- 10 Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Port security commands
- 06-Password control commands
- 07-Keychain commands
- 08-Public key management commands
- 09-PKI commands
- 10-IPsec commands
- 11-SSH commands
- 12-SSL commands
- 13-Attack detection and prevention commands
- 14-TCP attack prevention commands
- 15-IP source guard commands
- 16-ARP attack protection commands
- 17-ND attack defense commands
- 18-uRPF commands
- 19-MFF commands
- 20-FIPS commands
- 21-MACsec commands
- 22-802.1X client commands
- 23-Web authentication commands
- 24-Object group commands
| 15-IP source guard commands | 109.64 KB |
display ip verify source excluded
display ipv6 source binding pd
ip source binding (interface view)
ip source binding (system view)
ipv6 source binding (interface view)
ipv6 source binding (system view)
display ip source binding
Use display ip source binding to display IPv4SG bindings.
In standalone mode:
display ip source binding [ static | [ vpn-instance vpn-instance-name ] [ arp-snooping-vlan | arp-snooping-vsi | dhcp-relay | dhcp-server | dhcp-snooping | dot1x ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
display ip source binding [ static | [ vpn-instance vpn-instance-name ] [ arp-snooping-vlan | arp-snooping-vsi | dhcp-relay | dhcp-server | dhcp-snooping | dot1x ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
static: Displays static IPv4SG bindings.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display dynamic IPv4SG bindings for the public network, do not specify a VPN instance.
arp-snooping-vlan: Specifies IPv4SG bindings generated based on ARP snooping for VLANs.
arp-snooping-vsi: Specifies IPv4SG bindings generated based on ARP snooping for VSIs.
dhcp-relay: Specifies IPv4SG bindings generated based on DHCP relay agent.
dhcp-server: Specifies IPv4SG bindings generated based on DHCP server.
dhcp-snooping: Specifies IPv4SG bindings generated based on DHCP snooping.
dot1x: Specifies IPv4SG bindings generated based on 802.1X. To display dynamic IPv4SG bindings generated based on the 802.1X module, you must also specify the slot through which 802.1X users access the network.
ip-address ip-address: Specifies an IPv4 address.
mac-address mac-address: Specifies a MAC address in H-H-H format.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv4SG bindings for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv4SG bindings for the global active MPU. (In IRF mode.)
# Display all IPSG bindings on the public network.
<Sysname> display ip source binding
Total entries found: 5
IP Address MAC Address Interface VLAN Type
10.1.0.5 040a-0000-4000 XGE1/0/1 1 DHCP snooping
10.1.0.6 040a-0000-3000 XGE1/0/1 1 DHCP snooping
10.1.0.7 040a-0000-2000 XGE1/0/1 1 DHCP snooping
10.1.0.8 040a-0000-1000 XGE1/0/2 N/A DHCP relay
10.1.0.9 040a-0000-2000 XGE1/0/2 N/A Static
Total entries found |
Total number of IPv4SG bindings. |
IP Address |
IPv4 address in the IPv4SG binding. If no IP address is bound in the binding, this field displays N/A. |
MAC Address |
MAC address in the IPv4SG binding. If no MAC address is bound in the binding, this field displays N/A. |
Interface of the binding. This field displays N/A for a global IPv4SG binding. |
VLAN |
VLAN information in the IPv4SG binding. If the binding contains no VLAN information, this field displays N/A. |
Type |
IPSG binding type: · Static—Manually configured by using the ip source binding command. Static bindings are for packet filtering in IPSG or used by other modules to provide security services. · ARP snooping vlan—Dynamically generated based on ARP snooping for the VLAN. The binding is for packet filtering in IPSG. · ARP snooping vsi—Dynamically generated based on ARP snooping for the VSI. The binding is for packet filtering in IPSG. · 802.1X—Dynamically generated based on 802.1X. The binding is for packet filtering in IPSG. · DHCP relay—Dynamically generated based on DHCP relay agent. The binding is for packet filtering in IPSG. · DHCP server—Dynamically generated based on DHCP server. The binding is used by other modules to provide security services. · DHCP snooping—Dynamically generated based on DHCP snooping. The binding is for packet filtering in IPSG. |
ip source binding
ip verify source
Use display ip verify source excluded to display source items that have been configured to be excluded from IPSG filtering.
In standalone mode:
display ip verify source excluded [ vlan start-vlan-id [ to end-vlan-id ] ] [ slot slot-number ]
In IRF mode:
display ip verify source excluded [ vlan start-vlan-id [ to end-vlan-id ] ] [ chassis chassis-number slot slot-number ]
vlan start-vlan-id [ to end-vlan-id ]: Specifies VLANs that have been configured to be excluded from IPSG filtering. Value ranges for both the start-vlan-id and end-vlan-id arguments are 1 to 4094. The value for the end-vlan-id argument must be equal to or greater than the value for the start-vlan-id argument.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information for all cards. (In IRF mode.)
# Display all source items that have been configured to be excluded from IPSG filtering.
<Sysname> display ip verify source excluded
Slot:
Start VLAN ID End VLAN ID Status
1 20 Active
24 50 Active
200 300 Inactive
# Display VLANs (VLAN 3 and VLAN 5 through VLAN 10) that have been configured to be excluded from IPSG filtering.
<Sysname> display ip verify source excluded vlan 3
Slot:
VLAN ID: 3
Status: Active
<Sysname> display ip verify source excluded vlan 5 to 10
Slot:
5 10 Active
Start VLAN ID |
Start VLAN ID of the VLAN range that has been configured to be excluded from IPSG filtering. |
End VLAN ID |
End VLAN ID of the VLAN range that has been configured to be excluded from IPSG filtering. |
Status |
Whether the excluded VLAN configuration takes effect: · Active—The configuration takes effect. · Inactive—The configuration does not take effect. |
Use display ipv6 source binding to display IPv6SG address bindings.
In standalone mode:
display ipv6 source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcpv6-relay | dhcpv6-snooping | dot1x | nd-snooping-vlan | nd-snooping-vsi ] ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
display ipv6 source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcpv6-relay | dhcpv6-snooping | dot1x | nd-snooping-vlan | nd-snooping-vsi ] ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
static: Displays static IPv6SG address bindings.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display dynamic IPv6SG address bindings for the public network, do not specify a VPN instance.
dhcpv6-relay: Specifies IPv6SG bindings generated based on DHCPv6 relay agent.
dhcpv6-snooping: Specifies IPv6SG bindings generated based on DHCPv6 snooping.
dot1x: Specifies IPv6SG bindings generated based on 802.1X. To display dynamic IPv6SG address bindings generated based on the 802.1X module, you must also specify the slot through which 802.1X users access the network.
nd-snooping-vlan: Specifies IPv6SG bindings generated based on ND snooping for VLANs.
nd-snooping-vlan: Specifies IPv6SG bindings generated based on ND snooping for VSIs.
ip-address ipv6-address: Specifies an IPv6 address.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6SG address bindings for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6SG address bindings for the global active MPU. (In IRF mode.)
# Display all IPv6SG address bindings on the public network.
<Sysname> display ipv6 source binding
Total entries found: 2
IPv6 Address MAC Address Interface VLAN Type
2012:1222:2012:1222: 000f-2202-0435 XGE1/0/1 1 DHCPv6 snooping
2012:1222:2012:1222
2012:1222:2012:1222: 000f-2202-0436 XGE1/0/1 N/A Static
2012:1222:2012:1223
Total number of IPv6SG address bindings. |
IPv6 Address |
IPv6 address in the IPv6SG address binding. If no IPv6 address is bound in the binding, this field displays N/A. |
MAC Address |
MAC address in the IPv6SG address binding. If no MAC address is bound in the binding, this field displays N/A. |
Interface of the IPv6SG address binding. This field displays N/A for a global IPv6SG binding. |
VLAN |
VLAN information in the IPv6SG address binding. If the binding contains no VLAN information, this field displays N/A. |
Type |
Type of the IPv6SG address binding: · Static—Manually configured by using the ipv6 source binding command. Static bindings are for packet filtering in IPv6SG or used by other modules to provide security services. · DHCPv6 relay—Dynamically generated based on DHCPv6 relay agent. The binding is for packet filtering in IPv6SG. · DHCPv6 snooping—Dynamically generated based on DHCPv6 snooping. The binding is for packet filtering in IPv6SG. · 802.1X—Dynamically generated based on 802.1X. The binding is for packet filtering in IPv6SG. · ND snooping vlan—Dynamically generated based on ND snooping for the VLAN. The binding is for packet filtering in IPv6SG. · ND snooping vsi—Dynamically generated based on ND snooping for the VSI. The binding is for packet filtering in IPv6SG. |
ipv6 source binding
ipv6 verify source
Use display ipv6 source binding pd to display IPv6SG prefix bindings.
In standalone mode:
display ipv6 source binding pd [ vpn-instance vpn-instance-name ] [ prefix prefix/prefix-length ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
display ipv6 source binding pd [ vpn-instance vpn-instance-name ] [ prefix prefix/prefix-length ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
Any views
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display IPv6SG prefix bindings for the public network, do not specify a VPN instance.
prefix prefix/prefix-length: Specifies an IPv6 prefix. The value range for the prefix-length argument is 1 to 128. If you do not specify an IPv6 prefix, this command displays all IPv6SG prefix bindings.
mac-address mac-address: Specifies a MAC address in H-H-H format. If you do not specify a MAC address, this command displays IPv6SG prefix bindings for all MAC addresses.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays IPv6SG prefix bindings for all VLANs.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IPv6SG prefix bindings for all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6SG prefix bindings for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6SG prefix bindings for the global active MPU. (In IRF mode.)
IPv6SG prefix bindings are dynamically obtained from the DHCPv6 snooping module.
# Display all IPv6SG prefix bindings.
<Sysname> display ipv6 source binding pd
Total entries found: 3
IPv6 prefix MAC address Interface VLAN Type
2012:1111::/64 000f-2202-0435 XGE1/0/1 1 DHCPv6 snooping
2012:2222::/64 000f-2202-0436 XGE2/0/1 2 DHCPv6 snooping
Total number of IPv6SG prefix bindings. |
IPv6 prefix |
IPv6 prefix and prefix length in the IPv6SG prefix binding. |
MAC address |
MAC address in the IPv6SG prefix binding. This field displays N/A if the MAC address is invalid. |
Interface to which the IPv6SG prefix binding belongs. This field displays N/A for a global IPv6SG prefix binding. |
VLAN |
VLAN information in the IPv6SG prefix binding. This field displays N/A if the IPv6SG prefix binding does not contain the VLAN information. |
Type |
Type of the IPv6SG prefix binding: DHCPv6 snooping—The binding is generated based on a DHCPv6 snooping entry. |
ipv6 source binding
ipv6 verify source
Use ip source binding to configure a static IPv4SG binding on an interface.
Use undo ip source binding to delete the static IPv4SG bindings configured on an interface.
ip source binding { ip-address ip-address | ip-address ip-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
undo ip source binding { all | ip-address ip-address | ip-address ip-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
No static IPv4SG bindings exist on an interface.
VLAN interface view
all: Removes all static IPv4SG bindings on the interface.
ip-address ip-address: Specifies an IPv4 address for the static binding. The IPv4 address must be a class A, B, or C address, and cannot be 127.x.x.x or 0.0.0.0.
mac-address mac-address: Specifies a MAC address for the static binding. The MAC address must be in H-H-H format, and cannot be all 0s, all Fs (a broadcast MAC address), or a multicast MAC address.
vlan vlan-id: Specifies a VLAN ID for the static binding. The value range is 1 to 4094. This option is supported only in Layer 2 Ethernet interface view.
Static IPv4SG bindings on an interface implement the following functions:
· Filter incoming IPv4 packets on the interface.
· Check user validity by cooperating with the ARP attack detection feature.
You cannot configure static IPv4SG bindings on a service loopback interface.
# Configure a static IPv4SG binding on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] ip source binding ip-address 192.168.0.1 mac-address 0001-0001-0001
Use ip source binding to configure a global static IPv4SG binding.
Use undo ip source binding to delete one or all global static IPv4SG bindings.
undo ip source binding { all | ip-address ip-address mac-address mac-address }
No global static IPv4SG bindings exist.
ip-address ip-address: Specifies the IPv4 address for the static binding. The IPv4 address must be a class A, B, or C address, and cannot be 127.x.x.x or 0.0.0.0.
mac-address mac-address: Specifies the MAC address for the static binding. The MAC address is in the format H-H-H but cannot be all 0s, all Fs (a broadcast MAC address), or a multicast MAC address.
all: Removes all global static IPv4SG bindings.
A global static IPv4SG binding takes effect on all interfaces.
# Configure a global static IPv4SG binding.
[Sysname] ip source binding ip-address 192.168.0.1 mac-address 0001-0001-0001
ip verify source
Use ip verify source to enable IPv4SG on an interface.
Use undo ip verify source to disable IPv4SG on an interface.
The IPv4SG feature is disabled on an interface.
VLAN interface view
ip-address: Filters incoming packets by source IPv4 addresses.
ip-address mac-address: Filters incoming packets by source IPv4 addresses and source MAC addresses.
mac-address: Filters incoming packets by source MAC addresses.
After you enable IPv4SG on an interface, this feature uses static and dynamic IPv4SG bindings to match incoming packets on the interface. Packets that match an IPv4SG binding are forwarded and packets that do not match any IPv4SG binding are discarded.
The matching criterion specified by this command applies only to dynamic IPSG. Static IPv4SG uses static bindings configured by using the ip source binding command.
You cannot enable dynamic IPv4SG on a service loopback interface.
# Enable IPv4SG on Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/1 and verify the source IPv4 address and MAC address for dynamic IPSG.
[Sysname-Ten-GigabitEthernet1/0/1] ip verify source ip-address mac-address
# Enable IPv4SG on VLAN-interface 100 and verify the source IPv4 address and MAC address for dynamic IPSG.
[Sysname-Vlan-interface100] ip verify source ip-address mac-address
# Enable IPv4SG on Layer 3 Ethernet interface Ten-GigabitEthernet 1/0/2 and verify the source IPv4 address and MAC address for dynamic IPSG.
[Sysname-Ten-GigabitEthernet1/0/2] ip verify source ip-address mac-address
# Enable IPv4SG on Layer 3 Ethernet interface Ten-GigabitEthernet 1/0/2 and verify the source MAC address for dynamic IPSG.
[Sysname-Ten-GigabitEthernet1/0/2] ip verify source mac-address
Use ip verify source exclude to exclude IPv4 packets with the specified source items from IPSG filtering.
Use undo ip verify source exclude to remove the specified excluded source items.
ip verify source exclude vlan start-vlan-id [ to end-vlan-id ]
undo ip verify source exclude vlan start-vlan-id [ to end-vlan-id ]
No excluded source items are configured.
vlan start-vlan-id [ to end-vlan-id ]: Specifies excluded VLANs. Value ranges for both the start-vlan-id and end-vlan-id arguments are 1 to 4094. The value for the end-vlan-id argument must be equal to or greater than the value for the start-vlan-id argument. A single excluded VLAN is specified if you specify only the start-vlan-id argument or specify the same VLAN ID for the start-vlan-id and end-vlan-id arguments.
This command allows all IPv4 packets with the specified source items to be forwarded without being processed by IPSG.
You can execute this command multiple times to specify multiple excluded VLANs. The specified excluded VLANs cannot overlap.
To successfully delete excluded VLANs, make sure the VLANs specified in the undo form of this command are the same as the VLANs specified when you configure excluded VLANs.
# Exclude IPv4 packets from VLAN 3 and VLAN 5 through VLAN 10 from IPSG filtering.
[Sysname] ip verify source exclude vlan 3
[Sysname] ip verify source exclude vlan 5 to 10
Use ipv6 source binding to configure a static IPv6SG binding.
Use undo ipv6 source binding to delete the static IPv6SG bindings configured on an interface.
ipv6 source binding { ip-address ipv6-address | ip-address ipv6-address mac-address mac-address | mac-address mac-address }
undo ipv6 source binding { all | ip-address ipv6-address | ip-address ipv6-address mac-address mac-address | mac-address mac-address }
No static IPv6SG bindings exist on an interface.
VLAN interface view
all: Removes all the static IPv6SG bindings on the interface.
ip-address ipv6-address: Specifies an IPv6 address for the static binding. The IPv6 address cannot be an all-zero address, a multicast address, or a loopback address.
Static IPv6SG bindings on an interface filter incoming IPv6 packets, and check user validity by cooperating with the ND attack detection feature.
You cannot configure static IPv6SG bindings on a service loopback interface.
# Configure a static IPv6SG binding on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] ipv6 source binding ip-address 2001::1 mac-address 0002-0002-0002
Use ipv6 source binding to configure a global static IPv6SG binding.
Use undo ipv6 source binding to delete one or all global static IPv6SG bindings.
undo ipv6 source binding { all | ip-address ipv6-address mac-address mac-address }
No global static IPv6SG bindings exist.
ipv6-address ipv6-address: Specifies the IPv6 address for the static binding. The IPv6 address cannot be an all-zero address, a multicast address, or a loopback address.
mac-address mac-address: Specifies the MAC address for the static binding. The MAC address must be in H-H-H format, and cannot be all 0s, all Fs (a broadcast MAC address), or a multicast MAC address.
all: Removes all global static IPv6SG bindings.
A global static IPv6SG binding takes effect on all interfaces.
# Configure a global static IPv6SG binding.
[Sysname] ipv6 source binding ipv6-address 2001::1 mac-address 0002-0002-0002
ipv6 verify source
Use ipv6 verify source to enable IPv6SG on an interface.
Use undo ipv6 verify source to disable IPv6SG on an interface.
The IPv6SG feature is disabled on an interface.
VLAN interface view
ip-address: Filters incoming packets by source IPv6 addresses.
ip-address mac-address: Filters incoming packets by source IPv6 addresses and source MAC addresses.
After you enable IPv6SG on an interface, this feature uses static and dynamic IPv6SG bindings to match incoming packets on the interface. Packets that match an IPv6SG binding are forwarded and packets that do not match any IPv6SG binding are discarded.
The matching criterion specified by this command applies only to dynamic IPv6SG. Static IPv6SG uses static bindings configured by using the ipv6 source binding command.
You cannot enable dynamic IPv6SG on a service loopback interface.
# Enable IPv6SG on Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/1 and verify the source IPv6 address and MAC address for dynamic IPv6SG.
[Sysname-Ten-GigabitEthernet1/0/1] ipv6 verify source ip-address mac-address
