00-Preface
Preface
The H3C SecPath M9000 Multi Service Security Gateway Series Installation Guide guides you through the installation of your gateway, including installing the gateway, logging in to and configuring the gateway, troubleshooting, and replacing FRUs.
This preface includes:
· Audience
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the M9000 security gateway series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Documentation feedback
We appreciate your comments.
