12-Security Configuration Guide
HomeSupportRoutersH3C SR8800-F Router SeriesConfigure & DeployConfiguration GuidesH3C SR8800-F Routers Configuration Guides-Release7951PXX-6W10012-Security Configuration Guide
10-Object group configuration
10-Object group configuration 39.67 KB
Configuring object groups
About object groups
An object group is a group of objects that can be used by an ACL to identify packets. Object groups are divided into the following types:
·          IPv4 address object group—A group of IPv4 address objects used to match the IPv4 address in a packet or match the user from whom a packet comes.
·          IPv6 address object group—A group of IPv6 address objects used to match the IPv6 address in a packet or match the user from whom a packet comes.
·          Port object group—A group of port objects used to match the protocol port number in a packet.
Configuring an IPv4 address object group
1.        Enter system view.
2.        Configure an IPv4 address object group and enter its view.
object-group ip address object-group-name
The system has one default IPv4 address object group named any.
3.        (Optional.) Configure a description for the IPv4 address object group.
By default, an object group does not have a description.
4.        Configure an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name } | subnet ip-address { mask-length | mask } | range ip-address1 ip-address2 }
Configuring an IPv6 address object group
2.        Configure an IPv6 address object group and enter its view.
object-group ipv6 address object-group-name
The system has one default IPv6 address object group named any.
3.        (Optional.) Configure a description for the IPv6 address object group.
4.        Configure an IPv6 address object.
[ object-id ] network { host { address ipv6-address | name host-name } | subnet ipv6-address prefix-length | range ipv6-address1 ipv6-address2 }
Configuring a port object group
2.        Configure a port object group and enter its view.
object-group port object-group-name
The system has one default port object group named any.
3.        (Optional.) Configure a description for the port object group.
4.        Configure a port object.
[ object-id ] port { { eq | lt | gt } port | range port1 port2 }
Display and maintenance commands for object groups
Display information about object groups.
display object-group [ { { ip | ipv6 } address | port } [ default ] [ name object-group-name ] | name object-group-name ]
