undo qos wfq queue-id
All queues on a WFQ-enabled interface are in WFQ group 1 and have a weight of 1.
group 1: Specifies WFQ group 1. Only WFQ group 1 is supported in the current software version.
schedule-value: Specifies a scheduling weight for the specified queue in WFQ queuing. The value range for this argument is 1 to 15.
You must use the qos wfq command to enable WFQ before you configure this command.
# Enable byte-count WFQ on Ten-GigabitEthernet 1/0/1, and specify scheduling weight 10 for queue 0.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq 0 group 1 byte-count 10
qos bandwidth queue
qos wfq
qos wfq group sp
Use qos wfq group sp to assign a queue to the SP group.
Use undo qos wfq group sp to remove a queue from the SP group.
qos wfq queue-id group sp
All queues on a WFQ-enabled interface are in WFQ group 1.
This command is available only on a WFQ-enabled interface. Queues in the SP group are scheduled with SP, instead of WFQ. The SP group has higher scheduling priority than the WFQ groups.
# Enable WFQ on Ten-GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq 0 group sp
qos bandwidth queue
qos wfq
Queue scheduling profile commands
bandwidth queue
Use bandwidth queue to set the minimum guaranteed bandwidth for a queue.
Use undo bandwidth queue to restore the default.
undo bandwidth queue queue-id
Queue scheduling profile view
min bandwidth-value: Specifies the minimum guaranteed bandwidth in kbps. The value range for the bandwidth-value argument is 8 to 100000000.
You must configure a queue as a WFQ queue before you set the minimum guaranteed bandwidth for the queue.
# Configure queue 0 as a WFQ queue, and set the minimum guaranteed bandwidth to 100 kbps for queue 0.
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 0 wfq group 1 weight 1
[Sysname-qmprofile-myprofile] bandwidth queue 0 min 100
display qos qmprofile configuration
Use display qos qmprofile configuration to display the queue scheduling profile configuration.
profile-name: Specifies a queue scheduling profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a queue scheduling profile, this command displays the configuration of all queue scheduling profiles.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the queue scheduling profile configuration for the master device.
# Display the configuration of queue scheduling profile myprofile.
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
Queue ID Type Group Schedule Schedule Min Max
unit value bandwidth bandwidth
be WRR 1 weight 1 N/A N/A
af1 WRR 1 weight 2 N/A N/A
af2 WRR 1 weight 3 N/A N/A
af3 WRR 1 weight 4 N/A N/A
af4 WRR 1 weight 5 N/A N/A
ef WRR 1 weight 9 N/A N/A
cs6 WRR 1 weight 13 N/A N/A
cs7 WRR 1 weight 15 N/A N/A
Table 28 Command output
Queue management profile |
Queue scheduling profile name. |
Type |
Queue scheduling type: · SP. · WRR. · WFQ. |
Group |
Priority group to which the queue belongs. The value can only be 1. N/A indicates this field is ignored. |
Schedule unit |
Scheduling unit: weight or byte-count. N/A indicates that this field is ignored. |
Schedule value |
This field indicates: · Number of packets for the weight scheduling unit. · Number of bytes for the byte-count scheduling unit. |
Min bandwidth |
Minimum guaranteed bandwidth for the queue. N/A indicates that this field is ignored. |
Max bandwidth |
Maximum allowed bandwidth for the queue. N/A indicates that this field is ignored. |
display qos qmprofile interface
Use display qos qmprofile interface to display the queue scheduling profile applied to an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queue scheduling profiles applied to all interfaces.
# Display the queue scheduling profile applied to Ten-GigabitEthernet 1/0/1.
<Sysname> display qos qmprofile interface ten-gigabitethernet 1/0/1
Table 29 Command output
Name of the queue scheduling profile applied to the interface. |
qos apply qmprofile
Use qos apply qmprofile to apply a queue scheduling profile to an interface.
Use undo qos apply qmprofile to restore the default.
No queue scheduling profile is applied to an interface.
You can apply only one queue scheduling profile to an interface.
# Apply queue scheduling profile myprofile to the outbound direction of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply qmprofile myprofile
qos qmprofile
Use qos qmprofile to create a queue scheduling profile and enter its view, or enter the view of an existing queue scheduling profile.
Use undo qos qmprofile to delete a queue scheduling profile.
qos qmprofile profile-name
undo qos qmprofile profile-name
No user-created queue scheduling profiles exist.
profile-name: Specifies a name for the queue scheduling profile, a case-sensitive string of 1 to 31 characters.
To delete a queue scheduling profile already applied to an object, first remove it from the object.
# Create a queue scheduling profile named myprofile and enter queue scheduling profile view.
queue
queue
Use queue to configure queue scheduling parameters.
Use undo queue to delete queue scheduling parameter settings.
queue queue-id { sp | wfq [ group group-id ] { weight | byte-count } schedule-value | wrr group group-id { weight | byte-count } schedule-value }
undo queue queue-id
All queues in a queue scheduling profile use packet-count WRR queuing, and queues 0 through 7 have a weight of 1, 2, 3, 4, 5, 9, 13, and 15, respectively.
sp: Enables SP for the queue.
wfq: Enables WFQ for the queue.
wrr: Enables WRR for the queue.
group group-id: Specifies a WFQ or WRR group by its ID. The group ID can only be 1.
schedule-value: Specifies the scheduling weight. The value range for this argument is 1 to 15.
To change the scheduling unit of a queue, you must first configure all queues as SP queues and then reconfigure the queues as required.
# Create a queue scheduling profile named myprofile, and configure queue 0 to use SP.
[Sysname-qmprofile-myprofile] queue 0 sp
# Create a queue scheduling profile named myprofile. Configure queue 1 to meet the following requirements:
· The WRR queuing is used.
· The WRR group is group 1.
· The scheduling weight is 10.
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 10
qos qmprofile
Queue aging time commands
qos queue aging-time
Use qos queue aging-time to set the queue aging time.
Use undo qos queue aging-time to restore the default.
qos queue aging-time time-value
The aging function is disabled.
time-value: Specifies the queue aging time in the range of 100 to 500 milliseconds. The specified value must be an integral multiple of 100.
The aging timer starts when a packet enters a queue. If the packet is still in the queue when the aging timer expires, the packet is dropped.
# Set the queue aging time to 100 milliseconds.
[Sysname] qos queue aging-time 100
Queue-based accounting commands
display qos queue-statistics interface outbound
Use display qos queue-statistics interface outbound to display queue-based outgoing traffic statistics for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queue-based outgoing traffic statistics for all interfaces.
# Display queue-based outgoing traffic statistics for Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue-statistics interface ten-gigabitethernet 1/0/1 outbound
Direction: outbound
Forwarded: 0 packets, 0 bytes
Dropped: 0 packets, 0 bytes
Queue 0
Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
Current queue length: 0 packets
Queue 1
Queue 2
Queue 3
Queue 4
Queue 5
Queue 6
Queue 7
Table 30 Command output
Interface for which queue-based traffic statistics are displayed. |
Direction |
Direction of traffic for which statistics are collected. |
Forwarded |
Counts forwarded traffic both in packets and in bytes. |
Dropped |
Counts dropped traffic both in packets and in bytes. |
Current queue length |
Number of packets in the queue. |
reset counters interface (Interface Command Reference)
Congestion avoidance commands
WRED commands
display qos wred interface
Use display qos wred interface to display the WRED information for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRED information for all interfaces.
# Display the WRED information for all interfaces.
<Sysname> display qos wred interface
Current WRED configuration:
Applied WRED table name: q1
Table 31 Command output
display qos wred table
Use display qos wred table to display the WRED table configuration.
name table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command displays the configuration of all WRED tables.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the WRED table configuration for the master device.
# Display the configuration of WRED table 1.
<Sysname> display qos wred table name 1
Table name: 1
Table type: Queue based WRED
QID gmin gmax gprob ymin ymax yprob rmin rmax rprob exponent ECN
0 100 1000 10 100 1000 10 100 1000 10 9 N
1 100 1000 10 100 1000 10 100 1000 10 9 N
2 100 1000 10 100 1000 10 100 1000 10 9 N
3 100 1000 10 100 1000 10 100 1000 10 9 N
4 100 1000 10 100 1000 10 100 1000 10 9 N
5 100 1000 10 100 1000 10 100 1000 10 9 N
6 100 1000 10 100 1000 10 100 1000 10 9 N
7 100 1000 10 100 1000 10 100 1000 10 9 N
Table 32 Command output
Table name |
Name of a WRED table. |
Table type |
Type of a WRED table. |
QID |
Queue ID. |
gmin |
Lower limit for green packets. |
gmax |
Upper limit for green packets. |
gprob |
Drop probability for green packets. |
ymin |
Lower limit for yellow packets. |
ymax |
Upper limit for yellow packets. |
yprob |
Drop probability for yellow packets. |
rmin |
Lower limit for red packets. |
rmax |
Upper limit for red packets. |
rprob |
Drop probability for red packets. |
exponent |
Exponent for average queue length calculation. |
ECN |
Indicates whether ECN is enabled for the queue: · Y—Enabled. · N—Disabled. |
qos wred apply
Use qos wred apply to apply a WRED table to an interface.
Use undo qos wred apply to restore the default.
qos wred apply [ table-name ]
undo qos wred apply
No WRED table is applied to an interface, and the tail drop mode is used on an interface.
table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command applies the default WRED table to the interface.
# Apply WRED table table1 to Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wred apply table1
qos wred queue table
Use qos wred queue table to create a WRED table and enter its view, or enter the view of an existing WRED table.
Use undo qos wred queue table to delete a WRED table.
undo qos wred queue table table-name
No WRED tables exist.
table table-name: Specifies a name for the WRED table, a case-sensitive string of 1 to 32 characters.
You cannot delete a WRED table in use. To delete it, first remove it from the specified interface.
You can use the display qos wred table command to display the default WRED table, which cannot be modified or deleted.
# Create a queue-based WRED table named queue-table1.
[Sysname-wred-table-queue-table1]
queue
Use queue to configure the drop-related parameters for a queue in the queue-based WRED table.
Use undo queue to restore the default.
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-id | all }
The lower limit is 100, the upper limit is 1000, and the drop probability is 10%.
WRED table view
all: Specifies all queues.
queue-id: Specifies a queue by its ID. The value range for this argument is 0 to 7.
drop-level drop-level: Specifies a drop level. This argument is a consideration for dropping packets. The value 0 corresponds to green packets, the value 1 corresponds to yellow packets, and the value 2 corresponds to red packets. If you do not specify a drop level, the subsequent configuration takes effect on the packets in the queue regardless of the drop level.
low-limit low-limit: Specifies the lower limit for the average queue length. The value range for low-limit is 0 to 38000 bytes, in increments of 208.
high-limit high-limit: Specifies the upper limit for the average queue length. The value range for high-limit is 0 to 38000 bytes, in increments of 208. The upper limit must be greater than the lower limit.
discard-probability discard-prob: Specifies the denominator for drop probability calculation. The greater the denominator, the greater the calculated drop probability. The value range for discard-prob is 0 to 100.
When the average queue size is smaller than the lower threshold, no packet is dropped. When the average queue size is between the lower threshold and the upper threshold, the packets are dropped at random. The longer the queue is, the higher the drop probability is. When the average queue size exceeds the upper threshold, subsequent packets are dropped.
# In queue-based WRED table queue-table1, configure the following drop-related parameters for packets in queue 1:
· The drop level is 1.
· The lower limit for the average queue length is 10.
· The upper limit for the average queue length is 20.
· The drop probability is 30%.
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
queue ecn
Use queue ecn to enable ECN for a queue.
Use undo queue ecn to restore the default.
queue queue-id ecn
undo queue queue-id ecn
ECN is disabled for a queue.
WRED table view
queue-id: Specifies a queue by its ID in the range of 0 to 7.
When both the receiver and sender support ECN, the device can notify the peer end of the congestion status by identifying and setting the ECN flag. ECN avoids deteriorating congestion.
# In WRED table queue-table1, enable ECN for queue 1.
[Sysname-wred-table-queue-table1] queue 1 ecn
queue weighting-constant
Use queue weighting-constant to specify an exponent for average queue length calculation for a queue.
Use undo queue weighting-constant to restore the default.
queue queue-id weighting-constant exponent
undo queue queue-id weighting-constant
The exponent for average queue length calculation is 9.
WRED table view
weighting-constant exponent: Specifies the WRED exponent for average queue length calculation. The value range for exponent is 0 to 15.
The bigger the exponent is, the less sensitive the average queue size is to real-time queue size changes. The average queue size is calculated using the formula:
Average queue size = previous average queue size × (1-2-n) + current queue size × 2-n,
where n can be configured with the qos wred weighting-constant command.
# In WRED table queue-table1, set the exponent for average queue length calculation to 12 for queue 1.
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
Aggregate CAR commands
car name
Use car name to use an aggregate CAR action in a traffic behavior.
Use undo car to restore the default.
car name car-name
undo car
No aggregate CAR action is configured in a traffic behavior.
Traffic behavior view
car-name: Specifies the name of an aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
# Use aggregate CAR action aggcar-1 in traffic behavior be1.
display qos car name
display traffic behavior user-defined
Use display qos car name to display information about aggregate CAR actions.
car-name: Specifies an aggregate CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify an aggregate CAR action, this command displays information about all aggregate CAR actions.
# Display information about all aggregate CAR actions.
<Sysname> display qos car name
Mode: aggregative
CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Slot 0:
Green packets : 0 (Packets), 0 (Bytes)
Red packets : 0 (Packets), 0 (Bytes)
Slot 1:
Slot 2:
Apply failed
Table 33 Command output
Name |
Name of the aggregate CAR action. |
Mode |
Type of the CAR action, which can be aggregative. |
CIR CBS PIR EBS |
Parameters for the CAR action. |
Green action |
Action to take on green packets: · discard—Drops the packets. · pass—Permits the packets to pass through. |
Yellow action |
Action to take on yellow packets: · discard—Drops the packets. · pass—Permits the packets to pass through. |
Red action |
Action to take on red packets: · discard—Drops the packets. · pass—Permits the packets to pass through. |
Green packets |
Statistics about green packets. |
Red packets |
Statistics about red packets. |
qos car
Use qos car aggregative to configure an aggregate CAR action.
Use undo qos car to delete an aggregate CAR action.
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
No aggregate CAR action is configured.
car-name: Specifies the name of the aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
cir committed-information-rate: Specifies the CIR in kbps, which is an average traffic rate. The value range for committed-information-rate is 8 to 160000000, in increments of 8.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 256000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the EBS in bytes. The value range for excess-burst-size is 0 to 256000000, in increments of 512. If the PIR is configured, the default EBS is the product of 62.5 and the PIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000.
pir peak-information-rate: Specifies the PIR in kbps. The value range for peak-information-rate is 8 to 160000000, in increments of 8.
green action: Specifies the action to take on packets that conform to CIR. The default setting is pass.
red action: Specifies the action to take on the packet that conforms to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to PIR but not to CIR. The default setting is pass.
action: Specifies the action to take on packets:
· discard: Drops the packet.
· pass: Permits the packet to pass through.
· remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
· remark-dscp-pass new-dscp: Remarks the packet with a new DSCP value and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63. Alternatively, you can specify the new-dscp argument with af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
To use two rates for aggregate CAR, configure the qos car command with the pir peak-information-rate option. To use one rate for aggregate CAR, configure the qos car command without the pir peak-information-rate option.
An aggregate CAR action takes effect only after it is applied to an interface or used in a QoS policy.
# Configure aggregate CAR action aggcar-1, where CIR is 25600, CBS is 512000, and red packets are dropped.
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
reset qos car name
Use reset qos car name to clear the statistics about aggregate CAR actions.
car-name: Specifies an aggregate CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify an aggregate CAR action, this command clears statistics for all aggregate CAR actions.
# Clear the statistics about aggregate CAR action aggcar-1.
<Sysname> reset qos car name aggcar-1
