02-Layer 2 Command Reference
HomeSupportWirelessWX3000E Series Wireless SwitchesReference GuidesCommand ReferencesH3C WX3000E Series Wireless Switches Switching Engine Command References(R3507P26)-6W10202-Layer 2 Command Reference
07-VLAN Commands
07-VLAN Commands 212.86 KB
VLAN configuration commands
The term "switch" or "device" in this chapter refers to the switching engine on a WX3000E wireless switch.
The WX3000E series comprises WX3024E and WX3010E wireless switches.
The port numbers in this chapter are for illustration only.
description
View
VLAN view, VLAN interface view
Default level
2: System level
text: Specifies a description for a VLAN or VLAN interface. The string can include case-sensitive letters, digits, special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /), spaces, and other Unicode characters and symbols.
·           For a VLAN, this is a string of 1 to 32 characters.
·           For a VLAN interface, this is a string of 1 to 80 characters.
·       Each Unicode character takes the space of two regular characters.
·       To use Unicode characters or symbols in an interface description, install the specific input method editor and log in to the device through remote login software that supports the character type.
·       When the length of a description string reaches or exceeds the maximum line width on the terminal software, the software starts a new line, possibly breaking a Unicode character into two. As a result, garbled characters may be displayed at the end of a line.
Use the description command to change the description of the VLAN or VLAN interface.
Use the undo description command to restore the default.
·           For a VLAN, the default description is the VLAN ID. For example, VLAN 0001.
·           For a VLAN interface, the default description is the name of the interface. For example, Vlan-interface1 Interface.
You can configure a description to describe the function or connection of a VLAN or VLAN interface, which is very helpful when a large number of VLANs are created on the device.
# Change the description of VLAN 2 to sales-private.
[Sysname] vlan 2
[Sysname-vlan2] description sales-private
# Change the description of VLAN-interface 2 to linktoPC56.
[Sysname] vlan 2
[Sysname-vlan2] quit
[Sysname-Vlan-interface2] description linktoPC56
display interface vlan-interface
display interface [ vlan-interface ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface vlan-interface vlan-interface-id [ brief ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan-interface-id: Specifies a VLAN interface number.
down: Displays information about interfaces in the DOWN state and the causes. If you do not specify this keyword, this command displays information about interfaces in all states.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see the Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, which is a case sensitive string of 1 to 256 characters.
Use the display interface vlan-interface command to display information about a specified or all VLAN interfaces.
If you do not provide the vlan-interface keyword, this command displays information about all interfaces.
If you provide the vlan-interface keyword but do not specify the VLAN interface number, this command displays information about all VLAN interfaces.
Related commands: reset counters interface vlan-interface.
# Display information for VLAN-interface 2, which supports interface statistics collection.
<Sysname> display interface vlan-interface 2
Vlan-interface2 current state: DOWN
Line protocol current state: DOWN
Description: Vlan-interface2 Interface
The Maximum Transmit Unit is 1500
Internet protocol processing : disabled
IP Packet Frame Type: PKTFMT_ETHNT_2,  Hardware Address: 000f-e249-8050
IPv6 Packet Frame Type: PKTFMT_ETHNT_2,  Hardware Address: 000f-e249-8050
Last clearing of counters:  Never
     Last 300 seconds input:  0 bytes/sec 0 packets/sec
     Last 300 seconds output:  0 bytes/sec 0 packets/sec
     0 packets input, 0 bytes, 0 drops
     0 packets output, 0 bytes, 0 drops
# Display brief information for VLAN-interface 2.
<Sysname> display interface vlan-interface 2 brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Vlan2                DOWN DOWN     --
# Display brief information for VLAN interfaces in DOWN state.
<Sysname> display interface vlan-interface brief down
Vlan2                DOWN Not connected
Table 1 Output description
The physical state of a VLAN interface:
·       DOWN ( Administratively )—The administrative state of the VLAN interface is down, because it has been shut down with the shutdown command.
·       DOWN—The administrative sate of the VLAN interface is up, but its physical sate is down. The VLAN corresponding to this interface does not contain any physical port in the UP state (possibly because the ports are not well connected or the lines have failed).
·       UP—Both the administrative state and the physical state of the VLAN interface are up.
The link layer protocol state of a VLAN interface:
·       DOWN—The protocol state of the VLAN interface is down.
·       UP—The protocol state of the VLAN interface is up.
The description string of a VLAN interface.
The MTU of a VLAN interface.
The interface is not capable of processing IP packets. This information is displayed when the interface is not configured with an IP address.
Internet Address is 192.168.1.54/24 Primary
The primary IP address of the interface is 192.168.1.54/24. This information is displayed only if the primary IP address is configured for the interface.
The IPv4 outgoing frame format.
Hardware address
The MAC address corresponding to a VLAN interface.
The IPv6 outgoing frame format.
The time when the reset counts interface vlan-interface command was last used to clear the interface statistics.
Never indicates the reset counters interface command has never been used on the interface since the device’s startup.
Average rate of input packets in the last 300 seconds (in bps and pps).
Average rate of output packets in the last 300 seconds (in bps and pps).
Total number and size (in bytes) of the received packets of the interface and the number of the dropped packets.
Total number and size (in bytes) of the sent packets of the interface and the number of the dropped packets.
Brief information about Layer 3 interfaces.
ADM—The interface has been administratively shut down. To recover its physical state, perform the undo shutdown command.
Stby—The interface is operating as a standby interface. To see the main interface, use the display standby state command.
If the network layer protocol state of an interface is shown as UP, but its link is an on-demand link or not present at all, its protocol attribute includes the spoofing flag (an s in parentheses).
The abbreviated interface name.
Link
The physical link state of the interface:
·       UP—The link is up.
·       ADM—The link has been administratively shut down. To recover its physical state, perform the undo shutdown command.
Protocol
Protocol connection state of the interface, which can be UP, DOWN, or UP(s).
Main IP
The main IP address of the interface.
The description of the interface.
Cause
The cause of a DOWN physical link. If the port has been shut down with the shutdown command, this field displays Administratively. To restore the physical state of the interface, use the undo shutdown command.
display vlan
display vlan [ vlan-id1 [ to vlan-id2 ] | all | dynamic | reserved | static ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan-id1: Displays information about a VLAN specified by VLAN ID, ranging from 1 to 4094.
vlan-id1 to vlan-id2: Displays information about VLANs specified by a VLAN ID range.
all: Displays all VLAN information except for the reserved VLANs.
dynamic: Displays the number of dynamic VLANs and the ID for each dynamic VLAN. The dynamic VLANs are generated through GVRP or those distributed by a RADIUS server.
reserved: Displays information about the reserved VLANs. Protocol modules determine which VLANs are reserved VLANs according to function implementation, and reserved VLANs serve protocol modules. You cannot do any configuration on reserved VLANs.
static: Displays the number of static VLANs and the ID for each static VLAN. The static VLANs are manually created.
Use the display vlan command to display VLAN information.
Related commands: vlan.
# Display VLAN 2 information.
<Sysname> display vlan 2
 VLAN ID: 2
 VLAN Type: static
 Route interface: not configured
 Description: VLAN 0002
 Tagged   Ports: none
 Untagged Ports:
    GigabitEthernet1/0/1     GigabitEthernet1/0/2     GigabitEthernet1/0/3
# Display VLAN 3 information.
<Sysname> display vlan 3
 VLAN ID: 3
 VLAN Type: static
 Route Interface: configured
 IP Address: 1.1.1.1
 Subnet Mask: 255.255.255.0
 Description: VLAN 0003
 Tagged   Ports: none
 Untagged Ports: none
Table 2 Output description
VLAN Type
VLAN type, static or dynamic.
Route interface
Indicates whether the VLAN interface is configured or not.
Description of the VLAN.
Name
Name configured for the VLAN.
IP Address
Primary IP address of the VLAN interface (available only when an IP address is configured for the VLAN interface). To display secondary IP addresses, use the display interface vlan-interface command in any view or the display this command in VLAN interface view.
Subnet Mask
Subnet mask of the primary IP address (available only when an IP address is configured for the VLAN interface).
Tagged Ports
Ports through which VLAN packets are sent tagged.
Untagged Ports
Ports through which VLAN packets are sent untagged.
undo interface vlan-interface vlan-interface-id
View
Default level
2: System level
vlan-interface-id: Specifies a VLAN interface number, ranging from 1 to 4094.
Use the interface vlan-interface command to create a VLAN interface and enter its view or enter the view of an existing VLAN interface.
Use the undo interface vlan-interface command to remove the specified VLAN interface.
Create the VLAN before you create the VLAN interface.
To configure an IP address for a VLAN interface that will perform IP routing, use the ip address command in VLAN interface view.
Related commands: display interface vlan-interface.
# Create VLAN-interface 2.
[Sysname] vlan 2
ip address
ip address ip-address { mask | mask-length }
undo ip address [ ip-address { mask | mask-length }
View
VLAN interface view
Default level
2: System level
ip-address: Specifies an IP address in dotted decimal notation.
mask: Specifies a subnet mask in dotted decimal notation.
mask-length: Sets the number of consecutive 1s in the subnet mask, ranging from 0 to 32.
Use the ip address command to assign an IP address and subnet mask to a VLAN interface.
Use the undo ip address command to remove the IP address and subnet mask for a VLAN interface.
By default, no IP address is assigned to any VLAN interface.
Related commands: display ip interface (Layer 3—IP Services Command Reference).
# Specify the IP address as 1.1.0.1, the subnet mask as 255.255.255.0 for VLAN interface 1.
[Sysname-Vlan-interface1] ip address 1.1.0.1 255.255.255.0
name
name text
undo name
View
VLAN view
Default level
2: System level
text: Specifies a VLAN name, a string of 1 to 32 characters. The string can include case-sensitive letters, digits, special characters (including ~ ! @ # $ % ^ & * ( ) - _ + = { } [ ] | \ : ; " ' < > , . /), and spaces.
Use the name command to configure a name for the VLAN.
Use the undo name command to restore the default name of the VLAN.
By default, the name of a VLAN is its VLAN ID. For example, VLAN 0001.
When 802.1X or MAC address authentication is configured on a switch, you can use a RADIUS server to issue VLAN configuration to ports that have passed the authentication. Some servers can send IDs or names of the issued VLANs to the switch. You can use VLAN names, rather than VLAN IDs, to distinguish a large number of VLANs.
# Configure the name of VLAN 2 as Test VLAN.
[Sysname] vlan 2
[Sysname-vlan2] name Test VLAN
reset counters interface vlan-interface [ vlan-interface-id ]
View
Default level
2: System level
Use the reset counters interface vlan-interface command to clear the statistics on a VLAN interface.
Before collecting the traffic statistics within a specific period of time on an interface, you need to clear the existing statistics first.
If the vlan-interface-id argument is not specified, this command clears the statistics of all VLAN interfaces.
If the vlan-interface-id argument is specified, this command clears the statistics of the specified VLAN interface.
# Clear the statistics on VLAN-interface 2.
<Sysname> reset counters interface vlan-interface 2
shutdown
shutdown
View
VLAN interface view
Default level
2: System level
None
Use the shutdown command to shut down a VLAN interface.
Use the undo shutdown command to bring up a VLAN interface.
By default, a VLAN interface is up unless all ports in the VLAN are down.
You can use the undo shutdown command to bring up a VLAN interface after you have configured related parameters and protocols for the VLAN interface. You can shut down a failed interface with the shutdown command and then bring it up with the undo shutdown command to see if it recovers.
In a VLAN, the state of any Ethernet port is independent of the state of the VLAN interface.
# Shut down VLAN-interface 2 and then bring it up.
[Sysname-Vlan-interface2] shutdown
[Sysname-Vlan-interface2] undo shutdown
vlan
vlan { vlan-id1 [ to vlan-id2 ] | all }
undo vlan { vlan-id1 [ to vlan-id2 ] | all }
View
Default level
2: System level
vlan-id1, vlan-id2: Specifies a VLAN ID, ranging from 1 to 4094.
vlan-id1 to vlan-id2: Specifies a VLAN range.
all: Creates or removes all VLANs except reserved VLANs. The keyword is not supported when the maximum number of VLANs that can be created on a device is less than 4094.
Use the vlan vlan-id command to create a VLAN and enter its view or enter the view of an existing VLAN.
Use the vlan vlan-id1 to vlan-id2 command to create VLANs ranging from vlan-id1 to vlan-id2, except reserved VLANs.
Use the undo vlan command to remove the specified VLANs.
You cannot create or remove the default VLAN (VLAN 1).
You cannot create or remove reserved VLANs reserved for specific functions.
For the following VLANs, you must remove the related configurations first, because you cannot use the undo vlan command to directly remove them:
·           Protocol reserved VLANs
·           Voice VLANs
·           Management VLANs
·           Dynamic VLANs
·           VLANs configured with QoS policies
·           Control VLANs configured for smart link groups
·           Source VLANs for port mirroring
·           Remote probe VLANs for remote port mirroring
Related commands: display vlan.
# Enter VLAN 2 view.
[Sysname] vlan 2
[Sysname-vlan2]
# Create VLAN 4 through VLAN 100.
[Sysname] vlan 4 to 100
Please wait............. Done.
Port-based VLAN configuration commands
display port
display port { hybrid | trunk } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
hybrid: Displays hybrid ports.
trunk: Displays trunk ports.
Use the display port command to display information about the hybrid or trunk ports on the device, including the port names, PVIDs, and allowed VLAN IDs.
# Display information about the hybrid ports in the system.
<Sysname> display port hybrid
Interface            PVID  VLAN passing
GE1/0/4              100   Tagged:  1000, 1002, 1500, 1600-1611, 2000,
                                    2555-2558, 3000, 4000
                           Untagged:1, 10, 15, 18, 20-30, 44, 55, 67, 100,
                                    150-160, 200, 255, 286, 300-302
# Display information about the trunk ports in the system.
<Sysname> display port trunk
GE1/0/8              2     1-4, 6-100, 145, 177, 189-200, 244, 289, 400,
                           555, 600-611, 1000, 2006-2008
Table 3 Output description
Port name.
PVID
Port VLAN ID.
VLAN passing
VLANs for which the port allows packets to pass through.
Tagged
VLANs for which the port sends packets without removing VLAN tags.
Untagged
VLANs for which the port sends packets after removing VLAN tags.
port
port interface-list
undo port interface-list
View
VLAN view
Default level
2: System level
interface-list: Specifies an interface list, in the format of interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where interface-type interface-number represents the interface type and interface number and &<1-10> indicates that you can specify up to 10 ports or port ranges.
Use the port command to assign the specified access ports to the VLAN.
Use the undo port command to remove the specified access ports from the VLAN.
By default, all ports are in VLAN 1.
This command is only applicable on access ports.
By default, all ports are access ports. However, you can manually configure the port type. For more information, see “port link-type.”
You cannot assign Layer 2 aggregate interfaces to a VLAN.
# Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] port gigabitethernet 1/0/1 to gigabitethernet 1/0/3
port access vlan
port access vlan vlan-id
undo port access vlan
View
Ethernet interface view, port group view, aggregate interface view
Default level
2: System level
vlan-id: Specifies a VLAN ID, ranging from 1 to 4094. Make sure that the VLAN specified by the VLAN ID already exists.
Use the port access vlan command to assign the access ports to the specified VLAN.
Use the undo port access vlan command to restore the default.
By default, all access ports belong to VLAN 1.
The configuration made in Ethernet interface view applies only to the port.
The configuration made in port group view applies to all ports in the port group.
The configuration made in aggregate interface view applies to the aggregate interface and its aggregation member ports.
·           If the system fails to apply the configuration to the aggregate interface, it stops applying the configuration to aggregation member ports.
·           If the system fails to apply the configuration to an aggregation member port, it skips the port and moves to the next member port.
# Assign GigabitEthernet 1/0/1 to VLAN 3.
[Sysname] vlan 3
[Sysname-vlan3] quit
[Sysname-GigabitEthernet1/0/1] port access vlan 3
# Assign aggregate interface Bridge-Aggregation 1 and its member ports to VLAN 3.
[Sysname] vlan 3
[Sysname-Bridge-Aggregation1] port access vlan 3
port hybrid pvid
port hybrid pvid vlan vlan-id
undo port hybrid pvid
View
Default level
2: System level
Use the port hybrid pvid command to configure the PVID of the hybrid port.
Use the undo port hybrid pvid command to restore the default.
By default, the PVID of a hybrid port is VLAN 1.
You can use a nonexistent VLAN as the PVID for a hybrid port. If you remove the PVID of a hybrid port with the undo vlan command, it does not affect the setting of the PVID on the port.
The configuration made in Ethernet view applies only to the port.
H3C recommends that you set the same PVID for the local and remote hybrid ports.
You must use the port hybrid vlan command to configure the hybrid port to allow and forward packets from the PVID.
Related commands: port link-type and port hybrid vlan.
# Configure VLAN 100 as the PVID of the hybrid port GigabitEthernet 1/0/1.
[Sysname] vlan 100
[Sysname-vlan100] quit
[Sysname-GigabitEthernet1/0/1] port link-type hybrid
[Sysname-GigabitEthernet1/0/1] port hybrid pvid vlan 100
# Configure VLAN 100 as the PVID of the hybrid Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] port link-type hybrid
[Sysname-Bridge-Aggregation1] port hybrid pvid vlan 100
port hybrid vlan
undo port hybrid vlan vlan-id-list
View
Default level
2: System level
vlan-id-list: Specifies a list of VLANs that the hybrid ports will be assigned to, in the format of [ vlan-id1 [ to vlan-id2 ] ]&<1-10>, where vlan-id ranges from 1 to 4094 and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges. Make sure that the specified VLANs already exist.
tagged: Configures the ports to send the packets of the specified VLANs without removing VLAN tags.
untagged: Configures the ports to send the packets of the specified VLANs after removing VLAN tags.
Use the port hybrid vlan command to assign the hybrid ports to the specified VLANs.
Use the undo port hybrid vlan command to remove the hybrid ports from the specified VLANs.
By default, a hybrid port only allows packets from VLAN 1 to pass through untagged.
A hybrid port can carry multiple VLANs. If you execute the port hybrid vlan command multiple times, the VLANs the hybrid port carries are the set of VLANs specified by vlan-id-list in each execution.
Related commands: port link-type.
# Assign the hybrid port GigabitEthernet 1/0/1 to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100, and configure GigabitEthernet 1/0/1 to send packets of these VLANs with tags kept.
[Sysname-GigabitEthernet1/0/1] port hybrid vlan 2 4 50 to 100 tagged
# Assign hybrid ports in port group 2 to VLAN 2, and configure these hybrid ports to send packets of VLAN 2 with VLAN tags removed.
[Sysname] vlan 2
[Sysname] port-group manual 2
[Sysname-port-group-manual-2] group-member gigabitethernet 1/0/1 to gigabitethernet 1/0/6
[Sysname-port-group-manual-2] port link-type hybrid
[Sysname-port-group-manual-2] port hybrid vlan 2 untagged
 Configuring GigabitEthernet1/0/1... Done.
 Configuring GigabitEthernet1/0/2... Done.
 Configuring GigabitEthernet1/0/3... Done.
 Configuring GigabitEthernet1/0/4... Done.
 Configuring GigabitEthernet1/0/5... Done.
 Configuring GigabitEthernet1/0/6... Done.
# Assign the hybrid Layer 2 aggregate interface Bridge-Aggregation 1 and its member ports to VLAN 2, and configure them to send packets of VLAN 2 with tags removed.
[Sysname-Bridge-Aggregation1] port hybrid vlan 2 untagged
 Please wait... Done.
The output shows that GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 are the member ports of the aggregation group corresponding to Bridge-Aggregation 1.
port link-type
undo port link-type
View
Default level
2: System level
access: Configures the link type of a port as access.
hybrid: Configures the link type of a port as hybrid.
trunk: Configures the link type of a port as trunk.
Use the port link-type command to configure the link type of a port.
Use the undo port link-type command to restore the default link type of a port.
By default, any port is an access port.
To change the link type of a port from trunk to hybrid or vice versa, you must set the link type to access.
After you change the link type of an interface with the port link-type command, the loopback detection action configured on the interface with the loopback-detection action command automatically restores the default. For more information about the loopback-detection action command, see the Interface Command Reference.
# Configure GigabitEthernet 1/0/1 as a trunk port.
# Configure all the ports in the manual port group group1 as hybrid ports.
[Sysname] port-group manual group1
[Sysname-port-group manual group1] group-member gigabitethernet 1/0/1
[Sysname-port-group manual group1] group-member gigabitethernet 1/0/2
[Sysname-port-group manual group1] port link-type hybrid
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 and its member ports as hybrid ports.
port trunk permit vlan
undo port trunk permit vlan { vlan-id-list | all }
View
Default level
2: System level
vlan-id-list: Specifies a list of VLANs that the trunk ports will be assigned to, in the format of [vlan-id1 [ to vlan-id2 ] ]&<1-10>, where vlan-id ranges from 1 to 4094 and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges.
all: Permits all VLANs to pass through the trunk ports. On GVRP-enabled trunk ports, you must configure the port trunk permit vlan all command to ensure that the traffic of all dynamically registered VLANs can pass through. To prevent unauthorized VLAN users from accessing restricted resources through a GVRP-disabled port, do not use the port trunk permit vlan all command on the port.
Use the port trunk permit vlan command to assign the trunk ports to the specified VLANs.
Use the undo port trunk permit vlan command to remove the trunk ports from the specified VLANs.
By default, a trunk port allows only packets from VLAN 1 to pass through.
A trunk port can carry multiple VLANs. If you execute the port trunk permit vlan command multiple times, the trunk port carries the set of VLANs specified by vlan-id-list in each execution.
On a trunk port, only traffic of the PVID can pass through untagged.
# Assign the trunk port GigabitEthernet 1/0/1 to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100.
[Sysname-GigabitEthernet1/0/1] port trunk permit vlan 2 4 50 to 100
Please wait........... Done.
# Assign the trunk Layer 2 aggregate interface Bridge-Aggregation 1 to VLAN 2.
[Sysname-Bridge-Aggregation1] port link-type trunk
[Sysname-Bridge-Aggregation1] port trunk permit vlan 2
port trunk pvid
port trunk pvid vlan vlan-id
undo port trunk pvid
View
Default level
2: System level
Use the port trunk pvid command to configure the PVID for the trunk port.
Use the undo port trunk pvid command to restore the default.
By default, the PVID of a trunk port is VLAN 1.
You can use a nonexistent VLAN as the PVID for a trunk port. If you remove the PVID of a trunk port with the undo vlan command, it does not affect the setting of the PVID on the port.
The local and remote trunk ports must use the same PVID for the traffic of the PVID to be transmitted properly.
You must use the port trunk permit vlan command to configure the trunk port to allow and forward packets from the PVID.
Related commands: port link-type and port trunk permit vlan.
# Configure VLAN 100 as the PVID of the trunk port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port trunk pvid vlan 100
# Configure VLAN 100 as the PVID of the trunk Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] port trunk pvid vlan 100
MAC-based VLAN configuration commands
display mac-vlan
display mac-vlan { all | dynamic | mac-address mac-address [ mask mac-mask ] | static | vlan vlan-id } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays all the MAC address-to-VLAN entries.
dynamic: Displays dynamically configured MAC address-to-VLAN entries.
mac-address mac-address: Displays the MAC address-to-VLAN entry containing the specified MAC address.
mask mac-mask: Displays the MAC address-to-VLAN entries with their MAC addresses in the specified range.
static: Displays the statically configured MAC address-to-VLAN entries.
vlan vlan-id: Displays the MAC address-to-VLAN entries associated with the specified VLAN.
Use the display mac-vlan command to display the specified MAC address-to-VLAN entries.
If mac-address mac-address is specified but mask is not specified, only the MAC address-to-VLAN entry containing the specified MAC address is displayed.
# Display all the MAC address-to-VLAN entries.
<Sysname> display mac-vlan all
The following MAC-VLAN address exist:
S: Static   D: Dynamic
MAC ADDR           MASK                    VLAN ID   PRIO    STATE
0008-0001-0000     FFFF-FF00-0000          5         3       S
0002-0001-0000     FFFF-FFFF-FFFF          5         3       S&D
Total MAC VLAN address count:2
Table 4 Output description
S: Static
The character S stands for the MAC address-to-VLAN entries that are configured statically.
D: Dynamic
The character D stands for the MAC address-to-VLAN entries that are configured dynamically.
MAC ADDR
MAC address of a MAC address-to-VLAN entry.
MASK
Mask of the MAC address of a MAC address-to-VLAN entry.
VLAN ID
VLAN ID of a MAC address-to-VLAN entry.
PRIO
802.1p priority corresponding to the MAC address of a MAC address-to-VLAN entry
STATE
The state of a MAC address-to-VLAN entry:
·       S—The MAC address-to-VLAN entry is configured statically.
·       D—The MAC address-to-VLAN entry is configured automatically through the authentication server.
·       S&D—The MAC address-to-VLAN entry is configured both statically and dynamically.
display mac-vlan interface
display mac-vlan interface [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display mac-vlan interface command to display all the ports with MAC-based VLAN enabled.
Related commands: mac-vlan enable.
# Display all the interfaces with MAC-based VLAN enabled.
<Sysname> display mac-vlan interface
MAC VLAN is enabled on following ports:
mac-vlan enable
mac-vlan enable
undo mac-vlan enable
View
Layer 2 Ethernet port view
Default level
2: System level
None
Use the mac-vlan enable command to enable the MAC-based VLAN feature on a port.
Use the undo mac-vlan enable command to disable the MAC-based VLAN feature on a port.
By default, the MAC-based VLAN feature is disabled on a port.
# Enable the MAC-based VLAN feature on GigabitEthernet 1/0/1.
[Sysname–GigabitEthernet1/0/1] mac-vlan enable
mac-vlan mac-address
mac-vlan mac-address mac-address [ mask mac-mask ] vlan vlan-id [ priority pri ]
undo mac-vlan { all | mac-address mac-address [ mask mac-mask ] | vlan vlan-id }
View
Default level
2: System level
mac-address mac-address: Specifies a MAC address.
mask mac-mask: Specifies a mask for the MAC address in the format of H-H-H. The mac-mask argument is comprised of the high-order part (all the binary bits of which are 1s) and the low-order part (all the binary bits of which are 0s). By default, the hexadecimal digits of this argument are all Fs.
vlan vlan-id: Specifies a VLAN ID, ranging from of 1 to 4094.
priority pri: Specifies the 802.1p priority value corresponding to the specified MAC address. The pri argument ranges from 0 to 7.
all: Removes all the static MAC address-to-VLAN entries.
Use the mac-vlan mac-address command to associate the specified VLAN and priority value with the specified MAC addresses.
Use the undo mac-vlan command to remove the association.
Two MAC address-to-VLAN entry tables exist in a device. One table contains the MAC address-to-VLAN entries configured with the mask keyword specified. A MAC address-to-VLAN entry of this type describes the relationship between a group of MAC addresses and a VLAN, and a priority value. Another table contains the MAC address-to-VLAN entries configured without the mask keyword specified. A MAC address-to-VLAN entry of this type describes the relationship between a single MAC address and a VLAN, and a priority value. The system adds/removes MAC address-to-VLAN entries to/from the two tables according to the configuration.
# Associate a single MAC address 0-1-1 with VLAN 100 and 802.1p priority 7.
[Sysname] mac-vlan mac-address 0-1-1 vlan 100 priority 7
# Associate the MAC addresses with the high-order six hexadecimal digits being 111122 with VLAN 100 and 802.1p priority 4.
[Sysname] mac-vlan mac-address 1111-2222-3333 mask ffff-ff00-0000 vlan 100 priority 4
mac-vlan trigger enable
undo mac-vlan trigger enable
View
Default level
2: System level
None
Use the mac-vlan trigger enable command to enable dynamic MAC-based VLAN assignment. The port configured with this command will be dynamically assigned to VLANs based on the source MAC addresses of the received packets.
Use the undo mac-vlan trigger enable command to restore the default.
By default, dynamic MAC-based VLAN assignment is not enabled.
After receiving a packet with an unknown source MAC address, a port submits the packet to the CPU. If the source MAC address matches a MAC address-to-VLAN entry (whose mask is all Fs) maintained by the device, the device dynamically learns the source MAC address and assigns the receiving port to the corresponding VLAN. Then, subsequent packets with this source MAC address can be directly forwarded through the port. If the MAC address does not match any MAC address-to-VLAN entry or matches only a MAC address-to-VLAN entry whose mask is not all Fs, the device will not dynamically learn the MAC address and assign the receiving port to the corresponding VLAN.
# Enable dynamic MAC-based VLAN assignment on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-vlan trigger enable
port pvid disable
port pvid disable
undo port pvid disable
View
Default level
2: System level
None
Use the port pvid disable command to disable the PVID of the port from forwarding packets whose source MAC addresses do not match any MAC address-to-VLAN entry.
Use the undo port pvid disable command to restore the default.
By default, when a port receives a packet with an unknown source MAC address that does not match any MAC address-to-VLAN entry, it forwards the packet in its PVID.
# Disable the PVID of GigabitEthernet 1/0/1 from forwarding packets whose source MAC addresses do not match any MAC address-to-VLAN entry.
[Sysname-GigabitEthernet1/0/1] port pvid disable
Protocol-based VLAN configuration commands
display protocol-vlan interface
display protocol-vlan interface { interface-type interface-number1 [ to interface-type interface-number2 ] | all } [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
interface-type interface-number1: Specifies an interface by its type and number.
interface-type interface-number1 to interface-type interface-number2: Specifies an interface range.
all: Displays information about protocol-based VLANs on all ports.
Use the display protocol-vlan interface command to display information about protocol-based VLANs for the specified ports.
# Display protocol-based VLAN information on GigabitEthernet 1/0/1.
[Sysname] display protocol-vlan interface gigabitethernet 1/0/1
   VLAN ID   Protocol Index      Protocol Type
       2          0               ipv6
       3          0               ipv4
Table 5 Output description
VLAN ID
ID of the protocol-based VLAN bound to the port
Protocol Index
Protocol template index
Protocol Type
Protocol type specified by the protocol template
display protocol-vlan vlan
display protocol-vlan vlan { vlan-id1 [ to vlan-id2 ] | all } [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
vlan-id1: Specifies a protocol-based VLAN ID, ranging from 1 to 4094.
vlan-id1 to vlan-id2: Displays protocol-based VLAN information of a VLAN range from vlan-id1 to vlan-id2. The vlan-id2 argument specifies a protocol-based VLAN ID, ranging from 1 to 4094, but you must ensure that its value is greater than or equal to that of vlan-id1.
all: Displays information about all protocol-based VLANs.
Use the display protocol-vlan vlan command to display the protocols and protocol indexes configured on the specified VLANs.
# Display the protocols and protocol indexes configured on all protocol-based-VLANs.
<Sysname> display protocol-vlan vlan all
 VLAN ID:2
          0              ipv4
          3              ipv6
 VLAN ID:3
          0              ipv4
          1              ipv6
For the output description, see Table 5.
port hybrid protocol-vlan
port hybrid protocol-vlan vlan vlan-id { protocol-index [ to protocol-end ] | all }
undo port hybrid protocol-vlan { vlan vlan-id { protocol-index [ to protocol-end ] | all } | all }
View
Default level
2: System level
vlan vlan-id: Specifies a VLAN ID, ranging from 1 to 4094.
protocol-index: Specifies a protocol index. The value can be specified by the users or assigned by the system automatically when the protocol-based VLAN is created. You can use the display protocol-vlan vlan all command to display the protocol indexes.
to protocol-end: Specifies the end protocol index. The protocol-end argument must be greater than or equal to the beginning protocol index.
all: Specifies all protocols bound to vlan-id.
Use the port hybrid protocol-vlan command to associate the hybrid ports with a protocol-based VLAN.
Use the undo port hybrid protocol-vlan command to remove the association.
Before you use this command, make the following configurations:
·           Create a VLAN and associate it with specified protocols.
·           Configure the link type as hybrid.
·           Configure the port to allow the protocol-based VLAN to pass through.
Related commands: display protocol-vlan interface.
# Associate the hybrid port GigabitEthernet 1/0/1 with protocol 0 (IPv4) in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] protocol-vlan ipv4
[Sysname-GigabitEthernet1/0/1] port hybrid vlan 2 untagged
 Please wait... Done
[Sysname-GigabitEthernet1/0/1] port hybrid protocol-vlan vlan 2 0
# Associate the hybrid Layer 2 aggregate interface Bridge-Aggregation 1 with protocol 0 in VLAN 2.
[Sysname] vlan 2
 Please wait... Done
[Sysname-Bridge-Aggregation1] port hybrid protocol-vlan vlan 2 0
protocol-vlan
protocol-vlan [ protocol-index ] { at | ipv4 | ipv6 | ipx { ethernetii | llc | raw | snap } | mode { ethernetii etype etype-id | llc { dsap dsap-id [ ssap ssap-id ] | ssap ssap-id } | snap etype etype-id } }
undo protocol-vlan { protocol-index [ to protocol-end ] | all }
View
VLAN view
Default level
2: System level
at: Specifies the AppleTalk based VLAN.
ipv4: Specifies the IPv4 based VLAN.
ipv6: Specifies the IPv6 based VLAN.
ipx: Specifies the IPX based VLAN. The keywords ethernetii, llc, raw, and snap are encapsulation formats for IPX.
mode: Configures a user-defined protocol template for the VLAN, which could also have the following encapsulation formats: ethernetii, llc, and snap.
ethernetii etype etype-id: Matches Ethernet II encapsulation format and the corresponding protocol type values. The etype-id argument is the protocol type ID of inbound packets, ranging from 0x0600 to 0xFFFF (excluding 0x0800, 0x809B, 0x8137, and 0x86DD).
llc: Matches the llc encapsulation format.
dsap dsap-id: Specifies the destination service access point, ranging from of 0x00 to 0xFF.
ssap ssap-id: Specifies the source service access point, ranging from of 0x00 to 0xFF.
snap etype etype-id: Matches SNAP encapsulation format and the corresponding protocol type values. The etype-id argument is the Ethernet type of inbound packets, ranging from 0x0600 to 0xFFFF (excluding 0x8137).
protocol-index: Specifies a protocol template index. System will automatically assign an index if this parameter is not specified.
to protocol-end: Specifies the end protocol index. The protocol-end argument must be greater than or equal to the protocol-index argument.
all: Removes all the protocols bound to the VLAN.
CAUTION
CAUTION:
·       In the protocol-vlan command, do not set the dsap-id argument and the ssap-id argument to 0xe0 (which corresponds to the ipx llc protocol template) or 0xff (which corresponds to the ipx raw protocol template) at the same time.
·       When you use the mode keyword to configure a protocol-based VLAN, do not set the etype-id argument of ethernetii packets to 0x0800, 0x8137, 0x809b, and 0x86dd, which correspond to ipv4, ipx, appletalk, and ipv6 protocol templates.
Use the protocol-vlan command to configure the VLAN as a protocol based VLAN and configure the protocol template for the VLAN.
Use the undo protocol-vlan command to remove the configured protocol template.
By default, no VLAN is bound to any protocol template.
Related commands: display protocol-vlan vlan.
# Configure VLAN 3 as an IPv4 based VLAN.
[Sysname] vlan 3
[Sysname-vlan3] protocol-vlan ipv4
CAUTION
CAUTION:
IP uses ARP for address resolution in Ethernet. To prevent communication failure, configure the IP and ARP templates in the same VLAN and associate them with the same port.
# Create an ARP protocol template for VLAN 3 (ARP code is 0x0806) to make VLAN 3 transmit ARP packets.
·           To use Ethernet encapsulation, use the command:
[Sysname-vlan3] protocol-vlan mode ethernetii etype 0806
·           To use 802.3 encapsulation, use the command:
[Sysname-vlan3] protocol-vlan mode snap etype 0806
display voice vlan oui
display voice vlan oui [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display voice vlan oui command to display the supported organizationally unique identifier (OUI) addresses, the OUI address masks, and the description strings.
Related commands: voice vlan mac-address.
In general, as the first 24 bits of a MAC address (in binary format), an OUI address is a globally unique identifier assigned to a vendor by IEEE. OUI addresses mentioned in this document, however, are different from those in common sense. OUI addresses in this document are used to determine whether a received packet is a voice packet. They are the results of the AND operation of the two arguments mac-address and oui-mask in the voice vlan mac-address command.
# Display the supported OUI addresses, and their masks and descriptions.
<Sysname> display voice vlan oui
Oui Address     Mask            Description
0001-e300-0000  ffff-ff00-0000  Siemens phone
0003-6b00-0000  ffff-ff00-0000  Cisco phone
0004-0d00-0000  ffff-ff00-0000  Avaya phone
00d0-1e00-0000  ffff-ff00-0000  Pingtel phone
0060-b900-0000  ffff-ff00-0000  Philips/NEC phone
00e0-7500-0000  ffff-ff00-0000  Polycom phone
00e0-bb00-0000  ffff-ff00-0000  3com phone
Table 6 Output description
Oui Address
OUI addresses supported.
Mask
Masks of the OUI addresses supported.
Description strings of the OUI addresses supported.
display voice vlan state
display voice vlan state [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display voice vlan state command to display voice VLAN configuration.
Related commands: voice vlan enable, voice vlan qos, and voice vlan qos trust.
# Display voice VLAN configurations.
<Sysname> display voice vlan state
 Maximum of Voice VLANs: 1
 Current Voice VLANs: 1
 Voice VLAN security mode: Security
 Voice VLAN aging time: 1440 minutes
 Voice VLAN enabled port and its mode:
 PORT                        VLAN        MODE
 GigabitEthernet1/0/1                 2           AUTO
 GigabitEthernet1/0/2                 2           AUTO
Table 7 Output description
Voice VLAN system capacity
Maximum number of voice VLANs supported by the system.
Current Voice VLAN Count
Number of existing voice VLANs.
Security mode of the voice VLAN: Security for security mode; Normal for normal mode.
Aging time of the voice VLAN.
Current voice vlan enabled port and its mode
Voice VLAN-enabled port and its voice VLAN assignment mode.
PORT
Voice VLAN-enabled port name.
VLAN
ID of the voice VLAN enabled on the port.
MODE
Voice VLAN assignment mode of the port, manual or automatic.
voice vlan aging
voice vlan aging minutes
undo voice vlan aging
View
Default level
2: System level
minutes: Sets the voice VLAN aging time, ranging from 5 to 43200 minutes.
Use the voice vlan aging command to configure the voice VLAN aging time.
Use the undo voice vlan aging command to restore the default.
By default, the voice VLAN aging time is 1440 minutes.
When a port in automatic voice VLAN assignment mode receives a voice packet, the system decides whether to assign the port to the voice VLAN based on the source MAC address of the voice packet. Upon assigning the port to the voice VLAN, the system starts the aging timer. If no voice packets are received on the port until the aging time expires, the system automatically removes the port from the voice VLAN. This aging time applies only to the ports in automatic voice VLAN assignment mode.
Related commands: display voice vlan state.
# Configure the voice VLAN aging time as 100 minutes.
[Sysname] voice vlan aging 100
voice vlan enable
voice vlan vlan-id enable
undo voice vlan [ vlan-id ] enable
View
Default level
2: System level
vlan-id: Specifies a VLAN ID, ranging from 2 to 4096.
Use the voice vlan enable command to enable the voice VLAN feature and configure a VLAN as the voice VLAN for the Ethernet port.
Use the undo voice vlan enable command to disable the voice VLAN feature on an Ethernet port.
By default, the voice VLAN feature is disabled on ports.
You can enable the voice VLAN feature on a hybrid or trunk port operating in automatic voice VLAN assignment mode, but not on an access port operating in automatic voice VLAN assignment mode.
# Enable the voice VLAN feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] voice vlan 2 enable
voice vlan mac-address mac-address mask oui-mask [ description text ]
undo voice vlan mac-address oui
View
Default level
2: System level
mac-address: Specifies a source MAC address of voice traffic, in the format of H-H-H. For example, 1234-1234-1234.
mask oui-mask: Specifies the valid length of the OUI address by a mask in the format of H-H-H, formed by consecutive 1s and 0s. For example, FFFF-0000-0000. To filter the voice device of a specific vendor, set the mask to FFFF-FF00-0000.
description text: Specifies a string that describes the OUI address. The string is of 1 to 30 case-sensitive characters.
oui: Specifies the OUI address you want to remove, in the format of H-H-H. For example, 1234-1200-0000. An OUI address is the logic AND result of mac-address and oui-mask. An OUI address cannot be a broadcast address, a multicast address, or an all-zero address. You can use the display voice vlan oui command to display the OUI addresses.
Use the voice vlan mac-address command to allow packets carrying the specified OUI address to pass through.
Use the undo voice vlan mac-address command to prohibit packets carrying the specified OUI address from passing through.
By default, the system is configured with the default OUI addresses. You can remove the default OUI addresses and then add recognizable OUI addresses manually.
Table 8 Default OUI addresses
Number
OUI address
Vendor
1
0001-E300-0000
Siemens phone
2
0003-6B00-0000
Cisco phone
3
0004-0D00-0000
Avaya phone
4
00D0-1E00-0000
Pingtel phone
5
0060-B900-0000
Philips/NEC phone
6
00E0-7500-0000
Polycom phone
7
00E0-BB00-0000
3Com phone
The system supports up to 16 OUI addresses.
Related commands: display voice vlan oui.
# Add a recognizable OUI address 1234-1200-0000 by specifying the MAC address as 1234-1234-1234 and the mask as fff-ff00-0000, and configure its description string as PhoneA.
[Sysname] voice vlan mac-address 1234-1234-1234 mask ffff-ff00-0000 description PhoneA
voice vlan mode auto
undo voice vlan mode auto
View
Default level
2: System level
None
Use the voice vlan mode auto command to configure the port to operate in automatic voice VLAN assignment mode.
Use the undo voice vlan mode auto command to configure the port to operate in manual voice VLAN assignment mode.
By default, a port operates in automatic voice VLAN assignment mode.
The voice VLAN modes of different ports are independent of one another.
To make voice VLAN take effect on a port which is enabled with voice VLAN and operates in manual voice VLAN assignment mode, you need to assign the port to the voice VLAN manually.
# Configure GigabitEthernet 1/0/1 to operate in manual voice VLAN assignment mode.
[Sysname-GigabitEthernet1/0/1] undo voice vlan mode auto
voice vlan qos
voice vlan qos cos-value dscp-value
undo voice vlan qos
View
Interface view
Default level
2: System level
cos-value: Sets the CoS precedence value for voice VLAN traffic. The default value is 6.
dscp-value: Sets the DSCP value for voice VLAN traffic. The default value is 46.
Use the voice vlan qos command to configure the interface to modify the CoS and DSCP values marked for incoming traffic of the voice VLAN into specified values.
Use the undo voice vlan qos command to restore the default.
By default, an interface modifies the CoS value and the DSCP value marked for voice VLAN traffic into 6 and 46 respectively.
Configure the QoS priority settings for voice VLAN traffic on an interface before you enable voice VLAN on the interface. If the configuration order is reversed, the priority settings will fail.
The voice vlan qos command and the voice vlan qos trust command can overwrite each other. When you execute the two commands on a port multiple times, the most recent one takes effect.
Related commands: voice vlan qos trust.
# Configure interface GigabitEthernet 1/0/1 to modify the CoS value and the DSCP value marked for voice VLAN packets into 5 and 45 respectively.
[Sysname-GigabitEthernet1/0/1] voice vlan qos 5 45
undo voice vlan qos
View
Interface view
Default level
2: System level
None
Use the voice vlan qos trust command to configure the interface to trust the priority settings carried in incoming voice traffic. With this command configured, an interface keeps the CoS and DSCP values marked for incoming voice traffic unchanged.
Configure the QoS priority trust mode for voice VLAN traffic on an interface before enabling voice VLAN on the interface. If the configuration order is reversed, your priority trust setting will fail.
The voice vlan qos command and the voice vlan qos trust command can overwrite each other. After you execute the two commands on a port multiple times, the one that was last executed takes effect.
Related commands: voice vlan qos.
# Configure interface GigabitEthernet 1/0/1 to trust the priority settings carried in incoming voice VLAN traffic.
[Sysname-GigabitEthernet1/0/1] voice vlan qos trust
voice vlan security enable
undo voice vlan security enable
View
Default level
2: System level
None
Use the voice vlan security enable command to enable the voice VLAN security mode.
Use the undo voice vlan security enable command to disable the voice VLAN security mode.
When you enable the security mode for a voice VLAN, only voice traffic can be transmitted in the voice VLAN.
The device matches the source MAC addresses of the packets against the supported OUI addresses to determine whether they are voice traffic and filters all non-voice traffic, guaranteeing high priority and high quality for voice traffic.
When a voice VLAN operates in common mode, other data traffic is also allowed to be transmitted in the voice VLAN.
# Disable voice VLAN security mode.
[Sysname] undo voice vlan security enable
