03-Layer 2 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX Series Access Controllers Command References(R3308 R2308)-6W10703-Layer 2 Command Reference
05-Ethernet Link Aggregation Commands
05-Ethernet Link Aggregation Commands 119.63 KB
Support of the H3C WX series access controllers for Ethernet link aggregation commands may vary by device model. For more information, see About the WX Series Access Controllers Command References.
default
default
View
Default level
2: System level
None
Use default to restore the default settings for an aggregate interface.
# Restore the default settings for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] default
This command will restore the default settings. Continue? [Y/N]:y
description
View
Default level
2: System level
text: Specifies the interface description, a string of 1 to 80 characters.
Use description to configure a description for an interface. Fore example, you can include information such as the purpose of the interface for the ease of management.
Use undo description to restore the default setting.
By default, the description of an interface is interface-name Interface. For example, the default description of Bridge-Aggregation1 is Bridge-Aggregation1 Interface.
# Set the description of Layer 2 aggregate interface Bridge-Aggregation 1 to connect to the lab.
[Sysname-Bridge-Aggregation1] description connect to the lab
display interface
display interface [ bridge-aggregation ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface bridge-aggregation interface-number [ brief ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
bridge-aggregation: Displays information about Layer 2 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number. The value range for the interface-number argument is the set of all existing aggregate interface numbers and varies with device models. For more information, see About the WX Series Access Controllers Command References.
brief: Displays brief interface information. If you do not specify this keyword, this command displays detailed interface information.
down: Displays information about interfaces in DOWN state and the causes. If you do not specify this keyword, this command displays information about interfaces in all states.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display interface to display aggregate interface information.
·     If bridge-aggregation is not specified, this command displays information about all interfaces.
·     If bridge-aggregation is specified without any interface number specified, this command displays information about all aggregate interfaces.
·     If bridge-aggregation interface-number is specified, this command displays information about the specified aggregate interface.
# Display information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1
 Bridge-Aggregation1 current state: DOWN
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e207-f2e0
 Description: Bridge-Aggregation1 Interface
 PVID: 1
 Port link-type: access
  Tagged   VLAN ID : none
  Untagged VLAN ID : 1
  Port priority: 0
 Last clearing of counters:  11:08:46 Thu 01/20/2011
# Display brief information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1 brief
The brief information of interface(s) under bridge mode:
Speed or Duplex: (a)/A - auto; H - half; F - full
BAGG1                DOWN auto    A      A    1
# Display information about all Layer 2 aggregate interfaces in DOWN state.
<Sysname> display interface bridge-aggregation brief down
BAGG1                DOWN Not connected
The output from this command was collected on a WX5004 access controller and may vary with device models.
The Layer 2 interface status:
·     DOWN (Administratively)—The interface is administratively shut down with the shutdown command.
·     DOWN—The interface is administratively up but physically down (possibly because no physical link is present or the link is faulty).
·     UP—The Ethernet interface is both administratively and physically up.
The interface speed and duplex mode are unknown.
PVID
Port VLAN ID.
Port priority
Aggregation priority of the port.
Time when the reset counters interface command was last used to clear the interface statistics.
Never indicates the reset counters interface command has never been used on the current interface since the device's startup.
Brief information about Layer 2 interfaces.
Link status:
·     ADM—The interface has been administratively shut down. To recover its physical layer state, execute the undo shutdown command.
·     Stby—The interface is operating as a backup interface. To see the primary interface, use the display standby state command (see High Availability Command Reference).
If the speed of an interface is automatically negotiated, its speed attribute includes the auto negotiation flag, letter a in parentheses.
If the duplex mode of an interface is automatically negotiated, its duplex mode attribute includes the auto negotiation flag, letter a in parentheses or a capital A. Letter H indicates the half duplex mode, and letter F indicates the full duplex mode.
Link type options for Ethernet interfaces.
Abbreviated interface name.
Link
Physical link state of the interface.
Speed
Interface speed, in bps.
Cause
Cause of a DOWN physical link.
display link-aggregation load-sharing mode
display link-aggregation load-sharing mode [ interface [ bridge-aggregation interface-number ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
bridge-aggregation: Displays the load sharing criterion or criteria of the aggregation group corresponding to the specified Layer 2 aggregate interface.
interface-number: Specifies an existing aggregate interface number. The value range for the interface-number argument varies with device models. For more information, see About the WX Series Access Controllers Command References.
Use display link-aggregation load-sharing mode to display global or group-specific link-aggregation load sharing criterion or criteria.
To display the global link-aggregation load sharing criterion or criteria, run the command without the interface keyword.
To display all the group-specific load sharing criteria, run the command with the interface keyword, but do not specify a particular interface.
To display the load sharing criterion or criteria of a particular aggregation group, perform the command with the aggregate interface specified.
The bridge-aggregation keyword becomes available only after you create Layer 2 aggregate interfaces on the device.
# Display the global link-aggregation load sharing criteria.
<Sysname> display link-aggregation load-sharing mode
Link-Aggregation Load-Sharing Mode:
Layer 2 traffic: destination-mac address, source-mac address
# Display the link-aggregation load sharing criteria of the aggregation group corresponding to Layer 2 aggregate interface Bridge-Aggregation 2.
<Sysname> display link-aggregation load-sharing mode interface bridge-aggregation 2
Bridge-Aggregation2 Load-Sharing Mode:
Global link-aggregation load sharing criteria.
·     By default, the link-aggregation load sharing criteria for Layer 2 traffic are displayed.
·     If you have configured the global link-aggregation load sharing criteria, the configured ones are displayed.
Link-aggregation load sharing criteria of the aggregation group corresponding to the aggregate interface Bridge-Aggregation 2.
·     By default, the global link-aggregation load sharing criteria are displayed.
·     If you have configured link-aggregation load sharing criteria especially for this aggregation group, the configured ones are displayed.
Default link-aggregation load sharing criteria for Layer 2 traffic. In this sample output, the criteria are the source and destination MAC addresses of packets.
display link-aggregation member-port
display link-aggregation member-port [ interface-list ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number [ to interface-type interface-number ], where interface-type interface-number indicates the port type and port number.
Use display link-aggregation member-port to display detailed link aggregation information for the specified member ports or all member ports if no interface is specified.
For a member port in a static aggregation group, only the port number and operational key are displayed, because the aggregation group is unaware of information about the peer groups.
# Display detailed link aggregation information for GigabitEthernet 1/0/1, a member port of a static aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 1/0/1
GigabitEthernet1/0/1:
Aggregation Interface: Bridge-Aggregation1
Port Number: 1
Port Priority: 32768
Oper-Key: 1
Aggregate interface to which the member port belongs.
Port Priority
Oper-key
Operational key.
display link-aggregation summary
display link-aggregation summary [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display link-aggregation summary to display summary information about all aggregation groups.
You might find that information about the remote system for a static link aggregation group is either displayed as none or is not displayed at all. This is normal, because static link aggregation groups are unaware of information about the peer groups.
# Display summary information about all aggregation groups.
<Sysname> display link-aggregation summary
Aggregation Interface Type:
BAGG -- Bridge-Aggregation, RAGG -- Route-Aggregation
AGG         Select Unselect   Share
Interface   Ports  Ports      Type
BAGG1       0      0          Shar
BAGG2       0      1          Shar
Aggregate interface type: BAGG for Layer 2 aggregate interface
Loadsharing Type
Load-sharing type:
·     Shar for load sharing
·     NonS for non-load sharing
AGG Interface
Type and number of the aggregate interface
Select Ports
Total number of Selected ports
Unselect Ports
Total number of Unselected ports
Share Type
Load sharing type
display link-aggregation verbose
display link-aggregation verbose [ bridge-aggregation [ interface-number ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
bridge-aggregation: Displays detailed information about the Layer 2 aggregation groups corresponding to Layer 2 aggregate interfaces.
Use display link-aggregation verbose to display detailed information about the aggregation groups corresponding to the aggregate interfaces.
To display information about a specific Layer 2 aggregation group, use the display link-aggregation verbose bridge-aggregation interface-number command.
To display information about all Layer 2 aggregation groups, use the display link-aggregation verbose bridge-aggregation command.
To display information about all aggregation groups, use the display link-aggregation verbose command.
The bridge-aggregation keyword is available only after you create Layer 2 aggregate interfaces on the device.
# Display detailed information about the aggregation group corresponding to Layer 2 aggregate interface Bridge-Aggregation 2, which is a static aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 2
Port Status: S -- Selected, U -- Unselected
Aggregation Interface: Bridge-Aggregation2
Aggregation Mode: Static
  Port             Status  Priority  Oper-Key
  GE1/0/2          U       32768     1
Table 5 Command output
Loadsharing Type
Load-sharing type:
Port Status
Port state: Selected or Unselected
Name of the aggregate interface
Aggregation Mode
Mode of the aggregation group: Static for static aggregation
Port
Port type and number
Status
Port state: selected or unselected
Priority
Port aggregation priority
Oper-Key
Operational key
enable snmp trap updown
undo enable snmp trap updown
View
Default level
2: System level
None
Use enable snmp trap updown to enable link state trapping for the aggregate interface.
Use undo enable snmp trap updown to disable link state trapping for the aggregate interface.
By default, link state trapping is enabled for an aggregate interface.
With the link state trapping function enabled, an aggregate interface generates linkUp trap messages when its link goes up, and linkDown trap messages when its link goes down.
For an aggregate interface to generate linkUp/linkDown traps when its link state changes, you must enable link state trapping globally with the snmp-agent trap enable [ standard [ linkdown | linkup ] * ] command.
For more information about the snmp-agent trap enable command, see Network Management and Monitoring Command Reference.
# Enable linkUp/linkDown trap generation on Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] enable snmp trap updown
undo interface bridge-aggregation interface-number
View
Default level
2: System level
interface-number: Specifies a Layer 2 aggregate interface number. The value range for the interface-number argument varies with device models. For more information, see About the WX Series Access Controllers Command References.
Use interface bridge-aggregation to create a Layer 2 aggregate interface and enter the Layer 2 aggregate interface view.
Use undo interface bridge-aggregation to remove a Layer 2 aggregate interface.
When a Layer 2 aggregate interface is created, a Layer 2 aggregation group with the same number is automatically created. If you remove the Layer 2 aggregate interface, you also remove the Layer 2 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
# Create Layer 2 aggregate interface Bridge-Aggregation 1 and enter its view.
link-aggregation load-sharing mode { destination-ip | destination-mac | source-ip | source-mac } *
undo link-aggregation load-sharing mode
View
System view, Layer 2 aggregate interface view
Default level
2: System level
destination-ip: Performs load sharing in link aggregation groups based on destination IP address.
destination-mac: Performs load sharing in link aggregation groups based on destination MAC address.
source-ip: Performs load sharing in link aggregation groups based on source IP address.
source-mac: Performs load sharing in link aggregation groups based on source MAC address.
Use link-aggregation load-sharing mode to configure the global or group-specific link-aggregation load sharing criteria.
Use undo link-aggregation load-sharing mode to restore the default setting.
By default, the device performs load sharing in link aggregation groups based on source and destination MAC addresses.
The load sharing criteria that you configure will overwrite the previous criteria.
# Configure the destination MAC address as the global link-aggregation load sharing criterion.
[Sysname] link-aggregation load-sharing mode destination-mac
# Configure the destination MAC address as the load sharing criterion specific to the link aggregation group of aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] link-aggregation load-sharing mode destination-mac
link-aggregation port-priority
link-aggregation port-priority port-priority
undo link-aggregation port-priority
View
Ethernet interface view
Default level
2: System level
port-priority: Specifies a port aggregation priority, ranging from 0 to 65535. The smaller the value, the higher the port aggregation priority.
Use link-aggregation port-priority to set the aggregation priority of a port.
Use undo link-aggregation port-priority to restore the default setting.
The default aggregation priority of a port is 32768.
# Set the aggregation priority of port GigabitEthernet 1/0/1 to 64.
[Sysname-GigabitEthernet1/0/1] link-aggregation port-priority 64
port link-aggregation group
port link-aggregation group number
undo port link-aggregation group
View
Default level
2: System level
number: Specifies the number of the aggregate interface corresponding to an aggregation group. The value range for the number argument varies with device models. For more information, see About the WX Series Access Controllers Command References.
Use port link-aggregation group to assign the current Ethernet interface to the specified aggregation group.
Use undo port link-aggregation group to remove the current Ethernet interface from the aggregation group to which it belongs.
A Layer 2 Ethernet interface can be assigned to a Layer 2 aggregation group only.
An Ethernet interface can belong to only one aggregation group.
# Assign Layer 2 interface GigabitEthernet 1/0/1 to Layer 2 aggregation group 1.
[Sysname-GigabitEthernet1/0/1] port link-aggregation group 1
reset counters interface [ bridge-aggregation [ interface-number ] ]
View
Default level
2: System level
bridge-aggregation: Clears statistics for Layer 2 aggregate interfaces.
interface-number: Specifies an aggregate interface number. The range for the interface-number argument varies with device models. For more information, see About the WX Series Access Controllers Command References.
Use reset counters interface to clear the statistics of the specified Layer 2 aggregate interface or interfaces.
Before collecting statistics for a Layer 2 aggregate interface within a specific period, clear the existing statistics of the interface.
·     If no keywords or argument is specified, the command clears the statistics of all interfaces in the system.
·     If only the bridge-aggregation keyword is specified, the command clears the statistics of all Layer 2 aggregate interfaces.
·     If the bridge-aggregation interface-number option is specified, the command clears the statistics of the specified Layer 2 aggregate interface.
·     The bridge-aggregation keyword becomes available only after you create Layer 2 aggregate interfaces on the device.
# Clear the statistics of Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> reset counters interface bridge-aggregation 1
shutdown
shutdown
View
Default level
2: System level
None
Use shutdown to shut down the current aggregate interface.
Use undo shutdown to bring up the current aggregate interface.
By default, aggregate interfaces are up.
# Shut down Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] shutdown
