- 07-Security Command Reference
- 01-AAA Commands
- 02-802.1X Commands
- 03-MAC Authentication Commands
- 04-Portal Commands
- 05-Port Security Commands
- 06-User Profile Commands
- 07-Password Control Commands
- 08-Public Key Commands
- 09-PKI Commands
- 10-SSH2.0 Commands
- 11-SSL Commands
- 12-TCP and ICMP Attack Protection Commands
- 13-ARP Attack Protection Commands
- 14-FIPS Commands
- 15-IPsec Commands
| 15-IPsec Commands | 294.92 KB |
ike-peer (IPsec policy view/IPsec policy template view/IPsec profile view)
proposal (IPsec policy view/IPsec policy template view/IPsec profile view)
ike next-payload check disabled
ike sa keepalive-timer interval
ike sa keepalive-timer timeout
ike sa nat-keepalive-timer interval
ah authentication-algorithm
ah authentication-algorithm { md5 | sha1 }
undo ah authentication-algorithm
View
IPsec proposal view
Default level
2: System level
md5: Uses MD5.
sha1: Uses SHA1.
Use ah authentication-algorithm to specify authentication algorithms for the authentication header (AH) protocol.
Use undo ah authentication-algorithm to restore the default.
By default, AH uses the MD5 authentication algorithm.
You must use the transform command to specify the AH security protocol or both AH and ESP before you specify authentication algorithms for AH.
Related commands: ipsec proposal and transform.
# Configure IPsec proposal prop1 to use AH and SHA1.
[Sysname] ipsec proposal prop1
[Sysname-ipsec-proposal-prop1] transform ah
[Sysname-ipsec-proposal-prop1] ah authentication-algorithm sha1
connection-name
connection-name name
undo connection-name
View
IPsec policy view, IPsec policy template view
Default level
2: System level
name: IPsec connection name, a case-insensitive string of 1 to 32 characters.
Use connection-name to configure an IPsec connection name. This name functions only as a description of the IPsec policy.
Use undo connection-name to restore the default.
By default, no IPsec connection name is configured.
Example
# Set IPsec connection name to CenterToA.
[Sysname] ipsec policy policy1 1 isakmp
[Sysname-ipsec-policy-isakmp-policy1-1] connection-name CenterToA
display ipsec policy
display ipsec policy [ brief | name policy-name [ seq-number ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
brief: Displays brief information about all IPsec policies.
name: Displays detailed information about a specified IPsec policy or IPsec policy group.
policy-name: Name of the IPsec policy, a string of 1 to 15 characters.
seq-number: Sequence number of the IPsec policy, in the range 1 to 65535.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display ipsec policy to display information about IPsec policies.
If you do not specify any parameters, the command displays detailed information about all IPsec policies.
If you specify the name policy-name option but leave the seq-number argument, the command displays detailed information about the specified IPsec policy group.
Related commands: ipsec policy (system view).
# Display brief information about all IPsec policies.
<Sysname> display ipsec policy brief
IPsec-Policy-Name Mode acl ike-peer name Mapped Template
bbbbbbbbbbbbbbb-1 template aaaaaaaaaaaaaaa
man-1 manual 3400
map-1 isakmp 3000 peer
nat-1 isakmp 3500 nat
test-1 isakmp 3200 test
toccccc-1 isakmp 3003 tocccc
IPsec-Policy-Name Mode acl Local-Address Remote-Address
man-1 manual 3400 3.3.3.1 3.3.3.2
IPsec-Policy-Name |
Name and sequence number of the IPsec policy separated by hyphen |
Mode |
Negotiation mode of the IPsec policy: · manual—Manual mode · isakmp—IKE negotiation mode · template—IPsec policy template mode |
acl |
Access control list (ACL) referenced by the IPsec policy |
ike-peer name |
IKE peer name |
Mapped Template |
Referenced IPsec policy template |
Local-Address |
IP address of the local end |
Remote-Address |
IP address of the remote end |
# Display detailed information about all IPsec policies.
IPsec Policy Group: "policy_isakmp"
Interface: Vlan-interface1
IPsec policy name: "policy_isakmp"
sequence number: 10
mode: isakmp
security data flow : 3000
selector mode: standard
ike-peer name: per
perfect forward secrecy: None
proposal name: prop1
Synchronization inbound anti-replay-interval: 1000 packets
Synchronization outbound anti-replay-interval: 10000 packets
IPsec sa local duration(time based): 3600 seconds
IPsec sa local duration(traffic based): 1843200 kilobytes
policy enable: True
IPsec Policy Group: "policy_man"
Interface: Vlan-interface2
IPsec policy name: "policy_man"
sequence number: 10
mode: manual
security data flow : 3002
tunnel local address: 162.105.10.1
tunnel remote address: 162.105.10.2
inbound AH setting:
AH spi: 12345 (0x3039)
AH string-key:
AH authentication hex key : 1234567890123456789012345678901234567890
inbound ESP setting:
ESP spi: 23456 (0x5ba0)
ESP string-key:
ESP encryption hex key: 1234567890abcdef1234567890abcdef1234567812345678
ESP authentication hex key: 1234567890abcdef1234567890abcdef
outbound AH setting:
AH spi: 54321 (0xd431)
AH string-key:
AH authentication hex key: 1122334455667788990011223344556677889900
outbound ESP setting:
ESP spi: 65432 (0xff98)
ESP string-key:
ESP encryption hex key: 11223344556677889900aabbccddeeff1234567812345678
ESP authentication hex key: 11223344556677889900aabbccddeeff
security data flow |
ACL referenced by the IPsec policy. |
Interface to which the IPsec policy is applied. |
sequence number |
Sequence number of the IPsec policy. |
mode |
Negotiation mode of the IPsec policy: · manual—Manual mode. · isakmp—IKE negotiation mode. · template—IPsec policy template mode. |
selector mode |
Data flow protection mode of the IPsec policy, standard or aggregation. |
ike-peer name |
IKE peer referenced by the IPsec policy. |
tunnel local address |
Local IP address of the tunnel. |
tunnel remote address |
Remote IP address of the tunnel. |
perfect forward secrecy |
Whether PFS is enabled. |
proposal name |
Proposal referenced by the IPsec policy. |
policy enable |
Whether the IPsec policy is enabled or not. |
Synchronization inbound anti-replay-interval |
Interval for synchronizing anti-replay windows in inbound direction, expressed in the number of received packets. |
Synchronization outbound anti-replay-interval |
Interval for synchronizing anti-replay sequence numbers in outbound direction, expressed in the number of sent packets. |
inbound/outbound AH/ESP setting |
AH/ESP settings in the inbound/outbound direction, including the SPI and keys. |
display ipsec policy-template
display ipsec policy-template [ brief | name template-name [ seq-number ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
brief: Displays brief information about all IPsec policy templates.
name: Displays detailed information about a specified IPsec policy template or IPsec policy template group.
template-name: Name of the IPsec policy template, a string of 1 to 15 characters.
seq-number: Sequence number of the IPsec policy template, in the range 1 to 65535.
Use display ipsec policy-template to display information about IPsec policy templates.
If you do not specify any parameters, the command displays detailed information about all IPsec policy templates.
If you specify the name template-name option but leave the seq-number argument, the command displays information about the specified IPsec policy template group.
Related commands: ipsec policy-template
# Display brief information about all IPsec policy templates.
<Sysname> display ipsec policy-template brief
Policy-template-Name acl Remote-Address
test-tplt300 2200
Policy-template-Name |
Name and sequence number of the IPsec policy template separated by hyphen |
acl |
ACL referenced by the IPsec policy template |
Remote Address |
Remote IP address |
# Display detailed information about all IPsec policy templates.
IPsec Policy Template Group: "test"
Policy template name: "test"
sequence number: 1
ike-peer name: None
proposal name: testprop
ACL referenced by the IPsec policy template. |
ike-peer name |
IKE peer referenced by the IPsec policy template. |
proposal name |
IPsec proposal referenced by the IPsec policy template. |
IPsec sa local duration(time based) |
Time-based lifetime of the IPsec SAs at the local end. |
IPsec sa local duration(traffic based) |
Traffic-based lifetime of the IPsec SAs at the local end. |
display ipsec proposal
display ipsec proposal [ proposal-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
proposal-name: Name of a proposal, a string of 1 to 15 characters.
Use display ipsec proposal to display information about IPsec proposals.
If you do not specify any parameters, the command displays information about all IPsec proposals.
Related commands: ipsec proposal.
# Display information about all IPsec proposals.
<Sysname> display ipsec proposal
IPsec proposal name: prop2
encapsulation mode: tunnel
transform: ah-new
AH protocol: authentication sha1-hmac-96
Table 5 Command output
IPsec proposal name |
Name of the IPsec proposal. |
encapsulation mode |
Encapsulation mode used by the IPsec proposal, transport or tunnel. IPsec between AC and AP supports only the tunnel mode. |
transform |
Security protocols used by the IPsec proposal: AH, ESP, or both. If both protocols are configured, IPsec uses ESP before AH. |
AH protocol |
Authentication algorithm used by AH |
ESP protocol |
Authentication algorithm and encryption algorithm used by ESP |
display ipsec sa
display ipsec sa [ active | brief | policy policy-name [ seq-number ] | remote ip-address | standby ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
active: Displays detailed information about the active IPsec SAs in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For whether your AC supports this keyword, see the command matrixes in About the WX series Access Controllers Command References.
brief: Displays brief information about all IPsec SAs.
policy: Displays detailed information about IPsec SAs created by using a specified IPsec policy.
policy-name: Name of the IPsec policy, a string 1 to 15 characters.
remote: Displays detailed information about the IPsec SA with a specified remote address.
standby: Displays detailed information about the standby IPsec SAs in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For whether your AC supports this keyword, see the command matrixes in About the WX series Access Controllers Command References.
Use display ipsec sa to display information about IPsec SAs.
If you do not specify any parameters, the command displays information about all IPsec SAs.
Related commands: reset ipsec sa and ipsec sa global-duration.
# Display brief information about all IPsec SAs.
<Sysname> display ipsec sa brief
Src Address Dst Address SPI Protocol Algorithm
10.1.1.1 10.1.1.2 300 ESP E:DES;
A:HMAC-MD5-96
10.1.1.2 10.1.1.1 400 ESP E:DES;
A:HMAC-MD5-96
Table 6 Command output
Src Address |
Local IP address. |
Dst Address |
Remote IP address. |
SPI |
Security parameter index. |
Protocol |
Security protocol used by IPsec. |
Algorithm |
Authentication algorithm and encryption algorithm used by the security protocol, where E indicates the encryption algorithm and A indicates the authentication algorithm. A value of NULL means that type of algorithm is not specified. |
# Display detailed information about all IPsec SAs.
path MTU: 1500
IPsec policy name: "p"
sequence number: 1
mode: template
connection id: 14
tunnel:
local address: 133.1.3.1
remote address: 133.1.1.32
flow:
sour addr: 133.1.3.1/255.255.255.255 port: 12223 protocol: UDP
dest addr: 133.1.1.32/255.255.255.255 port: 12223 protocol: UDP
[inbound ESP SAs]
spi: 1723826666 (0x66bf81ea)
proposal: ESP-ENCRYPT-DES ESP-AUTH-SHA1
sa duration (kilobytes/sec): 1843200/3600
sa remaining duration (kilobytes/sec): 1843182/3448
max received sequence-number: 70
anti-replay check enable: Y
anti-replay window size: 32
udp encapsulation used for nat traversal: N
[outbound ESP SAs]
spi: 2479317078 (0x93c76056)
sa remaining duration (kilobytes/sec): 1843196/3448
max received sequence-number: 71
sequence number: 1
mode: template
connection id: 15
tunnel:
flow:
sour addr: 133.1.3.1/255.255.255.255 port: 12222 protocol: UDP
dest addr: 133.1.1.32/255.255.255.255 port: 12222 protocol: UDP
[inbound ESP SAs]
spi: 3696099664 (0xdc4e0150)
sa remaining duration (kilobytes/sec): 1843078/2581
max received sequence-number: 1893
[outbound ESP SAs]
spi: 4091929623 (0xf3e5e417)
sa remaining duration (kilobytes/sec): 1843129/2581
max received sequence-number: 574
Table 7 Command output
Interface referencing the IPsec policy. |
path MTU |
Maximum IP packet length supported by the interface. |
IPsec policy name |
Name of IPsec policy used. |
sequence number |
mode |
IPsec negotiation mode. |
connection id |
IPsec tunnel identifier. |
Encapsulation mode, transport or tunnel. IPsec between AC and AP supports only the tunnel mode. |
Whether the perfect forward secrecy feature is enabled. |
tunnel |
IPsec tunnel. |
local address |
Local IP address of the IPsec tunnel. |
remote address |
Remote IP address of the IPsec tunnel. |
flow |
Data flow. |
sour addr |
Source IP address of the data flow. |
dest addr |
Destination IP address of the data flow. |
port |
Port number. |
protocol |
Protocol type. |
inbound |
Information of the inbound SA. |
spi |
proposal |
Security protocol and algorithms used by the IPsec proposal. |
sa duration |
Lifetime of the IPsec SA. |
sa remaining key duration |
Remaining lifetime of the SA. |
max received sequence-number |
Maximum sequence number of the received packets (relevant to the anti-replay function provided by the security protocol). |
udp encapsulation used for nat traversal |
Whether NAT traversal is enabled for the SA. |
outbound |
Information of the outbound SA. |
max sent sequence-number |
Maximum sequence number of the sent packets (relevant to the anti-replay function provided by the security protocol). |
anti-replay check enable |
Whether IPsec anti-replay checking is enabled. |
anti-replay window size |
Size of the anti-replay window. |
status |
Whether the SA is in the active or standby state. This field is displayed only when IPsec stateful failover is enabled. |
display ipsec statistics
display ipsec statistics [ tunnel-id integer ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
tunnel-id integer: Specifies an IPsec tunnel by its ID, which is in the range 1 to 2000000000.
Use display ipsec statistics to display IPsec packet statistics.
If you do not specify any parameters, the command displays the statistics for all IPsec packets.
Related commands: reset ipsec statistics.
# Display statistics on all IPsec packets.
<Sysname> display ipsec statistics
the security packet statistics:
input/output security packets: 47/62
input/output security bytes: 3948/5208
input/output dropped security packets: 0/45
dropped security packet detail:
not enough memory: 0
can't find SA: 45
queue is full: 0
authentication has failed: 0
wrong length: 0
replay packet: 0
packet too long: 0
wrong SA: 0
# Display IPsec packet statistics for Tunnel 3.
<Sysname> display ipsec statistics tunnel-id 3
Connection ID : 3
input/output security packets: 5124/8231
input/output security bytes: 52348/64356
input/output dropped security packets: 0/0
queue is full: 0
wrong length: 0
replay packet: 0
packet too long: 0
wrong SA: 0
Table 8 Command output
Connection ID |
ID of the tunnel. |
input/output security packets |
Counts of inbound and outbound IPsec protected packets. |
input/output security bytes |
Counts of inbound and outbound IPsec protected bytes. |
input/output dropped security packets |
Counts of inbound and outbound IPsec protected packets that are discarded by the device. |
dropped security packet detail |
Detailed information about inbound/outbound packets that get dropped. |
not enough memory |
Number of packets dropped due to lack of memory. |
can't find SA |
Number of packets dropped due to finding no security association. |
queue is full |
Number of packets dropped due to full queues. |
authentication has failed |
Number of packets dropped due to authentication failure. |
wrong length |
Number of packets dropped due to wrong packet length. |
replay packet |
Number of packets replayed. |
packet too long |
Number of packets dropped due to excessive packet length. |
wrong SA |
Number of packets dropped due to improper SA. |
display ipsec tunnel
display ipsec tunnel [ active | standby ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
active: Displays information about the active IPsec tunnels in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For whether your AC supports this keyword, see the command matrixes in About the WX series Access Controllers Command References.
standby: Displays information about the standby IPsec tunnels in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For whether your AC supports this keyword, see the command matrixes in About the WX series Access Controllers Command References.
Use display ipsec tunnel to display information about IPsec tunnels.
If you do not specify any parameters, the command displays information about all IPsec tunnels.
# Display information about IPsec tunnels.
<Sysname> display ipsec tunnel
total tunnel : 2
connection id: 3
status: active
SA's SPI:
inbound: 187199087 (0xb286e6f) [ESP]
outbound: 3562274487 (0xd453feb7) [ESP]
tunnel:
local address: 44.44.44.44
remote address : 44.44.44.55
flow:
sour addr : 44.44.44.0/255.255.255.0 port: 0 protocol : IP
dest addr : 44.44.44.0/255.255.255.0 port: 0 protocol : IP
current Encrypt-card: None
connection id: 5
SA's SPI:
inbound: 12345 (0x3039) [ESP]
outbound: 12345 (0x3039) [ESP]
tunnel:
flow:
# Display information about IPsec tunnels in aggregation mode.
total tunnel: 2
connection id: 4
status: active
SA's SPI:
inbound : 2454606993 (0x924e5491) [ESP]
outbound : 675720232 (0x2846ac28) [ESP]
tunnel :
remote address : 44.44.44.45
flow :
as defined in acl 3001
current Encrypt-card : None
Table 9 Command output
connection id |
Connection ID, used to uniquely identify an IPsec tunnel. |
status |
Whether the tunnel is in the active or standby state. This field is displayed only when IPsec stateful failover is enabled. |
Perfect forward secrecy, indicating which DH group is to be used for fast negotiation mode in IKE phase 2. |
SA's SPI |
SPIs of the inbound and outbound SAs. |
tunnel |
Local and remote addresses of the tunnel. |
flow |
Data flow protected by the IPsec tunnel, including source IP address, destination IP address, source port, destination port and protocol. |
as defined in acl 3001 |
The IPsec tunnel protects all data flows defined by ACL 3001. |
current Encrypt-card |
Encryption card interface used by the current tunnel. |
encapsulation-mode
encapsulation-mode { transport | tunnel }
undo encapsulation-mode
View
IPsec proposal view
Default level
2: System level
transport: Uses transport mode.
tunnel: Uses tunnel mode.
Use encapsulation-mode to set the encapsulation mode that the security protocol uses to encapsulate IP packets.
Use undo encapsulation-mode to restore the default.
By default, a security protocol encapsulates IP packets in tunnel mode.
# When IPsec uses IKEv1, configure IPsec proposal prop2 to use the transport encapsulation mode.
[Sysname] ipsec proposal prop2
[Sysname-ipsec-proposal-prop2] encapsulation-mode transport
esp authentication-algorithm
esp authentication-algorithm { md5 | sha1 }
undo esp authentication-algorithm
ESP uses the MD5 authentication algorithm.
View
IPsec proposal view
Default level
2: System level
md5: Uses the MD5 algorithm, which uses a 128-bit key.
sha1: Uses the SHA1 algorithm, which uses a 160-bit key.
Use esp authentication-algorithm to specify authentication algorithms for ESP.
Use undo esp authentication-algorithm to configure ESP to not authenticate packets.
Compared with SHA1, MD5 is faster but less secure. MD5 is sufficient for most networks. To deploy a highly secure network, use SHA1.
For ESP, you must specify an encryption algorithm, an authentication algorithm, or both. The undo esp authentication-algorithm command takes effect only if an encryption algorithm is specified for ESP.
Related commands: display ipsec proposal, esp encryption-algorithm, proposal, and transform.
# Configure IPsec proposal prop1 to use ESP and specify SHA1 as the authentication algorithm for ESP.
[Sysname-ipsec-proposal-prop1] transform esp
[Sysname-ipsec-proposal-prop1] esp authentication-algorithm sha1
esp encryption-algorithm { 3des | aes [ key-length ] | des }
undo esp encryption-algorithm
View
IPsec proposal view
Default level
2: System level
3des: Uses the triple Data Encryption Standard (3DES) in CBC mode, which uses a 168-bit key.
aes: Uses the Advanced Encryption Standard (AES) in CBC mode, which uses a 128-bit, 192-bit, or 256-bit key.
key-length: Specifies the key length (in bits) of the AES algorithm. This argument is valid when AES is used, and can be 128, 192, or 256. The default value is 128.
des: Uses the DES in cipher block chaining (CBC) mode, which uses a 56-bit key.
Use esp encryption-algorithm to specify encryption algorithms for ESP.
Use undo esp encryption-algorithm to configure ESP to not encrypt packets.
By default, ESP uses the DES encryption algorithm.
Compared with 3DES, DES is faster but less secure. DES is sufficient for most networks. To deploy a highly secure network, use 3DES.
ESP supports three IP packet protection schemes: encryption only, authentication only, or both encryption and authentication.
For ESP, you must specify an encryption algorithm, an authentication algorithm, or both. The undo esp encryption-algorithm command takes effect only if an authentication algorithm is specified for ESP.
Related commands: display ipsec proposal, esp authentication-algorithm, proposal, and transform.
# Configure IPsec proposal prop1 to use ESP and specify 3DES as the encryption algorithm for ESP.
[Sysname-ipsec-proposal-prop1] esp encryption-algorithm 3des
ike-peer peer-name
undo ike-peer peer-name
View
IPsec policy view, IPsec policy template view, IPsec profile view
Default level
2: System level
peer-name: IKE peer name, a string of 1 to 32 characters.
Use ike-peer to reference an IKE peer in an IPsec policy, IPsec policy template, or IPsec profile configured through IKE negotiation.
Use undo ike peer to remove the reference.
Related commands: ipsec policy, and ipsec profile.
# Configure a reference to an IKE peer in an IPsec policy.
[Sysname] ipsec policy policy1 10 isakmp
[Sysname-ipsec-policy-isakmp-policy1-10] ike-peer peer1
# Configure a reference to an IKE peer in an IPsec profile.
[Sysname] ipsec profile profile1
[Sysname-ipsec-profile- profile1] ike-peer peer1
ipsec policy (interface view)
ipsec policy policy-name
undo ipsec policy [ policy-name ]
View
Interface view
Default level
2: System level
policy-name: Name of the existing IPsec policy group to be applied to the interface, a string of 1 to 15 characters.
Use ipsec policy to apply an IPsec policy group to an interface.
Use undo ipsec policy to remove the application.
Only one IPsec policy group can be applied to an interface. To apply another IPsec policy group to the interface, remove the original application first. An IPsec policy group can be applied to more than one interface.
With an IPsec policy group applied to an interface, the system uses each IPsec policy in the group to protect certain data flows.
For each packet to be sent out an IPsec protected interface, the system checks the IPsec policies of the IPsec policy group in the ascending order of sequence numbers. If it finds an IPsec policy whose ACL matches the packet, it uses the IPsec policy to protect the packet. If it finds no ACL of the IPsec policies matches the packet, it does not provide IPsec protection for the packet and sends the packet out directly.
# Apply IPsec policy group pg1 to interface Serial 2/2.
[Sysname] interface serial 2/2
[Sysname-Serial2/2] ipsec policy pg1
ipsec policy policy-name seq-number [ isakmp | manual ]
undo ipsec policy policy-name [ seq-number ]
View
Default level
2: System level
policy-name: Name for the IPsec policy, a case-insensitive string of 1 to 15 characters. No minus sign (-) can be included.
seq-number: Sequence number for the IPsec policy, in the range 1 to 65535.
isakmp: Sets up SAs through IKE negotiation.
manual: Sets up SAs manually.
Use ipsec policy to create an IPsec policy and enter its view.
Use undo ipsec policy to delete the specified IPsec policies.
By default, No IPsec policy exists.
When creating an IPsec policy, you must specify the generation mode.
You cannot change the generation mode of an existing IPsec policy; you can only delete the policy and then re-create it with the new mode.
IPsec policies with the same name constitute an IPsec policy group. An IPsec policy is identified uniquely by its name and sequence number. In an IPsec policy group, an IPsec policy with a smaller sequence number has a higher priority.
The undo ipsec policy command without the seq-number argument deletes an IPsec policy group.
Related commands: ipsec policy (interface view) and display ipsec policy.
# Create an IPsec policy with the name policy1 and sequence number 100, and specify to set up SAs through IKE negotiation.
[Sysname] ipsec policy policy1 100 isakmp
[Sysname-ipsec-policy-isakmp-policy1-100]
# Create an IPsec policy with the name policy1 and specify the manual mode for it.
[Sysname] ipsec policy policy1 101 manual
[Sysname-ipsec-policy-manual-policy1-101]
ipsec policy isakmp template
ipsec policy policy-name seq-number isakmp template template-name
View
Default level
2: System level
seq-number: Sequence number for the IPsec policy, in the range of 1 to 65535.
isakmp template template-name: Name of the IPsec policy template to be referenced.
Use ipsec policy isakmp template to create an IPsec policy by referencing an existing IPsec policy template, so that IKE can use the IPsec policy for SA negotiation.
Use undo ipsec policy with the seq-number argument to delete an IPsec policy.
Use undo ipsec policy without the seq-number argument to delete an IPsec policy group.
After you create an IPsec policy by referencing an IPsec policy template, to modify the configuration for the IPsec policy, you must enter the IPsec policy template view instead of the IPsec policy view.
You cannot change the negotiation mode of an IPsec policy. To do so, you must delete the IPsec policy and then re-create it.
Related commands: ipsec policy (system view) and ipsec policy-template.
# Create an IPsec policy with the name policy2 and sequence number 200 by referencing IPsec policy template temp1.
[Sysname] ipsec policy policy2 200 isakmp template temp1
ipsec policy-template template-name seq-number
undo ipsec policy-template template-name [ seq-number ]
View
Default level
2: System level
template-name: Name for the IPsec policy template, a case-insensitive string of 1 to 41 characters. No minus sign (-) can be included.
seq-number: Sequence number for the IPsec policy template, in the range 1 to 65535.
Use ipsec policy-template to create an IPsec policy template and enter the IPsec policy template view.
Use undo ipsec policy-template to delete the specified IPsec policy templates.
By default, no IPsec policy template exists.
Using the undo command without the seq-number argument deletes an IPsec policy template group.
In an IPsec policy template group, an IPsec policy template with a smaller sequence number has a higher priority.
Related commands: display ipsec policy template.
# Create an IPsec policy template with the name template1 and the sequence number 100.
[Sysname] ipsec policy-template template1 100
[Sysname-ipsec-policy-template-template1-100]
ipsec proposal
ipsec proposal proposal-name
undo ipsec proposal proposal-name
View
Default level
2: System level
proposal-name: Name of an IPsec proposal, a case-insensitive string of 1 to 32 characters.
Use ipsec proposal to create an IPsec proposal and enter IPsec proposal view.
Use undo ipsec proposal to delete an IPsec proposal.
By default, no IPsec proposal exists.
An IPsec proposal created by using the ipsec proposal command takes the security protocol of ESP, the encryption algorithm of DES, and the authentication algorithm of MD5 by default.
Related commands: display ipsec proposal.
# Create an IPsec proposal named newprop1 and enter its view.
[Sysname] ipsec proposal newprop1
ipsec sa global-duration { time-based seconds | traffic-based kilobytes }
undo ipsec sa global-duration { time-based | traffic-based }
View
Default level
2: System level
seconds: Time-based global SA lifetime in seconds, in the range 180 to 604800.
kilobytes: Traffic-based global SA lifetime in kilobytes, in the range 2560 to 4294967295.
Use ipsec sa global-duration to configure the global SA lifetime.
Use undo ipsec sa global-duration to restore the default.
By default, the time-based global SA lifetime is 3600 seconds, and the traffic-based global SA lifetime is 1843200 kilobytes.
When negotiating to set up an SA, IKE prefers the lifetime of the IPsec policy or IPsec profile that it uses. If the IPsec policy is not configured with its own lifetime, IKE uses the global SA lifetime.
When negotiating to set up an SA, IKE prefers the shorter one of the local lifetime and that proposed by the remote.
You can configure both a time-based and a traffic-based global SA lifetime. An SA is aged out when it has existed for the specified time period or has processed the specified volume of traffic.
The SA lifetime applies to only IKE negotiated SAs; it is not effective for manually configured SAs.
Related commands: sa duration and display ipsec sa duration.
# Set the time-based global SA lifetime to 7200 seconds (2 hours).
[Sysname] ipsec sa global-duration time-based 7200
# Set the traffic-based global SA lifetime to 10240 kilobytes (10 Mbytes).
[Sysname] ipsec sa global-duration traffic-based 10240
ipsec synchronization enable
NOTE: Support for this command depends on the device model. For whether your AC supports this command, see the command matrixes in About the WX series Access Controllers Command References. |
undo ipsec synchronization enable
View
Default level
2: System level
Use ipsec synchronization enable to enable IPsec stateful failover.
Use undo ipsec synchronization enable to disable IPsec stateful failover.
By default, IPsec stateful failover is enabled.
You enable IPsec stateful failover typically on two redundant gateways in active/standby mode to ensure instant IPsec tunnel failover for nonstop services.
Disabling IPsec stateful failover will delete all active or standby IPsec SAs and IKE SA.
# Enable IPsec stateful failover.
[Sysname] ipsec synchronization enable
pfs
pfs { dh-group1 | dh-group2 | dh-group5 | dh-group14 }
undo pfs
View
Default level
2: System level
dh-group1: Uses 768-bit Diffie-Hellman group.
dh-group2: Uses 1024-bit Diffie-Hellman group.
dh-group5: Uses 1536-bit Diffie-Hellman group.
dh-group14: Uses 2048-bit Diffie-Hellman group.
Use pfs to enable and configure the perfect forward secrecy (PFS) feature so that the system uses the feature when employing the IPsec policy or IPsec profile to initiate a negotiation.
Use undo pfs to remove the configuration.
By default, the PFS feature is not used for negotiation.
In terms of security and necessary calculation time, the following four groups are in the descending order: 2048-bit Diffie-Hellman group (dh-group14), 1536-bit Diffie-Hellman group (dh-group5), 1024-bit Diffie-Hellman group (dh-group2) and 768-bit Diffie-Hellman group (dh-group1).
This command allows IPsec to perform an additional key exchange process during the negotiation phase 2, providing an additional level of security.
The local Diffie-Hellman group must be the same as that of the peer.
This command can be used only when the SAs are to be set up through IKE negotiation.
Related commands: ipsec policy-template, ipsec policy (system view), and ipsec profile (system view).
# Enable and configure PFS for IPsec policy policy1.
[Sysname] ipsec policy policy1 200 isakmp
[Sysname-ipsec-policy-isakmp-policy1-200] pfs dh-group1
policy enable
policy enable
undo policy enable
View
Default level
2: System level
Use policy enable to enable the IPsec policy.
Use undo policy enable to disable the IPsec policy.
By default, the IPsec policy is enabled.
The command is not applicable to manual IPsec policies.
If the IPsec policy is not enabled for the IKE peer, the peer cannot take part in the IKE negotiation.
# Enable the IPsec policy with the name policy1 and sequence number 100.
[Sysname-ipsec-policy-isakmp-policy1-100] policy enable
proposal proposal-name&<1-6>
undo proposal [ proposal-name ]
View
Default level
2: System level
proposal-name&<1-6>: Name of the IPsec proposal, a string of 1 to 32 characters. &<1-6> means that you can specify up to six proposals, which are separated by space.
Use proposal to specify an IPsec proposal for the IPsec policy or IPsec profile to reference.
Use undo proposal to remove an IPsec proposal referenced by the IPsec policy or IPsec profile.
By default, an IPsec policy or IPsec profile references no IPsec proposal.
The specified IPsec proposals must already exist.
A manual IPsec policy can reference only one IPsec proposal. To replace a referenced IPsec proposal, use the undo proposal command to remove the original proposal binding and then use the proposal command to reconfigure one.
An IKE negotiated IPsec policy can reference up to six IPsec proposals. The IKE negotiation process will search for and use the exactly matched proposal.
An IPsec profile can reference up to six IPsec proposals. The IKE negotiation process will search for and use the exactly matched proposal.
Related commands: ipsec proposal, ipsec policy (system view) and ipsec profile (system view).
# Configure IPsec policy policy1 to reference IPsec proposal prop1.
[Sysname-ipsec-proposal-prop1] quit
[Sysname] ipsec policy policy1 100 manual
[Sysname-ipsec-policy-manual-policy1-100] proposal prop1
# Configure IPsec profile profile1 to reference IPsec proposal prop2.
[Sysname-ipsec-proposal-prop2] quit
[Sysname-ipsec-profile-profile1] proposal prop2
reset ipsec sa
reset ipsec sa [ active | parameters dest-address protocol spi | policy policy-name [ seq-number ] | remote ip-address | standby ]
View
Default level
2: System level
active: Specifies all active IPsec SAs in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For whether your AC supports this keyword, see the command matrixes in About the WX series Access Controllers Command References.
parameters: Specifies IPsec SAs that use the specified destination address, security protocol, and SPI.
dest-address: Destination address, in dotted decimal notation.
protocol: Security protocol, which can be keyword ah or esp, case insensitive.
spi: Security parameter index, in the range 256 to 4294967295.
policy: Specifies IPsec SAs that use an IPsec policy or IPsec profile.
policy-name: Name of the IPsec policy or IPsec profile, a case-sensitive string of 1 to 15 alphanumeric characters.
seq-number: Sequence number of the IPsec policy, in the range 1 to 65535. If no seq-number is specified, all the policies in the IPsec policy group named policy-name are specified.
remote: Specifies SAs to or from a remote address, in dotted decimal notation.
standby: Specifies all standby IPsec SAs in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For whether your AC supports this keyword, see the command matrixes in About the WX series Access Controllers Command References.
Use reset ipsec sa to clear IPsec SAs.
If you do not specify any parameter, the command clears all IPsec SAs.
Immediately after a manually set up SA is cleared, the system automatically sets up a new SA based on the parameters of the IPsec policy. After IKE negotiated SAs are cleared, the system sets up new SAs only when IKE negotiation is triggered by interesting packets.
IPsec SAs appear in pairs. If you specify the parameters keyword to clear an IPsec SA, the IPsec SA in the other direction is also automatically cleared.
When you use this command in a stateful failover environment, note the following issues:
· If you specify neither active nor standby, the command clears both active and standby IPsec SAs.
· When you clear the active IPsec SAs on the active device, the active device automatically notifies the standby device to clear the standby IPsec SAs.
· When you clear the standby IPsec SAs on the standby device, the standby device re-synchronizes the IPsec service data with the active device to set up new standby IPsec SAs.
Related commands: display ipsec sa.
# Clear all IPsec SAs.
<Sysname> reset ipsec sa
# Clear the IPsec SA with a remote IP address of 10.1.1.2.
<Sysname> reset ipsec sa remote 10.1.1.2
# Clear all IPsec SAs of IPsec policy template policy1.
<Sysname> reset ipsec sa policy policy1
# Clear the IPsec SA of the IPsec policy with the name of policy1 and sequence number of 10.
<Sysname> reset ipsec sa policy policy1 10
# Clear the IPsec SA with a remote IP address of 10.1.1.2, security protocol of AH, and SPI of 10000.
<Sysname> reset ipsec sa parameters 10.1.1.2 ah 10000
# Clear all IPsec SAs of IPsec profile policy1.
# Clear active IPsec SAs on an IPsec stateful failover device.
<Sysname> reset ipsec sa active
View
Default level
2: System level
Use reset ipsec statistics to clear IPsec packet statistics.
Related commands: display ipsec statistics.
# Clear IPsec packet statistics.
<Sysname> reset ipsec statistics
sa authentication-hex
sa authentication-hex { inbound | outbound } { ah | esp } hex-key
undo sa authentication-hex { inbound | outbound } { ah | esp }
View
IPsec policy view
Default level
2: System level
inbound: Specifies the inbound SA through which IPsec processes the received packets.
outbound: Specifies the outbound SA through which IPsec processes the packets to be sent.
ah: Uses AH.
esp: Uses ESP.
hex-key: Specifies the hexadecimal key string. This argument is a 16-byte string for MD5 and is a 20-byte string for SHA1.
Use sa authentication-hex to configure an authentication key for an SA.
Use undo sa authentication-hex to remove the configuration.
This command applies to only manual IPsec policies.
When configuring a manual IPsec policy, you must set the parameters of both the inbound and outbound SAs.
The authentication key for the inbound SA at the local end must be the same as that for the outbound SA at the remote end, and the authentication key for the outbound SA at the local end must be the same as that for the inbound SA at the remote end.
At each end of an IPsec tunnel, the keys for the inbound and outbound SAs must be in the same format (both in hexadecimal format or both in string format), and the keys must be specified in the same format for both ends of the tunnel.
# Configure the authentication keys of the inbound and outbound SAs that use AH as 0x112233445566778899aabbccddeeff00 and 0xaabbccddeeff001100aabbccddeeff00.
[Sysname-ipsec-policy-manual-policy1-100] sa authentication-hex inbound ah 112233445566778899aabbccddeeff00
[Sysname-ipsec-policy-manual-policy1-100] sa authentication-hex outbound ah aabbccddeeff001100aabbccddeeff00
sa duration
sa duration { time-based seconds | traffic-based kilobytes }
undo sa duration { time-based | traffic-based }
View
Default level
2: System level
seconds: Time-based SA lifetime in seconds, in the range 180 to 604800.
kilobytes: Traffic-based SA lifetime in kilobytes, in the range 2560 to 4294967295.
Use sa duration to set an SA lifetime for the IPsec policy or IPsec profile.
Use undo sa duration to restore the default.
By default, the SA lifetime of an IPsec policy or an IPsec profile equals the current global SA lifetime. The time-based global SA lifetime is 3600 seconds, and traffic-based SA lifetime is 1843200 kilobytes.
When negotiating to set up an SA, IKE prefers the lifetime settings of the IPsec policy or IPsec profile that it uses. If the IPsec policy or IPsec proposal is not configured with its own lifetime settings, IKE uses the global SA lifetime settings, which are configured with the ipsec sa global-duration command.
When negotiating to set up an SA, IKE prefers the shorter ones of the local lifetime settings and those proposed by the remote.
The SA lifetime applies to only IKE negotiated SAs. It is not effective for manually configured SAs.
Related commands: ipsec sa global-duration, ipsec policy (system view), and ipsec profile (system view).
# Set the SA lifetime for IPsec policy1 to 7200 seconds (two hours).
[Sysname-ipsec-policy-isakmp-policy1-100] sa duration time-based 7200
# Set the SA lifetime for IPsec policy policy1 to 20480 kilobytes (20 Mbytes).
[Sysname-ipsec-policy-isakmp-policy1-100] sa duration traffic-based 20480
# Set the SA lifetime for IPsec profile profile1 to 7200 seconds (two hours).
[Sysname-ipsec-profile-profile1] sa duration time-based 7200
# Set the SA lifetime for IPsec profile profile1 to 20480 kilobytes (20 Mbytes).
[Sysname-ipsec-profile-profile1] sa duration traffic-based 20480
sa encryption-hex
sa encryption-hex { inbound | outbound } esp hex-key
undo sa encryption-hex { inbound | outbound } esp
View
IPsec policy view
Default level
2: System level
esp: Uses ESP.
hex-key: Encryption key for the SA, in hexadecimal format. The length of the key must be 8 bytes for DES-CBC, 16 bytes for AES128-CBC, 24 bytes for 3DES-CBC and AES192-CBC, 42 bytes for AES256-CBC, and 64 bytes for AES128-CBC.
Use sa encryption-hex to configure an encryption key for an SA.
Use undo sa encryption-hex to remove the configuration.
The encryption key for the inbound SA at the local end must be the same as that for the outbound SA at the remote end, and the encryption key for the outbound SA at the local end must be the same as that for the inbound SA at the remote end.
# Configure the encryption keys for the inbound and outbound SAs that use ESP as 0x1234567890abcdef and 0xabcdefabcdef1234.
[Sysname-ipsec-policy-manual-policy1-100] sa encryption-hex inbound esp 1234567890abcdef
[Sysname-ipsec-policy-manual-policy1-100] sa encryption-hex outbound esp abcdefabcdef1234
sa spi
sa spi { inbound | outbound } { ah | esp } spi-number
undo sa spi { inbound | outbound } { ah | esp }
View
IPsec policy view
Default level
2: System level
ah: Uses AH.
esp: Uses ESP.
spi-number: Security parameters index (SPI) in the SA triplet, in the range 256 to 4294967295.
Use sa spi to configure an SPI for an SA.
Use undo sa spi to remove the configuration.
When configuring a manual IPsec policy, you must configure parameters for both inbound and outbound SAs. For an ACL-based manual IPsec policy, specify different SPIs for different SAs.
The local inbound SA must use the same SPI and keys as the remote outbound SA. The same is true of the local outbound SA and remote inbound SA.
# Set the SPI for the inbound SA to 10000 and that for the outbound SA to 20000 in a manual IPsec policy.
[Sysname-ipsec-policy-manual-policy1-100] sa spi inbound ah 10000
[Sysname-ipsec-policy-manual-policy1-100] sa spi outbound ah 20000
sa string-key
sa string-key { inbound | outbound } { ah | esp } string-key
undo sa string-key { inbound | outbound } { ah | esp }
View
IPsec policy view
Default level
2: System level
ah: Uses AH.
esp: Uses ESP.
string-key: Specifies the key string for the SA, consisting of 1 to 255 characters. For different algorithms, enter a string at any length in the specified range and the system automatically generates a key meeting the algorithm requirements. When the protocol is ESP, the system generates the keys for the authentication algorithm and the encryption algorithm, respectively.
Use sa string-key to set a key string for an SA.
Use undo sa string-key to remove the configuration.
When configuring a manual IPsec policy, you must set parameters for both inbound and outbound SAs.
Enter keys in the same format for the local and remote inbound and outbound SAs. For example, if the local inbound SA uses a key in characters, the local outbound SA and remote inbound and outbound SAs must use keys in characters.
# Configure the inbound and outbound SAs that use AH to use keys abcdef and efcdab, respectively.
[Sysname-ipsec-policy-manual-policy1-100] sa string-key inbound ah abcdef
[Sysname-ipsec-policy-manual-policy1-100] sa string-key outbound ah efcdab
security acl
security acl acl-number [ aggregation | per-host ]
undo security acl
View
Default level
2: System level
acl-number: Number of the ACL for the IPsec policy to reference, in the range 3000 to 3999.
aggregation: Uses the data flow protection mode of aggregation. If you do not specify this keyword, the standard mode is used. This keyword is not available for IPv6.
per-host: Uses the data flow protection mode of per-host. If you do not specify this keyword, the standard mode is used. This keyword is not available for IPv6.
Use security acl to specify the ACL for the IPsec policy to reference.
Use undo security acl to remove the configuration.
By default, An IPsec policy references no ACL.
With an IKE-dependent IPsec policy configured, data flows can be protected in the following modes:
· Standard mode—One tunnel protects one data flow. The data flow permitted by each ACL rule is protected by one tunnel that is established separately for it.
· Aggregation mode—One tunnel protects all data flows permitted by all the rules of an ACL.
· Per-host mode—One tunnel protects one host-to-host data flow. Each ACL rule matches a host-to-host data flow, and the data flow permitted by each ACL rule is protected by one tunnel that is established separately for it.
When your device works with an old-version device, use the aggregation mode on both devices.
An IPsec policy references only one ACL. If you specify more than one ACL for an IPsec policy, the IPsec policy references the one last specified.
The per-host mode can be configured only in the view of an IKE negotiated IPsec policy.
To use the per-host mode in a wired network, you only need to specify an ACL in per-host mode in the IPsec policy of the IPsec initiator, and you do not need to specify the per-host keyword in the IPsec policy of the responder.
In a wireless network where an IPsec tunnel is required between an AC and an AP, if the IPsec policy that the AC assigns to the APs references a per-host mode ACL, multiple APs can simultaneously initiate an SA negotiation with the AC, and the AC can establish different IPsec SAs with the APs at different IP addresses.
# Configure IPsec policy policy1 to reference ACL 3001.
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule permit tcp source 10.1.1.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
[Sysname-acl-adv-3001] quit
[Sysname-ipsec-policy-manual-policy1-100] security acl 3001
# Configure IPsec policy policy2 to reference ACL 3002, setting the data flow protection mode to aggregation.
[Sysname] acl number 3002
[Sysname-acl-adv-3002] rule 0 permit ip source 10.1.2.1 0.0.0.255 destination 10.1.2.2 0.0.0.255
[Sysname-acl-adv-3002] rule 1 permit ip source 10.1.3.1 0.0.0.255 destination 10.1.3.2 0.0.0.255
[Sysname] ipsec policy policy2 1 isakmp
[Sysname-ipsec-policy-isakmp-policy2-1] security acl 3002 aggregation
# Configure IPsec policy policy1 to reference ACL 3003, setting the data flow protection mode to per-host.
[Sysname] acl number 3003
[Sysname-acl-adv-3003] rule permit ip source 10.1.1.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
[Sysname-acl-adv-3003] quit
[Sysname-ipsec-policy-isakmp-policy1-10] security acl 3003 per-host
synchronization anti-replay-interval (IPsec policy view/IPsec policy template view/IPsec profile view)
NOTE: Support for the command depends on the device model. For whether your AC supports this command, see the command matrixes in About the WX series Access Controllers Command References. |
synchronization anti-replay-interval inbound inbound-number outbound outbound-number
undo synchronization anti-replay-interval
View
Default level
2: System level
inbound-number: Interval at which the device, when functioning as the active device, synchronizes the inbound anti-replay window to the standby device. It is expressed in the number of received packets and ranges from 0 to 1000. If you set the argument to 0, inbound anti-replay window synchronization is disabled.
outbound-number: Interval at which the device, when functioning as the active device, synchronizes the outbound anti-replay sequence number to the standby device. It is expressed in the number of sent packets and ranges from 1000 to 100000.
Use synchronization anti-replay-interval to set the inbound anti-replay window synchronization interval and the outbound anti-replay sequence number synchronization interval.
Use undo synchronization anti-replay-interval to restore the defaults.
By default, the inbound anti-replay window synchronization interval is 1000, and the outbound anti-replay sequence number synchronization interval is 100000.
In an IPsec stateful failover scenario, the active device regularly synchronizes anti-replay information to the standby device. When the active device fails, the standby device continues to provide the anti-replay service based on the synchronized anti-replay information.
A short interval improves the anti-replay information consistency between the active device and the standby device, but also increases the anti-replay information synchronization frequency and the impact on the performance of the devices.
Related commands: display ipsec policy and display ipsec policy-template.
# Set the inbound anti-replay window synchronization interval to 800 and the outbound anti-replay sequence number synchronization interval to 50000.
[Sysname] ipsec policy test 10 isakmp
[Sysname-ipsec-policy-isakmp-test-10] synchronization anti-replay-interval inbound 800 outbound 50000
transform
transform { ah | ah-esp | esp }
undo transform
View
IPsec proposal view
Default level
2: System level
ah: Uses the AH protocol.
ah-esp: Uses ESP first and then AH.
esp: Uses the ESP protocol.
Use transform to specify a security protocol for an IPsec proposal.
Use undo transform to restore the default.
By default, the ESP protocol is used.
The IPsec proposals at the two ends of an IPsec tunnel must use the same security protocol.
If the security protocol is ESP, the default encryption algorithm is DES and the default authentication algorithm is MD5.
If the security protocol is AH, the default authentication algorithm is MD5.
If you specify both the ESP and AH (by using the ah-esp keyword), by default, the authentication algorithm for AH is MD5, the encryption algorithm for ESP is DES, and no authentication algorithm is used for ESP.
# Configure IPsec proposal prop1 to use AH.
tunnel local
tunnel local ip-address
undo tunnel local
View
IPsec policy view
Default level
2: System level
ip-address: Local address for the IPsec tunnel.
Use tunnel local to configure the local address of an IPsec tunnel.
Use undo tunnel local to remove the configuration.
By default, no local address is configured for an IPsec tunnel.
The local address, if not configured, will be the address of the interface to which the IPsec policy is applied.
# Set the local address of the IPsec tunnel to the address of Loopback 0, 10.0.0.1.
[Sysname] interface loopback 0
[Sysname-LoopBack0] ip address 10.0.0.1 32
[Sysname-LoopBack0] quit
[Sysname-ipsec-policy-manual-policy1-100] tunnel local 10.0.0.1
tunnel remote
tunnel remote ip-address
undo tunnel remote [ ip-address ]
No remote address is configured for the IPsec tunnel.
View
IPsec policy view
Default level
2: System level
ip-address: Remote address for the IPsec tunnel.
Use tunnel remote to configure the remote address of an IPsec tunnel.
Use undo tunnel remote to remove the configuration.
By default, no remote address is configured for the IPsec tunnel.
If you configure the remote address repeatedly, the last one takes effect.
An IPsec tunnel is established between the local and remote ends. The remote IP address of the local end must be the same as that of the local IP address of the remote end.
# Set the remote address of the IPsec tunnel to 10.1.1.2.
[Sysname] ipsec policy policy1 10 manual
[Sysname-ipsec-policy-policy1-10] tunnel remote 10.1.1.2
authentication-algorithm { md5 | sha }
undo authentication-algorithm
An IKE proposal uses the SHA1 authentication algorithm.
View
IKE proposal view
Default level
2: System level
md5: Uses HMAC-MD5.
sha: Uses HMAC-SHA1.
Use authentication-algorithm to specify an authentication algorithm for an IKE proposal.
Use undo authentication-algorithm to restore the default.
By default, an IKE proposal uses the SHA1 authentication algorithm.
Related commands: ike proposal and display ike proposal.
# Set MD5 as the authentication algorithm for IKE proposal 10.
[Sysname] ike proposal 10
[Sysname-ike-proposal-10] authentication-algorithm md5
authentication-method
authentication-method { pre-share | rsa-signature }
undo authentication-method
An IKE proposal uses the pre-shared key authentication method.
View
IKE proposal view
Default level
2: System level
pre-share: Uses the pre-shared key method.
rsa-signature: Uses the RSA digital signature method.
Use authentication-method to specify an authentication method for an IKE proposal.
Use undo authentication-method to restore the default.
By default, an IKE proposal uses the pre-shared key authentication method.
# Specify that IKE proposal 10 uses the pre-shared key authentication method.
[Sysname-ike-proposal-10] authentication-method pre-share
certificate domain
certificate domain domain-name
undo certificate domain
View
IKE peer view
Default level
2: System level
domain-name: Name of the PKI domain, a string of 1 to 15 characters.
Use certificate domain to configure the PKI domain of the certificate when IKE uses digital signature as the authentication mode.
Use undo certificate domain to remove the configuration.
Related commands: authentication-method and pki domain.
# Configure the PKI domain as abcde for IKE negotiation.
[Sysname] ike peer peer1
[Sysname-ike-peer-peer1] certificate domain abcde
dh
dh { group1 | group2 | group5 | group14 }
undo dh
View
IKE proposal view
Default level
2: System level
group1: Uses the 768-bit Diffie-Hellman group for key negotiation in phase 1
group2: Uses the 1024-bit Diffie-Hellman group for key negotiation in phase 1.
group5: Uses the 1536-bit Diffie-Hellman group for key negotiation in phase 1.
group14: Uses the 2048-bit Diffie-Hellman group for key negotiation in phase 1.
Use dh to specify the DH group to be used in key negotiation phase 1 for an IKE proposal.
Use undo dh to restore the default.
By default, group1, the 768-bit Diffie-Hellman group, is used.
# Specify 768-bit Diffie-Hellman for IKE proposal 10.
[Sysname-ike-proposal-10] dh group1
display ike dpd
display ike dpd [ dpd-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
dpd-name: DPD name, a string of 1 to 15 characters.
Use display ike dpd to display information about Dead Peer Detection (DPD) detectors.
If you do not specify any parameters, the command displays information about all DPD detectors.
Related commands: ike dpd.
# Display information about all DPD detectors.
<Sysname> display ike dpd
IKE dpd: dpd1
references: 1
interval-time: 10
time_out: 5
Table 10 Command output
references |
Number of IKE peers that use the DPD detector |
Interval-time |
DPD query trigging interval in seconds |
time_out |
DPD packet retransmission interval in seconds |
display ike peer
display ike peer [ peer-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
peer-name: Name of the IKE peer, a string of 1 to 15 characters.
Use display ike peer to display information about IKE peers.
If you do not specify any parameters, the command displays information about all IKE peers.
Related commands: ike peer.
# Display information about all IKE peers.
<Sysname> display ike peer
IKE Peer: rtb4tunn
exchange mode: main on phase 1
pre-shared-key simple 123
peer id type: ip
peer ip address: 44.44.44.55
local ip address:
peer name:
nat traversal: disable
dpd: dpd1
exchange mode |
IKE negotiation mode in phase 1 |
pre-shared-key |
Pre-shared key used in phase 1 |
peer id type |
ID type used in phase 1 |
peer ip address |
IP address of the remote security gateway |
local ip address |
IP address of the local security gateway |
peer name |
Name of the remote security gateway |
nat traversal |
Whether NAT traversal is enabled |
dpd |
Name of the peer DPD detector |
display ike proposal [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ike proposal to view the settings of all IKE proposals.
This command displays the configuration information of all IKE proposals in the descending order of proposal priorities.
Related commands: authentication-method, ike proposal, encryption-algorithm, authentication-algorithm, dh, and sa duration.
# Display the settings of all IKE proposals.
<Sysname> display ike proposal
priority authentication authentication encryption Diffie-Hellman duration
method algorithm algorithm group (seconds)
10 PRE_SHARED SHA DES_CBC MODP_1024 5000
11 PRE_SHARED MD5 DES_CBC MODP_768 50000
default PRE_SHARED SHA DES_CBC MODP_768 86400
Table 12 Command output
priority |
Priority of the IKE proposal |
authentication method |
Authentication method used by the IKE proposal |
authentication algorithm |
Authentication algorithm used by the IKE proposal |
encryption algorithm |
Encryption algorithm used by the IKE proposal |
Diffie-Hellman group |
DH group used in IKE negotiation phase 1 |
duration (seconds) |
ISAKMP SA lifetime of the IKE proposal in seconds |
display ike sa
display ike sa [ active | standby | verbose [ connection-id connection-id | remote-address remote-address ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
active: Displays the summary of active IKE SAs in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For whether your AC supports this keyword, see the command matrixes in About the WX series Access Controllers Command References.
standby: Displays the summary of standby IKE SAs in an IPsec stateful failover scenario. Support for this keyword depends on the device model. For whether your AC supports this keyword, see the command matrixes in About the WX series Access Controllers Command References.
verbose: Displays detailed information.
connection-id connection-id: Displays detailed information about IKE SAs by connection ID, in the range 1 to 2000000000.
remote-address remote-address: Displays detailed information about IKE SAs with a specified remote address.
Use display ike sa to display information about the current IKE SAs.
If you do not specify any parameters or keywords, the command displays brief information about the current IKE SAs.
Related commands: ike proposal and ike peer.
# Display brief information about the current IKE SAs.
<Sysname> display ike sa
total phase-1 SAs: 1
connection-id peer flag phase doi
1 202.38.0.2 RD|ST 1 IPSEC
2 202.38.0.2 RD|ST 2 IPSEC
flag meaning
RD--READY ST--STAYALIVE RL--REPLACED FD—FADING TO—TIMEOUT
# Display brief information about IKE SAs in an IPsec stateful failover scenario.
connection-id peer flag phase doi status
1 202.38.0.2 RD|ST 1 IPSEC ACTIVE
2 202.38.0.2 RD|ST 2 IPSEC ACTIVE
flag meaning
RD--READY ST--STAYALIVE RL--REPLACED FD—FADING TO—-TIMEOUT
Table 13 Command output
total phase-1 SAs |
Total number of SAs for phase 1. |
connection-id |
Identifier of the ISAKMP SA. |
peer |
Remote IP address of the SA. |
flag |
Status of the SA: · RD (READY)—The SA has been established. · ST (STAYALIVE)—This end is the initiator of the tunnel negotiation. · RL (REPLACED)—The tunnel has been replaced by a new one and will be deleted later. · FD (FADING)—The soft lifetime is over but the tunnel is still in use. The tunnel will be deleted when the hard lifetime is over. · TO (TIMEOUT)—The SA has received no keepalive packets after the last keepalive timeout. If no keepalive packets are received before the next keepalive timeout, the SA will be deleted. |
phase |
The phase the SA belongs to: · Phase 1—The phase for establishing the ISAKMP SA. · Phase 2—The phase for negotiating the security service. IPsec SAs are established in this phase. |
doi |
Interpretation domain the SA belongs to. |
status |
Stateful failover status of the SA, active or standby. This field appears only in an IPsec stateful failover scenario. |
# Display detailed information about the current IKE SAs.
<Sysname> display ike sa verbose
connection id: 2
vpn-instance:
transmitting entity:
initiatorstatus: active
local ip: 4.4.4.4
local id type: IPV4_ADDR
local id: 4.4.4.4
remote ip: 4.4.4.5
remote id type: IPV4_ADDR
remote id: 4.4.4.5
authentication-method: PRE-SHARED
authentication-algorithm: SHA
encryption-algorithm: DES-CBC
life duration(sec): 86400
remaining key duration(sec): 86379
exchange-mode: MAIN
diffie-hellman group: GROUP1
nat traversal: NO
# Display detailed information about the IKE SA with the connection ID of 2.
<Sysname> display ike sa verbose connection-id 2
connection id: 2
vpn-instance:
initiator status: active
local ip: 4.4.4.4
local id: 4.4.4.4
remote ip: 4.4.4.5
remote id: 4.4.4.5
remaining key duration(sec): 82480
exchange-mode: MAIN
nat traversal: NO
# Display detailed information about the IKE SA with the remote address of 4.4.4.5.
<Sysname> display ike sa verbose remote-address 4.4.4.5
connection id: 2
vpn-instance:
transmitting entity: initiator
status: active
local ip: 4.4.4.4
local id: 4.4.4.4
remote ip: 4.4.4.5
remote id: 4.4.4.5
remaining key duration(sec): 82236
exchange-mode: MAIN
nat traversal: NO
Table 14 Command output
connection id |
vpn-instance |
MPLS L3VPN that the protected data belongs to. The WX series access controllers do not support VPN. |
transmitting entity |
Entity in the IKE negotiation. |
status |
local ip |
IP address of the local gateway. |
local id type |
Identifier type of the local gateway. |
local id |
Identifier of the local gateway. |
remote ip |
IP address of the remote gateway. |
remote id type |
Identifier type of the remote gateway. |
remote id |
Identifier of the remote security gateway. |
authentication-method |
Authentication method used by the IKE proposal. |
authentication-algorithm |
Authentication algorithm used by the IKE proposal. |
encryption-algorithm |
Encryption algorithm used by the IKE proposal. |
life duration(sec) |
Lifetime of the ISAKMP SA in seconds. |
remaining key duration(sec) |
Remaining lifetime of the ISAKMP SA in seconds. |
exchange-mode |
IKE negotiation mode in phase 1. |
diffie-hellman group |
DH group used for key negotiation in IKE phase 1. |
nat traversal |
Whether NAT traversal is enabled. |
dpd
dpd dpd-name
undo dpd
View
IKE peer view
Default level
2: System level
dpd-name: DPD detector name, a string of 1 to 32 characters.
Use dpd to apply a DPD detector to an IKE peer.
Use undo dpd to remove the application.
By default, no DPD detector is applied to an IKE peer.
# Apply dpd1 to IKE peer peer1.
[Sysname-ike-peer-peer1] dpd dpd1
encryption-algorithm { aes-cbc [ key-length ] | des-cbc }
undo encryption-algorithm
View
IKE proposal view
Default level
2: System level
aes-cbc: Uses the AES algorithm in CBC mode as the encryption algorithm. The AES algorithm uses 128-bit, 192-bit, or 256-bit keys for encryption.
key-length: Key length for the AES algorithm, which can be 128, 192 or 256 bits and is defaulted to 128 bits.
des-cbc: Uses the DES algorithm in CBC mode as the encryption algorithm. The DES algorithm uses 56-bit keys for encryption.
Use encryption-algorithm to specify an encryption algorithm for an IKE proposal.
Use undo encryption-algorithm to restore the default.
By default, an IKE proposal uses the 56-bit DES encryption algorithm in CBC mode.
# Use 56-bit DES in CBC mode as the encryption algorithm for IKE proposal 10.
[Sysname-ike-proposal-10] encryption-algorithm des-cbc
exchange-mode
exchange-mode { aggressive | main }
undo exchange-mode
Main mode is used.
View
IKE peer view
Default level
2: System level
aggressive: Aggressive mode.
main: Main mode.
Use exchange-mode to select an IKE negotiation mode.
Use undo exchange-mode to restore the default.
By default, main mode is used.
When the user (for example, a dial-up user) at the remote end of an IPsec tunnel obtains an IP address automatically and pre-shared key authentication is used, H3C recommends setting the IKE negotiation mode to aggressive at the local end.
Related commands: id-type.
# Specify that IKE negotiation operates in main mode.
[Sysname-ike-peer-peer1] exchange-mode main
id-type
id-type { ip | name | user-fqdn }
undo id-type
View
IKE peer view
Default level
2: System level
ip: Uses an IP address as the ID during IKE negotiation.
name: Uses a name of the Fully Qualified Domain Name (FQDN) type as the ID during IKE negotiation.
user-fqdn: Uses a name of the user FQDN type as the ID during IKE negotiation.
Use id-type to select the type of the ID for IKE negotiation.
Use undo id-type to restore the default.
By default, the ID type is IP address.
In main mode, only the ID type of IP address can be used in IKE negotiation and SA creation. In aggressive mode, either type can be used.
If the ID type of FQDN is used, configure a name without any at sign (@) for the local security gateway, for example, foo.bar.com. If the ID type of user FQDN is used, configure a name with an at sign (@) for the local security gateway, for example, [email protected].
Related commands: local-name, ike local-name, remote-name, remote-address, local-address, and exchange-mode.
# Use the ID type of name during IKE negotiation.
[Sysname-ike-peer-peer1] id-type name
ike dpd
ike dpd dpd-name
undo ike dpd dpd-name
View
Default level
2: System level
dpd-name: Name for the dead peer detection (DPD) detector, a string of 1 to 32 characters.
Use ike dpd to create a DPD detector and enter IKE DPD view.
Use undo ike dpd to remove a DPD detector.
Dead peer detection (DPD) irregularly detects dead IKE peers. It works as follows:
1. When the local end sends an IPsec packet, it checks the time the last IPsec packet was received from the peer.
2. If the time interval exceeds the DPD interval, it sends a DPD hello to the peer.
3. If the local end receives no DPD acknowledgement within the DPD packet retransmission interval, it retransmits the DPD hello.
4. If the local end still receives no DPD acknowledgement after having made the maximum number of retransmission attempts (two by default), it considers the peer already dead, and clears the IKE SA and the IPsec SAs based on the IKE SA.
DPD enables an IKE entity to check the liveliness of its peer only when necessary. It generates less traffic than the keepalive mechanism, which exchanges messages periodically.
Related commands: display ike dpd, interval-time, and time-out.
# Create a DPD detector named dpd2.
[Sysname] ike dpd dpd2
ike local-name
ike local-name name
undo ike local-name
View
Default level
2: System level
name: Name of the local security gateway for IKE negotiation, a case-sensitive string of 1 to 32 characters.
Use ike local-name to configure a name for the local security gateway.
Use undo ike local-name to restore the default.
By default, the device name is used as the name of the local security gateway.
If you configure the id-type name or id-type user-fqdn command on the initiator, the IKE negotiation peer uses the security gateway name as its ID to initiate IKE negotiation, and you must configure the ike local-name command in system view or the local-name command in IKE peer view on the local device. If you configure both the ike local-name command and the local-name command, the name configured by the local-name command is used.
The IKE negotiation initiator sends its security gateway name as its ID to the peer, and the peer uses the security gateway name configured with the remote-name command to authenticate the initiator. Make sure the local gateway name matches the remote gateway name configured on the peer.
Related commands: remote-name and id-type.
# Configure the local security gateway name as app.
[Sysname] ike local-name app
ike next-payload check disabled
undo ike next-payload check disabled
View
Default level
2: System level
Use ike next-payload check disabled to disable the checking of the Next payload field in the last payload of an IKE message during IKE negotiation, gaining interoperation with products assigning the field a value other than zero.
Use undo ike next-payload check disabled to restore the default.
By default, the Next payload field is checked.
# Disable Next payload field checking for the last payload of an IKE message.
[Sysname] ike next-payload check disabled
ike peer (system view)
ike peer peer-name
undo ike peer peer-name
View
Default level
2: System level
Use ike peer to create an IKE peer and enter IKE peer view.
Use undo ike peer to delete an IKE peer.
# Create an IKE peer named peer1 and enter IKE peer view.
ike proposal
ike proposal proposal-number
undo ike proposal proposal-number
View
Default level
2: System level
proposal-number: IKE proposal number, in the range 1 to 65535. The lower the number, the higher the priority of the IKE proposal. During IKE negotiation, a high priority IKE proposal is matched before a low priority IKE proposal.
Use ike proposal to create an IKE proposal and enter IKE proposal view.
Use undo ike proposal to delete an IKE proposal.
The system provides a default IKE proposal, which has the lowest priority and uses these settings:
· Encryption algorithm DES-CBC
· Authentication algorithm HMAC-SHA1
· Authentication method Pre-shared key
· DH group MODP_768
· SA lifetime 86400 seconds
Related commands: display ike proposal.
# Create IKE proposal 10 and enter IKE proposal view.
ike sa keepalive-timer interval
ike sa keepalive-timer interval seconds
undo ike sa keepalive-timer interval
View
Default level
2: System level
seconds: Transmission interval of ISAKMP SA keepalives in seconds, in the range 20 to 28,800.
Use ike sa keepalive-timer interval to set the ISAKMP SA keepalive interval.
Use undo ike sa keepalive-timer interval to disable the ISAKMP SA keepalive transmission function.
By default, no keepalive packet is sent.
The keepalive interval configured at the local end must be shorter than the keepalive timeout configured at the remote end.
Related commands: ike sa keepalive-timer timeout.
# Set the keepalive interval to 200 seconds.
[Sysname] ike sa keepalive-timer interval 200
ike sa keepalive-timer timeout seconds
undo ike sa keepalive-timer timeout
View
Default level
2: System level
seconds: ISAKMP SA keepalive timeout in seconds, in the range 20 to 28,800.
Use ike sa keepalive-timer timeout to set the ISAKMP SA keepalive timeout.
Use undo ike sa keepalive-timer timeout to disable the function.
The keepalive timeout configured at the local end must be longer than the keepalive interval configured at the remote end. Since it seldom occurs that more than three consecutive packets are lost on a network, the keepalive timeout can be configured to be three times of the keepalive interval.
Related commands: ike sa keepalive-timer interval.
# Set the keepalive timeout to 20 seconds.
[Sysname] ike sa keepalive-timer timeout 20
ike sa nat-keepalive-timer interval
ike sa nat-keepalive-timer interval seconds
undo ike sa nat-keepalive-timer interval
View
Default level
2: System level
seconds: NAT keepalive interval in seconds, in the range 5 to 300.
Use ike sa nat-keepalive-timer interval to set the NAT keepalive interval.
Use undo ike sa nat-keepalive-timer interval to disable the function.
By default, the NAT keepalive interval is 20 seconds.
# Set the NAT keepalive interval to 5 seconds.
[Sysname] ike sa nat-keepalive-timer interval 5
interval-time
interval-time interval-time
undo interval-time
View
IKE DPD view
Default level
2: System level
interval-time: Sets DPD interval in seconds, in the range of 1 to 300 seconds. When the local end sends an IPsec packet, it checks the time the last IPsec packet was received from the peer. If the time interval exceeds the DPD interval, it sends a DPD hello to the peer.
Use interval-time to set the DPD query triggering interval for a DPD detector.
Use undo interval-time to restore the default.
By default, the default DPD interval is 10 seconds.
# Set the DPD interval to 1 second for dpd2.
[Sysname-ike-dpd-dpd2] interval-time 1
local-address
local-address ip-address
undo local-address
View
IKE peer view
Default level
2: System level
ip-address: IP address of the local security gateway to be used in IKE negotiation.
Use local-address to configure the IP address of the local security gateway in IKE negotiation.
Use undo local-address to remove the configuration.
By default, the primary address of the interface referencing the IPsec policy is used as the local security gateway IP address for IKE negotiation. Use this command if you want to specify a different address for the local security gateway.
# Set the IP address of the local security gateway to 1.1.1.1.
[Sysname] ike peer xhy
[Sysname-ike-peer-xhy] local-address 1.1.1.1
local-name
local-name name
undo local-name
View
IKE peer view
Default level
2: System level
name: Name for the local security gateway to be used in IKE negotiation, a case-sensitive string of 1 to 32 characters.
Use local-name to configure a name for the local security gateway to be used in IKE negation.
Use undo local-name to restore the default.
By default, the device name is used as the name of the local security gateway view.
# Set the name of the local security gateway to localgw in IKE peer view of peer1.
[Sysname-ike-peer-peer1] local-name localgw
pre-shared-key
pre-shared-key [ cipher | simple ] key
undo pre-shared-key
View
IKE peer view
Default level
2: System level
cipher: Sets a ciphertext pre-shared key.
simple: Sets a plaintext pre-shared key.
key: Specifies the key string. This argument is case sensitive. If cipher is specified, it must be a ciphertext string of 1 to 201 characters. If simple is specified, it must be a string of 1 to 128 characters. If neither cipher nor simple is specified, you set a plaintext key string.
Use pre-shared-key to configure the pre-shared key to be used in IKE negotiation.
Use undo pre-shared-key to remove the configuration.
Related commands: authentication-method.
# Set the pre-shared key used in IKE negotiation to string abcde.
[Sysname-ike-peer-peer1] pre-shared-key abcde
proposal (IKE peer view)
proposal proposal-number&<1-6>
undo proposal [ proposal-number ]
An IKE peer references no IKE proposals and, when initiating IKE negotiation, it uses the IKE proposals configured in system view.
View
IKE peer view
Default level
2: System level
Use proposal to specify the IKE proposals for the IKE peer to reference.
Use undo proposal to remove one or all IKE proposals referenced by the IKE peer.
By default, an IKE peer references no IKE proposals and, when initiating IKE negotiation, it uses the IKE proposals configured in system view.
In the IKE negotiation phase 1, the local end uses the IKE proposals specified for it, if any.
An IKE peer can reference up to six IKE proposals.
The responder uses the IKE proposals configured in system view for negotiation.
Related commands: ike proposal and ike peer (system view).
# Configure IKE peer peer1 to reference IKE proposal 10.
[Sysname-ike-peer-peer1] proposal 10
remote-address
remote-address { hostname [ dynamic ] | low-ip-address [ high-ip-address ] }
undo remote-address
View
IKE peer view
Default level
2: System level
hostname: Host name of the IPsec remote security gateway, a case-insensitive string of 1 to 255 characters. The host name uniquely identifies the remote IPsec peer and can be resolved to an IP address by the DNS server.
dynamic: Specifies to use dynamic address resolution for the IPsec remote peer name. If you do not provide this keyword, the local end has the remote host name resolved only once after you configure the remote host name.
low-ip-address: IP address of the IPsec remote security gateway. It is the lowest address in the address range if you want to specify a range of addresses.
high-ip-address: Highest address in the address range if you want to specify a range of addresses.
Use remote-address to configure the IP address of the IPsec remote security gateway.
Use undo remote-address to remove the configuration.
The IP address configured with the remote-address command must match the local security gateway IP address that the remote security gateway uses for IKE negotiation, which is the IP address configured with the local-address command or, if the local-address command is not configured, the primary IP address of the interface to which the policy is applied.
The local end can be the initiator of IKE negotiation if the remote address is a host IP address or a host name. The local end can only be the responder of IKE negotiation if the remote address is an address range that the local end can respond to.
If the IP address of the remote address changes frequently, configure the host name of the remote gateway with the dynamic keyword so that the local end can use the up-to-date remote IP address to initiate IKE negotiation.
Related commands: id-type ip and local-address.
# Configure the IP address of the remote security gateway as 10.0.0.1.
[Sysname-ike-peer-peer1] remote-address 10.0.0.1
# Configure the host name of the remote gateway as test.com, and specify the local end to dynamically update the remote IP address.
[Sysname] ike peer peer2
[Sysname-ike-peer-peer2] remote-address test.com dynamic
remote-name
remote-name name
undo remote-name
View
IKE peer view
Default level
2: System level
name: Name of the peer security gateway for IKE negotiation, a string of 1 to 32 characters.
Use remote-name to configure the name of the remote gateway.
Use undo remote-name to remove the configuration.
If you configure the id-type name or id-type user-fqdn command on the initiator, the IKE negotiation initiator sends its security gateway name as its ID for IKE negotiation, and the peer uses the security gateway name configured with the remote-name command to authenticate the initiator. Make sure the local gateway name matches the remote gateway name configured on the peer.
Related commands: id-type, local-name, and ike local-name.
# Configure the remote security gateway name as apple for IKE peer peer1.
[Sysname-ike-peer-peer1] remote-name apple
reset ike sa
reset ike sa [ connection-id | active | standby ]
View
Default level
2: System level
connection-id: Connection ID of the IKE SA to be cleared, in the range 1 to 2000000000.
active: Clears all active IKE SAs in an IPsec stateful failover scenario. For whether your AC supports this keyword, see the command matrixes in About the WX series Access Controllers Command References.
standby: Clears all standby IKE SAs in an IPsec stateful failover scenario. For whether your AC supports this keyword, see the command matrixes in About the WX series Access Controllers Command References.
Use reset ike sa to clear IKE SAs.
If you do not specify any parameter, the command clears all IKE SAs.
If you specify only a connection ID, the command clears all IKE SAs with the specified connection ID, including the active and standby IKE SAs.
When you clear the active IKE SAs on the active device, the active device automatically notifies the standby device to clear the standby IKE SAs.
When you clear the standby IKE SAs on the standby device, the standby device re-synchronizes the IKE SA data with the active device to set up new standby IKE SAs.
When you clear a local IPsec SA, its IKE SA can transmit the Delete message to notify the remote end to delete the paired IPsec SA. If the IKE SA has been cleared, the local end cannot notify the remote end to clear the paired IPsec SA, and you must manually clear the remote IPsec SA.
Related commands: display ike sa.
# Clear the IKE SA that uses connection ID 2.
flag meaning
RD--READY ST--STAYALIVE RL--REPLACED FD—FADING TO--TIMEOUT
<Sysname> reset ike sa 2
flag meaning
# Clear all active IKE SAs.
total phase-1 SAs: 2
1 201.31.0.9 RD|ST 1 IPSEC STANDBY
2 201.31.0.9 RD|ST 2 IPSEC STANDBY
flag meaning
<Sysname> reset ike sa active
sa duration
sa duration seconds
undo sa duration
View
IKE proposal view
Default level
2: System level
Seconds: Specifies the ISAKMP SA lifetime in seconds, in the range 60 to 604800.
Use sa duration to set the ISAKMP SA lifetime for an IKE proposal.
By default, the ISAKMP SA lifetime is 86400 seconds.
Before an SA expires, IKE negotiates a new SA. The new SA takes effect immediately after being set up, and the old one will be cleared automatically when it expires.
# Specify the ISAKMP SA lifetime for IKE proposal 10 as 600 seconds (10 minutes).
[Sysname-ike-proposal-10] sa duration 600
time-out
time-out time-out
undo time-out
View
IKE DPD view
Default level
2: System level
time-out: DPD packet retransmission interval in seconds, in the range 1 to 60.
Use time-out to set the DPD packet retransmission interval for a DPD detector.
Use undo time-out to restore the default.
The default DPD packet retransmission interval is 5 seconds.
# Set the DPD packet retransmission interval to 1 second for dpd2.
[Sysname-ike-dpd-dpd2] time-out 1
