11-Network Management and Monitoring Configuration Examples
HomeSupportSwitchesH3C S7500E Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E Switch Series Configuration Examples-R7577P04-6W10011-Network Management and Monitoring Configuration Examples
06-H3C_NetStream_Configuration_Examples
06-H3C_NetStream_Configuration_Examples 799.80 KB
H3C NetStream Configuration Examples
Software version: 6W100-20190330
Document version: Release 7577P04
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides IPv4 NetStream and IPv6 NetStream configuration examples.
This document assumes that you have basic knowledge of NetStream.
General restrictions and guidelines
The NetStream feature is available on the following interface modules:
·          SD and EB.
·          LSQ3GV48SC0.
·          LSQ1TGS8SC0.
Example: Configuring IPv4 NetStream
As shown in Figure 1, configure IPv4 NetStream on the gateway to monitor traffic and user behavior of internal users in the education areas.
Figure 1 Network diagram
Software version used
This configuration example was created and verified on S7500E-CMW710-R7577P01.
When you configure IPv4 NetStream, follow these restrictions and guidelines:
·          You must specify the UDP port number of the NetStream server as the destination UDP port for NetStream data export.
·          In this example, the NetStream server runs IMC PLAT 7.0 (E0202).
Procedures
Configuring the gateway
# Mirror both incoming and outgoing traffic on GigabitEthernet 1/0/1.
<Gateway> system-view
[Gateway] interface gigabitethernet 1/0/1
[Gateway-GigabitEthernet1/0/1] ip netstream inbound
[Gateway-GigabitEthernet1/0/1] ip netstream outbound
[Gateway-GigabitEthernet1/0/1] quit
# Specify GigabitEthernet 1/0/2 as the source interface for NetStream traditional data packets.
[Gateway] interface gigabitethernet 1/0/2
[Gateway-GigabitEthernet1/0/2] ip address 10.1.1.1 255.255.255.0
[Gateway-GigabitEthernet1/0/2] quit
[Gateway] ip netstream export source interface gigabitethernet 1/0/2
# Specify the destination host as 10.1.1.2 and UDP port 5000.
[Gateway] ip netstream export host 10.1.1.2 5000
Configuring the NetStream server
Adding the gateway to the NetStream server
1.        Click the Service tab.
2.        From the navigation tree, select Traffic Analysis and Audit > Settings.
3.        In the Guide to Quick Traffic Analysis And Audit Configuration area, click Device Management.
4.        In the Device List area, click Add.
5.        Add the gateway, as shown in Figure 2.
Figure 2 Adding the gateway
Deploying the server configuration
3.        In the Guide to Quick Traffic Analysis And Audit Configuration area, click Server Management.
4.        In the Server List area, click the Modify icon .
5.        Configure the NetStream server parameters, as shown in Figure 3.
6.        Click Deploy.
Figure 3 Deploying the server configuration
Adding an interface traffic analysis task
You can add multiple types of traffic analysis tasks. This example uses the interface traffic analysis task type.
3.        In the Guide to Quick Traffic Analysis And Audit Configuration area, click Traffic Analysis Task Management.
4.        In the Traffic Analysis Task List area, click Add.
5.        In the Select Task Type area, select Interface, and click Next.
6.        Configure basic task parameters, select interfaces, and click OK, as shown in Figure 4.
Figure 4 Adding an interface traffic analysis task
1.        Verify that the gateway exports NetStream data to the NetStream server.
[Gateway] display ip netstream export
IP export information:
  Flow source interface                           : GigabitEthernet1/0/2
  Flow destination VPN instance                   : Not specified
  Flow destination IP address (UDP)               : 10.1.1.2 (5000)
  Version 5 exported flow number                  : 0
  Version 5 exported UDP datagram number (failed) : 0 (0)
  Version 9 exported flow number                  : 0
  Version 9 exported UDP datagram number (failed) : 0 (0)
  Version 10 exported flow number                 : 0
  Version 10 exported UDP datagram number (failed): 0 (0)
L2 export information:
2.        Display the report of an interface traffic analysis task:
a.    Click the Service tab.
b.    From the navigation tree, select Traffic Analysis and Audit > Interface Traffic Analysis Task.
c.    Click the Expand icon  next to Interface Traffic Analysis Task, and select interface from the shortcut menu.
The Traffic tab page displays interface traffic statistics for the task, as shown in Figure 5.
Figure 5 Interface traffic analysis
Configuration files
 ip netstream export source interface GigabitEthernet1/0/2
Example: Configuring IPv6 NetStream
As shown in Figure 6, configure IPv6 NetStream on the gateway to monitor traffic and user behavior of internal users in the education areas.
Figure 6 Network diagram
When you configure IPv6 NetStream, follow these restrictions and guidelines:
·          You must specify the UDP port number of the NetStream server as the destination UDP port for IPv6 NetStream data export.
Procedures
# Assign an IP address to the NetStream server. Make sure the gateway and NetStream server can reach each other. (Details not shown.)
# Enable IPv6 NetStream for both incoming and outgoing traffic on GigabitEthernet 1/0/1.
[Gateway] interface GigabitEthernet 1/0/1
[Gateway-GigabitEthernet1/0/1] ipv6 netstream inbound
[Gateway-GigabitEthernet1/0/1] ipv6 netstream outbound
# Assign an IP address to GigabitEthernet 1/0/2.
[Gateway-GigabitEthernet1/0/2] ip address 20.1.1.1 255.255.255.0
# Specify GigabitEthernet 1/0/2 as the source interface for IPv6 NetStream data packets.
[Gateway] ipv6 netstream export source interface GigabitEthernet 1/0/2
# Specify the destination host as 22.1.1.2 and UDP port 5000.
[Gateway] ipv6 netstream export host 22.1.1.2 5000
5.        Add the gateway, as shown in Figure 7.
Figure 7 Adding the gateway
5.        Configure the NetStream server parameters, as shown in Figure 8.
6.        Click Deploy.
Figure 8 Deploying the server configuration
6.        Configure basic task parameters, select interfaces, and click OK, as shown in Figure 9.
Figure 9 Adding an interface traffic analysis task
1.        Verify that the gateway exports IPv6 NetStream data to the NetStream server.
[Gateway] display ipv6 netstream export
IPv6 export information:
  Flow destination IP address (UDP)               : 22.1.1.2 (5000)
The Traffic tab page displays interface traffic statistics for the task, as shown in Figure 10.
Figure 10 Interface traffic analysis
Configuration files
 ipv6 netstream export source interface GigabitEthernet1/0/2
Related documentation
·          H3C S7500E Switch Series Network Management and Monitoring Configuration Guide-R757X
·          H3C S7500E Switch Series Network Management and Monitoring Command Reference-R757X
  • Become a Partner
  • Partner Resources
