- 03-WLAN Command References
- 01-AP management commands
- 02-Radio management commands
- 03-WLAN access commands
- 04-WLAN security commands
- 05-WLAN authentication commands
- 06-WIPS commands
- 07-WLAN QoS commands
- 08-WLAN roaming commands
- 09-WLAN load balancing commands
- 10-WLAN radio resource measurement commands
- 11-Channel scanning commands
- 12-Band navigation commands
- 13-WLAN high availability commands
- 14-802.11r commands
- 15-Wireless location commands
- 16-AC hierarchy commands
- 17-WLAN RRM commands
- 18-WLAN IP snooping commands
- 19-WLAN probe commands
- 20-WLAN forwarding commands
- 21-Spectrum management commands
- 22-WLAN radio load balancing commands
- 23-User isolation commands
- 24-Packet capture commands
- 25-802.1X client commands
- 26-IP source guard commands
| 15-Wireless location commands | 98.04 KB |
display wlan rfid-tracking radio
rfid-tracking client rate-limit
rfid-tracking client rate-limit cir
rfid-tracking fingerprint engine-address
rfid-tracking fingerprint mu-report
rfid-tracking fingerprint raw-frame-report
rfid-tracking fingerprint report-format
rfid-tracking fingerprint report-mode
rfid-tracking fingerprint tag-multicast-address
rfid-tracking fingerprint vendor-port
snmp-agent trap enable wlan location-aware
Use display wlan rfid-tracking radio to display radio information for wireless location.
display wlan rfid-tracking radio [ ap ap-name ]
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The name can include letters, numbers, underscores (_), dots (.), left brackets ([), right brackets (]), slashes (/), and minus signs (-). If you do not specify this option, the command displays radio information for all APs.
# Display radio information for wireless location.
<Sysname> display wlan rfid-tracking radio
Wireless Locating
AP name Radio ID Type
ap1 1 MU/Tag
ap2 1 MU
ap3 2 Tag
ap4 1 N/A
Type |
Type of devices to locate: · MU/Tag—Both MU and Tag devices. · MU. · Tag. · N/A—The AP does not locate any devices. |
Use rfid-tracking client rate-limit enable to enable client packet rate limiting for an AP.
Use rfid-tracking client rate-limit disable to disable client packet rate limiting for an AP.
Use undo rfid-tracking client rate-limit to restore the default.
rfid-tracking client rate-limit { disable | enable }
In AP view, the configuration in AP group view is used. If no configuration exists in AP group view, the configuration in global configuration view is used.
In AP group view, the configuration in global configuration view is used.
In global configuration view, client packet rate limiting is disabled for an AP.
AP view
AP group view
Global configuration view
This feature enables an AP to not report location information from excessive client packets when both the CIR and CBS are exceeded. This feature ensures that the location information for each client can be sent to the location server and prevents client packets from flooding the AP.
If packet dilution is enabled, this feature limits the rate for diluted packets.
# Enable client packet rate limiting for AP ap1.
[Sysname] wlan ap ap1 model WA4320H
[Sysname-wlan-ap-ap1] rfid-tracking client rate-limit enable
# Enable client packet rate limiting for APs in AP group 10.
[Sysname] wlan ap-group 10
[Sysname-wlan-ap-group-10] rfid-tracking client rate-limit enable
# Enable client packet rate limiting globally.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] rfid-tracking client rate-limit enable
Use rfid-tracking client rate-limit cir to set the rate limits for client packets.
Use undo rfid-tracking client rate-limit cir to restore the default.
rfid-tracking client rate-limit cir cir [ cbs cbs ]
In global configuration view, both the CIR and the CBS are 0. An AP does not limit the rate for incoming wireless packets.
AP view
AP group view
cir cir: Specifies the CIR for client packets, in the range of 1 to 1300000 kbps.
cbs cbs: Specifies the CBS for client packets, in the range of 80 to 130000000 bytes. The default CBS is the CIR × 700 bytes.
The CIR and CBS configuration takes effect only when you enable client packet rate limiting.
# Set the CIR and CBS to 200000 kbps and 50000 bytes, respectively for client packets for AP ap1.
[Sysname-wlan-ap-ap1] rfid-tracking client rate-limit cir 200000 cbs 50000
# Set the CIR and CBS to 200000 kbps and 50000 bytes, respectively for client packets for APs in AP group 10.
[Sysname-wlan-ap-group-10] rfid-tracking client rate-limit cir 200000 cbs 50000
# Set the CIR to 200000 kbps and the CBS to 50000 bytes for client packets globally.
[Sysname-wlan-global-configuration] rfid-tracking client rate-limit cir 200000 cbs 50000
rfid-tracking dilution
Use rfid-tracking dilution enable to enable packet dilution.
Use rfid-tracking dilution disable to disable packet dilution.
Use undo rfid-tracking dilution to restore the default.
rfid-tracking dilution { disable | enable }
In global configuration view, packet dilution is disabled.
AP view
AP group view
For RF fingerprinting, this feature controls the number of location packets from an AP to the location server.
This feature takes effect only on MU clients for RF fingerprinting.
# Enable packet dilution for AP ap1.
[Sysname-wlan-ap-ap1] rfid-tracking dilution enable
# Enable packet dilution for APs in AP group 10.
[Sysname-wlan-ap-group-10] rfid-tracking dilution enable
# Enable packet dilution globally.
[Sysname-wlan-global-configuration] rfid-tracking dilution enable
rfid-tracking dilution factor
rfid-tracking mode mu
Use rfid-tracking dilution factor to set the packet dilution factor and the dilution timeout timer.
Use undo rfid-tracking dilution factor to restore the default.
rfid-tracking dilution factor factor timeout timeout
In global configuration view, the packet dilution factor and the dilution timeout timer are not set.
AP view
AP group view
factor factor: Specifies the dilution factor in the range of 1 to 10000.
timeout timeout: Specifies the dilution timeout timer in the range of 1 to 60 seconds.
Packet dilution takes effect only on MU clients for RF fingerprinting. For packet dilution to take effect, make sure RF fingerprinting is enabled.
If the dilution factor is 10 and the timeout timer is 5 seconds, the AP sends a location packet every time it receives 10 wireless packets from an MU client (excluding management and broadcast packets). If the AP fails to receive 10 packets from an MU client before the timeout timer expires, it sends the most recent wireless packet to the location server.
The dilution factor and dilution timeout timer take effect only when you enable packet dilution.
# Set the dilution factor to 10 and the dilution timeout timer to 10 seconds for AP ap1.
[Sysname-wlan-ap-ap1] rfid-tracking dilution factor 10 timeout 10
# Set the dilution factor to 10 and the dilution timeout timer to 10 seconds for APs in AP group 10.
[Sysname-wlan-ap-group-10] rfid-tracking dilution factor 10 timeout 10
# Set the dilution factor to 10 and the dilution timeout timer to 10 seconds globally.
[Sysname-wlan-global-configuration] rfid-tracking dilution factor 10 timeout 10
Use rfid-tracking fingerprint enable to enable RF fingerprinting.
Use rfid-tracking fingerprint disable to disable RF fingerprinting.
Use undo rfid-tracking fingerprint to restore the default.
rfid-tracking fingerprint { disable | enable }
In global configuration view, RF fingerprinting is disabled.
AP view
AP group view
For an AP to send location packets to the location server, you must enable both RF fingerprinting and radio-based location.
# Enable RF fingerprinting for AP ap1.
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint enable
# Enable RF fingerprinting for APs in AP group 10.
[Sysname-wlan-ap-group-10] rfid-tracking fingerprint enable
# Enable RF fingerprinting globally.
[Sysname-wlan-global-configuration] rfid-tracking fingerprint enable
rfid-tracking radio enable
Use rfid-tracking fingerprint engine-address to specify an IPv4 address and a port number for the RF fingerprinting server.
Use undo rfid-tracking fingerprint engine-address to restore the default.
rfid-tracking fingerprint engine-address engine-address engine-port engine-port
In global configuration view, the IPv4 address and port number for the RF fingerprinting server are not configured.
AP view
AP group view
engine-address engine-address: Specifies an IPv4 address for the RF fingerprinting server.
engine-port engine-port: Specifies a port number for the RF fingerprinting server, in the range of 1 to 65535.
APs send location packets to the specified IPv4 address and port number for communicating with the RF fingerprinting server.
# Set the IPv4 address and port number for the RF fingerprinting server to 192.168.10.10 and 1145 for AP ap1.
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint engine-address 192.168.10.10 engine-port 1145
# Set the IPv4 address and port number for the RF fingerprinting server to 192.168.10.10 and 1145 for APs in AP group 10.
[Sysname-wlan-ap-group10] rfid-tracking fingerprint engine-address 192.168.10.10 engine-port 1145
# Set the IPv4 address and port number for the RF fingerprinting server to 192.168.10.10 and 1145 globally.
[Sysname-wlan-global-configuration] rfid-tracking fingerprint engine-address 192.168.10.10 engine-port 1145
Use rfid-tracking fingerprint mu-report enable to enable MU information reporting.
Use rfid-tracking fingerprint mu-report disable to disable MU information reporting.
Use undo rfid-tracking fingerprint mu-report to restore the default.
rfid-tracking fingerprint mu-report { disable | enable }
In global configuration view, MU information reporting is disabled.
AP view
AP group view
This feature enables an AP to encapsulate MU information in location packets. MU information includes the IP address and the transmission rate of an MU.
# Enable MU information reporting for AP ap1.
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint mu-report enable
# Enable MU information reporting for APs in AP group 10.
[Sysname-wlan-ap-group10] rfid-tracking fingerprint mu-report enable
# Enable MU information reporting globally.
[Sysname-wlan-global-configuration] rfid-tracking fingerprint mu-report enable
Use rfid-tracking fingerprint raw-frame-report enable to enable raw frame reporting.
Use rfid-tracking fingerprint raw-frame-report disable to disable raw frame reporting.
Use undo rfid-tracking fingerprint raw-frame-report to restore the default.
rfid-tracking fingerprint raw-frame-report { disable | enable }
In global configuration view, raw frame reporting is disabled.
AP view
AP group view
This feature enables an AP to encapsulate both the raw frames and the location information obtained from the frames in location packets.
# Enable raw frame reporting for AP ap1.
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint raw-frame-report enable
#Enable raw frame reporting for APs in AP group 10.
[Sysname-wlan-ap-group10] rfid-tracking fingerprint raw-frame-report enable
# Enable raw frame reporting globally.
[Sysname-wlan-global-configuration] rfid-tracking fingerprint raw-frame-report enable
Use rfid-tracking fingerprint report-format to specify the location packet format for RF fingerprinting.
Use undo rfid-tracking fingerprint report-format to restore the default.
rfid-tracking fingerprint report-format { cupid-hybrid | general | light-weight }
In global configuration view, location packets for RF fingerprinting are in general format.
AP view
AP group view
cupid-hybrid: Specifies the CUPID-hybrid packet format.
general: Specifies the general packet format.
light-weight: Specifies the lightweight packet format.
RF fingerprinting supports the following location packet formats:
· CUPID-hybrid—An AP encapsulates only clients' MAC addresses and RSSIs in location packets.
· General—This format is applicable to most scenarios. Most third-party location servers support only the general format.
· Lightweight—An AP encapsulates location information for several clients in one lightweight location packet to save bandwidth. This format is applicable to traffic-sensitive scenarios.
# Configure AP ap1 to use the lightweight format to send RF fingerprinting location packets to the location server.
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint report-format light-weight
# Configure APs in AP group 10 to use the lightweight format to send RF fingerprinting location packets to the location server.
[Sysname-wlan-ap-group10] rfid-tracking fingerprint report-format light-weight
# Configure APs to use the lightweight format to send RF fingerprinting packets to the location server globally.
[Sysname-wlan-global-configuration] rfid-tracking fingerprint report-format light-weight
Use rfid-tracking fingerprint report-mode to specify the report mode for location packets of RF fingerprinting.
Use undo rfid-tracking fingerprint report-mode to restore the default.
rfid-tracking fingerprint report-mode { central | local }
In global configuration view, the local report mode is used.
AP view
AP group view
central: Specifies the central report mode.
local: Specifies the local report mode.
Both the AC (centralized report) and APs (local report) can report location packets to the location server. In the centralized report mode, APs need to send location packets to the AC first.
# Set the report mode for location packets of RF fingerprinting to central for AP ap1.
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint report-mode central
# Set the report mode for location packets of RF fingerprinting to central for APs in AP group 10.
[Sysname-wlan-ap-group10] rfid-tracking fingerprint report-mode central
# Set the report mode for location packets of RF fingerprinting to central globally.
[Sysname-wlan-global-configuration] rfid-tracking fingerprint report-mode central
Use rfid-tracking fingerprint tag-multicast-address to specify a multicast MAC address for Tags.
Use undo rfid-tracking fingerprint tag-multicast-address to restore the default.
rfid-tracking fingerprint tag-multicast-address mac-address
In global configuration view, no multicast MAC address is specified for Tags.
AP view
AP group view
mac-address: Specifies a MAC address in the format of H-H-H.
An AP identifies a Tag by the destination MAC address in the received wireless packet. If you do not specify a multicast MAC address for Tags, an AP determines that all received 802.11 packets are from MUs.
# Set the multicast MAC address for Tags to 0134-ed66-8923 for AP ap1.
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint tag-multicast-address 0134-ed66-8923
# Set the multicast MAC address for Tags to 0134-ed66-8923 for APs in AP group 10.
[Sysname-ap-group-10] rfid-tracking fingerprint tag-multicast-address 0134-ed66-8923
# Set the multicast MAC address for Tags to 0134-ed66-8923 globally.
[Sysname-wlan-global-configuration] rfid-tracking fingerprint tag-multicast-address 0134-ed66-8923
Use rfid-tracking fingerprint vendor-port to specify a port to listen for messages from the RF fingerprinting server.
Use undo rfid-tracking fingerprint vendor-port to restore the default.
rfid-tracking fingerprint vendor-port vendor-port-number
In global configuration view, the port to listen is port 1144.
AP view
AP group view
vendor-port-number: Specifies a port number in the range of 1 to 65535.
Perform this task to specify a port for an AP to listen for messages from the RF fingerprinting server.
# Configure AP ap1 to listen to port 3000 for messages from the RF fingerprinting server.
[Sysname-wlan-ap-ap1] rfid-tracking fingerprint vendor-port 3000
# Configure APs in AP group 10 to listen to port 3000 for messages from the RF fingerprinting server.
[Sysname-wlan-ap-group-10] rfid-tracking fingerprint vendor-port 3000
# Configure APs to listen to port 3000 for messages from the RF fingerprinting server globally.
[Sysname-wlan-global-configuration] rfid-tracking fingerprint vendor-port 3000
rfid-tracking ignore ap-frame
Use rfid-tracking ignore ap-frame enable to enable ignoring AP frames.
Use rfid-tracking ignore ap-frame disable to disable ignoring AP frames.
Use undo rfid-tracking ignore ap-frame to restore the default.
rfid-tracking ignore ap-frame { disable | enable }
In global configuration view, ignoring AP frames is disabled.
AP view
AP group view
Ignoring AP frames disables an AP from sending information in the received AP frames to the location server. AP frames are frames that an AP received from other APs. Configure this feature if you do not need to locate or monitor APs.
# Enable ignoring AP frames for AP ap1.
[Sysname-wlan-ap-ap1] rfid-tracking ignore ap-frame enable
# Enable ignoring AP frames for APs in AP group 10.
[Sysname-wlan-ap-group-10] rfid-tracking ignore ap-frame enable
# Enable ignoring AP frames for APs globally.
[Sysname-wlan-global-configuration] rfid-tracking ignore ap-frame enable
rfid-tracking ignore beacon
Use rfid-tracking ignore beacon enable to enable ignoring beacon frames.
Use rfid-tracking ignore beacon disable to disable ignoring beacon frames.
Use undo rfid-tracking ignore beacon to restore the default.
rfid-tracking ignore beacon { disable | enable }
In global configuration view, ignoring beacon frames is disabled.
AP view
AP group view
Ignoring beacon frames disables an AP from sending information in the received beacon frames to the location server to ensure performance of the location server.
# Enable ignoring beacon frames for AP ap1.
[Sysname-wlan-ap-ap1] rfid-tracking ignore beacon enable
# Enable ignoring beacon frames for APs in AP group 10.
[Sysname-wlan-ap-group-10] rfid-tracking ignore beacon enable
# Enable ignoring beacon frames for APs globally.
[Sysname-wlan-global-configuration] rfid-tracking ignore beacon enable
rfid-tracking keepalive
Use rfid-tracking keepalive enable to enable wireless location keepalive.
Use rfid-tracking keepalive disable to disable wireless location keepalive.
Use undo rfid-tracking keepalive to restore the default.
rfid-tracking keepalive { disable | enable }
In global configuration view, wireless location keepalive is disabled.
AP view
AP group view
This feature takes effect only when RF fingerprinting is configured.
This feature enables an AP to send Hello packets to the location server at an interval of 15 seconds. If the location server does not receive any packets from an AP within 30 seconds, the location server determines that the AP is offline.
Disable this feature to avoid bandwidth waste if the location server cannot process Hello packets.
# Enable wireless location keepalive for AP ap1.
[Sysname] wlan ap ap1 WA4320H
[Sysname-wlan-ap-ap1] rfid-tracking keepalive enable
# Enable wireless location keepalive APs in AP group 10.
[Sysname-ap-group10] rfid-tracking keepalive enable
# Enable wireless location keepalive globally.
[Sysname-wlan-global-configuration] rfid-tracking keepalive enable
rfid-tracking mode
Use rfid-tracking mode to specify the type of devices to locate.
Use undo rfid-tracking mode to delete the specified device type.
rfid-tracking mode { mu | tag }
undo rfid-tracking mode { mu | tag }
In radio view, the configuration in an AP group's radio view is used.
In an AP group's radio view, the type of wireless devices to locate is not specified.
Radio view
mu: Specifies MUs.
tag: Specifies Tags.
An AP sends location packets from the specified devices to the location server when you execute the rfid-tracking mode command.
This feature takes effect only when RF fingerprinting is enabled.
You can execute this command multiple times to configure an AP to locate both MUs and Tags.
# Specify the type of wireless devices to locate as MU for AP ap1.
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] rfid-tracking mode mu
# Specify the type of wireless devices to locate as MU for APs in AP group 10.
[Sysname-wlan-ap-group-10] ap-model WA4320H
[Sysname-wlan-ap-group-10-ap-model-WA4320H] radio 1
[Sysname-wlan-ap-group-10-ap-model-WA4320H-radio-1] rfid-tracking mode mu
rfid-tracking radio
Use rfid-tracking radio enable to enable radio-based location.
Use rfid-tracking radio disable to disable radio-based location.
Use undo rfid-tracking radio to restore the default.
rfid-tracking radio { disable | enable }
In an AP group's radio view, radio-based location is disabled.
Radio view
Perform this task when RF fingerprinting is enabled.
# Enable radio-based location for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] rfid-tracking radio enable
# Enable radio-based location for APs in AP group 10.
[Sysname-wlan-ap-group-10-ap-model-WA4320H-radio-1] rfid-tracking radio enable
rfid-tracking rate-limit
Use rfid-tracking rate-limit enable to enable location packet rate limiting for an AP.
Use rfid-tracking rate-limit disable to disable location packet rate limiting for an AP.
Use undo rfid-tracking rate-limit to restore the default.
rfid-tracking rate-limit { disable | enable }
In global configuration view, location packet rate limiting is disabled for an AP.
AP view
AP group view
Configure this command to enable an AP to discard excessive location packets when both the CIR and the CBS are exceeded.
# Enable location packet rate limiting for AP ap1.
[Sysname-wlan-ap-ap1] rfid-tracking rate-limit enable
# Enable location packet rate limiting for APs in AP group 10.
[Sysname-wlan-ap-group-10] rfid-tracking rate-limit enable
# Enable location packet rate limiting globally.
[Sysname-wlan-global-configuration] rfid-tracking rate-limit enable
rfid-tracking rate-limit cir
Use rfid-tracking rate-limit cir to set the rate limits for location packets for an AP.
Use undo rfid-tracking rate-limit cir to restore the default.
rfid-tracking rate-limit cir cir [ cbs cbs ]
In global configuration view, both the CIR and the CBS are 0. An AP does not limit the rate for outgoing location packets.
AP view
AP group view
cir cir: Specifies the CIR for location packets, in the range of 8 to 1300000 kbps.
cbs cbs: Specifies the CBS for location packets, in the range of 500 to 130000000 bytes. The default CBS is the CIR × 700 bytes.
The CIR and CBS configuration takes effect only when you enable location packet rate limiting.
# Set the CIR and CBS to 800000 kbps and 50000 bytes, respectively for location packets for AP ap1.
[Sysname-wlan-ap-ap1] rfid-tracking rate-limit cir 800000 cbs 50000
# Set the CIR and CBS to 800000 kbps and 50000 bytes, respectively for location packets for APs in AP group 10.
[Sysname-wlan-ap-group-10] rfid-tracking rate-limit cir 800000 cbs 50000
# Set the CIR to 800000 kbps and the CBS to 50000 bytes for location packets globally.
[Sysname-wlan-global-configuration] rfid-tracking rate-limit cir 800000 cbs 50000
rfid-tracking rssi
Use rfid-tracking rssi enable to enable RSSI-based packet filtering.
Use rfid-tracking rssi disable to disable RSSI-based packet filtering.
Use undo rfid-tracking rssi to restore the default.
rfid-tracking rssi { disable | enable }
In global configuration view, RSSI-based packet filtering is disabled.
AP view
AP group view
After you enable RSSI filtering, an AP does not report location information in packets with an RSSI lower than the specified RSSI threshold.
# Enable RSSI-based packet filtering for AP ap1.
[Sysname-wlan-ap-ap1] rfid-tracking rssi enable
# Enable RSSI-based packet filtering for APs in AP group 10.
[Sysname-wlan-ap-group-10] rfid-tracking rssi enable
# Enable RSSI-based packet filtering globally.
[Sysname-wlan-global-configuration] rfid-tracking rssi enable
rfid-tracking rssi threshold
Use rfid-tracking rssi threshold to set the RSSI threshold for packet filtering.
Use undo rfid-tracking rssi threshold to restore the default.
rfid-tracking rssi threshold rssi-threshold
In global configuration view, the RSSI threshold for packet filtering is 5 (–123 dBm).
AP view
AP group view
threshold rssi-threshold: Specifies the RSSI threshold for packet filtering, in the range of 5 to 100 (–123 dBm to –28 dBm). The AP does not report location information in packets with an RSSI lower than the specified RSSI threshold.
This command takes effect only when RSSI-based packet filtering is enabled.
# Set the RSSI threshold for packet filtering to 50 for AP ap1.
[Sysname-wlan-ap-ap1] rfid-tracking rssi threshold 50
# Set the RSSI threshold for packet filtering to 50 for APs in AP group 10.
[Sysname-wlan-ap-group-10] rfid-tracking rssi threshold 50
# Set the RSSI threshold for packet filtering to 50 globally.
[Sysname-wlan-global-configuration] rfid-tracking rssi threshold 50
rfid-tracking rssi
Use snmp-agent trap enable wlan location-aware to enable SNMP notifications for wireless location.
Use undo snmp-agent trap enable wlan location-aware to restore the default.
SNMP notifications are disabled for wireless location.
This feature enables the device to report critical wireless location events to an NMS. For wireless location event notifications to be sent correctly, you must also configure SNMP as described in the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for wireless location.
[Sysname] snmp-agent trap enable wlan location-aware
