01-Text | 2.39 MB |
Using ping, tracert, and system debugging
Using a ping command to test network connectivity
Using a tracert command to identify failed or all nodes in a path
Debugging information control switches
Configuring NTP association modes
Configuring NTP in client/server mode
Configuring NTP in symmetric active/passive mode
Configuring NTP in broadcast mode
Configuring NTP in multicast mode
Configuring access control rights
Configuring NTP authentication
Configuring NTP authentication in client/server mode
Configuring NTP authentication in symmetric active/passive mode
Configuring NTP authentication in broadcast mode
Configuring NTP authentication in multicast mode
Configuring NTP optional parameters
Specifying the source interface for NTP messages
Disabling an interface from processing NTP messages
Configuring the maximum number of dynamic associations
Setting a DSCP value for NTP packets
Configuring the local clock as a reference source
Displaying and maintaining NTP
NTP client/server mode configuration example
NTP symmetric active/passive mode configuration example
NTP broadcast mode configuration example
NTP multicast mode configuration example
Configuration example for NTP client/server mode with authentication
Configuration example for NTP broadcast mode with authentication
Configuration example for MPLS VPN time synchronization in client/server mode
Configuration example for MPLS VPN time synchronization in symmetric active/passive mode
Specifying an NTP server for the device
Configuring SNTP authentication
Displaying and maintaining SNTP
Configuring the information center
Default output rules for diagnostic logs
Default output rules for hidden logs
Default output rules for trace logs
Information center configuration task list
Outputting logs to the console
Outputting logs to the monitor terminal
Outputting logs to the log buffer
Saving diagnostic logs to the diagnostic log file
Configuring the maximum size of the trace log file
Enabling synchronous information output
Enabling duplicate log suppression
Disabling an interface from generating link up or link down logs
Setting the minimum storage period for logs
Displaying and maintaining information center
Information center configuration examples
Configuration example for outputting logs to the console
Configuration example for outputting logs to a UNIX log host
Configuration example for outputting logs to a Linux log host
MIB and view-based MIB access control
Configuring SNMP basic parameters
Configuring SNMPv1 or SNMPv2c basic parameters
Configuring SNMPv3 basic parameters
Configuring SNMP notifications
Configuring the SNMP agent to send notifications to a host
SNMPv1/SNMPv2c configuration example
SNMPv3 in VACM mode configuration example
SNMPv3 in RBAC mode configuration example
Displaying and maintaining a sampler
Port mirroring classification and implementation
Configuring local port mirroring
Local port mirroring configuration task list
Creating a local mirroring group
Configuring source ports for the local mirroring group
Configuring source CPUs for the local mirroring group
Configuring the monitor port for the local mirroring group
Configure local port mirroring with multiple monitor ports
Configuring Layer 2 remote port mirroring
Layer 2 remote port mirroring configuration task list
Configuring a remote destination group on the destination device
Configuring a remote source group on the source device
Displaying and maintaining port mirroring
Port mirroring configuration examples
Local port mirroring configuration example (in source port mode)
Local port mirroring configuration example (in source CPU mode)
Local port mirroring with multiple monitor ports configuration example
Layer 2 remote port mirroring configuration example
Flow mirroring configuration task list
Configuring a traffic behavior
Applying a QoS policy to an interface
Applying a QoS policy to a VLAN
Applying a QoS policy globally
Flow mirroring configuration example
Configuring the sFlow agent and sFlow collector information
Displaying and maintaining sFlow
Troubleshooting sFlow configuration
The remote sFlow collector cannot receive sFlow packets
Feature and software version compatibility
Configuring a user-defined EAA environment variable
Configuring a monitor policy from the CLI
Configuring a monitor policy by using Tcl
Displaying and maintaining EAA settings
CLI event monitor policy configuration example
Track event monitor policy configuration example
CLI-defined policy with EAA environment variables configuration example
Tcl-defined policy configuration example
Configuring NQA operations on the NQA client
NQA operation configuration task list
Configuring the ICMP echo operation
Configuring the ICMP jitter operation
Configuring the DHCP operation
Configuring the HTTP operation
Configuring the UDP jitter operation
Configuring the SNMP operation
Configuring the UDP echo operation
Configuring the UDP tracert operation
Configuring the voice operation
Configuring the DLSw operation
Configuring the path jitter operation
Configuring optional parameters for the NQA operation
Configuring the collaboration feature
Configuring threshold monitoring
Configuring the NQA statistics collection feature
Configuring the saving of NQA history records
Scheduling the NQA operation on the NQA client
Configuring NQA templates on the NQA client
NQA template configuration task list
Configuring the TCP half open template
Configuring the HTTPS template
Configuring optional parameters for the NQA template
Displaying and maintaining NQA
ICMP echo operation configuration example
ICMP jitter operation configuration example
DHCP operation configuration example
DNS operation configuration example
FTP operation configuration example
HTTP operation configuration example
UDP jitter operation configuration example
SNMP operation configuration example
TCP operation configuration example
UDP echo operation configuration example
UDP tracert operation configuration example
Voice operation configuration example
DLSw operation configuration example
Path jitter operation configuration example
NQA collaboration configuration example (on routers)
ICMP template configuration example
DNS template configuration example
TCP template configuration example
TCP half open template configuration example
UDP template configuration example
HTTP template configuration example
HTTPS template configuration example
FTP template configuration example
SSL template configuration example
NETCONF configuration task list
Establishing a NETCONF session
Setting the NETCONF session idle timeout time
Subscribing to event notifications
Example for subscribing to event notifications
Locking/unlocking the configuration
Example for locking the configuration
Performing the get/get-bulk operation
Performing the get-config/get-bulk-config operation
Performing the edit-config operation
All-module configuration data retrieval example
Syslog configuration data retrieval example
Example for retrieving a data entry for the interface table
Example for changing the value of a parameter
Saving, rolling back, and loading the configuration
Rolling back the configuration based on a configuration file
Rolling back the configuration based on a rollback point
Example for saving the configuration
Example for filtering data with regular expression match
Example for filtering data by conditional match
Performing CLI operations through NETCONF
Retrieving NETCONF session information
Terminating another NETCONF session
Appendix A Supported NETCONF operations
This chapter covers ping, tracert, and information about debugging the system.
Ping
Use the ping utility to determine if a specific address is reachable.
Ping sends ICMP echo requests (ECHO-REQUEST) to the destination device. Upon receiving the requests, the destination device responds with ICMP echo replies (ECHO-REPLY) to the source device. The source device outputs statistics about the ping operation, including the number of packets sent, number of echo replies received, and the round-trip time. You can measure the network performance by analyzing these statistics.
Execute ping commands in any view.
Task |
Command |
Determine if a specified address in an IP network is reachable. |
When you configure the ping command for a low-speed network, set a larger value for the timeout timer (indicated by the -t keyword in the command). ping [ ip ] [ -a source-ip | -c count | -f | -h ttl | -i interface-type interface-number | -m interval | -n | -p pad | -q | -r | -s packet-size | -t timeout | -tos tos | -v | -vpn-instance vpn-instance-name ] * host |
Ping example
Network requirements
As shown in Figure 1, determine if Device A and Device C can reach each other. If they can reach each other, get detailed information about routes from Device A to Device C.
Configuration procedure
# Use the ping command on Device A to test connectivity to Device C.
Ping 1.1.2.2 (1.1.2.2): 56 data bytes, press CTRL_C to break
56 bytes from 1.1.2.2: icmp_seq=0 ttl=254 time=2.137 ms
56 bytes from 1.1.2.2: icmp_seq=1 ttl=254 time=2.051 ms
56 bytes from 1.1.2.2: icmp_seq=2 ttl=254 time=1.996 ms
56 bytes from 1.1.2.2: icmp_seq=3 ttl=254 time=1.963 ms
56 bytes from 1.1.2.2: icmp_seq=4 ttl=254 time=1.991 ms
--- Ping statistics for 1.1.2.2 ---
round-trip min/avg/max/std-dev = 1.963/2.028/2.137/0.062 ms
The output shows that:
· Device A sends five ICMP packets to Device C and Device A receives five ICMP packets.
· No ICMP packet is lost.
· The route is reachable.
# Get detailed information about routes from Device A to Device C.
<DeviceA> ping -r 1.1.2.2
56 bytes from 1.1.2.2: icmp_seq=0 ttl=254 time=4.685 ms
RR: 1.1.2.1
1.1.2.2
1.1.1.2
1.1.1.1
56 bytes from 1.1.2.2: icmp_seq=1 ttl=254 time=4.834 ms (same route)
56 bytes from 1.1.2.2: icmp_seq=2 ttl=254 time=4.770 ms (same route)
56 bytes from 1.1.2.2: icmp_seq=3 ttl=254 time=4.812 ms (same route)
56 bytes from 1.1.2.2: icmp_seq=4 ttl=254 time=4.704 ms (same route)
round-trip min/avg/max/std-dev = 4.685/4.761/4.834/0.058 ms
The test procedure of ping –r is as shown in Figure 1:
1. The source device (Device A) sends an ICMP echo request to the destination device (Device C) with the RR option blank.
2. The intermediate device (Device B) adds the IP address of its outbound interface (1.1.2.1) to the RR option of the ICMP echo request, and forwards the packet.
3. Upon receiving the request, the destination device copies the RR option in the request and adds the IP address of its outbound interface (1.1.2.2) to the RR option. Then the destination device sends an ICMP echo reply.
4. The intermediate device adds the IP address of its outbound interface (1.1.1.2) to the RR option in the ICMP echo reply, and then forwards the reply.
5. Upon receiving the reply, the source device adds the IP address of its inbound interface (1.1.1.1) to the RR option. The detailed information of routes from Device A to Device C is formatted as: 1.1.1.1 <-> {1.1.1.2; 1.1.2.1} <-> 1.1.2.2.
Tracert
Tracert (also called Traceroute) enables retrieval of the IP addresses of Layer 3 devices in the path to a specific destination. In the event of network failure, use tracert to test network connectivity and identify failed nodes.
Figure 2 Tracert operation
Tracert uses received ICMP error messages to get the IP addresses of devices. Tracert works as shown in Figure 2:
1. The source device sends a UDP packet with a TTL value of 1 to the destination device. The destination UDP port is not used by any application on the destination device.
2. The first hop (Device B, the first Layer 3 device that receives the packet) responds by sending a TTL-expired ICMP error message to the source, with its IP address (1.1.1.2) encapsulated. This way, the source device can get the address of the first Layer 3 device (1.1.1.2).
3. The source device sends a packet with a TTL value of 2 to the destination device.
4. The second hop (Device C) responds with a TTL-expired ICMP error message, which gives the source device the address of the second Layer 3 device (1.1.2.2).
5. This process continues until a packet sent by the source device reaches the ultimate destination device. Because no application uses the destination port specified in the packet, the destination device responds with a port-unreachable ICMP message to the source device, with its IP address encapsulated. This way, the source device gets the IP address of the destination device (1.1.3.2).
6. The source device thinks that the packet has reached the destination device after receiving the port-unreachable ICMP message, and the path to the destination device is 1.1.1.2 to 1.1.2.2 to 1.1.3.2.
Before you use a tracert command, perform the tasks in this section.
· Enable sending of ICMP timeout packets on the intermediate devices (devices between the source and destination devices). If the intermediate devices are H3C devices, execute the ip ttl-expires enable command on the devices. For more information about this command, see Layer 3—IP Services Command Reference.
· Enable sending of ICMP destination unreachable packets on the destination device. If the destination device is an H3C device, execute the ip unreachables enable command. For more information about this command, see Layer 3—IP Services Command Reference.
Execute tracert commands in any view.
Task |
Display the routes from source to destination. |
tracert [ -a source-ip | -f first-ttl | -m max-ttl | -p port | -q packet-number | -t tos | -vpn-instance vpn-instance-name | -w timeout ] * host |
Tracert example
As shown in Figure 3, Device A failed to Telnet to Device C.
Test the network connectivity between Device A and Device C. If they cannot reach each other, locate the failed nodes in the network.
1. Configure the IP addresses for devices as shown in Figure 3.
2. Configure a static route on Device A.
[DeviceA] ip route-static 0.0.0.0 0.0.0.0 1.1.1.2
[DeviceA] quit
3. Use the ping command to test connectivity between Device A and Device C.
<DeviceA> ping 1.1.2.2
Ping 1.1.2.2(1.1.2.2): 56 -data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
5 packet(s) transmitted,0 packet(s) received,100.0% packet loss
The output shows that Device A and Device C cannot reach each other.
4. Use the tracert command to identify failed nodes:
# Enable sending of ICMP timeout packets on Device B.
[DeviceB] ip ttl-expires enable
# Enable sending of ICMP destination unreachable packets on Device C.
<DeviceC> system-view
[DeviceC] ip unreachables enable
# Execute the tracert command on Device A.
<DeviceA> tracert 1.1.2.2
traceroute to 1.1.2.2(1.1.2.2) 30 hops at most,40 bytes each packet, press CTRL_C to break
1 1.1.1.2 1 ms 2 ms 1 ms
2 * * *
3 * * *
4 * * *
5
<DeviceA>
? Device A can reach Device B but cannot reach Device C.
? An error has occurred on the connection between Device B and Device C.
5. Use the debugging ip icmp command on Device A and Device C to verify that they can send and receive the specific ICMP packets.
Or use the display ip routing-table command to verify that there is a route from Device A to Device C.
System debugging
The device supports debugging for the majority of protocols and features and provides debugging information to help users diagnose errors.
The following switches control the display of debugging information:
· Module debugging switch—Controls whether to generate the module-specific debugging information.
· Screen output switch—Controls whether to display the debugging information on a certain screen. Use terminal monitor and terminal logging level commands to turn on the screen output switch. For more information about these two commands, see Network Management and Monitoring Command Reference.
As shown in Figure 4, assume that the device can provide debugging for the three modules 1, 2, and 3. The debugging information can be output on a terminal only when both the module debugging switch and the screen output switch are turned on.
Debugging information is typically displayed on a console. You can also send debugging information to other destinations. For more information, see "Configuring the information center"
Figure 4 Relationship between the module and screen output switch
Debugging a feature module
Output of debugging commands is memory intensive. To guarantee system performance, enable debugging only for modules that are in an exceptional condition. When debugging is complete, use the undo debugging all command to disable all the debugging functions.
To debug a feature module:
Step |
Command |
Remarks |
1. Enable debugging for a specified module in user view. |
debugging { all [ timeout time ] | module-name [ option ] } |
By default, all debugging functions are disabled. |
2. (Optional.) Display the enabled debugging in any view. |
display debugging [ module-name ] |
N/A |
Configuring NTP
Synchronize your device with a trusted time source by using the Network Time Protocol (NTP) or changing the system time before you run it on a live network. Various tasks, including network management, charging, auditing, and distributed computing depend on an accurate system time setting, because the timestamps of system messages and logs use the system time.
Overview
NTP is typically used in large networks to dynamically synchronize time among network devices. It guarantees higher clock accuracy than manual system clock setting. In a small network that does not require high clock accuracy, you can keep time synchronized among devices by changing their system clocks one by one.
NTP runs over UDP and uses UDP port 123.
How NTP works
Figure 5 shows how NTP synchronizes the system time between two devices, in this example, Device A and Device B. Assume that:
· Prior to the time synchronization, the time of Device A is set to 10:00:00 am and that of Device B is set to 11:00:00 am.
· Device B is used as the NTP server. Device A is to be synchronized to Device B.
· It takes 1 second for an NTP message to travel from Device A to Device B, and from Device B to Device A.
· It takes 1 second for Device B to process the NTP message.
The synchronization process is as follows:
1. Device A sends Device B an NTP message, which is timestamped when it leaves Device A. The time stamp is 10:00:00 am (T1).
2. When this NTP message arrives at Device B, Device B adds a timestamp showing the time when the message arrived at Device B. The timestamp is 11:00:01 am (T2).
3. When the NTP message leaves Device B, Device B adds a timestamp showing the time when the message left Device B. The timestamp is 11:00:02 am (T3).
4. When Device A receives the NTP message, the local time of Device A is 10:00:03 am (T4).
Up to now, Device A can calculate the following parameters based on the timestamps:
· The roundtrip delay of the NTP message: Delay = (T4–T1) – (T3-T2) = 2 seconds.
· Time difference between Device A and Device B: Offset = ((T2-T1) + (T3-T4)) /2 = 1 hour.
Based on these parameters, Device A can be synchronized to Device B.
This is only a rough description of the work mechanism of NTP. For more information, see the related protocols and standards.
NTP architecture
NTP uses stratums 1 to 16 to define clock accuracy, as shown in Figure 6. A lower stratum value represents higher accuracy. Clocks at stratums 1 through 15 are in synchronized state, and clocks at stratum 16 are not synchronized.
Typically, a stratum 1 NTP server gets its time from an authoritative time source, such as an atomic clock, and provides time for other devices as the primary NTP server. The accuracy of each server is the stratum, with the topmost level (primary servers) assigned as one and each level downwards in the hierarchy assigned as one greater than the preceding level. NTP uses a stratum to describe how many NTP "hops" away a device is from the primary time server. A stratum 2 time server receives its time from a stratum 1 time server, and so on.
To ensure time accuracy and availability, you can specify multiple NTP servers for a device. The device selects an optimal NTP server as the clock source based on parameters such as stratum. The clock that the device selects is called the reference source. For more information about clock selection, see the related protocols and standards.
If the devices in a network cannot synchronize to an authoritative time source, you can select a device that has a relatively accurate clock from the network, and use the local clock of the device as the reference clock to synchronize other devices in the network.
Association modes
NTP supports the following association modes:
· Client/server mode
· Symmetric active/passive mode
· Broadcast mode
· Multicast mode
Table 1 NTP association modes
Mode |
Working process |
Principle |
Application scenario |
Client/server |
On the client, specify the IP address of the NTP server. A client sends a clock synchronization message to the NTP servers. Upon receiving the message, the servers automatically operate in server mode and send a reply. If the client can be synchronized to multiple time servers, it selects an optimal clock and synchronizes its local clock to the optimal reference source after receiving the replies from the servers. |
A client can be synchronized to a server, but a server cannot be synchronized to a client. |
As Figure 6 shows, this mode is intended for configurations where devices of a higher stratum are synchronized to devices with a lower stratum. |
Symmetric active/passive |
On the symmetric active peer, specify the IP address of the symmetric passive peer. A symmetric active peer periodically sends clock synchronization messages to a symmetric passive peer. The symmetric passive peer automatically operates in symmetric passive mode and sends a reply. If the symmetric active peer can be synchronized to multiple time servers, it selects an optimal clock and synchronizes its local clock to the optimal reference source after receiving the replies from the servers. |
A symmetric active peer and a symmetric passive peer can be synchronized to each other. If both of them are synchronized, the peer with a higher stratum is synchronized to the peer with a lower stratum. |
As Figure 6 shows, this mode is most often used between two or more servers with the same stratum to operate as a backup for one another. If a server fails to communicate with all the servers of a higher stratum, the server can be synchronized to the servers of the same stratum. |
Broadcast |
A server periodically sends clock synchronization messages to the broadcast address 255.255.255.255. Clients listen to the broadcast messages from the servers to synchronize to the server according to the broadcast messages. When a client receives the first broadcast message, the client and the server start to exchange messages to calculate the network delay between them. Then, only the broadcast server sends clock synchronization messages. |
A broadcast client can be synchronized to a broadcast server, but a broadcast server cannot be synchronized to a broadcast client. |
A broadcast server sends clock synchronization messages to synchronize clients in the same subnet. As Figure 6 shows, broadcast mode is intended for configurations involving one or a few servers and a potentially large client population. The broadcast mode has a lower time accuracy than the client/server and symmetric active/passive modes because only the broadcast servers send clock synchronization messages. |
Multicast |
A multicast server periodically sends clock synchronization messages to the user-configured multicast address. Clients listen to the multicast messages from servers and synchronize to the server according to the received messages. |
A multicast client can be synchronized to a multicast server, but a multicast server cannot be synchronized to a multicast client. |
A multicast server can provide time synchronization for clients in the same subnet or in different subnets. The multicast mode has a lower time accuracy than the client/server and symmetric active/passive modes. |
In this document, an "NTP server" or a "server" refers to a device that operates as an NTP server in client/server mode. Time servers refer to all the devices that can provide time synchronization, including NTP servers, NTP symmetric peers, broadcast servers, and multicast servers.
NTP security
To improve time synchronization security, NTP provides the access control and authentication functions.
NTP access control
You can control NTP access by using an ACL. The access rights are in the following order, from least restrictive to most restrictive:
· Peer—Allows time requests and NTP control queries (such as alarms, authentication status, and time server information) and allows the local device to synchronize itself to a peer device.
· Server—Allows time requests and NTP control queries, but does not allow the local device to synchronize itself to a peer device.
· Synchronization—Allows only time requests from a system whose address passes the access list criteria.
· Query—Allows only NTP control queries from a peer device to the local device.
The device processes an NTP request, as follows:
· If no NTP access control is configured, peer is granted to the local device and peer devices.
· If the IP address of the peer device matches a permit statement in an ACL for more than one access right, the least restrictive access right is granted to the peer device. If a deny statement or no ACL is matched, no access right is granted.
· If no ACL is created for a specific access right, the associated access right is not granted.
· If no ACL is created for any access right, peer is granted.
This feature provides minimal security for a system running NTP. A more secure method is NTP authentication.
NTP authentication
Use this feature to authenticate the NTP messages for security purposes. If an NTP message passes authentication, the device can receive it and get time synchronization information. If not, the device discards the message. This function makes sure the device does not synchronize to an unauthorized time server.
Figure 7 NTP authentication
As shown in Figure 7, NTP authentication works as follows:
1. The sender uses the MD5 algorithm to calculate the NTP message according to the key identified by a key ID, and sends the calculated digest together with the NTP message and key ID to the receiver.
2. Upon receiving the message, the receiver finds the key according to the key ID in the message, uses the MD5 algorithm to calculate the digest, and compares the digest with the digest contained in the NTP message. If they are the same, the receiver accepts the message. Otherwise, it discards the message.
NTP for MPLS L3VPNs
In an MPLS L3VPN network, the device supports multiple VPN instances when:
· It functions as an NTP client to synchronize time with the NTP server.
· It functions as a symmetric active peer to synchronize time with the symmetric passive peer.
The device functions only as a CE.
Only the client/server and symmetric active/passive modes support VPN instances.
As shown in Figure 8, users in VPN 1 and VPN 2 are connected to the MPLS backbone network through provider edge (PE) devices, and services of the two VPNs are isolated. Time synchronization between PEs and devices of the two VPNs can be realized if you perform the following tasks:
· Configure the PEs to operate in NTP client or symmetric active mode.
· Specify the VPN to which the NTP server or NTP symmetric passive peer belongs.
Protocols and standards
· RFC 1305, Network Time Protocol (Version 3) Specification, Implementation and Analysis
· RFC 5905, Network Time Protocol Version 4: Protocol and Algorithms Specification
When you configure NTP, follow these guidelines:
· You cannot configure both NTP and SNTP on the same device.
· Do not configure NTP on an aggregate member port.
· The NTP service and SNTP service are mutually exclusive. You can only enable either NTP service or SNTP service at a time.
· To ensure time synchronization accuracy, do not specify different reference sources for a symmetric active peer and a symmetric passive peer if they operate as the NTP client for the client/server, broadcast, and multicast modes.
· You can use the clock protocol command to specify the system time source. For more information about the clock protocol command, see Fundamentals Command Reference.
· The term "interface" in this chapter collectively refers to Layer 3 interfaces, including VLAN interfaces and Layer 3 Ethernet interfaces. You can set an Ethernet port as a Layer 3 interface by using the port link-mode route command (see Layer 2—LAN Switching Configuration Guide)
Configuration task list
Tasks at a glance |
(Required.) Enabling the NTP service |
(Required.) Perform at least one of the following tasks: |
(Optional.) Configuring access control rights |
(Optional.) Configuring NTP authentication |
(Optional.) Configuring NTP optional parameters |
Step |
Command |
Remarks |
3. Enter system view. |
system-view |
N/A |
4. Enable the NTP service. |
ntp-service enable |
By default, the NTP service is not enabled. |
This section describes how to configure NTP association modes.
When the device operates in client/server mode, specify the IP address for the server on the client.
Follow these guidelines when you configure an NTP client:
· A server must be synchronized by other devices or use its local clock as a reference source before synchronizing an NTP client. Otherwise, the client will not be synchronized to the NTP server.
· If the stratum level of a server is higher than or equal to a client, the client will not synchronize to that server.
· You can configure multiple servers by repeating the ntp-service unicast-server command.
To configure an NTP client:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
ntp-service unicast-server { server-name | ip-address } [ vpn-instance vpn-instance-name ] [ authentication-keyid keyid | priority | source interface-type interface-number | version number ] * |
By default, no NTP server is specified for the device. |
When the device operates in symmetric active/passive mode, specify on a symmetric-active peer the IP address for a symmetric-passive peer.
Follow these guidelines when you configure a symmetric-active peer:
· Execute the ntp-service enable command on a symmetric passive peer to enable NTP. Otherwise, the symmetric-passive peer will not process NTP messages from a symmetric-active peer.
· Either the symmetric-active peer, or the symmetric-passive peer, or both of them must be in synchronized state. Otherwise, their time cannot be synchronized.
· You can configure multiple symmetric-passive peers by repeating the ntp-service unicast-peer command.
To configure a symmetric-active peer:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify a symmetric-passive peer for the device. |
ntp-service unicast-peer { peer-name | ip-address } [ vpn-instance vpn-instance-name ] [ authentication-keyid keyid | priority | source interface-type interface-number | version number ] * |
By default, no symmetric-passive peer is specified. |
A broadcast server must be synchronized by other devices or use its local clock as a reference source before synchronizing a broadcast client. Otherwise, the broadcast client will not be synchronized to the broadcast server.
Configure NTP in broadcast mode on both broadcast server and client.
Configuring a broadcast client
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
Enter the interface for receiving NTP broadcast messages. |
3. Configure the device to operate in broadcast client mode. |
ntp-service broadcast-client |
By default, the device does not operate in broadcast client mode. After you execute the command, the device receives NTP broadcast messages from the specified interface. |
Configuring the broadcast server
Step |
Command |
Remarks |
system-view |
N/A |
Enter the interface for sending NTP broadcast messages. |
3. Configure the device to operate in NTP broadcast server mode. |
ntp-service broadcast-server [ authentication-keyid keyid | version number ] * |
By default, the device does not operate in broadcast server mode. After you execute the command, the device receives NTP broadcast messages from the specified interface. |
A multicast server must be synchronized by other devices or use its local clock as a reference source before synchronizing a multicast client. Otherwise, the multicast client will not be synchronized to the multicast server.
Configure NTP in multicast mode on both a multicast server and client.
Configuring a multicast client
Step |
Command |
Remarks |
system-view |
N/A |
Enter the interface for receiving NTP multicast messages. |
3. Configure the device to operate in multicast client mode. |
ntp-service multicast-client [ ip-address ] |
By default, the device does not operate in multicast server mode. After you execute the command, the device receives NTP multicast messages from the specified interface. |
Configuring the multicast server
Step |
Command |
Remarks |
system-view |
N/A |
Enter the interface for sending NTP multicast message. |
3. Configure the device to operate in multicast server mode. |
ntp-service multicast-server [ ip-address ] [ authentication-keyid keyid | ttl ttl-number | version number ] * |
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the NTP service access control right for a peer device to access the local device. |
ntp-service access { peer | query | server | synchronization } acl-number |
By default, the NTP service access control right for a peer device to access the local device is peer. |
Before you configure the NTP service access control right to the local device, create and configure an ACL associated with the access control right. For more information about ACL, see ACL and QoS Configuration Guide.
This section provides instructions for configuring NTP authentication.
When you configure NTP authentication in client/server mode, enable NTP authentication, configure an authentication key, set the key as a trusted key on both client and server, and associate the key with the NTP server on the client. The key IDs and key values configured on the server and client must be the same. Otherwise, NTP authentication fails.
To configure NTP authentication for a client:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable NTP authentication. |
ntp-service authentication enable |
By default, NTP authentication is disabled. |
3. Configure an NTP authentication key. |
ntp-service authentication-keyid keyid authentication-mode md5 { cipher | simple } value |
By default, no NTP authentication key is configured. |
4. Configure the key as a trusted key. |
ntp-service reliable authentication-keyid keyid |
By default, no authentication key is configured as a trusted key. |
5. Associate the specified key with an NTP server. |
ntp-service unicast-server { server-name | ip-address } [ vpn-instance vpn-instance-name ] authentication-keyid keyid |
N/A |
To configure NTP authentication for a server:
Step |
Command |
Remarks |
system-view |
N/A |
NTP authentication results differ when different configurations are performed on client and server. For more information, see Table 2. (N/A in the table means that whether the configuration is performed does not make any difference.)
Table 2 NTP authentication results
Client |
Server |
Authentication result |
Enable NTP authentication |
Configure a key and configure it as a trusted key |
Associate the key with an NTP server |
Yes |
Yes |
Yes |
Yes |
Yes |
Succeeded. NTP messages can be sent and received correctly. |
Yes |
Yes |
Yes |
Yes |
No |
Failed. NTP messages cannot be sent and received correctly. |
Yes |
Yes |
Yes |
No |
N/A |
Yes |
No |
Yes |
N/A |
N/A |
Yes |
N/A |
No |
N/A |
N/A |
No authentication. NTP messages can be sent and received correctly. |
No |
N/A |
N/A |
N/A |
N/A |
When you configure NTP authentication in symmetric peers mode, enable NTP authentication, configure an authentication key, set the key as a trusted key on both active peer and passive peer, and associate the key with the passive peer on the active peer. The key IDs and key values configured on the active peer and passive peer must be the same. Otherwise, NTP authentication fails.
To configure NTP authentication for an active peer:
Step |
Command |
Remarks |
system-view |
N/A |
5. Associate the specified key with a passive peer. |
ntp-service unicast-peer { ip-address | peer-name } [ vpn-instance vpn-instance-name ] authentication-keyid keyid |
N/A |
To configure NTP authentication for a passive peer:
Step |
Command |
Remarks |
system-view |
N/A |
NTP authentication results differ when different configurations are performed on active peer and passive peer. For more information, see Table 3. (N/A in the table means that whether the configuration is performed does not make any difference.)
Table 3 NTP authentication results
Active peer |
Passive peer |
Associate the key with a passive peer |
Stratum level of the active and passive peers is not considered. |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
No |
N/A |
Yes |
N/A |
No |
Yes |
N/A |
Yes |
N/A |
No |
No |
N/A |
No |
N/A |
N/A |
Yes |
N/A |
No |
N/A |
N/A |
No |
N/A |
The active peer has a higher stratum than the passive peer. |
Yes |
No |
Yes |
N/A |
N/A |
The passive peer has a higher stratum than the active peer. |
Yes |
No |
Yes |
Yes |
N/A |
Yes |
No |
Yes |
No |
N/A |
When you configure NTP authentication in broadcast mode, enable NTP authentication, configure an authentication key, set the key as a trusted key on both the broadcast client and server, and configure an NTP authentication key on the broadcast server. The key IDs and key values configured on the broadcast server and client must be the same. Otherwise, NTP authentication fails.
To configure NTP authentication for a broadcast client:
Step |
Command |
Remarks |
system-view |
N/A |
To configure NTP authentication for a broadcast server:
Step |
Command |
Remarks |
system-view |
N/A |
5. Enter interface view. |
N/A |
6. Associate the specified key with the broadcast server. |
ntp-service broadcast-server authentication-keyid keyid |
By default, the broadcast server is not associated with any key. |
NTP authentication results differ when different configurations are performed on broadcast client and server. For more information, see Table 4. (N/A in the table means that whether the configuration is performed does not make any difference.)
Table 4 NTP authentication results
Broadcast server |
Broadcast client |
Associate the key with a broadcast server |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
No |
N/A |
Yes |
No |
Yes |
Yes |
N/A |
Yes |
No |
Yes |
No |
N/A |
Yes |
N/A |
No |
Yes |
N/A |
Yes |
N/A |
No |
No |
N/A |
No |
N/A |
N/A |
Yes |
N/A |
No |
N/A |
N/A |
No |
N/A |
When you configure NTP authentication in multicast mode, enable NTP authentication, configure an authentication key, set the key as a trusted key on both the multicast client and server, and configure an NTP authentication key on the multicast server. The key IDs and key values configured on the multicast server and client must be the same. Otherwise, NTP authentication fails.
To configure NTP authentication for a multicast client:
Step |
Command |
Remarks |
system-view |
N/A |
To configure NTP authentication for a multicast server:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
6. Associate the specified key with the multicast server. |
ntp-service multicast-server [ ip-address ] authentication-keyid keyid |
By default, no multicast server is associated with the specified key. |
NTP authentication results differ when different configurations are performed on broadcast client and server. For more information, see Table 5. (N/A in the table means that whether the configuration is performed does not make any difference.)
Table 5 NTP authentication results
Multicast server |
Multicast client |
Associate the key with a multicast server |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
No |
N/A |
Yes |
No |
Yes |
Yes |
N/A |
Yes |
No |
Yes |
No |
N/A |
Yes |
N/A |
No |
Yes |
N/A |
Yes |
N/A |
No |
No |
N/A |
No |
N/A |
N/A |
Yes |
N/A |
No |
N/A |
N/A |
No |
N/A |
The configuration tasks in this section are optional tasks. Configure them to improve NTP security, performance, or reliability.
To prevent interface status changes from causing NTP communication failures, configure the device to use the IP address of an interface that is always up, for example, a loopback interface, as the source IP address for the NTP messages to be sent. Set the loopback interface as the source interface so that any interface status change on the device will not cause NTP messages to be unable to be received.
When the device responds to an NTP request, the source IP address of the NTP response is always the IP address of the interface that has received the NTP request.
Follow these guidelines when you specify the source interface for NTP messages:
· If you have specified the source interface for NTP messages in the ntp-service unicast-server or ntp-service unicast-peer command, the interface specified in the ntp-service unicast-server or ntp-service unicast-peer command serves as the source interface for NTP messages.
· If you have configured the ntp-service broadcast-server or ntp-service multicast-server command, the source interface for the broadcast or multicast NTP messages is the interface configured with the respective command.
To specify the source interface for NTP messages:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify the source interface for NTP messages. |
ntp-service source interface-type interface-number |
By default, no source interface is specified for NTP messages. |
When NTP is enabled, all interfaces by default can process NTP messages. For security purposes, you can disable some of the interfaces from processing NTP messages.
To disable an interface from processing NTP messages:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Disable the interface from processing NTP messages. |
undo ntp-service inbound enable |
By default, an interface processes NTP messages. |
NTP has the following types of associations:
· Static association—A manually created association.
· Dynamic association—Temporary association created by the system during NTP operation. A dynamic association is removed if no messages are exchanged over a specific period of time.
The following describes how an association is established in different association modes:
· Client/server mode—After you specify an NTP server, the system creates a static association on the client. The server simply responds passively upon the receipt of a message, rather than creating an association (static or dynamic).
· Symmetric active/passive mode—After you specify a symmetric-passive peer on a symmetric active peer, static associations are created on the symmetric-active peer, and dynamic associations are created on the symmetric-passive peer.
· Broadcast or multicast mode—Static associations are created on the server, and dynamic associations are created on the client.
A single device can have a maximum of 128 concurrent associations, including static associations and dynamic associations.
Perform this task to restrict the number of dynamic associations to prevent dynamic associations from occupying too many system resources.
To configure the maximum number of dynamic associations:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the maximum number of dynamic sessions allowed to be established. |
ntp-service max-dynamic-sessions number |
By default, the command can establish up to 100 dynamic sessions. |
The DSCP value determines the sending precedence of a packet.
To configure a DSCP value for NTP packets:
Step |
Command |
Remarks |
system-view |
N/A |
2. Set a DSCP value for NTP packets. |
ntp-service dscp dscp-value |
The default DSCP value is 48 for NTP packets. |
Follow these guidelines when you configure the local clock as a reference source:
· Make sure the local clock can provide the time accuracy required for the network. After you configure the local clock as a reference source, the local clock is synchronized, and can operate as a time server to synchronize other devices in the network. If the local clock is incorrect, timing errors occur.
· Before you configure this feature, adjust the local system time to make sure it is accurate.
To configure the local clock as a reference source:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the local clock as a reference source. |
ntp-service refclock-master [ ip-address ] [ stratum ] |
By default, the device does not use the local clock as a reference source. |
Task |
Command |
Display information about NTP service status. |
display ntp-service status |
Display information about IPv4 NTP associations. |
display ntp-service sessions [ verbose ] |
Display brief information about the NTP servers from the local device back to the primary reference source. |
display ntp-service trace |
NTP configuration examples
As shown in Figure 9, perform the following tasks:
· Configure the local clock of Device A as a reference source, with the stratum level 2.
· Configure Device B to operate in client mode and Device A to be used as the NTP server for Device B.
1. Set the IP address for each interface, as shown in Figure 9. (Details not shown.)
2. Configure Device A:
# Enable the NTP service.
[DeviceA] ntp-service enable
# Specify the local clock as the reference source, with the stratum level 2.
[DeviceA] ntp-service refclock-master 2
3. Configure Device B:
[DeviceB] ntp-service enable
# Specify Device A as the NTP server of Device B so that Device B is synchronized to Device A.
[DeviceB] ntp-service unicast-server 1.0.1.11
4. Verify the configuration:
# Verify that Device B has synchronized to Device A, and the clock stratum level is 3 on Device B and 2 on Device A.
[DeviceB] display ntp-service status
Clock status: synchronized
Clock stratum: 3
System peer: 1.0.1.11
Local mode: client
Reference clock ID: 1.0.1.11
Leap indicator: 00
Clock jitter: 0.000977 s
Stability: 0.000 pps
Clock precision: 2^-18
Root delay: 0.00383 ms
Root dispersion: 16.26572 ms
Reference time: d0c6033f.b9923965 Wed, Dec 29 2010 18:58:07.724
# Verify that an IPv4 NTP association has been established between Device B and Device A.
[DeviceB] display ntp-service sessions
source reference stra reach poll now offset delay disper
[12345]1.0.1.11 127.127.1.0 2 1 64 15 -4.0 0.0038 16.262
Total sessions : 1
As shown in Figure 10, Device C has a clock more accurate than Device A.
· Configure the local clock of Device A as a reference source, with the stratum level 3.
· Configure the local clock of Device C as a reference source, with the stratum level 2.
· Configure Device B to operate in client mode and specify Device A as the NTP server of Device B.
· Configure Device C to operate in symmetric-active mode and specify Device B as the passive peer of Device C.
1. Set the IP address for each interface, as shown in Figure 10. (Details not shown.)
# Specify the local clock as the reference source, with the stratum level 3.
[DeviceA] ntp-service refclock-master 3
# Specify Device A as the NTP server of Device B.
[DeviceB] ntp-service unicast-server 3.0.1.31
4. Configure Device C:
[DeviceC] ntp-service enable
[DeviceC] ntp-service refclock-master 2
# Configure Device B as a symmetric passive peer.
[DeviceC] ntp-service unicast-peer 3.0.1.32
5. Verify the configuration:
After the configuration, Device B has two time servers Device A and Device C. Device C has a lower stratum level than Device A, so Device B selects Device C as a reference clock to synchronize to Device C.
# Verify that Device B has synchronized to Device C.
Clock stratum: 3
System peer: 3.0.1.33
Local mode: sym_passive
Reference clock ID: 3.0.1.33
Leap indicator: 00
Clock jitter: 0.000916 s
Clock precision: 2^-17
Root delay: 0.00609 ms
Root dispersion: 1.95859 ms
Reference time: 83aec681.deb6d3e5 Sun, Jan 4 1970 5:56:17.869
# Verify that an IPv4 NTP association has been established between Device B and Device A, and Device B and Device C.
[25]3.0.1.31 127.127.1.0 3 28 64 - 0.0000 0.0000 4000.0
[1234]3.0.1.33 127.127.1.0 2 62 64 34 0.4251 6.0882 1392.1
Total sessions: 2
As shown in Figure 11, Switch C functions as the NTP server for multiple devices on a network segment and synchronizes the time among multiple devices.
· Configure Switch C's local clock as a reference source, with the stratum level 2.
· Configure Switch C to operate in broadcast server mode and send out broadcast messages from VLAN-interface 2.
· Configure Switch A and Switch B to operate in broadcast client mode, and listen to broadcast messages through VLAN-interface 2.
1. Set the IP address for each interface, as shown in Figure 11. (Details not shown.)
2. Configure Switch C:
[SwitchC] ntp-service enable
[SwitchC] ntp-service refclock-master 2
# Configure Switch C to operate in broadcast server mode and send broadcast messages through VLAN-interface 2.
[SwitchC-Vlan-interface2] ntp-service broadcast-server
3. Configure Switch A:
[SwitchA] ntp-service enable
# Configure Switch A to operate in broadcast client mode and receive broadcast messages on VLAN-interface 2.
[SwitchA-Vlan-interface2] ntp-service broadcast-client
4. Configure Switch B:
[SwitchB] ntp-service enable
# Configure Switch B to operate in broadcast client mode and receive broadcast messages on VLAN-interface 2.
[SwitchB-Vlan-interface2] ntp-service broadcast-client
# Verify that Switch A has synchronized to Switch C, and the clock stratum level is 3 on Switch A and 2 on Switch C.
[SwitchA-Vlan-interface2] display ntp-service status
Clock stratum: 3
System peer: 3.0.1.31
Local mode: bclient
Reference clock ID: 3.0.1.31
Leap indicator: 00
Clock jitter: 0.044281 s
Clock precision: 2^-10
Root delay: 0.00229 ms
Root dispersion: 4.12572 ms
Reference time: d0d289fe.ec43c720 Sat, Jan 8 2011 7:00:14.922
# Verify that an IPv4 NTP association has been established between Switch A and Switch C.
[SwitchA-Vlan-interface2] display ntp-service sessions
[1245]3.0.1.31 127.127.1.0 2 1 64 519 -0.0 0.0022 4.1257
Total sessions : 1
As shown in Figure 12, Switch C functions as the NTP server for multiple devices on different network segments and synchronizes the time among multiple devices.
· Configure Switch C to operate in multicast server mode and send out multicast messages from VLAN-interface 2.
· Configure Switch A and Switch D to operate in multicast client mode and receive multicast messages through VLAN-interface 3 and VLAN-interface 2, respectively.
1. Set the IP address for each interface as shown in Figure 12. (Details not shown.)
# Configure Switch C to operate in multicast server mode and send multicast messages through VLAN-interface 2.
[SwitchC-Vlan-interface2] ntp-service multicast-server
3. Configure Switch D:
<SwitchD> system-view
[SwitchD] ntp-service enable
# Configure Switch D to operate in multicast client mode and receive multicast messages on VLAN-interface 2.
[SwitchD] interface vlan-interface 2
[SwitchD-Vlan-interface2] ntp-service multicast-client
Switch D and Switch C are on the same subnet, so Switch D can do the following:
? Receive the multicast messages from Switch C without being enabled with the multicast functions.
? Synchronize to Switch C.
# Verify that Switch D has synchronized to Switch C, and the clock stratum level is 3 on Switch D and 2 on Switch C.
[SwitchD-Vlan-interface2] display ntp-service status
Clock stratum: 3
Local mode: bclient
Leap indicator: 00
# Verify that an IPv4 NTP association has been established between Switch D and Switch C.
[SwitchD-Vlan-interface2] display ntp-service sessions
Total sessions : 1
5. Configure Switch B:
Because Switch A and Switch C are on different subnets, you must enable the multicast functions on Switch B before Switch A can receive multicast messages from Switch C.
# Enable IP multicast routing and IGMP.
[SwitchB] multicast routing
[SwitchB-mrib] quit
[SwitchB-Vlan-interface2] pim dm
[SwitchB] vlan 3
[SwitchB-vlan3] port ten-gigabitethernet 1/0/1
[SwitchB-vlan3] quit
[SwitchB-Vlan-interface3] igmp enable
[SwitchB-Vlan-interface3] igmp static-group 224.0.1.1
[SwitchB] igmp-snooping
[SwitchB-igmp-snooping] quit
[SwitchB] interface ten-gigabitethernet 1/0/1
[SwitchB-Ten-GigabitEthernet1/0/1] igmp-snooping static-group 224.0.1.1 vlan 3
6. Configure Switch A:
# Configure Switch A to operate in multicast client mode and receive multicast messages on VLAN-interface 3.
[SwitchA-Vlan-interface3] ntp-service multicast-client
7. Verify the configuration:
[SwitchA-Vlan-interface3] display ntp-service status
Clock stratum: 3
Local mode: bclient
Leap indicator: 00
Clock jitter: 0.165741 s
Root delay: 0.00534 ms
Root dispersion: 4.51282 ms
Reference time: d0c61289.10b1193f Wed, Dec 29 2010 20:03:21.065
[SwitchA-Vlan-interface3] display ntp-service sessions
[1234]3.0.1.31 127.127.1.0 2 247 64 381 -0.0 0.0053 4.5128
Total sessions : 1
As shown in Figure 13, perform the following tasks:
· Configure Device B to operate in client mode and specify Device A as the NTP server of Device B, with Device B as the client.
· Configure NTP authentication on both Device A and Device B.
1. Set the IP address for each interface, as shown in Figure 13. (Details not shown.)
# Enable NTP authentication on Device B.
[DeviceB] ntp-service authentication enable
# Set an authentication key, and input the key in plain text.
[DeviceB] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
# Specify the key as a trusted key.
[DeviceB] ntp-service reliable authentication-keyid 42
# Specify Device A as the NTP server of Device B, and associate the server with key 42.
[DeviceB] ntp-service unicast-server 1.0.1.11 authentication-keyid 42
Before Device B can synchronize its clock to that of Device A, enable NTP authentication for Device A.
4. Configure NTP authentication on Device A:
# Enable NTP authentication.
[DeviceA] ntp-service authentication enable
[DeviceA] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
[DeviceA] ntp-service reliable authentication-keyid 42
Clock stratum: 3
Local mode: client
Leap indicator: 00
Clock jitter: 0.005096 s
Root delay: 0.00655 ms
Root dispersion: 1.15869 ms
Reference time: d0c62687.ab1bba7d Wed, Dec 29 2010 21:28:39.668
[1245]1.0.1.11 127.127.1.0 2 1 64 519 -0.0 0.0065 0.0
Total sessions : 1
As shown in Figure 14, Switch C functions as the NTP server for multiple devices on different network segments and synchronizes the time among multiple devices. Switch A and Switch B authenticate the reference source.
· Configure Switch C's local clock as a reference source, with the stratum level 3.
· Configure Switch A and Switch B to operate in broadcast client mode and receive broadcast messages through VLAN-interface 2.
· Enable NTP authentication on Switch A, Switch B, and Switch C.
1. Set the IP address for each interface, as shown in Figure 14. (Details not shown.)
2. Configure Switch A:
# Enable NTP authentication on Switch A. Configure an NTP authentication key, with the key ID of 88 and key value of 123456. Input the key in plain text, and specify it as a trusted key.
[SwitchA] ntp-service authentication enable
[SwitchA] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[SwitchA] ntp-service reliable authentication-keyid 88
# Configure Switch A to operate in NTP broadcast client mode and receive NTP broadcast messages on VLAN-interface 2.
3. Configure Switch B:
# Enable NTP authentication on Switch B. Configure an NTP authentication key, with the key ID of 88 and key value of 123456. Input the key in plain text and specify it as a trusted key.
[SwitchB] ntp-service authentication enable
[SwitchB] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[SwitchB] ntp-service reliable authentication-keyid 88
# Configure Switch B to operate in broadcast client mode and receive NTP broadcast messages on VLAN-interface 2.
4. Configure Switch C:
[SwitchC] ntp-service refclock-master 3
# Configure Switch C to operate in NTP broadcast server mode and use VLAN-interface 2 to send NTP broadcast packets.
NTP authentication is enabled on Switch A and Switch B, but not on Switch C, so Switch A and Switch B cannot synchronize their local clocks to Switch C.
# Verify that Switch B has not synchronized to Switch C.
[SwitchB-Vlan-interface2] display ntp-service status
Clock status: unsynchronized
Clock stratum: 16
Reference clock ID: none
6. Enable NTP authentication on Switch C:
# Enable NTP authentication on Switch C. Configure an NTP authentication key, with the key ID of 88 and key value of 123456. Input the key in plain text, and specify it as a trusted key.
[SwitchC] ntp-service authentication enable
[SwitchC] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[SwitchC] ntp-service reliable authentication-keyid 88
# Specify Switch C as an NTP broadcast server, and associate the key 88 with Switch C.
[SwitchC-Vlan-interface2] ntp-service broadcast-server authentication-keyid 88
# Verify that Switch B has synchronized to Switch C, and the clock stratum level is 4 on Switch B and 3 on Switch C.
Clock stratum: 4
Local mode: bclient
Leap indicator: 00
Clock jitter: 0.006683 s
Root delay: 0.00127 ms
Root dispersion: 2.89877 ms
Reference time: d0d287a7.3119666f Sat, Jan 8 2011 6:50:15.191
# Verify that an IPv4 NTP association has been established between Switch B and Switch C.
[SwitchB-Vlan-interface2] display ntp-service sessions
[1245]3.0.1.31 127.127.1.0 3 3 64 68 -0.0 0.0000 0.0
Total sessions : 1
As shown in Figure 15, two VPNs are present on PE 1 and PE 2: VPN 1 and VPN 2. CE 1 and CE 3 are devices in VPN 1.
To synchronize time between PE 2 and CE 1 in VPN 1, perform the following tasks:
· Configure CE 1's local clock as a reference source, with the stratum level 2.
· Configure PE 1 to operate in client/server mode.
· Specify VPN 1 as the target VPN.
Before you perform the following configuration, be sure you have completed MPLS VPN-related configurations and make sure of the reachability between CE 1 and PE 1, between PE 1 and PE 2, and between PE 2 and CE 3.
1. Set the IP address for each interface, as shown in Figure 15. (Details not shown.)
2. Configure CE 1:
<CE1> system-view
[CE1] ntp-service enable
[CE1] ntp-service refclock-master 2
3. Configure PE 2:
<PE2> system-view
[PE2] ntp-service enable
# Specify CE 1 in VPN 1 as the NTP server of PE 2.
[PE2] ntp-service unicast-server 10.1.1.1 vpn-instance vpn1
# Verify that PE 2 has synchronized to CE 1, with the stratum level 3.
[PE2] display ntp-service status
Clock stratum: 3
System peer: 10.1.1.1
Local mode: client
Reference clock ID: 10.1.1.1
Leap indicator: 00
# Verify that an IPv4 NTP association has been established between PE 2 and CE 1.
[PE2] display ntp-service sessions
[1245]10.1.1.1 127.127.1.0 2 1 64 519 -0.0 0.0065 0.0
Total sessions : 1
# Verify that server 127.0.0.1 has synchronized to server 10.1.1.1, and server 10.1.1.1 has synchronized to the local clock.
[PE2] display ntp-service trace
Server 127.0.0.1
Stratum 3 , jitter 0.000, synch distance 796.50.
Server 10.1.1.1
Stratum 2 , jitter 939.00, synch distance 0.0000.
RefID 127.127.1.0
As shown in Figure 16, two VPNs are present on PE 1 and PE 2: VPN 1 and VPN 2. CE 1 and CE 3 belong to VPN 1.
To synchronize the time between PE 1 and CE 1 in VPN 1, perform the following tasks:
· Configure CE 1 to operate in symmetric active mode.
1. Set the IP address for each interface, as shown in Figure 16. (Details not shown.)
2. Configure CE 1:
<CE1> system-view
3. Configure PE 1:
<PE1> system-view
[PE1] ntp-service enable
# Specify CE 1 in VPN 1 as the symmetric-passive peer of PE 1.
[PE1] ntp-service unicast-peer 10.1.1.1 vpn-instance vpn1
# Verify that PE 1 has synchronized to CE 1, with the stratum level 3.
[PE1] display ntp-service status
Clock stratum: 3
Local mode: sym_active
Leap indicator: 00
# Verify that an IPv4 NTP association has been established between PE 1 and CE 1.
[PE1] display ntp-service sessions
[1245]10.1.1.1 127.127.1.0 2 1 64 519 -0.0 0.0000 0.0
Total sessions : 1
[PE1] display ntp-service trace
Server 127.0.0.1
Server 10.1.1.1
RefID 127.127.1.0
Configuring SNTP
SNTP is a simplified, client-only version of NTP specified in RFC 4330. SNTP supports only the client/server mode. An SNTP-enabled device can receive time from NTP servers, but cannot provide time services to other devices.
SNTP uses the same packet format and packet exchange procedure as NTP, but provides faster synchronization at the price of time accuracy.
If you specify multiple NTP servers for an SNTP client, the server with the best stratum is selected. If multiple servers are at the same stratum, the NTP server whose time packet is first received is selected.
Make sure you use the clock protocol command to specify the NTP time source.
Tasks at a glance |
(Required.) Enabling the SNTP service |
(Required.) Specifying an NTP server for the device |
(Optional.) Configuring SNTP authentication |
To enable the SNTP service:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the SNTP service. |
sntp enable |
By default, the SNTP service is not enabled. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify an NTP server for the device. |
sntp unicast-server { server-name | ip-address } [ vpn-instance vpn-instance-name ] [ authentication-keyid keyid | source interface-type interface-number | version number ] * |
By default, no NTP server is specified for the device. Repeat this step to specify multiple NTP servers. To use authentication, you must specify the authentication-keyid keyid option. |
To use an NTP server as the time source, make sure its clock has been synchronized. If the stratum level of the NTP server is greater than or equal to that of the client, the client does not synchronize with the NTP server.
SNTP authentication makes sure an SNTP client is synchronized only to an authenticated trustworthy NTP server.
Follow these guidelines when you configure SNTP authentication:
· Enable authentication on both the NTP server and the SNTP client.
· Configure the SNTP client with the same authentication key ID and key value as the NTP server, and specify the key as a trusted key on both the NTP server and the SNTP client. For information about configuring NTP authentication on an NTP server, see "Configuring NTP."
· Associate the specified key with the specific NTP server on the SNTP client.
With authentication disabled, the SNTP client can synchronize with the NTP server regardless of whether the NTP server is enabled with authentication.
To configure SNTP authentication on the SNTP client:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable SNTP authentication. |
sntp authentication enable |
By default, SNTP authentication is disabled. |
3. Configure an SNTP authentication key. |
sntp authentication-keyid keyid authentication-mode md5 { cipher | simple } value |
By default, no SNTP authentication key is configured. |
4. Specify the key as a trusted key. |
sntp reliable authentication-keyid keyid |
By default, no trusted key is specified. |
5. Associate the SNTP authentication key with the specific NTP server. |
sntp unicast-server { ip-address | server-name } [ vpn-instance vpn-instance-name ] authentication-keyid keyid |
By default, no NTP server is specified. |
Displaying and maintaining SNTP
Task |
Command |
Display information about all SNTP associations. |
display sntp sessions |
SNTP configuration example
As shown in Figure 17, perform the following tasks:
· Configure Device B to operate in SNTP client mode, and specify Device A as the NTP server.
· Configure NTP authentication on Device A and SNTP authentication on Device B.
1. Set the IP address for each interface, as shown in Figure 17. (Details not shown.)
# Configure the local clock of Device A as a reference source, with the stratum level 2.
# Enable NTP authentication on Device A.
# Configure an NTP authentication key, with the key ID of 10 and key value of aNiceKey. Input the key in plain text.
[DeviceA] ntp-service authentication-keyid 10 authentication-mode md5 simple aNiceKey
[DeviceA] ntp-service reliable authentication-keyid 10
# Enable the SNTP service.
[DeviceB] sntp enable
# Enable SNTP authentication on Device B.
[DeviceB] sntp authentication enable
# Configure an SNTP authentication key, with the key ID of 10 and key value of aNiceKey. Input the key in plain text.
[DeviceB] sntp authentication-keyid 10 authentication-mode md5 simple aNiceKey
[DeviceB] sntp reliable authentication-keyid 10
# Specify Device A as the NTP server of Device B, and associate the server with key 10.
[DeviceB] sntp unicast-server 1.0.1.11 authentication-keyid 10
# Verify that an SNTP association has been established between Device B and Device A, and Device B has synchronized to Device A.
[DeviceB] display sntp sessions
NTP server Stratum Version Last receive time
1.0.1.11 2 4 Tue, May 17 2011 9:11:20.833 (Synced)
The information center on a device classifies and manages logs for all modules so that network administrators can monitor network performance and troubleshoot network problems.
Overview
The information center receives logs generated by source modules and outputs logs to different destinations according to user-defined output rules. You can classify, filter, and output logs based on source modules. To view the supported source modules, use info-center source ?.
Figure 18 Information center diagram
By default, the information center is enabled.
Log types
Logs are classified into the following types:
· Common logs—Record common system information. Unless otherwise specified, the term "logs" in this document refers to common logs.
· Diagnostic logs—Record debug messages.
· Hidden logs—Record log information not displayed on the terminal, such as input commands.
· Trace logs—Record system tracing and debug messages,
Log levels
Logs are classified into eight severity levels from 0 through 7 in descending order. The device outputs logs with a severity level that is higher than or equal to the specified level. For example, if you configure an output rule with a severity level of 6 (informational), logs that have a severity level from 0 to 6 are output.
Severity value |
Level |
0 |
Emergency |
The system is unusable. For example, the system authorization has expired. |
1 |
Alert |
Action must be taken immediately. For example, traffic on an interface exceeds the upper limit. |
2 |
Critical |
Critical condition. For example, the device temperature exceeds the upper limit, the power module fails, or the fan tray fails. |
3 |
Error |
Error condition. For example, the link state changes. |
4 |
Warning |
Warning condition. For example, an interface is disconnected, or the memory resources are used up. |
5 |
Notification |
Normal but significant condition. For example, a terminal logs in to the device, or the device reboots. |
6 |
Informational |
Informational message. For example, a command or a ping operation is executed. |
7 |
Debug |
Debug message. |
Log destinations
The system outputs logs to the following destinations: console, monitor terminal, log buffer, log host, and log file. Log output destinations are independent and you can configure them after enabling the information center.
Default output rules for logs
A log output rule specifies the source modules and severity level of logs that can be output to a destination. Logs matching the output rule are output to the destination. Table 7 shows the default log output rules.
Destination |
Log source modules |
Output switch |
Severity |
Console |
All supported modules |
Enabled |
Debug |
Monitor terminal |
Disabled |
Debug |
Log host |
Enabled |
Informational |
Log buffer |
Enabled |
Informational |
Log file |
Enabled |
Informational |
Default output rules for diagnostic logs
Diagnostic logs can only be output to the diagnostic log file, and cannot be filtered by source modules and severity levels. Table 8 shows the default output rule for diagnostic logs.
Table 8 Default output rule for diagnostic logs
Destination |
Output switch |
Severity |
Diagnostic log file |
Enabled |
Debug |
Default output rules for hidden logs
Hidden logs can be output to the log host, log buffer, and the log file, but they cannot be filtered by source modules and severity levels. Table 9 shows the default output rules for hidden logs.
Table 9 Default output rules for hidden logs
Destination |
Output switch |
Severity |
Log host |
Enabled |
Informational |
Log buffer |
Enabled |
Informational |
Log file |
Enabled |
Informational |
Default output rules for trace logs
Trace logs can only be output to the trace log file, and cannot be filtered by source modules and severity levels. Table 10 shows the default output rules for trace logs.
Table 10 Default output rules for trace logs
Destination |
Output switch |
Severity |
Trace log file |
Enabled |
Debugging |
Log formats
The format of logs varies with output destinations. Table 11 shows the original format of log information, which might be different from what you see. The actual format depends on the log resolution tool used.
Output destination |
Format |
Example |
Console, monitor terminal, log buffer, or log file |
Prefix Timestamp Sysname Module/Level/Mnemonic: Content |
%Nov 24 14:21:43:502 2010 H3C SYSLOG/6/SYSLOG_RESTART: System restarted –- H3C Comware Software. |
Log host |
H3C format: ·
unicom format: ·
cmcc format: |
H3C format: ·
unicom format: ·
cmcc format: |
Table 12 describes the fields in a log message.
Table 12 Log field description
Prefix (information type) |
A log to a destination other than the log host has an identifier in front of the timestamp: · An identifier of percent sign (%) indicates a log with a level equal to or higher than informational. · An identifier of asterisk (*) indicates a debug log or a trace log. · An identifier of caret (^) indicates a diagnostic log. |
PRI (priority) |
A log destined to the log host has a priority identifier in front of the timestamp. The priority is calculated by using this formula: facility*8+level, where: · facility is the facility name. It can be configured with the info-center loghost command. It is used to identify log sources on the log host, and to query and filter the logs from specific log sources. · level ranges from 0 to 7. See Table 6 for more information about severity levels. |
Timestamp |
Records the time when the log was generated. Logs sent to the log host and those sent to the other destinations have different timestamp precisions, and their timestamp formats are configured with different commands. For more information, see Table 13 and Table 14. |
Hostip |
Source IP address of the log. If info-center loghost source is configured, this field displays the IP address of the specified source interface. Otherwise, this field displays the sysname. This field exists only in logs in unicom format that are sent to the log host. |
Serial number |
Serial number of the device that generated the log. This field exists only in logs in unicom format that are sent to the log host. |
Sysname (host name or host IP address) |
The sysname is the host name or IP address of the device that generated the log. You can use the sysname command to modify the name of the device. |
%% (vendor ID) |
Indicates that the information was generated by an H3C device. This field exists only in logs sent to the log host. |
vv (version information) |
Identifies the version of the log, and has a value of 10. This field exists only in logs that are sent to the log host. |
Module |
Specifies the name of the module that generated the log. You can enter the info-center source ? command in system view to view the module list. |
Level |
Identifies the level of the log. See Table 6 for more information about severity levels. |
Mnemonic |
Describes the content of the log. It contains a string of up to 32 characters. |
Source |
Identifies the source of the log. It can take one of the following values: · Slot number of a card. (In standalone mode.) · IRF member ID and card slot number. (In IRF mode.) · IP address of the log sender. |
Content |
Provides the content of the log. |
Table 13 Timestamp precisions and configuration commands
Item |
Destined to the log host |
Destined to the console, monitor terminal, log buffer, and log file |
Precision |
Seconds |
Milliseconds |
Command used to set the timestamp format |
info-center timestamp loghost |
info-center timestamp |
Table 14 Description of the timestamp parameters
Timestamp parameters |
Example |
boot |
Time that has elapsed since system startup, in the format of xxx.yyy. xxx represents the higher 32 bits, and yyy represents the lower 32 bits, of milliseconds elapsed. Logs that are sent to all destinations other than a log host support this parameter. |
%0.109391473 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully. 0.109391473 is a timestamp in the boot format. |
date |
Current date and time, in the format of mmm dd hh:mm:ss yyy for logs that are output to a log host, or MMM DD hh:mm:ss:xxx YYYY for logs that are output to other destinations. All logs support this parameter. |
%May 30 05:36:29:579 2003 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully. May 30 05:36:29:579 2003 is a timestamp in the date format. |
iso |
Timestamp format stipulated in ISO 8601. Only logs that are sent to a log host support this parameter. |
<189>2003-05-30T06:42:44 Sysname %%10FTPD/5/FTPD_LOGIN(l): User ftp (192.168.1.23) has logged in successfully. 2003-05-30T06:42:44 is a timestamp in the iso format. |
none |
No timestamp is included. All logs support this parameter. |
% Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully. No timestamp is included. |
no-year-date |
Current date and time without year information, in the format of MMM DD hh:mm:ss:xxx. Only logs that are sent to a log host support this parameter. |
<189>May 30 06:44:22 Sysname %%10FTPD/5/FTPD_LOGIN(l): User ftp (192.168.1.23) has logged in successfully. May 30 06:44:22 is a timestamp in the no-year-date format. |
FIPS compliance
Information center configuration task list
Tasks at a glance |
Perform at least one of the following tasks: · Outputting logs to the console · Outputting logs to the monitor terminal · Outputting logs to a log host |
(Optional.) Saving diagnostic logs to the diagnostic log file |
(Optional.) Configuring the maximum size of the trace log file |
(Optional.) Enabling synchronous information output |
(Optional.) Enabling duplicate log suppression |
(Optional.) Disabling an interface from generating link up or link down logs |
(Optional.) Setting the minimum storage period for logs |
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the information center. |
info-center enable |
By default, the information center is enabled. |
3. Configure an output rule for the console. |
info-center source { module-name | default } { console | monitor | logbuffer | logfile | loghost } { deny | level severity } |
For information about default output rules, see "Default output rules for logs." |
4. (Optional.) Configure the timestamp format. |
info-center timestamp { boot | date | none } |
By default, the timestamp format is date. |
5. Return to user view. |
quit |
N/A |
6. Enable log output to the console. |
terminal monitor |
The default setting is enabled. |
7. Enable the display of debug information on the current terminal. |
terminal debugging |
By default, the display of debug information is disabled on the monitor terminal. |
8. (Optional.) Set the lowest severity level of logs that can be output to the console. |
terminal logging level severity |
The default setting is 6 (informational). |
Monitor terminals refer to terminals that log in to the device through the VTY user interface.
To output logs to the monitor terminal:
Step |
Command |
Remarks |
system-view |
N/A |
3. Configure an output rule for the monitor terminal. |
quit |
N/A |
6. Enable log output to the monitor terminal. |
terminal monitor |
8. (Optional.) Set the lowest level of logs that can be output to the monitor terminal. |
Step |
Command |
Remarks |
system-view |
N/A |
3. Configure an output rule for outputting logs to a log host. |
4. (Optional.) Specify the source IP address for output logs. |
info-center loghost source interface-type interface-number |
By default, the source IP address of output log information is the primary IP address of the matching route's egress interface. |
5. (Optional.) Configure the timestamp format. |
info-center timestamp loghost { date | iso | no-year-date | none } |
6. Specify a log host and configure related parameters. |
info-center loghost [ vpn-instance vpn-instance-name ] loghost [ port port-number ] [ facility local-number ] |
By default, no log host or related parameters are specified. The value of the port-number argument must be the same as the value configured on the log host. Otherwise, the log host cannot receive logs. |
Outputting logs to the log buffer
Step |
Command |
Remarks |
N/A |
3. (Optional.) Set the maximum number of logs that can be stored in the log buffer. |
info-center logbuffer size buffersize |
By default, the log buffer can store 512 logs. |
4. Configure an output rule for the log buffer. |
Saving logs to the log file
By default, the log file feature saves logs from the log file buffer to the log file every 24 hours. You can adjust the saving interval or manually save logs to the log file. After saving logs into the log file, the system clears the log file buffer.
The log file has a maximum capacity. When the capacity is reached, the system will replace earliest logs with new logs.
To save logs to the log file:
Step |
Command |
Remarks |
system-view |
N/A |
3. Enable the log file feature. |
info-center logfile enable |
By default, the log file feature is enabled. |
4. (Optional.) Enable log file overwrite-protection. |
info-center logfile overwrite-protection [ all-port-powerdown ] |
By default, log file overwrite-protection is disabled. When it is enabled, the device stops saving new logs when the log file is full or the storage device runs out of space. This command is supported only in FIPS mode. |
5. (Optional.) Configure the maximum size for the log file. |
info-center logfile size-quota size |
The default setting is10 MB. To ensure normal operation, set the size argument to a value between 1 MB and 10 MB. |
6. (Optional.) Specify the directory to save the log file. |
info-center logfile directory dir-name |
The default setting is flash:/logfile. The configuration made by this command cannot survive a reboot or an active/standby switchover. |
7. Save the logs in the log file buffer to the log file. |
Method 1: Configure
the interval to perform the save operation: ·
Method 2: Manually
save the logs in the log file buffer to the
log file: |
Use either method. The default saving interval is 86400 seconds. The logfile save command is available in any view. |
By default, the system saves diagnostic logs from the diagnostic log buffer to the diagnostic log file every 24 hours. You can adjust the saving interval or manually save diagnostic logs to the diagnostic log file. After saving diagnostic logs into the diagnostic log file, the system clears the diagnostic log buffer.
The diagnostic log file has a maximum capacity. When the capacity is reached, the system replaces earliest diagnostic logs with new logs.
To enable saving diagnostic logs to the diagnostic log file:
Step |
Command |
Remarks |
system-view |
N/A |
3. Enable saving diagnostic logs to the diagnostic log file. |
info-center diagnostic-logfile enable |
By default, saving diagnostic logs to the diagnostic log file is enabled. |
4. (Optional.) Configure the maximum size of the diagnostic log file. |
info-center diagnostic-logfile quota size |
The default setting is 10 MB. To ensure normal operation, set the size argument to a value between 1 MB and 10 MB. |
5. (Optional.) Specify the directory to save the diagnostic log file. |
info-center diagnostic-logfile directory dir-name |
The default setting is flash:/diagfile. The configuration made by this command cannot survive a reboot or an active/standby switchover. |
6. Save the diagnostic logs in the diagnostic log buffer to the diagnostic log file. |
Method 1: Configure
the interval to perform the saving operation: ·
Method 2: Manually
save the diagnostic logs in the buffer to a diagnostic log file: |
The default saving interval is 86400 seconds. The diagnostic-logfile save command is available in any view. |
The device has only one trace log file. When the trace log file is full, the device overwrites the oldest trace logs with new ones.
To set the maximum size of the trace log file:
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the maximum size of the trace log file. |
info-center trace-logfile quota size |
By default, the maximum size of the trace log file is 1 MB. |
System log output interrupts ongoing configuration operations, obscuring previously entered commands. Synchronous information output shows the obscured commands. It also provides a command prompt in command editing mode, or a [Y/N] string in interaction mode so you can continue your operation from where you were stopped.
To enable synchronous information output:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable synchronous information output. |
info-center synchronous |
By default, synchronous information output is disabled. |
The output of consecutive duplicate logs at an interval of less than 30 seconds wastes system and network resources.
With this feature enabled, the system starts a suppression period upon outputting a log:
· During the suppression period, the system does not output logs that have the same module name, level, mnemonic, location, and text as the previous log.
· After the suppression period expires, if the same log continues to appear, the system outputs the suppressed logs and the log number and starts another suppression period. The suppression period is 30 seconds for the first time, 2 minutes for the second time, and 10 minutes for subsequent times.
· If a different log is generated during the suppression period, the system aborts the current suppression period, outputs suppressed logs and the log number and then the different log, and starts another suppression period.
To enable duplicate log suppression:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable duplicate log suppression. |
info-center logging suppress duplicates |
By default, duplicate log suppression is disabled. |
By default, all interfaces generate link up or link down log information when the interface state changes. In some cases, you might want to disable specific interfaces from generating this information. For example:
· You are concerned only about the states of some interfaces. In this case, you can use this function to disable other interfaces from generating link up and link down log information.
· An interface is unstable and continuously outputs log information. In this case, you can disable the interface from generating link up and link down log information.
To disable an interface from generating link up or link down logs:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Disable the interface from generating link up or link down logs. |
undo enable log updown |
By default, all interfaces generate link up and link down logs when the interface state changes. |
Use this feature to set the minimum storage period for logs in the log buffer and log file. This feature ensures that logs will not be overwritten by new logs during a set period of time.
In the log buffer or log file, new logs will automatically overwrite the oldest logs when the following conditions are met:
· The log buffer is full.
· The log file is full and the log file overwrite-protection feature is disabled.
After the minimum storage period is set, the system identifies the storage period of a log to determine whether to delete the log. The system current time minus a log's generation time is the log's storage period.
· If the storage period of a log is shorter than or equal to the minimum storage period, the system does not delete the log. The new log will not be saved.
· If the storage period of a log is longer than the minimum storage period, the system deletes the log to save the new log.
To set the log minimum storage period:
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the log minimum storage period. |
info-center syslog min-age min-age |
By default, the log minimum storage period is not set. |
Displaying and maintaining information center
Task |
Command |
Display the information of each output destination. |
display info-center |
Display the state and the log information of the log buffer (in standalone mode). |
display logbuffer [ reverse ] [ level severity | size buffersize | slot slot-number ] * |
Display the state and the log information of the log buffer (in IRF mode). |
display logbuffer [ reverse ] [ level severity | size buffersize | chassis chassis-number slot slot-number ] * |
Display a summary of the log buffer (in standalone mode). |
display logbuffer summary [ level severity | slot slot-number ] * |
Display a summary of the log buffer (in IRF mode). |
display logbuffer summary [ level severity | chassis chassis-number slot slot-number ] * |
Display the configuration of the log file. |
display logfile summary |
Clear the log buffer. |
reset logbuffer |
Information center configuration examples
Configuration example for outputting logs to the console
Network requirements
Configure the device to output to the console FTP logs that have a severity level of at least warning.
Configuration procedure
# Enable the information center.
[Sysname] info-center enable
# Disable log output to the console.
[Sysname] info-center source default console deny
To avoid output of unnecessary information, disable all modules from outputting log information to the specified destination (console in this example) before you configure the output rule.
# Configure an output rule to output to the console FTP logs that have a severity level of at least warning.
[Sysname] info-center source ftp console level warning
[Sysname] quit
# Enable the display of logs on the console. (This function is enabled by default.)
<Sysname> terminal logging level 6
<Sysname> terminal monitor
Current terminal monitor is on.
Now, if the FTP module generates logs, the information center automatically sends the logs to the console, and the console displays the logs.
Configuration example for outputting logs to a UNIX log host
Configure the device to output to the UNIX log host FTP logs that have a severity level of at least informational.
Figure 20 Network diagram
Before the configuration, make sure the device and the log host can reach each other. (Details not shown.)
1. Configure the device:
[Device] info-center enable
# Specify the log host 1.2.0.1/16 and specify local4 as the logging facility.
[Device] info-center loghost 1.2.0.1 facility local4
# Disable log output to the log host.
To avoid output of unnecessary information, disable all modules from outputting logs to the specified destination (loghost in this example) before you configure an output rule.
# Configure an output rule to output to the log host FTP logs that have a severity level of at least informational.
[Device] info-center source ftp loghost level informational
2. Configure the log host:
The following configurations were performed on Solaris. Other UNIX operating systems have similar configurations.
a. Log in to the log host as a root user.
b. Create a subdirectory named Device in directory /var/log/, and then create file info.log in the Device directory to save logs from Device.
# mkdir /var/log/Device
c. Edit the file syslog.conf in directory /etc/ and add the following contents.
In this configuration, local4 is the name of the logging facility that the log host uses to receive logs. info is the informational level. The UNIX system records the log information that has a severity level of at least informational to the file /var/log/Device/info.log.
NOTE: Follow these guidelines while editing the file /etc/syslog.conf: · Comments must be on a separate line and must begin with a pound sign (#). · No redundant spaces are allowed after the file name. · The logging facility name and the severity level specified in the /etc/syslog.conf file must be identical to those configured on the device by using the info-center loghost and info-center source commands. Otherwise, the log information might not be output properly to the log host. |
d. Display the process ID of syslogd, kill the syslogd process, and then restart syslogd using the –r option to make the new configuration take effect.
# ps -ae | grep syslogd
147
# kill -HUP 147
# syslogd -r &
Now, the device can output FTP logs to the log host, which stores the logs to the specified file.
Configuration example for outputting logs to a Linux log host
Configure the device to output to the Linux log host 1.2.0.1/16 FTP logs that have a severity level of at least informational.
Figure 21 Network diagram
# Specify the log host 1.2.0.1/16, and specify local5 as the logging facility.
[Sysname] info-center loghost 1.2.0.1 facility local5
[Sysname] info-center source default loghost deny
To avoid outputting unnecessary information, disable all modules from outputting log information to the specified destination (loghost in this example) before you configure an output rule.
# Configure an output rule to enable output to the log host FTP logs that have a severity level of at least informational.
[Sysname] info-center source ftp loghost level informational
b. Create a subdirectory named Device in the directory /var/log/, and create file info.log in the Device directory to save logs of Device.
local5.info /var/log/Device/info.log
In the above configuration, local5 is the name of the logging facility used by the log host to receive logs. info is the informational level. The Linux system will store the log information with a severity level equal to or higher than informational to the file /var/log/Device/info.log.
NOTE: Follow these guidelines while editing the file /etc/syslog.conf: · Comments must be on a separate line and must begin with a pound sign (#). · No redundant spaces are allowed after the file name. · The logging facility name and the severity level specified in the /etc/syslog.conf file must be identical to those configured on the device by using the info-center loghost and info-center source commands. Otherwise, the log information might not be output to the log host. |
d. Display the process ID of syslogd, kill the syslogd process, and then restart syslogd by using the -r option to apply the new configuration.
Make sure the syslogd process is started with the -r option on a Linux log host.
147
# kill -9 147
# syslogd -r &
Now, the system can record log information into the specified file.
Configuring SNMP
This chapter provides an overview of the Simple Network Management Protocol (SNMP) and guides you through the configuration procedure.
Overview
SNMP is an Internet standard protocol widely used for a management station to access and operate the devices on a network, regardless of their vendors, physical characteristics, and interconnect technologies.
SNMP enables network administrators to read and set the variables on managed devices for state monitoring, troubleshooting, statistics collection, and other management purposes.
FIPS compliance
SNMP framework
The SNMP framework comprises the following elements:
· SNMP manager—Works on an NMS to monitor and manage the SNMP-capable devices in the network.
· SNMP agent—Works on a managed device to receive and handle requests from the NMS, and sends notifications to the NMS when events, such as an interface state change, occur.
· Management Information Base (MIB)—Specifies the variables (for example, interface status and CPU usage) maintained by the SNMP agent for the SNMP manager to read and set.
Figure 22 Relationship between NMS, agent, and MIB
MIB and view-based MIB access control
A MIB stores variables called "nodes" or "objects" in a tree hierarchy and identifies each node with a unique OID. An OID is a dotted numeric string that uniquely identifies the path from the root node to a leaf node. For example, object B in Figure 23 is uniquely identified by the OID {1.2.1.1}.
A MIB view represents a set of MIB objects (or MIB object hierarchies) with certain access privileges and is identified by a view name. The MIB objects included in the MIB view are accessible while those excluded from the MIB view are inaccessible.
A MIB view can have multiple view records each identified by a view-name oid-tree pair.
You control access to the MIB by assigning MIB views to SNMP groups or communities.
SNMP operations
SNMP provides the following basic operations:
· Get—NMS retrieves the SNMP object nodes in an agent MIB.
· Set—NMS modifies the value of an object node in an agent MIB.
· Notification—SNMP agent sends traps or informs to report events to the NMS. The difference between these two types of notification is that informs require acknowledgement but traps do not. Traps are available in SNMPv1, SNMPv2c, and SNMPv3, but informs are available only in SNMPv2c and SNMPv3.
Protocol versions
SNMPv1, SNMPv2c, and SNMPv3 are supported in non-FIPS mode. Only SNMPv3 is supported in FIPS mode. An NMS and an SNMP agent must use the same SNMP version to communicate with each other.
· SNMPv1—Uses community names for authentication. To access an SNMP agent, an NMS must use the same community name as set on the SNMP agent. If the community name used by the NMS differs from the community name set on the agent, the NMS cannot establish an SNMP session to access the agent or receive traps from the agent.
· SNMPv2c—Uses community names for authentication. SNMPv2c is compatible with SNMPv1, but supports more operation types, data types, and error codes.
· SNMPv3—Uses a user-based security model (USM) to secure SNMP communication. You can configure authentication and privacy mechanisms to authenticate and encrypt SNMP packets for integrity, authenticity, and confidentiality.
Access control modes
SNMP uses the following modes to control access to MIB objects:
· View-based Access Control Model—The VACM mode controls access to MIB objects by assigning MIB views to SNMP communities or users.
· Role based access control—The RBAC mode controls access to MIB objects by assigning user roles to SNMP communities or users.
? An SNMP community or user with a predefined user role network-admin or level-15 has read and write access to all MIB objects.
? An SNMP community or user with a predefined user role network-operator has read-only access to all MIB objects.
? An SNMP community or user with a user role specified by the role command accesses MIB objects through the user role rules specified by the rule command.
If you create the same SNMP community or user with both modes multiple times, the most recent configuration takes effect. For more information about user roles and the rule command, see Fundamentals Command Reference.
For an NMS to access an agent:
· The RBAC mode requires the user role bound to a community name or username to have the same access right to MIB objects as the NMS.
· The VACM mode requires only the access right from the NMS to MIB objects.
The RBAC mode is more secure. As a best practice, use the RBAC mode to control access to MIB objects.
Configuring SNMP basic parameters
SNMPv3 differs from SNMPv1 and SNMPv2c in many ways. Their configuration procedures are described in separate sections.
Configuring SNMPv1 or SNMPv2c basic parameters
SNMPv1 and SNMPv2c settings are supported only in non-FIPS mode.
To configure SNMPv1 or SNMPv2c basic parameters:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. (Optional.) Enable the SNMP agent. |
snmp-agent |
By default, the SNMP agent is disabled. The SNMP agent is enabled when you perform any command that begins with snmp-agent except for the snmp-agent calculate-password command. |
3. (Optional.) Configure the system contact. |
snmp-agent sys-info contact sys-contact |
By default, the system contact is Hangzhou H3C Tech. Co., Ltd. |
4. (Optional.) Configure the system location. |
snmp-agent sys-info location sys-location |
By default, the system location is Hangzhou, China. |
5. Enable SNMPv1 or SNMPv2c. |
snmp-agent sys-info version { all | { v1 | v2c | v3 } * } |
The default is SNMPv3. |
6. (Optional.) Change the local engine ID. |
snmp-agent local-engineid engineid |
By default, the local engine ID is the company ID plus the device ID. |
7. (Optional.) Create or update a MIB view. |
snmp-agent mib-view { excluded | included } view-name oid-tree [ mask mask-value ] |
By default, the MIB view ViewDefault is predefined. In this view, all the MIB objects in the iso subtree but the snmpUsmMIB, snmpVacmMIB, and snmpModules.18 subtrees are accessible. Each view-name oid-tree pair represents a view record. If you specify the same record with different MIB sub-tree masks multiple times, the most recent configuration takes effect. Except for the four sub-trees in the default MIB view, you can create up to 16 unique MIB view records. |
8. Configure the SNMP access right. |
(Method 1.) Create an SNMP community: · (Method 2.) Create an SNMPv1/v2c group, and add users to the group: a. snmp-agent group { v1 | v2c } group-name [ read-view view-name ] [ write-view view-name ] [ notify-view view-name ] [ acl acl-number ] b. snmp-agent usm-user { v1 | v2c } user-name group-name [ acl acl-number ] |
By default, no SNMP group or SNMP community exists. The username configured by using method 1 is the same as that configured by using method 2. Usernames created by either method must be the same as the community name configured on the NMS. |
9. (Optional.) Create an SNMP context. |
snmp-agent context context-name |
By default, no SNMP context is configured on the device. |
10. (Optional.) Map an SNMP community to an SNMP context. |
snmp-agent community-map community-name context context-name |
By default, no mapping between an SNMP community and an SNMP context exists on the device. |
11. (Optional.) Configure the maximum SNMP packet size (in bytes) that the SNMP agent can handle. |
snmp-agent packet max-size byte-count |
By default, the maximum SNMP packet size that the SNMP agent can handle is 1500 bytes. |
12. (Optional.) Specify the UDP port for receiving SNMP packets. |
snmp-agent port port-number |
By default, the device uses UDP port 161 for receiving SNMP packets. |
Configuring SNMPv3 basic parameters
SNMPv3 users are managed in groups. All SNMPv3 users in a group share the same security model, but can use different authentication and privacy key settings. To implement a security model for a user and avoid SNMP communication failures, make sure the security model configuration for the group and the security key settings for the user are compliant with Table 15 and match the settings on the NMS.
Table 15 Basic security setting requirements for different security models
Security model |
Security model keyword for the group |
Security key settings for the user |
Remarks |
Authentication with privacy |
privacy |
Authentication key, privacy key |
If the authentication key or the privacy key is not configured, SNMP communication will fail. |
Authentication without privacy |
authentication |
Authentication key |
If no authentication key is configured, SNMP communication will fail. The privacy key (if any) for the user does not take effect. |
No authentication, no privacy |
Neither authentication nor privacy |
None |
The authentication and privacy keys, if configured, do not take effect. |
To configure SNMPv3 basic parameters:
Step |
Command |
Remarks |
system-view |
N/A |
snmp-agent |
5. Enable SNMPv3. |
snmp-agent sys-info version { all | { v1 | v2c | v3 }* } |
By default, the local engine ID is the company ID plus the device ID. IMPORTANT: After you change the local engine ID, the existing SNMPv3 users and encrypted keys become invalid, and you must reconfigure them. |
7. (Optional.) Configure a remote engine ID. |
snmp-agent remote ip-address [ vpn-instance vpn-instance-name ] engineid engineid |
By default, no remote engine ID is configured. To send informs to an SNMPv3 NMS, you must configure the SNMP engine ID of the NMS. |
8. (Optional.) Create or update a MIB view. |
9. Create an SNMPv3 group. |
In non-FIPS mode: ·
In FIPS mode: |
By default, no SNMP group exists. |
10. (Optional.) Create an SNMP context. |
11. (Optional.) Calculate a digest for the ciphertext key converted from a plaintext key. |
In non-FIPS mode: ·
In FIPS mode: |
N/A |
12. Create an SNMPv3 user. |
In non-FIPS mode (in
VACM mode): ·
RBAC mode): ·
In FIPS mode (in VACM
mode): ·
In FIPS mode (in RBAC mode): |
If the cipher keyword is specified, the arguments auth-password and priv-password are used as encrypted keys. To send informs to an SNMPv3 NMS, you must configure the remote ip-address option to specify the IP address of the NMS. |
13. (Optional.) Configure the maximum SNMP packet size (in bytes) that the SNMP agent can handle. |
14. (Optional.) Specify the UDP port for receiving SNMP packets. |
Configuring SNMP logging
Enable SNMP logging only if necessary. SNMP logging is memory-intensive and might impact device performance.
The SNMP agent logs Get requests, Set requests, Set responses, and SNMP notifications, but does not log Get responses.
· Get operation—The agent logs the IP address of the NMS, name of the accessed node, and node OID.
· Set operation—The agent logs the NMS' IP address, name of accessed node, node OID, variable value, and error code and index for the Set operation.
· Notification tracking—The agent logs the SNMP notifications after sending them to the NMS.
To configure SNMP logging:
Step |
Command |
Remarks |
system-view |
N/A |
2. (Optional.) Enable SNMP logging. |
snmp-agent log { all | get-operation | set-operation } |
By default, SNMP logging is disabled. |
3. (Optional.) Enable SNMP notification logging. |
snmp-agent trap log |
By default, SNMP notification logging is disabled. |
Configuring SNMP notifications
The SNMP Agent sends notifications (traps and informs) to inform the NMS of significant events, such as link state changes and user logins or logouts. Unless otherwise stated, the trap keyword in the command line includes both traps and informs.
Enabling SNMP notifications
Enable an SNMP notification only if necessary. SNMP notifications are memory-intensive and might affect device performance.
To generate linkUp or linkDown notifications when the link state of an interface changes, you must enable linkUp or linkDown notification globally by using the snmp-agent trap enable standard [ linkdown | linkup ] * command and on the interface by using the enable snmp trap updown command.
After you enable notifications for a module, whether the module generates notifications also depends on the configuration of the module. For more information, see the configuration guide for each module.
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable notifications globally. |
snmp-agent trap enable [ configuration | protocol | standard [ authentication | coldstart | linkdown | linkup | warmstart ] * | system ] |
By default, SNMP configuration notifications, standard notifications, and system notifications are enabled. Whether other SNMP notifications are enabled varies with modules. |
3. Enter interface view. |
N/A |
4. Enable link state notifications. |
enable snmp trap updown |
By default, link state notifications are enabled. |
Configuring the SNMP agent to send notifications to a host
You can configure the SNMP agent to send notifications as traps or informs to a host, typically an NMS, for analysis and management. Traps are less reliable and use fewer resources than informs, because an NMS does not send an acknowledgement when it receives a trap.
Configuration guidelines
When network congestion occurs or the destination is not reachable, the SNMP agent buffers notifications in a queue. You can configure the queue size and the notification lifetime (the maximum time that a notification can stay in the queue). A notification is deleted when its lifetime expires. When the notification queue is full, the oldest notifications are automatically deleted.
You can extend standard linkUp/linkDown notifications to include interface description and interface type, but must make sure that the NMS supports the extended SNMP messages.
To send informs, make sure:
· The SNMP agent and the NMS use SNMPv2c or SNMPv3.
· If SNMPv3 is used, you must configure the SNMP engine ID of the NMS when you configure SNMPv3 basic settings. Also, specify the IP address of the SNMP engine when you create the SNMPv3 user.
Configuration prerequisites
· Configure the SNMP agent with the same basic SNMP settings as the NMS. If SNMPv1 or SNMPv2c is used, you must configure a community name. If SNMPv3 is used, you must configure an SNMPv3 user, a MIB view, and a remote SNMP engine ID associated with the SNMPv3 user for notifications.
· The SNMP agent and the NMS can reach each other.
To configure the SNMP agent to send notifications to a host:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure a target host. |
(Method 1.) Send traps to the target host: ·
(Method 2.) Send informs to the target host: |
By default, no target host is configured. |
3. (Optional.) Configure a source address for notifications. |
snmp-agent { inform | trap } source interface-type { interface-number | interface-number.subnumber } |
By default, SNMP uses the IP address of the outgoing routed interface as the source IP address. |
4. (Optional.) Enable extended linkUp/linkDown notifications. |
snmp-agent trap if-mib link extended |
By default, the SNMP agent sends standard linkup/linkDown notifications. |
5. (Optional.) Configure the notification queue size. |
snmp-agent trap queue-size size |
By default, the notification queue can hold 100 notification messages. |
6. (Optional.) Configure the notification lifetime. |
snmp-agent trap life seconds |
The default notification lifetime is 120 seconds. |
Displaying the SNMP settings
Execute display commands in any view. The display snmp-agent community command is supported only in non-FIPS mode.
Task |
Command |
Display SNMP agent system information, including the contact, physical location, and SNMP version. |
display snmp-agent sys-info [ contact | location | version ] * |
Display SNMP agent statistics. |
display snmp-agent statistics |
Display the local engine ID. |
display snmp-agent local-engineid |
Display SNMP group information. |
display snmp-agent group [ group-name ] |
Display remote engine IDs. |
display snmp-agent remote [ ip-address [ vpn-instance vpn-instance-name ] ] |
Display basic information about the notification queue. |
display snmp-agent trap queue |
Display the modules that can generate notifications and their notification status (enable or disable). |
display snmp-agent trap-list |
Display SNMPv3 user information. |
display snmp-agent usm-user [ engineid engineid | username user-name | group group-name ] * |
Display SNMPv1 or SNMPv2c community information. |
display snmp-agent community [ read | write ] |
Display MIB view information. |
display snmp-agent mib-view [ exclude | include | viewname view-name ] |
Display SNMP MIB node information. |
display snmp-agent mib-node [ details | index-node | trap-node | verbose ] |
Display an SNMP context. |
display snmp-agent context [ context-name ] |
SNMPv1/SNMPv2c configuration example
SNMPv1 configuration procedure is the same as the SNMPv2c configuration procedure. This example uses SNMPv1, and is available only for non-FIPS mode.
As shown in Figure 24, the NMS (1.1.1.2/24) uses SNMPv1 to manage the SNMP agent (1.1.1.1/24), and the agent automatically sends notifications to report events to the NMS.
1. Configure the SNMP agent:
# Configure the IP address of the agent and make sure the agent and the NMS can reach each other. (Details not shown.)
# Specify SNMPv1, and create the read-only community public and the read and write community private.
<Agent> system-view
[Agent] snmp-agent sys-info version v1
[Agent] snmp-agent community read public
[Agent] snmp-agent community write private
# Configure contact and physical location information for the agent.
[Agent] snmp-agent sys-info contact Mr.Wang-Tel:3306
[Agent] snmp-agent sys-info location telephone-closet,3rd-floor
# Enable SNMP notifications, set the NMS at 1.1.1.2 as an SNMP trap destination, and use public as the community name. (To make sure the NMS can receive traps, specify the same SNMP version in the snmp-agent target-host command as is configured on the NMS.)
[Agent] snmp-agent trap enable
[Agent] snmp-agent target-host trap address udp-domain 1.1.1.2 params securityname public v1
2. Configure the SNMP NMS:
? Specify SNMPv1.
? Create the read-only community public, and create the read and write community private.
? Set the timeout timer and maximum number of retries as needed.
For information about configuring the NMS, see the NMS manual.
NOTE: The SNMP settings on the agent and the NMS must match. |
3. Verify the configuration:
# Try to get the MTU value of NULL0 interface from the agent. The attempt succeeds.
Send request to 1.1.1.1/161 ...
Protocol version: SNMPv1
Operation: Get
Request binding:
1: 1.3.6.1.2.1.2.2.1.4.135471
Response binding:
1: Oid=ifMtu.135471 Syntax=INT Value=1500
Get finished
# Use a wrong community name to get the value of a MIB node on the agent. You can see an authentication failure trap on the NMS.
1.1.1.1/2934 V1 Trap = authenticationFailure
SNMP Version = V1
Community = public
Command = Trap
Enterprise = 1.3.6.1.4.1.43.1.16.4.3.50
GenericID = 4
SpecificID = 0
Time Stamp = 8:35:25.68
SNMPv3 in VACM mode configuration example
As shown in Figure 25, the NMS (1.1.1.2/24) uses SNMPv3 to monitor and manage the interface status of the agent (1.1.1.1/24). The agent automatically sends notifications to report events to the NMS. The default UDP port 162 is used for SNMP notifications.
The NMS and the agent perform authentication when they set up an SNMP session. The authentication algorithm is SHA-1 and the authentication key is 123456TESTauth&!. The NMS and the agent also encrypt the SNMP packets between them by using the AES algorithm and the privacy key 123456TESTencr&!.
1. Configure the agent:
# Configure the IP address of the agent, and make sure the agent and the NMS can reach each other. (Details not shown.)
# Assign the NMS (SNMPv3 group managev3group) read and write access to the objects under the snmp node (OID 1.3.6.1.2.1.11), and deny its access to any other MIB object.
<Agent> system-view
[Agent] undo snmp-agent mib-view ViewDefault
[Agent] snmp-agent mib-view included test snmp
[Agent] snmp-agent group v3 managev3group privacy read-view test write-view test
# Add the user managev3user to the SNMPv3 group managev3group, and set the authentication algorithm to sha, authentication key to 123456TESTauth&!, encryption algorithm to aes128, and privacy key to 123456TESTencr&!.
[Agent] snmp-agent usm-user v3 managev3user managev3group simple authentication-mode sha 123456TESTauth&! privacy-mode aes128 123456TESTencr&!
# Enable notifications, specify the NMS at 1.1.1.2 as a trap destination, and set the username to managev3user for the traps.
[Agent] snmp-agent target-host trap address udp-domain 1.1.1.2 params securityname managev3user v3 privacy
? Specify SNMPv3.
? Create the SNMPv3 user managev3user.
? Enable both authentication and privacy functions.
? Use SHA-1 for authentication and AES for encryption.
? Set the authentication key to 123456TESTauth&! and the privacy key to 123456TESTencr&!.
? Set the timeout timer and maximum number of retries.
# Try to get the MTU value of NULL0 interface from the agent. The get attempt succeeds.
Protocol version: SNMPv3
Operation: Get
Request binding:
Response binding:
Get finished
# Try to get the device name from the agent. The get attempt fails because the NMS has no access right to the node.
Operation: Get
Request binding:
1: 1.3.6.1.2.1.1.5.0
Response binding:
1: Oid=sysName.0 Syntax=noSuchObject Value=NULL
Get finished
# Execute the shutdown or undo shutdown command on an idle interface on the agent. You can see the link state change traps on the NMS:
1.1.1.1/3374 V3 Trap = linkdown
SNMP Version = V3
Community = managev3user
Command = Trap
1.1.1.1/3374 V3 Trap = linkup
SNMP Version = V3
SNMPv3 in RBAC mode configuration example
As shown in Figure 26, the NMS (1.1.1.2/24) uses SNMPv3 to monitor and manage the interface status of the agent (1.1.1.1/24). The agent automatically sends notifications to report events to the NMS.
The NMS and the agent perform authentication when they establish an SNMP session. The authentication algorithm is SHA-1 and the authentication key is 123456TESTauth&!. The NMS and the agent also encrypt the SNMP packets between them by using the AES algorithm and the privacy key 123456TESTencr&!.
# Create the user role test, and permit test to have read and write access to the snmp node (OID 1.3.6.1.2.1.11).
[Agent] role name test
[Agent-role-test] rule 1 permit read write oid 1.3.6.1.2.1.11
# Permit the user role test to have read-only access to the system node (OID 1.3.6.1.2.1.1) and hh3cUIMgt node (OID 1.3.6.1.4.1.25506.2.2).
[Agent-role-test] rule 2 permit read oid 1.3.6.1.4.1.25506.2.2
[Agent-role-test] rule 3 permit read oid 1.3.6.1.2.1.1
[Agent-role-test] quit
# Create the SNMPv3 user managev3user with the user role test, and enable the authentication with privacy security model for the user. Set the authentication algorithm to sha, authentication key to 123456TESTauth&!, encryption algorithm to aes128, and privacy key to 123456TESTencr&!.
# Enable notifications, specify the NMS at 1.1.1.2 as a notification destination, and set the username to managev3user for the notifications.
? Specify SNMPv3.
For information about how to configure the NMS, see the NMS manual.
# Try to get the value of sysName from the agent. The get attempt succeeds.
Operation: Get
Request binding:
Response binding:
1: Oid=sysName.0 Syntax=OCTETS Value=Agent
Get finished
# Try to set the device name from the agent. The set attempt fails because the NMS does not have access rights to the node.
Operation: Set
Request binding:
Response binding:
Session failed ! SNMP: Cannot access variable, No Access, error index=11: Oid=sysName.0 Syntax=OCTETS Value=h3c Set finished
# Log in to the agent. You can see a notification on the NMS.
hh3cLogIn inform received from: 192.168.41.41 at 2013/8/14 17:36:16
Time stamp: 0 days 08h:03m:43s.37th
Agent address: 1.1.1.1 Port: 62861 Transport: IP/UDP Protocol: SNMPv2c Inform
Manager address: 1.1.1.2 Port: 10005 Transport: IP/UDP
Community: public
Bindings (4)
Binding #1: sysUpTime.0 *** (timeticks) 0 days 08h:03m:43s.37th
Binding #2: snmpTrapOID.0 *** (oid) hh3cLogIn
Binding #3: hh3cTerminalUserName.0 *** (octets) testuser [74.65.73.74.75.73.65.72 hex)]
Binding #4: hh3cTerminalSource.0 *** (octets) VTY [56.54.59 (hex)]
Configuring samplers
A sampler selects a packet from sequential packets and sends the packet to other service modules for processing. It operates in fixed mode, which selects the first packet from sequential packets in each sampling.
Port mirroring can use a sampler to sample packets to reduce the number of mirrored packets. For more information about port mirroring, see "Configuring port mirroring"
Creating a sampler
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a sampler. |
sampler sampler-name mode fixed packet-interval rate |
By default, no sampler exists. |
Displaying and maintaining a sampler
Task |
Command |
Display configuration information for a sampler (in standalone mode). |
display sampler [ sampler-name ] [ slot slot-number ] |
Display configuration information for a sampler (in IRF mode). |
display sampler [ sampler-name ] [ chassis chassis-number slot slot-number ] |
The port mirroring feature is available on both Layer 2 and Layer 3 Ethernet interfaces. The term "interface" in this chapter collectively refers to these two types of interfaces. You can use the port link-mode command to configure an Ethernet port as a Layer 2 or Layer 3 interface (see Layer 2—LAN Switching Configuration Guide).
Overview
Port mirroring copies the packets passing through a port or CPU to the monitor port that connects to a data monitoring device for packet analysis.
Terminology
The following terms are used in port mirroring configuration.
Mirroring source
The mirroring sources can be one or more monitored ports or CPUs. The monitored ports and CPUs are called source ports and source CPUs, respectively.
Packets passing through mirroring sources are copied to a port connecting to a data monitoring device for packet analysis. The copies are called mirrored packets.
Source device
The device where the mirroring sources reside is called a source device.
Mirroring destination
The mirroring destination connects to a data monitoring device and is the destination port (also known as the monitor port) of mirrored packets. Mirrored packets are sent out of the monitor port to the data monitoring device.
A monitor port might receive multiple copies of a packet when it monitors multiple mirroring sources. For example, two copies of a packet are received on Port 1 when the following conditions exist:
· Port 1 is monitoring bidirectional traffic of Port 2 and Port 3 on the same device.
· The packet travels from Port 2 to Port 3.
Destination device
The device where the monitor port resides is called the destination device.
Mirroring direction
The mirroring direction specifies the direction of the traffic that is copied on a mirroring source.
· Inbound—Copies packets received.
· Outbound—Copies packets sent.
· Bidirectional—Copies packets received and sent.
Mirroring group
Port mirroring is implemented through mirroring groups, which include local, remote source, and remote destination groups. For more information about the mirroring groups, see "Port mirroring classification and implementation."
Reflector port, egress port, and remote probe VLAN
Reflector ports, remote probe VLANs, and egress ports are used for Layer 2 remote port mirroring. The remote probe VLAN is a dedicated VLAN for transmitting mirrored packets to the destination device. Both the reflector port and egress port reside on a source device and send mirrored packets to the remote probe VLAN.
For more information about the reflector port, egress port, remote probe VLAN, and Layer 2 remote port mirroring, see "Port mirroring classification and implementation."
NOTE: On port mirroring devices, all ports except source, destination, reflector, and egress ports are called common ports. |
Port mirroring includes local port mirroring and remote port mirroring.
· Local port mirroring—The mirroring sources and the mirroring destination are on the same device.
· Remote port mirroring—The mirroring sources and the mirroring destination are on different devices.
In local port mirroring, the following conditions exist:
· The source device is directly connected to a data monitoring device.
· The source device acts as the destination device to forward mirrored packets to the data monitoring device.
A local mirroring group is a mirroring group that contains the mirroring sources and the mirroring destination on the same device.
In a local mirroring group, the source ports or source CPUs, and the monitor port can be located on different cards of the same device.
Figure 27 Local port mirroring implementation
As shown in Figure 27, the source port FortyGigE 1/0/1 and the monitor port FortyGigE 1/0/2 reside on the same device. Packets received on FortyGigE 1/0/1 are copied to FortyGigE 1/0/2. FortyGigE 1/0/2 then forwards the packets to the data monitoring device for analysis.
In remote port mirroring, the following conditions exist:
· The source device is not directly connected to a data monitoring device.
· The source device copies mirrored packets to the destination device, which forwards them to the data monitoring device.
· The mirroring sources and the mirroring destination reside on different devices and are in different mirroring groups.
A remote source group is a mirroring group that contains the mirroring sources. A remote destination group is a mirroring group that contains the mirroring destination. Intermediate devices are the devices between the source device and the destination device.
In Layer 2 remote port mirroring, the mirroring source and the mirroring destination are located on different devices on a same Layer 2 network.
In Layer 2 remote port mirroring, packets are mirrored as follows:
1. The source device copies packets received on the mirroring sources to the egress port.
2. The egress port forwards the mirrored packets to the intermediate devices.
3. The intermediate devices then flood the mirrored packets in the remote probe VLAN and transmit the packets to the destination device.
4. Upon receiving the mirrored packets, the destination device checks whether the ID of the mirrored packets is the same as the remote probe VLAN ID. If the two VLAN IDs match, the destination device forwards the mirrored packets to the data monitoring device through the monitor port.
Figure 28 Layer 2 remote port mirroring implementation
To ensure Layer 2 forwarding of the mirrored packets, assign the intermediate devices' ports facing the source and destination devices to the remote probe VLAN.
In Layer 2 remote port mirroring, the switch does not support bidirectional mirroring on the same port in a mirroring group.
Configuring local port mirroring
A local mirroring group takes effect only when you configure the source ports or source CPUs, and the monitor port for the local mirroring group.
On an IRF fabric, mirroring traffic between IRF member devices is not supported.
Local port mirroring configuration task list
Tasks at a glance |
1. (Required.) Creating a local mirroring group |
2. (Required.) Perform at least one of the following tasks: |
3. (Required.) Configuring the monitor port for the local mirroring group |
Command |
Remarks |
system-view |
N/A |
2. Create a local mirroring group. |
mirroring-group group-id local [ sampler sampler-name ] |
By default, no local mirroring group exists. |
Configuring source ports for the local mirroring group
To configure source ports for a local mirroring group, use one of the following methods:
· Assign a list of source ports to a mirroring group in system view.
· Assign a port to it as a source port in interface view.
To assign multiple ports to the mirroring group as source ports in interface view, repeat the operation.
When you configure source ports for a local mirroring group, follow these restrictions and guidelines:
· A mirroring group can contain multiple source ports.
· A source port can belong to only one mirroring group.
· A source port cannot be configured as a reflector port, egress port, or monitor port.
Configuring source ports in system view
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure source ports for the specified local mirroring group. |
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound } |
By default, no source port is configured for a local mirroring group. |
Configuring source ports in interface view
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Configure the port as a source port for the specified local mirroring group. |
mirroring-group group-id mirroring-port { both | inbound | outbound } |
By default, a port does not act as a source port for any local mirroring group. |
Configuring source CPUs for the local mirroring group
A mirroring group can contain multiple source CPUs.
To configure source CPUs for a local mirroring group:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure source CPUs for the specified local mirroring group. |
mirroring-group group-id mirroring-cpu slot slot-number-list { both | inbound | outbound } |
By default, no source CPU is configured for a local mirroring group. |
To configure the monitor port for a local mirroring group, use one of the following methods:
· Configure the monitor port for the local mirroring group in system view.
· Assign a port to the mirroring group as the monitor port in interface view.
When you configure the monitor port for a mirroring group, follow these restrictions and guidelines:
· For the mirroring function to operate correctly, disable the spanning tree feature on the monitor port.
· For a Layer 2 aggregate interface configured as the monitor port of a mirroring group, do not configure its member interfaces as source ports of the mirroring group.
· A mirroring group contains only one monitor port.
· Use a monitor port for port mirroring only, so the data monitoring device receives only the mirrored traffic.
· In source CPU mode, directly connect the monitor port to the data monitoring device. Disable the following features on the monitor port:
? IGMP snooping.
? MAC address learning.
? Spanning tree.
? Static ARP.
Configuring the monitor port in system view
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the monitor port for the specified local mirroring group. |
mirroring-group group-id monitor-port interface-type interface-number |
By default, no monitor port is configured for a local mirroring group. |
Configuring the monitor port in interface view
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the port as the monitor port for the specified mirroring group. |
mirroring-group group-id monitor-port |
By default, a port does not act as the monitor port for any local mirroring group. |
Configure local port mirroring with multiple monitor ports
Typically, you can configure only one monitor port in a local mirroring group. To configure local port mirroring to support multiple monitor ports, use the remote probe VLAN.
In Layer 2 remote port mirroring, mirrored packets are broadcast within the remote probe VLAN.
To broadcast mirrored packets to multiple monitor ports through the remote probe VLAN, perform the following tasks:
1. Configure a remote source group on the local device.
2. Specify the reflector port for this mirroring group.
3. Configure a remote probe VLAN for this mirroring group.
4. Assign the ports connecting the data monitoring devices to the remote probe VLAN.
When you configure local port mirroring to support multiple monitor ports, follow these restrictions and guidelines:
· Do not configure a Layer 2 aggregate interface as the reflector port.
· As a best practice, configure an unused port as the reflector port of a remote source group, and do not connect a cable to the reflector port.
· For the port mirroring function to operate correctly, do not assign a source port to the remote probe VLAN.
· If you have already configured a reflector port for a remote source group, do not configure an egress port for it.
· A VLAN can act as the remote probe VLAN for only one remote source group. As a best practice, use the remote probe VLAN for port mirroring exclusively. Do not create a VLAN interface for the VLAN or configure any other features for the VLAN.
· A remote probe VLAN must be a static VLAN. To delete this static VLAN, you must first remove the remote probe VLAN configuration by using the undo mirroring-group remote-probe vlan command.
· If the remote probe VLAN of a remote mirroring group is removed, the remote mirroring group will become invalid.
To configure local port mirroring with multiple monitor ports:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a remote source group. |
mirroring-group group-id remote-source [ sampler sampler-name ] |
By default, no mirroring group exists on a device. |
3. Configure source ports for the remote source group. |
· In system view: · In interface view: a. interface interface-type interface-number b. mirroring-group group-id mirroring-port { both | inbound | outbound } c. quit |
By default, no source port is configured for a mirroring group. |
4. Configure the reflector port for the remote source group. |
mirroring-group group-id reflector-port reflector-port |
By default, no reflector port is configured for a mirroring group. |
5. Create the remote probe VLAN and enter VLAN view. |
vlan vlan-id |
By default, no remote probe VLAN is configured for a mirroring group. |
6. Assign monitor ports to the remote probe VLAN. |
port interface-list |
By default, a newly-created VLAN does not have any member port. |
7. Return to system view. |
quit |
N/A |
8. Configure the remote probe VLAN for the remote source group. |
mirroring-group group-id remote-probe vlan rprobe-vlan-id |
Configuring Layer 2 remote port mirroring
To configure Layer 2 remote port mirroring, perform the following tasks:
· Configure a remote source group on the source device.
· Configure a cooperating remote destination group on the destination device.
· If intermediate devices exist, configure the following devices and ports to allow the remote probe VLAN to pass through:
? Intermediate devices.
? Ports connected to the intermediate devices on the source and destinations devices.
When you configure Layer 2 remote port mirroring, follow these restrictions and guidelines:
· For a mirrored packet to successfully arrive at the remote destination device, make sure the VLAN ID of the mirrored packet is not removed or changed.
· Layer 2 remote port mirroring does not support using Layer 2 aggregate interfaces as source ports or monitor ports.
· As a best practice, configure devices in the order of the destination device, the intermediate devices, and the source device.
· On an IRF fabric, mirroring traffic between IRF member devices is not supported.
Layer 2 remote port mirroring configuration task list
Configuring a remote destination group on the destination device
Creating a remote destination group
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a remote destination group. |
mirroring-group group-id remote-destination [ sampler sampler-name ] |
By default, no remote destination group exists on a device. |
Configuring the monitor port for a remote destination group
To configure the monitor port for a mirroring group, use one of the following methods:
· Configure the monitor port for the mirroring group in system view.
When you configure the monitor port for a remote destination group, follow these restrictions and guidelines:
· Do not enable the spanning tree feature on the monitor port.
· Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
· A mirroring group must contain only one monitor port.
? IGMP snooping.
? Spanning tree.
? Static ARP.
Configuring the monitor port for a remote destination group in system view
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the monitor port for the specified remote destination group. |
By default, no monitor port is configured for a remote destination group. |
Configuring the monitor port for a remote destination group in interface view
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the port as the monitor port for the specified remote destination group. |
By default, a port does not act as the monitor port for any remote destination group. |
Configuring the remote probe VLAN for a remote destination group
When you configure the remote probe VLAN for a remote destination group, follow these restrictions and guidelines:
· Only an existing static VLAN can be configured as a remote probe VLAN.
· When a VLAN is configured as a remote probe VLAN, use the remote probe VLAN for port mirroring exclusively.
· Configure the same remote probe VLAN for the remote mirroring groups on the source and destination devices.
To configure the remote probe VLAN for a remote destination group:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the remote probe VLAN for the specified remote destination group. |
mirroring-group group-id remote-probe vlan vlan-id |
By default, no remote probe VLAN is configured for a remote destination group. |
Assigning the monitor port to the remote probe VLAN
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter the interface view of the monitor port. |
N/A |
3. Assign the port to the remote probe VLAN. |
For an access port: ·
For a trunk port: ·
For a hybrid port: |
For more information about the port access vlan, port trunk permit vlan, and port hybrid vlan commands, see Layer 2—LAN Switching Command Reference. |
Configuring a remote source group on the source device
Creating a remote source group
Step |
Command |
Remarks |
system-view |
N/A |
By default, no remote source group exists on a device. |
Configuring source ports for a remote source group
To configure source ports for a mirroring group, use one of the following methods:
· Assign a list of source ports to the mirroring group in system view.
· Assign a port to the mirroring group as a source port in interface view.
When you configure source ports for a remote source group, follow these restrictions and guidelines:
· Do not assign a source port of a mirroring group to the remote probe VLAN of the mirroring group.
· A source port cannot be configured as a reflector port, monitor port, or egress port.
Configuring source ports for a remote source group in system view
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure source ports for the specified remote source group. |
By default, no source port is configured for a remote source group. |
Configuring a source port for a remote source group in interface view
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the port as a source port for the specified remote source group. |
By default, a port does not act as a source port for any remote source group. |
Configuring source CPUs for a remote source group
To configure source CPUs for a remote source group:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure source CPUs for the specified remote source group. |
In standalone mode: ·
In IRF mode: |
By default, no source CPU is configured for a remote source group. |
Configuring the egress port for a remote source group
To configure the egress port for a remote source group, use one of the following tasks:
· Configure the egress port for the remote source group in system view.
· Assign a port to the remote source group as the egress port in interface view.
When you configure the egress port for a remote source group, follow these restrictions and guidelines:
· Disable the following features on the egress port:
? Spanning tree.
? IGMP snooping.
? Static ARP.
· A mirroring group contains only one egress port.
· A port of an existing mirroring group cannot be configured as an egress port.
Configuring the egress port for a remote source group in system view
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the egress port for the specified remote source group. |
mirroring-group group-id monitor-egress interface-type interface-number |
By default, no egress port is configured for a remote source group. |
Configuring the egress port for a remote source group in interface view
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the port as the egress port for the specified remote source group. |
mirroring-group group-id monitor-egress |
By default, a port does not act as the egress port for any remote source group. |
Configuring the remote probe VLAN for a remote source group
When you configure the remote probe VLAN for a remote source group, follow these restrictions and guidelines:
· The remote mirroring groups on the source device and destination device must use the same remote probe VLAN.
To configure the remote probe VLAN for a remote source group:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the remote probe VLAN for the specified remote source group. |
By default, no remote probe VLAN is configured for a remote source group. |
Displaying and maintaining port mirroring
Task |
Command |
Display mirroring group information. |
display mirroring-group { group-id | all | local | remote-destination | remote-source } |
Port mirroring configuration examples
Local port mirroring configuration example (in source port mode)
As shown in Figure 29, configure local port mirroring in source port mode to enable the server to monitor the bidirectional traffic of the Marketing department and the Technical department.
# Create local mirroring group 1.
[Device] mirroring-group 1 local
# Configure FortyGigE 1/0/1 and FortyGigE 1/0/2 as source ports for local mirroring group 1.
[Device] mirroring-group 1 mirroring-port fortygige 1/0/1 fortygige 1/0/2 both
# Configure FortyGigE 1/0/3 as the monitor port for local mirroring group 1.
[Device] mirroring-group 1 monitor-port fortygige 1/0/3
# Disable the spanning tree feature on the monitor port FortyGigE 1/0/3.
[Device] interface fortygige 1/0/3
[Device-FortyGigE1/0/3] undo stp enable
[Device-FortyGigE1/0/3] quit
# Display information about all mirroring groups.
[Device] display mirroring-group all
Mirroring group 1:
Type: Local
Status: Active
Mirroring port:
FortyGigE1/0/1 Both
FortyGigE1/0/2 Both
Monitor port: FortyGigE1/0/3
Local port mirroring configuration example (in source CPU mode)
As shown in Figure 30, FortyGigE 1/0/1 and FortyGigE 1/0/2 are located on the card in slot 1.
Configure local port mirroring in source CPU mode to enable the server to monitor all packets matching the following criteria:
· Received and sent by the Marketing department and the Technical department.
· Processed by the CPU of the card in slot 1 of the device.
# Configure the CPU of the card in slot 1 of the device as a source CPU for local mirroring group 1.
[Device] mirroring-group 1 mirroring-cpu slot 1 both
Mirroring group 1:
Type: Local
Status: Active
Mirroring CPU:
Slot 1 Both
Local port mirroring with multiple monitor ports configuration example
As shown in Figure 31, configure port mirroring to enable all data monitoring devices (Server A, Server B, and Server C) to monitor the bidirectional traffic of the three departments.
# Create remote source group 1.
[DeviceA] mirroring-group 1 remote-source
# Configure FortyGigE 1/0/1 through FortyGigE 1/0/3 as source ports of remote source group 1.
[DeviceA] mirroring-group 1 mirroring-port fortygige 1/0/1 to fortygige 1/0/3 both
# Configure an unused port (FortyGigE 1/0/5, for example) of Device A as the reflector port of remote source group 1.
[DeviceA] mirroring-group 1 reflector-port fortygige 1/0/5
# Create VLAN 10 and assign the FortyGigE 1/0/11 through FortyGigE 1/0/13 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port fortygige 1/0/11 to fortygige 1/0/13
[DeviceA-vlan10] quit
# Configure VLAN 10 as the remote probe VLAN of remote source group 1.
[DeviceA] mirroring-group 1 remote-probe vlan 10
Layer 2 remote port mirroring configuration example
As shown in Figure 32, configure Layer 2 remote port mirroring to enable the server to monitor the outbound traffic from the Marketing department.
1. Configure Device C (the destination device):
# Configure FortyGigE 1/0/1 as a trunk port, and assign the port to VLAN 2.
<DeviceC> system-view
[DeviceC] interface fortygige 1/0/1
[DeviceC-FortyGigE1/0/1] port link-type trunk
[DeviceC-FortyGigE1/0/1] port trunk permit vlan 2
[DeviceC-FortyGigE1/0/1] quit
# Create a remote destination group.
[DeviceC] mirroring-group 2 remote-destination
# Create VLAN 2.
[DeviceC] vlan 2
# Disable MAC address learning for VLAN 2.
[DeviceC-vlan2] undo mac-address mac-learning enable
[DeviceC-vlan2] quit
# Configure VLAN 2 as the remote probe VLAN for the mirroring group.
[DeviceC] mirroring-group 2 remote-probe vlan 2
# Configure FortyGigE 1/0/2 as the monitor port for the mirroring group.
[DeviceC] interface fortygige 1/0/2
[DeviceC-FortyGigE1/0/2] mirroring-group 2 monitor-port
# Disable the spanning tree feature on FortyGigE 1/0/2.
[DeviceC-FortyGigE1/0/2] undo stp enable
# Assign FortyGigE 1/0/2 to VLAN 2.
[DeviceC-FortyGigE1/0/2] port access vlan 2
[DeviceC-FortyGigE1/0/2] quit
2. Configure Device B (the intermediate device):
# Create VLAN 2.
[DeviceB] vlan 2
[DeviceB-vlan2] undo mac-address mac-learning enable
[DeviceB-vlan2] quit
[DeviceB] interface fortygige 1/0/1
[DeviceB-FortyGigE1/0/1] port link-type trunk
[DeviceB-FortyGigE1/0/1] port trunk permit vlan 2
[DeviceB-FortyGigE1/0/1] quit
# Configure FortyGigE 1/0/2 as a trunk port, and assign the port to VLAN 2.
[DeviceB] interface fortygige 1/0/2
[DeviceB-FortyGigE1/0/2] port link-type trunk
[DeviceB-FortyGigE1/0/2] port trunk permit vlan 2
[DeviceB-FortyGigE1/0/2] quit
3. Configure Device A (the source device):
# Create a remote source group.
# Create VLAN 2.
[DeviceA] vlan 2
[DeviceA-vlan2] undo mac-address mac-learning enable
[DeviceA-vlan2] quit
[DeviceA] mirroring-group 1 remote-probe vlan 2
# Configure FortyGigE 1/0/1 as a source port for the mirroring group.
[DeviceA] mirroring-group 1 mirroring-port fortygige 1/0/1 outbound
# Configure FortyGigE 1/0/2 as the egress port for the mirroring group.
[DeviceA] mirroring-group 1 monitor-egress fortygige 1/0/2
[DeviceA] interface fortygige 1/0/2
[DeviceA-FortyGigE1/0/2] port link-type trunk
[DeviceA-FortyGigE1/0/2] port trunk permit vlan 2
[DeviceA-FortyGigE1/0/2] undo stp enable
[DeviceA-FortyGigE1/0/2] quit
# Display information about all mirroring groups on Device C.
[DeviceC] display mirroring-group all
Mirroring group 2:
Type: Remote destination
Status: Active
Monitor port: FortyGigE1/0/2
Remote probe VLAN: 2
# Display information about all mirroring groups on Device A.
[DeviceA] display mirroring-group all
Mirroring group 1:
Type: Remote source
Status: Active
Mirroring port:
FortyGigE1/0/1 Outbound
Configuring flow mirroring
Overview
Flow mirroring copies packets matching a class to a destination for packet analysis and monitoring. It is implemented through QoS policies.
To configure flow mirroring, perform the following tasks:
· Define traffic classes and configure match criteria to classify packets to be mirrored. Flow mirroring allows you to flexibly classify packets to be analyzed by defining match criteria.
· Configure traffic behaviors to mirror the matching packets to the specified destination.
You can configure an action to mirror the matching packets to one of the following destinations:
· Interface—The matching packets are copied to an interface connecting to a data monitoring device. The data monitoring device analyzes the packets received on the interface.
· CPU—The matching packets are copied to the CPU of the card where they are received, The CPU analyzes the packets or deliver the packets to upper layers.
For more information about QoS policies, traffic classes, and traffic behaviors, see ACL and QoS Configuration Guide.
Flow mirroring configuration task list
Tasks at a glance |
(Required.) Configuring match criteria |
(Required.) Configuring a traffic behavior |
(Required.) Configuring a QoS policy |
(Required.) Applying a QoS policy: · Applying a QoS policy to an interface |
For more information about the following commands except the mirror-to command, see ACL and QoS Command Reference.
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a class and enter class view. |
traffic classifier tcl-name [ operator { and | or } ] |
By default, no traffic class exists. |
3. Configure match criteria. |
if-match match-criteria |
By default, no match criterion is configured in a traffic class. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a QoS policy and enter QoS policy view. |
qos policy policy-name |
By default, no QoS policy exists. |
3. Associate a class with a traffic behavior in the QoS policy. |
classifier tcl-name behavior behavior-name |
By default, no traffic behavior is associated with a class. |
4. (Optional.) Display QoS policy configuration. |
display qos policy |
Available in any view. |
By applying a QoS policy to an interface, you can mirror the traffic in the specified direction of the interface. A policy can be applied to multiple interfaces. In one direction (inbound or outbound) of an interface, only one policy can be applied.
To apply a QoS policy to an interface:
Step |
Command |
system-view |
3. Apply a policy to the interface. |
qos apply policy policy-name { inbound | outbound } |
Applying a QoS policy to a VLAN
You can apply a QoS policy to a VLAN to mirror the traffic in the specified direction on all ports in the VLAN.
To apply the QoS policy to a VLAN:
Step |
Command |
system-view |
2. Apply a QoS policy to a VLAN. |
qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound } |
Applying a QoS policy globally
You can apply a QoS policy globally to mirror the traffic in the specified direction on all ports.
To apply a QoS policy globally:
Step |
Command |
system-view |
2. Apply a QoS policy globally. |
qos apply policy policy-name global { inbound | outbound } |
Flow mirroring configuration example
As shown in Figure 33, different departments use IP addresses on different subnets.
Configure flow mirroring so that the server can monitor the following traffic:
· Traffic that the Technical department sends to access the Internet.
· IP traffic that the Technical department sends to the Marketing department during working hours (8:00 to 18:00) on weekdays.
Configuration procedure
# Create a working hour range work, in which the working hour is from 8:00 to 18:00 on weekdays.
[DeviceA] time-range work 8:00 to 18:00 working-day
# Create ACL 3000 to allow packets from the Technical department to access the Internet and to the Marketing department during working hours.
[DeviceA] acl number 3000
[DeviceA-acl-adv-3000] rule permit tcp source 192.168.2.0 0.0.0.255 destination-port eq www
[DeviceA-acl-adv-3000] rule permit ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255 time-range work
[DeviceA-acl-adv-3000] quit
# Create traffic class tech_c, and configure the match criterion as ACL 3000.
[DeviceA] traffic classifier tech_c
[DeviceA-classifier-tech_c] if-match acl 3000
[DeviceA-classifier-tech_c] quit
# Create traffic behavior tech_b, configure the action of mirroring traffic to port FortyGigE 1/0/3.
[DeviceA] traffic behavior tech_b
[DeviceA-behavior-tech_b] mirror-to interface fortygige 1/0/3
[DeviceA-behavior-tech_b] quit
# Create QoS policy tech_p, and associate traffic class tech_c with traffic behavior tech_b in the QoS policy.
[DeviceA] qos policy tech_p
[DeviceA-qospolicy-tech_p] classifier tech_c behavior tech_b
[DeviceA-qospolicy-tech_p] quit
# Apply QoS policy tech_p to the incoming packets of FortyGigE 1/0/4.
[DeviceA] interface fortygige 1/0/4
[DeviceA-FortyGigE1/0/4] qos apply policy tech_p inbound
[DeviceA-FortyGigE1/0/4] quit
# Verify that you can monitor the following traffic through the server:
· All traffic sent by the Technical department to access the Internet.
· IP traffic that the Technical department sends to the Marketing department during working hours on weekdays.
Configuring sFlow
Sampled Flow (sFlow) is a traffic monitoring technology.
As shown in Figure 34, the sFlow system involves an sFlow agent embedded in a device and a remote sFlow collector. The sFlow agent collects interface counter information and packet information and encapsulates the sampled information in sFlow packets. When the sFlow packet buffer is full, or the aging timer (fixed to 1 second) of sFlow packets expires, the sFlow agent sends the sFlow packets in UDP datagrams to the specified sFlow collector. The sFlow collector analyzes the information and displays the results.
sFlow provides the following sampling mechanisms:
· Flow sampling—Obtains packet information.
· Counter sampling—Obtains interface counter information.
Figure 34 sFlow system
As a traffic monitoring technology, sFlow has the following advantages:
· Supports traffic monitoring on Gigabit and higher-speed networks.
· Provides good scalability to allow one sFlow collector to monitor multiple sFlow agents.
· Saves money by embedding the sFlow agent in a device, instead of using a dedicated sFlow agent device.
Protocols and standards
· RFC 3176, InMon Corporation's sFlow: A Method for Monitoring Traffic in Switched and Routed Networks
· sFlow.org, sFlow Version 5
sFlow configuration task list
Tasks at a glance |
(Required.) Configuring the sFlow agent and sFlow collector information |
Step |
Command |
Remarks |
system-view |
N/A |
2. (Optional.) Configure an IP address for the sFlow agent. |
sflow agent ip ip-address |
By default, no IP address is configured for the sFlow agent. The device periodically checks whether the sFlow agent has an IP address. If not, the device automatically selects an IPv4 address for the sFlow agent but does not save the IPv4 address in the configuration file. NOTE: · As a best practice, manually configure an IP address for the sFlow agent. · Only one IP address can be configured for the sFlow agent on the device, and a newly configured IP address overwrites the existing one. |
3. Configure the sFlow collector information. |
sflow collector collector-id [ vpn-instance vpn-instance-name ] ip ip-address [ port port-number | datagram-size size | time-out seconds | description text ] * |
By default, no sFlow collector information is configured. |
4. (Optional.) Specify the source IP address of sFlow packets. |
sflow source ip ip-address |
By default, the source IP address is determined by routing. |
Configuring flow sampling
Perform this task to configure flow sampling on an Ethernet interface. The sFlow agent samples packets on that interface according to the configured parameters, encapsulates them into sFlow packets, and sends them in UDP packets to the specified sFlow collector.
To configure flow sampling:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter Ethernet interface view. |
N/A |
3. (Optional.) Set the flow sampling mode. |
sflow sampling-mode { determine | random } |
The default setting is random. The switch does not support the determine mode. |
4. Enable flow sampling and specify the number of packets out of which flow sampling samples a packet on the interface. |
sflow sampling-rate rate |
By default, flow sampling samples no packet. |
5. (Optional.) Set the maximum number of bytes of a packet (starting from the packet header) that flow sampling can copy. |
sflow flow max-header length |
The default setting is 128 bytes. |
6. Specify the sFlow collector for flow sampling. |
sflow flow collector collector-id |
By default, no sFlow collector is specified for flow sampling. |
Configuring counter sampling
Perform this task to configure counter sampling on an Ethernet interface. The sFlow agent periodically collects the counter information on that interface, encapsulates the information into sFlow packets, and sends them in UDP packets to the specified sFlow collector.
To configure counter sampling:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable counter sampling and set the counter sampling interval. |
sflow counter interval interval-time |
By default, counter sampling is disabled. |
4. Specify the sFlow collector for counter sampling. |
sflow counter collector collector-id |
By default, no sFlow collector is specified for counter sampling. |
Displaying and maintaining sFlow
Task |
Command |
Display sFlow configuration. |
display sflow |
sFlow configuration example
Network requirements
As shown in Figure 35, perform the following tasks:
· Configure flow sampling in random mode and counter sampling on FortyGigE 1/0/1 of the device to monitor traffic on the port.
· Configure the device to send sampled information in sFlow packets through FortyGigE 1/0/3 to the sFlow collector.
1. Configure the IP addresses and subnet masks for interfaces, as shown in Figure 35. (Details not shown.)
2. Configure the sFlow agent and configure information about the sFlow collector:
# Configure the IP address for the sFlow agent.
[Sysname] sflow agent ip 3.3.3.1
# Configure information about the sFlow collector: specify the sFlow collector ID as 1, IP address as 3.3.3.2, port number as 6343 (default), and description as netserver.
[Sysname] sflow collector 1 ip 3.3.3.2 description netserver
3. Configure counter sampling:
# Enable counter sampling and set the counter sampling interval to 120 seconds on FortyGigE 1/0/1.
[Sysname] interface fortygige 1/0/1
[Sysname-FortyGigE1/0/1] sflow counter interval 120
# Specify sFlow collector 1 for counter sampling.
[Sysname-FortyGigE1/0/1] sflow counter collector 1
4. Configure flow sampling:
# Enable flow sampling and set the flow sampling mode to random and sampling interval to 4000.
[Sysname-FortyGigE1/0/1] sflow sampling-mode random
[Sysname-FortyGigE1/0/1] sflow sampling-rate 4000
# Specify sFlow collector 1 for flow sampling.
[Sysname-FortyGigE1/0/1] sflow flow collector 1
# Verify that FortyGigE 1/0/1 enabled with sFlow is active, and sFlow is operating correctly.
[Sysname-FortyGigE1/0/1] display sflow
sFlow datagram version: 5
Global information:
Agent IP: 3.3.3.1(CLI)
Source address:
Collector information:
ID IP Port Aging Size VPN-instance Description
1 3.3.3.2 6343 N/A 1400 netserver
Port information:
Interface CID Interval(s) FID MaxHLen Rate Mode Status
FGE1/1 1 120 1 128 4000 Random Active
Troubleshooting sFlow configuration
The remote sFlow collector cannot receive sFlow packets
Symptom
The remote sFlow collector cannot receive sFlow packets.
Analysis
The possible reasons include:
· The sFlow collector is not specified.
· sFlow is not configured on the interface.
· The IP address of the sFlow collector specified on the sFlow agent is different from that of the remote sFlow collector.
· No IP address is configured for the Layer 3 interface that sends sFlow packets,
· An IP address is configured for the Layer 3 interface that sends sFlow packets. However, the UDP datagrams with this source IP address cannot reach the sFlow collector.
· The physical link between the device and the sFlow collector fails.
· The length of an sFlow packet is less than the sum of the following two values:
? The length of the sFlow packet header.
? The number of bytes that flow sampling can copy per packet.
· The sFlow collector is bound to a non-existent VPN.
Solution
To resolve the problem:
1. Verify that sFlow is correctly configured by using the display sflow command.
2. Verify that a correct IP address is configured for the device to communicate with the sFlow collector.
3. Verify that the physical link between the device and the sFlow collector is up.
4. Verify that the length of an sFlow packet is greater than the sum of the following two values:
? The number of bytes (as a best practice, use the default) that flow sampling can copy per packet.
5. Verify that the VPN bound to the sFlow collector already exists.
Configuring EAA
Overview
Embedded Automation Architecture (EAA) is a monitoring framework that enables you to self-define monitored events and actions to take in response to an event. It allows you to create monitor policies by using the CLI or Tcl scripts.
EAA framework
EAA framework includes a set of event sources, a set of event monitors, a real-time event manager (RTM), and a set of user-defined monitor policies, as shown in Figure 36.
Figure 36 EAA framework
Event sources
Event sources are software or hardware modules that trigger events (see Figure 36).
For example, the CLI module triggers an event when you enter a command. The Syslog module (the information center) triggers an event when it receives a log message.
Event monitors
EAA creates one event monitor to monitor the system for the event specified in each monitor policy. An event monitor notifies the RTM to run the monitor policy when the monitored event occurs.
RTM
RTM manages the creation, state machine, and execution of monitor policies.
EAA monitor policies
A monitor policy specifies the event to monitor and actions to take when the event occurs.
You can configure EAA monitor policies by using the CLI or Tcl.
A monitor policy contains the following elements:
· One event.
· A minimum of one action.
· A minimum of one user role.
· One running time setting.
For more information about these elements, see "Elements in a monitor policy."
Event
Table 16 shows types of events that EAA can monitor.
Event type |
CLI |
CLI event occurs in response to monitored operations performed at the CLI. For example, a command is entered, a question mark (?) is entered, or the Tab key is pressed to complete a command. |
Syslog |
Syslog event occurs when the information center receives the monitored log within a specific period. NOTE: The log that is generated by the EAA RTM does not trigger the monitor policy to run. |
Process |
Process event occurs in response to a state change of the monitored process (such as an exception, shutdown, start, or restart). Both manual and automatic state changes can cause the event to occur. |
Hotplug |
Hotplug event occurs when the monitored card is inserted or removed while the device is operating. |
Each interface event is associated with two user-defined thresholds: start and restart. An interface event occurs when the monitored interface traffic statistic crosses the start threshold in the following situations: · The statistic crosses the start threshold for the first time. · The statistic crosses the start threshold each time after it crosses the restart threshold. |
SNMP |
Each SNMP event is associated with two user-defined thresholds: start and restart. SNMP event occurs when the monitored MIB variable's value crosses the start threshold in the following situations: · The monitored variable's value crosses the start threshold for the first time. · The monitored variable's value crosses the start threshold each time after it crosses the restart threshold. |
SNMP-Notification |
SNMP-Notification event occurs when the monitored MIB variable's value in an SNMP notification matches the specified condition. For example, the broadcast traffic rate on an Ethernet interface reaches or exceeds 30%. |
Track |
Track event occurs when the state of the track entry changes from positive to negative. If you specify multiple track entries for a policy, EAA triggers the policy only when the state of all the track entries changes from positive to negative. If you set a suppress time for a policy, the timer starts when the policy is triggered. The system does not process the messages that report the track entry positive-to-negative state change until the timer times out. |
Action
You can create a series of order-dependent actions to take in response to the event specified in the monitor policy.
The following are available actions:
· Executing a command.
· Sending a log.
· Enabling an active/standby switchover.
· Executing a reboot without saving the running configuration.
User role
For EAA to execute an action in a monitor policy, you must assign the policy the user role that has access to the action-specific commands and resources. If EAA lacks access to an action-specific command or resource, EAA does not perform the action and all the subsequent actions.
For example, a monitor policy has four actions numbered from 1 to 4. The policy has user roles that are required for performing actions 1, 3, and 4. However, it does not have the user role required for performing action 2. When the policy is triggered, EAA executes only action 1.
For more information about user roles, see RBAC in Fundamentals Configuration Guide.
Runtime
Policy runtime limits the amount of time that the monitor policy can run from the time it is triggered. This setting prevents system resources from being occupied by incorrectly defined policies.
EAA environment variables
EAA environment variables decouple the configuration of action arguments from the monitor policy so you can modify a policy easily.
An EAA environment variable is defined as a <variable_name variable_value> pair and can be used in different policies. When you define an action, you can enter a variable name with a leading dollar sign ($variable_name). EAA will replace the variable name with the variable value when it performs the action.
To change the value for an action argument, modify the value specified in the variable pair instead of editing each affected monitor policy.
EAA environment variables include system-defined variables and user-defined variables.
System-defined variables
System-defined variables are provided by default, and they cannot be created, deleted, or modified by users. System-defined variable names start with an underscore (_) sign. The variable values are set automatically depending on the event setting in the policy that uses the variables.
System-defined variables include the following types:
· Public variable—Available for any events.
· Event-specific variable—Available only for a type of event.
Table 17 shows all system-defined variables.
Table 17 System-defined EAA environment variables by event type
Variable name |
Any event: |
_event_id |
Event ID. |
_event_type |
Event type. |
_event_type_string |
Event type description. |
_event_time |
Time when the event occurs. |
_event_severity |
Severity level of an event. |
CLI: |
_cmd |
Commands that are matched. |
Syslog: |
_syslog_pattern |
Log message content. |
Hotplug: |
_slot |
ID of the slot where a hot swap event occurs. |
Interface: |
_ifname |
Interface name. |
SNMP: |
_oid |
OID of the MIB variable where an SNMP operation is performed. |
_oid_value |
Value of the MIB variable. |
SNMP-Notification: |
_oid |
OID that is included in the SNMP notification. |
Process: |
_process_name |
Process name. |
User-defined variables
You can use user-defined variables for all types of events.
User-defined variable names can contain digits, characters, and the underscore sign (_), except that the underscore sign cannot be the leading character.
Feature and software version compatibility
The EAA feature is available in Release 1138P01 and later versions.
Configuring a user-defined EAA environment variable
Configure a user-defined EAA environment variable before you use it in an action.
To configure a user-defined EAA environment variable:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Configure a user-defined EAA environment variable. |
rtm environment var-name var-value |
By default, no user-defined environment variables exist. The system provides the system-defined variables in Table 17. |
Configuring a monitor policy
You can configure a monitor policy by using the CLI or Tcl.
When you configure monitor policies, follow these restrictions and guidelines:
· Make sure the actions in different policies do not conflict. Policy execution result will be unpredictable if policies that conflict in actions are running concurrently.
· You can assign the same policy name to a CLI-defined policy and a Tcl-defined policy. However, you cannot assign the same name to policies that are the same type.
· The system executes the actions in a policy in ascending order of action IDs. When you add actions to a policy, you must make sure the execution order is correct.
Configuring a monitor policy from the CLI
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter CLI-defined policy view. |
rtm cli-policy policy-name |
If the policy does not exist, this command creates the policy first. |
3. Configure an event in the policy. |
Configure a CLI event: ·
Configure a hotplug event in standalone mode: ·
Configure a hotplug event in IRF mode: ·
Configure an interface event: ·
Configure a process event in standalone mode: ·
Configure a process event in IRF mode: ·
Configure an SNMP event: ·
Configure an SNMP-Notification event: ·
Configure a Syslog event: ·
Configure a track event: |
By default, a monitor policy does not contain an event. You can configure only one event in a monitor policy. If the monitor policy already contains an event, the new event overrides the old event. |
4. Configure the actions to take when the event occurs. |
Configure the action to execute a command: ·
Configure a reboot action in standalone mode: ·
Configure a reboot action in IRF mode: ·
Configure a logging action: ·
Configure an active/standby switchover
action: |
By default, a monitor policy does not contain any actions. Repeat this step to add a maximum of 232 actions to the policy. When you define an action, you can specify a value or specify a variable name in $variable_name format for an argument. |
5. (Optional.) Assign a user role to the policy. |
user-role role-name |
By default, a monitor policy contains user roles that its creator had at the time of policy creation. A monitor policy supports a maximum of 64 valid user roles. User roles added after this limit is reached do not take effect. |
6. (Optional.) Configure the policy runtime. |
running-time time |
The default runtime is 20 seconds. |
7. Enable the policy. |
commit |
By default, CLI-defined policies are not enabled. A CLI-defined policy can take effect only after you perform this step. |
Configuring a monitor policy by using Tcl
Step |
Command |
Remarks |
1. Edit a Tcl script file (see Table 18). |
N/A |
The supported Tcl version is 8.5.8. |
2. Download the file to the device by using FTP or TFTP. |
N/A |
For more information about using FTP and TFTP, see Fundamentals Configuration Guide. |
3. Enter system view. |
system-view |
N/A |
4. Create a Tcl-defined policy and bind it to the Tcl script file. |
rtm tcl-policy policy-name tcl-filename |
By default, no Tcl policies exist. Make sure the script file is saved on all MPUs. This practice ensures that the policy can run correctly after an active/standby or master/standby switchover occurs or the MPU where the script file resides fails or is removed. This step enables the Tcl-defined policy. To revise the Tcl script of a policy, you must suspend all monitor policies first, and then resume the policies after you finish revising the script. The system cannot execute a Tcl-defined policy if you edit its Tcl script without suspending policies. |
Write a Tcl script in two lines for a monitor policy, as shown in Table 18.
Table 18 Tcl script requirements
Line |
Content |
Requirements |
Line 1 |
Event, user roles, and policy runtime |
This line must use the following format: ::comware::rtm::event_register eventname arg1 arg2 arg3 …user-role role-name1 | [ user-role role-name2 | [ ] ][ running-time running-time ] The arg1 arg2 arg3 … arguments represent event matching rules. If an argument value contains spaces, use double quotation marks ("") to enclose the value. For example, "a b c." |
Line 2 |
Actions |
When you define an action, you can specify a value or specify a variable name in $variable_name format for an argument. The following actions are available: · Standard Tcl commands. · EAA-specific Tcl commands. · Commands supported by the device. |
Suspending monitor policies
This task suspends all CLI-defined and Tcl-defined monitor policies except for the policies that are running.
To suspend monitor policies:
Step |
Command |
Remarks |
system-view |
N/A |
2. Suspend monitor policies. |
rtm scheduler suspend |
To resume monitor polices, use the undo rtm scheduler suspend command. |
Displaying and maintaining EAA settings
Execute display commands except for the display this command in any view.
Task |
Command |
Display user-defined EAA environment variables. |
display rtm environment [ var-name ] |
Display EAA monitor policies. |
display rtm policy { active | registered [ verbose ] } [ policy-name ] |
Display the running configuration of all CLI-defined monitor policies. |
display current-configuration |
Display the running configuration of a CLI-defined monitor policy in CLI-defined monitor policy view. |
display this |
EAA configuration examples
CLI event monitor policy configuration example
Configure a policy from the CLI to monitor the event that occurs when a question mark (?) is entered at the command line that contains letters and digits.
When the event occurs, the system executes the command and sends the log message "hello world" to the information center.
# Create CLI-defined policy test and enter its view.
[Sysname] rtm cli-policy test
# Add a CLI event that occurs when a question mark (?) is entered at any command line that contains letters and digits.
[Sysname-rtm-test] event cli async mode help pattern [a-zA-Z0-9]
# Add an action that sends the message "hello world" with a priority of 4 from the logging facility local3 when the event occurs.
[Sysname-rtm-test] action 0 syslog priority 4 facility local3 msg “hello world”
# Add an action that enters system view when the event occurs.
[Sysname-rtm-test] action 2 cli system-view
# Add an action that creates VLAN 2 when the event occurs.
[Sysname-rtm-test] action 3 cli vlan 2
# Set the policy runtime to 2000 seconds. The system stops executing the policy and displays an execution failure message if it fails to complete policy execution within 2000 seconds.
[Sysname-rtm-test] running-time 2000
# Specify the network-admin user role for executing the policy.
# Enable the policy.
[Sysname-rtm-test] commit
# Display information about the policy.
[Sysname-rtm-test] display rtm policy registered
Total number: 1
Type Event TimeRegistered PolicyName
CLI CLI Aug 29 14:56:50 2013 test
# Enable the information center to output log messages to the current monitoring terminal.
[Sysname-rtm-test] return
<Sysname> terminal monitor
# Enter a question mark (?) at a command line that contains a letter d. Verify that the system displays the "hello world" message and a policy successfully executed message on the terminal screen.
<Sysname> d?
debugging
delete
diagnostic-logfile
dir
display
<Sysname>d%May 7 02:10:03:218 2013 Sysname RTM/4/RTM_ACTION: "hello world"
%May 7 02:10:04:176 2013 Sysname RTM/6/RTM_POLICY: CLI policy test is running successfully.
Track event monitor policy configuration example
As shown in Figure 37, Device A has established BGP sessions with Device D and Device E. Traffic from Device D and Device E to the Internet is forwarded through Device A.
Configure a CLI-defined EAA monitor policy on Device A to disconnect the sessions with Device D and Device E when FortyGigE 1/0/1 connected to Device C is down. In this way, traffic from Device D and Device E to the Internet can be forwarded through Device B.
Configuration procedures
# Display BGP peer information for Device A.
<Sysname> display bgp peer ipv4
BGP local router ID: 1.1.1.1
Local AS number: 100
Total number of peers: 3 Peers in established state: 3
* - Dynamically created peer
10.2.1.2 200 13 16 0 0 00:16:12 Established
10.3.1.2 300 13 16 0 0 00:10:34 Established
10.3.2.2 300 13 16 0 0 00:10:38 Established
# Create track entry 1 and associate it with the link state of FortyGigE 1/0/1.
[Sysname] track 1 interface fortygige 1/0/1
# Configure a CLI-defined EAA monitor policy so that the system automatically disables session establishment with Device D and Device E when FortyGigE 1/0/1 is down.
[Sysname-rtm-test] event track 1 state negative
[Sysname-rtm-test] action 0 cli system-view
[Sysname-rtm-test] action 1 cli bgp 100
[Sysname-rtm-test] action 2 cli peer 10.3.1.2 ignore
[Sysname-rtm-test] action 3 cli peer 10.3.2.2 ignore
[Sysname-rtm-test] quit
# Shut down FortyGigE 1/0/1.
[H3C-FortyGigE1/0/1] shutdown
# Display BGP peer information.
Total number of peers: 0 Peers in established state: 0
The command output shows that Device A does not have any BGP peers.
CLI-defined policy with EAA environment variables configuration example
Define an environment variable to match the IP address 1.1.1.1.
Configure a policy from the CLI to monitor the event that occurs when a command line that contains loopback0 is executed. In the policy, use the environment variable for IP address assignment.
When the event occurs, the system performs the following tasks:
· Creates the Loopback 0 interface.
· Assigns 1.1.1.1/24 to the interface.
· Sends the matching command line to the information center.
# Configure an EAA environment variable for IP address assignment. The variable name is loopback0IP, and the variable value is 1.1.1.1.
[Sysname] rtm environment loopback0IP 1.1.1.1
# Create the CLI-defined policy test and enter its view.
# Add a CLI event that occurs when a command line that contains loopback0 is executed.
[Sysname-rtm-test] event cli async mode execute pattern loopback0
# Add an action that creates the interface Loopback 0 and enters loopback interface view.
[Sysname-rtm-test] action 1 cli interface loopback 0
# Add an action that assigns the IP address 1.1.1.1 to Loopback 0. The loopback0IP variable is used in the action for IP address assignment.
[Sysname-rtm-test] action 2 cli ip address $loopback0IP 24
# Add an action that sends the matching loopback0 command with a priority of 0 from the logging facility local7 when the event occurs.
[Sysname-rtm-test] action 3 syslog priority 0 facility local7 msg $_cmd
<Sysname>
# Execute the loopback0 command. Verify that the system displays the loopback0 message and a policy successfully executed message on the terminal screen.
<Sysname> loopback0
<Sysname>
%Jan 3 09:46:10:592 2014 Sysname RTM/0/RTM_ACTION: -MDC=1; loopback0
%Jan 3 09:46:10:613 2014 Sysname RTM/6/RTM_POLICY: -MDC=1; CLI policy test is running successfully.
# Verify that Loopback 0 has been created and assigned the IP address 1.1.1.1.
<Sysname> display interface loopback brief
Protocol: (s) - spoofing
Loop0 UP UP(s) 1.1.1.1
<Sysname>
Tcl-defined policy configuration example
As shown in Figure 38, use Tcl to create a monitor policy on the Device. This policy must meet the following requirements:
· EAA sends the log message "rtm_tcl_test is running" when a command that contains the display this string is entered.
· The system executes the command only after it executes the policy successfully.
# Edit a Tcl script file (rtm_tcl_test.tcl, in this example) for EAA to send the message "rtm_tcl_test is running" when a command that contains the display this string is executed.
::comware::rtm::event_register cli sync mode execute pattern display this user-role network-admin
::comware::rtm::action syslog priority 1 facility local4 msg rtm_tcl_test is running
# Download the Tcl script file from the TFTP server at 1.2.1.1.
<Sysname> tftp 1.2.1.1 get rtm_tcl_test.tcl
# Create Tcl-defined policy test and bind it to the Tcl script file.
[Sysname] rtm tcl-policy test rtm_tcl_test.tcl
[Sysname] quit
Total number: 1
TCL CLI Aug 29 14:54:50 2013 test
# Execute the display this command. Verify that the system displays the rtm_tcl_test is running message and a message that the policy is being successfully executed.
<Sysname> display this
return
<Sysname>%Jun 4 15:02:30:354 2013 Sysname RTM/1/RTM_ACTION: -MDC=1; rtm_tcl_test is running
%Jun 4 15:02:30:382 2013 Sysname RTM/6/RTM_POLICY: -MDC=1; TCL policy test is running successfully.
Configuring NQA
Overview
Network quality analyzer (NQA) allows you to measure network performance, verify the service levels for IP services and applications, and troubleshoot network problems. It provides the following types of operations:
· ICMP echo.
· ICMP jitter.
· DHCP.
· DLSw.
· DNS.
· FTP.
· HTTP.
· Path jitter.
· SNMP.
· TCP.
· UDP echo.
· UDP jitter.
· UDP tracert.
· Voice.
As shown in Figure 39, the NQA source device (NQA client) sends data to the NQA destination device by simulating IP services and applications to measure network performance. The obtained performance metrics include the one-way latency, jitter, packet loss, voice quality, application performance, and server response time.
All types of NQA operations require the NQA client, but only the TCP, UDP echo, UDP jitter, and voice operations require the NQA server. The NQA operations for services that are already provided by the destination device such as FTP do not need the NQA server.
You can configure the NQA server to listen and respond to specific IP addresses and ports to meet various test needs.
NQA operation
The following describes how NQA performs different types of operations:
· A TCP or DLSw operation sets up a connection.
· An ICMP jitter, UDP jitter, or voice operation sends a number of probe packets. The number of probe packets is set by using the probe packet-number command.
· An FTP operation uploads or downloads a file.
· An HTTP operation gets a Web page.
· A DHCP operation gets an IP address through DHCP.
· A DNS operation translates a domain name to an IP address.
· An ICMP echo operation sends an ICMP echo request.
· A UDP echo operation sends a UDP packet.
· An SNMP operation sends one SNMPv1 packet, one SNMPv2c packet, and one SNMPv3 packet.
· A path jitter operation is accomplished in the following steps:
a. The operation uses tracert to obtain the path from the NQA client to the destination. A maximum of 64 hops can be detected.
b. The NQA client sends ICMP echo requests to each hop along the path. The number of ICMP echo requests is set by using the probe packet-number command.
· A UDP tracert operation determines the routing path from the source to the destination. The number of the probe packets sent to each hop is set by using the probe count command.
Collaboration
NQA can collaborate with the Track module to notify application modules of state or performance changes so that the application modules can take predefined actions.
The following describes how a static route destined for 192.168.0.88 is monitored through collaboration:
1. NQA monitors the reachability to 192.168.0.88.
2. When 192.168.0.88 becomes unreachable, NQA notifies the Track module of the change.
3. The Track module notifies the static routing module of the state change.
4. The static routing module sets the static route to invalid according to a predefined action.
For more information about collaboration, see High Availability Configuration Guide.
Threshold monitoring
Threshold monitoring enables the NQA client to take a predefined action when the NQA operation performance metrics violate the specified thresholds.
Table 19 describes the relationships between performance metrics and NQA operation types.
Table 19 Performance metrics and NQA operation types
Performance metric |
NQA operation types that can gather the metric |
Probe duration |
All NQA operation types except UDP jitter, UDP tracert, path jitter, and voice |
Number of probe failures |
Round-trip time |
ICMP jitter, UDP jitter, and voice |
Number of discarded packets |
One-way jitter (source-to-destination or destination-to-source) |
One-way delay (source-to-destination or destination-to-source) |
Calculated Planning Impairment Factor (ICPIF) (see "Configuring the voice operation") |
Voice |
Mean Opinion Scores (MOS) (see "Configuring the voice operation") |
Voice |
NQA configuration task list
Tasks at a glance |
Remarks |
Required for TCP, UDP echo, UDP jitter, and voice operations. |
(Required.) Enabling the NQA client |
N/A |
When you configure an NQA template to analyze network performance, the feature that uses the template performs the NQA operation. |
Configuring the NQA server
To perform TCP, UDP echo, UDP jitter, and voice operations, you must enable the NQA server on the destination device. The NQA server listens and responds to requests on the specified IP addresses and ports.
You can configure multiple TCP or UDP listening services on an NQA server, where each corresponds to a specific IP address and port number. The IP address and port number for a listening service must be unique on the NQA server and match the configuration on the NQA client.
To configure the NQA server:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the NQA server. |
nqa server enable |
By default, the NQA server is disabled. |
3. Configure a TCP or UDP listening service. |
TCP listening service: ·
UDP listening service: |
The default ToS value is 0. You can set the ToS value in the IP header of reply packets sent by the NQA server. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the NQA client. |
nqa agent enable |
By default, the NQA client is enabled. The NQA client configuration takes effect after you enable the NQA client. |
Configuring NQA operations on the NQA client
NQA operation configuration task list
Tasks at a glance |
(Required.) Perform at least one of the following tasks: · Configuring the ICMP echo operation · Configuring the ICMP jitter operation · Configuring the DHCP operation · Configuring the DNS operation · Configuring the FTP operation · Configuring the HTTP operation · Configuring the UDP jitter operation · Configuring the SNMP operation · Configuring the TCP operation · Configuring the UDP echo operation · Configuring the UDP tracert operation · Configuring the voice operation |
(Optional.) Configuring optional parameters for the NQA operation |
(Optional.) Configuring the collaboration feature |
(Optional.) Configuring threshold monitoring |
(Optional.) Configuring the NQA statistics collection feature |
(Optional.) Configuring the saving of NQA history records |
(Required.) Scheduling the NQA operation on the NQA client |
The ICMP echo operation measures the reachability of a destination device. It has the same function as the ping command, but provides more output information. In addition, if multiple paths exist between the source and destination devices, you can specify the next hop for the ICMP echo operation.
To configure the ICMP echo operation:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create an NQA operation and enter NQA operation view. |
nqa entry admin-name operation-tag |
By default, no NQA operations exist. |
3. Specify the ICMP echo type and enter its view. |
type icmp-echo |
N/A |
4. Specify the destination IP address for ICMP echo requests. |
destination ip ip-address |
By default, no destination IP address is specified. |
5. (Optional.) Set the payload size for each ICMP echo request. |
data-size size |
The default setting is 100 bytes. |
6. (Optional.) Specify the payload fill string for ICMP echo requests. |
data-fill string |
The default payload fill string is the hexadecimal string 00010203040506070809. |
7. (Optional.) Specify the output interface for ICMP echo requests. |
out interface interface-type interface-number |
By default, the output interface for ICMP echo requests is not specified. The NQA client determines the output interface based on the routing table lookup. |
8. (Optional.) Specify the source IP address for ICMP echo requests. |
Use the IP address of the specified interface
as the source IP address: ·
Specify the source IP address: |
By default, the requests take the primary IP address of the output interface as their source IP address. If you execute the source interface and source ip commands multiple times, the most recent configuration takes effect. The specified source interface must be up. The specified source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no probe packets can be sent out. |
9. (Optional.) Specify the next hop IP address for ICMP echo requests. |
next-hop ip ip-address |
By default, no next hop IP address is configured. |
IMPORTANT: This feature is available in Release 1138P01 and later versions. |
The ICMP jitter operation measures unidirectional and bidirectional jitters. The operation result helps you to determine whether the network can carry jitter-sensitive services such as real-time voice and video services.
The ICMP jitter operation works as follows:
1. The NQA client sends ICMP packets to the destination device.
2. The destination device time stamps each packet it receives, and then sends the packet back to the NQA client.
3. Upon receiving the responses, the NQA client calculates the jitter according to the timestamps.
To configure the ICMP jitter operation:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify the ICMP jitter type and enter its view. |
type icmp-jitter |
N/A |
4. Specify the destination address of ICMP packets. |
5. (Optional.) Set the number of ICMP packets sent in one ICMP jitter operation. |
probe packet-number packet-number |
The default setting is 10. |
6. (Optional.) Set the interval for sending ICMP packets. |
probe packet-interval interval |
The default setting is 20 milliseconds. |
7. (Optional.) Specify how long the NQA client waits for a response from the server before it regards the response times out. |
probe packet-timeout timeout |
The default setting is 3000 milliseconds. |
8. (Optional.) Specify the source IP address for ICMP packets. |
By default, the packets take the primary IP address of the output interface as their source IP address. The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no ICMP packets can be sent out. |
NOTE: Use the display nqa result or display nqa statistics command to verify the ICMP jitter operation. The display nqa history command does not display the ICMP jitter operation results or statistics. |
The DHCP operation measures whether or not the DHCP server can respond to client requests. DHCP also measures the amount of time it takes the NQA client to obtain an IP address from a DHCP server.
The NQA client simulates the DHCP relay agent to forward DHCP requests for IP address acquisition from the DHCP server. The interface that performs the DHCP operation does not change its IP address. When the DHCP operation completes, the NQA client sends a packet to release the obtained IP address.
To configure the DHCP operation:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify the DHCP type and enter its view. |
type dhcp |
N/A |
4. Specify the IP address of the DHCP server as the destination IP address of DHCP packets. |
5. (Optional.) Specify an output interface for DHCP request packets. |
By default, the output interface for DHCP request packets is not specified. The NQA client determines the output interface based on the routing table lookup. |
6. (Optional.) Specify the source IP address of DHCP request packets. |
By default, the packets take the primary IP address of the output interface as their source IP address. The specified source IP address must be the IP address of a local interface, and the local interface must be up. Otherwise, no probe packets can be sent out. The NQA client adds the source IP address to the giaddr field in DHCP requests to be sent to the DHCP server. For more information about the giaddr field, see Layer 3—IP Services Configuration Guide. |
The DNS operation measures the time for the NQA client to translate a domain name into an IP address through a DNS server.
A DNS operation simulates domain name resolution and does not save the obtained DNS entry.
To configure the DNS operation:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify the DNS type and enter its view. |
type dns |
N/A |
4. Specify the IP address of the DNS server as the destination address of DNS packets. |
5. Specify the domain name to be translated. |
resolve-target domain-name |
By default, no domain name is specified. |
The FTP operation measures the time for the NQA client to transfer a file to or download a file from an FTP server.
When you configure the FTP operation, follow these restrictions and guidelines:
· When you perform the put operation with the filename command configured, make sure the file exists on the NQA client.
· If you get a file from the FTP server, make sure the file specified in the URL exists on the FTP server.
· The NQA client does not save the file obtained from the FTP server.
· Use a small file for the FTP operation. A big file might result in transfer failure because of timeout, or might affect other services for occupying much network bandwidth.
To configure the FTP operation:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify the FTP type and enter its view. |
type ftp |
N/A |
4. Specify the URL of the destination FTP server. |
url url |
By default, no URL is specified for the destination FTP server. Enter the URL in one of the following formats: · ftp://host/filename. · ftp://host:port/filename. When you perform the get operation, the file name is required. |
5. (Optional.) Specify the source IP address of FTP request packets. |
By default, the packets take the primary IP address of the output interface as their source IP address. The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no FTP requests can be sent out. |
6. (Optional.) Specify the FTP operation type. |
operation { get | put } |
By default, the FTP operation type is get, which means obtaining files from the FTP server. |
7. Specify an FTP login username. |
username username |
By default, no FTP login username is configured. |
8. Specify an FTP login password. |
password { cipher | simple } string |
By default, no FTP login password is configured. |
9. (Optional.) Specify the name of a file to be transferred. |
filename file-name |
By default, no file is specified. This step is required if you perform the put operation. |
10. Set the data transmission mode. |
mode { active | passive } |
The default mode is active. |
An HTTP operation measures the time for the NQA client to obtain data from an HTTP server.
To configure an HTTP operation:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify the HTTP type and enter its view. |
type http |
N/A |
4. Specify the URL of the destination HTTP server. |
url url |
By default, no URL is specified for the destination HTTP server. Enter the URL in one of the following formats: · http://host/resource. · http://host:port/resource. |
5. Specify an HTTP login username. |
username username |
By default, no HTTP login username is specified. |
6. Specify an HTTP login password. |
By default, no HTTP login password is specified. |
7. (Optional.) Specify the source IP address of request packets. |
By default, the packets take the primary IP address of the output interface as their source IP address. The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no request packets can be sent out. |
8. (Optional.) Specify the HTTP version. |
By default, HTTP 1.0 is used. |
9. (Optional.) Specify the HTTP operation type. |
operation { get | post | raw } |
By default, the HTTP operation type is get, which means obtaining data from the HTTP server. If you set the HTTP operation type to raw, configure the content of the HTTP request to be sent to the HTTP server in raw request view. |
10. (Optional.) Enter raw request view. |
raw-request |
Every time you enter raw request view, the previously configured content of the HTTP request is removed. |
11. (Optional.) Specify the HTTP request content. |
Enter or paste the content. |
By default, no contents are specified. This step is required for the raw operation. |
12. Save the input and return to HTTP operation view. |
quit |
N/A |
CAUTION: To ensure successful UDP jitter operations and avoid affecting existing services, do not perform the operations on well-known ports from 1 to 1023. |
Jitter means inter-packet delay variance. A UDP jitter operation measures unidirectional and bidirectional jitters. The operation result helps you to determine whether the network can carry jitter-sensitive services such as real-time voice and video services through the UDP jitter operation.
The UDP jitter operation works as follows:
1. The NQA client sends UDP packets to the destination port.
The UDP jitter operation requires both the NQA server and the NQA client. Before you perform the UDP jitter operation, configure the UDP listening service on the NQA server. For more information about UDP listening service configuration, see "Configuring the NQA server."
To configure a UDP jitter operation:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify the UDP jitter type and enter its view. |
type udp-jitter |
N/A |
4. Specify the destination address of UDP packets. |
By default, no destination IP address is specified. The destination IP address must be the same as the IP address of the listening service on the NQA server. |
5. Specify the destination port of UDP packets. |
destination port port-number |
By default, no destination port number is specified. The destination port number must be the same as the port number of the listening service on the NQA server. |
6. (Optional.) Specify the source IP address for UDP packets. |
By default, the packets take the primary IP address of the output interface as their source IP address. The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no UDP packets can be sent out. |
7. (Optional.) Specify the source port number of UDP packets. |
source port port-number |
By default, no source port number is specified. |
8. (Optional.) Set the payload size for each UDP packet. |
data-size size |
9. (Optional.) Specify the payload fill string for UDP packets. |
data-fill string |
10. (Optional.) Set the number of UDP packets sent in one UDP jitter operation. |
11. (Optional.) Set the interval for sending UDP packets. |
12. (Optional.) Specify how long the NQA client waits for a response from the server before it regards the response times out. |
NOTE: Use the display nqa result or display nqa statistics command to verify the UDP jitter operation. The display nqa history command does not display the UDP jitter operation results or statistics. |
The SNMP operation measures the time for the NQA client to get a response packet from an SNMP agent.
To configure the SNMP operation:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify the SNMP type and enter its view. |
type snmp |
N/A |
4. Specify the destination address of SNMP packets. |
5. (Optional.) Specify the source port of SNMP packets. |
6. (Optional.) Specify the source IP address of SNMP packets. |
By default, the packets take the primary IP address of the output interface as their source IP address. The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no SNMP packets can be sent out. |
7. (Optional.) Specify the read-only community name for the SNMP operation if the operation uses the SNMPv1 or SNMPv2c agent. |
community read { cipher | simple } community-name |
The default read-only community name is public. Make sure the specified community name is the same as the community name configured on the SNMP agent. |
The TCP operation measures the time for the NQA client to establish a TCP connection to a port on the NQA server.
The TCP operation requires both the NQA server and the NQA client. Before you perform a TCP operation, configure a TCP listening service on the NQA server. For more information about the TCP listening service configuration, see "Configuring the NQA server."
To configure the TCP operation:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify the TCP type and enter its view. |
type tcp |
N/A |
4. Specify the destination address of TCP packets. |
By default, no destination IP address is specified. The destination address must be the same as the IP address of the listening service configured on the NQA server. |
5. Specify the destination port of TCP packets. |
By default, no destination port number is configured. The destination port number must be the same as the port number of the listening service on the NQA server. |
6. (Optional.) Specify the source IP address of TCP packets. |
By default, the packets take the primary IP address of the output interface as their source IP address. The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no TCP packets can be sent out. |
The UDP echo operation measures the round-trip time between the client and a UDP port on the NQA server.
The UDP echo operation requires both the NQA server and the NQA client. Before you perform a UDP echo operation, configure a UDP listening service on the NQA server. For more information about the UDP listening service configuration, see "Configuring the NQA server."
To configure the UDP echo operation:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify the UDP echo type and enter its view. |
type udp-echo |
N/A |
6. (Optional.) Set the payload size for each UDP packet. |
data-size size |
7. (Optional.) Specify the payload fill string for UDP packets. |
data-fill string |
8. (Optional.) Specify the source port of UDP packets. |
9. (Optional.) Specify the source IP address of UDP packets. |
The UDP tracert operation determines the routing path from the source device to the destination device.
Before you configure the UDP tracert operation, perform the following tasks:
· Enable sending ICMP time exceeded messages on the intermediate devices between the source and destination devices. If the intermediate devices are H3C devices, use the ip ttl-expires enable command.
· Enable sending ICMP destination unreachable messages on the destination device. If the destination device is an H3C device, use the ip unreachables enable command.
For more information about the ip ttl-expires enable and ip unreachables enable commands, see Layer 3—IP Services Command Reference.
To configure the UDP tracert operation:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify the UDP tracert operation type and enter its view. |
type udp-tracert |
N/A |
4. Specify the destination device for the operation. |
Specify the destination device by its
host name: ·
IP address: |
By default, no destination IP address or host name is specified. |
5. (Optional.) Specify the destination port of UDP packets. |
By default, the destination port number is 33434. This port number must be an unused number on the destination device, so that the destination device can reply with ICMP port unreachable messages. |
data-size size |
7. (Optional.) Enable the no-fragmentation feature. |
no-fragment enable |
By default, the no-fragmentation feature is disabled. |
8. (Optional.) Set the maximum number of consecutive probe failures. |
max-failure times |
The default setting is 5. |
9. (Optional.) Set the TTL value for UDP packets in the start round of the UDP tracert operation. |
init-ttl value |
The default setting is 1. |
10. (Optional.) Specify an output interface for UDP packets. |
By default, the output interface for UDP packets is not specified. The NQA client determines the output interface based on the routing table lookup. |
11. (Optional.) Specify the source port of UDP packets. |
12. (Optional.) Specify the source IP address of UDP packets. |
Specify the IP address of the specified
interface as the source IP address: ·
By default, the packets take the primary IP address of the output interface as their source IP address. If you execute the source ip and source interface commands multiple times, the most recent configuration takes effect. The specified source interface must be up. The source IP address must be the IP address of a local interface, and the local interface must be up. Otherwise, no probe packets can be sent out. |
CAUTION: To ensure successful voice operations and avoid affecting existing services, do not perform the operations on well-known ports from 1 to 1023. |
The voice operation measures VoIP network performance.
The voice operation works as follows:
1. The NQA client sends voice packets at sending intervals to the destination device (NQA server).
The voice packets are of one of the following codec types:
? G.711 A-law.
? G.711 μ-law.
? G.729 A-law.
2. The destination device time stamps each voice packet it receives and sends it back to the source.
3. Upon receiving the packet, the source device calculates the jitter and one-way delay based on the timestamp.
The following parameters that reflect VoIP network performance can be calculated by using the metrics gathered by the voice operation:
· Calculated Planning Impairment Factor (ICPIF)—Measures impairment to voice quality in a VoIP network. It is decided by packet loss and delay. A higher value represents a lower service quality.
· Mean Opinion Scores (MOS)—A MOS value can be evaluated by using the ICPIF value, in the range of 1 to 5. A higher value represents a higher service quality.
The evaluation of voice quality depends on users' tolerance for voice quality. For users with higher tolerance for voice quality, use the advantage-factor command to set an advantage factor. When the system calculates the ICPIF value, it subtracts the advantage factor to modify ICPIF and MOS values for voice quality evaluation.
The voice operation requires both the NQA server and the NQA client. Before you perform a voice operation, configure a UDP listening service on the NQA server. For more information about UDP listening service configuration, see "Configuring the NQA server."
The voice operation cannot repeat.
To configure the voice operation:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify the voice type and enter its view. |
type voice |
N/A |
4. Specify the destination address of voice packets. |
By default, no destination IP address is configured. The destination IP address must be the same as the IP address of the listening service on the NQA server. |
5. Specify the destination port of voice packets. |
6. (Optional.) Specify the codec type. |
codec-type { g711a | g711u | g729a } |
By default, the codec type is G.711 A-law. |
7. (Optional.) Set the advantage factor for calculating MOS and ICPIF values. |
advantage-factor factor |
By default, the advantage factor is 0. |
8. (Optional.) Specify the source IP address of voice packets. |
By default, the packets take the primary IP address of the output interface as their source IP address. The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no voice packets can be sent out. |
9. (Optional.) Specify the source port number of voice packets. |
10. (Optional.) Set the payload size for each voice packet. |
data-size size |
By default, the voice packet size varies by codec type. The default packet size is 172 bytes for G.711A-law and G.711 μ-law codec type, and 32 bytes for G.729 A-law codec type. |
11. (Optional.) Specify the payload fill string for voice packets. |
data-fill string |
12. (Optional.) Set the number of voice packets to be sent in a voice probe. |
The default setting is 1000. |
13. (Optional.) Set the interval for sending voice packets. |
14. (Optional.) Specify how long the NQA client waits for a response from the server before it regards the response times out. |
The default setting is 5000 milliseconds. |
NOTE: Use the display nqa result or display nqa statistics command to verify the voice operation. The display nqa history command does not display the voice operation results or statistics. |
Configuring the DLSw operation
The DLSw operation measures the response time of a DLSw device.
To configure the DLSw operation:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify the DLSw type and enter its view. |
type dlsw |
N/A |
4. Specify the destination IP address of probe packets. |
5. (Optional.) Specify the source IP address of probe packets. |
By default, the packets take the primary IP address of the output interface as their source IP address. The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no probe packets can be sent out. |
Configuring the path jitter operation
The path jitter operation measures the jitter, negative jitters, and positive jitters from the NQA client to each hop on the path to the destination.
Before you configure the path jitter operation, perform the following tasks:
To configure the path jitter operation:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify the path jitter type and enter its view. |
type path-jitter |
N/A |
4. Specify the destination address of ICMP echo requests. |
data-size size |
data-fill string |
7. Specify the source IP address of ICMP echo requests. |
By default, the packets take the primary IP address of the output interface as their source IP address. The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no ICMP echo requests can be sent out. |
8. (Optional.) Set the number of ICMP echo requests to be sent in a path jitter operation. |
9. (Optional.) Set the interval for sending ICMP echo requests. |
10. (Optional.) Specify how long the NQA client waits for a response from the server before it regards the response times out. |
11. (Optional.) Specify an LSR path. |
lsr-path ip-address&<1-8> |
By default, no LSR path is specified. The path jitter operation uses the tracert to detect the LSR path to the destination, and sends ICMP echo requests to each hop on the LSR. |
12. (Optional.) Perform the path jitter operation only on the destination address. |
target-only |
By default, the path jitter operation is performed on each hop on the path to the destination. |
Unless otherwise specified, the following optional parameters apply to all types of NQA operations.
The parameter settings take effect only on the current operation.
To configure optional parameters for an NQA operation:
Step |
Command |
Remarks |
system-view |
N/A |
3. Specify an NQA operation type and enter its view. |
type { dhcp | dlsw | dns | ftp | http | icmp-echo | icmp-jitter | path-jitter | snmp | tcp | udp-echo | udp-jitter | udp-tracert | voice } |
N/A |
4. Configure a description. |
description text |
By default, no description is configured. |
5. Set the interval at which the NQA operation repeats. |
frequency interval |
For a voice or path jitter operation, the default setting is 60000 milliseconds. For other types of operations, the default setting is 0 milliseconds, and only one operation is performed. If the operation is not completed when the interval expires, the next operation does not start. |
6. Specify the probe times. |
probe count times |
By default: · In an UDP tracert operation, the NQA client performs three probes to each hop to the destination. · In other types of operations, the NQA client performs one probe to the destination per operation. This command is not available for the path jitter and voice operations. Each of these operations performs only one probe. |
7. Set the probe timeout time. |
probe timeout timeout |
The default setting is 3000 milliseconds. This command is not available for the ICMP jitter, path jitter, UDP jitter, or voice operations. |
8. Set the maximum number of hops that the probe packets can traverse. |
ttl value |
The default setting is 30 for probe packets of the UDP tracert operation, and is 20 for probe packets of other types of operations. This command is not available for the DHCP or path jitter operation. |
9. Set the ToS value in the IP header of probe packets. |
tos value |
The default setting is 0. |
10. Enable the routing table bypass feature. |
route-option bypass-route |
By default, the routing table bypass feature is disabled. This command is not available for the DHCP and path jitter operations. |
11. Specify the VPN instance where the operation is performed. |
vpn-instance vpn-instance-name |
By default, the operation is performed on the public network. |
Collaboration is implemented by associating a reaction entry of an NQA operation with a track entry. The reaction entry monitors the NQA operation. If the number of operation failures reaches the specified threshold, the configured action is triggered.
To configure the collaboration feature:
Step |
Command |
Remarks |
system-view |
N/A |
type { dhcp | dlsw | dns | ftp | http | icmp-echo | snmp | tcp | udp-echo } |
The collaboration feature is not available for the ICMP jitter, path jitter, UDP tracert, UDP jitter, or voice operations. |
4. Configure a reaction entry. |
reaction item-number checked-element probe-fail threshold-type consecutive consecutive-occurrences action-type trigger-only |
By default, no reaction entry is configured. You cannot modify the content of an existing reaction entry. |
5. Return to system view. |
quit |
N/A |
6. Associate Track with NQA. |
See High Availability Configuration Guide. |
N/A |
7. Associate Track with an application module. |
N/A |
This feature allows you to monitor the NQA operation running status.
Threshold types
An NQA operation supports the following threshold types:
· average—If the average value for the monitored performance metric either exceeds the upper threshold or goes below the lower threshold, a threshold violation occurs.
· accumulate—If the total number of times that the monitored performance metric is out of the specified value range reaches or exceeds the specified threshold, a threshold violation occurs.
· consecutive—If the number of consecutive times that the monitored performance metric is out of the specified value range reaches or exceeds the specified threshold, a threshold violation occurs.
Threshold violations for the average or accumulate threshold type are determined on a per NQA operation basis. The threshold violations for the consecutive type are determined from the time the NQA operation starts.
Triggered actions
The following actions might be triggered:
· none—NQA displays results only on the terminal screen. It does not send traps to the NMS.
· trap-only—NQA displays results on the terminal screen, and meanwhile it sends traps to the NMS.
· trigger-only—NQA displays results on the terminal screen, and meanwhile triggers other modules for collaboration.
The DNS operation does not support the action of sending trap messages.
Reaction entry
In a reaction entry, configure a monitored element, a threshold type, and an action to be triggered to implement threshold monitoring.
The state of a reaction entry can be invalid, over-threshold, or below-threshold.
· Before an NQA operation starts, the reaction entry is in invalid state.
· If the threshold is violated, the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold.
If the action is trap-only for a reaction entry, a trap message is sent to the NMS when the state of the entry changes.
Before you configure threshold monitoring, configure the destination address of the trap messages by using the snmp-agent target-host command. For more information about the command, see Network Management and Monitoring Command Reference.
To configure threshold monitoring:
Step |
Command |
Remarks |
system-view |
N/A |
3. Enter NQA operation view. |
type { dhcp | dlsw | dns | ftp | http | icmp-echo | icmp-jitter | snmp | tcp | udp-echo | udp-jitter | udp-tracert | voice } |
The threshold monitoring feature is not available for the path jitter operation. |
4. Enable sending traps to the NMS when specific conditions are met. |
reaction trap { path-change | probe-failure consecutive-probe-failures | test-complete | test-failure [ accumulate-probe-failures ] } |
By default, no traps are sent to the NMS. The ICMP jitter, UDP jitter, and voice operations support only the test-complete keyword. The following parameters are not available for the UDP tracert operation: · The probe-failure consecutive-probe-failures option. · The accumulate-probe-failures argument. |
5. Configure threshold monitoring. |
Monitor the operation duration (not
supported in the ICMP jitter, UDP jitter, UDP tracert, or voice operations): ·
Monitor failure times (not supported in the
Monitor the round-trip time (only for the ICMP
jitter, UDP jitter, and voice operations): ·
Monitor packet loss (only for the ICMP jitter,
Monitor the one-way jitter (only for the ICMP
Monitor the one-way delay (only for the ICMP
Monitor the ICPIF value (only for the voice
operation): ·
Monitor the MOS value (only for the voice
operation): |
N/A |
NQA forms statistics within the same collection interval as a statistics group. To display information about the statistics groups, use the display nqa statistics command.
If you use the frequency command to set the interval to 0 milliseconds for an NQA operation, NQA does not generate any statistics group for the operation.
To configure the NQA statistics collection feature:
Step |
Command |
Remarks |
system-view |
N/A |
type { dhcp | dlsw | dns | ftp | http | icmp-echo | icmp-jitter | path-jitter | snmp | tcp | udp-echo | udp-jitter| voice } |
The NQA statistics collection feature is not available for UDP tracert operation. |
4. (Optional.) Set the interval for collecting the statistics. |
statistics interval interval |
The default setting is 60 minutes. |
5. (Optional.) Set the maximum number of statistics groups that can be saved. |
statistics max-group number |
The default setting is two groups. To disable the NQA statistics collection feature, set the maximum number to 0. When the maximum number of statistics groups is reached, to save a new statistics group, the oldest statistics group is deleted. |
6. (Optional.) Set the hold time of statistics groups. |
statistics hold-time hold-time |
The default setting is 120 minutes. A statistics group is deleted when its hold time expires. |
Step |
Command |
Remarks |
system-view |
N/A |
3. Enter NQA operation type view. |
type { dhcp | dlsw | dns | ftp | http | icmp-echo | snmp | tcp | udp-echo | udp-tracert } |
The history record saving feature is not available for the ICMP jitter, UDP jitter, path jitter, or voice operations. |
4. Enable the saving of history records for the NQA operation. |
history-record enable |
By default, this feature is enabled only for the UDP tracert operation. |
5. (Optional.) Set the lifetime of history records. |
history-record keep-time keep-time |
The default setting is 120 minutes. A record is deleted when its lifetime is reached. |
6. (Optional.) Set the maximum number of history records that can be saved. |
history-record number number |
The default setting is 50. If the maximum number of history records for an NQA operation is reached, the earliest history records are deleted. |
7. (Optional.) Display NQA history records. |
display nqa history |
N/A |
The NQA operation works between the specified start time and the end time (the start time plus operation duration). If the specified start time is ahead of the system time, the operation starts immediately. If both the specified start and end time are ahead of the system time, the operation does not start. To display the current system time, use the display clock command.
When you schedule an NQA operation, follow these restrictions and guidelines:
· You cannot enter the operation type view or the operation view of a scheduled NQA operation.
· A system time adjustment does not affect started or completed NQA operations. It affects only the NQA operations that have not started.
To schedule the NQA operation on the NQA client:
Step |
Command |
system-view |
2. Specify the scheduling parameters for an NQA operation. |
nqa schedule admin-name operation-tag start-time { hh:mm:ss [ yyyy/mm/dd | mm/dd/yyyy ] | now } lifetime { lifetime | forever } [ recurring ] |
Configuring NQA templates on the NQA client
An NQA template is a set of operation parameters, such as the destination address, the destination port number, and the destination server URL. You can use an NQA template in a feature module to provide statistics. You can create multiple templates on a device, and each template must be uniquely named.
NQA template supports the DNS, FTP, HTTP, HTTPS, ICMP, SSL, TCP, TCP half open, and UDP operation types.
Some operation parameters for an NQA template can be specified by the template configuration or the feature that uses the template. When both are specified, the parameters in the template configuration take effect.
NQA template configuration task list
Tasks at a glance |
(Required.) Perform at least one of the following tasks: · Configuring the ICMP template · Configuring the DNS template · Configuring the TCP template · Configuring the TCP half open template · Configuring the UDP template · Configuring the HTTP template · Configuring the HTTPS template |
(Optional.) Configuring optional parameters for the NQA template |
A feature that uses the ICMP template performs the ICMP operation to measure the reachability of a destination device.
To configure the ICMP template:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create an ICMP template and enter its view. |
nqa template icmp name |
By default, no ICMP templates exist. |
3. (Optional.) Specify the destination IP address of the operation. |
By default, no destination IP address is configured. |
4. (Optional.) Set the payload size for each ICMP request. |
data-size size |
5. (Optional.) Specify the payload fill string for requests. |
data-fill string |
6. (Optional.) Specify the source IP address for ICMP echo requests. |
7. (Optional.) Specify the next hop IP address for ICMP echo requests. |
By default, no IP address of the next hop is configured. |
8. (Optional.) Configure the probe result sending on a per-probe basis. |
reaction trigger per-probe |
By default, the probe result is sent to the feature that uses the template after three consecutive failed or successful probes. If you execute the reaction trigger per-probe and reaction trigger probe-pass commands multiple times, the most recent configuration takes effect. If you execute the reaction trigger per-probe and reaction trigger probe-fail commands multiple times, the most recent configuration takes effect. |
A feature that uses the DNS template performs the DNS operation to determine the status of the server. In DNS template view, you can specify the address expected to be returned. If the returned IP addresses include the expected address, the DNS server is valid and the operation succeeds. Otherwise, the operation fails.
Create a mapping between the domain name and an address before you perform the DNS operation. For information about configuring the DNS server, see Layer 3—IP Services Configuration Guide.
To configure the DNS template:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a DNS template and enter DNS template view. |
nqa template dns name |
By default, no DNS templates exist. |
3. (Optional.) Specify the destination IP address of DNS packets. |
4. (Optional.) Specify the destination port number for the operation. |
By default, the destination port number is 53. |
6. Specify the domain name resolution type. |
resolve-type A |
By default, the type is type A. A type A query resolves a domain name to a mapped IP address. |
7. (Optional.) Specify the source IP address for the probe packets. |
source ip ip-address |
8. (Optional.) Specify the source port for probe packets. |
9. (Optional.) Specify the IP address that is expected to be returned. |
expect ip ip-address |
By default, no expected IP address is specified. |
A feature that uses the TCP template performs the TCP operation to test whether the NQA client can establish a TCP connection to a specific port on the server.
In TCP template view, you can specify the expected data to be returned. If you do not specify the expected data, the TCP operation tests only whether the client can establish a TCP connection to the server.
To configure the TCP template:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a TCP template and enter its view. |
nqa template tcp name |
By default, no TCP templates exist. |
data-fill string |
6. (Optional.) Specify the source IP address for the probe packets. |
7. (Optional.) Configure the expected data. |
expect data expression [ offset number ] |
By default, no expected data is configured. The NQA client performs expect data check only when you configure both the data-fill and expect-data commands. |
A feature that uses the TCP half open template performs the TCP half open operation to test whether the TCP service is available on the server. The TCP half open operation is used when the feature cannot get a response from the TCP server through an existing TCP connection.
In the TCP half open operation, the NQA client sends a TCP ACK packet to the server. If the client receives an RST packet, it considers that the TCP service is available on the server.
To configure the TCP half open template:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a TCP half open template and enter its view. |
nqa template tcphalfopen name |
By default, no TCP half open templates exist. |
4. (Optional.) Specify the source IP address for the probe packets. |
5. (Optional.) Specify the next hop IP address for the probe packets. |
By default, the IP address of the next hop is configured. |
6. (Optional.) Configure the probe result sending on a per-probe basis. |
A feature that uses the UDP template performs the UDP operation to test the following items:
· Reachability of a specific port on the NQA server.
· Availability of the requested service on the NQA server.
In UDP template view, you can specify the expected data to be returned. If you do not specify the expected data, the UDP operation tests only whether the client can receive the response packet from the server.
The UDP operation requires both the NQA server and the NQA client. Before you perform a UDP operation, configure a UDP listening service on the NQA server. For more information about the UDP listening service configuration, see "Configuring the NQA server."
To configure the UDP template:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a UDP template and enter its view. |
nqa template udp name |
By default, no UDP templates exist. |
5. (Optional.) Specify the payload fill string for the probe packets. |
data-fill string |
6. (Optional.) Set the payload size for the probe packets. |
data-size size |
8. (Optional.) Configure the expected data. |
By default, no expected data is configured. If you want to configure this command, make sure the data-fill command is already executed. |
A feature that uses the HTTP template performs the HTTP operation to measure the time it takes the NQA client to obtain data from an HTTP server.
The expected data is checked only when the data is configured and the HTTP response contains the Content-Length field in the HTTP header.
The status code of the HTTP packet is a three-digit field in decimal notation, and it includes the status information for the HTTP server. The first digit defines the class of response.
Configure the HTTP server before you perform the HTTP operation.
To configure the HTTP template:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Create an HTTP template and enter its view. |
nqa template http name |
By default, no HTTP templates exist. |
3. Specify the URL of the destination HTTP server. |
url url |
4. Specify an HTTP login username. |
username username |
5. Specify an HTTP login password. |
6. (Optional.) Specify the HTTP version. |
version { v1.0 | v1.1 } |
7. (Optional.) Specify the HTTP operation type. |
By default, the HTTP operation type is get, which means obtaining data from the HTTP server. If you set the HTTP operation type to raw, use the raw-request command to specify the content of the HTTP request to be sent to the HTTP server. |
8. (Optional.) Enter raw request view. |
raw-request |
This step is required for the raw operation. Every time you enter the raw request view, the existing request content configuration is removed. |
9. (Optional.) Enter or paste the content of the HTTP request for the HTTP operation. |
N/A |
This step is required for the raw operation. By default, the HTTP request content is not specified. |
10. (Optional.) Return to HTTP template view. |
quit |
The system automatically saves the configuration in raw request view before it returns to HTTP template view. |
11. (Optional.) Specify the source IP address for the probe packets. |
12. (Optional.) Configure the expected status codes. |
expect status status-list |
By default, no expected status code is configured. |
13. (Optional.) Configure the expected data. |
By default, no expected data is configured. |
A feature that uses the HTTPS template performs the HTTPS operation to measure the time it takes for the NQA client to obtain data from an HTTPS server.
The expected data is checked only when the expected data is configured and the HTTPS response contains the Content-Length field in the HTTPS header.
The status code of the HTTPS packet is a three-digit field in decimal notation, and it includes the status information for the HTTPS server. The first digit defines the class of response.
Before you perform the HTTPS operation, configure the HTTPS server and the SSL client policy for the SSL client. For information about configuring SSL client policies, see Security Configuration Guide.
To configure the HTTPS template:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create an HTTPS template and enter its view. |
nqa template https name |
By default, no HTTPS templates exist. |
3. Specify the URL of the destination HTTPS server. |
url url |
By default, no URL is specified for the destination HTTPS server. Enter the URL in one of the following formats: · https://host/resource. · https://host:port/resource. |
4. Specify an HTTPS login username. |
username username |
By default, no HTTPS login username is specified. |
5. Specify an HTTPS login password. |
By default, no HTTPS login password is specified. |
6. Specify an SSL client policy. |
ssl-client-policy policy-name |
By default, no SSL client policy is specified. |
7. (Optional.) Specify the HTTPS version. |
By default, HTTPS 1.0 is used. |
8. (Optional.) Specify the HTTPS operation type. |
By default, the HTTPS operation type is get, which means obtaining data from the HTTPS server. If you set the HTTPS operation type to raw, use the raw-request command to configure the content of the request to be sent to the HTTPS server. |
9. (Optional.) Enter raw request view. |
raw-request |
This step is required for the raw operation. Every time you enter the raw request view, the previously configured request content is removed. |
10. (Optional.) Enter or paste the content of the HTTPS request for the HTTPS operation. |
N/A |
This step is required for the raw operation. By default, the HTTPS request content is not specified. |
11. (Optional.) Return to HTTPS template view. |
quit |
The system automatically saves the configuration in raw request view before it returns to HTTPS template view. |
12. (Optional.) Specify the source IP address for the probe packets. |
14. (Optional.) Configure the expected status codes. |
Configuring the FTP template
A feature that uses the FTP template performs the FTP operation. The operation measures the time it takes the NQA client to transfer a file to or download a file from an FTP server.
Configure the username and password for the FTP client to log in to the FTP server before you perform an FTP operation. For information about configuring the FTP server, see Fundamentals Configuration Guide.
To configure the FTP template:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create an FTP template and enter its view. |
nqa template ftp name |
By default, no FTP templates exist. |
3. Specify the URL of the destination FTP server. |
url url |
By default, no URL is specified for the destination FTP server. Enter the URL in one of the following formats: · ftp://host/filename. · ftp://host:port/filename. When you perform the get operation, the file name is required. When you perform the put operation, the filename argument does not take effect, even if it is specified. The file name for the put operation is determined by the filename command. |
4. (Optional.) Specify the FTP operation type. |
5. Specify an FTP login username. |
username username |
By default, no FTP login username is specified. |
6. Specify an FTP login password. |
password { cipher | simple } sting |
By default, no FTP login password is specified. |
7. (Optional.) Specify the name of a file to be transferred. |
filename filename |
This step is required if you perform the put operation. This configuration does not take effect for the get operation. By default, no file is specified. |
8. Set the data transmission mode. |
9. (Optional.) Specify the source IP address for the probe packets. |
Configuring the SSL template
Before you configure the SSL template, configure the SSL client policy. For information about configuring SSL client policies, see Security Configuration Guide.
To configure the SSL template:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create an SSL template and enter its view. |
nqa template ssl name |
By default, no SSL templates exist. |
By default, the destination port number is not specified. |
5. (Optional.) Specify the source IP address for the probe packets. |
Unless otherwise specified, the following optional parameters apply to all types of NQA templates.
The parameter settings take effect only on the current NQA template.
To configure optional parameters for an NQA template:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create an NQA template and enter its view. |
nqa template { dns | ftp | http | https | icmp | ssl | tcp | tcphalfopen | udp } name |
By default, no NQA templates exist. |
3. Configure a description. |
description text |
4. Set the interval at which the NQA operation repeats. |
The default setting is 5000 milliseconds. If the operation is not completed when the interval expires, the next operation does not start. |
5. Set the probe timeout time. |
6. Set the TTL for probe packets. |
ttl value |
The default setting is 20. |
7. Set the ToS value in the IP header of probe packets. |
tos value |
8. Specify the VPN instance where the operation is performed. |
9. Set the number of consecutive successful probes to determine a successful operation event. |
reaction trigger probe-pass count |
The default setting is 3. If the number of consecutive successful probes for an NQA operation is reached, the NQA client notifies the feature that uses the template of the successful operation event. |
10. Set the number of consecutive probe failures to determine an operation failure. |
reaction trigger probe-fail count |
The default setting is 3. If the number of consecutive probe failures for an NQA operation is reached, the NQA client notifies the feature that uses the NQA template of the operation failure. |
Displaying and maintaining NQA
Task |
Command |
Display history records of NQA operations. |
display nqa history [ admin-name operation-tag ] |
Display the current monitoring results of reaction entries. |
display nqa reaction counters [ admin-name operation-tag [ item-number ] ] |
Display the most recent result of the NQA operation. |
display nqa result [ admin-name operation-tag ] |
Display NQA statistics. |
display nqa statistics [ admin-name operation-tag ] |
Display NQA server status. |
display nqa server status |
NQA configuration examples
ICMP echo operation configuration example
Network requirements
As shown in Figure 41, configure an ICMP echo operation on the NQA client (Device A) to test the round-trip time to Device B. The next hop of Device A is Device C.
Configuration procedure
# Assign IP addresses to interfaces, as shown in Figure 41. (Details not shown.)
# Configure static routes or a routing protocol to make sure the devices can reach each other. (Details not shown.)
# Create an ICMP echo operation.
[DeviceA] nqa entry admin test1
[DeviceA-nqa-admin-test1] type icmp-echo
# Specify 10.2.2.2 as the destination IP address of ICMP echo requests.
[DeviceA-nqa-admin-test1-icmp-echo] destination ip 10.2.2.2
# Specify 10.1.1.2 as the next hop. The ICMP echo requests are sent through Device C to Device B.
[DeviceA-nqa-admin-test1-icmp-echo] next-hop ip 10.1.1.2
# Configure the ICMP echo operation to perform 10 probes.
[DeviceA-nqa-admin-test1-icmp-echo] probe count 10
# Set the probe timeout time to 500 milliseconds for the ICMP echo operation.
[DeviceA-nqa-admin-test1-icmp-echo] probe timeout 500
# Configure the ICMP echo operation to repeat every 5000 milliseconds.
[DeviceA-nqa-admin-test1-icmp-echo] frequency 5000
# Enable saving history records.
[DeviceA-nqa-admin-test1-icmp-echo] history-record enable
# Set the maximum number of history records to 10.
[DeviceA-nqa-admin-test1-icmp-echo] history-record number 10
[DeviceA-nqa-admin-test1-icmp-echo] quit
# Start the ICMP echo operation.
[DeviceA] nqa schedule admin test1 start-time now lifetime forever
# After the ICMP echo operation runs for a period of time, stop the operation.
[DeviceA] undo nqa schedule admin test1
# Display the most recent result of the ICMP echo operation.
[DeviceA] display nqa result admin test1
NQA entry (admin admin, tag test1) test results:
Send operation times: 10 Receive response times: 10
Min/Max/Average round trip time: 2/5/3
Square-Sum of round trip time: 96
Last succeeded probe time: 2011-08-23 15:00:01.2
Extended results:
Packet loss ratio: 0%
Failures due to timeout: 0
Failures due to internal error: 0
Failures due to other errors: 0
# Display the history records of the ICMP echo operation.
[DeviceA] display nqa history admin test1
NQA entry (admin admin, tag test) history records:
Index Response Status Time
370 3 Succeeded 2007-08-23 15:00:01.2
369 3 Succeeded 2007-08-23 15:00:01.2
368 3 Succeeded 2007-08-23 15:00:01.2
367 5 Succeeded 2007-08-23 15:00:01.2
366 3 Succeeded 2007-08-23 15:00:01.2
365 3 Succeeded 2007-08-23 15:00:01.2
364 3 Succeeded 2007-08-23 15:00:01.1
363 2 Succeeded 2007-08-23 15:00:01.1
362 3 Succeeded 2007-08-23 15:00:01.1
361 2 Succeeded 2007-08-23 15:00:01.1
The output shows that the packets sent by Device A can reach Device B through Device C. No packet loss occurs during the operation. The minimum, maximum, and average round-trip times are 2, 5, and 3 milliseconds, respectively.
ICMP jitter operation configuration example
As shown in Figure 42, configure an ICMP jitter operation to test the jitter between Device A and Device B.
1. Assign IP addresses to interfaces, as shown in Figure 42. (Details not shown.)
2. Configure static routes or a routing protocol to make sure the devices can reach each other. (Details not shown.)
3. Configure Device A:
# Create an ICMP jitter operation.
[DeviceA-nqa-admin-test1] type icmp-jitter
# Specify 10.2.2.2 as the destination address for the operation.
[DeviceA-nqa-admin-test1-icmp-jitter] destination ip 10.2.2.2
# Configure the operation to repeat every 1000 milliseconds.
[DeviceA-nqa-admin-test1-icmp-jitter] frequency 1000
[DeviceA-nqa-admin-test1-icmp-jitter] quit
# Start the ICMP jitter operation.
# After the ICMP jitter operation runs for a period of time, stop the operation.
# Display the most recent result of the ICMP jitter operation.
Min/Max/Average round trip time: 1/2/1
Square-Sum of round trip time: 13
Last packet received time: 2015-03-09 17:40:29.8
Extended results:
Packets out of sequence: 0
Packets arrived late: 0
ICMP-jitter results:
RTT number: 10
Min positive SD: 0 Min positive DS: 0
Max positive SD: 0 Max positive DS: 0
Positive SD number: 0 Positive DS number: 0
Positive SD sum: 0 Positive DS sum: 0
Positive SD average: 0 Positive DS average: 0
Positive SD square-sum: 0 Positive DS square-sum: 0
Min negative SD: 1 Min negative DS: 2
Max negative SD: 1 Max negative DS: 2
Negative SD number: 1 Negative DS number: 1
Negative SD sum: 1 Negative DS sum: 2
Negative SD average: 1 Negative DS average: 2
Negative SD square-sum: 1 Negative DS square-sum: 4
One way results:
Max SD delay: 1 Max DS delay: 2
Min SD delay: 1 Min DS delay: 2
Number of SD delay: 1 Number of DS delay: 1
Sum of SD delay: 1 Sum of DS delay: 2
Square-Sum of SD delay: 1 Square-Sum of DS delay: 4
Lost packets for unknown reason: 0
# Display the statistics of the ICMP jitter operation.
[DeviceA] display nqa statistics admin test1
NQA entry (admin admin, tag test1) test statistics:
NO. : 1
Start time: 2015-03-09 17:42:10.7
Life time: 156 seconds
Send operation times: 1560 Receive response times: 1560
Square-Sum of round trip time: 1563
Extended results:
RTT number: 1560
Min positive SD: 1 Min positive DS: 1
Max positive SD: 1 Max positive DS: 2
Positive SD number: 18 Positive DS number: 46
Positive SD sum: 18 Positive DS sum: 49
Positive SD average: 1 Positive DS average: 1
Positive SD square-sum: 18 Positive DS square-sum: 55
Min negative SD: 1 Min negative DS: 1
Negative SD number: 24 Negative DS number: 57
Negative SD sum: 24 Negative DS sum: 58
Negative SD average: 1 Negative DS average: 1
Negative SD square-sum: 24 Negative DS square-sum: 60
One way results:
Min SD delay: 1 Min DS delay: 1
Number of SD delay: 4 Number of DS delay: 4
Sum of SD delay: 4 Sum of DS delay: 5
Square-Sum of SD delay: 4 Square-Sum of DS delay: 7
DHCP operation configuration example
As shown in Figure 43, configure a DHCP operation to test the time required for Switch A to obtain an IP address from the DHCP server (Switch B).
# Create a DHCP operation.
[SwitchA] nqa entry admin test1
[SwitchA-nqa-admin-test1] type dhcp
# Specify the DHCP server address 10.1.1.2 as the destination address.
[SwitchA-nqa-admin-test1-dhcp] destination ip 10.1.1.2
# Enable the saving of history records.
[SwitchA-nqa-admin-test1-dhcp] history-record enable
[SwitchA-nqa-admin-test1-dhcp] quit
# Start the DHCP operation.
[SwitchA] nqa schedule admin test1 start-time now lifetime forever
# After the DHCP operation runs for a period of time, stop the operation.
[SwitchA] undo nqa schedule admin test1
# Display the most recent result of the DHCP operation.
[SwitchA] display nqa result admin test1
Send operation times: 1 Receive response times: 1
Min/Max/Average round trip time: 512/512/512
Square-Sum of round trip time: 262144
Last succeeded probe time: 2011-11-22 09:56:03.2
Extended results:
# Display the history records of the DHCP operation.
[SwitchA] display nqa history admin test1
NQA entry (admin admin, tag test1) history records:
1 512 Succeeded 2011-11-22 09:56:03.2
The output shows that it took Switch A 512 milliseconds to obtain an IP address from the DHCP server.
DNS operation configuration example
As shown in Figure 44, configure a DNS operation to test whether Device A can perform address resolution through the DNS server and test the resolution time.
# Assign IP addresses to interfaces, as shown in Figure 44. (Details not shown.)
# Create a DNS operation.
[DeviceA-nqa-admin-test1] type dns
# Specify the IP address of the DNS server 10.2.2.2 as the destination address.
[DeviceA-nqa-admin-test1-dns] destination ip 10.2.2.2
# Specify host.com as the domain name to be translated.
[DeviceA-nqa-admin-test1-dns] resolve-target host.com
[DeviceA-nqa-admin-test1-dns] history-record enable
[DeviceA-nqa-admin-test1-dns] quit
# Start the DNS operation.
# After the DNS operation runs for a period of time, stop the operation.
# Display the most recent result of the DNS operation.
Min/Max/Average round trip time: 62/62/62
Square-Sum of round trip time: 3844
Last succeeded probe time: 2011-11-10 10:49:37.3
Extended results:
# Display the history records of the DNS operation.
1 62 Succeeded 2011-11-10 10:49:37.3
The output shows that it took Device A 62 milliseconds to translate domain name host.com into an IP address.
FTP operation configuration example
As shown in Figure 45, configure an FTP operation to test the time required for Device A to upload a file to the FTP server. The login username and password are admin and systemtest, respectively. The file to be transferred to the FTP server is config.txt.
# Assign IP addresses to interfaces, as shown in Figure 45. (Details not shown.)
# Create an FTP operation.
[DeviceA-nqa-admin-test1] type ftp
# Specify the URL of the FTP server.
[DeviceA-nqa-admin-test-ftp] url ftp://10.2.2.2
# Specify 10.1.1.1 as the source IP address.
[DeviceA-nqa-admin-test1-ftp] source ip 10.1.1.1
# Configure the device to upload file config.txt to the FTP server.
[DeviceA-nqa-admin-test1-ftp] operation put
[DeviceA-nqa-admin-test1-ftp] filename config.txt
# Set the username to admin for the FTP operation.
[DeviceA-nqa-admin-test1-ftp] username admin
# Set the password to systemtest for the FTP operation.
[DeviceA-nqa-admin-test1-ftp] password simple systemtest
[DeviceA-nqa-admin-test1-ftp] history-record enable
[DeviceA-nqa-admin-test1-ftp] quit
# Start the FTP operation.
# After the FTP operation runs for a period of time, stop the operation.
# Display the most recent result of the FTP operation.
Min/Max/Average round trip time: 173/173/173
Square-Sum of round trip time: 29929
Last succeeded probe time: 2011-11-22 10:07:28.6
Extended results:
Failures due to disconnect: 0
Failures due to no connection: 0
# Display the history records of the FTP operation.
1 173 Succeeded 2011-11-22 10:07:28.6
The output shows that it took Device A 173 milliseconds to upload a file to the FTP server.
HTTP operation configuration example
As shown in Figure 46, configure an HTTP operation on the NQA client to test the time required to obtain data from the HTTP server.
# Assign IP addresses to interfaces, as shown in Figure 46. (Details not shown.)
# Create an HTTP operation.
[DeviceA-nqa-admin-test1] type http
# Specify the URL of the HTTP server.
[DeviceA-nqa-admin-test-http] url http://10.2.2.2/index.htm
# Configure the HTTP operation to get data from the HTTP server.
[DeviceA-nqa-admin-test1-http] operation get
# Configure the operation to use HTTP version 1.0.
[DeviceA-nqa-admin-test1-http] version v1.0
[DeviceA-nqa-admin-test1-http] history-record enable
[DeviceA-nqa-admin-test1-http] quit
# Start the HTTP operation.
# After the HTTP operation runs for a period of time, stop the operation.
# Display the most recent result of the HTTP operation.
Min/Max/Average round trip time: 64/64/64
Square-Sum of round trip time: 4096
Last succeeded probe time: 2011-11-22 10:12:47.9
Extended results:
# Display the history records of the HTTP operation.
1 64 Succeeded 2011-11-22 10:12:47.9
The output shows that it took Device A 64 milliseconds to obtain data from the HTTP server.
UDP jitter operation configuration example
As shown in Figure 47, configure a UDP jitter operation to test the jitter, delay, and round-trip time between Device A and Device B.
1. Assign IP addresses to interfaces, as shown in Figure 47. (Details not shown.)
3. Configure Device B:
# Enable the NQA server.
[DeviceB] nqa server enable
# Configure a listening service to listen on the IP address 10.2.2.2 and UDP port 9000.
[DeviceB] nqa server udp-echo 10.2.2.2 9000
4. Configure Device A:
# Create a UDP jitter operation.
[DeviceA-nqa-admin-test1] type udp-jitter
# Specify 10.2.2.2 as the destination address of the operation.
[DeviceA-nqa-admin-test1-udp-jitter] destination ip 10.2.2.2
# Set the destination port number to 9000.
[DeviceA-nqa-admin-test1-udp-jitter] destination port 9000
[DeviceA-nqa-admin-test1-udp-jitter] frequency 1000
[DeviceA-nqa-admin-test1-udp-jitter] quit
# Start the UDP jitter operation.
# After the UDP jitter operation runs for a period of time, stop the operation.
# Display the most recent result of the UDP jitter operation.
Min/Max/Average round trip time: 15/32/17
Square-Sum of round trip time: 3235
Last packet received time: 2011-05-29 13:56:17.6
Extended results:
UDP-jitter results:
RTT number: 10
Min positive SD: 4 Min positive DS: 1
Max positive SD: 21 Max positive DS: 28
Positive SD number: 5 Positive DS number: 4
Positive SD sum: 52 Positive DS sum: 38
Positive SD average: 10 Positive DS average: 10
Positive SD square-sum: 754 Positive DS square-sum: 460
Min negative SD: 1 Min negative DS: 6
Max negative SD: 13 Max negative DS: 22
Negative SD number: 4 Negative DS number: 5
Negative SD sum: 38 Negative DS sum: 52
Negative SD average: 10 Negative DS average: 10
Negative SD square-sum: 460 Negative DS square-sum: 754
One way results:
Max SD delay: 15 Max DS delay: 16
Min SD delay: 7 Min DS delay: 7
Number of SD delay: 10 Number of DS delay: 10
Sum of SD delay: 78 Sum of DS delay: 85
Square-Sum of SD delay: 666 Square-Sum of DS delay: 787
SD lost packets: 0 DS lost packets: 0
# Display the statistics of the UDP jitter operation.
NO. : 1
Start time: 2011-05-29 13:56:14.0
Life time: 47 seconds
Send operation times: 410 Receive response times: 410
Min/Max/Average round trip time: 1/93/19
Square-Sum of round trip time: 206176
Extended results:
UDP-jitter results:
RTT number: 410
Min positive SD: 3 Min positive DS: 1
Max positive SD: 30 Max positive DS: 79
Positive SD number: 186 Positive DS number: 158
Positive SD sum: 2602 Positive DS sum: 1928
Positive SD average: 13 Positive DS average: 12
Positive SD square-sum: 45304 Positive DS square-sum: 31682
Max negative SD: 30 Max negative DS: 78
Negative SD number: 181 Negative DS number: 209
Negative SD sum: 181 Negative DS sum: 209
Negative SD average: 13 Negative DS average: 14
Negative SD square-sum: 46994 Negative DS square-sum: 3030
One way results:
Max SD delay: 46 Max DS delay: 46
Number of SD delay: 410 Number of DS delay: 410
Sum of SD delay: 3705 Sum of DS delay: 3891
Square-Sum of SD delay: 45987 Square-Sum of DS delay: 49393
SNMP operation configuration example
As shown in Figure 48, configure an SNMP operation to test the time the NQA client uses to get a response from the SNMP agent.
1. Assign IP addresses to interfaces, as shown in Figure 48. (Details not shown.)
3. Configure the SNMP agent (Device B):
# Set the SNMP version to all.
[DeviceB] snmp-agent sys-info version all
# Set the read community to public.
[DeviceB] snmp-agent community read public
# Set the write community to private.
[DeviceB] snmp-agent community write private
# Create an SNMP operation.
[DeviceA-nqa-admin-test1] type snmp
# Specify 10.2.2.2 as the destination IP address of the SNMP operation.
[DeviceA-nqa-admin-test1-snmp] destination ip 10.2.2.2
[DeviceA-nqa-admin-test1-snmp] history-record enable
[DeviceA-nqa-admin-test1-snmp] quit
# Start the SNMP operation.
# After the SNMP operation runs for a period of time, stop the operation.
# Display the most recent result of the SNMP operation.
Min/Max/Average round trip time: 50/50/50
Square-Sum of round trip time: 2500
Last succeeded probe time: 2011-11-22 10:24:41.1
Extended results:
# Display the history records of the SNMP operation.
1 50 Succeeded 2011-11-22 10:24:41.1
The output shows that it took Device A 50 milliseconds to receive a response from the SNMP agent.
TCP operation configuration example
As shown in Figure 49, configure a TCP operation to test the time required for Device A to establish a TCP connection with Device B.
1. Assign IP addresses to interfaces, as shown in Figure 49. (Details not shown.)
# Configure a listening service to listen on the IP address 10.2.2.2 and TCP port 9000.
[DeviceB] nqa server tcp-connect 10.2.2.2 9000
# Create a TCP operation.
[DeviceA-nqa-admin-test1] type tcp
# Specify 10.2.2.2 as the destination IP address.
[DeviceA-nqa-admin-test1-tcp] destination ip 10.2.2.2
[DeviceA-nqa-admin-test1-tcp] destination port 9000
[DeviceA-nqa-admin-test1-tcp] history-record enable
[DeviceA-nqa-admin-test1-tcp] quit
# Start the TCP operation.
# After the TCP operation runs for a period of time, stop the operation.
# Display the most recent result of the TCP operation.
Min/Max/Average round trip time: 13/13/13
Square-Sum of round trip time: 169
Last succeeded probe time: 2011-11-22 10:27:25.1
Extended results:
# Display the history records of the TCP operation.
1 13 Succeeded 2011-11-22 10:27:25.1
The output shows that it took Device A 13 milliseconds to establish a TCP connection to port 9000 on the NQA server.
UDP echo operation configuration example
As shown in Figure 50, configure a UDP echo operation on the NQA client to test the round-trip time to Device B. The destination port number is 8000.
1. Assign IP addresses to interfaces, as shown in Figure 50. (Details not shown.)
# Configure a listening service to listen on the IP address 10.2.2.2 and UDP port 8000.
[DeviceB] nqa server udp-echo 10.2.2.2 8000
# Create a UDP echo operation.
[DeviceA-nqa-admin-test1] type udp-echo
[DeviceA-nqa-admin-test1-udp-echo] destination ip 10.2.2.2
# Set the destination port number to 8000.
[DeviceA-nqa-admin-test1-udp-echo] destination port 8000
[DeviceA-nqa-admin-test1-udp-echo] history-record enable
[DeviceA-nqa-admin-test1-udp-echo] quit
# Start the UDP echo operation.
# After the UDP echo operation runs for a period of time, stop the operation.
# Display the most recent result of the UDP echo operation.
Min/Max/Average round trip time: 25/25/25
Square-Sum of round trip time: 625
Last succeeded probe time: 2011-11-22 10:36:17.9
Extended results:
# Display the history records of the UDP echo operation.
1 25 Succeeded 2011-11-22 10:36:17.9
The output shows that the round-trip time between Device A and port 8000 on Device B is 25 milliseconds.
UDP tracert operation configuration example
As shown in Figure 51, configure a UDP tracert operation to determine the routing path from Device A to Device B.
1. Assign IP addresses to interfaces, as shown in Figure 51. (Details not shown.)
3. Execute the ip ttl-expires enable command on the intermediate devices and execute the ip unreachables enable command on Device B.
# Create a UDP tracert operation.
[DeviceA-nqa-admin-test1] type udp-tracert
[DeviceA-nqa-admin-test1-udp-tracert] destination ip 10.2.2.2
# Set the destination port number to 33434.
[DeviceA-nqa-admin-test1-udp-tracert] destination port 33434
# Configure Device A to perform three probes to each hop.
[DeviceA-nqa-admin-test1-udp-tracert] probe count 3
# Set the probe timeout time to 500 milliseconds.
[DeviceA-nqa-admin-test1-udp-tracert] probe timeout 500
# Configure the UDP tracert operation to repeat every 5000 milliseconds.
[DeviceA-nqa-admin-test1-udp-tracert] frequency 5000
# Specify GigabitEthernet 1/0/1 as the output interface for UDP packets.
[DeviceA-nqa-admin-test1-udp-tracert] out interface gigabitethernet 1/0/1
# Enable the no-fragmentation feature.
[DeviceA-nqa-admin-test1-udp-tracert] no-fragment enable
# Set the maximum number of consecutive probe failures to 6.
[DeviceA-nqa-admin-test1-udp-tracert] max-failure 6
# Set the TTL value to 1 for UDP packets in the start round of the UDP tracert operation.
[DeviceA-nqa-admin-test1-udp-tracert] init-ttl 1
# Start the UDP tracert operation.
# After the UDP tracert operation runs for a period of time, stop the operation.
# Display the most recent result of the UDP tracert operation.
Send operation times: 6 Receive response times: 6
Min/Max/Average round trip time: 1/1/1
Last succeeded probe time: 2013-09-09 14:46:06.2
Extended results:
Packet loss in test: 0%
UDP-tracert results:
TTL Hop IP Time
1 3.1.1.1 2013-09-09 14:46:03.2
2 10.2.2.2 2013-09-09 14:46:06.2
# Display the history records of the UDP tracert operation.
Index TTL Response Hop IP Status Time
1 2 2 10.2.2.2 Succeeded 2013-09-09 14:46:06.2
1 2 1 10.2.2.2 Succeeded 2013-09-09 14:46:05.2
1 2 2 10.2.2.2 Succeeded 2013-09-09 14:46:04.2
1 1 1 3.1.1.1 Succeeded 2013-09-09 14:46:03.2
1 1 2 3.1.1.1 Succeeded 2013-09-09 14:46:02.2
1 1 1 3.1.1.1 Succeeded 2013-09-09 14:46:01.2
Voice operation configuration example
As shown in Figure 52, configure a voice operation to test jitters, delay, MOS, and ICPIF between Device A and Device B.
1. Assign IP addresses to interfaces, as shown in Figure 52. (Details not shown.)
# Configure a listening service to listen on IP address 10.2.2.2 and UDP port 9000.
# Create a voice operation.
[DeviceA-nqa-admin-test1] type voice
[DeviceA-nqa-admin-test1-voice] destination ip 10.2.2.2
[DeviceA-nqa-admin-test1-voice] destination port 9000
[DeviceA-nqa-admin-test1-voice] quit
# Start the voice operation.
# After the voice operation runs for a period of time, stop the operation.
# Display the most recent result of the voice operation.
Send operation times: 1000 Receive response times: 1000
Min/Max/Average round trip time: 31/1328/33
Square-Sum of round trip time: 2844813
Last packet received time: 2011-06-13 09:49:31.1
Extended results:
Voice results:
RTT number: 1000
Max positive SD: 204 Max positive DS: 1297
Positive SD number: 257 Positive DS number: 259
Positive SD sum: 759 Positive DS sum: 1797
Positive SD average: 2 Positive DS average: 6
Positive SD square-sum: 54127 Positive DS square-sum: 1691967
Max negative SD: 203 Max negative DS: 1297
Negative SD number: 255 Negative DS number: 259
Negative SD sum: 759 Negative DS sum: 1796
Negative SD average: 2 Negative DS average: 6
Negative SD square-sum: 53655 Negative DS square-sum: 1691776
One way results:
Max SD delay: 343 Max DS delay: 985
Min SD delay: 343 Min DS delay: 985
Sum of SD delay: 343 Sum of DS delay: 985
Square-Sum of SD delay: 117649 Square-Sum of DS delay: 970225
Voice scores:
MOS value: 4.38 ICPIF value: 0
# Display the statistics of the voice operation.
NO. : 1
Start time: 2011-06-13 09:45:37.8
Life time: 331 seconds
Send operation times: 4000 Receive response times: 4000
Min/Max/Average round trip time: 15/1328/32
Square-Sum of round trip time: 7160528
Extended results:
Voice results:
RTT number: 4000
Max positive SD: 360 Max positive DS: 1297
Positive SD number: 1030 Positive DS number: 1024
Positive SD sum: 4363 Positive DS sum: 5423
Positive SD average: 4 Positive DS average: 5
Positive SD square-sum: 497725 Positive DS square-sum: 2254957
Max negative SD: 360 Max negative DS: 1297
Negative SD number: 1028 Negative DS number: 1022
Negative SD sum: 1028 Negative DS sum: 1022
Negative SD average: 4 Negative DS average: 5
Negative SD square-sum: 495901 Negative DS square-sum: 5419
One way results:
Max SD delay: 359 Max DS delay: 985
Min SD delay: 0 Min DS delay: 0
Sum of SD delay: 1390 Sum of DS delay: 1079
Square-Sum of SD delay: 483202 Square-Sum of DS delay: 973651
Voice scores:
Max MOS value: 4.38 Min MOS value: 4.38
Max ICPIF value: 0 Min ICPIF value: 0
DLSw operation configuration example
As shown in Figure 53, configure a DLSw operation to test the response time of the DLSw device.
# Assign IP addresses to interfaces, as shown in Figure 53. (Details not shown.)
# Create a DLSw operation.
[DeviceA-nqa-admin-test1] type dlsw
[DeviceA-nqa-admin-test1-dlsw] destination ip 10.2.2.2
[DeviceA-nqa-admin-test1-dlsw] history-record enable
[DeviceA-nqa-admin-test1-dlsw] quit
# Start the DLSw operation.
# After the DLSw operation runs for a period of time, stop the operation.
# Display the most recent result of the DLSw operation.
Min/Max/Average round trip time: 19/19/19
Square-Sum of round trip time: 361
Last succeeded probe time: 2011-11-22 10:40:27.7
Extended results:
# Display the history records of the DLSw operation.
1 19 Succeeded 2011-11-22 10:40:27.7
The output shows that the response time of the DLSw device is 19 milliseconds.
Path jitter operation configuration example
As shown in Figure 54, configure a path jitter operation to test the round trip time and jitters from Device A to Device B and Device C.
# Assign IP addresses to interfaces, as shown in Figure 54. (Details not shown.)
# Execute the ip ttl-expires enable command on Device B and execute the ip unreachables enable command on Device C.
# Create a path jitter operation.
[DeviceA-nqa-admin-test1] type path-jitter
[DeviceA-nqa-admin-test1-path-jitter] destination ip 10.2.2.2
# Configure the path jitter operation to repeat every 10000 milliseconds.
[DeviceA-nqa-admin-test1-path-jitter] frequency 10000
[DeviceA-nqa-admin-test1-path-jitter] quit
# Start the path jitter operation.
# After the path jitter operation runs for a period of time, stop the operation.
# Display the most recent result of the path jitter operation.
Hop IP 10.1.1.2
Basic Results
Min/Max/Average round trip time: 9/21/14
Square-Sum of round trip time: 2419
Extended Results
Path-Jitter Results
Jitter number: 9
Min/Max/Average jitter: 1/10/4
Positive jitter number: 6
Min/Max/Average positive jitter: 1/9/4
Sum/Square-Sum positive jitter: 25/173
Negative jitter number: 3
Min/Max/Average negative jitter: 2/10/6
Sum/Square-Sum positive jitter: 19/153
Hop IP 10.2.2.2
Basic Results
Min/Max/Average round trip time: 15/40/28
Square-Sum of round trip time: 4493
Extended Results
Path-Jitter Results
Jitter number: 9
NQA collaboration configuration example (on routers)
As shown in Figure 55, configure a static route to Router C with Router B as the next hop on Router A. Associate the static route, a track entry, and an ICMP echo operation to monitor the state of the static route.
1. Assign IP addresses to interfaces, as shown in Figure 55. (Details not shown.)
2. On Router A, configure a static route, and associate the static route with track entry 1.
[RouterA] ip route-static 10.1.1.2 24 10.2.1.1 track 1
3. On Router A, configure an ICMP echo operation:
# Create an NQA operation with the administrator name admin and operation tag test1.
[RouterA] nqa entry admin test1
# Set the NQA operation type to ICMP echo.
[RouterA-nqa-admin-test1] type icmp-echo
# Specify 10.2.1.1 as the destination IP address.
[RouterA-nqa-admin-test1-icmp-echo] destination ip 10.2.1.1
# Configure the operation to repeat every 100 milliseconds.
[RouterA-nqa-admin-test1-icmp-echo] frequency 100
# Create reaction entry 1. If the number of consecutive probe failures reaches 5, collaboration is triggered.
[RouterA-nqa-admin-test1-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
[RouterA-nqa-admin-test1-icmp-echo] quit
[RouterA] nqa schedule admin test1 start-time now lifetime forever
4. On Router A, create track entry 1, and associate it with reaction entry 1 of the NQA operation.
[RouterA] track 1 nqa entry admin test1 reaction 1
# Display information about all the track entries on Router A.
[RouterA] display track all
Track ID: 1
State: Positive
Duration: 0 days 0 hours 0 minutes 0 seconds
Notification delay: Positive 0, Negative 0 (in seconds)
Tracked object:
NQA entry: admin test1
Reaction: 1
# Display brief information about active routes in the routing table on Router A.
Destinations : 13 Routes : 13
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
10.1.1.0/24 Static 60 0 10.2.1.1 GE1/0/1
10.2.1.0/24 Direct 0 0 10.2.1.2 GE1/0/1
10.2.1.0/32 Direct 0 0 10.2.1.2 GE1/0/1
10.2.1.2/32 Direct 0 0 127.0.0.1 InLoop0
10.2.1.255/32 Direct 0 0 10.2.1.2 GE1/0/1
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
The output shows that the static route with the next hop 10.2.1.1 is active, and the status of the track entry is positive.
# Remove the IP address of GigabitEthernet 1/0/1 on Router B.
<RouterB> system-view
[RouterB-GigabitEthernet1/0/1] undo ip address
Track ID: 1
State: Negative
Tracked object:
Reaction: 1
Destinations : 12 Routes : 12
The output shows that the static route does not exist, and the status of the track entry is negative.
As shown in Figure 56, configure a static route to Switch C with Switch B as the next hop on Switch A. Associate the static route, a track entry, and an ICMP echo operation to monitor the state of the static route.
1. Assign IP addresses to interfaces, as shown in Figure 56. (Details not shown.)
2. On Switch A, configure a static route, and associate the static route with track entry 1.
[SwitchA] ip route-static 10.1.1.2 24 10.2.1.1 track 1
3. On Switch A, configure an ICMP echo operation:
# Configure the NQA operation type as ICMP echo.
[SwitchA-nqa-admin-test1] type icmp-echo
[SwitchA-nqa-admin-test1-icmp-echo] destination ip 10.2.1.1
[SwitchA-nqa-admin-test1-icmp-echo] frequency 100
[SwitchA-nqa-admin-test1-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
[SwitchA-nqa-admin-test1-icmp-echo] quit
# Start the ICMP operation.
4. On Switch A, create track entry 1, and associate it with reaction entry 1 of the NQA operation.
[SwitchA] track 1 nqa entry admin test1 reaction 1
# Display information about all the track entries on Switch A.
[SwitchA] display track all
Track ID: 1
State: Positive
Tracked object:
Reaction: 1
# Display brief information about active routes in the routing table on Switch A.
10.1.1.0/24 Static 60 0 10.2.1.1 Vlan3
10.2.1.0/24 Direct 0 0 10.2.1.2 Vlan3
10.2.1.0/32 Direct 0 0 10.2.1.2 Vlan3
10.2.1.255/32 Direct 0 0 10.2.1.2 Vlan3
# Remove the IP address of VLAN-interface 3 on Switch B.
[SwitchB-Vlan-interface3] undo ip address
Track ID: 1
State: Negative
Tracked object:
Reaction: 1
ICMP template configuration example
As shown in Figure 57, configure an ICMP template for a feature to perform the ICMP echo operation from Device A to Device B.
# Assign IP addresses to interfaces, as shown in Figure 57. (Details not shown.)
# Create ICMP template icmp.
[DeviceA] nqa template icmp icmp
[DeviceA-nqatplt-icmp-icmp] destination ip 10.2.2.2
[DeviceA-nqatplt-icmp-icmp] probe timeout 500
# Configure the ICMP echo operation to repeat every 3000 milliseconds.
[DeviceA-nqatplt-icmp-icmp] frequency 3000
# Configure the NQA client to notify the feature of the successful operation event if the number of consecutive successful probes reaches 2.
[DeviceA-nqatplt-icmp-icmp] reaction trigger probe-pass 2
# Configure the NQA client to notify the feature of the operation failure if the number of consecutive failed probes reaches 2.
[DeviceA-nqatplt-icmp-icmp] reaction trigger probe-fail 2
DNS template configuration example
As shown in Figure 58, configure a DNS template for a feature to perform the DNS operation. The operation tests whether Device A can perform the address resolution through the DNS server.
# Assign IP addresses to interfaces, as shown in Figure 58. (Details not shown.)
# Create DNS template dns.
[DeviceA] nqa template dns dns
# Specify the IP address of the DNS server 10.2.2.2 as the destination IP address.
[DeviceA-nqatplt-dns-dns] destination ip 10.2.2.2
[DeviceA-nqatplt-dns-dns] resolve-target host.com
# Set the domain name resolution type to type A.
[DeviceA-nqatplt-dns-dns] resolve-type A
# Specify 3.3.3.3 as the expected IP address.
[DeviceA-nqatplt-dns-dns] expect ip 3.3.3.3
[DeviceA-nqatplt-dns-dns] reaction trigger probe-pass 2
[DeviceA-nqatplt-dns-dns] reaction trigger probe-fail 2
TCP template configuration example
As shown in Figure 59, configure a TCP template for a feature to perform the TCP operation. The operation tests whether Device A can establish a TCP connection to Device B.
1. Assign IP addresses to interfaces, as shown in Figure 59. (Details not shown.)
# Configure a listening service to listen to the IP address 10.2.2.2 and TCP port 9000.
# Create TCP template tcp.
[DeviceA] nqa template tcp tcp
[DeviceA-nqatplt-tcp-tcp] destination ip 10.2.2.2
[DeviceA-nqatplt-tcp-tcp] destination port 9000
[DeviceA-nqatplt-tcp-tcp] reaction trigger probe-pass 2
[DeviceA-nqatplt-tcp-tcp] reaction trigger probe-fail 2
TCP half open template configuration example
As shown in Figure 60, configure a TCP half open template for a feature to test whether Device B can provide the TCP service for Device A.
1. Assign IP addresses to interfaces, as shown in Figure 60. (Details not shown.)
# Create TCP half open template test.
[DeviceA] nqa template tcphalfopen test
[DeviceA-nqatplt-tcphalfopen-test] destination ip 10.2.2.2
[DeviceA-nqatplt-tcphalfopen-test] reaction trigger probe-pass 2
[DeviceA-nqatplt-tcphalfopen-test] reaction trigger probe-fail 2
UDP template configuration example
As shown in Figure 61, configure a UDP template for a feature to perform the UDP operation. The operation tests whether Device A can receive a response from Device B.
1. Assign IP addresses to interfaces, as shown in Figure 61. (Details not shown.)
# Configure a listening service to listen to the IP address 10.2.2.2 and UDP port 9000.
# Create UDP template udp.
[DeviceA] nqa template udp udp
[DeviceA-nqatplt-udp-udp] destination ip 10.2.2.2
[DeviceA-nqatplt-udp-udp] destination port 9000
[DeviceA-nqatplt-udp-udp] reaction trigger probe-pass 2
[DeviceA-nqatplt-udp-udp] reaction trigger probe-fail 2
HTTP template configuration example
As shown in Figure 62, configure an HTTP template for a feature to perform the HTTP operation. The operation tests whether the NQA client can get data from the HTTP server.
# Assign IP addresses to interfaces, as shown in Figure 62. (Details not shown.)
# Create the HTTP template http.
[DeviceA] nqa template http http
# Specify http://10.2.2.2/index.htm as the URL of the HTTP server.
[DeviceA-nqatplt-http-http] url http://10.2.2.2/index.htm
# Set the HTTP operation type to get.
[DeviceA-nqatplt-http-http] operation get
[DeviceA-nqatplt-http-http] reaction trigger probe-pass 2
[DeviceA-nqatplt-http-http] reaction trigger probe-fail 2
HTTPS template configuration example
As shown in Figure 63, configure an HTTPS template for a feature to test whether the NQA client can get data from the HTTPS server (Device B).
# Assign IP addresses to interfaces, as shown in Figure 63. (Details not shown.)
# Configure an SSL client policy named abc on Device A, and make sure Device A can use the policy to connect to the HTTPS server. (Details not shown.)
# Create the HTTPS template test.
[DeviceA] nqa template https https
# Specify http://10.2.2.2/index.htm as the URL of the HTTPS server.
[DeviceA-nqatplt-https- https] url https://10.2.2.2/index.htm
# Specify the SSL client policy abc for the HTTPS template.
[DeviceA-nqatplt-https- https] ssl-client-policy abc
# Set the HTTPS operation type to get (the default HTTPS operation type).
[DeviceA-nqatplt-https- https] operation get
# Set the HTTPS version to 1.0 (the default HTTPS version).
[DeviceA-nqatplt-https- https] version v1.0
[DeviceA-nqatplt-https- https] reaction trigger probe-pass 2
[DeviceA-nqatplt-https- https] reaction trigger probe-fail 2
FTP template configuration example
As shown in Figure 64, configure an FTP template for a feature to perform the FTP operation. The operation tests whether Device A can upload a file to the FTP server. The login username and password are admin and systemtest, respectively. The file to be transferred to the FTP server is config.txt.
# Assign IP addresses to interfaces, as shown in Figure 64. (Details not shown.)
# Create the FTP template ftp.
[DeviceA] nqa template ftp ftp
[DeviceA-nqatplt-ftp-ftp] url ftp://10.2.2.2
[DeviceA-nqatplt-ftp-ftp] source ip 10.1.1.1
[DeviceA-nqatplt-ftp-ftp] operation put
[DeviceA-nqatplt-ftp-ftp] filename config.txt
# Set the username to admin for the FTP server login.
[DeviceA-nqatplt-ftp-ftp] username admin
# Set the password to systemtest for the FTP server login.
[DeviceA-nqatplt-ftp-ftp] password simple systemtest
[DeviceA-nqatplt-ftp-ftp] reaction trigger probe-pass 2
[DeviceA-nqatplt-ftp-ftp] reaction trigger probe-fail 2
SSL template configuration example
As shown in Figure 65, configure an SSL template for a feature to test whether Device A can establish an SSL connection to the SSL server on Device B.
# Assign IP addresses to interfaces, as shown in Figure 65. (Details not shown.)
# Configure an SSL client policy named abc on Device A, and make sure Device A can use the policy to connect to the SSL server on Device B. (Details not shown.)
# Create the SSL template ssl.
[DeviceA] nqa template ssl ssl
# Set the destination IP address and port number to 10.2.2.2 and 9000, respectively.
[DeviceA-nqatplt-ssl-ssl] destination ip 10.2.2.2
[DeviceA-nqatplt-ssl-ssl] destination port 9000
# Specify the SSL client policy abc for the SSL template.
[DeviceA-nqatplt-ssl-ssl] ssl-client-policy abc
[DeviceA-nqatplt-ssl-ssl] reaction trigger probe-pass 2
[DeviceA-nqatplt-ssl-ssl] reaction trigger probe-fail 2
Configuring NETCONF
Overview
Network Configuration Protocol (NETCONF) is an XML-based network management protocol with good filtering capabilities. It provides programmable mechanisms to manage and configure network devices. Through NETCONF, you can configure device parameters, retrieve parameter values, and get statistics information.
In NETCONF messages, each data item is contained in a fixed element. This enables different devices of the same vendor to provide the same access method and the same result presentation method. For the devices of different vendors, XML mapping in NETCONF messages can achieve the same effect. For a network environment containing different devices regardless of vendors, you can develop a NETCONF-based NMS system to configure and manage devices in a simple and effective way.
NETCONF structure
NETCONF has four layers: content layer, operations layer, RPC layer, and transport protocol layer.
Table 20 NETCONF layers and XML layers
NETCONF layer |
XML layer |
Content |
Configuration data, status data, and statistics information |
The content layer contains a set of managed objects, which can be configuration data, status data, and statistics information. For more information about the operable data, see the NETCONF XML API reference for the switch. |
Operations |
<get>,<get-config>,<edit-config>… |
The operations layer defines a set of base operations invoked as RPC methods with XML-encoded parameters. NETCONF base operations include data retrieval operations, configuration operations, lock operations, and session operations. For the device supported operations, see "Appendix A Supported NETCONF operations." |
RPC |
<rpc>,<rpc-reply> |
The RPC layer provides a simple, transport-independent framing mechanism for encoding RPCs. The <rpc> and <rpc-reply> elements are used to enclose NETCONF requests and responses (data at the operations layer and the content layer). |
Transport Protocol |
In non-FIPS mode: ·
In FIPS mode: |
The transport protocol layer provides reliable, connection-oriented, serial data links. In non-FIPS mode, you can log in through Telnet, SSH, or the console port to perform NETCONF operations at the CLI. You can also log in through HTTP or HTTPS to perform NETCONF operations in the Web interface or perform NETCONF-over-SOAP operations. In FIPS mode, all login methods are the same as in non-FIPS mode except that you cannot use HTTP or Telnet. |
NETCONF message format
NETCONF
IMPORTANT: When configuring NETCONF in XML view, you must add the end mark "]]>]]>" at the end of an XML message. Otherwise, the device cannot identify the message. |
All NETCONF messages are XML-based and comply with RFC 4741. Any incoming NETCONF messages must pass XML Schema check before it can be processed. If a NETCONF message fails XML Schema check, the device sends an error message to the client.
For information about the NETCONF operations supported by the device and the operable data, see the NETCONF XML API reference for the switch.
The following example shows a NETCONF message for getting all parameters of all interfaces on the device:
<?xml version="1.0" encoding="utf-8"?>
<rpc message-id ="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<get-bulk>
<filter type="subtree">
<top xmlns="http://www.h3c.com/netconf/data:1.0">
<Ifmgr>
<Interfaces>
<Interface/>
</Interfaces>
</Ifmgr>
</top>
</filter>
</get-bulk>
</rpc>
NETCONF over SOAP
All NETCONF over SOAP messages are XML-based and comply with RFC 4741. NETCONF messages are contained in the <Body> element of SOAP messages. NETCONF over SOAP messages also comply with the following rules:
· SOAP messages must use the SOAP Envelope namespaces.
· SOAP messages must use the SOAP Encoding namespaces.
· SOAP messages cannot contain the following information:
? DTD reference.
? XML processing instructions.
The following example shows a NETCONF over SOAP message for getting all parameters of all interfaces on the device:
<env:Envelope xmlns:env="http://www.w3.org/2003/05/soap-envelope">
<env:Header>
<auth:Authentication env:mustUnderstand="1" xmlns:auth="http://www.h3c.com/netconf/base:1.0">
<auth:AuthInfo>800207F0120020C</auth:AuthInfo>
</auth:Authentication>
</env:Header>
<env:Body>
<get-bulk>
<Ifmgr>
<Interfaces>
<Interface/>
</Interfaces>
</Ifmgr>
</top>
</filter>
</get-bulk>
</rpc>
</env:Body>
</env:Envelope>
How to use NETCONF
You can use NETCONF to manage and configure the device by using the methods in Table 21.
Table 21 NETCONF methods for configuring the device
Configuration tool |
Login method |
Remarks |
CLI |
· Console port · SSH · Telnet |
To implement NETCONF operations, copy valid NETCONF messages to the CLI in XML view. This method is suitable for R&D and test purposes. |
Custom interface |
N/A |
To use this method, you must enable NETCONF over SOAP. By default, the device cannot interpret Custom Web interfaces' URLs. For the device to interpret these URLs, you must encode the NETCONF messages sent from a custom interface in SOAP. |
Protocols and standards
· RFC 3339, Date and Time on the Internet: Timestamps
· RFC 4741, NETCONF Configuration Protocol
· RFC 4742, Using the NETCONF Configuration Protocol over Secure SHell (SSH)
· RFC 5277, NETCONF Event Notifications
· RFC 5539, NETCONF over Transport Layer Security (TLS)
· RFC 6241, Network Configuration Protocol
FIPS compliance
The device supports the FIPS mode that complies with NIST FIPS 140-2 requirements. Support for features, commands, and parameters might differ in FIPS mode (see Security Configuration Guide) and non-FIPS mode.
NETCONF configuration task list
Task at a glance |
(Optional.) Enabling NETCONF over SOAP |
(Optional.) Enabling NETCONF over SSH |
(Optional.) Enabling NETCONF logging |
(Required.) Establishing a NETCONF session |
(Optional.) Subscribing to event notifications |
(Optional.) Locking/unlocking the configuration |
(Optional.) Performing the get/get-bulk operation |
(Optional.) Performing the get-config/get-bulk-config operation |
(Optional.) Performing the edit-config operation |
(Optional.) Saving, rolling back, and loading the configuration |
(Optional.) Filtering data |
(Optional.) Performing CLI operations through NETCONF |
(Optional.) Retrieving NETCONF session information |
(Optional.) Terminating another NETCONF session |
(Optional.) Returning to the CLI |
NETCONF messages can be encapsulated into SOAP messages and transmitted over HTTP and HTTPS. After enabling NETCONF over SOAP, you can develop configuration interface to perform NETCONF operations.
To enable NETCONF over SOAP:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable NETCONF over SOAP. |
Enable NETCONF over SOAP over HTTP (not available in FIPS mode): ·
Enable NETCONF over SOAP over HTTPS: |
By default, NETCONF over SOAP is disabled. |
This feature allows users to use a client to perform NETCONF operations on the device through a NETCONF over SSH connection.
To enable NETCONF over SSH:
Step |
Command |
Remark |
system-view |
N/A |
2. Specify a port to listen for NETCONF over SSH connections. |
netconf ssh server port port number |
By default, port 830 listens for NETCONF over SSH connections. |
3. Enable NETCONF over SSH. |
netconf ssh server enable |
By default, NETCONF over SSH is disabled. |
NETCONF logging generates logs for different NETCONF operation sources and NETCONF operations.
To enable NETCONF logging:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable NETCONF logging. |
netconf log source { all | { agent | soap | web } * } { { protocol-operation { all | { action | config | get | set | session | syntax | others } * } } | verbose } |
By default, NETCONF logging is disabled. |
A client must send a hello message to a device and finish capabilities exchange before the device processes other requests from the client.
The device supports a maximum of 32 NETCONF sessions. If the upper limit is reached, new NETCONF users cannot access the device.
Do not configure NETCONF when another user is configuring NETCONF. If multiple users simultaneously configure NETCONF, the configuration result returned to each user might be inconsistent with the user request.
Setting the NETCONF session idle timeout time
IMPORTANT: This feature is available in Release 1138P01 and later versions. |
If no packets are exchanged between the device and a user within the NETCONF session idle timeout time, the device tears down the session.
To set the NETCONF session idle timeout time:
Task |
Command |
Remarks |
system-view |
N/A |
2. Set the NETCONF session idle timeout time. |
netconf { soap | agent } idle-timeout minute |
By default, the NETCONF session idle timeout time is as follows: · 10 minutes for NETCONF over SOAP over HTTP and for NETCONF over SOAP over HTTPS sessions. · 0 minutes for SSH, Telnet, and NETCONF over SSH sessions. |
Entering XML view
Task |
Command |
Remarks |
Enter XML view. |
xml |
Available in user view. |
Exchanging capabilities
After you enter XML view, the client and the device exchange their capabilities before you can perform subsequent operations. The device automatically advertises its NETCONF capabilities to the client in a hello message as follows:
<?xml version="1.0" encoding="UTF-8"?><hello xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"><capabilities><capability>urn:ietf:params:netconf:base:1.1</capability><capability>urn:ietf:params:netconf:writable-running</capability><capability>urn:ietf:params:netconf:capability:notification:1.0</capability><capability>urn:ietf:params:netconf:capability:validate:1.1</capability><capability>urn:ietf:params:netconf:capability:interleave:1.0</capability><capability>urn:ietf:params:netconf:capability:h3c-netconf-ext:1.0</capability></capabilities><session-id>1</session-id></hello>]]>]]>
The <capabilities> parameter represents the capabilities supported by the device.
The <session-id> parameter represents the unique ID assigned to the current session.
After receiving the hello message from the device, copy the following message to notify the device of the capabilities (user-configurable) supported by the client:
<capabilities>
<capability>
capability-set
</capability>
</capabilities>
</hello>
The capability-set parameter represents the capabilities supported by the client. Use a pair of <capability> and </capability> tags to enclose a capability.
After you subscribe to event notifications, the device sends event notifications to the NETCONF client when a subscribed event takes place on the device. The notifications include the code, group, severity, start time, and description of the events. The device supports only log subscription.
A subscription takes effect only on the current session. If the session is terminated, the subscription is automatically canceled.
You can send multiple subscription messages to subscribe to notification of multiple events.
Subscription procedure
# Copy the following message to the client to complete the subscription:
<rpc message-id="101" xmlns ="urn:ietf:params:xml:ns:netconf:base:1.0">
<create-subscription xmlns="urn:ietf:params:xml:ns:netconf:notification:1.0">
<stream>NETCONF</stream>
<filter>
<event xmlns="http://www.h3c.com/netconf/event:1.0">
<Code>code</Code>
<Group>group</Group>
<Severity>severity</Severity>
</event>
</filter>
<startTime>start-time</startTime>
<stopTime>stop-time</stopTime>
</create-subscription>
</rpc>
The <stream> parameter represents the event stream type supported by the device. Only NETCONF is supported.
The <event> parameter represents an event to which you have subscribed.
The <code> parameter represents a mnemonic symbol.
The <group> parameter represents the module name.
The <severity> parameter represents the severity level of the event.
The <start-time> parameter represents the start time of the subscription.
The <stop-time> argument represents the end time of the subscription.
After receiving the subscription request from the client, the device returns a response in the following format if the subscription is successful:
<rpc-reply message-id="101" xmlns:netconf="urn:ietf:params:xml:ns:netconf:base:1.0">
<ok/>
</rpc-reply>
If the subscription fails, the device returns an error message in the following format:
<rpc-reply message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<rpc-error>
<error-type>error-type</error-type>
<error-tag>error-tag</error-tag>
<error-severity>error-severity</error-severity>
<error-message xml:lang="en">error-message</error-message>
</rpc-error>
</rpc-reply>
For more information about error messages, see RFC 4741.
Example for subscribing to event notifications
Configure a client to subscribe to all events with no time limitation. After the subscription is successful, all events on the device are sent to the client before the session between the device and client is terminated.
# Enter XML view.
<Sysname> xml
# Exchange capabilities.
<capabilities>
<capability>
urn:ietf:params:netconf:base:1.0
</capability>
</capabilities>
</hello>
# Subscribe to all events with no time limitation.
<create-subscription xmlns ="urn:ietf:params:xml:ns:netconf:notification:1.0">
</rpc>
# If the client receives the following response, the subscription is successful:
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="101">
<ok/>
</rpc-reply>
# If fan 1 on the device encounters problems, the device sends the following text to the client that has subscribed to all events:
<notification xmlns="urn:ietf:params:xml:ns:netconf:notification:1.0">
<eventTime>2011-01-04T12:30:46</eventTime>
<Group>DEV</Group>
<Code>FAN_DIRECTION_NOT_PREFERRED</Code>
<Slot>6</Slot>
<Severity>Alert</Severity>
<context>Fan 1 airflow direction is not preferred on slot 6, please check it.</context>
</event>
</notification>
# When another client (192.168.100.130) logs in to the device, the device sends a notification to the client that has subscribed to all events:
<eventTime>2011-01-04T12:30:52</eventTime>
<Group>SHELL</Group>
<Code>SHELL_LOGIN</Code>
<Slot>6</Slot>
<Severity>Notification</Severity>
<context>VTY logged in from 192.168.100.130.</context>
</event>
</notification>
The device supports multiple NETCONF sessions. Multiple users can simultaneously manage and monitor the device using NETCONF. During device configuration and maintenance or network troubleshooting, a user can lock the configuration to prevent other users from changing it. After that, only the user holding the lock can change the configuration, and other users can only read the configuration.
In addition, only the user holding the lock can release the lock. After the lock is released, other users can change the current configuration or lock the configuration. If the session of the user that holds the lock is terminated, the system automatically releases the lock.
Locking the configuration
# Copy the following text to the client to lock the configuration:
<rpc message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<lock>
<target>
<running/>
</target>
</lock>
</rpc>
After receiving the lock request, the device returns a response in the following format if the lock operation is successful:
<ok/>
</rpc-reply>
Unlocking the configuration
# Copy the following text to the client to unlock the configuration:
<unlock>
<target>
<running/>
</target>
</unlock>
</rpc>
After receiving the unlock request, the device returns a response in the following format if the unlock operation is successful:
<ok/>
</rpc-reply>
Example for locking the configuration
Lock the device configuration so that other users cannot change the device configuration.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Lock the configuration.
<lock>
<target>
<running/>
</target>
</lock>
</rpc>
If the client receives the following response, the lock operation is successful:
<ok/>
</rpc-reply>
If another client sends a lock request, the device returns the following response:
<rpc-error>
<error-type>protocol</error-type>
<error-tag>lock-denied</error-tag>
<error-severity>error</error-severity>
<error-message xml:lang="en">Lock failed, lock is already held.</error-message>
<error-info>
</error-info>
</rpc-error>
</rpc-reply>
The output shows that the lock operation failed because the client with session ID 1 held the lock, and only the client holding the lock can release the lock.
Performing service operations
You can use NETCONF to perform service operations on the device, such as retrieving and modifying the specified information. The basic operations include get, get-bulk, get-config, get-bulk-config, and edit-config, which are used to retrieve all data, retrieve configuration data, and edit the data of the specified module. For more information, see the NETCONF XML API reference for the switch.
The get operation is used to retrieve device configuration and state information that match the conditions. In some cases, this operation leads to inefficiency.
The get-bulk operation is used to retrieve a number of data entries starting from the data entry next to the one with the specified index. One data entry contains a device configuration entry and a state information entry. The data entry quantity is defined by the count attribute, and the index is specified by the index attribute. The returned output does not include the index information. If you do not specify the index attribute, the index value starts with 1 by default.
The get-bulk operation retrieves all the rest data entries starting from the data entry next to the one with the specified index if either of the following conditions exists:
· You do not specify the count attribute.
· The number of matched data entries is less than the value of the count attribute.
# Copy the following text to the client to perform the get operation:
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<getoperation>
<filter>
<top xmlns=" http://www.h3c.com/netconf/data:1.0">
Specify the module, submodule, table name, and column name
</top>
</filter>
</getoperation>
</rpc>
The <getoperation> parameter can be <get> or <get-bulk>. The <filter> element is used to filter data, and it can contain module name, submodule name, table name, and column name.
· If the module name and the submodule name are not provided, the operation retrieves the data for all modules and submodules. If a module name or a submodule name is provided, the operation retrieves the data for the specified module or submodule.
· If the table name is not provided, the operation retrieves the data for all tables. If a table name is provided, the operation retrieves the data for the specified table.
· If only the index column is provided, the operation retrieves the data for all columns. If the index column and other columns are provided, the operation retrieves the data for the index column and the specified columns.
The <get> and <get-bulk> messages are similar. A <get-bulk> message carries the count and index attributes. The following is a <get-bulk> message example:
<rpc message-id ="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:xc="http://www.h3c.com/netconf/base:1.0">
<get-bulk>
<top xmlns="http://www.h3c.com/netconf/data:1.0" xmlns:base="http://www.h3c.com/netconf/base:1.0">
<Syslog>
<Logs xc:count="5">
<Log>
<Index>10</Index>
</Log>
</Logs>
</Syslog>
</top>
</filter>
</get-bulk>
</rpc>
The count attribute complies with the following rules:
· The count attribute can be placed in the module node and table node. In other nodes, it cannot be resolved.
· When the count attribute is placed in the module node, a descendant node inherits this count attribute if the descendant node does not contain the count attribute.
After receiving the get-bulk request, the device returns a response in the following format if the operation is successful:
<?xml version="1.0"?>
<rpc-reply message-id="100"
<data>
Device state and configuration data
</data>
</rpc-reply>
The get-config and get-bulk-config operations are used to retrieve all non-default configurations, which are configured by means of CLI and MIB. The <get-config> and <get-bulk-config> messages can contain the <filter> element for filtering data.
The <get-config> and <get-bulk-config> messages are similar. The following is a <get-config> message example:
<get-config>
<source>
<running/>
</source>
<filter>
<top xmlns="http://www.h3c.com/netconf/config:1.0">
Specify the module name, submodule name, table name, and column name
</top>
</filter>
</get-config>
</rpc>
After receiving the get-config request, the device returns a response in the following format if the operation is successful:
<rpc-reply message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<data>
All data matching the specified filter
</data>
</rpc-reply>
The edit-config operation supports the following operation attributes: merge, create, replace, remove, delete, default-operation, error-option, test-option, and incremental. For more information about these attributes, see "Appendix A Supported NETCONF operations."
# Copy the following text to perform the <edit-config> operation:
<edit-config>
<target><running></running></target>
<error-option>
Default operation when an error occurs
</error-option>
<config>
</top>
</config>
</edit-config>
</rpc>
After receiving the edit-config request, the device returns a response in the following format if the operation is successful:
<?xml version="1.0">
<ok/>
</rpc-reply>
All-module configuration data retrieval example
Retrieve configuration data for all modules.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Retrieve configuration data for all modules.
<get-config>
<source>
<running/>
</source>
</get-config>
</rpc>
If the client receives the following text, the get-config operation is successful:
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:web="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="101">
<data>
<Ifmgr>
<Interfaces>
<Interface>
<IfIndex>1307</IfIndex>
<Shutdown>1</Shutdown>
</Interface>
<Interface>
<IfIndex>1308</IfIndex>
</Interface>
<Interface>
<IfIndex>1309</IfIndex>
</Interface>
<Interface>
<IfIndex>1311</IfIndex>
<VlanType>2</VlanType>
</Interface>
<Interface>
<Index>1313</Index>
</Interface>
</Interfaces>
</Ifmgr>
<Syslog>
<LogBuffer>
<BufferSize>120</BufferSize>
</LogBuffer>
</Syslog>
<System>
<Device>
<SysName>H3C</SysName>
<TimeZone>
<Zone>+11:44</Zone>
<ZoneName>beijing</ZoneName>
</TimeZone>
</Device>
</System>
</top>
</data>
</rpc-reply>
Syslog configuration data retrieval example
Retrieve configuration data for the Syslog module.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Retrieve configuration data for the Syslog module.
<get-config>
<source>
<running/>
</source>
<Syslog/>
</top>
</filter>
</get-config>
</rpc>
<data>
<Syslog>
<LogBuffer>
</LogBuffer>
</Syslog>
</top>
</data>
</rpc-reply>
Example for retrieving a data entry for the interface table
Network requirements
Retrieve a data entry for the interface table.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>urn:ietf:params:netconf:base:1.0</capability>
</capabilities>
</hello>
# Retrieve a data entry for the interface table.
<rpc message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:web="urn:ietf:params:xml:ns:netconf:base:1.0">
<get-bulk>
<top xmlns="http://www.h3c.com/netconf/data:1.0" xmlns:web="http://www.h3c.com/netconf/base:1.0">
<Ifmgr>
<Interfaces web:count="1">
</Interfaces>
</Ifmgr>
</top>
</filter>
</get-bulk>
</rpc>
If the client receives the following text, the get-bulk operation is successful:
<data>
<Ifmgr>
<Interfaces>
<Interface>
<IfIndex>3</IfIndex>
<Name>Ten-GigabitEthernet1/0/2</Name>
<AbbreviatedName>XGE1/0/2</AbbreviatedName>
<PortIndex>3</PortIndex>
<ifTypeExt>22</ifTypeExt>
<ifType>6</ifType>
<Description> Ten-GigabitEthernet 1/0/2 Interface</Description>
<AdminStatus>2</AdminStatus>
<OperStatus>2</OperStatus>
<ConfigSpeed>0</ConfigSpeed>
<ActualSpeed>100000</ActualSpeed>
<ConfigDuplex>3</ConfigDuplex>
<ActualDuplex>1</ActualDuplex>
</Interface>
</Interfaces>
</Ifmgr>
</top>
</data>
</rpc-reply>
Example for changing the value of a parameter
Change the log buffer size for the Syslog module to 512.
Configuration procedure
# Enter XML view.
<Sysname> xml
<capabilities>
</capabilities>
</hello>
# Change the log buffer size for the Syslog module to 512.
<edit-config>
<target>
<running/>
</target>
<config>
<top xmlns="http://www.h3c.com/netconf/config:1.0" web:operation="merge">
<Syslog>
<LogBuffer>
<BufferSize>512</BufferSize>
</LogBuffer>
</Syslog>
</top>
</config>
</edit-config>
</rpc>
If the client receives the following text, the edit-config operation is successful:
<ok/>
</rpc-reply>
Use NETCONF to save, roll back, or load the configuration.
Performing the save, rollback, or load operation consumes a lot of system resources. Do not perform these operations when the system resources are heavily occupied.
Saving the configuration
# Copy the following text to the client to save the device configuration to the specified file:
<save>
<file>Specify the configuration file name</file>
</save>
</rpc>
The name of the specified configuration file must start with the storage media name and end with the extension .cfg. If the text does not include the <file> element, the configuration is saved to the main next-startup configuration file by default.
After receiving the save request, the device returns a response in the following format if the save operation is successful:
<ok/>
</rpc-reply>
Rolling back the configuration based on a configuration file
# Copy the following text to the client to roll back the configuration:
<rollback>
</rollback>
</rpc>
After receiving the rollback request, the device returns a response in the following format if the rollback operation is successful:
<ok/>
</rpc-reply>
Rolling back the configuration based on a rollback point
You can roll back the configuration based on a rollback point when one of the following situations occurs:
· A NETCONF client sends a rollback request.
· The NETCONF session idle time is longer than the rollback idle timeout time.
· A NETCONF client is unexpectedly disconnected from the device.
To roll back the configuration based on a rollback point, perform the following tasks:
1. Lock the system.
Multiple users might simultaneously use NETCONF to configure the device. As a best practice, lock the system before rolling back the configuration to prevent other users from modifying the running configuration.
2. Mark the beginning of a rollback operation. For more information, see "Performing the save-point/begin operation."
3. Edit the device configuration. For more information, see "Performing the edit-config operation."
4. Configure the rollback point. For more information, see "Performing the save-point/commit operation."
You can repeat this step to configure multiple rollback points.
5. Roll back the configuration based on the rollback point. For more information, see "Performing the save-point/rollback operation."
The configuration can also be rolled back automatically when the NETCONF session idle time is longer than the rollback idle timeout time.
6. End the rollback configuration. For more information, see "Performing the save-point/end operation."
7. Release the lock.
# Copy the following text to the client to mark the beginning of a rollback operation based on a rollback point:
<save-point>
<begin>
<confirm-timeout>100</confirm-timeout>
</begin>
</save-point>
</rpc>
The <confirm-timeout> parameter specifies the rollback idle timeout time in the range of 1 to 65536 seconds (the default is 600 seconds). This parameter is optional.
After receiving the begin request, the device returns a response in the following format if the begin operation is successful:
<data>
<save-point>
<commit>
<commit-id>1</commit-id>
</commit>
</save-point>
</data>
</rpc-reply>
The system supports a maximum of 50 rollback points. When the limit is reached, you must specify the force attribute to overwrite the earliest rollback point.
# Copy the following text to the client to configure the rollback point:
<save-point>
<commit>
<label>SUPPORT VLAN<label>
<comment>vlan 1 to 100 and interfaces. Each vlan used for different custom as fllows: ……</comment>
</commit>
</save-point>
</rpc>
The <label> and <comment> parameters are optional.
After receiving the commit request, the device returns a response in the following format if the commit operation is successful:
<data>
<save-point>
<commit>
<commit-id>2</commit-id>
</commit>
</save-point>
</data>
</rpc-reply>
<save-point>
<rollback>
<commit-id/>
<commit-index/>
<commit-label/>
</rollback>
</save-point>
</rpc>
The <commit-id> parameter uniquely identifies a rollback point.
The <commit-index> parameter specifies 50 most recently configured rollback points. The value of 0 indicates the most recently configured one and 49 indicates the earliest configured one.
The <commit-label> parameter exclusively specifies a label for a rollback point. The label is not required for a rollback point.
Specify one of these parameters to roll back the specified configuration. If no parameter is specified, this operation rolls back configuration based on the most recently configured rollback point.
<ok/>
</rpc-reply>
# Copy the following text to the client to end the rollback configuration:
<save-point>
<end/>
</save-point>
</rpc>
After receiving the end request, the device returns a response in the following format if the end operation is successful:
<ok/>
</rpc-reply>
Performing the save-point/get-commits operation
# Copy the following text to the client to get the rollback point configuration records:
<save-point>
<get-commits>
<commit-id/>
<commit-index/>
<commit-label/>
</get-commits>
</save-point>
</rpc>
Specify one of the <commit-id>, <commit-index>, and <commit-label> parameters to get the specified rollback point configuration records. If no parameter is specified, this operation gets records for all rollback point configuration. The following text is a <save-point>/<get-commits> request example:
<save-point>
<get-commits>
<commit-label>SUPPORT VLAN</commit-label>
</get-commits>
</save-point>
</rpc>
After receiving the get commits request, the device returns a response in the following format if the get commits operation is successful:
<data>
<save-point>
<commit-information>
<CommitID>2</CommitID>
<TimeStamp>Thu Oct 30 11:30:28 1980</TimeStamp>
<UserName>test</UserName>
<Label>SUPPORT VLAN</Label>
</commit-information>
</save-point>
</data>
</rpc-reply>
Performing the save-point/get-commit-information operation
# Copy the following text to the client to get the system configuration data corresponding to a rollback point:
<save-point>
<get-commit-information>
<commit-id/>
<commit-index/>
<commit-label/>
<compare-information>
<commit-id/>
<commit-index/>
<commit-label/>
</compare-information
</get-commit-information>
</save-point>
</rpc>
Specify one of the <commit-id>, <commit-index>, and <commit-label> parameters to get the configuration data corresponding to the specified rollback point. The <compare-information> parameter is optional. If no parameter is specified, this operation gets the configuration data corresponding to the most recently configured rollback point. The following text is a <save-point>/< get-commit-information> request example:
<save-point>
</save-point>
</rpc>
After receiving the get-commit-information request, the device returns a response in the following format if the get-commit-information operation is successful:
<data>
<save-point>
<content>
interface vlan 1
</content>
</save-point>
</data>
</rpc-reply>
Loading the configuration
After you perform the load operation, the loaded configurations are merged into the current configuration as follows:
· New configurations are directly loaded.
· Configurations that already exist in the current configuration are replaced by those loaded from the configuration file.
# Copy the following text to the client to load a configuration file for the device:
<load>
</load>
</rpc>
After receiving the load request, the device returns a response in the following format if the load operation is successful:
<ok/>
</rpc-reply>
Example for saving the configuration
Save the current configuration to the configuration file my_config.cfg.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Save the configuration of the device to the configuration file my_config.cfg.
<save>
<file>my_config.cfg</file>
</save>
</rpc>
If the client receives the following response, the save operation is successful:
<ok/>
</rpc-reply>
Filtering data
You can define a filter to filter information when you perform a get, get-bulk, get-config, or get-bulk-config operation. Data filtering includes the following types:
· Table-based filtering—Filters table information.
· Column-based filtering—Filters information for a single column.
For table-based filtering to take effect, you must configure table-based filtering before column-based filtering.
You can specify a match criterion for the row attribute filter to implement table-based filtering, for example, IP address filtering. The namespace is http://www.h3c.com/netconf/base:1.0. For information about the support for table-based match, see NETCONF XML API documents.
# Copy the following text to the client to retrieve the longest data with VRF name vpn1, IP address 1.1.1.0, and mask length 24 from the IPv4 routing table:
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:h3c="http://www.h3c.com/netconf/base:1.0">
<get>
<Route>
<Ipv4Routes>
<RouteEntry h3c:filter="vrf vpn1 IP 1.1.1.0 MaskLen 24 longer/>
</Ipv4Routes>
</Route>
</top>
</filter>
</get>
</rpc>
Column-based filtering includes full match filtering, regular expression match filtering, and conditional match filtering. Full match filtering has the highest priority and the conditional match filtering has the lowest priority. When more than one filtering criterion is specified, the one with the highest priority takes effect.
You can specify an element value in an XML message to implement full match. If multiple element values are provided, the system returns the data that matches all the specified values.
# Copy the following text to the client to retrieve the configuration data of all interfaces in UP state:
<rpc message-id ="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<get>
<Ifmgr>
<Interfaces>
<Interface>
</Interface>
</Interfaces>
</Ifmgr>
</top>
</filter>
</get>
</rpc>
Regular expression match filtering
To implement a complex data filtering with characters, you can add a regExp attribute for a specific element.
# Copy the following text to the client to retrieve the descriptions of interfaces, of which all the characters must be upper-case letters from A to Z:
<rpc message-id="1-0" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:h3c="http://www.h3c.com/netconf/base:1.0">
<get-config>
<source>
<running/>
</source>
<Ifmgr>
<Interfaces>
<Interface>
<Description h3c:regExp="^[A-Z]*$"/>
</Interface>
</Interfaces>
</Ifmgr>
</top>
</filter>
</get-config>
</rpc>
Conditional match filtering
To implement a complex data filtering with digits and character strings, you can add a match attribute for a specific element. Table 22 lists the conditional match operators.
Table 22 Conditional match operators
Operation |
Operator |
Remarks |
More than |
match="more:value" |
More than the specified value. The supported data types include date, digit, and character string. |
Less than |
match="less:value" |
Less than the specified value. The supported data types include date, digit, and character string. |
Not less than |
match="notLess:value" |
Not less than the specified value. The supported data types include date, digit, and character string. |
Not more than |
match="notMore:value" |
Not more than the specified value. The supported data types include date, digit, and character string. |
Equal |
match="equal:value" |
Equal to the specified value. The supported data types include date, digit, character string, OID, and BOOL. |
Not equal |
match="notEqual:value" |
Not equal to the specified value. The supported data types include date, digit, character string, OID, and BOOL. |
Include |
match="include:string" |
Includes the specified string. The supported data types include only character string. |
Not include |
match="exclude:string" |
Excludes the specified string. The supported data types include only character string. |
Start with |
match="startWith:string" |
Starts with the specified string. The supported data types include character string and OID. |
End with |
match="endWith:string" |
Ends with the specified string. The supported data types include only character string. |
# Copy the following text to the client to retrieve extension information about the entity of which the CPU usage is more than 50%:
<get>
<Device>
<ExtPhysicalEntities>
<Entity>
<CpuUsage h3c:match="more:50"></CpuUsage>
</Entity>
</ExtPhysicalEntities>
</Device>
</top>
</filter>
</get>
</rpc>
Example for filtering data with regular expression match
Retrieve all data including Ten-Gigabit in the Description column of the Interfaces table under the Ifmgr module.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Retrieve all data including Ten-Gigabit in the Description column of the Interfaces table under the Ifmgr module.
xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:reg="http://www.h3c.com/netconf/base:1.0">
<get>
<Ifmgr>
<Interfaces>
<Interface>
<Description h3c:regExp="(Ten-Gigabit)+"/>
</Interface>
</Interfaces>
</Ifmgr>
</top>
</filter>
</get>
</rpc>
If the client receives the following text, the operation is successful:
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:reg="http://www.h3c.com/netconf/base:1.0" message-id="100">
<data>
<Ifmgr>
<Interfaces>
<Interface>
<IfIndex>2681</IfIndex>
<Description>Ten-GigabitEthernet1/0/1 Interface</Description>
</Interface>
<Interface>
<IfIndex>2682</IfIndex>
<Description>Ten-GigabitEthernet1/0/2 Interface</Description>
</Interface>
<Interface>
<IfIndex>2683</IfIndex>
<Description>Ten-GigabitEthernet1/0/3 Interface</Description>
</Interface>
<Interface>
<IfIndex>2684</IfIndex>
<Description>Ten-GigabitEthernet1/0/4 Interface</Description>
</Interface>
</Interfaces>
</Ifmgr>
</top>
</data>
</rpc-reply>
Example for filtering data by conditional match
Retrieve data in the Name column with the ifindex value not less than 5000 in the Interfaces table under the Ifmgr module.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Retrieve data in the Name column with the ifindex value not less than 5000 in the Interfaces table under the Ifmgr module.
xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:nc="http://www.h3c.com/netconf/base:1.0">
<get>
<Ifmgr>
<Interfaces>
<Interface>
<IfIndex h3c:match="notLess:5000"/>
<Name/>
</Interface>
</Interfaces>
</Ifmgr>
</top>
</filter>
</get>
</rpc>
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:nc="http://www.h3c.com/netconf/base:1.0" message-id="100">
<data>
<Ifmgr>
<Interfaces>
<Interface>
<IfIndex>7241</IfIndex>
<Name>NULL0</Name>
</Interface>
<Interface>
<IfIndex>7243</IfIndex>
<Name>Register-Tunnel0</Name>
</Interface>
</Interfaces>
</Ifmgr>
</top>
</data>
</rpc-reply>
You can enclose command lines in XML messages to configure the device.
# Copy the following text to the client to execute the commands:
<CLI>
<Execution>
Commands
</Execution>
</CLI>
</rpc>
The <Execution> element can contain multiple commands, with one command on one line.
After receiving the CLI operation request, the device returns a response in the following format if the CLI operation is successful:
<CLI>
<Execution>
<![CDATA[Responses to the commands]]>
</Execution>
</CLI>
</rpc-reply>
CLI operation example
Configuration requirements
Send the display current-configuration command to the device.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Copy the following text to the client to execute the display current-configuration command:
<CLI>
<Execution>
</Execution>
</CLI>
</rpc>
<CLI>
<Execution><![CDATA[
<Sysname>display current-configuration
version 7.1.045, ESS 2305
sysname Sysname
telnet server enable
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 1
</Execution>
</CLI>
</rpc-reply>
You can use the get-sessions operation to retrieve NETCONF session information of the device.
# Copy the following message to the client to retrieve NETCONF session information from the device:
<get-sessions/>
</rpc>
After receiving the get-sessions request, the device returns a response in the following format if the get-sessions operation is successful:
<get-sessions>
<Session>
<SessionID>Configuration session ID</SessionID>
<Line>Line information</Line>
<UserName>Name of the user creating the session</UserName>
<Since>Time when the session was created</Since>
<LockHeld>Whether the session holds a lock</LockHeld>
</Session>
</get-sessions>
</rpc-reply>
For example, to get NETCONF session information:
# Enter XML view.
<Sysname> xml
# Copy the following message to the client to exchange capabilities with the device:
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Copy the following message to the client to get the current NETCONF session information on the device:
<get-sessions/>
</rpc>
If the client receives a message as follows, the operation is successful:
<get-sessions>
<Session>
<SessionID>1</SessionID>
<Line>vty0</Line>
<UserName></UserName>
<Since>2011-01-05T00:24:57</Since>
<LockHeld>false</LockHeld>
</Session>
</get-sessions>
</rpc-reply>
· The session ID of an existing NETCONF session is 1.
· The login user type is vty0.
· The login time is 2011-01-05T00:24:57.
· The user does not hold the lock of the configuration.
NETCONF allows one client to terminate the NETCONF session of another client. The client whose session is terminated returns to user view.
# Copy the following message to the client to terminate the specified NETCONF session:
<kill-session>
<session-id>
Specified session-ID
</session-id>
</kill-session>
</rpc>
After receiving the kill-session request, the device returns a response in the following format if the kill-session operation is successful:
<ok/>
</rpc-reply>
Configuration example
The user whose session's ID is 1 terminates the session with session ID 2.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Terminate the session with session ID 2.
<kill-session>
<session-id>2</session-id>
</kill-session>
</rpc>
If the client receives the following text, the NETCONF session with session ID 2 has been terminated. The client with session ID 2 has returned from XML view to user view:
<ok/>
</rpc-reply>
To return from XML view to the CLI, send the following close-session request:
<close-session/>
</rpc>
When the device receives the close-session request, it sends the following response and returns to CLI's user view:
<ok/>
</rpc-reply>
Appendix
Table 23 lists the NETCONF operations available with Comware V7.
Operation |
XML example |
get |
Retrieves device configuration and state information. |
To retrieve device configuration and state information for the Syslog module: |
get-config |
Retrieves the non-default configuration data. If non-default configuration data does not exist, the device returns a response with empty data. |
To retrieve non-default configuration data for the interface table: |
get-bulk |
Retrieves a number of data entries (including device configuration and state information) starting from the data entry next to the one with the specified index. |
To retrieve device configuration and state information for all interface: |
get-bulk-config |
Retrieves a number of non-default configuration data entries starting from the data entry next to the one with the specified index. |
To retrieve non-default configuration for all interfaces: |
edit-config: incremental |
Adds configuration data to a column without affecting the original data. The incremental attribute applies to a list column such as the vlan permitlist column. You can use the incremental attribute for edit-config operations except for the replace operation. Support for the incremental attribute varies by module. For more information, see NETCONF XML API documents. |
To add VLANs 1 through 10 to an untagged VLAN list that has untagged VLANs 12 through 15: |
edit-config: merge |
Changes the running configuration. To use the merge attribute in the edit-config operation, you must specify the operation target (on a specified level): · If the specified target exists, the operation directly changes the configuration for the target. · If the specified target does not exist, the operation creates and configures the target. · If the specified target does not exist and it cannot be created, an error message is returned. |
To change the buffer size to 120: |
edit-config: create |
Creates a specified target. To use the create attribute in the edit-config operation, you must specify the operation target. · If the table supports target creation and the specified target does not exist, the operation creates and then configures the target. · If the specified target exists, a data-exist error message is returned. |
The XML data format is the same as the edit-config message with the merge attribute. Change the operation attribute from merge to create. |
edit-config: replace |
Replaces the specified target. · If the specified target exists, the operation replaces the configuration of the target with the configuration carried in the message. · If the specified target does not exist, the operation is not conducted and an invalid-value error message is returned. |
The syntax is the same as the edit-config message with the merge attribute. Change the operation attribute from merge to replace. |
edit-config: remove |
Removes the specified configuration. · If the specified target has only the table index, the operation removes all configuration of the specified target, and the target itself. · If the specified target has the table index and configuration data, the operation removes the specified configuration data of this target. · If the specified target does not exist, or the XML message does not specify any target, a success message is returned. |
The syntax is the same as the edit-config message with the merge attribute. Change the operation attribute from merge to remove. |
edit-config: delete |
Deletes the specified configuration. · If the specified target has only the table index, the operation removes all configuration of the specified target, and the target itself. · If the specified target has the table index and configuration data, the operation removes the specified configuration data of this target. · If the specified target does not exist, an error message is returned, showing that the target does not exist. |
The syntax is the same as the edit-config message with the merge attribute. Change the operation attribute from merge to delete. |
edit-config: default-operation |
Modifies the current configuration of the device using the default operation method. If you do not specify an operation attribute for an edit-config message, NETCONF uses one of the following default operation attributes: merge, create, delete, and replace. Your setting of the value for the <default-operation> element takes effect only once. If you do not specify an operation attribute and the default operation method for an <edit-config> message, merge is always applied. · merge—The default value for the <default-operation> element. · replace—Value used when the operation attribute is not specified and the default operation method is specified as replace. · none—Value used when the operation attribute is not specified and the default operation method is specified as none. If this value is specified, the edit-config operation is used only for schema verification rather than issuing a configuration. If the schema verification is passed, a successful message is returned. Otherwise, an error message is returned. |
To issue an empty operation for schema verification purposes: |
edit-config: error-option |
Determines the action to take in case of a configuration error. The error-option element has one of the following values: · stop-on-error—Stops the operation on error and returns an error message. This is the default error-option value. · continue-on-error—Continues the operation on error and returns an error message. · rollback-on-error—Rolls back the configuration. |
To issue the configuration for two interfaces with the error-option element value as continue-on-error: |
edit-config: test-option |
Determines whether to issue a configuration item in the edit-configure operation. The test-option element has one of the following values: · test-then-set—Performs a validation test before attempting to set. If the validation test fails, the edit-config operation is not performed. This is the default test-option value. · set—Directly performs the set operation without the validation test. · test-only—Performs only a validation test without attempting to set. If the validation test succeeds, a successful message is returned. Otherwise, an error message is returned. |
To issue the configuration for an interface for test purposes: |
action |
Issues actions that are not for configuring data, for example, reset action. |
To clear statistics information for all interfaces: |
lock |
Locks the configuration data made through NETCONF sessions. The configuration data can be changed by the edit-config operation. Other configurations are not limited by the lock operation. This lock operation does not lock configurations made through other protocols, for example, SNMP. |
To lock the configuration: |
unlock |
Unlocks the configuration, so NETCONF sessions can change device configuration. When a NETCONF session is terminated, the related locked configuration is also unlocked. |
To unlock the configuration: |
get-sessions |
Retrieves information about all NETCONF sessions in the system. |
To retrieve information about all NETCONF sessions in the system: |
close-session |
Terminates the NETCONF session for the current user, to unlock the configuration and release the resources (for example, memory) of this session. This operation logs the current user off the XML view. |
To terminate the NETCONF session for the current user: |
kill-session |
Terminates the NETCONF session for another user. This operation cannot terminate the NETCONF session for the current user. |
To terminate the NETCONF session with session-id 1: |
CLI |
Executes CLI operations. A request message encloses commands in the <CLI> element, and a response message encloses the command output in the <CLI> element. NETCONF supports the following views: · Execution—Use view. · Configuration—System view. To execute a command in other views, specify the command for entering the specified view, and then the desired command. |
To execute the display this command in system view: |
save |
Saves the running configuration. You can use the <file> element to specify a file for saving the configuration. If the <file> element does not exist, the running configuration is saved to the main next-startup configuration file. |
To save the running configuration to the file test.cfg: |
load |
Loads the configuration. After the device finishes the load operation, the configuration in the specified file is merged into the current configuration of the device. |
To merge the configuration in the file a1.cfg to the current configuration of the device: |
rollback |
Rolls back the configuration. To do so, you must specify the configuration file in the <file> element. After the device finishes the rollback operation, the current device configuration is totally replaced with the configuration in the specified configuration file. |
To roll back the current configuration to the configuration in the file 1A.cfg: |
A
access control
SNMP MIB, 63
SNMP mode, 64
SNMP view-based MIB, 63
accessing
NTP access control, 10
NTP access control rights, 15
address reachability determination (ping), 1
agent
NMM sFlow configuration, 107
SNMP agent host notification, 72
Appendix A (supported NETCONF operations), 234
applying
flow mirroring QoS policy, 103
flow mirroring QoS policy (global), 103
flow mirroring QoS policy (interface), 103
flow mirroring QoS policy (VLAN), 103
architecture
NTP, 8
assigning
port mirroring monitor port to remote probe VLAN, 91
associating
NMM NTP broadcast association mode, 29
NMM NTP broadcast association mode with authentication, 36
NMM NTP client/server mode with MPLS VPN time synchronization, 38
NMM NTP multicast association mode, 31
NMM NTP symmetric active/passive mode with MPLS VPN time synchronization, 40
NTP association mode, 13
NTP broadcast association mode, 9, 14
NTP client/server association mode, 9, 13, 26
NTP client/server association mode+authentication, 34
NTP multicast association mode, 9, 15
NTP symmetric active/passive association mode, 9, 13, 28
authenticating
NMM NTP broadcast mode with authentication, 36
NTP, 11
NTP broadcast authentication, 20
NTP client/server mode authentication, 16
NTP client/server mode+authentication, 34
NTP configuration, 16
NTP multicast authentication, 22
NTP security, 10
NTP symmetric active/passive mode authentication, 17
SNTP authentication, 44
B
bidirectional
port mirroring, 82
broadcast
NMM NTP association mode, 29
NTP broadcast association mode, 9, 14, 20
NTP broadcast client configuration, 14
NTP broadcast mode dynamic associations max, 25
NTP broadcast server configuration, 14
buffer
information center log buffer, 54
C
changing
NETCONF parameter value, 216
classifying
port mirroring classification, 83
CLI
EAA configuration, 112, 120
EAA monitor policy configuration, 116, 120
EAA monitor policy configuration (CLI-defined+environment variables), 123
NETCONF CLI operations, 229, 229
NETCONF return to CLI, 233
client
NQA client history record save, 150
NQA client operation (DHCP), 132
NQA client operation (DLSw), 143
NQA client operation (DNS), 133
NQA client operation (FTP), 134
NQA client operation (HTTP), 135
NQA client operation (ICMP echo), 130
NQA client operation (path jitter), 144
NQA client operation (SNMP), 137
NQA client operation (TCP), 138
NQA client operation (UDP echo), 139
NQA client operation (UDP jitter), 136
NQA client operation (UDP tracert), 140
NQA client operation (voice), 141
NQA client operation scheduling, 151
NQA client statistics collection, 150
NQA client template, 151
NQA client template (DNS), 153
NQA client template (FTP), 160
NQA client template (HTTP), 157
NQA client template (HTTPS), 159
NQA client template (ICMP), 152
NQA client template (SSL), 161
NQA client template (TCP half open), 155
NQA client template (TCP), 154
NQA client template (UDP), 156
NQA client template optional parameters, 162
NQA client threshold monitoring, 128, 147
NQA client+Track collaboration, 146
NQA collaboration configuration, 188
NQA collaboration configuration (on router), 186
NQA enable, 129
NQA operation, 130
NQA operation configuration (DHCP), 168
NQA operation configuration (DLSw), 183
NQA operation configuration (DNS), 169
NQA operation configuration (FTP), 170
NQA operation configuration (HTTP), 171
NQA operation configuration (ICMP echo), 163
NQA operation configuration (path jitter), 184
NQA operation configuration (SNMP), 175
NQA operation configuration (TCP), 176
NQA operation configuration (UDP echo), 177
NQA operation configuration (UDP jitter), 172
NQA operation configuration (UDP tracert), 179
NQA operation configuration (voice), 180
NTP multicast client configuration, 15
SNTP configuration, 12, 12, 43, 43, 45
client/server
NMM NTP client/server mode MPLS VPN time synchronization, 38
NTP association mode, 9, 13
NTP client/server association mode, 16, 26
NTP client/server mode dynamic associations max, 25
clock
NTP local clock as reference source, 26
collaborating
NQA client+Track function, 146
NQA+Track collaboration, 127
collector
common
information center common logs, 47
conditional match NETCONF data filtering, 223, 228
conditional match NETCONF data filtering (column-based), 225
configuring
EAA, 112, 120
EAA environment variable (user-defined), 116
EAA monitor policy, 116
EAA monitor policy (CLI), 116
EAA monitor policy (CLI-defined), 120
EAA monitor policy (CLI-defined+environment variables), 123
EAA monitor policy (Tcl), 118
EAA monitor policy (Tcl-defined), 124
flow mirroring, 101, 101, 104
flow mirroring match criteria, 102
flow mirroring QoS policy, 102
flow mirroring traffic behavior, 102
information center, 47, 52, 59
information center trace log file max size, 56
Layer 2 remote port mirroring, 89, 98
local port mirroring, 85
local port mirroring (in source CPU mode), 96
local port mirroring (in source port mode), 95
local port mirroring group monitor port, 87
local port mirroring group monitor port (interface view), 87
local port mirroring group monitor port (system view), 87
local port mirroring group source CPUs, 86
local port mirroring group source ports, 86
local port mirroring group source ports (interface view), 86
local port mirroring group source ports (system view), 86
local port mirroring with multiple monitor ports, 97
NETCONF, 199, 202
NMM sFlow, 106, 106, 109
NMM sFlow agent, 107
NMM sFlow collector information, 107
NMM sFlow counter sampling, 108
NMM sFlow flow sampling, 107
NMM SNMPv3 (RBAC mode ), 77
NMM SNMPv3 (VACM mode ), 76
NQA, 126, 128, 163
NQA client operation, 130
NQA client operation optional parameters, 145
NQA client threshold monitoring, 147
NQA collaboration, 188
NQA collaboration (on router), 186
NQA operation (DHCP), 168
NQA operation (DLSw), 183
NQA operation (DNS), 169
NQA operation (FTP), 170
NQA operation (HTTP), 171
NQA operation (ICMP echo), 163
NQA operation (path jitter), 184
NQA operation (SNMP), 175
NQA operation (TCP), 176
NQA operation (UDP echo), 177
NQA operation (UDP jitter), 172
NQA operation (UDP tracert), 179
NQA operation (voice), 180
NQA server, 128
NQA template (DNS), 191
NQA template (FTP), 196
NQA template (HTTP), 195
NQA template (HTTPS), 195
NQA template (ICMP), 190
NQA template (SSL), 197
NQA template (TCP half open), 193
NQA template (TCP), 192
NQA template (UDP), 194
NTP, 7, 12, 26
NTP broadcast association mode, 14
NTP broadcast client, 14
NTP broadcast mode authentication, 20
NTP broadcast server, 14
NTP client/server association mode, 13, 26
NTP dynamic associations max, 25
NTP multicast association mode, 15
NTP multicast client, 15
NTP multicast mode authentication, 22
NTP multicast server, 15
NTP optional parameters, 24
NTP symmetric active/passive association mode, 13, 28
port mirroring, 95
port mirroring remote destination group monitor port, 90
port mirroring remote destination group remote probe VLAN, 91
remote port mirroring destination group, 90
remote port mirroring source group, 92
remote port mirroring source group egress port, 93
remote port mirroring source group remote probe VLAN, 94
remote port mirroring source group source CPUs, 93
remote port mirroring source group source ports, 92
sampler, 81
SNMP, 63
SNMP basics, 65
SNMP logging, 71
SNMP notification, 71
SNMPv1, 74
SNMPv1 agent host notification, 72
SNMPv1 basics, 65
SNMPv2c, 74
SNMPv2c agent host notification, 72
SNMPv2c basics, 65
SNMPv3 agent host notification, 72
SNMPv3 basics, 67
SNTP, 12, 12, 43, 43, 45
console
information center log output, 52, 59
controlling
CPU
flow mirroring configuration, 101, 101, 104
creating
local port mirroring group, 85
port mirroring remote destination group, 90
port mirroring remote source group, 92
sampler, 81
D
data
NETCONF configuration data retrieval (all modules), 212
NETCONF configuration data retrieval (Syslog module), 214
NETCONF data entry retrieval (interface table), 215
NETCONF filtering (conditional match), 223, 228
NETCONF filtering (full match), 223
NETCONF filtering (regex match), 223, 226
NMM NETCONF filtering (column-based), 224
NMM NETCONF filtering (column-based) (conditional match), 225
NMM NETCONF filtering (column-based) (full match), 224
NMM NETCONF filtering (column-based) (regex match), 225
NMM NETCONF filtering (table-based), 224
debugging
feature module, 6
information control module debugging switch, 5
information control screen output switch, 5
system maintenance, 1
default
information center log default output rules, 48
system information diagnostic log output rules, 48
system information hidden log output rules, 49
system information trace log output rules, 49
destination
destination device, 82
information center system logs, 48
port mirroring, 82
determining
ping address reachability determination, 1
device
information center configuration, 47, 52, 59
information center log output (console), 59, 59
information center log output (Linux log host), 61
information center log output (UNIX log host), 59
information center system log types, 47
Layer 2 remote port mirroring, 98
Layer 2 remote port mirroring configuration, 89
local port mirroring configuration, 85
local port mirroring configuration (in source CPU mode), 96
local port mirroring configuration (in source port mode), 95
local port mirroring configuration with multiple monitor ports, 97
NETCONF capability exchange, 204
NETCONF configuration, 199, 202
NETCONF configuration lock/unlock, 207, 208
NETCONF edit-config operation, 212
NETCONF get/get-bulk operation, 210
NETCONF get-config/get-bulk-config operation, 211
NETCONF save-point/begin operation, 219
NETCONF save-point/commit operation, 219
NETCONF save-point/end operation, 220
NETCONF save-point/get-commit-information operation, 221
NETCONF save-point/get-commits operation, 220
NETCONF save-point/rollback operation, 220
NETCONF service operations, 209
NETCONF session information retrieval, 230
NETCONF session termination, 232
NMM NTP MPLS L3VPN support, 11
NMM SNMPv3 configuration (RBAC mode ), 77
NMM SNMPv3 configuration (VACM mode ), 76
NQA server, 128
NTP architecture, 8
port mirroring configuration, 82, 95
port mirroring remote source group egress port, 93
port mirroring remote source group remote probe VLAN, 94
port mirroring remote source group source CPUs, 93
port mirroring remote source group source ports, 92
SNMP basics configuration, 65
SNMP configuration, 63
SNMP MIB, 63
SNMP view-based MIB access control, 63
SNMPv1 basics configuration, 65
SNMPv1 configuration, 74
SNMPv2c basics configuration, 65
SNMPv2c configuration, 74
SNMPv3 basics configuration, 67
DHCP
NQA client operation, 132
NQA operation configuration, 168
diagnosing
information center diagnostic log, 47
information center diagnostic log save (log file), 55
direction
port mirroring (bidirectional), 82
port mirroring (inbound), 82
port mirroring (outbound), 82
disabling
information center interface link up/link down log generation, 57
NTP message processing, 25
displaying
EAA settings, 120
information center, 58
NMM sFlow, 108
NQA, 163
NTP, 26
port mirroring, 94
sampler, 81
SNMP settings, 73
SNTP, 45
DLSw
NQA client operation, 143
NQA operation configuration, 183
DNS
NQA client operation, 133
NQA client template, 153
NQA operation configuration, 169
NQA template configuration, 191
DSCP
NTP packet value setting, 25
duplicate log suppression, 57
dynamic
E
environment variable configuration (user-defined), 116
event monitor, 112
event monitor policy action, 114
event monitor policy element, 113
event monitor policy environment variable, 114
event monitor policy event types, 113
event monitor policy runtime, 114
event monitor policy user role, 114
event source, 112
how it works, 112
monitor policy, 113
monitor policy configuration (CLI), 116
monitor policy configuration (CLI-defined), 120
monitor policy configuration (Tcl), 118
monitor policy configuration (Tcl-defined), 124
monitor policy configuration restrictions, 116
monitor policy suspension, 119
RTM, 113
settings display, 120
echo
egress port
Layer 2 remote port mirroring, 83, 98
Embedded Automation Architecture. Use EAA
enabling
information center duplicate log suppression, 57
information center synchronous output, 56
NETCONF logging, 203
NETCONF over SOAP, 202
NETCONF over SSH, 203
NQA client, 129
NTP, 13
SNTP, 43
entering
NETCONF XML view, 204
environment
EAA environment variable configuration (user-defined), 116
EAA event monitor policy environment variable, 114
establishing
NETCONF session, 203
Ethernet
NMM sFlow configuration, 106, 106, 109
sampler configuration, 81
event
EAA event monitor, 112
EAA event monitor policy element, 113
EAA event source, 112
EAA monitor policy, 113
NETCONF event notification subscription, 205, 206
exchanging
NETCONF capabilities, 204
F
file
information center diagnostic log output destination, 55
information center log save (log file), 54
filtering
NETCONF data (conditional match), 228
NETCONF data (regex match), 226
NMM NETCONF data filtering (column-based), 224
NMM NETCONF data filtering (table-based), 224
FIPS compliance
information center, 52
NETCONF, 202
SNMP, 63
fixed mode (NMM sampler), 81
flow
mirroring. See flow mirroring
Sampled Flow. Use sFlow
match criteria configuration, 102
QoS policy application, 103
QoS policy application (global), 103
QoS policy application (interface), 103
QoS policy application (VLAN), 103
QoS policy configuration, 102
traffic behavior configuration, 102
format
information center system logs, 49
NETCONF message, 200
FTP
NQA client operation, 134
NQA client template, 160
NQA operation configuration, 170
NQA template configuration, 196
full match NETCONF data filtering, 223
full match NETCONF data filtering (column-based), 224
G
generating
get operation
NETCONF get/get-bulk, 210
NETCONF get-config/get-bulk-config, 211
SNMP, 64
SNMP logging, 71
group
local port mirroring group source CPU, 86
local port mirroring group source port, 86
port mirroring group, 83
H
hidden log (information center), 47
history
host
information center log output (log host), 54
HTTP
NETCONF over SOAP (HTTP-based), 202
NETCONF over SOAP (HTTPS-based), 202
NQA client operation, 135
NQA client template, 157
NQA operation configuration, 171
NQA template configuration, 195
HTTPS
I
ICMP
NQA client template, 152
NQA template configuration, 190
ping command, 1, 1
identifying
node failure with tracert, 4
implementing
local port mirroring, 83
port mirroring, 83
remote port mirroring, 84
inbound
port mirroring, 82
information center
diagnostic log default output rules, 48
display, 58
FIPS compliance, 52
hidden log default output rules, 49
log output (console), 52, 59
log output (log buffer), 54
log output (monitor terminal), 53
maintain, 58
synchronous log output, 56
system information log types, 47
system log destinations, 48
system log formats, 49
system log levels, 47
trace log default output rules, 49
Internet
NQA configuration, 126, 128, 163
SNMP MIB, 63
interval
sampler creation, 81
IP addressing
tracert, 3, 4
tracert node failure identification, 4
IP services
NQA template configuration (DNS), 191
NQA template configuration (FTP), 196
NQA template configuration (HTTP), 195
NQA template configuration (HTTPS), 195
NQA template configuration (ICMP), 190
NQA template configuration (SSL), 197
NQA template configuration (TCP half open), 193
NQA template configuration (TCP), 192
NQA template configuration (UDP), 194
L
Layer 2
Layer 3
tracert, 3, 4
level
information center system logs, 47
link
Linux
information center log host output, 61
loading
NETCONF configuration, 217, 222
local
port mirroring, 83
port mirroring group creation, 85
configuration, 97
locking
NETCONF configuration, 207, 208
logging
information center diagnostic logs, 47
information center hidden logs, 47
information center log output (console), 52, 59
information center log output (log buffer), 54
information center log output (monitor terminal), 53
information center synchronous log output, 56
information center system log destinations, 48
information center system log formats, 49
information center system log levels, 47
NETCONF logging enable, 203
SNMP configuration, 71
system information diagnostic log default output rules, 48
system information hidden log default output rules, 49
system information trace log default output rules, 49
M
maintaining
Management Information Base. Use MIB
matching
NETCONF data filtering (conditional match), 223, 228
NETCONF data filtering (full match), 223
NETCONF data filtering (regex match), 223, 226
NETCONF data filtering (table-based match), 223
NMM NETCONF data filtering (column-based) (conditional match), 225
NMM NETCONF data filtering (column-based) (full match), 224
NMM NETCONF data filtering (column-based) (regex match), 225
message
NETCONF format, 200
NTP message processing disable, 25
NTP message source interface, 24
SNMP, 63, 63
SNMP get operation, 64
SNMP set operation, 64
SNMP view-based access control, 63
mirroring
flow. See flow mirroring
port. See port mirroring
mode
NTP association, 13
NTP broadcast association, 9, 14
NTP client/server association, 9, 13
NTP multicast association, 9, 15
NTP symmetric active/passive association, 9, 13
sampler fixed, 81
SNMP access control (rule-based), 64
SNMP access control (view-based), 64
module
feature module debug, 6
monitor terminal
information center log output, 53
monitoring
configuring local mirroring to support multiple monitor ports, 88
NQA threshold monitoring, 128
MPLS L3VPN
NMM NTP support, 11
multicast
NTP multicast mode dynamic associations max, 25
NTP multicast server configuration, 15
N
CLI return, 233
configuration load, 217, 222
configuration rollback, 217
configuration rollback (configuration-file-based), 218
configuration rollback (rollback-point-based), 218
configuration save, 217, 217, 223
data filtering, 223
data filtering (conditional match), 228
data filtering (regex match), 226
FIPS compliance, 202
message format, 200
NETCONF over SSH enable, 203
over SOAP, 200
over SOAP enable, 202
parameter value change, 216
protocols and standards, 201
session establishment, 203
session idle timeout time set, 204
supported operations, 234
XML view, 204
NetStream
network
flow mirroring QoS policy application, 103
flow mirroring QoS policy application (global), 103
flow mirroring QoS policy application (interface), 103
flow mirroring QoS policy application (VLAN), 103
Network Configuration Protocol. Use NETCONF
NMM sFlow counter sampling configuration, 108
NMM sFlow flow sampling configuration, 107
NQA server, 128
NTP authentication, 16
ping connectivity test, 1
quality analyzer. See NQA
SNTP NTP server specification, 43
tracert node failure identification, 4, 4
network management
NTP configuration, 7, 12, 26
ping, 1, 1
system debugging, 1
tracert, 1
Network Time Protocol. Use NTP
NMM
EAA monitor policy configuration (CLI), 116
EAA monitor policy configuration (CLI-defined), 120
EAA monitor policy configuration (Tcl), 118
EAA monitor policy configuration (Tcl-defined), 124
EAA monitor policy suspension, 119
EAA RTM, 113
EAA settings display, 120
information center display, 58
information center log destinations, 48
information center log formats, 49
information center log levels, 47
information center maintain, 58
NETCONF CLI return, 233
NETCONF configuration load, 217
NETCONF configuration rollback, 217
NETCONF configuration save, 217
NETCONF over SOAP enable, 202
NETCONF parameter value change, 216
NETCONF session establishment, 203
NETCONF supported operations, 234
NQA display, 163
NQA server, 128
NTP architecture, 8
NTP authentication configuration, 16
NTP broadcast association mode configuration, 14, 29
NTP broadcast mode authentication configuration, 20
NTP client/server association mode configuration, 26
NTP client/server mode authentication configuration, 16
NTP display, 26
NTP enable, 13
NTP message source interface specification, 24
NTP multicast association mode configuration, 31
NTP multicast mode authentication configuration, 22
NTP optional parameter configuration, 24
NTP packet DSCP value setting, 25
NTP protocols and standards, 12
NTP security, 10
NTP symmetric active/passive association mode configuration, 28
NTP symmetric active/passive mode authentication configuration, 17
port mirroring display, 94
port mirroring implementation, 83
sFlow agent configuration, 107
sFlow collector information configuration, 107
SNMP access control mode, 64
SNMP framework, 63
SNMP logging configuration, 71
SNMP MIB, 63
SNMP protocol versions, 64
SNMP settings display, 73
SNTP display, 45
SNTP enable, 43
system debugging, 1, 5
tracert, 3, 4
NMS
SNMP Notification operation, 64
SNMP set operation, 64, 64
notifying
client enable, 129
client template configuration, 151
display, 163
how it works, 126
server configuration, 128
supported operations, 126
Track collaboration function, 127
access control, 10
access control rights configuration, 15
architecture, 8
association mode configuration, 13
authentication, 11
client/server association mode configuration, 13, 26
configuration restrictions, 12
display, 26
enable, 13
how it works, 7
multicast association mode configuration, 15, 31
security, 10
SNTP server specification, 43
symmetric active/passive association mode configuration, 13, 28
symmetric active/passive mode dynamic associations max, 25
O
outbound
port mirroring, 82
outputting
information center logs (Linux log host), 61
information center logs (log buffer), 54
information center logs (UNIX log host), 59
information logs (console), 52, 59
information logs (log host), 54
information logs (monitor terminal), 53
P
packet
NTP DSCP value setting, 25
parameter
path
NQA operation configuration, 184
performing
ping
address reachability determination, 1, 1
network connectivity test, 1
policy
port
mirroring. See port mirroring
NTP client/server association mode, 26
NTP symmetric active/passive association mode, 28
classification, 83
destination, 82
direction (bidirectional), 82
direction (inbound), 82
direction (outbound), 82
display, 94
egress port, 83
implementation, 83
Layer 2 remote configuration, 89
Layer 2 remote port mirroring configuration, 98
local, 83
local configuration, 85
local group creation, 85
local group monitor port, 87
local group monitor port configuration restrictions, 87
local group source CPU, 86
local group source port, 86
local group source port configuration restrictions, 86
local mirroring configuration (in source CPU mode), 96
local mirroring configuration (in source port mode), 95
local mirroring configuration with multiple monitor ports, 97
local mirroring supporting multiple monitors configuration restrictions, 88
mirroring group, 83
monitor port to remote probe VLAN assignment, 91
reflector port, 83
remote, 84
remote destination group configuration, 90
remote destination group creation, 90
remote probe VLAN, 83
remote source group configuration, 92
source, 82
source device, 82
terminology, 82
procedure
applying flow mirroring QoS policy, 103
applying flow mirroring QoS policy (global), 103
applying flow mirroring QoS policy (interface), 103
applying flow mirroring QoS policy (VLAN), 103
changing NETCONF parameter value, 216
configuring EAA environment variable (user-defined), 116
configuring EAA monitor policy, 116
configuring EAA monitor policy (CLI), 116
configuring EAA monitor policy (CLI-defined), 120
configuring EAA monitor policy (CLI-defined+environment variables), 123
configuring EAA monitor policy (Tcl), 118
configuring EAA monitor policy (Tcl-defined), 124
configuring flow mirroring, 101, 104
configuring flow mirroring match criteria, 102
configuring flow mirroring QoS policy, 102
configuring flow mirroring traffic behavior, 102
configuring information center, 52
configuring information center trace log file max size, 56
configuring Layer 2 remote port mirroring, 89, 98
configuring local port mirroring, 85
configuring local port mirroring (in source CPU mode), 96
configuring local port mirroring (in source port mode), 95
configuring local port mirroring group monitor port, 87
configuring local port mirroring group monitor port (interface view), 87
configuring local port mirroring group monitor port (system view), 87
configuring local port mirroring group source CPUs, 86
configuring local port mirroring group source ports, 86
configuring local port mirroring group source ports (interface view), 86
configuring local port mirroring group source ports (system view), 86
configuring local port mirroring with multiple monitor ports, 97
configuring NETCONF, 202
configuring NMM NTP broadcast association mode, 29
configuring NMM NTP broadcast mode with authentication, 36
configuring NMM NTP client/server mode with MPLS VPN time synchronization, 38
configuring NMM NTP multicast association mode, 31
configuring NMM NTP symmetric active/passive mode with MPLS VPN time synchronization, 40
configuring NMM sFlow, 106, 109
configuring NMM sFlow agent, 107
configuring NMM sFlow collector information, 107
configuring NMM sFlow counter sampling, 108
configuring NMM sFlow flow sampling, 107
configuring NMM SNMPv3 (RBAC mode ), 77
configuring NMM SNMPv3 (VACM mode ), 76
configuring NQA, 128
configuring NQA client history record save, 150
configuring NQA client operation, 130
configuring NQA client operation (DHCP), 132
configuring NQA client operation (DLSw), 143
configuring NQA client operation (DNS), 133
configuring NQA client operation (FTP), 134
configuring NQA client operation (HTTP), 135
configuring NQA client operation (ICMP echo), 130
configuring NQA client operation (path jitter), 144
configuring NQA client operation (SNMP), 137
configuring NQA client operation (TCP), 138
configuring NQA client operation (UDP echo), 139
configuring NQA client operation (UDP jitter), 136
configuring NQA client operation (UDP tracert), 140
configuring NQA client operation (voice), 141
configuring NQA client operation optional parameters, 145
configuring NQA client statistics collection, 150
configuring NQA client template, 151
configuring NQA client template (DNS), 153
configuring NQA client template (FTP), 160
configuring NQA client template (HTTP), 157
configuring NQA client template (HTTPS), 159
configuring NQA client template (ICMP), 152
configuring NQA client template (SSL), 161
configuring NQA client template (TCP half open), 155
configuring NQA client template (TCP), 154
configuring NQA client template (UDP), 156
configuring NQA client template optional parameters, 162
configuring NQA client threshold monitoring, 147
configuring NQA client+Track collaboration, 146
configuring NQA collaboration, 188
configuring NQA collaboration (on router), 186
configuring NQA operation (DHCP), 168
configuring NQA operation (DLSw), 183
configuring NQA operation (DNS), 169
configuring NQA operation (FTP), 170
configuring NQA operation (HTTP), 171
configuring NQA operation (path jitter), 184
configuring NQA operation (SNMP), 175
configuring NQA operation (TCP), 176
configuring NQA operation (UDP echo), 177
configuring NQA operation (UDP jitter), 172
configuring NQA operation (UDP tracert), 179
configuring NQA operation (voice), 180
configuring NQA server, 128
configuring NQA template (DNS), 191
configuring NQA template (FTP), 196
configuring NQA template (HTTP), 195
configuring NQA template (HTTPS), 195
configuring NQA template (ICMP), 190
configuring NQA template (SSL), 197
configuring NQA template (TCP half open), 193
configuring NQA template (TCP), 192
configuring NQA template (UDP), 194
configuring NTP, 12
configuring NTP access control rights, 15
configuring NTP association mode, 13
configuring NTP broadcast association mode, 14
configuring NTP broadcast client, 14
configuring NTP broadcast mode authentication, 20
configuring NTP broadcast server, 14
configuring NTP client/server association mode, 13, 26
configuring NTP client/server mode authentication, 16
configuring NTP client/server mode+authentication, 34
configuring NTP dynamic associations max, 25
configuring NTP local clock as reference source, 26
configuring NTP multicast association mode, 15
configuring NTP multicast client, 15
configuring NTP multicast mode authentication, 22
configuring NTP multicast server, 15
configuring NTP optional parameters, 24
configuring NTP symmetric active/passive association mode, 13, 28
configuring NTP symmetric active/passive mode authentication, 17
configuring port mirroring monitor port to remote probe VLAN assignment, 91
configuring port mirroring remote destination group monitor port, 90
configuring port mirroring remote destination group on the destination device, 90
configuring port mirroring remote destination group remote probe VLAN, 91
configuring port mirroring remote source group egress port, 93
configuring port mirroring remote source group on source device, 92
configuring port mirroring remote source group remote probe VLAN, 94
configuring port mirroring remote source group source CPUs, 93
configuring port mirroring remote source group source ports, 92
configuring SNMP basic parameters, 65
configuring SNMP logging, 71
configuring SNMP notification, 71
configuring SNMPv1, 74
configuring SNMPv1 agent host notification, 72
configuring SNMPv1 basics, 65
configuring SNMPv2c, 74
configuring SNMPv2c agent host notification, 72
configuring SNMPv2c basics, 65
configuring SNMPv3 agent host notification, 72
configuring SNMPv3 basic parameters, 67
configuring SNTP, 12, 12, 43, 45
configuring SNTP authentication, 44
creating local port mirroring group, 85
creating port mirroring remote destination group, 90
creating port mirroring remote source group, 92
creating sampler, 81
debugging feature module, 6
determining address reachability with ping, 1
disabling information center interface link up/link down log generation, 57
disabling NTP message interface processing, 25
displaying EAA settings, 120
displaying information center, 58
displaying NMM sFlow, 108
displaying NQA, 163
displaying NTP, 26
displaying port mirroring, 94
displaying sampler, 81
displaying SNMP settings, 73
displaying SNTP, 45
enabling information center duplicate log suppression, 57
enabling information center synchronous log output, 56
enabling NETCONF logging, 203
enabling NETCONF over SOAP, 202
enabling NETCONF over SSH, 203
enabling NQA client, 129
enabling NTP, 13
enabling SNMP notification, 71
enabling SNTP, 43
entering NETCONF XML view, 204
establishing NETCONF session, 203
exchanging NETCONF capabilities, 204
filtering NETCONF data, 223
filtering NETCONF data (conditional match), 228
filtering NETCONF data (regex match), 226
identifying node failure with tracert, 4, 4
loading NETCONF configuration, 217, 222
locking NETCONF configuration, 207, 208
maintaining information center, 58
outputting information center logs (console), 52, 59
outputting information center logs (Linux log host), 61
outputting information center logs (log buffer), 54
outputting information center logs (log host), 54
outputting information center logs (monitor terminal), 53
outputting information center logs (UNIX log host), 59
performing NETCONF CLI operations, 229, 229
performing NETCONF edit-config operation, 212
performing NETCONF get/get-bulk operation, 210
performing NETCONF get-config/get-bulk-config operation, 211
performing NETCONF save-point/begin operation, 219
performing NETCONF save-point/commit operation, 219
performing NETCONF save-point/end operation, 220
performing NETCONF save-point/get-commit-information operation, 221
performing NETCONF save-point/get-commits operation, 220
performing NETCONF save-point/rollback operation, 220
performing NETCONF service operations, 209
retrieving NETCONF configuration data (all modules), 212
retrieving NETCONF configuration data (Syslog module), 214
retrieving NETCONF data entry (interface table), 215
retrieving NETCONF session information, 230
returning to NETCONF CLI, 233
rolling back NETCONF configuration, 217
rolling back NETCONF configuration (configuration-file-based), 218
rolling back NETCONF configuration (rollback-point-based), 218
saving information center diagnostic logs (log file), 55
saving information center log (log file), 54
saving NETCONF configuration, 217, 217, 223
scheduling NQA client operation, 151
setting NMM NETCONF session idle timeout time, 204
setting NTP packet DSCP value, 25
specifying NTP message source interface, 24
specifying SNTP NTP server, 43
subscribing to NETCONF event notifications, 205, 206
suspending EAA monitor policy, 119
terminating NETCONF session, 232
testing connectivity with ping, 1
troubleshooting NMM sFlow, 110
troubleshooting NMM sFlow remote collector cannot receive packets, 110
unlocking NETCONF configuration, 207, 208
NETCONF, 199, 201
NMM sFlow, 106
NTP, 12
SNMP versions, 64
Q
QoS
R
real-time
event manager. See RTM
reflector port
regex match NETCONF data filtering, 223, 226
regex match NETCONF data filtering (column-based), 225
regular expression. Use regex
remote
port mirroring, 84
port mirroring destination group creation, 90
port mirroring destination group monitor port, 90
port mirroring destination group remote probe VLAN, 91
port mirroring source group creation, 92
remote probe VLAN
port mirroring remote destination group, 91
restrictions
local mirroring supporting multiple monitor ports configuration, 88
local port mirroring group monitor port configuration, 87
local port mirroring group source port configuration, 86
SNTP configuration restrictions, 12, 12, 43
retrieving
returning
rollback
rolling back
router
NQA collaboration configuration, 186
routing
EAA, 113
rule
system information default diagnostic log output rules, 48
system information default hidden log output, 49
system information default trace log output, 49
runtime
EAA event monitor policy runtime, 114
S
sampler
configuration, 81
creation, 81
displaying, 81
sampling
NMM sFlow, 107
saving
NQA client history records, 150
scheduling
security
NTP, 10
NTP authentication, 11, 16
server
NQA configuration, 128
service
NETCONF operations, 209
session
set operation
SNMP, 64
SNMP logging, 71
setting
severity level (system information), 47
displaying, 108
protocols and standards, 106
troubleshooting, 110
troubleshooting remote collector cannot receive packets, 110
Simple Network Management Protocol. Use SNMP
Simplified NTP. See SNTP
agent, 63
agent notification, 71
basic parameter configuration, 65
configuration, 63
FIPS compliance, 63
framework, 63
get operation, 64, 71
manager, 63
MIB, 63, 63
MIB view-based access control, 63
notification configuration, 71
notification enable, 71
NQA client operation, 137
NQA operation configuration, 175
set operation, 64, 71
SNMPv1 basic parameter configuration, 65
SNMPv2c basic parameter configuration, 65
SNMPv3 basic parameter configuration, 67
SNMPv1
configuration, 74
protocol version, 64
SNMPv2c
configuration, 74
SNMPv3
authentication, 44
configuration restrictions, 12, 12, 12, 43
display, 45
enable, 43
SOAP
NETCONF message format, 200
source
port mirroring, 82
source device, 82
specifying
SNTP NTP server, 43
SSH
SSL
NQA template configuration, 197
statistics
NMM sFlow agent configuration, 107
NMM sFlow collector information configuration, 107
subscribing
suppressing
suspending
switch
module debug, 5
screen output, 5
symmetric
NMM NTP symmetric active/passive mode MPLS VPN time synchronization, 40
NTP symmetric active/passive association mode, 9, 13, 17, 28
NTP symmetric active/passive mode dynamic associations max, 25
synchronizing
NMM NTP client/server mode, 38
NMM NTP symmetric active/passive mode, 40
Syslog
system
information center log types, 47
information log formats, 49
system administration
debugging, 1, 5
ping, 1, 1
tracert, 1, 3, 4
system information
T
table-based match NETCONF data filtering, 223
Tcl
EAA monitor policy configuration, 118, 124
TCP
NQA client operation, 138
NQA client template, 154
NQA operation configuration, 176
NQA template configuration, 192
NQA template configuration (half open), 193
template
terminating
testing
ping network connectivity test, 1
threshold
NQA operation reaction entry, 147
NQA operation support accumulate type, 147
NQA operation support average type, 147
NQA operation support consecutive type, 147
NQA operation triggered action none, 147
NQA operation triggered action trap-only, 147
NQA operation triggered action trigger-only, 147
time
timeout
traceroute. See tracert
IP address retrieval, 3
node failure detection, 3, 4
tracing
Track
NQA collaboration, 127
traffic
trapping
triggering
NQA operation threshold triggered action none, 147
NQA operation threshold triggered action trap-only, 147
NQA operation threshold triggered action trigger-only, 147
troubleshooting
NMM sFlow, 110
U
UDP
NQA client template, 156
NQA template configuration, 194
UNIX
information center log host output, 59
unlocking
V
value
variable
EAA event monitor policy environment (user-defined), 115
EAA event monitor policy environment system-defined (event-specific), 115
EAA event monitor policy environment system-defined (public), 115
view
VLAN
port mirroring remote probe VLAN, 83
voice
NQA client operation, 141
NQA operation configuration, 180
VPN
X
XML
NETCONF data filtering (conditional match), 228
NETCONF data filtering (regex match), 226
NETCONF structure, 199
XSD
