01-EVPN configuration | 905.33 KB |
Assignment of traffic to VXLANs
Traffic from the local site to a remote site
Traffic from a remote site to the local site
Centralized EVPN gateway deployment
Distributed EVPN gateway deployment
RD and route target selection of BGP EVPN routes
VXLAN tunnel configuration restrictions and guidelines
EVPN gateway configuration restrictions and guidelines
Configuring BGP to advertise BGP EVPN routes
Mapping a static Ethernet service instance to a VSI
Mapping dynamic Ethernet service instances to VSIs
Configuring a centralized EVPN gateway
Configuring a distributed EVPN gateway
Configuring an L3 VXLAN ID for a VSI interface
Configuring IP prefix route advertisement
Managing remote MAC address entries and remote ARP or ND learning
Disabling remote MAC address learning and remote ARP or ND learning
Disabling MAC address advertisement
Disabling learning of MAC addresses from ARP or ND information
Disabling ARP information advertisement
Enabling conversational learning for forwarding entries
Enabling conversational learning for remote MAC address entries
Enabling conversational learning for host route FIB entries
Enabling conversational learning for IPv6 host route FIB entries
Enabling BGP EVPN route advertisement to the local site
Enabling ARP flood suppression
Displaying and maintaining EVPN
Centralized IPv4 EVPN gateway configuration example
Distributed IPv4 EVPN gateway configuration example
Distributed IPv6 EVPN gateway configuration example
Private-public IPv4 network communication example
EVPN-DCI configuration task list
Enabling route nexthop replacement and route router MAC replacement
Configuring the BGP EVPN address family and the BGP VPNv4 or VPNv6 address family to exchange routes
Enabling BGP VPNv4 or VPNv6 route advertisement for the BGP EVPN address family
Enabling BGP EVPN route advertisement for the BGP VPNv4 or VPNv6 address family
Configuring EVPN-DCI dual-homing
EVPN-DCI configuration examples
Basic EVPN-DCI configuration example
EVPN-DCI intermediate VXLAN mapping configuration example
EVPN-DCI Layer 3 communication configuration example
EVPN overview
Ethernet Virtual Private Network (EVPN) is a Layer 2 VPN technology that provides both Layer 2 and Layer 3 connectivity between distant network sites across an IP network. EVPN uses MP-BGP in the control plane and VXLAN in the data plane. EVPN is typically used in data centers for multitenant services.
EVPN provides the following benefits:
· Configuration automation—MP-BGP automates VTEP discovery, VXLAN tunnel establishment, and VXLAN tunnel assignment to ease deployment.
· Separation of the control plane and the data plane—EVPN uses MP-BGP to advertise host reachability information in the control plane and uses VXLAN to forward traffic in the data plane.
· Integrated routing and bridging (IRB)—MP-BGP advertises both Layer 2 and Layer 3 host reachability information to provide optimal forwarding paths and minimize flooding.
EVPN network model
As shown in Figure 1, EVPN uses the VXLAN technology for traffic forwarding in the data plane. The transport edge devices assign user terminals to different VXLANs, and then forward traffic between sites for user terminals by using VXLAN tunnels. The transport edge devices are VXLAN tunnel endpoints (VTEPs).
A VTEP uses ESs, VSIs, and VXLAN tunnels to provide VXLAN services:
· Ethernet segment (ES)—An ES is a link that connects a site to a VTEP. Each ES is uniquely identified by an Ethernet segment identifier (ESI). A site can be connected to a VTEP through only one ES. The ES uses ESI 0.
· VSI—A virtual switch instance is a virtual Layer 2 switched domain. Each VSI provides switching services only for one VXLAN. VSIs learn MAC addresses and forward frames independently of one another. User terminals in different sites have Layer 2 connectivity if they are in the same VXLAN. A VXLAN is identified by a 24-bit VXLAN ID which is also called the virtual network identifier (VNI). A VXLAN corresponds to an EVPN instance.
· VXLAN tunnel—A VXLAN tunnel is a logical point-to-point tunnel between VTEPs over the transport network. Each VXLAN tunnel can trunk multiple VXLANs.
All VXLAN processing is performed on VTEPs. The ingress VTEP encapsulates VXLAN traffic in the VXLAN, outer UDP, and outer IP headers, and forwards the traffic through VXLAN tunnels. The egress VTEP removes the VXLAN encapsulation and forwards the traffic to the destination. Transport network devices (for example, the P device in Figure 1) forward VXLAN traffic only based on the outer IP header of VXLAN packets.
Layered transport network
As shown in Figure 2, typically the EVPN transport network uses a layered structure. On the transport network, leaf nodes act as VTEPs to provide VXLAN services, and spine nodes perform forwarding for VXLAN traffic based on the outer IP header. If all VTEPs and transport network devices of an EVPN network belong to the same AS, the spine nodes can act as route reflectors (RRs) to reflect routes between the VTEPs. In this scenario, the spine nodes advertise and receive BGP EVPN routes, but do not perform VXLAN encapsulation and de-encapsulation.
Figure 2 Layered transport network
MP-BGP extension for EVPN
To support EVPN, MP-BGP introduces the EVPN subsequent address family under the L2VPN address family and the following network layer reachability information (BGP EVPN routes):
· Ethernet auto-discovery route—Advertises ES information in multihomed sites.
· MAC/IP advertisement route—Advertises MAC reachability information and host route information (host ARP or ND information).
· Inclusive multicast Ethernet tag (IMET) route—Advertises VTEP and VXLAN mappings for automating VTEP discovery, VXLAN tunnel establishment, and VXLAN tunnel assignment.
· Ethernet segment route—Advertises ES and VTEP mappings.
· IP prefix advertisement route—Advertises BGP IPv4 or IPv6 unicast routes as IP prefixes.
The current software version does not support Ethernet auto-discovery routes and ES routes.
MP-BGP uses the route distinguisher (RD) field to differentiate BGP EVPN routes of different VXLANs and uses route targets to control the advertisement and acceptance of BGP EVPN routes. MP-BGP supports the following types of route targets:
· Export targets—A VTEP sets the export targets for BGP EVPN routes learned from the local site before advertising them to remote VTEPs.
· Import targets—A VTEP checks the export targets of BGP EVPN routes received from remote VTEPs. The VTEP imports the BGP EVPN routes only when their export targets match the local import targets.
VTEPs use BGP EVPN routes to discover VTEP neighbors, establish VXLAN tunnels, and assign the tunnels to VXLANs.
· IMET route—VTEPs advertise their VXLAN IDs through IMET routes. If two VTEPs have the same VXLAN ID, they automatically establish a VXLAN tunnel and assign the tunnel to the VXLAN.
· MAC/IP advertisement route and IP prefix advertisement route—In the EVPN gateway deployment, VTEPs advertise MAC/IP advertisement routes or IP prefix advertisement routes which carry export targets. When a VTEP receives a route, it compares the export targets of the route with the local import targets. If the route targets match, the VTEP establishes a VXLAN tunnel with the remote VTEP and associates the tunnel with the L3 VXLAN ID of the corresponding VPN instance. For more information about the L3 VXLAN ID, see "Distributed EVPN gateway deployment."
The VTEP uses an Ethernet service instance to match customer traffic on a site-facing interface. The VTEP assigns customer traffic to a VXLAN by mapping the Ethernet service instance to a VSI.
An Ethernet service instance is identical to an attachment circuit (AC) in L2VPN. An Ethernet service instance matches a list of VLANs on a Layer 2 Ethernet interface by using a frame match criterion. The frame match criterion specifies the characteristics of traffic from the VLANs, such as tagging status and VLAN IDs.
As shown in Figure 3, Ethernet service instance 1 matches VLAN 2 and is mapped to VSI A (VXLAN 10). When a frame from VLAN 2 arrives, the VTEP assigns the frame to VXLAN 10 and looks up VSI A's MAC address table for the outgoing interface.
Figure 3 Identifying traffic from the local site
When a VXLAN packet arrives at a VXLAN tunnel interface, the VTEP uses the VXLAN ID in the packet to identify its VXLAN.
Layer 2 forwarding
MAC learning
The VTEP performs Layer 2 forwarding based on a VSI's MAC address table. The VTEP learns MAC addresses by using the following methods:
· Local MAC learning—The VTEP automatically learns the source MAC addresses of frames sent from the local site. The outgoing interfaces of local MAC address entries are site-facing interfaces on which the MAC addresses are learned.
· Remote MAC learning—The VTEP uses MP-BGP to advertise local MAC reachability information to remote sites and learn MAC reachability information from remote sites. The outgoing interfaces of MAC address entries advertised from a remote site are VXLAN tunnel interfaces.
Unicast
As shown in Figure 4, the VTEP performs typical Layer 2 forwarding for known unicast traffic within the local site.
As shown in Figure 5, the following process applies to a known unicast frame between sites:
1. The source VTEP encapsulates the Ethernet frame in the VXLAN/UDP/IP header.
In the outer IP header, the source IP address is the source VTEP's VXLAN tunnel source IP address. The destination IP address is the VXLAN tunnel destination IP address.
2. The source VTEP forwards the encapsulated packet out of the outgoing VXLAN tunnel interface found in the VSI's MAC address table.
3. The intermediate transport devices (P devices) forward the packet to the destination VTEP by using the outer IP header.
4. The destination VTEP removes the headers on top of the inner Ethernet frame. It then performs MAC address table lookup in the VXLAN's VSI to forward the frame out of the matching outgoing interface.
Flood
As shown in Figure 6, a VTEP floods a broadcast, multicast, or unknown unicast frame to all site-facing interfaces and VXLAN tunnels in the VXLAN, except for the incoming interface. The source VTEP replicates the flood frame, and then sends one replica to the destination IP address of each VXLAN tunnel in the VXLAN. Each destination VTEP floods the inner Ethernet frame to all the site-facing interfaces in the VXLAN. To avoid loops, the destination VTEPs do not flood the frame to VXLAN tunnels.
Figure 6 Forwarding of flood traffic
Layer 3 forwarding
EVPN uses EVPN gateways to provide Layer 3 forwarding services for hosts in VXLANs. EVPN provides the following EVPN gateway placement designs:
· Centralized EVPN gateway deployment—Uses one VTEP to provide Layer 3 forwarding for VXLANs. Typically, the gateway-collocated VTEP connects to other VTEPs and the external network. To use this design, make sure the gateway has sufficient bandwidth and processing capability.
· Distributed EVPN gateway deployment—Deploys one EVPN gateway on each VTEP to provide Layer 3 forwarding for VXLANs at their respective sites. This design distributes the Layer 3 traffic load across VTEPs. However, its configuration is more complex than the centralized EVPN gateway design.
In either design, the gateways use virtual Layer 3 VSI interfaces as gateway interfaces for VXLANs.
NOTE: A centralized EVPN gateway can provide services only for IPv4 sites. A distributed EVPN gateway can provide services for both IPv4 sites and IPv6 sites. This section uses IPv4 sites as examples to describe the Layer 3 forwarding process of EVPN networks. |
As shown in Figure 7, a VTEP acts as a gateway for user terminals in the VXLANs. The VTEP both terminates the VXLANs and performs Layer 3 forwarding for the user terminals. The network uses the following process to forward Layer 3 traffic from a user terminal to the destination:
1. The user terminal sends an ARP request to obtain the MAC address of the VSI interface that acts as the gateway, and then sends the Layer 3 traffic to the centralized EVPN gateway.
2. The local VTEP looks up the matching VSI's MAC address table and forwards the traffic to the centralized EVPN gateway through a VXLAN tunnel.
3. The centralized EVPN gateway removes the VXLAN encapsulation and forwards the traffic at Layer 3.
4. The centralized EVPN gateway forwards the replies sent by the destination node to the user terminal based on the ARP entry for the user terminal.
Figure 7 Example of centralized EVPN gateway deployment
As shown in Figure 8, each site's VTEP acts as a gateway to perform Layer 3 forwarding for the VXLANs of the local site. A VTEP acts as a border gateway to the Layer 3 network for the VXLANs.
Figure 8 Distributed EVPN gateway placement design
Symmetric IRB
A distributed EVPN gateway uses symmetric IRB for Layer 3 forwarding, which means both the ingress and egress gateways perform Layer 2 and Layer 3 lookups. Symmetric IRB introduces the following concepts:
· L3 VXLAN ID—Also called L3 VNI. An L3 VXLAN ID identifies the traffic of a routing domain where devices have Layer 3 reachability. An L3 VXLAN ID is associated with one VPN instance. Distributed EVPN gateways use VPN instances to isolate traffic of different services on VXLAN tunnel interfaces.
· Router MAC address—Each distributed EVPN gateway has a unique router MAC address used for inter-gateway forwarding. The MAC addresses in the inner Ethernet header of VXLAN packets are router MAC addresses of distributed EVPN gateways.
VSI interfaces
As shown in Figure 9, each distributed EVPN gateway has the following types of VSI interfaces:
· VSI interface as a gateway interface of a VXLAN—The VSI interface acts as the gateway interface for user terminals in a VXLAN. The VSI interface is associated with a VSI and a VPN instance. On different distributed EVPN gateways, the VSI interface of a VXLAN uses the same IP address to provide services.
· VSI interface associated with an L3 VXLAN ID—The VSI interface is associated with a VPN instance and assigned an L3 VXLAN ID. VSI interfaces associated with the same VPN instance share an L3 VXLAN ID.
A border gateway only has VSI interfaces that are associated with an L3 VXLAN ID.
Figure 9 Example of distributed EVPN gateway deployment
Layer 3 forwarding entry learning
A distributed EVPN gateway forwards Layer 3 traffic based on FIB entries generated from BGP EVPN routes and ARP information.
A VTEP advertises an external route imported in the EVPN address family through MP-BGP. A remote VTEP adds the route to the FIB table of a VPN instance based on the L3 VXLAN ID carried in the route. In the FIB entry, the outgoing interface is the VXLAN tunnel interface where the route is received, and the next hop is the peer VTEP address in the NEXT_HOP attribute of the route.
A VTEP has the following types of ARP information:
· Local ARP information—ARP information of user terminals in the local site. The VTEP snoops GARP packets, RARP packets, and ARP requests for the gateway MAC address to learn the ARP information of the senders and generates ARP entries and FIB entries. In an ARP or FIB entry, the outgoing interface is the site-facing interface where the packet is received, and the VPN instance is the instance associated with the corresponding VSI interface.
· Remote ARP information—ARP information of user terminals in remote sites. Each VTEP uses MP-BGP to advertise its local ARP information with L3 VXLAN IDs in routes to remote sites. A VTEP generates only FIB entries for the remote ARP information. A FIB entry contains the following information:
? Outgoing interface: VSI interface associated with the L3 VXLAN ID.
? Next hop: Peer VTEP address in the NEXT_HOP attribute of the route.
? VPN instance: VPN instance associated with the L3 VXLAN ID.
The VTEP then creates an ARP entry for the next hop in the FIB entry.
Traffic forwarding
For more information about MAC address table-based Layer 2 forwarding, see "Unicast."
Figure 10 shows the intra-site Layer 3 forwarding process.
1. The source terminal sends an ARP request to obtain the MAC address of the destination terminal.
2. The gateway replies to the source terminal with the MAC address of the VSI interface associated with the source terminal's VSI.
3. The source terminal sends a Layer 3 packet to the gateway.
4. The gateway looks up the FIB table of the VPN instance associated with the source terminal's VSI and finds the matching outgoing site-facing interface.
5. The gateway processes the Ethernet header of the Layer 3 packet as follows:
? Replaces the destination MAC address with the destination terminal's MAC address.
? Replaces the source MAC address with the VSI interface's MAC address.
6. The gateway forwards the Layer 3 packet to the destination terminal.
Figure 10 Intra-site Layer 3 forwarding
Figure 11 shows the inter-site Layer 3 forwarding process.
4. The gateway looks up the FIB table of the VPN instance associated with the source terminal's VSI and finds the matching outgoing VSI interface.
? Replaces the destination MAC address with the destination gateway's router MAC address.
? Replaces the source MAC address with its own router MAC address.
6. The gateway adds VXLAN encapsulation to the Layer 3 packet and forwards the packet to the destination gateway. The encapsulated VXLAN ID is the L3 VXLAN ID of the corresponding VPN instance.
7. The destination gateway identifies the VPN instance of the packet based on the L3 VXLAN ID and removes the VXLAN encapsulation. Then the gateway forwards the packet based on the matching ARP entry.
Figure 11 Inter-site Layer 3 forwarding
Communication between private and public networks
A distributed EVPN gateway uses the public instance to perform Layer 3 forwarding for the public network and to enable communication between private and public networks. The public instance is similar to a VPN instance. A distributed EVPN gateway processes traffic of the public instance in the same way it does for a VPN instance. For the public instance to work correctly, you must configure an RD, an L3 VXLAN ID, and route targets for it. If a VSI interface is not associated with any VPN instance, the VSI interface belongs to the public instance.
As shown in Table 1, you can configure RDs and route targets for BGP EVPN routes in multiple views.
Table 1 Supported views for RD and route target configuration
Item |
Views |
RD |
· EVPN instance view of a VSI · VPN instance view · Public instance view |
Route targets |
· EVPN instance view of a VSI · VPN instance view · IPv4 VPN view of a VPN instance · IPv6 VPN view of a VPN instance · EVPN view of a VPN instance · IPv4 VPN view of the public instance · IPv6 VPN view of the public instance · EVPN view of the public instance NOTE: Route targets configured in VPN instance view apply to IPv4 VPN, IPv6 VPN, and EVPN. Route targets configured in IPv4 VPN view apply only to IPv4 VPN. Route targets configured in IPv6 VPN view apply only to IPv6 VPN. Route targets configured in EVPN view of a VPN instance apply only to EVPN. Route targets configured in IPv4 VPN view, IPv6 VPN view, or EVPN view of a VPN instance take precedence over those in VPN instance view. |
The device selects RDs and route targets for BGP EVPN routes by using the following rules:
· IMET routes and MAC/IP advertisement routes that contain only MAC addresses—The device uses the RD and route targets configured in EVPN instance view when advertising and accepting the routes.
· MAC/IP advertisement routes that contain ARP or ND information—The device uses the following settings when advertising the routes:
? RD and export route targets configured in EVPN instance view.
? Export route targets configured for EVPN on a VPN instance or the public instance (VPN instance view, and EVPN view of a VPN instance or the public instance).
The device uses the import route targets configured for EVPN on a VPN instance or the public instance when accepting the routes.
· IP prefix advertisement routes—The device uses the route targets configured for IPv4 or IPv6 VPN on a VPN instance or the public instance (VPN instance view, and IPv4 or IPv6 VPN view of a VPN instance or the public instance) when advertising and accepting the routes.
ARP flood suppression reduces ARP request broadcasts by enabling the VTEP to reply to ARP requests on behalf of user terminals.
As shown in Figure 12, this feature snoops ARP requests, ARP responses, and BGP EVPN routes to populate the ARP flood suppression table with local and remote MAC addresses. If an ARP request has a matching entry, the VTEP replies to the request on behalf of the user terminal. If no match is found, the VTEP floods the request to both local and remote sites.
Figure 12 ARP flood suppression
ARP flood suppression uses the following workflow:
1. Terminal 1 sends an ARP request to obtain the MAC address of Terminal 7.
2. VTEP 1 creates a suppression entry for Terminal 1, floods the ARP request in the VXLAN, and sends the suppression entry to VTEP 2 and VTEP 3 through BGP EVPN.
3. VTEP 2 and VTEP 3 de-encapsulate the ARP request and broadcast the request in the local site.
4. Terminal 7 sends an ARP reply.
5. VTEP 2 creates a suppression entry for Terminal 7, forwards the ARP reply to VTEP 1, and sends the suppression entry to VTEP 1 and VTEP 3 through BGP EVPN.
6. VTEP 1 de-encapsulates the ARP reply and forwards the ARP reply to Terminal 1.
7. Terminal 4 sends an ARP request to obtain the MAC address of Terminal 1.
8. VTEP 1 creates a suppression entry for Terminal 4 and replies to the ARP request.
9. Terminal 10 sends an ARP request to obtain the MAC address of Terminal 1.
10. VTEP 3 creates a suppression entry for Terminal 10 and replies to the ARP request.
MAC mobility
MAC mobility refers to the movement of a user terminal from one ES to another. The source VTEP is unaware of the MAC move event. To notify other VTEPs of the change, the destination VTEP advertises a MAC/IP advertisement route for the MAC address. The source VTEP withdraws the old route for the MAC address after receiving the new route. The MAC/IP advertisement route has a sequence number that increases when the MAC address moves. The sequence number identifies the most recent move if the MAC address moves multiple times.
Configuring EVPN
Make sure the following VXLAN tunnels are not associated with the same VXLAN when they have the same tunnel destination IP address:
· A VXLAN tunnel automatically created by EVPN.
· A manually created VXLAN tunnel.
For more information about manual tunnel configuration, see VXLAN Configuration Guide.
For information about hardware compatibility, feature restrictions, and hardware restrictions of site-facing interfaces of EVPN gateways, see VXLAN Configuration Guide.
EVPN configuration task list
Tasks at a glance |
Remarks |
(Required) Creating a VXLAN on a VSI |
N/A |
(Required) Configuring an EVPN instance |
N/A |
(Required) Configuring BGP to advertise BGP EVPN routes |
N/A |
(Required) Mapping ACs to a VSI |
Perform this task to assign customer traffic to VXLANs. |
(Optional.) Configuring an EVPN gateway: |
Perform this task to provide Layer 3 connectivity for VXLANs. |
(Optional.) Managing remote MAC address entries and remote ARP or ND learning |
N/A |
(Optional.) Enabling conversational learning for forwarding entries |
N/A |
(Optional.) Enabling BGP EVPN route advertisement to the local site |
Perform this task to advertise private BGP EVPN routes to the local site. |
(Optional.) Disabling flooding for a VSI |
Perform this task to reduce flooding to the transport network. |
(Optional.) Enabling ARP flood suppression |
Perform this task to reduce ARP request broadcasts. |
For more information about the VXLAN commands in this task, see VXLAN Command Reference.
To create a VXLAN on a VSI:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable L2VPN. |
l2vpn enable |
By default, L2VPN is disabled. |
3. Create a VSI and enter VSI view. |
vsi vsi-name |
By default, no VSIs exist. |
4. (Optional.) Configure a VSI description. |
description text |
By default, a VSI does not have a description. |
5. Enable the VSI. |
undo shutdown |
By default, a VSI is enabled. |
6. (Optional.) Set the MTU for the VSI. |
mtu size |
The default MTU is 1500 bytes for a VSI. |
7. (Optional.) Enable MAC address learning for the VSI. |
mac-learning enable |
By default, MAC address learning is enabled for a VSI. |
8. Create a VXLAN and enter VXLAN view. |
vxlan vxlan-id |
By default, no VXLANs exist. You can create only one VXLAN on a VSI. The VXLAN ID must be unique for each VSI. |
You do not need to associate a VPN instance with a VXLAN that requires only Layer 2 connectivity. The BGP EVPN routes advertised by the device carry the RD and route targets configured for the EVPN instance associated with the VXLAN.
To configure an EVPN instance:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter VSI view. |
vsi vsi-name |
N/A |
3. Create an EVPN instance and enter EVPN instance view. |
evpn encapsulation vxlan |
By default, no EVPN instance exists. |
4. Configure an RD for the EVPN instance. |
route-distinguisher { route-distinguisher | auto } |
By default, no RD is configured for an EVPN instance. |
5. Configure route targets for the EVPN instance. |
vpn-target { vpn-target&<1-8> | auto } [ both | export-extcommunity | import-extcommunity ] |
By default, an EVPN instance does not have route targets. Make sure the following requirements are met: · The import targets of the EVPN instance do not match the export targets of the VPN instance associated with the VXLAN or the public instance. · The export targets of the EVPN instance do not match the import targets of the VPN instance associated with the VXLAN or the public instance. For more information about VPN instance and public instance configuration, see "Configuring an L3 VXLAN ID for a VSI interface." |
For more information about the following BGP commands, see Layer 3—IP Routing Command Reference:
· peer allow-as-loop
· peer as-number
· peer enable
· peer reflect-client
· reflect between-clients
· reflector cluster-id
· refresh bgp
· reset bgp
To configure BGP to advertise BGP EVPN routes:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure a global router ID. |
router id router-id |
By default, no global router ID is configured. |
3. Enable a BGP instance and enter BGP instance view. |
bgp as-number [ instance instance-name ] [ multi-session-thread ] |
By default, BGP is disabled and no BGP instances exist. |
4. Specify remote VTEPs as BGP peers. |
peer { group-name | ipv4-address [ mask-length ] } as-number as-number |
By default, no BGP peers are specified. |
5. Create the BGP EVPN address family and enter BGP EVPN address family view. |
address-family l2vpn evpn |
By default, the BGP EVPN address family does not exist. |
6. Enable BGP to exchange BGP EVPN routes with a peer or peer group. |
peer { group-name | ipv4-address [ mask-length ] } enable |
By default, BGP does not exchange BGP EVPN routes with peers. |
7. (Optional.) Permit the local AS number to appear in routes from a peer or peer group and set the number of appearances. |
peer { group-name | ipv4-address [ mask-length ] } allow-as-loop [ number ] |
By default, the local AS number is not allowed in routes from peers. |
8. (Optional.) Enable route target filtering for BGP EVPN routes. |
policy vpn-target |
By default, route target filtering is enabled for BGP EVPN routes. |
9. (Optional.) Configure the device as an RR and specify a peer or peer group as its client. |
peer { group-name | ipv4-address [ mask-length ] } reflect-client |
By default, no RR or client is configured. |
10. (Optional.) Enable BGP EVPN route reflection between clients. |
reflect between-clients |
By default, BGP EVPN route reflection between clients is enabled. |
11. (Optional.) Configure the cluster ID of the RR. |
reflector cluster-id { cluster-id | ipv4-address } |
By default, an RR uses its own router ID as the cluster ID. |
12. (Optional.) Create a reflection policy for the RR to filter reflected BGP EVPN routes. |
rr-filter ext-comm-list-number |
By default, an RR does not filter reflected BGP EVPN routes. |
13. (Optional.) Configure the device to not change the next hop of routes advertised to an EBGP peer or peer group. |
peer { group-name | ipv4-address [ mask-length ] } next-hop-invariable |
By default, the device uses its address as the next hop of routes advertised to EBGP peers. |
14. (Optional.) Apply a routing policy to routes received from or advertised to a peer or peer group. |
peer { group-name | ipv4-address [ mask-length ] } route-policy route-policy-name { export | import } |
By default, no routing policies are applied to routes received from or advertised to peers. |
15. (Optional.) Advertise the COMMUNITY attribute to a peer or peer group. |
peer { group-name | ipv4-address [ mask-length ] } advertise-community |
By default, the device does not advertise the COMMUNITY attribute to peers. |
16. (Optional.) Return to user view. |
return |
N/A |
17. (Optional.) Soft-reset BGP sessions of the BGP EVPN address family. |
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } l2vpn evpn |
N/A |
18. (Optional.) Reset BGP sessions of the BGP EVPN address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } l2vpn evpn |
N/A |
Overview
A static Ethernet service instance matches a list of VLANs on a site-facing interface by using a frame match criterion. The VTEP assigns traffic from the VLANs to a VXLAN by mapping the static Ethernet service instance to a VSI. The VSI performs Layer 2 forwarding for the VLANs based on its MAC address table.
For a VSI that uses Ethernet access mode, you can manipulate the VLAN tags of incoming and outgoing traffic in its Ethernet service instance. The VLAN tag processing rules include adding VLAN tags, replacing VLAN tags, and removing VLAN tags. For information about the restrictions and guidelines for configuring VLAN tag processing rules, see the rewrite inbound tag and rewrite outbound tag commands in VXLAN Command Reference.
For information about the restrictions and guidelines, see mapping customer frames to a VSI in VXLAN Configuration Guide. For more information about the VXLAN commands in this task, see VXLAN Command Reference.
Configuration procedure
To map a static Ethernet service instance to a VSI:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view. |
· interface interface-type interface-number · interface bridge-aggregation interface-number |
N/A |
3. Assign the Layer 2 interface to a local-site VLAN. |
a
Set the port link type. b
Use one of the following commands to assign
the interface to a local-site VLAN: |
The default link type is access. Make sure the VLAN has been created on the VTEP. |
4. Create an Ethernet service instance and enter Ethernet service instance view. |
service-instance instance-id |
By default, no Ethernet service instances exist. |
5. Configure a frame match criterion. |
Match frames that do not match any other
service instance on the interface: ·
Match any 802.1Q tagged or untagged frames: ·
Match frames tagged with the specified inner
802.1Q VLAN IDs: ·
Match frames tagged with the specified outer
802.1Q VLAN IDs: ·
and inner 802.1Q VLAN IDs: |
By default, an Ethernet service instance does not contain a frame match criterion. |
6. (Optional.) Configure the VLAN tag processing rule for incoming traffic. |
rewrite inbound tag { nest { c-vid vlan-id | s-vid vlan-id [ c-vid vlan-id ] } | remark { { 1-to-1 | 2-to-1 } { c-vid vlan-id | s-vid vlan-id } | { 1-to-2 | 2-to-2 } s-vid vlan-id c-vid vlan-id } | strip { c-vid | s-vid [ c-vid ] } } [ symmetric ] |
By default, VLAN tags of incoming traffic are not processed. |
7. (Optional.) Configure the VLAN tag processing rule for outgoing traffic. |
rewrite outbound tag { nest { c-vid vlan-id | s-vid vlan-id [ c-vid vlan-id ] } | remark { { 1-to-1 | 2-to-1 } { c-vid vlan-id | s-vid vlan-id } | { 1-to-2 | 2-to-2 } s-vid vlan-id c-vid vlan-id } | strip { c-vid | s-vid [ c-vid ] } } |
By default, VLAN tags of outgoing traffic are not processed. |
8. Map the Ethernet service instance to a VSI. |
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-3> ] |
By default, an Ethernet service instance is not mapped to any VSI. |
Overview
The 802.1X or MAC authentication feature can use the authorization VSI, the guest VSI, the Auth-Fail VSI, and the critical VSI to control the access of users to network resources. When assigning a user to a VSI, 802.1X or MAC authentication sends the VXLAN feature the VSI information and the user's access information, including access interface, VLAN, and MAC address. Then the VXLAN feature creates a dynamic Ethernet service instance for the user and maps it to the VSI. For more information about 802.1X authentication and MAC authentication, see Security Configuration Guide.
A dynamic Ethernet service instance supports the MAC-based traffic match mode that matches frames by source MAC address.
To use MAC-based traffic match mode for dynamic Ethernet service instances, you must enable MAC authentication or 802.1X authentication that uses MAC-based access control.
To use dynamic Ethernet service instances, follow these restrictions and guidelines:
· The site-facing interfaces must be on the following modules:
? FD interface modules.
? FE interface modules.
? SF interface module LSUM1CQGS32SF0.
? SG interface modules.
· If two users in different VLANs use the same MAC address, they cannot access VXLANs simultaneously through an interface configured with the mac-based ac command.
· The link type of site-facing interfaces must be access or trunk.
· A site-facing interface can forward only untagged packets if it receives packets that do not carry tags or packets that carry the VLAN tag of the PVID.
· A dynamic Ethernet service instance supports only the frame match criterion configured by using the encapsulation s-vid vlan-id [ only-tagged ] command.
· Packets with the same source MAC address can match only one dynamic Ethernet service instance on an interface.
· Dynamic Ethernet service instances cannot be created on member ports of a Layer 2 aggregation group.
The device automatically creates a dynamic Ethernet service instance for an 802.1X or MAC authentication user and maps the Ethernet service instance to a VSI in the following conditions:
· The user is assigned to the guest VSI, Auth-Fail VSI, or critical VSI configured on the device.
· A remote AAA server issues an authorization VSI to the user.
For a dynamic Ethernet service instance to match traffic by the source MAC address, enable MAC-based traffic match mode for the dynamic Ethernet service instance.
To enable MAC-based traffic match mode for dynamic Ethernet service instances on an interface:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable MAC-based traffic match mode for dynamic Ethernet service instances on the interface. |
mac-based ac |
By default, MAC-based traffic match mode is disabled for dynamic Ethernet service instances. For more information about this command, see VXLAN Command Reference. |
If an EVPN network contains a centralized EVPN gateway, you must enable ARP flood suppression on VTEPs. Typically remote ARP learning is disabled in an EVPN network. When ARP requests for the gateway MAC address are sent to the centralized EVPN gateway through VXLAN tunnels, the gateway does not respond to the requests. If ARP flood suppression is disabled on VTEPs, user terminals cannot obtain the MAC address of the gateway.
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a VSI interface and enter VSI interface view. |
interface vsi-interface vsi-interface-id |
By default, no VSI interfaces exist. For more information about this command, see VXLAN Command Reference. |
3. Assign an IPv4 or IPv6 address to the VSI interface. |
Assign an IPv4 address: ·
Assign an IPv6 address: |
By default, no IPv4 or IPv6 address is assigned to a VSI interface. |
4. Return to system view. |
quit |
N/A |
5. Enter VSI view. |
vsi vsi-name |
N/A |
6. Specify the VSI interface as the gateway interface for the VSI. |
gateway vsi-interface vsi-interface-id |
By default, no gateway interface is specified for a VSI. For more information about this command, see VXLAN Command Reference. |
IPv4 or IPv6 addresses of remote ARP or ND entries cannot be pinged by the distributed VXLAN IP gateway that learns the ARP or ND entries.
If both ARP flood suppression and local proxy ARP are enabled on a distributed EVPN gateway, only local proxy ARP takes effect. As a best practice, do not use these features together on distributed EVPN gateways.
Configuration prerequisites
For a VXLAN to access the external network, specify the VXLAN's VSI interface on the border gateway as the next hop on distributed EVPN gateways by using one of the following methods:
· Configure a static route.
· Configure a PBR policy, and apply the policy by using the apply default-next-hop or apply next-hop command. For more information about configuring PBR policies, see PBR configuration in Layer 3—IP Routing Configuration Guide.
Configuring a VSI interface
Step |
Command |
Remarks |
system-view |
N/A |
By default, no IPv4 or IPv6 address is assigned to a VSI interface. You can assign multiple IP addresses to a VSI interface for VSIs to share one gateway interface. |
4. Assign a MAC address to the VSI interface. |
mac-address mac-address |
By default, the MAC address of VSI interfaces is the bridge MAC address + 1. To ensure correct forwarding after VM migration, you must assign the same MAC address to the VSI interfaces of a VXLAN on all distributed gateways. |
5. Specify the VSI interface as a distributed gateway. |
distributed-gateway local |
By default, a VSI interface is not a distributed gateway. For more information about this command, see VXLAN Command Reference. |
6. (Optional.) Enable local proxy ARP or local ND proxy. |
Enable local proxy ARP on an IPv4 gateway: ·
Enable local ND proxy on an IPv6 gateway: |
By default, local proxy ARP and local ND proxy are disabled. For more information about the commands, see Layer 3—IP Services Command Reference. |
7. Return to system view. |
quit |
N/A |
8. Enter VSI view. |
vsi vsi-name |
N/A |
9. Specify the VSI interface as the gateway interface for the VSI. |
10. Assign a subnet to the VSI. |
gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length } |
By default, no subnet exists on a VSI. You must configure this command on VSIs that share a gateway interface. This command enables the VSI interface to identify the VSI of a packet. For VSIs that share a gateway interface, the subnets must be unique. For more information about this command, see VXLAN Command Reference. |
Configuring an L3 VXLAN ID for the VSI interface of a VPN instance
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a VPN instance and enter VPN instance view. |
ip vpn-instance vpn-instance-name |
By default, no VPN instances exist. |
3. Configure an RD for the VPN instance. |
route-distinguisher route-distinguisher |
By default, no RD is configured for a VPN instance. |
4. (Optional.) Configure route targets for the VPN instance. |
vpn-target { vpn-target&<1-8> [ both | export-extcommunity | import-extcommunity ] | auto } |
By default, a VPN instance does not have route targets. |
5. (Optional.) Apply an export routing policy to the VPN instance. |
export route-policy route-policy |
By default, no export routing policy is applied to a VPN instance. |
6. Enter EVPN view of the VPN instance. |
address-family evpn |
N/A |
7. Configure route targets for EVPN on the VPN instance. |
vpn-target vpn-target&<1-8> [ both | export-extcommunity | import-extcommunity ] |
By default, EVPN does not have route targets on a VPN instance. Make sure the following requirements are met: · The import targets of EVPN do not match the export targets of the VPN instance. · The export targets of EVPN do not match the import targets of the VPN instance. |
8. (Optional.) Apply an export routing policy to EVPN on the VPN instance. |
By default, no export routing policy is applied to EVPN on a VPN instance. |
9. (Optional.) Apply an import routing policy to EVPN on the VPN instance. |
import route-policy route-policy |
By default, no import routing policy is applied to EVPN on a VPN instance. The VPN instance accepts a route when the export route targets of the route match local import route targets. |
10. Return to VPN instance view. |
quit |
N/A |
11. Return to system view. |
quit |
N/A |
12. Create a VSI interface and enter VSI interface view. |
By default, no VSI interfaces exist. |
13. Associate the VSI interface with the VPN instance. |
ip binding vpn-instance vpn-instance-name |
By default, a VSI interface is not associated with a VPN instance. The interface is on the public network. |
14. Configure an L3 VXLAN ID for the VSI interface. |
l3-vni vxlan-id |
By default, no L3 VXLAN ID is configured for a VSI interface. A VPN instance can have only one L3 VXLAN ID. If multiple L3 VXLAN IDs are configured for a VPN instance, the VPN instance uses the lowest one. To view the L3 VXLAN ID of a VPN instance, use the display evpn routing-table command. |
Configuring an L3 VXLAN ID for the VSI interface of the public instance
Step |
Command |
Remarks |
system-view |
N/A |
2. Create the public instance and enter its view. |
ip public-instance |
By default, the public instance does not exist. |
3. Configure an RD for the public instance. |
By default, no RD is configured for the public instance. |
4. Configure an L3 VXLAN ID for the public instance. |
l3-vni vxlan-id |
By default, the public instance does not have an L3 VXLAN ID. The public instance can have only one L3 VXLAN ID. To modify the L3 VXLAN ID for the public instance, you must first delete the original L3 VXLAN ID. |
5. (Optional.) Configure route targets for the public instance. |
By default, the public instance does not have route targets. |
6. Enter IPv4 VPN view, IPv6 VPN view, or EVPN view. |
Enter IPv4 VPN view: ·
Enter IPv6 VPN view: ·
Enter EVPN view: |
N/A |
7. Configure route targets for IPv4 VPN, IPv6 VPN, or EVPN. |
By default, IPv4 VPN, IPv6 VPN, and EVPN do not have route targets on the public instance. Make sure the following requirements are met: · The import targets of an EVPN instance do not match the export targets of the public instance. · The export targets of an EVPN instance do not match the import targets of the public instance. |
8. Return to public instance view. |
quit |
N/A |
9. Return to system view. |
quit |
N/A |
10. Create a VSI interface and enter its view. |
11. Configure an L3 VXLAN ID for the VSI interface. |
l3-vni vxlan-id |
By default, no L3 VXLAN ID is configured for a VSI interface. Of the VSI interfaces associated with the public instance, a minimum of one VSI interface must use the same L3 VXLAN ID as the public instance. |
Overview
If IGP routes are imported to the BGP-VPN IPv4 or IPv6 unicast address family and the corresponding VPN instance has an L3 VXLAN ID, the device advertises the imported routes as IP prefix advertisement routes.
If IGP routes are imported to the BGP IPv4 or IPv6 unicast address family and the public instance has an L3 VXLAN ID, the device advertises the imported routes as IP prefix advertisement routes.
A VTEP compares the export route targets of received IP prefix advertisement routes with the import route targets configured for IPv4 VPN or IPv6 VPN on a VPN instance or the public instance. If the route targets match, the VTEP accepts the routes and adds the routes to the routing table of the VPN instance or public instance.
This feature is supported only by distributed EVPN gateway deployment.
For more information about the BGP commands in this task, see Layer 3—IP Routing Command Reference.
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable a BGP instance and enter BGP instance view. |
3. Enter a BGP address family view. |
Enter BGP IPv4 unicast address family view: · Enter BGP-VPN IPv4 unicast address family view: a. ip vpn-instance vpn-instance-name b. address-family ipv4 [ unicast ] ·
Enter BGP IPv6 unicast address family view: · Enter BGP-VPN IPv6 unicast address family view: a. ip vpn-instance vpn-instance-name b. address-family ipv6 [ unicast ] |
N/A |
4. Enable BGP to redistribute routes from an IGP protocol. |
import-route protocol [ { process-id | all-processes } [ allow-direct | med med-value | route-policy route-policy-name ] * ] |
By default, BGP does not redistribute IGP routes. |
5. (Optional.) Enable default route redistribution into the BGP routing table. |
default-route imported |
By default, default route redistribution into the BGP routing table is disabled. |
6. (Optional.) Return to BGP instance view. |
quit |
N/A |
7. (Optional.) Enter BGP EVPN address family view. |
N/A |
8. (Optional.) Enable ECMP VPN route redistribution. |
vpn-route cross multipath |
By default, ECMP VPN route redistribution is disabled. If multiple routes have the same prefix and RD, BGP only imports the optimal route into the EVPN routing table. ECMP VPN route redistribution enables BGP to import all routes that have the same prefix and RD into the EVPN routing table. |
By default, the device learns MAC information, ARP information, and ND information of remote user terminals from packets received on VXLAN tunnel interfaces. The automatically learned remote MAC, ARP, and ND information might conflict with the remote MAC, ARP, and ND information advertised through BGP. As a best practice to avoid the conflicts, disable remote MAC address learning and remote ARP or ND learning on the device.
To disable remote MAC address learning and remote ARP or ND learning:
Step |
Command |
Remarks |
system-view |
N/A |
2. Disable remote MAC address learning. |
vxlan tunnel mac-learning disable |
By default, remote MAC address learning is enabled. |
3. Disable remote ARP learning. |
vxlan tunnel arp-learning disable |
By default, remote ARP learning is enabled. |
4. Disable remote ND learning. |
vxlan tunnel nd-learning disable |
By default, remote ND learning is enabled. |
The MAC information and ARP or ND information advertised by the VTEP overlap. To avoid duplication, disable MAC address advertisement and withdraw the MAC addresses advertised to remote VTEPs.
To disable MAC address advertisement:
Step |
Command |
Remarks |
system-view |
N/A |
vsi vsi-name |
N/A |
3. Enter EVPN instance view. |
N/A |
4. Disable MAC address advertisement and withdraw advertised MAC addresses. |
mac-advertising disable |
By default, MAC address advertisement is enabled. |
The MAC information and ARP or ND information advertised by a remote VTEP overlap. To avoid duplication, disable the learning of MAC addresses from ARP or ND information. EVPN will learn remote MAC addresses only from the MAC information advertised from remote sites.
To disable learning of MAC addresses from ARP or ND information:
Step |
Command |
Remarks |
system-view |
N/A |
vsi vsi-name |
N/A |
N/A |
4. Disable the EVPN instance from learning MAC addresses from ARP information. |
arp mac-learning disable |
By default, an EVPN instance learns MAC addresses from ARP information. |
5. Disable the EVPN instance from learning MAC addresses from ND information. |
nd mac-learning disable |
By default, an EVPN instance learns MAC addresses from ND information. |
In an EVPN network with distributed gateways, you can disable ARP information advertisement for a VXLAN to save resources if all its user terminals use the same EVPN gateway device. The EVPN instance of the VXLAN will stop advertising ARP information through MAC/IP advertisement routes and withdraw advertised ARP information. When ARP information advertisement is disabled, user terminals in other VXLANs still can communicate with that VXLAN through IP prefix advertisement routes.
To disable ARP information advertisement:
Step |
Command |
Remarks |
system-view |
N/A |
vsi vsi-name |
N/A |
N/A |
4. Disable ARP information advertisement for the EVPN instance. |
arp-advertising disable |
By default, ARP information advertisement is enabled for an EVPN instance. |
Perform the tasks in this section to issue forwarding entries to the hardware only when the entries are required for packet forwarding. The on-demand mechanism saves the device hardware resources.
The forwarding entries in this section include remote MAC address entries and host route FIB entries.
Perform the tasks in this section only on an EVPN network.
Overview
By default, the device issues a remote MAC address entry to the hardware after the remote MAC address is advertised to the local site by BGP EVPN routes. This feature enables the device to issue a remote MAC address entry to the hardware only when the entry is required for packet forwarding. This feature saves hardware resources on the device.
With this feature enabled, the device creates a blackhole MAC address entry for an unknown MAC address if it receives packets destined for that MAC address 50 times within a MAC aging interval. For more information about the aging timer for MAC address entries and blackhole MAC address entries, see MAC address table configuration in Layer 2—LAN Switching Configuration Guide.
To use this feature, execute the vxlan tunnel mac-learning disable command to disable remote MAC address learning.
This feature cannot take effect on VXLAN-DCI tunnels.
To enable conversational learning for remote MAC address entries:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable conversational learning for remote MAC address entries. |
mac-address forwarding-conversational-learning |
By default, conversational learning is disabled for remote MAC address entries. |
Overview
By default, the device issues a host route FIB entry to the hardware after the entry is generated. This feature enables the device to issue a host route FIB entry to the hardware only when the entry is required for packet forwarding. This feature saves hardware resources on the device.
Use this feature only in the distributed IPv4 EVPN gateway deployment. When this feature is enabled, you must disable remote ARP learning by using the vxlan tunnel arp-learning disable command.
Set an appropriate aging timer for host route FIB entries according to your network. A much longer or shorter aging timer will degrade the device performance.
· If the aging timer is too long, the device will save many outdated host route FIB entries and fail to accommodate the most recent network changes. These entries cannot be used for correct packet forwarding and exhaust FIB resources.
· If the aging timer is too short, the device will delete the valid host route FIB entries that can still be effective for packet forwarding. As a result, FIB entry flapping will occur, and the device performance will be affected.
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable conversational learning for host route FIB entries. |
ip forwarding-conversational-learning [ aging aging-time ] |
By default, conversational learning is disabled for host route FIB entries. |
Overview
By default, the device issues an IPv6 host route FIB entry to the hardware after the entry is generated. This feature enables the device to issue an IPv6 host route FIB entry to the hardware only when the entry is required for packet forwarding. This feature saves hardware resources on the device.
Use this feature only in the distributed IPv6 EVPN gateway deployment. When this feature is enabled, you must disable remote ND learning by using the vxlan tunnel nd-learning disable command.
Set an appropriate aging timer for IPv6 host route FIB entries according to your network. A much longer or shorter aging timer will degrade the device performance.
· If the aging timer is too long, the device will save many outdated IPv6 host route FIB entries and fail to accommodate the most recent network changes. These entries cannot be used for correct packet forwarding and exhaust FIB resources.
· If the aging timer is too short, the device will delete the valid IPv6 host route FIB entries that can still be effective for packet forwarding. As a result, FIB entry flapping will occur, and the device performance will be affected.
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable conversational learning for IPv6 host route FIB entries. |
ipv6 forwarding-conversational-learning [ aging aging-time ] |
By default, conversational learning is disabled for IPv6 host route FIB entries. |
This feature enables the device to advertise private BGP EVPN routes to the local site after the device adds the routes to the routing table of a VPN instance.
To enable BGP EVPN route advertisement to the local site:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter BGP instance view. |
N/A |
3. Enter BGP-VPN instance view. |
N/A |
4. Enter BGP-VPN IPv4 or IPv6 unicast address family view. |
view: ·
view: |
N/A |
5. Enable BGP EVPN route advertisement to the local site. |
advertise l2vpn evpn |
By default, BGP EVPN route advertisement to the local site is enabled. |
By default, the VTEP floods broadcast, unknown unicast, and unknown multicast frames received from the local site to the following interfaces in the frame's VXLAN:
· All site-facing interfaces except for the incoming interface.
· All VXLAN and VXLAN-DCI tunnel interfaces.
When receiving broadcast, unknown unicast, and unknown multicast frames on VXLAN tunnel interfaces, the device floods the frames to all site-facing interfaces in the frames' VXLAN.
To confine a kind of flood traffic, disable flooding for that kind of flood traffic on the VSI bound to the VXLAN.
To disable flooding for a VSI:
Step |
Command |
Remarks |
system-view |
N/A |
vsi vsi-name |
N/A |
3. Disable flooding for the VSI. |
flooding disable { all | { broadcast | unknown-multicast | unknown-unicast } * } [ all-direction | dci ] |
By default, flooding is enabled for a VSI. To disable flooding only to VXLAN-DCI tunnel interfaces, specify the dci keyword. To disable flooding to both VXLAN tunnel interfaces and VXLAN-DCI tunnel interfaces, do not specify the dci keyword. |
4. (Optional.) Enable selective flood for a MAC address. |
selective-flooding mac-address mac-address |
By default, selective flood is disabled. Use this feature to exclude a remote unicast or multicast MAC address from the remote flood suppression done by using the flooding disable command. The VTEP will flood the frames destined for the specified MAC address to remote sites when floods are confined to the local site. |
Use ARP flood suppression to reduce ARP request broadcasts.
The aging timer is fixed at 25 minutes for ARP flood suppression entries. If the flooding disable command is configured, set the MAC aging timer to a higher value than the aging timer for ARP flood suppression entries on all VTEPs. This setting prevents the traffic blackhole that occurs when a MAC address entry ages out before its ARP flood suppression entry ages out. To set the MAC aging timer, use the mac-address timer command.
When remote ARP learning is disabled for VXLANs, the device does not use ARP flood suppression entries to respond to ARP requests received on VXLAN tunnels.
To enable ARP flood suppression:
Step |
Command |
Remarks |
system-view |
N/A |
vsi vsi-name |
N/A |
3. Enable ARP flood suppression. |
arp suppression enable |
By default, ARP flood suppression is disabled. For more information about this command, see VXLAN Command Reference. |
Task |
Command |
Display BGP peer group information. |
display bgp [ instance instance-name ] group l2vpn evpn [ group-name group-name ] |
Display BGP EVPN routes. |
display bgp [ instance instance-name ] l2vpn evpn [ peer ipv4-address { advertised-routes | received-routes } [ statistics ] | [ route-distinguisher route-distinguisher | route-type { auto-discovery | es | imet | ip-prefix | mac-ip } ] * [ { evpn-route route-length | evpn-prefix } [ advertise-info ] | ipv4-address | ipv6-address | mac-address ] | statistics ] |
Display BGP peer or peer group information. |
display bgp [ instance instance-name ] peer l2vpn evpn [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] |
Display information about BGP update groups. |
display bgp [ instance instance-name ] update-group l2vpn evpn [ ipv4-address ] |
Display information about peers that are automatically discovered through BGP. |
display evpn auto-discovery { imet [ peer ip-address] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] } |
Display EVPN MAC address entries. |
display evpn route mac [ local | remote ] [ vsi vsi-name ] [ count ] |
Display EVPN ARP entries. |
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ count ] |
Display EVPN ND entries. |
display evpn route nd [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ count ] |
Display ARP flood suppression entries. |
display evpn route arp suppression [ local | remote ] [ vsi vsi-name ] [ count ] |
Display the routing table for a VPN instance. |
display evpn routing-table [ ipv6 ] { public-instance | vpn-instance vpn-instance-name } [ count ] |
NOTE: For more information about the display bgp group, display bgp peer, and display bgp update-group commands, see BGP commands in Layer 3—IP Routing Command Reference. |
EVPN configuration examples
Network requirements
As shown in Figure 13:
· Configure VXLAN 10 and VXLAN 20 on Switch A, Switch B, and Switch C to provide connectivity for the VMs in the VXLANs across the network sites.
· Configure Switch C as a centralized EVPN gateway to provide gateway services and access to the connected Layer 3 network.
· Configure Switch D as an RR to reflect BGP EVPN routes between Switch A, Switch B, and Switch C.
1. On VM 1 and VM 3, specify 10.1.1.1 as the gateway address. On VM 2 and VM 4, specify 10.1.2.1 as the gateway address. (Details not shown.)
2. Configure IP addresses and unicast routing settings:
# Assign IP addresses to interfaces, as shown in Figure 13. (Details not shown.)
# Configure OSPF on all transport network switches (Switches A through D) for them to reach one another. (Details not shown.)
3. Configure Switch A:
# Enable L2VPN.
[SwitchA] l2vpn enable
# Disable remote MAC address learning.
[SwitchA] vxlan tunnel mac-learning disable
# Create an EVPN instance on VSI vpna, and configure the switch to automatically generate an RD and a route target for the EVPN instance.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] arp suppression enable
[SwitchA-vsi-vpna] evpn encapsulation vxlan
[SwitchA-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchA-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchA-vsi-vpna] vxlan 10
[SwitchA-vsi-vpna] quit
# Create an EVPN instance on VSI vpnb, and configure the switch to automatically generate an RD and a route target for the EVPN instance.
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb] arp suppression enable
[SwitchA-vsi-vpnb] evpn encapsulation vxlan
[SwitchA-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchA-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchA-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[SwitchA-vsi-vpnb] vxlan 20
[SwitchA-vsi-vpnb-vxlan-20] quit
[SwitchA-vsi-vpnb] quit
# Configure BGP to advertise BGP EVPN routes.
[SwitchA] bgp 200
[SwitchA-bgp-default] peer 4.4.4.4 as-number 200
[SwitchA-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchA-bgp-default] address-family l2vpn evpn
[SwitchA-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchA-bgp-default-evpn] quit
[SwitchA-bgp-default] quit
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 1000 to match VLAN 2.
[SwitchA] interface ten-gigabitethernet 1/0/1
[SwitchA-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchA-Ten-GigabitEthernet1/0/1] port trunk permit vlan 2 3
[SwitchA-Ten-GigabitEthernet1/0/1] service-instance 1000
[SwitchA-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
# Map Ethernet service instance 1000 to VSI vpna.
[SwitchA-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchA-Ten-GigabitEthernet1/0/1-srv1000] quit
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 2000 to match VLAN 3.
[SwitchA-Ten-GigabitEthernet1/0/1] service-instance 2000
[SwitchA-Ten-GigabitEthernet1/0/1-srv2000] encapsulation s-vid 3
# Map Ethernet service instance 2000 to VSI vpnb.
[SwitchA-Ten-GigabitEthernet1/0/1-srv2000] xconnect vsi vpnb
[SwitchA-Ten-GigabitEthernet1/0/1-srv2000] quit
[SwitchA-Ten-GigabitEthernet1/0/1] quit
4. Configure Switch B:
# Enable L2VPN.
[SwitchB] l2vpn enable
[SwitchB] vxlan tunnel mac-learning disable
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] arp suppression enable
[SwitchB-vsi-vpna] evpn encapsulation vxlan
[SwitchB-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchB-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchB-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchB-vsi-vpna] vxlan 10
[SwitchB-vsi-vpna] quit
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb] arp suppression enable
[SwitchB-vsi-vpnb] evpn encapsulation vxlan
[SwitchB-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchB-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchB-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[SwitchB-vsi-vpnb] vxlan 20
[SwitchB-vsi-vpnb-vxlan-20] quit
[SwitchB-vsi-vpnb] quit
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 4.4.4.4 as-number 200
[SwitchB-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchB-bgp-default] address-family l2vpn evpn
[SwitchB-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchB-bgp-default-evpn] quit
[SwitchB-bgp-default] quit
[SwitchB] interface ten-gigabitethernet 1/0/1
[SwitchB-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchB-Ten-GigabitEthernet1/0/1] port trunk permit vlan 2
[SwitchB-Ten-GigabitEthernet1/0/1] service-instance 1000
[SwitchB-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
[SwitchB-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchB-Ten-GigabitEthernet1/0/1-srv1000] quit
[SwitchB-Ten-GigabitEthernet1/0/1] quit
# On Ten-GigabitEthernet 1/0/2, create Ethernet service instance 2000 to match VLAN 3.
[SwitchB] interface ten-gigabitethernet 1/0/2
[SwitchB-Ten-GigabitEthernet1/0/2] port link-type trunk
[SwitchB-Ten-GigabitEthernet1/0/2] port trunk permit vlan 3
[SwitchB-Ten-GigabitEthernet1/0/2] service-instance 2000
[SwitchB-Ten-GigabitEthernet1/0/2-srv2000] encapsulation s-vid 3
[SwitchB-Ten-GigabitEthernet1/0/2-srv2000] xconnect vsi vpnb
[SwitchB-Ten-GigabitEthernet1/0/2-srv2000] quit
[SwitchB-Ten-GigabitEthernet1/0/2] quit
5. Configure Switch C:
# Enable L2VPN.
[SwitchC] l2vpn enable
[SwitchC] vxlan tunnel mac-learning disable
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] evpn encapsulation vxlan
[SwitchC-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchC-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchC-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchC-vsi-vpna] vxlan 10
[SwitchC-vsi-vpna] quit
[SwitchC] vsi vpnb
[SwitchC-vsi-vpnb] evpn encapsulation vxlan
[SwitchC-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchC-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchC-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[SwitchC-vsi-vpnb] vxlan 20
[SwitchC-vsi-vpnb-vxlan-20] quit
[SwitchC-vsi-vpnb] quit
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 4.4.4.4 as-number 200
[SwitchC-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchC-bgp-default] address-family l2vpn evpn
[SwitchC-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchC-bgp-default-evpn] quit
[SwitchC-bgp-default] quit
# Create VSI-interface 1 and assign the interface an IP address. The IP address will be used as the gateway address for VXLAN 10.
[SwitchC] interface vsi-interface 1
[SwitchC-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchC-Vsi-interface1] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] gateway vsi-interface 1
# Create VSI-interface 2 and assign the interface an IP address. The IP address will be used as the gateway address for VXLAN 20.
[SwitchC] interface vsi-interface 2
[SwitchC-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchC-Vsi-interface2] quit
# Specify VSI-interface 2 as the gateway interface for VSI vpnb.
[SwitchC] vsi vpnb
[SwitchC-vsi-vpnb] gateway vsi-interface 2
6. Configure Switch D:
# Establish BGP connections with other transport network switches.
<SwitchD> system-view
[SwitchD] bgp 200
[SwitchD-bgp-default] group evpn
[SwitchD-bgp-default] peer 1.1.1.1 group evpn
[SwitchD-bgp-default] peer 2.2.2.2 group evpn
[SwitchD-bgp-default] peer 3.3.3.3 group evpn
[SwitchD-bgp-default] peer evpn as-number 200
[SwitchD-bgp-default] peer evpn connect-interface loopback 0
# Configure BGP to advertise BGP EVPN routes, and disable route target filtering for BGP EVPN routes.
[SwitchD-bgp-default] address-family l2vpn evpn
[SwitchD-bgp-default-evpn] peer evpn enable
[SwitchD-bgp-default-evpn] undo policy vpn-target
# Configure Switch D as an RR.
[SwitchD-bgp-default-evpn] peer evpn reflect-client
[SwitchD-bgp-default-evpn] quit
[SwitchD-bgp-default] quit
1. Verify the EVPN gateway settings on Switch C:
# Verify that Switch C has advertised MAC/IP advertisement routes and IMET routes for the gateways and received MAC/IP advertisement routes and IMET routes from Switch A and Switch B.
[SwitchC] display bgp l2vpn evpn
a - additional-path
Total number of routes from all PEs: 8
Route distinguisher: 1:10
Total number of routes: 4
* >i [2][0][48][0000-1234-0001][0][0.0.0.0]/104
1.1.1.1 0 100 0 i
* >i [2][0][48][0000-1234-0002][0][0.0.0.0]/104
1.1.1.1 0 100 0 i
* > [2][0][48][0003-0003-0003][32][10.1.1.1]/136
0.0.0.0 0 100 32768 i
* >i [3][10][32][1.1.1.1]/80
1.1.1.1 0 100 0 i
* > [3][10][32][3.3.3.3]/80
Route distinguisher: 1:20
* >i [2][0][48][0000-1234-0003][0][0.0.0.0]/104
3.3.3.3 0 100 0 i
* >i [2][0][48][0000-1234-0004][0][0.0.0.0]/104
3.3.3.3 0 100 0 i
* > [2][0][48][0005-0005-0005][32][10.1.2.1]/136
* > [3][20][32][3.3.3.3]/80
* >i [3][20][32][2.2.2.2]/80
3.3.3.3 0 100 0 i
# Verify that the VXLAN tunnel interfaces are up on Switch C.
[SwitchC] display interface tunnel
Tunnel0
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 2.2.2.2
Last 300 seconds output rate: 7 bytes/sec, 56 bits/sec, 0 packets/sec
Input: 10 packets, 980 bytes, 0 drops
Output: 85 packets, 6758 bytes, 0 drops
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 1.1.1.1
Last 300 seconds input rate: 1 bytes/sec, 8 bits/sec, 0 packets/sec
Last 300 seconds output rate: 9 bytes/sec, 72 bits/sec, 0 packets/sec
Input: 277 packets, 20306 bytes, 0 drops
Output: 1099 packets, 85962 bytes, 0 drops
# Verify that the VSI interfaces are up on Switch C.
[SwitchC] display interface vsi-interface
Vsi-interface1
Current state: UP
Description: Vsi-interface1 Interface
Bandwidth: 1000000 kbps
Maximum transmission unit: 1444
IP packet frame type: Ethernet II, hardware address: 0003-0003-0003
IPv6 packet frame type: Ethernet II, hardware address: 0003-0003-0003
Output: 64 packets, 6272 bytes, 0 drops
Vsi-interface2
Current state: UP
Description: Vsi-interface2 Interface
IP packet frame type: Ethernet II, hardware address: 0005-0005-0005
IPv6 packet frame type: Ethernet II, hardware address: 0005-0005-0005
Last 300 seconds input rate: 41 bytes/sec, 328 bits/sec, 0 packets/sec
Last 300 seconds output rate: 52 bytes/sec, 416 bits/sec, 0 packets/sec
Input: 2016 packets, 190272 bytes, 0 drops
Output: 2144 packets, 197568 bytes, 0 drops
# Verify that the VXLAN tunnels have been assigned to the VXLANs, and that the VSI interfaces are the gateway interfaces of their respective VXLANs.
[SwitchC] display l2vpn vsi verbose
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
Broadcast Restrain : -
Multicast Restrain : -
Unknown Unicast Restrain: -
MAC Learning : Enabled
MAC Table Limit : -
MAC Learning rate : -
Drop Unknown : -
Flooding : Enabled
Statistics : Disabled
Gateway Interface : VSI-interface 1
VXLAN ID : 10
Tunnels:
Tunnel Name Link ID State Type Flood proxy
Tunnel0 0x5000000 UP Auto Disabled
Tunnel1 0x5000001 UP Auto Disabled
VSI Name: vpnb
VSI Index : 1
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Gateway Interface : VSI-interface 2
VXLAN ID : 20
Tunnels:
# Verify that Switch C has created EVPN ARP entries for the VMs.
[SwitchC] display evpn route arp
Flags: D - Dynamic B - BGP L - Local active
G - Gateway S - Static M - Mapping
Public instance Interface: Vsi-interface2
IP address MAC address Router MAC VSI Index Flags
10.1.2.1 0005-0005-0005 - 1 GL
10.1.2.10 0000-1234-0002 - 1 B
10.1.2.20 0000-1234-0004 - 1 B
Public instance Interface: Vsi-interface1
10.1.1.1 0003-0003-0003 - 0 GL
10.1.1.10 0000-1234-0001 - 0 B
10.1.1.20 0000-1234-0003 - 0 B
# Verify that Switch C has created FIB entries for the VMs.
[SwitchC] display fib 10.1.1.10
Flag:
U:Usable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
10.1.1.10/32 10.1.1.10 UH Vsi1 Null
2. Verify that VM 1, VM 2, VM 3, and VM 4 can communicate with one another.
Distributed IPv4 EVPN gateway configuration example
As shown in Figure 14:
· Configure VXLAN 10 and VXLAN 20 on Switch A and Switch B to provide connectivity for the VMs in the VXLANs across the network sites.
· Configure Switch A and Switch B as distributed EVPN gateways to provide gateway services. Configure Switch C as a border gateway to provide access to the connected Layer 3 network.
# Assign IP addresses to interfaces, as shown in Figure 14. (Details not shown.)
# Enable L2VPN.
# Disable remote MAC address learning and remote ARP learning.
[SwitchA] vxlan tunnel arp-learning disable
[SwitchA] vsi vpna
# Create VXLAN 10.
[SwitchA] vsi vpnb
# Create VXLAN 20.
[SwitchA] bgp 200
# Configure RD and route target settings for VPN instance vpna.
[SwitchA] ip vpn-instance vpna
[SwitchA-vpn-instance-vpna] route-distinguisher 1:1
[SwitchA-vpn-instance-vpna] address-family ipv4
[SwitchA-vpn-ipv4-vpna] vpn-target 2:2
[SwitchA-vpn-ipv4-vpna] quit
[SwitchA-vpn-instance-vpna] address-family evpn
[SwitchA-vpn-evpn-vpna] vpn-target 1:1
[SwitchA-vpn-evpn-vpna] quit
[SwitchA-vpn-instance-vpna] quit
# Configure VSI-interface 1.
[SwitchA] interface vsi-interface 1
[SwitchA-Vsi-interface1] ip binding vpn-instance vpna
[SwitchA-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchA-Vsi-interface1] mac-address 1-1-1
[SwitchA-Vsi-interface1] distributed-gateway local
[SwitchA-Vsi-interface1] local-proxy-arp enable
[SwitchA-Vsi-interface1] quit
# Configure VSI-interface 2.
[SwitchA] interface vsi-interface 2
[SwitchA-Vsi-interface2] ip binding vpn-instance vpna
[SwitchA-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchA-Vsi-interface2] mac-address 2-2-2
[SwitchA-Vsi-interface2] distributed-gateway local
[SwitchA-Vsi-interface2] local-proxy-arp enable
[SwitchA-Vsi-interface2] quit
# Associate VSI-interface 3 with VPN instance vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchA] interface vsi-interface 3
[SwitchA-Vsi-interface3] ip binding vpn-instance vpna
[SwitchA-Vsi-interface3] l3-vni 1000
[SwitchA-Vsi-interface3] quit
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] gateway vsi-interface 1
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb] gateway vsi-interface 2
# Enable L2VPN.
[SwitchB] vxlan tunnel arp-learning disable
[SwitchB] vsi vpna
# Create VXLAN 10.
[SwitchB] vsi vpnb
# Create VXLAN 20.
[SwitchB] bgp 200
[SwitchB] ip vpn-instance vpna
[SwitchB-vpn-instance-vpna] route-distinguisher 1:1
[SwitchB-vpn-instance-vpna] address-family ipv4
[SwitchB-vpn-ipv4-vpna] vpn-target 2:2
[SwitchB-vpn-ipv4-vpna] quit
[SwitchB-vpn-instance-vpna] address-family evpn
[SwitchB-vpn-evpn-vpna] vpn-target 1:1
[SwitchB-vpn-evpn-vpna] quit
[SwitchB-vpn-instance-vpna] quit
[SwitchB] interface vsi-interface 1
[SwitchB-Vsi-interface1] ip binding vpn-instance vpna
[SwitchB-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchB-Vsi-interface1] mac-address 1-1-1
[SwitchB-Vsi-interface1] distributed-gateway local
[SwitchB-Vsi-interface1] local-proxy-arp enable
[SwitchB-Vsi-interface1] quit
[SwitchB] interface vsi-interface 2
[SwitchB-Vsi-interface2] ip binding vpn-instance vpna
[SwitchB-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchB-Vsi-interface2] mac-address 2-2-2
[SwitchB-Vsi-interface2] distributed-gateway local
[SwitchB-Vsi-interface2] local-proxy-arp enable
[SwitchB-Vsi-interface2] quit
[SwitchB] interface vsi-interface 3
[SwitchB-Vsi-interface3] ip binding vpn-instance vpna
[SwitchB-Vsi-interface3] l3-vni 1000
[SwitchB-Vsi-interface3] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] gateway vsi-interface 1
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb] gateway vsi-interface 2
# Enable L2VPN.
[SwitchC] vxlan tunnel arp-learning disable
[SwitchC] bgp 200
[SwitchC] ip vpn-instance vpna
[SwitchC-vpn-instance-vpna] route-distinguisher 1:1
[SwitchC-vpn-instance-vpna] address-family ipv4
[SwitchC-vpn-ipv4-vpna] vpn-target 2:2
[SwitchC-vpn-ipv4-vpna] quit
[SwitchC-vpn-instance-vpna] address-family evpn
[SwitchC-vpn-evpn-vpna] vpn-target 1:1
[SwitchC-vpn-evpn-vpna] quit
[SwitchC-vpn-instance-vpna] quit
[SwitchC] interface vsi-interface 3
[SwitchC-Vsi-interface3] ip binding vpn-instance vpna
[SwitchC-Vsi-interface3] l3-vni 1000
[SwitchC-Vsi-interface3] quit
# Configure a default route.
[SwitchC] ip route-static vpn-instance vpna 0.0.0.0 0 null0
# Import the default route to the BGP IPv4 unicast routing table of VPN instance vpna.
[SwitchC] bgp 200
[SwitchC-bgp-default] ip vpn-instance vpna
[SwitchC-bgp-default-vpna] address-family ipv4 unicast
[SwitchC-bgp-default-ipv4-vpna] default-route imported
[SwitchC-bgp-default-ipv4-vpna] import-route static
[SwitchC-bgp-default-ipv4-vpna] quit
[SwitchC-bgp-default-vpna] quit
# Associate VLAN-interface 20 with VPN instance vpna.
[SwitchC] interface vlan-interface 20
[SwitchC-Vlan-interface20] ip binding vpn-instance vpna
[SwitchC-Vlan-interface20] ip address 20.1.1.3 24
[SwitchC-Vlan-interface20] quit
[SwitchD] bgp 200
1. Verify the distributed EVPN gateway settings on Switch A:
# Verify that Switch A has advertised the IP prefix advertisement routes for the gateways and the MAC/IP advertisement routes and IMET routes for each VSI. Verify that Switch A has received the IP prefix advertisement routes for the gateways and the MAC/IP advertisement routes and IMET routes for each VSI from Switch B.
[SwitchA] display bgp l2vpn evpn
a - additional-path
Total number of routes from all PEs: 14
* > [5][0][24][10.1.1.0]/80
* > [5][0][24][10.1.2.0]/80
* >i [5][0][24][10.1.1.0]/80
2.2.2.2 0 100 0 i
* >i [5][0][24][10.1.2.0]/80
2.2.2.2 0 100 0 i
Total number of routes: 5
* > [2][0][48][0000-1234-0001][0][0.0.0.0]/104
* > [2][0][48][0000-1234-0001][32][10.1.1.10]/136
* >i [2][0][48][0000-1234-0003][32][10.1.1.20]/136
2.2.2.2 0 100 0 i
* > [3][10][32][1.1.1.1]/80
* >i [3][10][32][2.2.2.2]/80
2.2.2.2 0 100 32768 i
* > [2][0][48][0000-1234-0002][0][0.0.0.0]/104
* > [2][0][48][0000-1234-0002][32][10.1.2.10]/136
* >i [2][0][48][0000-1234-0004][32][10.1.2.20]/136
2.2.2.2 0 100 0 i
# Verify that the VXLAN tunnel interfaces are up on Switch A. (This example uses Tunnel 1.)
[SwitchA] display interface tunnel 1
Tunnel1
Current state: UP
# Verify that the VSI interfaces are up on Switch A. (This example uses VSI-interface 1.)
[SwitchA] display interface vsi-interface 1
Vsi-interface1
Current state: UP
IP packet frame type: Ethernet II, hardware address: 0001-0001-0001
IPv6 packet frame type: Ethernet II, hardware address: 0001-0001-0001
Output: 192 packets, 18816 bytes, 0 drops
[SwitchA] display l2vpn vsi verbose
VSI Name: Auto_L3VNI200_3
VSI Index : 1
VSI State : Down
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Gateway Interface : VSI-interface 3
VXLAN ID : 1000
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 10
Tunnels:
Tunnel0 0x5000001 Up Auto Disabled
Tunnel1 0x5000002 Up Auto Disabled
ACs:
AC Link ID State Type
XGE1/0/1 srv1000 0 Up Manual
VSI Name: vpnb
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 20
Tunnels:
ACs:
XGE1/0/1 srv2000 0 Up Manual
# Verify that Switch A has created ARP entries for the VMs.
[SwitchA] display arp
Type: S-Static D-Dynamic O-Openflow R-Rule M-Multiport I-Invalid
IP address MAC address VLAN/VSI Interface/Link ID Aging Type
10.1.1.10 0000-1234-0001 0 0x0 20 D
10.1.2.10 0000-1234-0002 0 0x0 19 D
2.2.2.2 a0ce-5e24-0100 1 Tunnel0 N/A R
# Verify that Switch A has created EVPN ARP entries for the local VMs.
[SwitchA] display evpn route arp
VPN instance:vpna Interface:Vsi-interface1
10.1.1.1 0001-0001-0001 a0ce-7e40-0400 0 GL
10.1.1.10 0000-1234-0001 a0ce-7e40-0400 0 DL
10.1.2.10 0000-1234-0002 a0ce-7e40-0400 0 DL
10.1.1.20 0000-1234-0003 a0ce-7e40-0400 0 B
10.1.2.20 0000-1234-0004 a0ce-7e40-0400 0 B
Distributed IPv6 EVPN gateway configuration example
As shown in Figure 15:
1. On VM 1 and VM 3, specify 11::1 as the gateway address. On VM 2 and VM 4, specify 12::1 as the gateway address. (Details not shown.)
# Assign IP addresses to interfaces, as shown in Figure 15. (Details not shown.)
# Enable L2VPN.
# Disable remote MAC address learning and remote ND learning.
[SwitchA] vxlan tunnel nd-learning disable
[SwitchA] vsi vpna
# Create VXLAN 10.
[SwitchA] vsi vpnb
# Create VXLAN 20.
[SwitchA] bgp 200
[SwitchA-vpn-instance-vpna] address-family ipv6
[SwitchA-vpn-ipv6-vpna] vpn-target 2:2
[SwitchA-vpn-ipv6-vpna] quit
[SwitchA-Vsi-interface1] ipv6 address 11::1 64
[SwitchA-Vsi-interface1] local-proxy-nd enable
[SwitchA-Vsi-interface2] ipv6 address 12::1 64
[SwitchA-Vsi-interface2] local-proxy-nd enable
[SwitchA-Vsi-interface3] ipv6 address auto link-local
[SwitchA] vsi vpna
[SwitchA] vsi vpnb
# Enable L2VPN.
[SwitchB] vxlan tunnel nd-learning disable
[SwitchB] vsi vpna
# Create VXLAN 10.
[SwitchB] vsi vpnb
# Create VXLAN 20.
[SwitchB] bgp 200
[SwitchB-vpn-instance-vpna] address-family ipv6
[SwitchB-vpn-ipv6-vpna] vpn-target 2:2
[SwitchB-vpn-ipv6-vpna] quit
[SwitchB-Vsi-interface1] ipv6 address 11::1 64
[SwitchB-Vsi-interface1] local-proxy-nd enable
[SwitchB-Vsi-interface2] ipv6 address 12::1 64
[SwitchB-Vsi-interface2] local-proxy-nd enable
[SwitchB-Vsi-interface3] ipv6 address auto link-local
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
# Enable L2VPN.
[SwitchC] vxlan tunnel nd-learning disable
[SwitchC] bgp 200
[SwitchC-vpn-instance-vpna] address-family ipv6
[SwitchC-vpn-ipv6-vpna] vpn-target 2:2
[SwitchC-vpn-ipv6-vpna] quit
[SwitchC-Vsi-interface3] ipv6 address auto link-local
# Configure a default route. The next hop is the IP address of a device in the Layer 3 network.
[SwitchC] ipv6 route-static vpn-instance vpna :: 0 20::100
# Import the default route to the BGP IPv6 unicast routing table of VPN instance vpna.
[SwitchC] bgp 200
[SwitchC-bgp-default-vpna] address-family ipv6 unicast
[SwitchC-bgp-default-ipv6-vpna] default-route imported
[SwitchC-bgp-default-ipv6-vpna] import-route static
[SwitchC-bgp-default-ipv6-vpna] quit
[SwitchC-Vlan-interface20] ipv6 address 20::1 64
[SwitchD] bgp 200
a - additional-path
* > [5][0][64][11::0]/176
* > [5][0][64][12::0]/176
* >i [5][0][64][11::0]/176
2.2.2.2 0 100 0 i
* >i [5][0][64][12::0]/176
2.2.2.2 0 100 0 i
* > [2][0][48][8291-87ab-0206][0][0.0.0.0]/104
* > [2][0][48][8291-87ab-0206][128][11::7]/232
* >i [2][0][48][8291-920d-0306][128][11::8]/232
2.2.2.2 0 100 0 i
* > [2][0][48][8291-87ab-0206][128][12::7]/232
* >i [2][0][48][8291-920d-0306][128][12::8]/232
2.2.2.2 0 100 0 i
Tunnel1
Current state: UP
Vsi-interface1
Current state: UP
VSI Index : 1
VSI State : Down
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 1000
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 10
Tunnels:
ACs:
VSI Name: vpnb
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 20
Tunnels:
ACs:
# Verify that Switch A has created EVPN ND entries for the local VMs.
[SwitchA] display evpn route nd
VPN instance: vpn1 Interface: Vsi-interface1
IPv6 address : 11::7
MAC address : 0001-0001-0001 Router MAC : 8291-a344-0400
VSI index : 0 Flags : GL
IPv6 address : 12::7
MAC address : 0001-0002-0001 Router MAC : 8291-7342-0200
IPv6 address : 11::8
MAC address : 0001-0002-0002 Router MAC : 8291-a342-0100
IPv6 address : 12::8
MAC address : 0002-0002-0002 Router MAC : 8291-a741-0420
IPv6 address : 11::11
MAC address : 0003-0003-0003 Router MAC : a0ce-7e80-0460
2. Verify that VM 1, VM 2, VM 3, and VM 4 can communicate with one another. (Details not shown.)
Private-public IPv4 network communication example
As shown in Figure 16:
· Configure VXLAN 10, VXLAN 20, and VXLAN 30 on Switch A, Switch B, and Switch C to meet the following requirements:
? VXLAN 10 and VXLAN 20 are on the private network, and VXLAN 30 is on the public network.
? VXLAN 10 can communicate with VXLAN 20 and VXLAN 30, and VXLAN 20 is isolated from VXLAN 30.
· Configure Switch A, Switch B, and Switch C as distributed EVPN gateways to provide gateway services for the VXLANs.
1. On VM 1, VM 2, and VM 3, specify 10.1.1.1, 10.1.2.1, and 10.1.3.1 as the gateway address, respectively. (Details not shown.)
# Assign IP addresses to interfaces, as shown in Figure 16. (Details not shown.)
# Enable L2VPN.
[SwitchA] vsi vpna
# Create VXLAN 10.
[SwitchA] bgp 200
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 1000 to match VLAN 1.
[SwitchA-Ten-GigabitEthernet1/0/1] port trunk permit vlan 1
[SwitchA-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 1
[SwitchA-vpn-ipv4-vpna] vpn-target 1:1
[SwitchA-vpn-ipv4-vpna] vpn-target 2:2 import-extcommunity
[SwitchA-vpn-ipv4-vpna] vpn-target 3:3 import-extcommunity
[SwitchA-vpn-evpn-vpna] vpn-target 2:2 import-extcommunity
[SwitchA-vpn-evpn-vpna] vpn-target 3:3 import-extcommunity
# Associate VSI-interface 2 with VPN instance vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchA-Vsi-interface2] l3-vni 1000
# Create VSI-interface 3 and configure its L3 VXLAN ID as 2000 for matching routes from Switch B.
[SwitchA-Vsi-interface3] l3-vni 2000
# Create VSI-interface 4 and configure its L3 VXLAN ID as 3000 for matching routes from Switch C.
[SwitchA] interface vsi-interface 4
[SwitchA-Vsi-interface4] l3-vni 3000
[SwitchA-Vsi-interface4] quit
[SwitchA] vsi vpna
# Enable L2VPN.
[SwitchB] vsi vpnb
# Create VXLAN 20.
[SwitchB] bgp 200
# Map Ethernet service instance 1000 to VSI vpnb.
[SwitchB-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpnb
# Configure RD and route target settings for VPN instance vpnb.
[SwitchB] ip vpn-instance vpnb
[SwitchB-vpn-instance-vpnb] route-distinguisher 2:2
[SwitchB-vpn-instance-vpnb] address-family ipv4
[SwitchB-vpn-ipv4-vpnb] vpn-target 2:2
[SwitchB-vpn-ipv4-vpnb] vpn-target 1:1 import-extcommunity
[SwitchB-vpn-ipv4-vpnb] quit
[SwitchB-vpn-instance-vpnb] address-family evpn
[SwitchB-vpn-evpn-vpnb] vpn-target 2:2
[SwitchB-vpn-evpn-vpnb] vpn-target 1:1 import-extcommunity
[SwitchB-vpn-evpn-vpnb] quit
[SwitchB-vpn-instance-vpnb] quit
[SwitchB-Vsi-interface1] ip binding vpn-instance vpnb
[SwitchB-Vsi-interface1] ip address 10.1.2.1 255.255.255.0
# Create VSI-interface 2, and configure its L3 VXLAN ID as 1000 for matching routes from Switch A.
[SwitchB-Vsi-interface2] l3-vni 1000
# Associate VSI-interface 3 with VPN instance vpnb, and configure the L3 VXLAN ID as 2000 for the VPN instance.
[SwitchB-Vsi-interface3] ip binding vpn-instance vpnb
[SwitchB-Vsi-interface3] l3-vni 2000
# Create VSI-interface 4, and configure its L3 VXLAN ID as 3000 for matching routes from Switch C.
[SwitchB] interface vsi-interface 4
[SwitchB-Vsi-interface4] l3-vni 3000
[SwitchB-Vsi-interface4] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpnb.
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb] gateway vsi-interface 1
# Enable L2VPN.
# Create an EVPN instance on VSI vpnc, and configure the switch to automatically generate an RD and a route target for the EVPN instance.
[SwitchC] vsi vpnc
[SwitchC-vsi-vpnc] evpn encapsulation vxlan
[SwitchC-vsi-vpnc-evpn-vxlan] route-distinguisher auto
[SwitchC-vsi-vpnc-evpn-vxlan] vpn-target auto
[SwitchC-vsi-vpnc-evpn-vxlan] quit
# Create VXLAN 30.
[SwitchC-vsi-vpnc] vxlan 30
[SwitchC-vsi-vpnc-vxlan-30] quit
[SwitchC-vsi-vpnc] quit
[SwitchC] bgp 200
# Configure RD, route target, and L3 VXLAN ID settings for the public instance.
[SwitchC] ip public-instance
[SwitchC-public-instance] route-distinguisher 3:3
[SwitchC-public-instance] l3-vni 3000
[SwitchC-public-instance] address-family ipv4
[SwitchC-public-instance-ipv4] vpn-target 3:3
[SwitchC-public-instance-ipv4] vpn-target 1:1 import-extcommunity
[SwitchC-public-instance-ipv4] quit
[SwitchC-public-instance] address-family evpn
[SwitchC-public-instance-evpn]vpn-target 3:3
[SwitchC-public-instance-evpn] vpn-target 1:1 import-extcommunity
[SwitchC-public-instance-evpn] quit
[SwitchC-public-instance] quit
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 1000 to match VLAN 3.
[SwitchC] interface ten-gigabitethernet 1/0/1
[SwitchC-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchC-Ten-GigabitEthernet1/0/1] port trunk permit vlan 3
[SwitchC-Ten-GigabitEthernet1/0/1] service-instance 1000
[SwitchC-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 3
# Map Ethernet service instance 1000 to VSI vpnc.
[SwitchC-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpnc
[SwitchC-Ten-GigabitEthernet1/0/1-srv1000] quit
[SwitchC-Ten-GigabitEthernet1/0/1] quit
[SwitchC-Vsi-interface1] ip address 10.1.3.1 255.255.255.0
[SwitchC-Vsi-interface1] distributed-gateway local
[SwitchC-Vsi-interface1] local-proxy-arp enable
[SwitchC-Vsi-interface2] l3-vni 1000
# Create VSI-interface 3, and configure its L3 VXLAN ID as 2000 for matching routes from Switch B.
[SwitchC-Vsi-interface3] l3-vni 2000
# Create VSI-interface 4 for the public instance, and configure the L3 VXLAN ID as 3000 for the VSI interface.
[SwitchC] interface vsi-interface 4
[SwitchC-Vsi-interface4] l3-vni 3000
[SwitchC-Vsi-interface4] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpnc.
[SwitchC] vsi vpnc
[SwitchC-vsi-vpnc] gateway vsi-interface 1
[SwitchD] bgp 200
# Verify that Switch A has advertised the IP prefix advertisement routes for the gateways and the MAC/IP advertisement routes and IMET routes for each VSI. Verify that Switch A has received the IP prefix advertisement routes for the gateways and the MAC/IP advertisement routes and IMET routes for each VSI from Switch B and Switch C.
a - additional-path
Total number of routes from all PEs: 9
Route distinguisher: 1:1(vpna)
Total number of routes: 3
* >i [2][0][48][582e-d6b2-0906][32][10.1.2.10]/136
2.2.2.2 0 100 0 i
* >i [2][0][48][9a50-488c-1106][32][10.1.3.10]/136
3.3.3.3 0 100 0 i
Total number of routes: 2
* > [2][0][48][582e-aaec-0806][32][10.1.1.10]/136
* > [3][0][32][1.1.1.1]/80
Total number of routes: 1
2.2.2.2 0 100 0 i
Route distinguisher: 1:30
3.3.3.3 0 100 0 i
Route distinguisher: 2:2
2.2.2.2 0 100 0 i
Route distinguisher: 3:3
* >i [5][0][24][10.1.3.0]/80
3.3.3.3 0 100 0 i
Tunnel0
Current state: UP
Bandwidth: 64 kbps
Input: 15 packets, 1470 bytes, 0 drops
Output: 15 packets, 1470 bytes, 0 drops
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Tunnel source 1.1.1.1, destination 3.3.3.3
Input: 22 packets, 2156 bytes, 0 drops
Output: 23 packets, 2254 bytes, 0 drops
Vsi-interface1
Current state: UP
IP packet frame type: Ethernet II, hardware address: 582e-81f2-0600
IPv6 packet frame type: Ethernet II, hardware address: 582e-81f2-0600
Last 300 seconds output rate: 4 bytes/sec, 32 bits/sec, 0 packets/sec
Output: 2656 packets, 138432 bytes, 0 drops
Vsi-interface2
Current state: UP
Vsi-interface3
Current state: UP
Description: Vsi-interface3 Interface
Vsi-interface4
Current state: UP
Description: Vsi-interface4 Interface
VSI Name: Auto_L3VNI1000_2
VSI Index : 1
VSI State : Down
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 1000
VSI Name: Auto_L3VNI2000_3
VSI Index : 2
VSI State : Down
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 2000
VSI Name: Auto_L3VNI3000_4
VSI Index : 3
VSI State : Down
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Gateway Interface : VSI-interface 4
VXLAN ID : 3000
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 10
ACs:
10.1.1.10 582e-aaec-0806 0 0x0 10 D
11.1.1.4 582c-1385-0517 -- Vlan11 14 D
2.2.2.2 582e-8ba6-0700 2 Tunnel0 N/A R
3.3.3.3 9a51-95ba-1000 3 Tunnel1 N/A R
2. Verify that VM 1 can communicate with VM 2 and VM 3, and VM 2 cannot communicate with VM 3. (Details not shown.)
Configuring EVPN-DCI
Overview
EVPN data center interconnect (EVPN-DCI) uses VXLAN-DCI tunnels to provide connectivity for data centers over an IP transport network.
EVPN-DCI network model
As shown in Figure 17, the EVPN-DCI network contains VTEPs and edge devices (EDs) located at the edge of the transport network. A VXLAN tunnel is established between a VTEP and an ED, and a VXLAN-DCI tunnel is established between two EDs. VXLAN-DCI tunnels use VXLAN encapsulation. Each ED de-encapsulates incoming VXLAN packets and re-encapsulates them based on the destination before forwarding the packets through a VXLAN or VXLAN-DCI tunnel.
Figure 17 EVPN-DCI network model
Working mechanisms
In an EVPN-DCI network, BGP EVPN peer relationships are established between EDs and between EDs and VTEPs. When advertising routes to a VTEP or another ED, an ED replaces the routes' nexthop IP address and router MAC address with its IP address and router MAC address.
In an EVPN-DCI network, a VTEP and an ED use a VXLAN tunnel to send traffic, and two EDs use a VXLAN-DCI tunnel to send traffic. An ED de-encapsulates incoming VXLAN packets and re-encapsulates them before forwarding the packets through a VXLAN or VXLAN-DCI tunnel.
EVPN-DCI dual-homing
As shown in Figure 18, EVPN-DCI dual-homing allows you to deploy two EDs at a data center for high availability and load sharing. To virtualize the redundant EDs into one device, a virtual ED address is configured on them. The redundant EDs use the virtual ED address to establish tunnels with VTEPs and remote EDs.
Figure 18 EVPN-DCI dual-homing
The redundant EDs use their respective IP addresses as the BGP peer addresses to establish BGP EVPN neighbor relationships with VTEPs and remote EDs. The VTEPs and remote EDs send traffic destined for the virtual ED address to both of the redundant EDs through the ECMP routes provided by the underlay network.
The redundant EDs communicate with remote data centers through the transport network. Devices in the dual-homed data center are unaware of the transport network. When the transport-side link fails on one of the redundant EDs, traffic destined for remote data centers is still sent to that ED. To resolve this issue, Monitor Link is used together with EVPN-DCI dual-homing.
On each redundant ED, the transport-facing physical interface is associated with the following loopback interfaces: The loopback interface that provides the IP address used for establishing BGP EVPN neighbor relationships and the loopback interface that provides the virtual ED address. If the transport-side link fails on a redundant ED, the loopback interfaces are placed in down state, and all traffic is forwarded by the other redundant ED. For more information about Monitor Link, see High Availability Configuration Guide.
For link redundancy, deploy multiple RRs on the spine nodes in a data center, and connect each redundant ED to the transport network through multiple links.
To avoid packet loss, do not use a transport-facing interface to provide services for both VXLAN-DCI tunnels and VXLAN tunnels.
EVPN-DCI configuration task list
Perform all EVPN-DCI configuration tasks on EDs.
Tasks at a glance |
(Required.) Enabling DCI |
(Required.) Enabling route nexthop replacement and route router MAC replacement |
(Optional.) Configuring VXLAN mapping |
(Optional.) Configuring the BGP EVPN address family and the BGP VPNv4 or VPNv6 address family to exchange routes |
(Optional.) Configuring EVPN-DCI dual-homing |
Before you configure EVPN-DCI, complete basic EVPN configuration for each data center. For more information about basic EVPN configuration, see "Configuring EVPN."
Enabling DCI
For EDs to automatically establish VXLAN-DCI tunnels, you must enable DCI on the Layer 3 interfaces that interconnect the EDs.
An ED establishes VXLAN-DCI tunnels based on BGP EVPN routes. If DCI is disabled on the outgoing interfaces to remote sites, EDs cannot establish VXLAN-DCI tunnels.
To enable DCI:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Enable DCI. |
dci enable |
By default, DCI is disabled on an interface. You cannot enable DCI on a subinterface. Subinterfaces of a DCI-enabled interface inherit configuration of the interface. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure a global router ID. |
router id router-id |
By default, no global router ID is configured. |
3. Enable a BGP instance and enter BGP instance view. |
bgp as-number [ instance instance-name ] [ multi-session-thread ] |
By default, BGP is disabled, and no BGP instances exist. |
4. Specify local VTEPs and remote EDs as BGP peers. |
peer { group-name | ipv4-address [ mask-length ] } as-number as-number |
By default, no BGP peers are specified. |
5. Create the BGP EVPN address family and enter BGP EVPN address family view. |
address-family l2vpn evpn |
By default, the BGP EVPN address family does not exist. |
6. Enable BGP to exchange BGP EVPN routes with a peer or peer group. |
peer { group-name | ipv4-address [ mask-length ] } enable |
By default, BGP does not exchange BGP EVPN routes with peers. |
7. Set the local router as the next hop for routes advertised to a peer or peer group. |
peer { group-name | ipv4-address [ mask-length ] } next-hop-local |
The default settings for this command are as follows: · BGP sets the local router as the next hop for all routes advertised to an EBGP peer or peer group. · BGP does not modify the next hop for EBGP routes advertised to an IBGP peer or peer group. The peers specified in this task must be VTEPs in the local data center. |
8. Enable route router MAC replacement for a peer or peer group. |
peer { group-name | ipv4-address [ mask-length ] } router-mac-local |
By default, the device does not modify the router MAC address of routes before advertising the routes. This command enables the device to use its router MAC address to replace the router MAC address of routes received from and advertised to a peer or peer group. The peers specified in this task must be remote EDs. |
Overview
The VXLAN mapping feature provides Layer 2 connectivity for a tenant subnet that uses different VXLAN IDs in multiple data centers.
If you map a local VXLAN to a remote VXLAN on an ED, the ED processes routes as follows:
· When the ED receives the local VXLAN's MAC/IP advertisement routes from local VTEPs, it performs the following operations:
? Adds the routes to the local VXLAN.
? Replaces the VXLAN ID of the routes with the remote VXLAN ID and advertises the routes to remote EDs.
· When the ED receives the remote VXLAN's MAC/IP advertisement routes from a remote data center, it adds the routes to the local VXLAN.
VXLAN mapping includes the following types:
· Non-intermediate VXLAN mapping—When two data centers use different VXLAN IDs for a subnet, map the local VXLAN to the remote VXLAN on the ED of one data center. For example, for VXLAN 10 of data center 1 to communicate with VXLAN 20 of data center 2, map VXLAN 10 to VXLAN 20 on the ED of data center 1.
· Intermediate VXLAN mapping—When multiple data centers use different VXLAN IDs for a subnet, map the VXLANs to an intermediate VXLAN on all EDs. For example, data center 1 uses VXLAN 10, data center 2 uses VXLAN 20, and data center 3 uses VXLAN 30. To provide connectivity for the VXLANs, map them to intermediate VXLAN 500 on EDs of the data centers. You must use intermediate VXLAN mapping if more than two data centers use different VXLAN IDs. The intermediate VXLAN can be used only for VXLAN mapping, and it cannot be used for common VXLAN services.
You must create mapped remote VXLANs on the device, create an EVPN instance for each remote VXLAN, and configure RD and route target settings for the EVPN instances.
When you use VXLAN mapping, follow these route target restrictions:
· EVPN instances and VPN instances do not have the same export targets.
· EVPN instances and the public instance do not have the same export targets.
Configuration procedure
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter VSI view. |
vsi vsi-name |
N/A |
evpn encapsulation vxlan |
N/A |
4. Map the local VXLAN to a remote VXLAN. |
mapping vni vxlan-id |
By default, a local VXLAN is not mapped to any remote VXLAN. The remote VXLAN ID cannot be the same as the reserved VXLAN ID specified by using the reserved vxlan command or the L3 VXLAN ID specified by using the l3-vni command. For more information about the reserved vxlan command, see VXLAN Command Reference. |
Overview
When data centers are interconnected through an MPLS L3VPN network, EVPN EDs also act as MPLS L3VPN PEs. To enable communication between the data centers, you must perform the following tasks on the EDs:
· Configure both MPLS L3VPN and EVPN.
· Configure the BGP EVPN address family and the BGP VPNv4 or VPNv6 address family to exchange routes.
Figure 19 Data centers interconnected through an MPLS L3VPN network
Enabling BGP VPNv4 or VPNv6 route advertisement for the BGP EVPN address family
Step |
Command |
Remarks |
system-view |
N/A |
bgp as-number [ instance instance-name ] |
N/A |
3. Enter BGP EVPN address family view. |
N/A |
4. Enable BGP VPNv4 or VPNv6 route advertisement for the BGP EVPN address family. |
advertise l3vpn route [ replace-rt ] [ advertise-policy policy-name ] |
By default, BGP VPNv4 or VPNv6 routes are not advertised through the BGP EVPN address family. After you execute this command, the device advertises BGP VPNv4 or VPNv6 routes as IP prefix advertisement routes through the BGP EVPN address family. |
Enabling BGP EVPN route advertisement for the BGP VPNv4 or VPNv6 address family
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enter BGP VPNv4 address family view or BGP VPNv6 address family view. |
address-family { vpnv4 | vpnv6 } |
N/A |
4. Enable BGP EVPN route advertisement for the BGP VPNv4 or VPNv6 address family. |
advertise evpn route [ replace-rt ] advertise-policy policy-name ] |
By default, BGP EVPN routes are not advertised through the BGP VPNv4 or VPNv6 address family. After you execute this command, the device advertises IP prefix advertisement routes and MAC/IP advertisement routes that contain host route information through the BGP VPNv4 or VPNv6 address family. |
Overview
For high availability and load sharing, you can deploy two EDs at a data center. To virtualize the redundant EDs into one device, you must configure the same virtual ED address on them.
Do not configure a virtual ED address on the only ED of a data center.
On a redundant ED, the virtual ED address must be the IP address of a loopback interface, and it cannot be the BGP peer IP address of the ED.
Redundant EDs cannot provide access service for local VMs. They can act only as EDs. For correct communication, do not redistribute external routes on only one of the redundant EDs. However, you can redistribute the same external routes on both EDs.
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure a virtual ED address. |
evpn edge group group-ip |
By default, no virtual ED address is configured. |
EVPN-DCI configuration examples
Basic EVPN-DCI configuration example
As shown in Figure 20:
· Configure VXLAN 10 on Switch A through Switch D to provide connectivity for the VMs in the data centers.
· Configure Switch A and Switch D as VTEPs, and configure Switch B and Switch C as EDs.
1. Configure IP addresses and unicast routing settings:
# Assign IP addresses to interfaces, as shown in Figure 20. (Details not shown.)
# Configure OSPF on the transport network for the switches to reach one another. (Details not shown.)
2. Configure Switch A:
# Enable L2VPN.
# Create VXLAN 10 on VSI vpna.
[SwitchA] vsi vpna
# Create an EVPN instance on VSI vpna. Configure the switch to automatically generate an RD, and manually configure a route target for the EVPN instance.
[SwitchA-vsi-vpna-evpn-vxlan] vpn-target 123:456
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 2.2.2.2 as-number 100
[SwitchA-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[SwitchA-bgp-default-evpn] peer 2.2.2.2 enable
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 1000 to match VLAN 100.
[SwitchA-Ten-GigabitEthernet1/0/1] port trunk permit vlan 100
[SwitchA-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 100
3. Configure Switch B:
# Enable L2VPN.
# Enable DCI on the Layer 3 interface that connects Switch B to Switch C for the switches to establish a VXLAN-DCI tunnel.
[SwitchB] interface vlan-interface 12
[SwitchB-Vlan-interface12] dci enable
[SwitchB-Vlan-interface12] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna-evpn-vxlan] vpn-target 123:456
# Configure BGP to advertise BGP EVPN routes. Enable nexthop replacement for routes advertised to Switch A, and enable router MAC replacement for routes advertised to and received from Switch C.
[SwitchB] bgp 100
[SwitchB-bgp-default] peer 3.3.3.3 as-number 200
[SwitchB-bgp-default] peer 3.3.3.3 ebgp-max-hop 64
[SwitchB-bgp-default] peer 1.1.1.1 as-number 100
[SwitchB-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SwitchB-bgp-default-evpn] peer 3.3.3.3 enable
[SwitchB-bgp-default-evpn] peer 3.3.3.3 router-mac-local
[SwitchB-bgp-default-evpn] peer 1.1.1.1 enable
[SwitchB-bgp-default-evpn] peer 1.1.1.1 next-hop-local
4. Configure Switch C:
# Enable L2VPN.
# Enable DCI on the Layer 3 interface that connects Switch C to Switch B for the switches to establish a VXLAN-DCI tunnel.
[SwitchC] interface vlan-interface 12
[SwitchC-Vlan-interface12] dci enable
[SwitchC-Vlan-interface12] quit
[SwitchC] vsi vpna
[SwitchC-vsi-vpna-evpn-vxlan] vpn-target 123:456
# Configure BGP to advertise BGP EVPN routes. Enable nexthop replacement for routes advertised to Switch D, and enable router MAC replacement for routes advertised to and received from Switch B.
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 2.2.2.2 as-number 100
[SwitchC-bgp-default] peer 2.2.2.2 ebgp-max-hop 64
[SwitchC-bgp-default-evpn] peer 2.2.2.2 enable
[SwitchC-bgp-default-evpn] peer 2.2.2.2 router-mac-local
[SwitchC-bgp-default-evpn] peer 4.4.4.4 next-hop-local
5. Configure Switch D:
# Enable L2VPN.
[SwitchD] l2vpn enable
[SwitchD] vxlan tunnel mac-learning disable
[SwitchD] vsi vpna
[SwitchD-vsi-vpna] vxlan 10
[SwitchD-vsi-vpna-vxlan-10] quit
[SwitchD-vsi-vpna] evpn encapsulation vxlan
[SwitchD-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchD-vsi-vpna-evpn-vxlan] vpn-target 123:456
[SwitchD-vsi-vpna-evpn-vxlan] quit
[SwitchD-vsi-vpna] quit
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 3.3.3.3 as-number 200
[SwitchD-bgp-default] peer 3.3.3.3 connect-interface Loopback 0
[SwitchD-bgp-default-evpn] peer 3.3.3.3 enable
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 1000 to match VLAN 200.
[SwitchD] interface ten-gigabitethernet 1/0/1
[SwitchD-Ten-GigabitEthernet1/0/1] port link-type trunk
[SwitchD-Ten-GigabitEthernet1/0/1] port trunk permit vlan 200
[SwitchD-Ten-GigabitEthernet1/0/1] service-instance 1000
[SwitchD-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 200
[SwitchD-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchD-Ten-GigabitEthernet1/0/1-srv1000] quit
1. Verify the configuration on EDs. (This example uses Switch B.)
# Verify that the ED has discovered Switch A and Switch C through IMET routes and has established VXLAN and VXLAN-DCI tunnels to the switches.
[SwitchB] display evpn auto-discovery imet
Total number of automatically discovered peers: 2
VSI name: vpna
RD PE_address Tunnel_address Tunnel mode VXLAN ID
1:10 1.1.1.1 1.1.1.1 VXLAN 10
1:10 3.3.3.3 3.3.3.3 VXLAN-DCI 10
# Verify that the VXLAN and VXLAN-DCI tunnels on the ED are up.
[SwitchB] display interface tunnel
Tunnel0
Current state: UP
Bandwidth: 64 kbps
Maximum transmission unit: 64000
Tunnel source 2.2.2.2, destination 1.1.1.1
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Tunnel source 2.2.2.2, destination 3.3.3.3
Tunnel protocol/transport UDP_VXLAN-DCI/IP
# Verify that the VXLAN and VXLAN-DCI tunnels have been assigned to the VXLAN.
[SwitchB] display l2vpn vsi name vpna verbose
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 10
Tunnels:
# Verify that the ED has generated EVPN MAC address entries for the VMs.
[SwitchB] display evpn route mac
VSI name: vpna
MAC address Link ID/Name Flags Next hop
0001-0001-0011 Tunnel0 B 1.1.1.1
0001-0001-0033 Tunnel1 B 3.3.3.3
2. Verify that VM 1 and VM 2 can communicate. (Details not shown.)
EVPN-DCI intermediate VXLAN mapping configuration example
As shown in Figure 21:
· Configure VXLAN 10 on VTEP Switch A and ED Switch B, and configure VXLAN 30 on VTEP Switch D and ED Switch C.
· Configure intermediate VXLAN mapping for VXLAN 10 and VXLAN 30 to have Layer 2 connectivity:
? Map VXLAN 10 to intermediate VXLAN 500 on Switch B.
? Map VXLAN 30 to intermediate VXLAN 500 on Switch C.
# Assign IP addresses to interfaces, as shown in Figure 21. (Details not shown.)
# Enable L2VPN.
[SwitchA] vsi vpna
# Create an EVPN instance on VSI vpna. Configure the switch to automatically generate an RD and a route target for the EVPN instance.
[SwitchA] bgp 100
# Enable L2VPN.
[SwitchB] vsi vpna
# Map local VXLAN 10 to intermediate VXLAN 500.
[SwitchB-vsi-vpna-evpn-vxlan] mapping vni 500
# Create VXLAN 500 on VSI vpnb. The switch will replace the VXLAN ID of VXLAN 10's traffic with VXLAN ID 500 when performing Layer 2 forwarding.
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb] vxlan 500
[SwitchB-vsi-vpnb-vxlan-500] quit
# Create an EVPN instance on VSI vpnb. Configure the switch to automatically generate an RD, and manually configure a route target for the EVPN instance.
[SwitchB-vsi-vpnb-evpn-vxlan] vpn-target 123:456
[SwitchB] bgp 100
# Enable L2VPN.
# Create VXLAN 30 on VSI vpna.
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] vxlan 30
[SwitchC-vsi-vpna-vxlan-30] quit
# Map local VXLAN 30 to intermediate VXLAN 500.
[SwitchC-vsi-vpna-evpn-vxlan] mapping vni 500
# Create VXLAN 500 on VSI vpnb. The switch will replace the VXLAN ID of VXLAN 30's traffic with VXLAN ID 500 when performing Layer 2 forwarding.
[SwitchC] vsi vpnb
[SwitchC-vsi-vpnb] vxlan 500
[SwitchC-vsi-vpnb-vxlan-500] quit
[SwitchC-vsi-vpnb-evpn-vxlan] vpn-target 123:456
[SwitchC] bgp 200
# Enable L2VPN.
[SwitchD] vsi vpna
[SwitchD-vsi-vpna] vxlan 30
[SwitchD-vsi-vpna-vxlan-30] quit
[SwitchD-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchD] bgp 200
VSI name: vpna
1:500 3.3.3.3 3.3.3.3 VXLAN-DCI 500
Tunnel0
Current state: UP
Bandwidth: 64 kbps
Tunnel1
Current state: UP
Bandwidth: 64 kbps
# Verify that the VXLAN and VXLAN-DCI tunnels have been assigned to VXLAN 10, and that no tunnels are assigned to intermediate VXLAN 500.
[SwitchB] display l2vpn vsi verbose
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 10
Tunnels:
VSI Name: vpnb
VSI Index : 1
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 500
# Verify that the ED has generated EVPN MAC address entries for the VMs, and the remote MAC address entry has the M flag.
VSI name: vpna
0001-0001-0033 Tunnel1 BM 3.3.3.3
EVPN-DCI Layer 3 communication configuration example
As shown in Figure 22:
· Configure VXLAN 10 for data center 1, and configure VXLAN 20 for data center 2.
· Configure Switch A and Switch D as distributed EVPN gateways to perform Layer 3 forwarding between VXLAN 10 and VXLAN 20.
· Configure Switch B and Switch C as EDs.
# On VM 1, specify 10.1.1.1 as the gateway address. On VM 2, specify 10.1.2.1 as the gateway address. (Details not shown.)
# Assign IP addresses to interfaces, as shown in Figure 22. (Details not shown.)
# Enable L2VPN.
[SwitchA] vsi vpna
[SwitchA] bgp 100
# Configure RD and route target settings for VPN instance vpn1.
[SwitchA] ip vpn-instance vpn1
[SwitchA-vpn-instance-vpn1] route-distinguisher 1:1
[SwitchA-vpn-instance-vpn1] address-family ipv4
[SwitchA-vpn-ipv4-vpn1] vpn-target 2:2
[SwitchA-vpn-ipv4-vpn1] quit
[SwitchA-vpn-instance-vpn1] address-family evpn
[SwitchA-vpn-evpn-vpn1] vpn-target 1:1
[SwitchA-vpn-evpn-vpn1] quit
[SwitchA-vpn-instance-vpn1] quit
# Configure VSI-interface 1 as a distributed gateway.
[SwitchA-Vsi-interface1] ip binding vpn-instance vpn1
# Create VSI-interface 2. Associate VSI-interface 2 with VPN instance vpn1, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchA-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchA] vsi vpna
# Enable L2VPN.
[SwitchB] bgp 100
[SwitchB] ip vpn-instance vpn1
[SwitchB-vpn-instance-vpn1] route-distinguisher 1:2
[SwitchB-vpn-instance-vpn1] address-family ipv4
[SwitchB-vpn-ipv4-vpn1] vpn-target 2:2
[SwitchB-vpn-ipv4-vpn1] quit
[SwitchB-vpn-instance-vpn1] address-family evpn
[SwitchB-vpn-evpn-vpn1] vpn-target 1:1
[SwitchB-vpn-evpn-vpn1] quit
[SwitchB-vpn-instance-vpn1] quit
[SwitchB-Vsi-interface2] ip binding vpn-instance vpn1
# Enable L2VPN.
# Enable DCI on the Layer 3 interface that connects Switch C to Switch B For the switches to establish a VXLAN-DCI tunnel.
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 2.2.2.2 connect-interface Loopback 0
[SwitchC-bgp-default] peer 4.4.4.4 connect-interface Loopback 0
[SwitchC] ip vpn-instance vpn1
[SwitchC-vpn-instance-vpn1] route-distinguisher 1:3
[SwitchC-vpn-instance-vpn1] address-family ipv4
[SwitchC-vpn-ipv4-vpn1] vpn-target 2:2
[SwitchC-vpn-ipv4-vpn1] quit
[SwitchC-vpn-instance-vpn1] address-family evpn
[SwitchC-vpn-evpn-vpn1] vpn-target 1:1
[SwitchC-vpn-evpn-vpn1] quit
[SwitchC-vpn-instance-vpn1] quit
[SwitchC-Vsi-interface2] ip binding vpn-instance vpn1
# Enable L2VPN.
[SwitchD] vxlan tunnel arp-learning disable
# Create an EVPN instance on VSI vpnb. Configure the switch to automatically generate an RD and a route target for the EVPN instance.
[SwitchD] vsi vpnb
[SwitchD-vsi-vpnb] evpn encapsulation vxlan
[SwitchD-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchD-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchD-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20 on VSI vpnb.
[SwitchD-vsi-vpnb] vxlan 20
[SwitchD-vsi-vpnb-vxlan-20] quit
[SwitchD-vsi-vpnb] quit
[SwitchD] bgp 200
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 3000 to match VLAN 3.
[SwitchD-Ten-GigabitEthernet1/0/1] port trunk permit vlan 3
[SwitchD-Ten-GigabitEthernet1/0/1] service-instance 3000
[SwitchD-Ten-GigabitEthernet1/0/1-srv3000] encapsulation s-vid 3
# Map Ethernet service instance 3000 to VSI vpnb.
[SwitchD-Ten-GigabitEthernet1/0/1-srv3000] xconnect vsi vpnb
[SwitchD-Ten-GigabitEthernet1/0/1-srv3000] quit
[SwitchD] ip vpn-instance vpn1
[SwitchD-vpn-instance-vpn1] route-distinguisher 1:4
[SwitchD-vpn-instance-vpn1] address-family ipv4
[SwitchD-vpn-ipv4-vpn1] vpn-target 2:2
[SwitchD-vpn-ipv4-vpn1] quit
[SwitchD-vpn-instance-vpn1] address-family evpn
[SwitchD-vpn-evpn-vpn1] vpn-target 1:1
[SwitchD-vpn-evpn-vpn1] quit
[SwitchD-vpn-instance-vpn1] quit
[SwitchD] interface vsi-interface 1
[SwitchD-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchD-Vsi-interface1] ip address 10.1.2.1 255.255.255.0
[SwitchD-Vsi-interface1] mac-address 1-2-1
[SwitchD-Vsi-interface1] distributed-gateway local
[SwitchD-Vsi-interface1] quit
[SwitchD] interface vsi-interface 2
[SwitchD-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchD-Vsi-interface2] l3-vni 1000
[SwitchD-Vsi-interface2] quit
[SwitchD] vsi vpnb
[SwitchD-vsi-vpnb] gateway vsi-interface 1
# Verify that the ED has discovered Switch A and Switch C through MAC/IP advertisement routes and IP prefix advertisement routes, and has established VXLAN and VXLAN-DCI tunnels to the switches.
[SwitchB] display evpn auto-discovery macip-prefix
Destination IP Source IP L3VNI Tunnel mode OutgoingInterface
1.1.1.1 2.2.2.2 1000 VXLAN Vsi-interface2
3.3.3.3 2.2.2.2 1000 VXLAN-DCI Vsi-interface2
Tunnel0
Current state: UP
Bandwidth: 64 kbps
Tunnel1
Current state: UP
Bandwidth: 64 kbps
# Verify that the ED has EVPN ARP entries and EVPN routes for the VMs.
[SwitchB] display arp vpn-instance vpn1
Type: S Type: S-Static D-Dynamic O-Openflow R-Rule M-Multiport I-Invalid
1.1.1.1 0031-1900-0000 0 Tunnel0 N/A R
3.3.3.3 0031-3900-0000 0 Tunnel1 N/A R
[SwitchB] display ip routing-table vpn-instance vpn1
Destinations : 4 Routes : 4
10.1.1.0/24 BGP 255 0 1.1.1.1 Vsi2
10.1.1.11/32 BGP 255 0 1.1.1.1 Vsi2
10.1.2.0/24 BGP 255 0 3.3.3.3 Vsi2
10.1.2.22/32 BGP 255 0 3.3.3.3 Vsi2
EVPN-DCI IPv6 Layer 3 communication configuration example
As shown in Figure 23:
# On VM 1, specify 11::1 as the gateway address. On VM 2, specify 12::1 as the gateway address. (Details not shown.)
# Assign IP addresses to interfaces, as shown in Figure 23. (Details not shown.)
# Enable L2VPN.
[SwitchA] vsi vpna
[SwitchA] bgp 100
[SwitchA-vpn-instance-vpn1] address-family ipv6
[SwitchA-vpn-ipv6-vpn1] vpn-target 2:2
[SwitchA-vpn-ipv6-vpn1] quit
[SwitchA-Vsi-interface2] ipv6 address auto link-local
[SwitchA] vsi vpna
# Enable L2VPN.
[SwitchB] bgp 100
[SwitchB-vpn-instance-vpn1] address-family ipv6
[SwitchB-vpn-ipv6-vpn1] vpn-target 2:2
[SwitchB-vpn-ipv6-vpn1] quit
[SwitchB-Vsi-interface2] ipv6 address auto link-local
# Enable L2VPN.
[SwitchC] bgp 200
[SwitchC-vpn-instance-vpn1] address-family ipv6
[SwitchC-vpn-ipv6-vpn1] vpn-target 2:2
[SwitchC-vpn-ipv6-vpn1] quit
[SwitchC-Vsi-interface2] ipv6 address auto link-local
# Enable L2VPN.
[SwitchD] vxlan tunnel nd-learning disable
[SwitchD] vsi vpnb
[SwitchD] bgp 200
[SwitchD-vpn-instance-vpn1] address-family ipv6
[SwitchD-vpn-ipv6-vpn1] vpn-target 2:2
[SwitchD-vpn-ipv6-vpn1] quit
[SwitchD-Vsi-interface1] ipv6 address 12::1 64
[SwitchD-Vsi-interface2] ipv6 address auto link-local
[SwitchD] vsi vpnb
Destination IP Source IP L3VNI Tunnel mode OutInterface
Tunnel0
Current state: UP
Bandwidth: 64 kbps
Tunnel1
Current state: UP
Bandwidth: 64 kbps
# Verify that the ED has routes for the VMs.
[SwitchB] display ipv6 routing-table vpn-instance vpn1
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: 12::1/128 Protocol : BGP4+
NextHop : ::FFFF:3.3.3.3 Preference: 255
Interface : Vsi2 Cost : 0
Destination: 11::1/128 Protocol : BGP4+
NextHop : ::FFFF:1.1.1.1 Preference: 255
Destination: FE80::/10 Protocol : Direct
NextHop : :: Preference: 0
EVPN-DCI dual-homing configuration example
As shown in Figure 24:
· Configure Switch A and Switch G as distributed EVPN gateways to perform Layer 3 forwarding between VXLAN 10 and VXLAN 20.
· Configure Switch C and Switch D as EDs of data center 1, and configure Switch F as the ED of data center 2.
· Configure Switch B as an RR.
# On VM 1, specify 100.1.1.1 as the gateway address. On VM 2, specify 100.1.2.1 as the gateway address. (Details not shown.)
# Assign IP addresses to the interfaces, as shown in Figure 24. (Details not shown.)
# Configure OSPF for the switches to reach one another. (Details not shown.)
# Enable L2VPN.
[SwitchA] vsi vpna
[SwitchA] bgp 100
[SwitchA-Vsi-interface1] ip address 100.1.1.1 255.255.255.0
[SwitchA] vsi vpna
3. Configure Switch B as an RR.
[SwitchB] bgp 100
[SwitchB-bgp-default] group evpn internal
[SwitchB-bgp-default] peer evpn connect-interface loopback 0
[SwitchB-bgp-default] peer 1.1.1.1 group evpn
[SwitchB-bgp-default] peer 3.3.3.3 group evpn
[SwitchB-bgp-default] peer 4.4.4.4 group evpn
[SwitchB-bgp-default-evpn] undo policy vpn-target
[SwitchB-bgp-default-evpn] peer evpn enable
[SwitchB-bgp-default-evpn] peer evpn reflect-client
# Enable L2VPN.
# Enable DCI on the Layer 3 interface that connects Switch C to Switch E for automatic VXLAN-DCI tunnel establishment.
[SwitchC] interface vlan-interface 13
[SwitchC-Vlan-interface13] dci enable
[SwitchC-Vlan-interface13] quit
# Configure BGP to advertise BGP EVPN routes. Enable nexthop replacement for routes advertised to Switch B, and enable router MAC replacement for routes advertised to and received from Switch F.
[SwitchC] bgp 100
[SwitchC-bgp-default] peer 6.6.6.6 as-number 200
[SwitchC-bgp-default] peer 6.6.6.6 connect-interface loopback 0
[SwitchC-bgp-default] peer 6.6.6.6 ebgp-max-hop 64
[SwitchC-bgp-default-evpn] peer 6.6.6.6 enable
[SwitchC-bgp-default-evpn] peer 6.6.6.6 router-mac-local
[SwitchC-bgp-default-evpn] peer 2.2.2.2 next-hop-local
[SwitchC-vpn-instance-vpn1] route-distinguisher 1:2
[SwitchC-Vsi-interface2] mac-address 1-2-3
# Configure 1.2.3.4 as the virtual ED address, and assign the IP address to Loopback 2. Configure OSPF to advertise the virtual ED address.
[SwitchC] evpn edge group 1.2.3.4
[SwitchC] interface loopback 2
[SwitchC-LoopBack2] ip address 1.2.3.4 32
[SwitchC-LoopBack2] quit
[SwitchC] ospf
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 1.2.3.4 0.0.0.0
[SwitchC-ospf-1] quit
# Configure monitor link group 1 to associate physical interfaces connected to Switch E with Loopback 0 and Loopback 2. Set the switchover delay for the downlink interface to 90 seconds.
[SwitchC] undo monitor-link disable
[SwitchC] monitor-link group 1
[SwitchC-mtlk-group1] port ten-gigabitethernet 1/0/1 uplink
[SwitchC-mtlk-group1] port loopback 0 downlink
[SwitchC-mtlk-group1] port loopback 2 downlink
[SwitchC-mtlk-group1] downlink up-delay 90
[SwitchC-mtlk-group1] quit
# Enable DCI on the Layer 3 interface that connects Switch D to Switch E for automatic VXLAN-DCI tunnel establishment.
[SwitchD] interface vlan-interface 14
[SwitchD-Vlan-interface14] dci enable
[SwitchD-Vlan-interface14] quit
[SwitchD] bgp 100
[SwitchD-bgp-default] peer 6.6.6.6 as-number 200
[SwitchD-bgp-default] peer 6.6.6.6 connect-interface loopback 0
[SwitchD-bgp-default] peer 6.6.6.6 ebgp-max-hop 64
[SwitchD-bgp-default] peer 2.2.2.2 as-number 100
[SwitchD-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[SwitchD-bgp-default-evpn] peer 6.6.6.6 enable
[SwitchD-bgp-default-evpn] peer 6.6.6.6 router-mac-local
[SwitchD-bgp-default-evpn] peer 2.2.2.2 enable
[SwitchD-bgp-default-evpn] peer 2.2.2.2 next-hop-local
[SwitchD-vpn-instance-vpn1] route-distinguisher 1:2
[SwitchD-Vsi-interface2] mac-address 1-2-3
[SwitchD] evpn edge group 1.2.3.4
[SwitchD] interface loopback 2
[SwitchD-LoopBack2] ip address 1.2.3.4 32
[SwitchD-LoopBack2] quit
[SwitchD] ospf
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 1.2.3.4 0.0.0.0
[SwitchD-ospf-1] quit
[SwitchD] undo monitor-link disable
[SwitchD] monitor-link group 1
[SwitchD-mtlk-group1] port ten-gigabitethernet 1/0/1 uplink
[SwitchD-mtlk-group1] port loopback 0 downlink
[SwitchD-mtlk-group1] port loopback 2 downlink
[SwitchD-mtlk-group1] downlink up-delay 90
[SwitchD-mtlk-group1] quit
6. Configure Switch F:
# Enable L2VPN.
<SwitchF> system-view
[SwitchF] l2vpn enable
[SwitchF] vxlan tunnel mac-learning disable
[SwitchF] vxlan tunnel arp-learning disable
# Enable DCI on the Layer 3 interface that connects Switch F to Switch E for automatic VXLAN-DCI tunnel establishment.
[SwitchF] interface vlan-interface 15
[SwitchF-Vlan-interface15] dci enable
[SwitchF-Vlan-interface15] quit
# Configure BGP to advertise BGP EVPN routes. Enable nexthop replacement for routes advertised to Switch G, and enable router MAC replacement for routes advertised to and received from Switch C and Switch D.
[SwitchF] bgp 200
[SwitchF-bgp-default] peer 3.3.3.3 as-number 100
[SwitchF-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[SwitchF-bgp-default] peer 3.3.3.3 ebgp-max-hop 64
[SwitchF-bgp-default] peer 4.4.4.4 as-number 100
[SwitchF-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchF-bgp-default] peer 4.4.4.4 ebgp-max-hop 64
[SwitchF-bgp-default] peer 7.7.7.7 as-number 200
[SwitchF-bgp-default] peer 7.7.7.7 connect-interface loopback 0
[SwitchF-bgp-default] address-family l2vpn evpn
[SwitchF-bgp-default-evpn] peer 3.3.3.3 enable
[SwitchF-bgp-default-evpn] peer 3.3.3.3 router-mac-local
[SwitchF-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchF-bgp-default-evpn] peer 4.4.4.4 router-mac-local
[SwitchF-bgp-default-evpn] peer 7.7.7.7 enable
[SwitchF-bgp-default-evpn] peer 7.7.7.7 next-hop-local
[SwitchF-bgp-default-evpn] quit
[SwitchF-bgp-default] quit
[SwitchF] ip vpn-instance vpn1
[SwitchF-vpn-instance-vpn1] route-distinguisher 1:4
[SwitchF-vpn-instance-vpn1] address-family ipv4
[SwitchF-vpn-ipv4-vpn1] vpn-target 2:2
[SwitchF-vpn-ipv4-vpn1] quit
[SwitchF-vpn-instance-vpn1] address-family evpn
[SwitchF-vpn-evpn-vpn1] vpn-target 1:1
[SwitchF-vpn-evpn-vpn1] quit
[SwitchF-vpn-instance-vpn1] quit
[SwitchF] interface vsi-interface 2
[SwitchF-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchF-Vsi-interface2] l3-vni 1000
[SwitchF-Vsi-interface2] quit
7. Configure Switch G:
# Enable L2VPN.
<SwitchG> system-view
[SwitchG] l2vpn enable
[SwitchG] vxlan tunnel mac-learning disable
[SwitchG] vxlan tunnel arp-learning disable
[SwitchG] vsi vpnb
[SwitchG-vsi-vpnb] vxlan 20
[SwitchG-vsi-vpnb-vxlan-20] quit
[SwitchG-vsi-vpnb] evpn encapsulation vxlan
[SwitchG-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchG-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchG-vsi-vpnb-evpn-vxlan] quit
[SwitchG-vsi-vpnb] quit
[SwitchG] bgp 200
[SwitchG-bgp-default] peer 6.6.6.6 as-number 200
[SwitchG-bgp-default] peer 6.6.6.6 connect-interface loopback 0
[SwitchG-bgp-default] address-family l2vpn evpn
[SwitchG-bgp-default-evpn] peer 6.6.6.6 enable
[SwitchG-bgp-default-evpn] quit
[SwitchG-bgp-default] quit
# On Ten-GigabitEthernet 1/0/1, create Ethernet service instance 2000 to match VLAN 200.
[SwitchG] interface ten-gigabitethernet 1/0/1
[SwitchG-Ten-GigabitEthernet1/0/1] service-instance 2000
[SwitchG-Ten-GigabitEthernet1/0/1-srv2000] encapsulation s-vid 200
# Map Ethernet service instance 2000 to VSI vpnb.
[SwitchG-Ten-GigabitEthernet1/0/1-srv2000] xconnect vsi vpnb
[SwitchG-Ten-GigabitEthernet1/0/1-srv2000] quit
[SwitchG] ip vpn-instance vpn1
[SwitchG-vpn-instance-vpn1] route-distinguisher 1:4
[SwitchG-vpn-instance-vpn1] address-family ipv4
[SwitchG-vpn-ipv4-vpn1] vpn-target 2:2
[SwitchG-vpn-ipv4-vpn1] quit
[SwitchG-vpn-instance-vpn1] address-family evpn
[SwitchG-vpn-evpn-vpn1] vpn-target 1:1
[SwitchG-vpn-evpn-vpn1] quit
[SwitchG-vpn-instance-vpn1] quit
[SwitchG] interface vsi-interface 1
[SwitchG-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchG-Vsi-interface1] ip address 100.1.2.1 255.255.255.0
[SwitchG-Vsi-interface1] mac-address 2-2-2
[SwitchG-Vsi-interface1] distributed-gateway local
[SwitchG-Vsi-interface1] quit
[SwitchG] interface vsi-interface 2
[SwitchG-Vsi-interface2] ip binding vpn-instance vpn1
[SwitchG-Vsi-interface2] l3-vni 1000
[SwitchG-Vsi-interface2] quit
[SwitchG] vsi vpnb
[SwitchG-vsi-vpnb] gateway vsi-interface 1
1. Verify the configuration on EDs. (This example uses Switch C.)
# Verify that the ED has discovered Switch A and Switch F through MAC/IP advertisement routes and IP prefix advertisement routes, and has established VXLAN and VXLAN-DCI tunnels to the switches.
[SwitchC] display evpn auto-discovery macip-prefix
1.1.1.1 1.2.3.4 1000 VXLAN Vsi-interface2
6.6.6.6 1.2.3.4 1000 VXLAN-DCI Vsi-interface2
Tunnel0
Current state: UP
Bandwidth: 64 kbps
Tunnel source 1.2.3.4, destination 1.1.1.1
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Tunnel source 1.2.3.4, destination 6.6.6.6
# Verify that the ED has ARP entries and routes for the VMs.
[SwitchC] display arp vpn-instance vpn1
6.6.6.6 0031-3900-0000 0 Tunnel1 N/A R
[SwitchC] display ip routing-table vpn-instance vpn1
100.1.1.0/24 BGP 255 0 1.1.1.1 Vsi2
100.1.1.10/32 BGP 255 0 1.1.1.1 Vsi2
100.1.2.0/24 BGP 255 0 6.6.6.6 Vsi2
100.1.2.20/32 BGP 255 0 6.6.6.6 Vsi2
2. Verify the configuration on Switch A:
# Verify that the switch has discovered the virtual ED through MAC/IP advertisement routes and IP prefix advertisement routes, and has established a VXLAN tunnel to the virtual ED.
[SwitchA] display evpn auto-discovery macip-prefix
1.2.3.4 1.1.1.1 1000 VXLAN Vsi-interface2
# Verify that the VXLAN tunnel on the switch is up.
Tunnel0
Current state: UP
Bandwidth: 64 kbps
Tunnel source 1.1.1.1, destination 1.2.3.4
# Verify that the switch has ARP entries and routes for the VMs.
[SwitchA] display arp vpn-instance vpn1
1.2.3.4 0031-1900-0001 0 Tunnel0 N/A R
[SwitchA] display ip routing-table vpn-instance vpn1
100.1.2.0/24 BGP 255 0 1.2.3.4 Vsi2
100.1.2.10/32 BGP 255 0 1.2.3.4 Vsi2
3. Verify that VM 1 and VM 2 can communicate when both Switch C and Switch D are working correctly and when Switch C or Switch D fails. (Details not shown.)
