03-Layer 2—LAN Switching Configuration Guide
HomeSupportSwitchesH3C S6300 Switch SeriesConfigure & DeployConfiguration GuidesH3C S6300 Switch Series Configuration Guides-Release 243x-6W10003-Layer 2—LAN Switching Configuration Guide
14-Cut-through forwarding configuration
14-Cut-through forwarding configuration 25.29 KB
Configuring cut-through Layer 2 forwarding
A cut-through forwarding-enabled switch forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame within the switch, and enhances forwarding performance.
To configure cut-through forwarding:
Step
Remarks
1.      Enter system view.
N/A
2.      Enable cut-through forwarding.
cut-through enable
By default, cut-through forwarding is disabled.
