03-Layer 2 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX Series Access Controllers Command References(R3308 R2308)-6W10703-Layer 2 Command Reference
03-VLAN Commands
03-VLAN Commands 152.75 KB
VLAN configuration commands
default
default
View
VLAN interface view
Default level
2: System level
None
Use default to restore the default settings for a VLAN interface.
# Restore the default settings for VLAN-interface 1.
[Sysname-Vlan-interface1] default
This command will restore the default settings. Continue? [Y/N]:y
description
View
VLAN view, VLAN interface view
Default level
2: System level
text: Specifies a description for a VLAN or VLAN interface. Valid characters and symbols include English letters (A to Z, a to z), digits (0 to 9), special English characters, spaces, and other Unicode characters and symbols.
·     For a VLAN, this is a string of 1 to 32 characters.
·     For a VLAN interface, this is a string of 1 to 80 characters.
·     Each Unicode character takes the space of two regular characters.
·     To use Unicode characters or symbols in an interface description, install the specific input method editor and log in to the device through remote login software that supports the character type.
·     When the length of a description string reaches or exceeds the maximum line width on the terminal software, the software starts a new line, possibly breaking a Unicode character into two. As a result, garbled characters may be displayed at the end of a line.
Use description to change the description of the current VLAN or VLAN interface.
·     For a VLAN, the default description is the VLAN ID. For example, VLAN 0001.
·     For a VLAN interface, the default description is the name of the interface. For example, Vlan-interface1 Interface.
You can configure a description to describe the function or connection of a VLAN or VLAN interface, which is very helpful when a large number of VLANs are created on the device.
# Change the description of VLAN 2 to sales-private.
[Sysname] vlan 2
[Sysname-vlan2] description sales-private
# Change the description of VLAN-interface 2 to linktoPC56.
[Sysname] vlan 2
[Sysname-vlan2] quit
[Sysname-Vlan-interface2] description linktoPC56
display interface vlan-interface
display interface [ vlan-interface ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface vlan-interface vlan-interface-id [ brief ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan-interface-id: Specifies a VLAN interface number.
down: Displays information about interfaces in DOWN state and the causes. If you do not specify this keyword, this command displays information about interfaces in all states.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display interface vlan-interface to display information about a specified or all VLAN interfaces.
If you do not provide the vlan-interface keyword, this command displays information about all interfaces.
If you provide the vlan-interface keyword but do not specify the VLAN interface number, this command displays information about all VLAN interfaces.
Related commands: reset counters interface vlan-interface.
# Display information for VLAN-interface 2.
<Sysname> display interface vlan-interface 2
Vlan-interface2 current state: DOWN
Line protocol current state: DOWN
Description: Vlan-interface2 Interface
The Maximum Transmit Unit is 1500
Internet protocol processing : disabled
IP Packet Frame Type: PKTFMT_ETHNT_2,  Hardware Address: 000f-e249-8050
IPv6 Packet Frame Type: PKTFMT_ETHNT_2,  Hardware Address: 000f-e249-8050
Last clearing of counters:  Never
# Display brief information for VLAN-interface 2.
<Sysname> display interface vlan-interface 2 brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Vlan2                DOWN DOWN     --
# Display brief information for VLAN interfaces in DOWN state.
<Sysname> display interface vlan-interface brief down
Vlan2                DOWN Not connected
The physical state of a VLAN interface:
·     DOWN ( Administratively )—The administrative state of the VLAN interface is down, because it has been shut down with the shutdown command.
·     DOWN—The administrative sate of the VLAN interface is up, but its physical sate is down. The VLAN corresponding to this interface does not contain any physical port in UP state (possibly because the ports are not well connected or the lines have failed).
·     UPBoth the administrative state and the physical state of the VLAN interface are up.
The link layer protocol state of a VLAN interface:
·     DOWN—The protocol state of this VLAN interface is down.
·     UP—The protocol state of this VLAN interface is up.
The description string of a VLAN interface.
The MTU of a VLAN interface.
The current interface is not capable of processing IP packets. This information is displayed when the interface is not configured with an IP address.
Internet Address is 192.168.1.54/24 Primary
The primary IP address of the interface is 192.168.1.54/24. This information is displayed only if the primary IP address is configured for the interface.
Internet Address is 6.4.4.4/24 Sub
The secondary IP address of the interface is 6.4.4.4/24. This information is displayed only if a secondary IP address is configured for the interface.
The IPv4 outgoing frame format.
Hardware address
The MAC address corresponding to a VLAN interface.
The IPv6 outgoing frame format.
The time when the reset counts interface vlan-interface command was last used to clear the interface statistics.
Never indicates the reset counters interface command has never been used on the current interface since the device's startup.
Brief information about Layer 3 interfaces.
The link layer state of the interface:
·     ADM—The interface has been administratively shut down. To recover its physical state, perform the undo shutdown command.
·     Stby—The interface is operating as a standby interface. To see the main interface, use the display standby state command.
If the network layer protocol state of an interface is shown as UP, but its link is an on-demand link or not present at all, its protocol attribute includes the spoofing flag (an s in parentheses).
The abbreviated interface name.
Link
The physical link state of the interface:
·     UP—The link is up.
·     ADM—The link has been administratively shut down. To recover its physical state, perform the undo shutdown command.
Protocol
Protocol connection state of the interface, which can be UP, DOWN, or UP(s).
Main IP
The main IP address of the interface.
The description of the interface.
Cause
The cause of a DOWN physical link. If the port has been shut down with the shutdown command, this field displays Administratively. To restore the physical state of the interface, use the undo shutdown command.
display mac-vlan
display mac-vlan { all | dynamic | mac-address mac-address [ mask mac-mask ] | static | vlan vlan-id } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays all the MAC address-to-VLAN entries.
dynamic: Displays dynamically configured MAC address-to-VLAN entries.
mac-address mac-address: Displays the MAC address-to-VLAN entry containing the specified MAC address.
mask mac-mask: Displays the MAC address-to-VLAN entries with their MAC addresses in the specified range.
static: Displays the statically configured MAC address-to-VLAN entries.
vlan vlan-id: Displays the MAC address-to-VLAN entries associated with the specified VLAN.
Use display mac-vlan to display the specified MAC address-to-VLAN entries.
If mac-address mac-addr is specified but mask is not specified, only the MAC address-to-VLAN entry containing the specified MAC address is displayed.
# Display all the MAC address-to-VLAN entries.
<Sysname> display mac-vlan all
The following MAC-VLAN address exist:
S: Static   D: Dynamic
MAC ADDR           MASK                    VLAN ID   PRIO    STATE
0008-0001-0000     FFFF-FF00-0000          5         3       S
0002-0001-0000     FFFF-FFFF-FFFF          5         3       S&D
Total MAC VLAN address count:2
S: Static
The character S stands for the MAC address-to-VLAN entries that are configured statically.
D: Dynamic
The character D stands for the MAC address-to-VLAN entries that are configured dynamically.
MAC ADDR
MAC address of a MAC address-to-VLAN entry.
MASK
Mask of the MAC address of a MAC address-to-VLAN entry.
VLAN ID
VLAN ID of a MAC address-to-VLAN entry.
PRIO
802.1p priority corresponding to the MAC address of a MAC address-to-VLAN entry.
STATE
The state of a MAC address-to-VLAN entry:
·     S—The MAC address-to-VLAN entry is configured statically.
·     D—The MAC address-to-VLAN entry is configured automatically through the authentication server.
·     S&D—The MAC address-to-VLAN entry is configured both statically and dynamically.
display mac-vlan interface
display mac-vlan interface [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display mac-vlan interface to display all the ports with MAC-based VLAN enabled.
Related commands: mac-vlan enable.
# Display all the interfaces with MAC-based VLAN enabled.
<Sysname> display mac-vlan interface
MAC VLAN is enabled on following ports:
GigabitEthernet1/0/1  GigabitEthernet1/0/2  GigabitEthernet1/0/3
display port
display port { hybrid | trunk } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
hybrid: Displays hybrid ports.
trunk: Displays trunk ports.
Use display port to display information about the hybrid or trunk ports on the device, including the port names, port VLAN IDs (PVIDs), and allowed VLAN IDs.
# Display information about the hybrid ports in the system.
<Sysname> display port hybrid
Interface            PVID  VLAN passing
GE1/0/2              1     Tagged:  2, 4
                           Untagged:1
# Display information about the trunk ports in the system.
<Sysname> display port trunk
GE1/0/1              1     1-3
Port name.
PVID
Port VLAN ID of the port.
VLAN passing
VLANs from which packets are allowed to pass through the port.
Tagged
VLANs from which tagged packets are required to pass through the port.
Untagged
VLANs from which untagged packets are required to pass through the port.
display vlan
display vlan [ vlan-id1 [ to vlan-id2 ] | all | dynamic | reserved | static ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan-id1: Displays the information of a VLAN specified by VLAN ID, ranging from 1 to 4094.
vlan-id1 to vlan-id2: Displays the information of a range of VLANs specified by a VLAN ID range.
all: Displays all current VLAN information except for the reserved VLANs.
dynamic: Displays the number of dynamic VLANs and the ID of each dynamic VLAN. The dynamic VLANs are generated through GVRP or those distributed by a RADIUS server.
reserved: Displays information of the reserved VLANs. Protocol modules determine which VLANs are reserved VLANs according to function implementation, and reserved VLANs serve protocol modules. You cannot do any configuration on reserved VLANs.
static: Displays the number of static VLANs and the ID of each static VLAN. The static VLANs are manually created.
Use display vlan to display VLAN information.
Related commands: vlan.
# Display VLAN 2 information.
<Sysname> display vlan 2
VLAN ID: 2
 VLAN Type: static
 Route interface: not configured
 IP Address: 1.1.1.1
 Subnet Mask: 255.255.255.0
 Description: VLAN 0002
 Tagged   Ports: none
 Untagged Ports:
VLAN Type
VLAN type, static or dynamic.
Route interface
Indicates whether a VLAN interface is configured for the VLAN (not configured or configured).
IP Address
Primary IP address of the VLAN interface (available only when an IP address is configured for the VLAN interface).
Subnet Mask
Subnet mask of the primary IP address (available only when an IP address is configured for the VLAN interface).
Description of the VLAN.
Name
Name configured for the VLAN.
Tagged Ports
Ports through which packets of the VLAN are sent tagged.
Untagged Ports
Ports through which packets of the VLAN are sent untagged.
undo interface vlan-interface vlan-interface-id
View
Default level
2: System level
vlan-interface-id: Specifies a VLAN interface number, ranging from 1 to 4094. Support for the maximum number of VLANs varies with your device models. For more information, see About the WX Series Access Controllers Command References.
Use interface vlan-interface to create a VLAN interface and enter its view or enter the view of an existing VLAN interface.
Use undo interface vlan-interface to remove the specified VLAN interface.
You must create the VLAN before you create the VLAN interface.
To configure an IP address for a VLAN interface to perform IP routing, use the ip address command in VLAN interface view.
Related commands: display interface vlan-interface.
# Create VLAN-interface 2.
[Sysname] vlan 2
ip address
undo ip address [ ip-address { mask | mask-length } [ sub ] ]
View
VLAN interface view
Default level
2: System level
ip-address: Specifies an IP address in dotted decimal notation.
mask: Specifies a subnet mask in dotted decimal notation.
mask-length: Sets the number of consecutive 1s in the subnet mask, ranging from 0 to 32.
sub: Indicates the address is a secondary IP address.
Use ip address to assign an IP address and subnet mask to a VLAN interface.
Use undo ip address to remove the IP address and subnet mask for a VLAN interface.
By default, no IP address is assigned to any VLAN interface.
Related commands: display ip interface (Layer 3 Command Reference).
# Specify the IP address as 1.1.0.1, the subnet mask as 255.255.255.0 for VLAN interface 1.
[Sysname-Vlan-interface1] ip address 1.1.0.1 255.255.255.0
mac-vlan enable
mac-vlan enable
undo mac-vlan enable
View
WLAN-ESS interface view, Layer 2 Ethernet port view
Default level
2: System level
None
Use mac-vlan enable to enable the MAC-based VLAN feature on a port.
Use undo mac-vlan enable to disable the MAC-based VLAN feature on a port.
By default, the MAC-based VLAN feature is disabled on a port.
# Enable the MAC-based VLAN feature on GigabitEthernet 1/0/1.
[Sysname–GigabitEthernet1/0/1] mac-vlan enable
mac-vlan mac-address
mac-vlan mac-address mac-address [ mask mac-mask ] vlan vlan-id [ priority pri ]
undo mac-vlan { all | mac-address mac-address [ mask mac-mask ] | vlan vlan-id }
View
Default level
2: System level
mac-address mac-address: Specifies a MAC address.
mask mac-mask: Specifies a mask for the MAC address in the format of H-H-H. The mac-mask argument is comprised of the high-order part (all the binary bits of which are 1s) and the low-order part (all the binary bits of which are 0s). By default, the hexadecimal digits of this argument are all Fs.
vlan vlan-id: Specifies a VLAN ID, ranging from of 1 to 4094.
priority pri: Specifies the 802.1p priority value corresponding to the specified MAC address. The pri argument ranges from 0 to 7.
all: Removes all the static MAC address-to-VLAN entries.
Use mac-vlan mac-address to associate the specified VLAN and priority value with the specified MAC addresses.
Use undo mac-vlan to remove the association.
Two MAC address-to-VLAN entry tables exist in a device. One table contains the MAC address-to-VLAN entries configured with the mask keyword specified. A MAC address-to-VLAN entry of this type describes the relationship between a group of MAC addresses and a VLAN, and a priority value. Another table contains the MAC address-to-VLAN entries configured without the mask keyword specified. A MAC address-to-VLAN entry of this type describes the relationship between a single MAC address and a VLAN, and a priority value. The system adds/removes MAC address-to-VLAN entries to/from the two tables according to the configuration.
# Associate a single MAC address 0-1-1 with VLAN 100 and 802.1p priority 7.
[Sysname] mac-vlan mac-address 0-1-1 vlan 100 priority 7
# Associate the MAC addresses with the high-order six hexadecimal digits being 111122 with VLAN 100 and 802.1p priority 4.
[Sysname] mac-vlan mac-address 1111-2222-3333 mask ffff-ff00-0000 vlan 100 priority 4
mtu
mtu size
undo mtu
View
VLAN interface view
Default level
2: System level
size: Sets the maximum transmission unit (MTU). The value range for this argument may vary depending on your device model. For more information, see About the WX Series Access Controllers Command References.
Use mtu to set the MTU for a VLAN interface.
By default, the MTU of a VLAN interface is 1500 bytes.
# Set the MTU to 1492 bytes for VLAN-interface 1.
[Sysname-Vlan-interface1] mtu 1492
name
name text
undo name
View
VLAN view
Default level
2: System level
text: Specifies a VLAN name, a string of 1 to 32 characters. Spaces and special characters can be included in the name.
Use name to configure a name for the current VLAN.
Use undo name to restore the default name of the VLAN.
By default, the name of a VLAN is its VLAN ID. For example, VLAN 0001.
When 802.1X or MAC address authentication is configured on a switch, you can use a RADIUS server to issue VLAN configuration to ports that have passed the authentication. Some servers can send IDs or names of the issued VLANs to the switch. When there are a large number of VLANs, you can use VLAN names rather than VLAN IDs to better locate VLANs.
# Configure the name of VLAN 2 as Test VLAN.
[Sysname] vlan 2
[Sysname-vlan2] name Test VLAN
port
port interface-list
undo port interface-list
View
VLAN view
Default level
2: System level
interface-list: Specifies an interface list, in the format of interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where &<1-10> indicates that you can specify up to 10 ports or port ranges.
Use port to assign the specified access ports to the current VLAN.
Use undo port to remove the specified access ports from the current VLAN.
By default, all ports are in VLAN 1.
This command is only applicable on access ports.
All ports are access ports by default. However, you can manually configure the port type. For more information, see "port link-type."
You cannot assign a Layer 2 aggregate interface to the current VLAN.
Related commands: display vlan.
# Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] port gigabitethernet 1/0/1 to gigabitethernet 1/0/3
port access vlan
port access vlan vlan-id
undo port access vlan
View
WLAN-ESS interface view, Ethernet interface view, port group view, Layer 2 aggregate interface view
Default level
2: System level
vlan-id: Specifies a VLAN ID, ranging from 1 to 4094. Make sure that the VLAN specified by the VLAN ID already exists.
Use port access vlan to assign the current access ports to the specified VLAN.
Use undo port access vlan to restore the default.
By default, all access ports belong to VLAN 1.
The configuration made in WLAN-ESS or Ethernet interface view applies only to the port.
The configuration made in port group view applies to all ports in the port group.
The configuration made in Layer 2 aggregate interface view applies to the aggregate interface and its aggregation member ports.
·     If the system fails to apply the configuration to the aggregate interface, it stops applying the configuration to aggregation member ports.
·     If the system fails to apply the configuration to an aggregation member port, it skips the port and moves to the next member port.
# Assign GigabitEthernet 1/0/1 to VLAN 3.
[Sysname] vlan 3
[Sysname-vlan3] quit
[Sysname-GigabitEthernet1/0/1] port access vlan 3
# Assign Layer 2 aggregate interface Bridge-aggregation 1 and its member ports to VLAN 3.
[Sysname] vlan 3
[Sysname-Bridge-Aggregation1] port access vlan 3
port hybrid pvid
port hybrid pvid vlan vlan-id
undo port hybrid pvid
View
Default level
2: System level
Use port hybrid pvid to configure the port VLAN ID (PVID) of the hybrid port.
Use undo port hybrid pvid to restore the default.
By default, the PVID of a hybrid port is VLAN 1.
You can use a nonexistent VLAN as the PVID for a hybrid port. Removing the PVID of a hybrid port with the undo vlan command does not affect the setting of the PVID on the port.
H3C recommends that you set the same PVID for the local and remote hybrid ports.
After configuring the PVID for a hybrid port, you must use the port hybrid vlan command to configure the hybrid port to allow packets from the PVID to pass through, so that the port can forward packets from the PVID.
Related commands: port link-type and port hybrid vlan.
# Configure VLAN 100 as the PVID of the hybrid port GigabitEthernet 1/0/1.
[Sysname] vlan 100
[Sysname-vlan100] quit
[Sysname-GigabitEthernet1/0/1] port link-type hybrid
[Sysname-GigabitEthernet1/0/1] port hybrid pvid vlan 100
# Configure VLAN 100 as the PVID of the hybrid Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] port link-type hybrid
[Sysname-Bridge-Aggregation1] port hybrid pvid vlan 100
port hybrid vlan
undo port hybrid vlan vlan-id-list
View
Default level
2: System level
vlan-id-list: Specifies a list of VLANs that the hybrid ports will be assigned to, in the format of [ vlan-id1 [ to vlan-id2 ] ]&<1-10>, where vlan-id ranges from 1 to 4094, and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges. Make sure that the specified VLANs already exist.
tagged: Configures the ports to send the packets of the specified VLANs with the tags kept.
untagged: Configures the port to send the packets of the specified VLANs with the tags removed.
Use port hybrid vlan to assign the current hybrid ports to the specified VLANs.
Use undo port hybrid vlan to remove the current hybrid ports from the specified VLANs.
By default, a hybrid port only allows packets from VLAN 1 to pass through untagged.
A hybrid port can carry multiple VLANs. If you execute the port hybrid vlan command multiple times, the VLANs the hybrid port carries are the set of VLANs specified by vlan-id-list in each execution.
Related commands: port link-type.
# Assign the hybrid port GigabitEthernet 1/0/1 to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100, and configure GigabitEthernet 1/0/1 to send packets of these VLANs with tags kept.
[Sysname-GigabitEthernet1/0/1] port hybrid vlan 2 4 50 to 100 tagged
port link-type
undo port link-type
View
Default level
2: System level
access: Configures the link type of a port as access.
hybrid: Configures the link type of a port as hybrid.
trunk: Configures the link type of a port as trunk.
Use port link-type to configure the link type of a port.
Use undo port link-type to restore the default link type of a port.
By default, any port is an access port.
To change the link type of a port from trunk to hybrid or vice versa, you must set the link type to access first.
# Configure GigabitEthernet 1/0/1 as a trunk port.
# Configure all the ports in the manual port group group1 as hybrid ports.
[Sysname] port-group manual group1
[Sysname-port-group manual group1] group-member gigabitethernet 1/0/1
[Sysname-port-group manual group1] group-member gigabitethernet 1/0/2
[Sysname-port-group manual group1] port link-type hybrid
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 and its member ports as hybrid ports.
port trunk permit vlan
undo port trunk permit vlan { vlan-id-list | all }
View
Default level
2: System level
vlan-id-list: Specifies a list of VLANs that the trunk ports will be assigned to, in the format of [vlan-id1 [ to vlan-id2 ] ]&<1-10>, where vlan-id ranges from 1 to 4094, and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges.
all: Permits all VLANs to pass through the trunk ports. On GVRP-enabled trunk ports, you must configure the port trunk permit vlan all command to be sure that the traffic of all dynamically registered VLANs can pass through. To prevent unauthorized VLAN users from accessing restricted resources through a GVRP-disabled port, do not use the port trunk permit vlan all command on the port.
Use port trunk permit vlan to assign the current trunk ports to the specified VLANs.
Use undo port trunk permit vlan to remove the trunk ports from the specified VLANs.
By default, a trunk port allows only packets from VLAN 1 to pass through.
A trunk port can carry multiple VLANs. If you execute the port trunk permit vlan command multiple times, the VLANs the trunk port carries are the set of VLANs specified by vlan-id-list in each execution.
On a trunk port, only traffic of the PVID can pass through untagged.
The configuration made in Ethernet interface view applies only to the port.
# Assign the trunk port GigabitEthernet 1/0/1 to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100.
[Sysname-GigabitEthernet1/0/1] port trunk permit vlan 2 4 50 to 100
Please wait........... Done.
# Assign the trunk Layer 2 aggregate interface Bridge-Aggregation 1 to VLAN 2.
[Sysname-Bridge-Aggregation1] port link-type trunk
[Sysname-Bridge-Aggregation1] port trunk permit vlan 2
 Please wait... Done.
 Configuring GigabitEthernet1/0/1... Done.
 Configuring GigabitEthernet1/0/2... Done.
 Configuring GigabitEthernet1/0/3... Done.
The output shows that GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 are the member ports of the aggregation group corresponding to Bridge-aggregation 1.
port trunk pvid
port trunk pvid vlan vlan-id
undo port trunk pvid
View
Default level
2: System level
Use port trunk pvid to configure the PVID for the trunk port.
Use undo port trunk pvid to restore the default.
By default, the PVID of a trunk port is VLAN 1.
You can use a nonexistent VLAN as the PVID for a trunk port. Removing the PVID of a trunk port with the undo vlan command does not affect the setting of the PVID on the port.
The local and remote trunk ports must use the same PVID for the traffic of the PVID to be transmitted properly.
After configuring the PVID for a trunk port, you must use the port trunk permit vlan command to configure the trunk port to allow packets from the PVID to pass through, so that the port can forward packets from the PVID.
Related commands: port link-type and port trunk permit vlan.
# Configure VLAN 100 as the PVID of the trunk port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port trunk pvid vlan 100
# Configure VLAN 100 as the PVID of the trunk Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] port trunk pvid vlan 100
reset counters interface vlan-interface [ vlan-interface-id ]
View
Default level
2: System level
Use reset counters interface vlan-interface to clear the statistics on a VLAN interface.
Before collecting the traffic statistics within a specific period of time on an interface, you must clear the existing statistics first.
If the vlan-interface-id argument is not specified, this command clears the statistics of all VLAN interfaces.
If the vlan-interface-id argument is specified, this command clears the statistics of the specified VLAN interface.
# Clear the statistics on VLAN-interface 2.
<Sysname> reset counters interface vlan-interface 2
shutdown
shutdown
View
VLAN interface view
Default level
2: System level
None
Use shutdown to shut down a VLAN interface.
Use undo shutdown to bring up a VLAN interface.
By default, a VLAN interface is up except when all ports in the VLAN are down.
You can use the undo shutdown command to bring up a VLAN interface after configuring related parameters and protocols for the VLAN interface. When a VLAN interface fails, you can shut down the interface with the shutdown command and then bring it up with the undo shutdown command. In this way, the interface may resume.
The state of any Ethernet port in a VLAN is independent of the VLAN interface state.
# Shut down VLAN-interface 2 and then bring it up.
[Sysname-Vlan-interface2] shutdown
[Sysname-Vlan-interface2] undo shutdown
vlan
vlan { vlan-id1 [ to vlan-id2 ] | all }
undo vlan { vlan-id1 [ to vlan-id2 ] | all }
View
Default level
2: System level
vlan-id1, vlan-id2: Specifies a VLAN ID, ranging from 1 to 4094.
vlan-id1 to vlan-id2: Specifies a VLAN range.
all: Creates or removes all VLANs except reserved VLANs. The keyword is not supported when the maximum number of VLANs that can be created on a device is less than 4094.
Use vlan vlan-id to create a VLAN and enter its view or enter the view of an existing VLAN.
Use vlan vlan-id1 to vlan-id2 to create a range of VLANs specified by vlan-id1 to vlan-id2, except reserved VLANs.
Use undo vlan to remove the specified VLANs.
As the default VLAN, VLAN 1 cannot be created or removed.
You cannot create or remove reserved VLANs reserved for specific functions.
For dynamic VLANs, you must remove the related configurations first, because you cannot use the undo vlan command to directly remove them.
# Enter VLAN 2 view.
[Sysname] vlan 2
[Sysname-vlan2]
# Create VLAN 4 through VLAN 100.
[Sysname] vlan 4 to 100
Please wait............. Done.
