12-Telemetry Command Reference
HomeSupportSwitchesH3C S12500X-AF Switch SeriesReference GuidesCommand ReferencesH3C S12500X-AF Switch Series Command References(R320x)-6W10012-Telemetry Command Reference
02-INT commands
02-INT commands 67.32 KB
INT commands
display telemetry ifa
Use display telemetry ifa to display INT configuration.
# Display INT configuration.
<Sysname> display telemetry ifa
  Telemetry ifa status: Enabled
  Telemetry ifa device-id: 10.1.1.10
  Telemetry ifa role:
    HundredGigE1/0/3: Transit
  Telemetry ifa action:
    GigabitEthernet1/0/2:
      Telemetry ifa 1 acl 3000 action mirror-to-processor sampler S1
      Telemetry ifa 2 acl user-defined 5000 local-loopback action add-metadata
      Telemetry ifa 3 acl user-defined 5001 action add-metadata
Telemetry ifa role
INT role:
·     Ingress—Entry node.
·     Transit—Transit node.
·     Egress—Exit node.
Telemetry ifa collector
Encapsulation parameters for INT packets.
Enhanced INT configuration:
·     ifa 1—INT action ID.
·     acl—ACL used to match packets.
·     action add-metadata—Action of adding collected metadata on the transit node.
·     action mirror-to-processor drop—Action of mirroring packets to the INT processor and dropping the original packets on the entry node.
·     local-loopback action add-metadata—Action of adding collected metadata to looped back traffic on the entry node or exit node.
·     action mirror-to-processor—Action of mirroring packets to the INT processor.
·     sampler—Sampler used.
telemetry ifa acl action add-metadata
telemetry ifa acl action mirror-to-processor drop
telemetry ifa acl local-loopback action add-metadata
telemetry ifa action mirror-to-processor
telemetry ifa collector
telemetry ifa device-id
telemetry ifa role
Use telemetry ifa acl action add-metadata to configure an INT action of adding collected metadata to incoming packets on the input interface on the transit node.
Use undo telemetry ifa to delete an INT action.
telemetry ifa ifa-id acl user-defined { acl-number | name acl-name } action add-metadata
undo telemetry ifa ifa-id
No INT action is configured.
ifa-id: Specifies an INT action ID in the range of 1 to 65535.
user-defined: Specifies a user-defined ACL by its number or name.
acl-number: Specifies the ACL number in the range of 5000 to 5999.
name acl-name: Specifies the ACL name, a case-insensitive string of 1 to 63 characters.
After this command is executed, the device adds collected metadata to matching packets on the input interface to calculate the transmission delay of the link.
If the specified ACL does not contain rules, the action is not applied to any packets.
If an ACL is specified in the action of mirroring original packets on the entry node to the INT processor, the ACL specified in this command must contain the same traffic match criteria as that ACL and plus the statement to match the INT flag. The traffic match criteria and the statement to match the INT flag must be in the same ACL rule. For example, if the rule in the ACL in the action of mirroring original packets is rule permit tcp source 10.0.0.3 0, the rule in the ACL in this command must be rule permit tcp source 10.0.0.3 0 ifa l5 aaaaaaaabbbbbbbb ffffffffffffffff 0.
This command and the telemetry ifa role command are mutually exclusive on one interface.
If you execute this command multiple times for the action ID, the most recent configuration takes effect.
# Add collected metadata to incoming packets on HundredGigE 1/0/1 on the transit node.
[Sysname-HundredGigE1/0/1] telemetry ifa 1 acl user-defined 5001 action add-metadata
acl (ACL and QoS Command Reference)
telemetry ifa role
Use telemetry ifa acl action mirror-to-processor drop to configure an INT action of adding collected metadata to INT packets on the input interface on the exit node and dropping the original INT packets.
telemetry ifa ifa-id acl user-defined { acl-number | name acl-name } action mirror-to-processor drop
After this command is executed, the device mirrors matching INT packets on the input interface to the INT processor and drops the original INT packets. Then, the INT processor encapsulates the INT packets and sends them to the collector.
# Add collected metadata to INT packets on HundredGigE 1/0/1 on the exit node and drop the original INT packets.
[Sysname-HundredGigE1/0/1] telemetry ifa 2 acl user-defined 5001 action mirror-to-processor drop
telemetry ifa role
Use telemetry ifa acl local-loopback action add-metadata to configure an INT action of adding collected metadata to looped back traffic on the input interface on the entry or exit node.
telemetry ifa ifa-id acl user-defined { acl-number | name acl-name } local-loopback action add-metadata
After this command is executed, the device adds collected metadata to matching looped back traffic on the input interface to calculate the transmission delay of the link.
# Add collected metadata to looped back traffic on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] telemetry ifa 2 acl user-defined 5001 loopback action add-metadata
telemetry ifa role
Use telemetry ifa action mirror-to-processor to configure an INT action of mirroring original packets on the input interface on the entry or exit node to the INT processor.
telemetry ifa ifa-id [ acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name } ] action mirror-to-processor [ sampler sampler-name ]
acl: Specifies an ACL by its number or name for matching packets. If you do not specify this keyword, the action takes effect on all packets.
ipv6: Specifies the IPv6 ACL type.
mac: Specifies the Layer 2  ACL type.
user-defined: Specifies the user-defined ACL type.
acl-number: Specifies the ACL number. The following are available value ranges:
·     2000 to 2999 for basic ACLs.
·     3000 to 3999 for advanced ACLs.
·     4000 to 4999 for Layer 2 ACLs.
·     5000 to 5999 for user-defined ACLs.
sampler sampler-name: Specifies a sampler by its name, a case-insensitive string of 1 to 31. If you do not specify a sampler, all packets are mirrored.
After this command is executed, the device samples ACL-matched packets received on the input interface, and mirrors sampled packets to the INT processor. Then, the INT processor adds an INT header to the sampled packets and sends them back to the input interface as INT packets by using internal loopback.
To specify an ACL by a number, follow these rules:
·     To specify an IPv4 ACL, directly specify the acl-number argument.
?     To specify an IPv6 ACL, specify the ipv6 keyword and the acl-number argument.
·     To specify a Layer 2 or user-defined ACL, specify the mac or user-defined keyword and the acl-number argument, or directly specify the acl-number argument.
To specify an ACL by a name, follow these rules:
·     To specify an IPv4 ACL, directly specify the name acl-name option.
·     To specify an IPv6, Layer 2, or user-defined ACL, specify the ipv6, mac, or user-defined keyword and the name acl-name argument
A sampler selects a packet from sequential packets. You can specify a nonexistent sampler and then create it. For more information about samplers, see sampler configuration in Network Management and Monitoring Configuration Guide.
# Mirror original packets on HundredGigE 1/0/1 to the INT processor.
[Sysname-HundredGigE1/0/1] telemetry ifa 1 acl 3000 action mirror-to-processor sampler S1
telemetry ifa role
Use telemetry ifa device-id to specify a device ID for an INT node.
Use undo telemetry ifa device-id to restore the default.
telemetry ifa device-id address
An INT node does not have a device ID.
address: Specifies an IPv4 address as the device ID. You can specify any IPv4 address other than 0.0.0.0. As a best practice, specify the loopback address of the device as the device ID.
# Specify IPv4 address 10.1.1.10 as the device ID.
[Sysname] telemetry ifa device-id 10.1.1.10
telemetry ifa role
telemetry ifa global enable
Use telemetry ifa global enable to enable INT globally.
Use undo telemetry ifa global enable to disable INT globally.
INT is enabled globally.
# Enable INT globally.
[Sysname] telemetry ifa global enable
telemetry ifa role
telemetry ifa role
Use telemetry ifa role to specify an INT role for an interface.
Use undo telemetry ifa role to restore the default.
telemetry ifa role { egress | ingress | transit }
An interface does not take any INT role.
egress: Specifies the interface as an egress interface.
ingress: Specifies the interface as an ingress interface.
transit: Specifies the interface as a transit interface.
In an INT network, specify the interface on the entry node as the ingress interface. Specify the interface on the transit node as the transit interface. Specify the interface on the exit node as the egress interface.
Interfaces in different roles take different actions on incoming packets.
·     The ingress interface adds a timestamp and encapsulates the packet as an INT packet.
·     The transit interface adds a timestamp for the INT packet.
·     The egress interface adds a timestamp, encapsulates the INT packet according to the specified addressing parameters, and sends it to the collector.
This command is mutually exclusive with any command that is used to configure an INT action on one interface.
# Specify HundredGigE 1/0/1 as the transit interface.
[Sysname-HundredGigE1/0/1] telemetry ifa role transit
Use telemetry ifa collector to configure the addressing parameters to encapsulate in INT packets sent to the collector.
Use undo telemetry ifa collector to restore the default.
telemetry ifa collector source source-address destination dest-address source-port port destination-port port [ vlan vlan-id ]
No addressing parameters are configured for INT packets.
source source-address: Specifies the source IP address for INT packets.
destination dest-address: Specifies the destination IP address for INT packets.
source-port port: Specifies the source port number for INT packets.
destination-port port: Specifies the destination port number for INT packets.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
Use this command on the exit node. The exit node uses the addressing parameters to find the outgoing interface for INT packets and sends the packets to the collector.
Do not specify the IP address of the management Ethernet port on the local device for the destination dest-address option.
# Specify source IP address 1.1.1.1, destination IP address 2.2.2.2, source port number 67, and destination port number 68 for INT packets.
[Sysname] telemetry ifa collector source 1.1.1.1 destination 2.2.2.2 source-port 67 destination-port 68
telemetry ifa role
  • Become a Partner
  • Partner Resources
