- 07-Security Command Reference
- 01-AAA Commands
- 02-802.1X Commands
- 03-MAC Authentication Commands
- 04-Portal Commands
- 05-Port Security Commands
- 06-User Profile Commands
- 07-Password Control Commands
- 08-Public Key Commands
- 09-PKI Commands
- 10-SSH2.0 Commands
- 11-SSL Commands
- 12-TCP and ICMP Attack Protection Commands
- 13-ARP Attack Protection Commands
- 14-FIPS Commands
- 15-IPsec Commands
| 06-User Profile Commands | 87.17 KB |
display user-profile
display user-profile [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display user-profile to display information about all user profiles that have been created.
# Display information about all user profiles that have been created.
<Sysname> display user-profile
Status User profile
enabled a123
----Total user profiles: 1-------
----Enabled user profiles: 1-------
Status |
Status of the user profile: · enabled. · disabled. |
User profile |
User profile name. |
Total user profiles |
Total number of user profiles that have been created. |
Enabled user profiles |
Total number of user profiles that have been enabled. |
user-profile enable
user-profile profile-name enable
undo user-profile profile-name enable
View
Default level
2: System level
profile-name: Specifies the name of a user profile that has been created. The name takes a case-sensitive string of 1 to 31 characters. It can only contain English letters, digits, and underlines, and it must start with an English letter.
Use user-profile enable to enable a user profile that has been created. If the user profile does not exist, the command fails. Only enabled user profiles can be applied to authenticated users.
Use undo user-profile enable to disable the specified user profile. Disabling a user profile logs out users that are using the user profile. To edit or remove the configurations in a user profile, disable the user profile first.
By default, a created user profile is disabled.
# Enable user profile a123.
[Sysname] user-profile a123 enable
user-profile
View
Default level
2: System level
profile-name: Assigns a name to the user profile. The name is a case-sensitive string of 1 to 31 characters. It can only contain English letters, digits, and underlines, and it must start with an English letter. A user profile name must be globally unique.
Use user-profile to create a user profile and enter the user profile view. If the specified user profile has been created, you enter the user profile view directly.
Use undo user-profile to remove an existing disabled user profile. You cannot remove a user profile that is enabled.
By default, no user profiles exist on the device.
Related commands: user-profile enable.
# Create user profile a123.
[Sysname-user-profile-a123]
# Enter the user profile view of a123.
