13-OpenFlow Configuration Examples
HomeSupportSwitchesH3C S7500E Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E Switch Series Configuration Examples-R7577P04-6W10013-OpenFlow Configuration Examples
01-H3C_OpenFlow_Configuration_Examples
01-H3C_OpenFlow_Configuration_Examples 90.80 KB
H3C OpenFlow Configuration Examples
Software version: Release 7577P04
Document version: 6W100-20190330
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides examples for configuring OpenFlow.
OpenFlow separates the control plane and the data forwarding plane. An OpenFlow switch matches packets against one or more flow tables. A flow table contains one or more flow entries deployed by the controller. Packets are matched based on the matching precedence of flow entries.
These examples use VLAN-interface 1.
This document assumes that you have basic knowledge of OpenFlow.
General restrictions and guidelines
When you configure OpenFlow, follow these restrictions and guidelines:
·          Enable LLDP globally on OpenFlow switches so that the controller can learn the OpenFlow topology through LLDP.
·          Configure each OpenFlow switch with an interface for communicating with the controller so that OpenFlow instances can establish connections with the controller.
·          To ensure high availability, use TCP or SSL to establish connections between OpenFlow switches and the controller. This example uses TCP. SSL provides higher availability than TCP.
·          For the access ports of switches to belong to an OpenFlow instance, configure the Loosen mode when you associate VLANs 4092 and 4094 with the OpenFlow instance.
Example: Configuring OpenFlow to deploy dynamic flow entries
As shown in Figure 1, configure OpenFlow to meet the following requirements:
·          The controller can deploy dynamic flow entries.
·          Host A and Host C can communicate with each other based on the flow entries deployed by the controller.
·          Host B and Host D can communicate with each other based on the flow entries deployed by the controller.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on S7500E-CMW710-R7557
Procedures
Configuring Switch A
# Create VLAN 4092 and VLAN 4094.
[SwitchA] vlan 4092
[SwitchA-vlan4092] quit
[SwitchA] vlan 4094
[SwitchA-vlan4094] quit
# Configure Ten-GigabitEthernet 1/0/1, Ten-GigabitEthernet 1/0/2, and Ten-GigabitEthernet 1/0/3.
[SwitchA] interface Ten-GigabitEthernet 1/0/1
[SwitchA-Ten-GigabitEthernet1/0/1] port access vlan 4092
[SwitchA-Ten-GigabitEthernet1/0/1] quit
[SwitchA] interface Ten-GigabitEthernet 1/0/2
[SwitchA-Ten-GigabitEthernet1/0/2] port access vlan 4094
[SwitchA-Ten-GigabitEthernet1/0/2] quit
[SwitchA] interface Ten-GigabitEthernet 1/0/3
[SwitchA-Ten-GigabitEthernet1/0/3] port link-type trunk
[SwitchA-Ten-GigabitEthernet1/0/3] port trunk permit vlan 4092 4094
[SwitchA-Ten-GigabitEthernet1/0/3] quit
# Enable LLDP globally.
[SwitchA] lldp global enable
# Configure VLAN-interface 1 on Switch A for communicating with the controller.
[SwitchA] interface Vlan-interface 1
[SwitchA-Vlan-interface1] ip address 192.168.2.125 255.255.255.0
# Create OpenFlow instance 1. Associate VLAN 4092 and VLAN 4094 with it in loosen mode.
[SwitchA] openflow instance 1
[SwitchA-of-inst-1] classification vlan 4092 mask 4093 loosen
#Specify controller 0 with IP address 192.168.2.225 for OpenFlow instance 1 and activate the instance..
[SwitchA-of-inst-1] controller 0 address ip 192.168.2.225
[SwitchA-of-inst-1] active instance
[SwitchA-of-inst-1] quit
Configuring Switch B
[SwitchB] vlan 4092
[SwitchB-vlan4092] quit
[SwitchB] vlan 4094
[SwitchB-vlan4094] quit
[SwitchB] interface Ten-GigabitEthernet 1/0/1
[SwitchB-Ten-GigabitEthernet1/0/1] port access vlan 4092
[SwitchB-Ten-GigabitEthernet1/0/1] quit
[SwitchB] interface Ten-GigabitEthernet 1/0/2
[SwitchB-Ten-GigabitEthernet1/0/2] port access vlan 4094
[SwitchB-Ten-GigabitEthernet1/0/2] quit
[SwitchB] interface Ten-GigabitEthernet 1/0/3
[SwitchB-Ten-GigabitEthernet1/0/3] port link-type trunk
[SwitchB-Ten-GigabitEthernet1/0/3] port trunk permit vlan 4092 4094
[SwitchB-Ten-GigabitEthernet1/0/3] quit
[SwitchB] lldp global enable
# Configure VLAN-interface 1 on Switch B for communicating with the controller.
[SwitchB] interface Vlan-interface 1
[SwitchB-Vlan-interface1] ip address 192.168.2.126 255.255.255.0
[SwitchB-Vlan-interface1] quit
[SwitchB] openflow instance 1
[SwitchB-of-inst-1] classification vlan 4092 mask 4093 loosen
#Specify the IP address for controller 0 as 192.168.2.225 for OpenFlow instance 1 and activate the instance.
[SwitchB-of-inst-1] controller 0 address ip 192.168.2.225
[SwitchB-of-inst-1] active instance
[SwitchB-of-inst-1] quit
# Display details for OpenFlow instance 1 on devices, for example, Switch A.
[SwitchA] display openflow instance 1
Instance 1 information:
Configuration information:
 Description   : --
 Active status : Active
 Inactive configuration:
  None
 Active configuration:
  Classification VLAN, loosen mode, total VLANs(2)
   4092, 4094
  In-band management VLAN, total VLANs(0)
   Empty VLAN
  Connect mode: Multiple
  MAC address learning: Enabled
  TCP DSCP value: 64
  Flow table:
   Table ID(type): 0(Extensibility), count: 1
  Flow-entry max-limit: 65535
  Datapath ID: 0x00010000fc002500
  Default table-miss: Drop
  Forbidden port: None
  Qinq Network: Disabled
  TCP connection backup: Enabled
Port information:
Active channel information:
 Controller 0 IP address: 192.168.2.225 port: 6633
The output shows that Ten-GigabitEthernet 1/0/1, Ten-GigabitEthernet 1/0/2, and Ten-GigabitEthernet 1/0/3 belong to OpenFlow instance 1 and can be used to forward packets in the OpenFlow forwarding process.
# Display controller information for OpenFlow instance 1 on devices, for example, Switch A.
[SwitchA] display openflow instance 1 controller
Instance 1 controller information:
 Reconnect interval: 60 (s)
 Echo interval     : 5  (s)
 Controller ID           : 0
 Controller IP address   : 192.168.2.225
 Controller port         : 6633
 Controller role         : Equal
 Connect type            : TCP
 Connect state           : Established
 Packets sent            : 132
 Packets received        : 434
 SSL policy              : --
 VRF name                : --
The output shows that Switch A has established a connection with the controller.
# Display flow table information for OpenFlow instance 1 on devices, for example, Switch A.
[SwitchA] display openflow instance 1 flow-table
Instance 1 flow table information:
Table 0 information:
 Table type: Extensibility, flow entry count: 1, total flow entry count: 1
MissRule (default) flow entry information:
 cookie: 0x0, priority: 0, hard time: 0, idle time: 0, flags: flow_send_rem,
 byte count: --, packet count: 0
Match information: any
Instruction information:
 Write actions:
  Output interface: Controller, send length: 65509 bytes
The output shows that Switch A has only one table-miss flow entry with the priority of 0 and the action of outputting packets to the controller.
# Ping Host C from Host A.
Ping 10.1.1.2 (10.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.1.2: icmp_seq=0 ttl=255 time=4.582 ms
56 bytes from 10.1.1.2: icmp_seq=1 ttl=255 time=1.299 ms
56 bytes from 10.1.1.2: icmp_seq=2 ttl=255 time=1.389 ms
56 bytes from 10.1.1.2: icmp_seq=3 ttl=255 time=6.688 ms
56 bytes from 10.1.1.2: icmp_seq=4 ttl=255 time=1.294 ms
--- Ping statistics for 10.1.1.2 ---
round-trip min/avg/max/std-dev = 1.294/3.050/6.688/2.213 ms
The output shows that Host A and Host C can reach each other.
# Display flow table information for OpenFlow instance 1 again on devices, for example, Switch A.
 Table type: Extensibility, flow entry count: 4, total flow entry count: 4
 Write actions:
Flow entry 1 information:
 cookie: 0x2328, priority: 29999, hard time: 0, idle time: 300, flags:
 flow_send_rem, byte count: --, packet count: 1
Match information:
 Input interface: XGE1/0/3
 Ethernet destination MAC address: 0cda-41b1-d1c5
 Ethernet destination MAC address mask: ffff-ffff-ffff
 Ethernet source MAC address: 7425-8a0f-8034
 Ethernet source MAC address mask: ffff-ffff-ffff
 Ethernet type: 0x0806
 Write actions:
  Output interface: XGE1/0/1
Flow entry 2 information:
 flow_send_rem, byte count: --, packet count: 4
Match information:
 Input interface: XGE1/0/1
 Ethernet destination MAC address: 7425-8a0f-8034
 Ethernet source MAC address: 0cda-41b1-d1c5
 Ethernet type: 0x0800
 Write actions:
  Output interface: XGE1/0/3
Flow entry 3 information:
Match information:
 Write actions:
·          The ARP request/reply packets and ICMP request/replay packets between Host A and Host C successfully trigger the controller to deploy flow entries.
·          Switch A forwards packets based on the flow entries that are deployed by the controller.
# Ping Host D from Host B.
Ping 20.1.1.2 (20.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 20.1.1.2: icmp_seq=0 ttl=255 time=1.620 ms
56 bytes from 20.1.1.2: icmp_seq=1 ttl=255 time=6.625 ms
56 bytes from 20.1.1.2: icmp_seq=2 ttl=255 time=1.454 ms
56 bytes from 20.1.1.2: icmp_seq=3 ttl=255 time=1.134 ms
56 bytes from 20.1.1.2: icmp_seq=4 ttl=255 time=1.260 ms
--- Ping statistics for 20.1.1.2 ---
round-trip min/avg/max/std-dev = 1.134/2.419/6.625/2.110 ms
The output shows that Host B and Host D can reach each other.
 Table type: Extensibility, flow entry count: 7, total flow entry count: 7
 Write actions:
Match information:
 Write actions:
Match information:
 Write actions:
Match information:
 Write actions:
Flow entry 4 information:
Match information:
 Ethernet destination MAC address: 0cda-41b1-d1c4
 Ethernet source MAC address: 7425-8a0f-8035
 Write actions:
  Output interface: XGE1/0/2
Flow entry 5 information:
Match information:
 Input interface: XGE1/0/2
 Ethernet destination MAC address: 7425-8a0f-8035
 Ethernet source MAC address: 0cda-41b1-d1c4
 Write actions:
Flow entry 6 information:
Match information:
 Write actions:
·          The ARP request/reply packets and ICMP request/replay packets between Host B and Host D successfully trigger the controller to deploy flow entries.
Configuration files
·            Switch A:
lldp global enable
openflow instance 1
interface Vlan-interface1
 port link-mode bridge
 port trunk permit vlan 1 4092 4094
·            Switch B:
lldp global enable
openflow instance 1
Related documentation
·          H3C S7500E Switch Series OpenFlow Configuration Guide-R757X
·          H3C S7500E Switch Series OpenFlow Command Reference-R757X
  • Become a Partner
  • Partner Resources
