- 07-Security Command Reference
- 01-AAA Commands
- 02-802.1X Commands
- 03-MAC Authentication Commands
- 04-Portal Commands
- 05-Port Security Commands
- 06-User Profile Commands
- 07-Password Control Commands
- 08-Public Key Commands
- 09-PKI Commands
- 10-SSH2.0 Commands
- 11-SSL Commands
- 12-TCP and ICMP Attack Protection Commands
- 13-ARP Attack Protection Commands
- 14-FIPS Commands
- 15-IPsec Commands
| 12-TCP and ICMP Attack Protection Commands | 57.21 KB |
display tcp status
display tcp status [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display tcp status to display status of all TCP connections for monitoring TCP connections.
# Display status of all TCP connections.
<Sysname> display tcp status
*: TCP MD5 Connection
TCPCB Local Add:port Foreign Add:port State
03e37dc4 0.0.0.0:4001 0.0.0.0:0 Listening
04217174 100.0.0.204:23 100.0.0.253:65508 Established
*: TCP MD5 Connection |
If the status information of a TCP connection contains asterisk (*), the TCP adopts the MD5 algorithm for authentication. |
TCPCB |
TCP control block. |
Local Add:port |
Local IP address and port number. |
Foreign Add:port |
Remote IP address and port number. |
State |
State of the TCP connection. |
tcp syn-cookie enable
undo tcp syn-cookie enable
View
Default level
2: System level
None
Use tcp syn-cookie enable to enable the SYN Cookie feature to protect the device against SYN Flood attacks.
Use undo tcp syn-cookie enable to disable the SYN Cookie feature.
By default, the SYN Cookie feature is enabled.
# Enable the SYN Cookie feature.
[Sysname] tcp syn-cookie enable
