02-Layer 2 Command Reference
HomeSupportWirelessWX3000E Series Wireless SwitchesReference GuidesCommand ReferencesH3C WX3000E Series Wireless Switches Switching Engine Command References(R3507P26)-6W10202-Layer 2 Command Reference
06-Spanning Tree Commands
06-Spanning Tree Commands 273.64 KB
The term "switch" or "device" in this chapter refers to the switching engine on a WX3000E wireless switch.
The WX3000E series comprises WX3024E and WX3010E wireless switches.
The port numbers in this chapter are for illustration only.
active region-configuration
View
MST region view
Default level
2: System level
None
Use the active region-configuration command to activate your MST region configuration.
When you configure MST region–related parameters, MSTP launches a new spanning tree calculation process that may cause network topology instability. This is most likely to occur when you configure the VLAN-to-instance mapping table. The launch will occur only after the MST region–related parameters are activated with the active region-configuration command, or you enable the spanning tree feature with the stp enable command.
H3C recommends you to use the check region-configuration command to determine whether the MST region configurations to be activated are correct. Run this command only when they are correct.
Related commands: instance, region-name, revision-level, vlan-mapping modulo, and check region-configuration.
# Map VLAN 2 to MSTI 1 and manually activate the MST region configuration.
[Sysname-mst-region] instance 1 vlan 2
bpdu-drop any
bpdu-drop any
undo bpdu-drop any
View
Ethernet interface view
Default level
2: System level
None
Use the bpdu-drop any command to enable BPDU drop on a port.
Use the undo bpdu-drop any command to disable BPDU drop on a port.
By default, BPDU drop is disabled on a port.
# Enable BPDU drop on port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bpdu-drop any
View
MST region view
Default level
2: System level
None
Use the check region-configuration command to display MST region pre-configuration information, including the region name, revision level, and VLAN-to-instance mapping settings.
Two or more spanning tree devices belong to the same MST region only if they are configured with the same format selector (0 by default, not configurable), MST region name, MST region revision level, and the same VLAN-to-instance mapping entries in the MST region, and if they are connected via a physical link.
H3C recommends that you use this command to determine whether the MST region configurations to be activated are correct. Activate them only when they are correct.
Related commands: instance, region-name, revision-level, vlan-mapping modulo, and active region-configuration.
# Display MST region pre-configurations.
[Sysname-mst-region] check region-configuration
Admin Configuration
   Format selector      :0
   Region name          :000fe26a58ed
   Revision level       :0
   Configuration digest :0x41b5018aca57daa8dcfdba2984d99d06
   Instance   Vlans Mapped
      0       1 to 9, 11 to 4094
     15       10
Table 1 Output description
Format selector
Format selector of the MST region, which is 0 (not configurable).
Region name
MST region name.
Revision level
Revision level of the MST region.
VLAN-to-instance mappings in the MST region.
display stp
display stp [ instance instance-id ] [ interface interface-list | slot slot-number ] [ brief ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
instance instance-id: Displays the status and statistics of a specific MSTI. The instance-id argument specifies a MSTI ID, and ranges from 0 to 15. MSTI 0 is the CIST.
interface interface-list: Displays the spanning tree status and statistics on the ports specified by a port list, in the format of interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where &<1-10> indicates that you can specify up to 10 ports or port ranges.
slot slot-number: Displays the spanning tree status and statistics of the specified device. slot-number is 1 and specifies the slot number of the device.
brief: Displays brief spanning tree status and statistics.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see the Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, which is a case sensitive string of 1 to 256 characters.
Use the display stp command to display the spanning tree status and statistics.
Based on the spanning tree status and statistics, you can analyze and maintain the network topology or check whether spanning tree is working normally.
·           If you do not specify any MSTI or port, this command displays the spanning tree information of all MSTIs on all ports. The displayed information is sorted by MSTI ID and by port name in each MSTI.
·           If you specify an MSTI but not a port, this command displays the spanning tree information on all ports in that MSTI. The displayed information is sorted by port name.
·           If you specify some ports but not an MSTI, this command displays the spanning tree information of all MSTIs on the specified ports. The displayed information is sorted by MSTI ID and by port name in each MSTI.
·           If you specify both an MSTI ID and a port list, this command displays the spanning tree information on the specified ports in the specified MSTI. The displayed information is sorted by port name.
The MSTP status information includes the following parameters:
·           CIST global parameters:
¡  Protocol work mode
¡  Device priority in the CIST (Priority)
¡  MAC address
¡  Hello time
¡  Max age
¡  Forward delay
¡  Maximum hops
¡  Common root bridge of the CIST
¡  External path cost from the device to the CIST common root
¡  Regional root
¡  Internal path cost from the device to the regional root
¡  CIST root port of the device
¡  Status of the BPDU guard function (enabled or disabled)
·           CIST port parameters:
¡  Port status
¡  Role
¡  Priority
¡  Path cost
¡  Designated bridge
¡  Designated port
¡  Edge port/non-edge port
¡  Connecting to a point-to-point link or not
¡  Maximum transmission rate (transmit limit)
¡  Status of the root guard function (enabled or disabled)
¡  BPDU format
¡  Boundary port/non-boundary port
¡  Hello time
¡  Max age
¡  Forward delay
¡  Message age
¡  Remaining hops
¡  Status of rapid state transition (enabled or disabled) for designated ports
·           MSTI global parameters:
¡  MSTI ID
¡  Bridge priority of the MSTI
¡  Regional root
¡  MSTI root port
¡  Master bridge
·           MSTI port parameters:
¡  Port status
¡  Role
¡  Priority
¡  Path cost
¡  Designated bridge
¡  Designated port
¡  Remaining hops
The statistics include the following items:
·           The number of TCN BPDUs, configuration BPDUs, RST BPDUs, and MST BPDUs sent from each port
·           The number of TCN BPDUs, configuration BPDUs, RST BPDUs, MST BPDUs, and wrong BPDUs received on each port
·           The number of BPDUs discarded on each port
Related commands: reset stp.
# Display the brief spanning tree status and statistics of MSTI 0 on ports GigabitEthernet 1/0/1 through GigabitEthernet1/0/4.
<Sysname> display stp instance 0 interface gigabitethernet 1/0/1 to gigabitethernet 1/0/4 brief
 MSTID      Port                         Role  STP State     Protection
   0        GigabitEthernet1/0/1         ALTE  DISCARDING    LOOP
   0        GigabitEthernet1/0/2         DESI  FORWARDING    NONE
   0        GigabitEthernet1/0/3         DESI  FORWARDING    NONE
   0        GigabitEthernet1/0/4         DESI  FORWARDING    NONE
Table 2 display stp brief command output description
MSTID
MSTI ID in the MST region.
Port
Port name, corresponding to each MSTI.
Role
Port role:
·       ALTE—The port is an alternate port.
·       BACK—The port is a backup port.
·       ROOT—The port is a root port.
·       DESI—The port is a designated port.
·       MAST—The port is a master port.
·       DISA—The port is disabled.
STP State
Spanning tree status on the port:
·       FORWARDING—Learn MAC addresses, and also forward user traffic.
·       DISCARDING—Not learn MAC addresses, but cannot forward user traffic.
·       LEARNING—Learn MAC addresses, and do not forward user traffic.
Protection
Protection type on the port:
·       ROOT—Root guard.
·       LOOP—Loop guard.
·       BPDU—BPDU guard.
·       NONE—No protection.
# Display the spanning tree status and statistics of all MSTIs on all ports.
-------[CIST Global Info][Mode MSTP]-------
CIST Bridge         :32768.000f-e200-2200
Bridge Times        :Hello 2s MaxAge 20s FwDly 15s MaxHop 20
CIST Root/ERPC      :0.00e0-fc0e-6554 / 200200
CIST RegRoot/IRPC   :32768.000f-e200-2200 / 0
CIST RootPortId     :128.48
BPDU-Protection     :disabled
Bridge Config-
Digest-Snooping     :disabled
TC or TCN received  :2
Time since last TC  :0 days 0h:5m:42s
----[Port1(GigabitEthernet1/0/1)][FORWARDING]----
 Port Protocol       :enabled
 Port Role           :CIST Designated Port
 Port Priority       :128
 Port Cost(Legacy)   :Config=auto / Active=200
 Desg. Bridge/Port   :32768.000f-e200-2200 / 128.2
 Port Edged          :Config=disabled / Active=disabled
 Point-to-point      :Config=auto / Active=true
 Transmit Limit      :10 packets/hello-time
 Protection Type     :None
 MST BPDU Format     :Config=auto / Active=legacy
 Port Config-
 Rapid transition    :false
 Num of Vlans Mapped :1
 PortTimes           :Hello 2s MaxAge 20s FwDly 15s MsgAge 2s RemHop 20
 BPDU Sent           :186
          TCN: 0, Config: 0, RST: 0, MST: 186
 BPDU Received       :0
          TCN: 0, Config: 0, RST: 0, MST: 0
-------[MSTI 1 Global Info]-------
MSTI Bridge ID      :0.000f-e23e-9ca4
MSTI RegRoot/IRPC   :0.000f-e23e-9ca4 / 0
MSTI RootPortId     :0.0
MSTI Root Type      :PRIMARY root
Master Bridge       :32768.000f-e23e-9ca4
Cost to Master      :0
TC received         :0
# Display the spanning tree status and statistics when the spanning tree feature is disabled.
 Protocol Status    :disabled
 Protocol Std.      :IEEE 802.1s
 Version            :3
 CIST Bridge-Prio.  :32768
 MAC address        :000f-e200-8048
 Max age(s)         :20
 Forward delay(s)   :15
 Hello time(s)      :2
 Max hops           :20
Table 3 display stp command output description
CIST Bridge
The CIST bridge ID, which comprises the device’s priority in the CIST and its MAC address. For example, in output information “32768.000f-e200-2200”, the value preceding the dot is the device’s priority in the CIST, and the value following the dot is the device’s MAC address.
Bridge Times
Major parameters for the bridge:
·       Hello—Hello timer.
·       MaxAge—Max age timer.
·       FWDly—Forward delay timer.
·       Max Hop—Max hops within the MST region.
CIST Root/ERPC
CIST root ID and external path cost (the path cost from the device to the CIST root).
CIST RegRoot/IRPC
CIST regional root ID and internal path cost (the path cost from the device to the CIST regional root).
CIST RootPortId
CIST root port ID. "0.0" indicates that the device is the root and there is no root port.
BPDU-Protection
Global status of BPDU protection.
Bridge Config-
Digest-Snooping
Global status of Digest Snooping.
TC or TCN received
Number of TC/TCN BPDUs received in the MSTI or VLAN.
Time since last TC
Time since the latest topology change in the MSTI or VLAN.
[FORWARDING]
The port is in forwarding state.
[DISCARDING]
The port is in discarding state.
[LEARNING]
The port is in learning state.
Port Protocol
The status of the spanning tree feature on the port.
Port Role
Port role, which can be Alternate, Backup, Root, Designated, Master, or Disabled.
Port Cost(Legacy)
Path cost of the port. The field in parentheses indicates the standard (legacy, dot1d-1998, or dot1t) used for port path cost calculation.
·       Config—Configured value.
·       Active—Actual value.
Desg. Bridge/Port
Designated bridge ID and port ID of the port.
The port ID displayed is insignificant for a port which does not support port priority.
Port Edged
The port is an edge port or non-edge port.
Point-to-point
The port is connected to a point-to-point link or not.
Transmit Limit
The maximum number of packets sent within each hello time.
Protection Type
·       Root—Root guard.
·       Loop—Loop guard.
·       BPDU—BPDU guard.
·       None—No protection.
MST BPDU Format
Format of the MST BPDUs that the port can send, which can be legacy or 802.1s.
Port Config-
Digest-Snooping
The status of Digest Snooping on the port.
Rapid transition
The port rapidly transitions to the forwarding state or not in the MSTI or VLAN.
Num of Vlans Mapped
The number of VLANs mapped to the MSTI.
PortTimes
Major parameters for the port:
·       MaxAge—Max Age timer.
·       MsgAge—Message Age timer.
·       Remain Hop—Remaining hops.
BPDU Sent
Statistics on sent BPDUs.
BPDU Received
Statistics on received BPDUs.
MSTI RegRoot/IRPC
MSTI regional root/internal path cost.
MSTI RootPortId
MSTI root port ID.
MSTI Root Type
MSTI root type, which can be primary root or secondary root.
Master Bridge
MSTI root bridge ID.
Cost to Master
Path cost from the MSTI to the master bridge.
TC received
Number of received TC BPDUs.
Protocol Status
Spanning tree protocol status.
Protocol Std.
Spanning tree protocol standard.
Version
Spanning tree protocol version.
CIST Bridge-Prio.
In MSTP mode, this field indicates the device’s priority in the CIST.
Max age(s)
Aging timer (in seconds) for BPDUs.
Forward delay(s)
Port state transition delay (in seconds).
Hello time(s)
Interval (in seconds) for the root bridge to send BPDUs.
Max hops
Maximum hops in the MSTI.
display stp abnormal-port
display stp abnormal-port [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display stp abnormal-port command to display information about ports blocked by spanning tree protection functions.
# In MSTP mode, display information about ports blocked by spanning tree protection functions.
<Sysname> display stp abnormal-port
 MSTID       Blocked Port                 Reason
   1         GigabitEthernet1/0/1       ROOT-Protected
   2         GigabitEthernet1/0/2       LOOP-Protected
   2         GigabitEthernet1/0/3       Formatcompatibility–Protected
Table 4 Output description
Blocked Port
Name of a blocked port, which corresponds to the related MSTI or VLAN.
Reason
Reason that the port was blocked:
·       ROOT-Protected—Root guard function.
·       LOOP-Protected—Loop guard function.
·       Formatcompatibility-Protected—MSTP BPDU format incompatibility protection function.
display stp bpdu-statistics
display stp bpdu-statistics [ interface interface-type interface-number [ instance instance-id ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays the BPDU statistics on a specified port, where interface-type interface-number indicates the port type and number.
instance instance-id: Displays the BPDU statistics of a specified MSTI on a specified port. The instance-id argument specifies a MSTI ID, and ranges from 0 to 15. MSTI 0 is the CIST.
Use the display stp bpdu-statistics command to display the BPDU statistics on ports.
·           If you do not specify any MSTI or port, this command displays the BPDU statistics of all MSTIs on all ports. The displayed information is sorted by port name and by MSTI ID on each port.
·           If you specify a port but not an MSTI, this command displays the BPDU statistics of all MSTIs on the port. The displayed information is sorted by MSTI ID.
·           If you specify both an MSTI ID and a port, this command displays the BPDU statistics of the specified MSTI on the port.
# Display the BPDU statistics of all MSTIs on GigabitEthernet 1/0/1.
<Sysname> display stp bpdu-statistics interface gigabitethernet 1/0/1
 Port: GigabitEthernet1/0/1
 Instance-independent:
 Type                        Count      Last Updated
 Invalid BPDUs               0
 Looped-back BPDUs           0
 MAX-aged BPDUs              0
 TCN sent                    0
 TCN received                0
 TCA sent                    0
 TCA received                2          10:33:12 01/13/2010
 Config sent                 0
 Config received             0
 RST sent                    0
 RST received                0
 MST sent                    4          10:33:11 01/13/2010
 MST received                151        10:37:43 01/13/2010
 Instance 0:
 Timeout BPDUs               0
 MAX-hoped BPDUs             0
 TC detected                 1          10:32:40 01/13/2010
 TC sent                     3          10:33:11 01/13/2010
 TC received                 0
 Instance 1:
 Timeout BPDUs               0
 MAX-hoped BPDUs             0
 TC detected                 0
 TC sent                     0
 TC received                 0
 Instance 2:
 Timeout BPDUs               0
 MAX-hoped BPDUs             0
 TC detected                 0
 TC sent                     0
 TC received                 0
Table 5 Output description
Port
Port name.
Statistics not related to any particular MSTI.
Statistical item.
Looped-back BPDUs
BPDUs sent and then received by the same port.
Max-Aged BPDUs
BPDUs whose max age was exceeded.
TCN Sent
TCN BPDUs sent.
TCN Received
TCN BPDUs received.
TCA Sent
TCA BPDUs sent.
TCA Received
TCA BPDUs received.
Config Sent
Configuration BPDUs sent.
Config Received
Configuration BPDUs received.
RST Sent
RSTP BPDUs sent.
RST Received
RSTP BPDUs received.
MST Sent
MSTP BPDUs sent.
MST Received
MSTP BPDUs received.
Instance
Statistical information for a particular MSTI.
Timeout BPDUs
Expired BPDUs.
Max-Hoped BPDUs
BPDUs whose maximum hops were exceeded.
TC Detected
TC BPDUs detected.
TC Sent
TC BPDUs sent.
TC Received
TC BPDUs received.
display stp down-port
display stp down-port [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display stp down-port command to display information about ports shut down by spanning tree protection functions.
# Display information about ports shut down by spanning tree protection functions.
<Sysname> display stp down-port
 Down Port                     Reason
 GigabitEthernet1/0/1      BPDU-Protected
 GigabitEthernet1/0/2      Formatfrequency-Protected
Table 6 Output description
Down Port
Name of a port shut down by the spanning tree protection functions.
Reason
Reason that the port was shut down:
·       BPDU-Protected—BPDU guard function.
·       Formatfrequency-Protected—MSTP BPDU format frequent change protection function.
display stp history
display stp [ instance instance-id | vlan vlan-id ] history [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
0: Visit level
instance instance-id: Displays the historical port role calculation information of a specific MSTI. The instance-id argument specifies a MSTI ID, and ranges from 0 to 15. MSTI 0 is the CIST.
slot slot-number: Displays the historical port role calculation information of the specified device. slot-number is 1 and specifies the slot number of the device.
Use the display stp history command to display the historical port role calculation information of the specified MSTI or all MSTIs.
·           If you do not specify any MSTI, this command displays the historical port role calculation information of all MSTIs. The displayed information is sorted by MSTI ID and by port role calculation time in each MSTI.
·           If you specify an MSTI, this command displays the historical port role calculation information of the specified MSTI by the sequence of port role calculation time.
# In MSTP mode, display the historical port role calculation information of the card on slot 1 in MSTI 2.
<Sysname> display stp instance 2 history slot 1
 --------------- STP slot 1 history trace ---------------
 -------------------  Instance 2   ---------------------
 Port GigabitEthernet1/0/1
   Role change   : ROOT->DESI (Aged)
   Time          : 2009/02/08 00:22:56
   Port priority : 0.00e0-fc01-6510 0 0.00e0-fc01-6510 128.1
 Port GigabitEthernet1/0/2
   Role change   : ALTER->ROOT
   Port priority : 0.00e0-fc01-6510 0 0.00e0-fc01-6510 128.2
Table 7 Output description
Port
Port name.
Role change
A role change of the port (“Age” means that the change was caused by expiration of the received configuration BPDU).
Time
Time of port role calculation.
Port priority
Port priority.
display stp ignored-vlan
display stp ignored-vlan [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display stp ignored-vlan command to display VLAN Ignore-enabled VLANs.
# Display VLAN Ignore-enabled VLANs.
<Sysname> display stp ignored-vlan
STP-Ignored VLAN: 1 to 2
Table 8 Output description
STP-Ignored VLAN
List of VLAN Ignore-enabled VLANs. A value of NONE for this field indicates that no VLAN is enabled with the VLAN Ignore feature.
display stp region-configuration
display stp region-configuration [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display stp region-configuration command to display effective configuration information of the MST region, including the region name, revision level, and user-configured VLAN-to-instance mappings.
Related commands: instance, region-name, revision-level, and vlan-mapping modulo.
# Display effective MST region configuration information.
<Sysname> display stp region-configuration
 Oper Configuration
   Format selector      :0
   Region name          :hello
   Revision level       :0
   Configuration digest :0x5f762d9a46311effb7a488a3267fca9f
      0       21 to 4094
      1       1 to 10
      2       11 to 20
Table 9 Output description
Format selector
Format selector defined by the spanning tree protocol. The default value is 0 and the selector cannot be configured.
Region name
MST region name.
Revision level
Revision level of the MST region, which can be configured by using the revision-level command and defaults to 0.
display stp root
display stp root [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display stp root command to display the root bridge information of all MSTIs.
# Display the root bridge information of all spanning trees.
<Sysname> display stp root
 MSTID  Root Bridge ID        ExtPathCost IntPathCost Root Port
   0    0.00e0-fc0e-6554      200200      0           GigabitEthernet1/0/1
Table 10 Output description
ExtPathCost
External path cost. The device automatically calculates the default path cost of a port, or alternatively, you can use the stp cost command to configure the path cost of a port.
IntPathCost
Internal path cost. The device automatically calculates the default path cost of a port, or alternatively, you can use the stp cost command to configure the path cost of a port.
Root Port
Root port name (displayed only if a port of the device is the root port of MSTIs).
display stp tc
display stp [ instance instance-id ] tc [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
0: Visit level
instance instance-id: Displays the statistics of TC/TCN BPDUs received and sent by all ports in a particular MSTI. The instance-id argument specifies a MSTI ID, and ranges from 0 to 15. MSTI 0 is the CIST.
slot slot-number: Displays the statistics of TC/TCN BPDUs received and sent by the specified device. slot-number is 1, and specifies the slot number of the device.
Use the display stp tc command to display the statistics of TC/TCN BPDUs received and sent by all ports in an MSTI or all MSTIs.
·           If you do not specify any MSTI, this command displays the statistics of TC/TCN BPDUs received and sent by all ports in all MSTIs. The displayed information is sorted by instance ID and by port name in each MSTI.
·           If you specify an MSTI, this command displays the statistics of TC/TCN BPDUs received and sent by all ports in the specified MSTI, in port name order.
# Display the statistics of TC/TCN BPDUs received and sent by all ports on the card on slot 1 in MSTI 0.
<Sysname> display stp instance 0 tc slot 1
 -------------- STP slot 1 TC or TCN count -------------
 MSTID      Port                       Receive      Send
   0        GigabitEthernet1/0/1         6          4
   0        GigabitEthernet1/0/2         0          2
Table 11 Output description
Port
Port name.
Receive
Number of TC/TCN BPDUs received on each port.
Send
Number of TC/TCN BPDUs sent by each port.
instance
instance instance-id vlan vlan-list
undo instance instance-id [ vlan vlan-list ]
View
MST region view
Default level
2: System level
instance-id: Specifies an MSTI ID, which ranges from 0 to 15. MSTI 0 is CIST.
vlan vlan-list: Specifies a VLAN list in the format of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>, where the vlan-id argument represents the VLAN ID, ranges from 1 to 4094, and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges.
Use the instance command to map a list of VLANs to the specified MSTI.
Use the undo instance command to remap the specified VLAN or all VLANs to the CIST (MSTI 0).
By default, all VLANs are mapped to the CIST.
If you specify no VLAN in the undo instance command, all VLANs mapped to the specified MSTI will be remapped to the CIST.
You cannot map the same VLAN to different MSTIs. If you map a VLAN that has been mapped to an MSTI to a new MSTI, the old mapping will be automatically removed.
After configuring this command, run the active region-configuration command to activate the VLAN-to-instance mapping.
Related commands: display stp region-configuration, check region-configuration, and active region-configuration.
# Map VLAN 2 to MSTI 1.
region-name
region-name name
undo region-name
View
MST region view
Default level
2: System level
name: Specifies the MST region name, a string of 1 to 32 characters.
Use the region-name command to configure the MST region name.
Use the undo region-name command to restore the default MST region name.
By default, the MST region name of a device is its MAC address.
The MST region name, the VLAN-to-instance mapping table, and the MSTP revision level of a device determine the device's MST region.
After configuring this command, run the active region-configuration command to activate the configured MST region name.
Related commands: instance, revision-level, vlan-mapping modulo, display stp region-configuration, check region-configuration, and active region-configuration.
# Set the MST region name of the device to hello.
[Sysname-mst-region] region-name hello
reset stp
reset stp [ interface interface-list ]
View
Default level
1: Monitor level
interface interface-list: Clears the MSTP statistics of the ports specified in the format of interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where &<1-10> indicates that you can specify up to 10 ports or port ranges.
Use the reset stp command to clear the MSTP statistics.
The MSTP statistics includes the numbers of TCN BPDUs, configuration BPDUs, RST BPDUs and MST BPDUs sent/received through the specified ports.
If you specify the interface-list argument, the command clears the spanning tree-related statistics on the specified ports. Without the argument, the command clears the spanning tree-related statistics on all ports.
Related commands: display stp.
# Clear the spanning tree-related statistics on ports GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3.
<Sysname> reset stp interface gigabitethernet 1/0/1 to gigabitethernet 1/0/3
revision-level
revision-level level
undo revision-level
View
MST region view
Default level
2: System level
level: Specifies an MSTP revision level, ranging from 0 to 65535.
Use the revision-level command to configure the MSTP revision level.
Use the undo revision-level command to restore the default MSTP revision level.
By default, the MSTP revision level is 0.
The MSTP revision level, the MST region name, and the VLAN-to-instance mapping table of a device determine the device's MST region. When the MST region name and VLAN-to-instance mapping table are both the same for two MST regions, they can still be differentiated by their MSTP revision levels.
After configuring this command, run the active region-configuration command to activate the configured MST region level.
Related commands: instance, region-name, vlan-mapping modulo, display stp region-configuration, check region-configuration, and active region-configuration.
# Set the MSTP revision level of the MST region to 5.
[Sysname-mst-region] revision-level 5
stp bpdu-protection
stp bpdu-protection
undo stp bpdu-protection
View
Default level
2: System level
None
Use the stp bpdu-protection command to enable the BPDU guard function.
Use the undo stp bpdu-protection command to disable the BPDU guard function.
By default, the BPDU guard function is disabled.
# Enable the BPDU guard function.
[Sysname] stp bpdu-protection
stp bridge-diameter
stp bridge-diameter diameter
undo stp bridge-diameter
View
Default level
2: System level
diameter: Specifies the switched network diameter, ranging from 2 to 7.
Use the stp bridge-diameter command to specify the network diameter, the maximum possible number of stations between any two terminal devices on the switched network.
Use the undo stp bridge-diameter command to restore the default.
By default, the network diameter of the switched network is 7.
An appropriate setting of hello time, forward delay, and max age can speed up network convergence. The values of these timers are related to the network size and you can set the timers by setting the network diameter. With the network diameter set to 7 (the default), the three timers will be set to their defaults.
Each MST region is considered as a device, and the configured network diameter of the switched network is only effective for the CIST (or the common root bridge), not for MSTIs.
Related commands: stp timer forward-delay, stp timer hello, and stp timer max-age.
# Set the network diameter of the switched network to 5.
[Sysname] stp bridge-diameter 5
stp compliance
stp compliance { auto | dot1s | legacy }
undo stp compliance
View
Ethernet interface view, port group view, aggregate interface view
Default level
2: System level
auto: Configures the ports to recognize the MSTP BPDU format automatically and determine the format of MSTP BPDUs to send.
dot1s: Configures the ports to receive and send only standard-format (802.1s-compliant) MSTP BPDUs.
legacy: Configures the ports to receive and send only compatible-format MSTP BPDUs.
Use the stp compliance command to configure the mode the specified ports will use to recognize and send MSTP BPDUs.
Use the undo stp compliance command to restore the default.
By default, a port automatically recognizes the formats of received MSTP packets and determines the formats of MSTP packets to be sent based on the recognized formats.
Configured in Ethernet interface view, the setting takes effect on that interface only.
Configured in port group view, the setting takes effect on all ports in the port group.
Configured in aggregate interface view, the setting takes effect only on the aggregate interface.
Configured on a member port in an aggregation group, the setting takes effect only after the port leaves the aggregation group.
# Configure GigabitEthernet 1/0/1 to receive and send only standard-format (802.1s) MSTP packets.
[Sysname-GigabitEthernet1/0/1] stp compliance dot1s
stp config-digest-snooping
undo stp config-digest-snooping
View
System view, Ethernet interface view, port group view, aggregate interface view
Default level
2: System level
None
Use the stp config-digest-snooping command to enable Digest Snooping.
Use the undo stp config-digest-snooping command to disable Digest Snooping.
The feature is disabled by default.
Configured in system view, the setting takes effect globally.
Configured in Ethernet interface view, the setting takes effect on the interface only.
Enable this feature both globally and on ports connected to other vendors' devices to make it effective. To minimize impact, enable the feature on all associated ports before you enable it globally.
# Enable Digest Snooping on GigabitEthernet 1/0/1 and then globally.
[Sysname-GigabitEthernet1/0/1] stp config-digest-snooping
[Sysname] stp config-digest-snooping
stp cost
stp [ instance instance-id ] cost cost
undo stp [ instance instance-id ] cost
View
Default level
2: System level
instance instance-id: Sets the path cost of the ports in a particular MSTI. The instance-id argument specifies a MSTI ID, and ranges from 0 to 15. MSTI 0 is the CIST.
cost: Specifies the path cost of the port, with an effective range that depends on the path cost calculation standard adopted.
·           With the IEEE 802.1d-1998 standard selected for path cost calculation, the cost argument ranges from 1 to 65535.
·           With the IEEE 802.1t standard selected for path cost calculation, the cost argument ranges from 1 to 200000000.
·           With the private standard selected for path cost calculation, the cost argument ranges from 1 to 200000.
Use the stp cost command to set the path cost of the port or ports.
Use the undo stp cost command to restore the default.
By default, the device automatically calculates the path costs of ports in each spanning tree based on the corresponding standard.
Configured in aggregate interface view, the setting takes effect only on the aggregate interface. Configured on a member port in an aggregation group, the setting takes effect only after the port leaves the aggregation group.
Path cost is an important factor in spanning tree calculation. Setting different path costs for a port in MSTIs allows VLAN traffic flows to be forwarded along different physical links, achieving VLAN-based load balancing.
The path cost setting of a port can affect the role selection of the port. When the path cost of a port is changed, the system will re-calculate the role of the port and initiate a state transition.
Related commands: display stp and stp pathcost-standard.
# In MSTP mode, set the path cost of port GigabitEthernet 1/0/3 in MSTI 2 to 200.
[Sysname] interface gigabitethernet 1/0/3
[Sysname-GigabitEthernet1/0/3] stp instance 2 cost 200
stp edged-port
stp edged-port { enable | disable }
undo stp edged-port
View
Default level
2: System level
enable: Configures the ports as edge ports.
disable: Configures the ports as non-edge ports.
Use the stp edged-port enable command to configure the ports as edge ports.
Use the stp edged-port disable command to configure the ports as non-edge ports.
Use the undo stp edged-port command to restore the default.
By default, all ports are non-edge ports.
If a port directly connects to a user terminal rather than another device or a shared LAN segment, this port is regarded as an edge port. When the network topology changes, an edge port will not cause a temporary loop. You can enable the port to transition to the forwarding state rapidly by configuring it as an edge port. H3C recommends you to configure ports directly connecting to user terminals as edge ports.
Configuration BPDUs from other devices usually cannot reach an edge port, because the edge port does not connect to any other device. If a port receives a configuration BPDU when the BPDU guard function is disabled, the port functions as a non-edge port, even if you configure it as an edge port.
You cannot configure edge port settings and loop guard on a port at the same time.
Related commands: stp loop-protection.
# Configure GigabitEthernet 1/0/1 as an edge port.
[Sysname-GigabitEthernet1/0/1] stp edged-port enable
stp enable
stp enable
undo stp enable
View
Default level
2: System level
None
Use the stp enable command to enable the spanning tree feature.
Use the undo stp enable command to disable the spanning tree feature.
By default, the spanning tree feature is disabled globally, and enabled on each port. After you enable the spanning tree feature globally, the spanning tree feature takes effect on each port.
When you enable the spanning tree feature, the device works in STP-compatible, RSTP, or MSTP mode, depending on the spanning tree mode setting.
When the spanning tree feature is enabled, the device dynamically maintains the spanning tree status of VLANs based on received configuration BPDUs. When the spanning tree feature is disabled, the device stops maintaining the spanning tree status.
Related commands: stp mode.
# Enable the spanning tree feature globally.
[Sysname] stp enable
# Disable the spanning tree feature on port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] undo stp enable
stp ignored vlan
stp ignored vlan vlan-list
undo stp ignored vlan vlan-list
View
Default level
2: System level
Use the stp ignored vlan command to enable VLAN Ignore for the specified VLANs.
Use the undo stp ignored vlan command to disable VLAN Ignore for the specified VLANs.
By default, VLAN Ignore is disabled for a VLAN.
Related commands: display stp ignored-vlan.
# Enable VLAN Ignore for VLAN 1 through VLAN 10.
[Sysname] stp ignored vlan 1 to 10
stp loop-protection
stp loop-protection
undo stp loop-protection
View
Default level
2: System level
None
Use the stp loop-protection command to enable the loop guard function on the ports.
Use the undo stp loop-protection command to restore the default.
By default, the loop guard function is disabled.
You cannot configure edge port settings and loop guard, or configure root guard and loop guard on a port at the same time.
Related commands: stp edged-port and stp root-protection.
# Enable the loop guard function on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] stp loop-protection
stp max-hops
stp max-hops hops
undo stp max-hops
View
Default level
2: System level
hops: Sets the maximum hops, ranging from 1 to 40.
Use the stp max-hops command to set the maximum hops of the MST region.
Use the undo stp max-hops command to restore the default.
By default, the maximum number of hops of an MST region is 20.
The maximum hops limit the size of the MST region.
# Set the maximum hops of the MST region to 35.
[Sysname] stp max-hops 35
stp mcheck
stp mcheck
View
System view, Ethernet interface view, aggregate interface view
Default level
2: System level
None
Use the stp mcheck command to perform the mCheck operation globally or on a port.
If a port on a device running MSTP or RSTP mode connects to an STP device, this port will automatically transition to the STP-compatible mode. However, it cannot automatically transition back to the original mode when:
·           The STP device is shut down or removed.
·           The STP device transitions to the MSTP mode.
Then, you can perform an mCheck operation to forcibly transition the port to operation in the original mode.
The device works in STP-compatible, RSTP, MSTP mode depending on the spanning tree mode setting.
The stp mcheck command is effective only when the device works in MSTP or RSTP mode.
# Perform mCheck on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] stp mcheck
stp mode
stp mode { stp | rstp | mstp }
undo stp mode
View
Default level
2: System level
stp: Configures the spanning tree device to work in STP-compatible mode.
rstp: Configures the spanning tree device to work in RSTP mode.
mstp: Configures the spanning tree device to work in MSTP mode.
Use the stp mode command to configure the spanning tree work mode.
Use the undo stp mode command to restore the default.
By default, a spanning tree device works in MSTP mode.
Related commands: stp mcheck and stp enable.
# Configure the spanning tree device to work in STP-compatible mode.
[Sysname] stp mode stp
stp no-agreement-check
undo stp no-agreement-check
View
Default level
2: System level
None
Use the stp no-agreement-check command to enable No Agreement Check on the ports.
Use the undo stp no-agreement-check command to disable No Agreement Check on the ports.
By default, No Agreement Check is disabled.
Configured in port group view, the setting takes effect on all member ports in the port group.
This feature takes effect only after you enable it on the root port.
# Enable No Agreement Check on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] stp no-agreement-check
stp pathcost-standard { dot1d-1998 | dot1t | legacy }
undo stp pathcost-standard
View
Default level
2: System level
dot1d-1998: Configures the device to calculate the default path cost for ports based on IEEE 802.1d-1998.
dot1t: Configures the device to calculate the default path cost for ports based on IEEE 802.1t.
legacy: Configures the device to calculate the default path cost for ports based on a private standard.
Use the stp pathcost-standard command to specify a standard for the device to use when calculating the default path costs for ports.
Use the undo stp pathcost-standard command to restore the default.
By default, the legacy standard is used to calculate the default path costs for ports.
If you change the standard that the device uses in calculating the default path costs, you restore the path costs to the default.
Related commands: stp cost and display stp.
# Configure the device to calculate the default path cost for ports based on IEEE 802.1d-1998.
[Sysname] stp pathcost-standard dot1d-1998
stp point-to-point
stp point-to-point { auto | force-false | force-true }
undo stp point-to-point
View
Default level
2: System level
auto: Specifies automatic detection of the link type.
force-false: Specifies the non-point-to-point link type.
force-true: Specifies the point-to-point link type.
Use the stp point-to-point command to configure the link type of the ports.
Use the undo stp point-to-point command to restore the default.
The default setting is auto and the spanning tree device automatically detects whether a port connects to a point-to-point link.
When connecting to a non-point-to-point link, a port is incapable of rapid state transition.
You can configure the link type as point-to-point for an aggregate interface or a port that works in full duplex mode. H3C recommends that you use the default setting to let the device automatically detect the port link type.
The stp point-to-point force-false or stp point-to-point force-true command configured on a port in MSTP mode is effective for all MSTIs.
If the physical link to which the port connects is not a point-to-point link but you set it to be one, your configuration may bring a temporary loop.
# Configure the link connecting GigabitEthernet 1/0/3 as a point-to-point link.
[Sysname-GigabitEthernet1/0/3] stp point-to-point force-true
stp port priority
stp [ instance instance-id ] port priority priority
undo stp [ instance instance-id ] port priority
View
Default level
2: System level
instance instance-id: Sets the priority of the ports in a particular MSTI. The instance-id argument specifies a MSTI ID, and ranges from 0 to 15. MSTI 0 is the CIST.
priority: Specifies a port priority, ranging from 0 to 240 in steps of 16 (as in 0, 16, 32).
Use the stp port priority command to set the priority of the ports.
Use the undo stp port priority command to restore the default.
By default, the port priority is 128.
You can set different priorities for a port in different MSTIs, so that packets from different VLANs are forwarded along different physical links to implement VLAN-based load sharing.
When the priority of a port is changed, MSTP will re-calculate the port role and transition its state.
# Set the priority of port GigabitEthernet 1/0/3 to 16 in MSTI 2.
[Sysname-GigabitEthernet1/0/3] stp instance 2 port priority 16
stp port-log
stp port-log { instance instance-id | all }
undo stp port-log { instance instance-id | all }
View
Default level
2: System level
instance instance-id: Enables output of port state transition information for the specified MSTI. The instance-id argument specifies a MSTI ID, and ranges from 0 to 15. MSTI 0 is the CIST.
all: Specifies all MSTIs.
vlan vlan-list: Specifies a VLAN list in the format of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>, where the vlan-id argument represents the VLAN ID, and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges.
Use the stp port-log command to enable output of port state transition information for the specified MSTI or all MSTIs.
Use the undo stp port-log command to disable output of port state transition information for the specified MSTI or all MSTIs.
By default, output of port state transition information is enabled.
# Enable output of port state transition information for MSTI 2.
[Sysname] stp port-log instance 2
%Aug 16 00:49:41:856 2006 Sysname MSTP/3/PDISC: Instance 2's GigabitEthernet1/0/1 has been set to discarding state!
%Aug 16 00:49:41:856 2006 Sysname MSTP/3/PFWD: Instance 2's GigabitEthernet1/0/2 has been set to forwarding state!
The output shows that GigabitEthernet 1/0/1 in MSTI 2 transitioned to the discarding state and GigabitEthernet 1/0/2 in MSTI 2 transitioned to the forwarding state.
stp priority
stp [ instance instance-id ] priority priority
undo stp [ instance instance-id ] priority
View
Default level
2: System level
instance instance-id: Sets the priority of the device in a MSTI. The instance-id argument specifies a MSTI ID, and ranges from 0 to 15. MSTI 0 is the CIST.
priority: Specifies a device priority, ranging from 0 to 61440 in steps of 4096 (as in 0, 4096, 8192). You can set up to 16 priority values on the device. The smaller the value, the higher the device priority.
Use the stp priority command to set the priority of the device.
Use the undo stp priority command to restore the default priority.
By default, the device priority is 32768.
# Set the device priority to 4096 in MSTI 1.
[Sysname] stp instance 1 priority 4096
undo stp region-configuration
View
Default level
2: System level
None
Use the stp region-configuration command to enter MST region view.
Use the undo stp region-configuration command to restore the default MST region configurations.
These are the default settings for the MST region:
·           The MST region name of the device is the MAC address of the device.
·           All VLANs are mapped to the CIST.
·           The MSTP revision level is 0.
After you enter MST region view, you can configure the MST region-related parameters, including the region name, VLAN-to-instance mappings, and revision level.
# Enter MST region view.
stp root primary
stp [ instance instance-id ] root primary
undo stp [ instance instance-id ] root
View
Default level
2: System level
instance instance-id: Configures the device as the root bridge in a particular MSTI. The instance-id argument specifies a MSTI ID, and ranges from 0 to 15. MSTI 0 is the CIST.
Use the stp root primary command to configure the device as the root bridge.
Use the undo stp root command to restore the default.
By default, a device is not a root bridge.
An MSTI has only one valid root bridge. If you specify two or more devices as the root bridges for the same MSTI, the device with the lowest MAC address acts as the root bridge.
You can specify a root bridge for each MSTI, regardless of device priorities. Once you specify the device as the root bridge, you cannot change the priority of the device.
Related commands: stp priority and stp root secondary.
# Specify the device as the root bridge of MSTI 1.
[Sysname] stp instance 1 root primary
stp root secondary
stp [ instance instance-id ] root secondary
View
Default level
2: System level
instance instance-id: Configures the device as a secondary root bridge in a particular MSTI. The instance-id argument specifies a MSTI ID, and ranges from 0 to 15. MSTI 0 is the CIST.
Use the stp root secondary command to configure the device as a secondary root bridge.
By default, a device is not a secondary root bridge.
You can configure multiple secondary root bridges for an MSTI. When the root bridge of the MSTI fails or is powered down, a secondary root bridge can take over to become the root bridge. However, if you specify a new root bridge for the MSTI, a secondary root bridge will not take over. If you configure multiple secondary root bridges for an MSTI, the one with the lowest MAC address will take over.
Once you specify the device as a secondary root bridge, you cannot change the priority of the device.
Related commands: stp priority and stp root primary.
# Specify the device as a secondary root bridge in MSTI 1.
[Sysname] stp instance 1 root secondary
stp root-protection
stp root-protection
undo stp root-protection
View
Default level
2: System level
None
Use the stp root-protection command to enable the root guard function on the ports.
Use the undo stp root-protection command to restore the default.
By default, the root guard function is disabled.
Configured on the member port in an aggregation group, the setting takes effect only after the port leaves the aggregation group.
You cannot configure root guard and loop guard on a port at the same time.
# Enable the root guard function for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] stp root-protection
stp tc-protection
stp tc-protection enable
stp tc-protection disable
View
Default level
2: System level
None
Use the stp tc-protection enable command to enable the TC-BPDU attack guard function for the device.
Use the stp tc-protection disable command to disable the TC-BPDU attack guard function for the device.
By default, the TC-BPDU attack guard function is enabled.
# Disable the TC-BPDU attack guard function for the device.
[Sysname] stp tc-protection disable
stp tc-protection threshold
stp tc-protection threshold number
undo stp tc-protection threshold
View
Default level
2: System level
number: Sets the maximum number of immediate forwarding address entry flushes that the device can perform within a certain period of time (10 seconds). The value ranges from 1 to 255.
Use the stp tc-protection threshold command to configure the maximum number of forwarding address entry flushes that the device can perform every a certain period of time (10 seconds).
Use the undo stp tc-protection threshold command to restore the default.
By default, the device can perform a maximum of six forwarding address entry flushes every 10 seconds.
# Configure the device to perform up to 10 forwarding address entry flushes every 10 seconds.
[Sysname] stp tc-protection threshold 10
stp timer forward-delay time
undo stp timer forward-delay
View
Default level
2: System level
time: Sets the forward delay in centiseconds, ranging from 400 to 3000 in steps of 100 (as in 400, 500, 600).
Use the stp timer forward-delay command to set the forward delay timer of the device.
Use the undo stp timer forward-delay command to restore the default.
By default, the forward delay timer is 1500 centiseconds.
The forward delay timer determines the time interval of state transition. To prevent temporary loops, a spanning tree port goes through the learning (intermediate) state before it transitions from the discarding to the forwarding state. To stay synchronized with the remote device, the port has a wait period between transition states that is determined by the forward delay timer.
H3C does not recommend you to set the forward delay with this command. Instead, you can specify the network diameter of the switched network by using the stp bridge-diameter command and let spanning tree protocols automatically calculate optimal settings of the forward delay timer. If the network diameter uses the default value, the forward delay timer also uses the default value.
Related commands: stp timer hello, stp timer max-age, and stp bridge-diameter.
# Set the forward delay timer to 2000 centiseconds.
[Sysname] stp timer forward-delay 2000
stp timer hello
stp timer hello time
undo stp timer hello
View
Default level
2: System level
time: Sets the hello time in centiseconds, ranging from 100 to 1000 in steps of 100 (as in 100, 200, 300).
Use the stp timer hello command to set the hello time of the device.
Use the undo stp timer hello command to restore the default.
By default, the hello time is 200 centiseconds.
Hello time is the time interval at which spanning tree devices send configuration BPDUs to maintain spanning tree. If a device fails to receive configuration BPDUs within the set period of time, a new spanning tree calculation process will be triggered due to timeout.
H3C does not recommend you to set the hello time with this command. Instead, you can specify the network diameter of the switched network by using the stp bridge-diameter command and let spanning tree protocols automatically calculate optimal settings of the hello timer. If the network diameter uses the default value, the hello timer also uses the default value.
Related commands: stp timer forward-delay, stp timer max-age, and stp bridge-diameter.
# Set the hello time to 400 centiseconds.
[Sysname] stp timer hello 400
stp timer max-age
stp timer max-age time
undo stp timer max-age
View
Default level
2: System level
time: Sets the max age in centiseconds, ranging from 600 to 4000 in steps of 100 (as in 600, 700, 800).
Use the stp timer max-age command to set the max age timer of the device.
Use the undo stp timer max-age command to restore the default.
By default, the max age is 2000 centiseconds.
In the CIST of an MSTP network, the device determines whether a configuration BPDU received on a port has expired based on the max age timer. If yes, a new spanning tree calculation process starts. The max age timer is ineffective for MSTIs.
H3C does not recommend you to set the max age timer with this command. Instead, you can specify the network diameter of the switched network by using the stp bridge-diameter command and let spanning tree protocols automatically calculate optimal settings of the max age timer. If the network diameter uses the default value, the max age timer also uses the default value.
Related commands: stp timer forward-delay, stp timer hello, and stp bridge-diameter.
# Set the max age timer to 1000 centiseconds.
[Sysname] stp timer max-age 1000
stp timer-factor
stp timer-factor factor
undo stp timer-factor
View
Default level
2: System level
factor: Sets the timeout factor, ranging from 1 to 20.
Use the stp timer-factor command to set the timeout factor, which decides the timeout time.
Timeout time = timeout factor × 3 × hello time.
Use the undo stp timer-factor command to restore the default.
By default, the timeout factor is 3.
After the network topology is stabilized, each non-root-bridge device forwards configuration BPDUs to the surrounding devices at the interval of hello time to check whether any link is faulty. If a device does not receive a BPDU from the upstream device within nine times the hello time, it will assume that the upstream device has failed and start a new spanning tree calculation process.
In a stable network, this kind of spanning tree calculation may occur because the upstream device is busy. You can avoid such unwanted spanning tree calculations by lengthening the timeout time, saving the network resources. H3C recommends you to set the timeout factor to 5, 6, or 7 for a stable network.
Related commands: stp timer hello.
# Set the timeout factor of the device to 7.
[Sysname] stp timer-factor 7
stp transmit-limit
stp transmit-limit limit
undo stp transmit-limit
View
Default level
2: System level
limit: Sets the maximum number of BPDUs the ports can send within each hello time, ranging from 1 to 255.
Use the stp transmit-limit command to set the maximum transmission rate of the ports, which specifies the maximum number of BPDUs the ports can send within each hello time.
Use the undo stp transmit-limit command to restore the default.
By default, the maximum transmission rate of all ports is 10. Each port can send up to 10 BPDUs within each hello time.
A larger maximum transmission rate value requires more system resources. An appropriate maximum transmission rate setting can limit the speed at which a port sends BPDUs and prevent spanning tree protocols from using excessive bandwidth resources during network topology changes. H3C recommends you to use the default value.
# Set the maximum transmission rate of port GigabitEthernet 1/0/1 to 5.
[Sysname-GigabitEthernet1/0/1] stp transmit-limit 5
vlan-mapping modulo
vlan-mapping modulo modulo
View
MST region view
Default level
2: System level
modulo: Sets the modulo value, which ranges from 1 to 15.
Use the vlan-mapping modulo command to map VLANs in the MST region to MSTIs according to the specified modulo value, quickly creating a VLAN-to-instance mapping table.
By default, all VLANs are mapped to the CIST (MSTI 0).
This command maps each VLAN to the MSTI whose ID is (VLAN ID - 1) %modulo + 1, where (VLAN ID - 1) %modulo is the modulo operation for (VLAN ID - 1). If the modulo value is 15, for example, then VLAN 1 will be mapped to MSTI 1, VLAN 2 to MSTI 2, VLAN 15 to MSTI 15, VLAN 16 to MSTI 1, and so on.
Related commands: region-name, revision-level, display stp region-configuration, check region-configuration, and active region-configuration.
# Map VLANs to MSTIs as per modulo 8.
[Sysname-mst-region] vlan-mapping modulo 8
