02-Layer 2 Command Reference
HomeSupportWirelessWX3000E Series Wireless SwitchesReference GuidesCommand ReferencesH3C WX3000E Series Wireless Switches Switching Engine Command References(R3507P26)-6W10202-Layer 2 Command Reference
09-LLDP Commands
09-LLDP Commands 147.01 KB
LLDP configuration commands
The term "switch" or "device" in this chapter refers to the switching engine on a WX3000E wireless switch.
The WX3000E series comprises WX3024E and WX3010E wireless switches.
The port numbers in this chapter are for illustration only.
display lldp local-information
display lldp local-information [ global | interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
global: Displays the global LLDP information to be sent.
interface interface-type interface-number: Displays the LLDP information to be sent out the interface specified by its type and number.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see the Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, which is a case sensitive string of 1 to 256 characters.
Use the display lldp local-information command to display the LLDP information to be sent, which will be contained in the LLDP TLVs and sent to neighbor devices.
If no keyword or argument is specified, this command displays all LLDP information to be sent, including the global LLDP information and the LLDP information about the LLDP-enabled ports in the up state.
# Display all LLDP information to be sent.
<Sysname> display lldp local-information
  Chassis ID         : 00e0-fc00-5600
  System name        : Sysname
  System description : System
  System capabilities supported : Bridge,Router
  System capabilities enabled   : Bridge,Router
  MED information
  Device class: Connectivity device
  (MED inventory information of master board)
  HardwareRev               : REV.A
  FirmwareRev               : 109
  SoftwareRev               : 5.20 Alpha 2101
  SerialNum                 : NONE
  Manufacturer name         : Manufacturer
  Model name                : Model
  Asset tracking identifier : Unknown
LLDP local-information of port 1[GigabitEthernet1/0/1]:
  Port ID subtype  : Interface name
  Port ID          : GigabitEthernet1/0/1
  Port description : GigabitEthernet1/0/1 Interface
  Management address type           : ipv4
  Management address                : 192.168.1.11
  Management address interface ID   : 54
  Management address OID            : 0
  Port VLAN ID(PVID): 1
  Port and protocol VLAN ID(PPVID) : 1
  Port and protocol VLAN supported : Yes
  Port and protocol VLAN enabled   : No
  VLAN name of VLAN 1: VLAN 0001
  Auto-negotiation enabled   : Yes
  OperMau                    : speed(1000)/duplex(Full)
  Power port class          : PSE
  PSE power supported       : Yes
  PSE power enabled         : Yes
  PSE pairs control ability : Yes
  Power pairs               : Signal
  Port power classification : Class 0
  Link aggregation enabled   : No
  Aggregation port ID        : 0
  Maximum frame Size: 1536
  MED information
  Media policy type        : Unknown
  Unknown Policy           : Yes
  VLAN tagged              : No
  Media policy VlanID      : 0
  Media policy L2 priority : 0
  Media policy Dscp        : 0
  PoE PSE power source      : Primary
  Port PSE Priority         : Critical
  Port available power value: 30.0(w)
Table 1 Output description
The global LLDP information to be sent.
Chassis ID
Bridge MAC address of the device.
Supported capabilities:
·       Bridge—Switching is supported.
·       Router—Routing is supported.
Enabled capabilities:
·       Bridge—Switching is enabled.
·       Router—Routing is enabled.
Device class
MED device class:
·       Connectivity device—Network device.
·       Class I—Normal terminal device. It requires the basic LLDP discovery services.
·       Class II—Media terminal device. It supports media streams, and can also function as a normal terminal device.
·       Class III—Communication terminal device. It supports the IP communication systems of end users, and can also function as a normal terminal device or media terminal device.
HardwareRev
Hardware version.
FirmwareRev
Firmware version.
SoftwareRev
Software version.
SerialNum
Serial number.
Manufacturer name
Device manufacturer.
Model name
Device model.
LLDP information to be sent out port 1.
Port ID subtype
Port ID type, which can be MAC address or interface name.
Port ID
Port ID, the value of which depends on the port ID subtype.
Numbering type of the interface identified by the management address.
Index of the interface identified by the management address.
Management address object ID.
Port protocol VLAN ID.
Indicates whether or not protocol VLAN is supported on the port.
Indicates whether or not protocol VLAN is enabled on the port.
VLAN name of VLAN 1
Name of VLAN 1.
Indicates whether or not auto-negotiation is supported on the port.
Indicates whether or not auto-negotiation is enabled on the port.
OperMau
Speed and duplex state of the port.
PoE supported
Indicates whether or not PoE is supported on the port.
Power port class
PoE device type:
·       PSE—Power sourcing equipment.
·       PD—Powered device.
PSE power supported
Indicates whether or not the device can operate as a PSE.
PSE power enabled
Indicates whether or not the device is operating as a PSE.
Indicates whether or not the PSE-PD pair control is available.
Power pairs
PoE mode:
·       Signal—PoE via signal lines.
·       Spare—PoE via spare lines.
Port power classification of the PD:
·       Class 0.
·       Class 1.
·       Class 2.
·       Class 3.
·       Class 4.
Indicates whether or not link aggregation is supported.
Indicates whether or not link aggregation is enabled.
Aggregation port ID
Aggregation group ID, which is 0 when link aggregation is disabled.
MED information
MED LLDP information.
Media policy type
Media policy type:
·       unknown
·       voice
·       voiceSignaling
·       guestVoice
·       guestVoiceSignaling
·       softPhoneVoice
·       videoconferencing
·       streamingVideo
·       videoSignaling
Unknown Policy
Indicates whether or not the media policy is unknown.
VLAN tagged
Indicates whether or not packets of the media VLAN are tagged.
Media Policy VlanID
ID of the media VLAN.
Media Policy L2 priority
Layer 2 priority.
Media Policy Dscp
DSCP precedence.
Location format
Location information format:
·       Invalid—The format of the location information is invalid.
·       Coordinate-based LCI—The location information is coordinate-based.
·       Civic Address LCI—Typical address information.
·       ECS ELIN—Telephone number for urgencies.
PSE power type:
·       Unknown—Unknown power supply.
·       Primary—Primary power supply.
·       Backup—Backup power supply.
Port PSE Priority
PoE power supply priority of PSE ports:
·       Unknown.
·       Critical.
·       High.
·       Low.
Available PoE power on PSE ports, or power needed on PD ports, in watts.
display lldp neighbor-information
display lldp neighbor-information [ brief | interface interface-type interface-number [ brief ] | list [ system-name system-name ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
brief: Displays the summary of LLDP information sent from the neighboring devices. If this keyword is not specified, this command displays detailed LLDP information sent from the neighboring devices.
interface interface-type interface-number: Displays the LLDP information sent from the neighboring devices received through a port specified by its type and number. If this keyword-argument combination is not specified, this command displays the LLDP information sent from the neighboring devices received through all ports.
list: Displays the LLDP information sent from the neighboring devices in the form of a list.
system-name system-name: Displays the LLDP information sent from a neighboring device specified by its system name. The system-name argument is a character string of 1 to 255 characters. If this keyword-argument combination is not specified, this command displays the LLDP information sent from all neighboring devices in a list.
Use the display lldp neighbor-information command to display the LLDP information carried in LLDP TLVs sent from the neighboring devices.
# Display the LLDP information sent from the neighboring devices received through all ports.
<Sysname> display lldp neighbor-information
LLDP neighbor-information of port 1[GigabitEthernet1/0/1]:
  Neighbor index   : 1
  Update time      : 0 days,0 hours,1 minutes,1 seconds
  Chassis type     : MAC address
  Chassis ID       : 000f-0055-0002
  Port ID type     : Interface name
  Management address                : 192.168.1.55
  Management address interface ID   : Unknown
  Power port class          : PD
  PSE power supported       : No
  PSE power enabled         : No
  PSE pairs control ability : No
# Display the LLDP information sent from all neighboring devices in a list.
System Name          Local Interface Chassis ID      Port ID
System1              GE1/0/1         000f-e25d-ee91  GigabitEthernet1/0/5
System2              GE1/0/2         000f-e25d-ee92  GigabitEthernet1/0/6
System3              GE1/0/3         000f-e25d-ee93  GigabitEthernet1/0/7
Table 2 Output description
LLDP information received through port 1.
Update time
Time when LLDP information about a neighboring device was last updated.
Chassis type
Chassis information:
·       Chassis component.
·       Interface alias.
·       Port component.
·       MAC address.
·       Network address (the IP address type, such as ipv4).
·       Interface name.
·       Locally assigned—Indicates the local configuration.
Chassis ID
ID that identifies the LLDP sending device, which can be a MAC address, a network address, an interface or some other value depending on the chassis type.
Port ID type
Port information:
·       Interface alias.
·       Port component.
·       MAC address.
·       Interface name.
·       Agent circuit ID.
Port ID
Value of the port ID type.
System name
System name of the neighboring device.
System description
System description of the neighboring device.
Capabilities supported on the neighboring device:
·       Repeater—Signal repeating is supported.
Capabilities enabled on the neighboring device:
·       Repeater—Signal repeating is enabled.
VLAN name of VLAN 1
Name of VLAN 1.
OperMau
Speed and duplex state on the port.
Power port class
PoE device type:
PSE power supported
PSE power enabled
Power pairs
PoE mode:
·       Class 0.
·       Class 1.
·       Class 2.
·       Class 3.
·       Class 4.
Aggregation port ID
Location format
·       ECS ELIN—Telephone for urgencies.
PSE power type:
PoE PD power source
PD power type:
·       PSE—PSE power supply
·       Local—Local power supply
·       PSE and local—PSE and local power supplies
Port PSE Priority
·       Unknown.
·       Critical.
·       High.
·       Low.
Port PD Priority
PoE power receiving priority of PD ports:
·       Unknown.
·       Critical.
·       High.
·       Low.
TLV type
Unknown basic TLV type.
TLV information
Information contained in the unknown basic TLV type.
Unknown organizationally-defined TLV
Unknown organizationally specific TLV.
TLV OUI
OUI of the unknown organizationally specific TLV.
TLV subtype
Unknown organizationally specific TLV subtype.
Index
Unknown organization index.
TLV information
Information contained in unknown organizationally specific TLV.
Local Interface
Local port that receives the LLDP information.
display lldp statistics
display lldp statistics [ global | interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
global: Displays the global LLDP statistics.
interface interface-type interface-number: Specifies a port by its type and number.
Use the display lldp statistics command to display the global LLDP statistics or the LLDP statistics of a port.
If no keyword or argument is specified, this command displays the global LLDP statistics as well as the LLDP statistics of all ports.
# Display the global LLDP statistics as well as the LLDP statistics of all ports.
LLDP statistics global Information:
LLDP neighbor information last change time:0 days,0 hours,4 minutes,40 seconds
The number of LLDP neighbor information deleted  : 1
The number of LLDP neighbor information dropped  : 0
LLDP statistics information of port 1 [GigabitEthernet1/0/1]:
The number of LLDP frames transmitted            : 0
The number of LLDP frames received               : 0
The number of LLDP frames discarded              : 0
The number of LLDP error frames                  : 0
The number of LLDP TLVs discarded                : 0
The number of LLDP TLVs unrecognized             : 0
The number of CDP frames transmitted             : 0
The number of CDP frames received                : 0
The number of CDP frames discarded               : 0
The number of CDP error frames                   : 0
Table 3 Output description
LLDP statistics global information
Global LLDP statistics.
Time the neighbor information was last updated.
Number of times of adding neighbor information.
Number of times of removing neighbor information.
Number of times of dropping neighbor information due to lack of available memory space.
display lldp status
display lldp status [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display lldp status command to display LLDP status information.
If no port is specified, this command displays the global LLDP status and the LLDP status information for all ports.
# Display the global LLDP status as well as the LLDP status information of all ports.
<Sysname> display lldp status
Global status of LLDP: Enable
The current number of LLDP neighbors: 0
LLDP neighbor information last changed time: 0 days,0 hours,4 minutes,40 seconds
Transmit interval              : 30s
Hold multiplier                : 4
Reinit delay                   : 2s
Transmit delay                 : 2s
Trap interval                  : 5s
Fast start times               : 3
Port 1 [GigabitEthernet1/0/1]:
Port status of LLDP            : Enable
Admin status                   : Tx_Rx
Trap flag                      : No
Polling interval               : 0s
Number of neighbors            : 5
Number of MED neighbors        : 2
Number of CDP neighbors        : 0
Number of sent optional TLV    : 12
Table 4 Output description
Indicates whether or not LLDP is globally enabled.
Time when the neighbor information was last updated.
Transmit interval
LLDPDU transmit interval.
Hold multiplier
TTL multiplier.
Reinit delay
LLDP re-initialization delay.
Transmit delay
LLDPDU transmit delay.
Trap interval
Trap transmit interval.
Fast start times
Number of the LLDPDUs sent each time fast LLDPDU transmission is triggered.
Port 1
LLDP status of port 1.
Port status of LLDP
Indicates whether or not LLDP is enabled on the port.
Admin status
LLDP mode of the port:
·       TxRx—The port sends and receives LLDPDUs.
·       Rx_Only—The port only receives LLDPDUs.
·       Tx_Only—The port only sends LLDPDUs.
·       Disable—The port does not send or receive LLDPDUs.
Trap Flag
Indicates whether or not trapping is enabled.
Polling interval
LLDP polling interval, which is 0 when LLDP polling is disabled.
Number of neighbors
Number of LLDP neighbors connecting to the port.
Number of MED neighbors connecting to the port.
Number of CDP neighbors connecting to the port.
Number of optional TLVs contained in an LLDPDU sent through the port.
Number of unknown TLVs contained in a received LLDPDU.
display lldp tlv-config
display lldp tlv-config [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display lldp tlv-config command to display the types of advertisable optional LLDP TLVs of a port.
If no port is specified, this command displays the types of advertisable optional TLVs of each port.
# Display the types of advertisable optional LLDP TLVs of interface GigabitEthernet 1/0/1.
<Sysname> display lldp tlv-config interface gigabitethernet 1/0/1
LLDP tlv-config of port 1[GigabitEthernet1/0/1]:
NAME                              STATUS    DEFAULT
Basic optional TLV:
Port Description TLV              YES       YES
System Name TLV                   YES       YES
System Description TLV            YES       YES
System Capabilities TLV           YES       YES
Management Address TLV            YES       YES
IEEE 802.1 extend TLV:
Port VLAN ID TLV                  YES       YES
Port And Protocol VLAN ID TLV     YES       YES
VLAN Name TLV                     YES       YES
IEEE 802.3 extend TLV:
MAC-Physic TLV                    YES       YES
Power via MDI TLV                 YES       YES
Link Aggregation TLV              YES       YES
Maximum Frame Size TLV            YES       YES
LLDP-MED extend TLV:
Network Policy TLV                YES        YES
Location Identification TLV       NO         NO
Extended Power via MDI TLV        YES        YES
Inventory TLV                     YES        YES
Table 5 Output description
Advertisable optional TLVs of port 1.
NAME
TLV type.
STATUS
Indicates whether or not a specific type of TLV is sent through a port.
DEFAULT
Indicates whether or not a specific type of TLV is sent through a port by default.
Basic optional TLV
Basic TLVs:
·       Port description TLV.
·       System name TLV.
·       System description TLV.
·       System capabilities TLV.
·       Management address TLV.
IEEE 802.1 extended TLV
IEEE 802.1 organizationally specific TLVs:
·       Port VLAN ID TLV.
·       Port and protocol VLAN ID TLV.
·       VLAN name TLV.
IEEE 802.3 extended TLV
IEEE 802.3 organizationally specific TLVs:
·       MAC-Physic TLV.
·       Power via MDI TLV.
·       Link aggregation TLV.
·       Maximum frame size TLV.
LLDP-MED extend TLV
LLDP-MED TLVs:
·       Capabilities TLV.
·       Network Policy TLV.
·       Extended Power-via-MDI TLV.
·       Location Identification TLV.
·       Inventory TLV, including hardware revision TLV, firmware revision TLV, software revision TLV, serial number TLV, manufacturer name TLV, model name TLV, and asset id TLV.
lldp admin-status
lldp admin-status { disable | rx | tx | txrx }
undo lldp admin-status
View
Ethernet interface view, port group view
Default level
2: System level
disable: Specifies the Disable mode. A port in this mode does not send or receive LLDPDUs.
rx: Specifies the Rx mode. A port in this mode only receives LLDPDUs.
tx: Specifies the Tx mode. A port in this mode only sends LLDPDUs.
txrx: Specifies the TxRx mode. A port in this mode sends and receives LLDPDUs.
Use the lldp admin-status command to specify the LLDP operating mode for a port or all ports in a port group.
Use the undo lldp admin-status command to restore the default LLDP operating mode.
By default, the LLDP operating mode is TxRx.
# Configure the LLDP operating mode as Rx for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp admin-status rx
lldp check-change-interval
lldp check-change-interval interval
undo lldp check-change-interval
View
Default level
2: System level
interval: Sets the LLDP polling interval, ranging from 1 to 30 seconds.
Use the lldp check-change-interval command to enable LLDP polling and set the polling interval.
Use the undo lldp check-change-interval command to restore the default.
By default, LLDP polling is disabled.
# Enable LLDP polling on GigabitEthernet 1/0/1, setting the polling interval to 30 seconds.
[Sysname-GigabitEthernet1/0/1] lldp check-change-interval 30
lldp compliance admin-status cdp
lldp compliance admin-status cdp { disable | txrx }
View
Default level
2: System level
disable: Specifies the disable mode, where CDP-compatible LLDP cannot receive or transmit CDP packets.
txrx: Specifies the TxRx mode, where CDP-compatible LLDP can send and receive CDP packets.
Use the lldp compliance admin-status cdp command to configure the operating mode of CDP-compatible LLDP on a port or port group.
By default, CDP-compatible LLDP operates in disable mode.
For your device to work with Cisco IP phones, you must enable CDP-compatible LLDP globally and then configure CDP-compatible LLDP to operate in TxRx mode on the specified ports.
Related commands: lldp compliance cdp.
# Configure CDP-compatible LLDP to operate in TxRx mode on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp compliance admin-status cdp txrx
lldp compliance cdp
lldp compliance cdp
undo lldp compliance cdp
View
Default level
2: System level
None
Use the lldp compliance cdp command to enable global CDP compatibility.
Use the undo lldp compliance cdp command to restore the default.
By default, CDP compatibility is globally disabled.
Because the maximum TTL allowed by CDP is 255 seconds, the TTL configuration must be no more than 255 seconds for CDP-compatible LLDP to operate with Cisco IP phones. The TTL configuration is the product of the TTL multiplier and the LLDPDU transmit interval.
Related commands: lldp hold-multiplier and lldp timer tx-interval.
# Enable LLDP to be compatible with CDP globally.
[Sysname] lldp compliance cdp
lldp enable
lldp enable
undo lldp enable
View
System view, Ethernet interface view, port group view
Default level
2: System level
None
Use the lldp enable command to enable LLDP.
Use the undo lldp enable command to disable LLDP.
By default, LLDP is enabled globally and on all ports.
LLDP takes effect on a port only when LLDP is enabled both globally and on the port.
# Disable LLDP on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] undo lldp enable
lldp encapsulation snap
undo lldp encapsulation
View
Default level
2: System level
None
Use the lldp encapsulation snap command to configure the encapsulation format for LLDPDUs as SNAP on a port or a group of ports.
Use the undo lldp encapsulation command to restore the default encapsulation format for LLDPDUs.
By default, the encapsulation format for LLDPDUs is Ethernet II.
The command does not apply to LLDP-CDP packets, which use only SNAP encapsulation.
# Configure the encapsulation format for LLDPDUs as SNAP on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp encapsulation snap
lldp fast-count
lldp fast-count count
undo lldp fast-count
View
Default level
2: System level
count: Sets the number of the LLDPDUs sent each time fast LLDPDU transmission is triggered. The argument ranges from 1 to 10.
Use the lldp fast-count command to set the number of the LLDPDUs sent each time fast LLDPDU transmission is triggered.
Use the undo lldp fast-count command to restore the default.
By default, the number is 3.
# Configure the device to send four LLDPDUs each time fast LLDPDU transmission is triggered.
[Sysname] lldp fast-count 4
lldp hold-multiplier value
undo lldp hold-multiplier
View
Default level
2: System level
value: Sets the TTL multiplier, ranging from 2 to 10.
Use the lldp hold-multiplier command to set the TTL multiplier.
Use the undo lldp hold-multiplier command to restore the default.
By default, the TTL multiplier is 4.
You can set the TTL of the local device information by configuring the TTL multiplier.
The TTL configuration of a device is determined by the following expression:
TTL multiplier × LLDPDU transmit interval
The TTL can be up to 65535 seconds. Longer TTLs will be rounded off to 65535 seconds.
Related commands: lldp timer tx-interval.
# Set the TTL multiplier to 6.
lldp management-address-format string
undo lldp management-address-format
View
Default level
2: System level
None
Use the lldp management-address-format string command to encapsulate the management address in the form of strings in TLVs.
Use the undo lldp management-address-format command to restore the default.
By default, the management address is encapsulated in the form of numbers in TLVs.
# Configure GigabitEthernet 1/0/1 to encapsulate the management address in the form of strings in management address TLVs.
[Sysname-GigabitEthernet1/0/1] lldp management-address-format string
lldp management-address-tlv
lldp management-address-tlv [ ip-address ]
undo lldp management-address-tlv
View
Default level
2: System level
ip-address: Specifies a management address to be advertised in LLDPDUs.
Use the lldp management-address-tlv command to enable management address advertising and set the management address.
Use the undo lldp management-address-tlv command to disable management address advertising in LLDPDUs.
By default, the management address is advertised through LLDPDUs. For an Ethernet port, the management address is the main IP address of the lowest-ID VLAN carried on the port. If none of the carried VLANs is assigned an IP address, no management address will be advertised.
An LLDPDU carries only one management address TLV. If you set the management address repeatedly, the latest one takes effect.
In Ethernet interface view, if you run the lldp management-address-tlv command without specifying the ip-address argument, the advertised management address is the main IP address of the lowest-ID VLAN carried on the interface. If none of the carried VLANs is assigned an IP address, no management address will be advertised.
# Set the management address to 192.6.0.1 for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp management-address-tlv 192.6.0.1
lldp notification remote-change enable
undo lldp notification remote-change enable
View
Default level
2: System level
None
Use the lldp notification remote-change enable command to enable LLDP trapping for a port or all ports in a port group.
Use the undo lldp notification remote-change enable command to restore the default.
By default, LLDP trapping is disabled on ports.
# Enable LLDP trapping for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp notification remote-change enable
lldp timer notification-interval
undo lldp timer notification-interval
View
Default level
2: System level
interval: Sets the LLDP trap transmit interval, ranging from 5 to 3600 seconds.
Use the lldp timer notification-interval command to set the LLDP trap transmit interval.
Use the undo lldp timer notification-interval command to restore the default.
By default, the LLDP trap transmit interval is 5 seconds.
# Set the LLDP trap transmit interval to 8 seconds.
lldp timer reinit-delay
lldp timer reinit-delay delay
undo lldp timer reinit-delay
View
Default level
2: System level
delay: Sets the LLDP re-initialization delay, ranging from 1 to 10 seconds.
Use the lldp timer reinit-delay command to set the LLDP re-initialization delay.
Use the undo lldp timer reinit-delay command to restore the default.
By default, the LLDP re-initialization delay is 2 seconds.
# Set the LLDP re-initialization delay to 4 seconds.
lldp timer tx-delay
lldp timer tx-delay delay
undo lldp timer tx-delay
View
Default level
2: System level
delay: Sets the LLDPDU transmit delay, ranging from 1 to 8192 seconds.
Use the lldp timer tx-delay command to set the LLDPDU transmit delay.
Use the undo lldp timer tx-delay command to restore the default.
By default, the LLDPDU transmit delay is 2 seconds.
# Set the LLDPDU transmit delay to 4 seconds.
[Sysname] lldp timer tx-delay 4
undo lldp timer tx-interval
View
Default level
2: System level
interval: Sets the LLDPDU transmit interval, ranging from 5 to 32768 seconds.
Use the lldp timer tx-interval command to set the LLDPDU transmit interval.
Use the undo lldp timer tx-interval command to restore the default.
By default, the LLDPDU transmit interval is 30 seconds.
# Set the LLDPDU transmit interval to 20 seconds.
lldp tlv-enable
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } | network-policy | power-over-ethernet } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id | protocol-vlan-id | vlan-name } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id | network-policy | power-over-ethernet } }
View
Default level
2: System level
all: Advertises all basic LLDP TLVs, IEEE 802.1 organizationally specific LLDP TLVs, or IEEE 802.3 organizationally specific LLDP TLVs when the all keyword is specified for basic-tlv, dot1-tlv, or dot3-tlv; advertises all LLDP-MED TLVs except location identification TLVs when the all keyword is specified for med-tlv.
basic-tlv: Advertises basic LLDP TLVs.
port-description: Advertises port description TLVs.
system-capability: Advertises system capabilities TLVs.
system-description: Advertises system description TLVs.
system-name: Advertises system name TLVs.
dot1-tlv: Advertises IEEE 802.1 organizationally specific LLDP TLVs.
port-vlan-id: Advertises port VLAN ID TLVs.
protocol-vlan-id: Advertises port and protocol VLAN ID TLVs.
vlan-name: Advertises VLAN name TLVs.
vlan-id: Specifies a VLAN ID in the TLVs to be advertised. The argument ranges from 1 to 4094 and defaults to the least VLAN ID on the port.
dot3-tlv: Advertises IEEE 802.3 organizationally specific LLDP TLVs.
link-aggregation: Advertises link aggregation TLVs.
mac-physic: Advertises MAC/PHY configuration/status TLVs.
max-frame-size: Advertises maximum frame size TLVs.
power: Advertises power via MDI TLVs and power stateful control TLVs.
med-tlv: Advertises LLDP-MED TLVs.
capability: Advertises LLDP-MED capabilities TLVs.
inventory: Advertises the following TLVs: hardware revision, firmware revision, software revision, serial number, manufacturer name, model name, and asset ID.
location-id: Advertises location identification TLVs.
civic-address: Inserts the normal address information about the network device in location identification TLVs .
device-type: Sets a device type value, ranging from 0 to 2. Value 0 specifies a DHCP server. Value 1 specifies a switch. Value 2 specifies an LLDP-MED endpoint.
country-code: Sets a country code, corresponding to ISO 3166.
{ ca-type ca-value }&<1-10>: Configures address information, where ca-type represents the address information type, ranging from 0 to 255, ca-value represents address information, a string of 1 to 250 characters, and &<1-10> indicates that you can enter up to 10 parameters.
elin-address: Inserts telephone numbers for emergencies in location identification TLVs.
tel-number: Sets the telephone number for emergencies, a string of 10 to 25 characters.
network-policy: Advertises network policy TLVs.
power-over-ethernet: Advertises extended power-via-MDI TLVs.
Use the lldp tlv-enable command to configure the types of advertisable TLVs for a port or all ports in a port group.
Use the undo lldp tlv-enable command to disable the advertising of specific types of TLVs.
By default, the device can advertise all types of LLDP TLVs, except DCBX TLVs and location identification TLVs.
To enable the device to advertise LLDP-MED TLVs, you must first enable it to advertise LLDP-MED capabilities TLVs.
To disable the device from advertising LLDP-MED capabilities TLVs, you must first disable it from advertising other LLDP-MED TLVs.
To disable the device from advertising MAC/PHY configuration/status TLVs, you must first disable it from advertising LLDP-MED capabilities TLVs.
If you enable the device to advertise LLDP-MED capabilities TLVs, you also enable it to advertise MAC/PHY configuration/status TLVs.
To enable the device to advertise multiple types of TLVs, you can execute the lldp tlv-enable command repeatedly without the all keyword specified.
# Enable the device to advertise link aggregation TLVs of the IEEE 802.3 organizationally specific TLVs on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lldp tlv-enable dot3-tlv link-aggregation
