- 03-WLAN Command References
- 01-AP management commands
- 02-Radio management commands
- 03-WLAN access commands
- 04-WLAN security commands
- 05-WLAN authentication commands
- 06-WIPS commands
- 07-WLAN QoS commands
- 08-WLAN roaming commands
- 09-WLAN load balancing commands
- 10-WLAN radio resource measurement commands
- 11-Channel scanning commands
- 12-Band navigation commands
- 13-WLAN high availability commands
- 14-802.11r commands
- 15-Wireless location commands
- 16-AC hierarchy commands
- 17-WLAN RRM commands
- 18-WLAN IP snooping commands
- 19-WLAN probe commands
- 20-WLAN forwarding commands
- 21-Spectrum management commands
- 22-WLAN radio load balancing commands
- 23-User isolation commands
- 24-Packet capture commands
- 25-802.1X client commands
- 26-IP source guard commands
| 13-WLAN high availability commands | 29.58 KB |
WLAN uplink detection commands
wlan uplink track
Use wlan uplink track to associate a track entry with WLAN uplink detection.
Use undo wlan uplink track to restore the default.
wlan uplink track track-entry-number
WLAN uplink detection is not associated with any track entry.
track-entry-number: Specifies a track entry ID in the range of 1 to 1024.
This command enables the AC to adjust radio state based on the uplink state associated with a track entry. When the track entry is in Negative state, the AC disables radios of all connected APs. When the track entry is in Positive state, the AC enables radios of all connected APs.
# Associate track entry 1 with WLAN uplink detection.
[Sysname] wlan uplink track 1
