00-Preface
Preface
H3C Transceiver Modules and Network Cables Installation Guide describes transceiver module and cable views and guides you through the installation of transceiver modules, including installation and removal procedures and installation verification.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the devices.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
