03-Layer 2 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX Series Access Controllers Command References(R3308 R2308)-6W10703-Layer 2 Command Reference
07-Layer 2 Forwarding Commands
07-Layer 2 Forwarding Commands 76.09 KB
Layer 2 forwarding configuration commands
General Layer 2 forwarding configuration commands
display mac-forwarding statistics
display mac-forwarding statistics [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays the statistics of a specified interface.
interface-type: Specifies the interface type.
interface-number: Specifies the interface number.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display mac-forwarding statistics to display Layer 2 forwarding statistics.
If no parameter is specified, Layer 2 forwarding statistics for all interfaces is displayed.
# Display the Layer 2 forwarding statistics for all interfaces.
<Sysname> display mac-forwarding statistics
Total received:  888
Filtered:111      STP discarded:0
Broadcast:0       Multicast:0
Unknown Unicast:0 Invalid Tag:0
Total deliver to up:  111
L2 protocol:11  Local MAC address:100
Blackhole dropped:0
Total sent:  666
Filtered:0      STP discarded:0
# Display forwarding statistics of GigabitEthernet 1/0/1.
<Sysname> display mac-forwarding statistics interface GigabitEthernet 1/0/1
GigabitEthernet 1/0/1:
Input frames:100    Input bytes:23
Output frames:100   Output bytes:23
Filtered:0          Invalid Tag:0
Total received
Total number of received Ethernet frames.
Filtered
Number of frames filtered out by 802.1Q Tagged VLAN inbound filtering rules.
STP discarded
Number of Ethernet frames dropped on the ingress ports blocked by STP.
Broadcast
Number of received broadcast frames.
Multicast
Number of received multicast frames.
Unknown unicast
Number of received unknown unicast frames.
Invalid Tag
Number of Ethernet frames dropped because of invalid tags.
At present, Ethernet frames with the VLAN ID as 0 or 0xFFF are dropped.
Total deliver to up
Number of Ethernet frames delivered to upper layer protocols.
L2 protocol
Number of Layer 2 protocol frames delivered to the upper layer.
Local MAC address
Number of Ethernet frames with the destination being the MAC addresses of local Layer 3 interfaces.
Blackhole dropped
Number of frames dropped as they are destined to blackhole MAC addresses.
Total sent
Total number of sent Ethernet frames.
Filtered
Number of frames filtered out by the VLAN egress traffic filtering rule.
STP discarded
Number of Ethernet frames dropped on egress ports blocked by STP.
Input frames
Number of received Ethernet frames on the interface.
Output frames
Number of Ethernet frames sent from the interface.
Input bytes
Number of received bytes on the interface.
Output bytes
Number of bytes sent out of the interface.
Filtered
Number of Ethernet frames filtered out because they are from other VLANs.
reset mac-forwarding statistics
View
Default level
2: System level
None
Use reset mac-forwarding statistics to clear all Layer 2 forwarding statistics.
# Clear all Layer 2 forwarding statistics.
<Sysname> reset mac-forwarding statistics
Fast Layer 2 forwarding configuration commands
display mac-fast-forwarding cache
display mac-fast-forwarding cache { all | { destination-mac mac-address | source-mac mac-address | vlan vlan-id }* } [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays all fast Layer 2 forwarding entries.
destination-mac mac-address: Displays the fast Layer 2 forwarding entries of the specified destination MAC address.
source-mac mac-address: Displays the fast Layer 2 forwarding entries of the specified source MAC address.
vlan vlan-id: Displays the fast Layer 2 forwarding entries of the specified VLAN. The VLAN ID ranges 1 to 4094.
verbose: Displays detailed information about fast Layer 2 forwarding.
Use display mac-fast-forwarding cache to display fast Layer 2 forwarding entries.
If the verbose keyword is specified, the detailed information of the specified or all fast Layer 2 forwarding entries is displayed.
# Display the brief information of all fast Layer 2 forwarding entries.
<Sysname> display mac-fast-forwarding cache all
           Fast Forward Cache Table
 Number of entries in the table : 2
 Source MAC         Destination MAC     VLAN ID
 001B-111D-B192     001B-11B4-F729       1
 001B-11B4-F729     001B-111D-B192       1
# Display the detailed information about all fast Layer 2 forwarding entries.
<Sysname> display mac-fast-forwarding cache all verbose
 Destination MAC       : 001B-11B4-F729
 Source MAC            : 001B-111D-B192
 VLAN ID               : 1
 Destination Interface : WLAN-DBSS3:0
 Source Interface      : WLAN-DBSS3:0
 AP IP                 : 192.168.2.2
 AC IP                 : 192.168.2.110
 NextHop IP            : 192.168.2.2
 OutPut Interface      : GigabitEthernet1/0/2
 Cache Context         : 00238917b590000fe264493d08004500000000000000ff110000c0a
8026ec0a802022fbe2fbe0000000008000000000008020000001b11b4f72900238917b590001b111
db1920000aaaa030000000000
 Destination MAC       : 001B-111D-B192
 Source MAC            : 001B-11B4-F729
 VLAN ID               : 1
 AP IP                 : 192.168.2.2
8026ec0a802022fbe2fbe0000000008000000000008020000001b111db19200238917b590001b11b
4f7290000aaaa030000000000
# Display the brief information of fast Layer 2 forwarding entries of source MAC address 001B-111D-B192.
<Sysname> display mac-fast-forwarding cache source-mac 001B-111D-B192
 Number of entries in the table : 1
# Display the detailed information of fast Layer 2 forwarding entries of source MAC address 001B-111D-B192.
<Sysname> display mac-fast-forwarding cache source-mac 001B-111D-B192 verbose
 VLAN ID               : 1
 AP IP                 : 192.168.2.2
Source MAC
Source MAC address of a forwarding entry.
Destination MAC
Destination MAC address of a forwarding entry.
VLAN ID
VLAN to which the forwarded packet belongs.
AP IP
IP address of the AP to which the client associates. This field displays "N/A" on a wired client side.
AC IP
IP address of the AC to which the client associates. This field displays "N/A" on a wired client side.
NextHop IP
IP address of the next hop.
OutPut Interface
Physical outgoing interface.
Cache Context
Fast forwarding information.
mac-fast-forwarding
mac-fast-forwarding
undo mac-fast-forwarding
View
Default level
2: System level
None
Use mac-fast-forwarding to enable fast Layer 2 forwarding.
Use undo mac-fast-forwarding to disable fast Layer 2 forwarding.
By default, fast Layer 2 forwarding is enabled.
# Enable fast Layer 2 forwarding.
[Sysname] mac-fast-forwarding
reset mac-fast-forwarding cache
reset mac-fast-forwarding cache { all | { destination-mac mac-address | source-mac mac-address | vlan vlan-id }* }
View
Default level
2: System level
all: Clears all fast Layer 2 forwarding entries.
destination-mac mac-address: Clears the fast Layer 2 forwarding entries of the specified destination MAC address.
source-mac mac-address: Clears the fast Layer 2 forwarding entries of the specified source MAC address.
vlan vlan-id: Clears the fast Layer 2 forwarding entries of the specified VLAN. The VLAN ID ranges 1 to 4094.
Use reset mac-fast-forwarding cache to clear fast Layer 2 forwarding entries.
# Clear all fast Layer 2 forwarding entries.
<Sysname> reset mac-fast-forwarding cache all
