00-Preface | 81.30 KB |
Preface
This configuration guide describes OAA fundamentals and configuration. It describes how to configure the H3C open application platform (OAP) module connected to your device to exchange information between your device and the OAP module.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
WARNING! |
CAUTION: |
IMPORTANT: |
NOTE: |
TIP: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
