HomeSupportSwitchesH3C S5560-EI Switch SeriesConfigure & DeployConfiguration GuidesH3C S5560-EI Switch Series Configuration Guide-Release 1312-6W10101-Fundamentals Configuration Guide
00-Preface
00-Preface 100.63 KB
Preface
This configuration guide describes features and tasks that help you get started with the device, including:
·          CLI and RBAC.
·          Device login and device access control.
·          Management of the device, file systems, and configuration files.
·          FTP and TFTP.
·          Tcl and Python.
·          ISSU and common software upgrade.
·          License management.
·          Automatic configuration.
·          Audience
·          Conventions
·          Documentation feedback
Audience
·          Network planners.
·          Field technical support and servicing engineers.
·          Network administrators working with the S5560-EI switch series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
