- 10-Security Configuration Guide
- 01-AAA configuration
- 02-802.1X configuration
- 04-Portal configuration
- 05-Port security configuration
- 06-Password control configuration
- 07-Keychain configuration
- 08-Public key management
- 09-PKI configuration
- 10-IPsec configuration
- 11-SSH configuration
- 12-SSL configuration
- 13-Attack detection and prevention configuration
- 14-TCP attack prevention configuration
- 15-IP source guard configuration
- 16-ARP attack protection configuration
- 17-ND attack defense configuration
- 18-uRPF configuration
- 19-MFF configuration
- 20-FIPS configuration
- 21-MACsec configuration
- 22-802.1X client configuration
- 23-Web authentication configuration
- 24-Object group configuration
- 25-Triple authentication configuration
| 11-SSH configuration | 619.16 KB |
Configuring the device as an SSH server
SSH server configuration task list
Configuring the user lines for SSH login
Configuring a client's host public key
Configuring the SSH management parameters
Specifying a PKI domain for the SSH server
Specifying the SSH service port
Configuring the device as an Stelnet client
Stelnet client configuration task list
Specifying the source IP address for outgoing SSH packets
Establishing a connection to an Stelnet server
Deleting server public keys saved in the public key file on the Stelnet client
Establishing a connection to an Stelnet server based on Suite B
Configuring the device as an SFTP client
SFTP client configuration task list
Specifying the source IP address for outgoing SFTP packets
Establishing a connection to an SFTP server
Deleting server public keys saved in the public key file on the SFTP client
Establishing a connection to an SFTP server based on Suite B
Terminating the connection with the SFTP server
Configuring the device as an SCP client
SCP client configuration task list
Specifying the source IP address for outgoing SCP packets
Establishing a connection to an SCP server
Deleting server public keys saved in the public key file on the SCP client
Establishing a connection to an SCP server based on Suite B
Specifying algorithms for SSH2
Specifying key exchange algorithms for SSH2
Specifying public key algorithms for SSH2
Specifying encryption algorithms for SSH2
Specifying MAC algorithms for SSH2
Displaying and maintaining SSH
Stelnet configuration examples
Password authentication enabled Stelnet server configuration example
Publickey authentication enabled Stelnet server configuration example
Password authentication enabled Stelnet client configuration example
Publickey authentication enabled Stelnet client configuration example
Stelnet configuration example based on 128-bit Suite B algorithms
Password authentication enabled SFTP server configuration example
Publickey authentication enabled SFTP client configuration example
SFTP configuration example based on 192-bit Suite B algorithms
SCP configuration example with password authentication
SCP configuration example based on Suite B algorithms
NETCONF over SSH configuration example with password authentication
Configuring SSH
Overview
Secure Shell (SSH) is a network security protocol. Using encryption and authentication, SSH can implement secure remote access and file transfer over an insecure network.
SSH uses the typical client-server model to establish a channel for secure data transfer based on TCP.
SSH includes two versions: SSH1.x and SSH2.0 (hereinafter referred to as SSH1 and SSH2), which are not compatible. SSH2 is better than SSH1 in performance and security.
The device supports the following SSH applications:
· Secure Telnet—Stelnet provides secure and reliable network terminal access services. Through Stelnet, a user can securely log in to a remote server. Stelnet can protect devices against attacks, such as IP spoofing and plain text password interception. The device can act as an Stelnet server or an Stelnet client.
· Secure File Transfer Protocol—Based on SSH2, SFTP uses SSH connections to provide secure file transfer. The device can act as an SFTP server, allowing a remote user to log in to the SFTP server for secure file management and transfer. The device can also act as an SFTP client, enabling a user to log in from the device to a remote device for secure file transfer.
· Secure Copy—Based on SSH2, SCP offers a secure method to copy files. The device can act as an SCP server, allowing a user to log in to the device for file upload and download. The device can also act as an SCP client, enabling a user to log in from the device to a remote device for secure file transfer.
· NETCONF over SSH—Based on SSH2, it enables users to securely log in to the device through SSH and perform NETCONF operations on the device through the NETCONF-over-SSH connections. The device can act only as a NETCONF-over-SSH server. For more information about NETCONF, see Network Management and Monitoring Configuration Guide.
When acting as an SSH client or server, the device supports the following SSH versions:
· When acting as an SSH client, the device supports only SSH2.
· When acting as an Stelnet, SFTP, or SCP server, the device supports both SSH2 and SSH1 in non-FIPS mode and only SSH2 in FIPS mode.
· When acting as a NETCONF-over-SSH server, the device supports only SSH2 in either non-FIPS mode or FIPS mode.
How SSH works
This section uses SSH2 as an example to describe the stages to establish an SSH session. For more information about these stages, see SSH Technology White Paper.
Table 1 Stages to establish an SSH session
Stages |
Connection establishment |
The SSH server listens to connection requests on port 22. After a client initiates a connection request, the server and the client establish a TCP connection. |
Version negotiation |
The two parties determine a version to use. |
Algorithm negotiation |
SSH supports multiple algorithms. Based on the local algorithms, the two parties negotiate the following algorithms: · Key exchange algorithm for generating session keys. · Encryption algorithm for encrypting data. · Public key algorithm for the digital signature and authentication. · HMAC algorithm for protecting data integrity. |
Key exchange |
The two parties use the DH exchange algorithm to dynamically generate the session keys and session ID. · The session keys are used for protecting data transfer. · The session ID is used for identifying the SSH connection. In this stage, the client also authenticates the server. |
Authentication |
The SSH server authenticates the client in response to the client's authentication request. |
Session request |
After passing the authentication, the client sends a session request to the server to request the establishment of a session (or request the Stelnet, SFTP, SCP, or NETCONF service). |
Interaction |
After the server grants the request, the client and the server start to communicate with each other in the session. In this stage, you can paste commands in text format and execute them at the CLI. The text pasted at one time must be no more than 2000 bytes. As a best practice to ensure the correct execution of commands, paste commands that are in the same view. To execute commands of more than 2000 bytes, save the commands in a configuration file, upload the file to the server through SFTP, and use it to restart the server. |
SSH authentication methods
This section describes authentication methods that are supported by the device when it acts as an SSH server.
The SSH server authenticates a client through the AAA mechanism. The password authentication process is as follows:
1. The client sends the server an authentication request that includes the encrypted username and password.
2. The server performs the following operations:
a. Decrypts the request to get the username and password in plain text.
b. Verifies the username and password locally or through remote AAA authentication.
c. Informs the client of the authentication result.
If the remote AAA server requires the user to enter a password for secondary authentication, it send the SSH server an authentication response carrying a prompt. The prompt is transparently transmitted to the client to notify the user to enter a specific password. When the user enters the correct password, the AAA server examines the password validity. If the password is valid, the SSH server returns an authentication success message to the client.
For more information about AAA, see "Configuring AAA."
NOTE: SSH1 clients do not support secondary password authentication that is initiated by the AAA server. |
Keyboard-interactive authentication
In keyboard-interactive authentication, the remote authentication server and user exchanges information for authentication as follows:
1. The remote authentication server sends a prompt to the SSH server in an authentication response.
The prompt indicates the information required to be provided by the user.
2. The SSH server transparently transmits the prompt to the client terminal.
3. The user enters the required information as prompted.
This process repeats multiple times if the remote authentication server requires more interactive information. The remote authentication server returns an authentication success message after the user provides all required interactive information.
If the remote authentication server does not require interactive information, the keyboard-interactive authentication process is the same as the password authentication.
The server authenticates a client by verifying the digital signature of the client. The publickey authentication process is as follows:
1. The client sends the server a publickey authentication request that includes the username, public key, and public key algorithm name.
If the digital certificate of the client is required in authentication, the client also encapsulates the digital certificate in the authentication request. The digital certificate carries the public key information of the client.
2. The server verifies the client's public key.
¡ If the public key is invalid, the server informs the client of the authentication failure.
¡ If the public key is valid, the server requests the digital signature of the client. After receiving the signature, the server uses the public key to verify the signature and informs the client of the authentication result.
When acting as an SSH server, the device supports using the public key algorithms DSA, ECDSA, and RSA to verify digital signatures.
When acting as an SSH client, the device supports using the public key algorithms DSA, ECDSA, and RSA to generate digital signatures.
For more information about public key configuration, see "Managing public keys."
Password-publickey authentication
The server requires SSH2 clients to pass both password authentication and publickey authentication. However, an SSH1 client only needs to pass either authentication.
Any authentication
The server requires clients to pass keyboard-interactive authentication, password authentication, or publickey authentication. Success with any one authentication method is sufficient to connect to the server.
SSH support for Suite B
Suite B contains a set of encryption and authentication algorithms that meet high security requirements. Table 2 lists all algorithms in Suite B.
The SSH server and client support using the X.509v3 certificate for identity authentication in compliance with the algorithm, negotiation, and authentication specifications defined in RFC 6239.
Security level |
Key exchange algorithm |
Encryption algorithm and HMAC algorithm |
Public key algorithm |
128-bit |
ecdh-sha2-nistp256 |
aes128-gcm |
x509v3-ecdsa-sha2-nistp256 x509v3-ecdsa-sha2-nistp384 |
192-bit |
ecdh-sha2-nistp384 |
aes256-gcm |
Both |
ecdh-sha2-nistp256 ecdh-sha2-nistp384 |
aes128-gcm aes256-gcm |
FIPS compliance
The device supports the FIPS mode that complies with NIST FIPS 140-2 requirements. Support for features, commands, and parameters might differ in FIPS mode and non-FIPS mode. For more information about FIPS mode, see "Configuring FIPS."
Tasks at a glance |
Remarks |
(Required.) Generating local key pairs |
N/A |
(Required.) Enabling the Stelnet server |
Required only for Stelnet servers. |
(Required.) Enabling the SFTP server |
Required only for SFTP servers. |
(Required.) Enabling the SCP server |
Required only for SCP servers. |
(Required.) Enabling NETCONF over SSH |
Required only for NETCONF-over-SSH servers. |
(Required.) Configuring the user lines for SSH login |
Required only for Stelnet and NETCONF-over-SSH servers. |
(Required.) Configuring a client's host public key |
Required if the authentication method is publickey, password-publickey, or any. |
Configuring the PKI domain for verifying the client's digital certificate |
See "Configuring PKI." Required if the following conditions exist: · The authentication method is publickey. · The client sends its public key to the server through a digital certificate for validity check. The PKI domain must have the CA certificate to verify the client's digital certificate. |
(Required/optional.) Configuring an SSH user |
Required if the authentication method is keyboard-interactive, publickey, password-publickey, or any. Optional if the authentication method is password. |
(Optional.) Configuring the SSH management parameters |
N/A |
(Optional.) Specifying a PKI domain for the SSH server |
N/A |
(Optional.) Specifying the SSH service port |
N/A |
(Optional.) Releasing SSH connections |
N/A |
The DSA, ECDSA, or RSA key pairs on the SSH server are required for generating the session keys and session ID in the key exchange stage. They can also be used by a client to authenticate the server. When a client authenticates the server, it compares the public key received from the server with the server's public key that the client saved locally. If the keys are consistent, the client uses the locally saved server's public key to decrypt the digital signature received from the server. If the decryption succeeds, the server passes the authentication.
The SSH application starts when you execute an SSH server command on the device. If the device does not have RSA key pairs with default names, the device automatically generates one RSA server key pair and one RSA host key pair. Both key pairs use their default names. You can also use the public-key local create command to generate DSA, ECDSA, or RSA key pairs on the device.
When you generate local key pairs, follow these restrictions and guidelines:
· Local DSA, ECDSA, and RSA key pairs for SSH use default names. You cannot assign names to the key pairs.
· To support SSH clients that use different types of key pairs, generate DSA, ECDSA, and RSA key pairs on the SSH server.
· The SSH server operating in FIPS mode supports only ECDSA and RSA key pairs. Do not generate a DSA key pair on the SSH server.
· The public-key local create rsa command generates a server key pair and a host key pair for RSA. The RSA server key pair is only used in SSH1 to encrypt the session key for secure transmission of the session key. It is not used in SSH2, because no session key transmission is required in SSH2.
· The public-key local create dsa command generates only one DSA host key pair. The key modulus length must be less than 2048 bits when you generate the DSA key pair on the SSH server. SSH1 does not support the DSA algorithm.
· The public-key local create ecdsa secp256r1 or public-key local create ecdsa secp384r1 command generates only one ECDSA host key pair.
Configuration procedure
To generate local key pairs on the SSH server:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Generate local key pairs. |
public-key local create { dsa | ecdsa { secp256r1 | secp384r1 } | rsa } |
By default, no local key pairs exist on the server. |
After you enable the Stelnet server on the device, a client can log in to the device through Stelnet.
To enable the Stelnet server:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the Stelnet server. |
ssh server enable |
By default, the Stelnet server is disabled. |
After you enable the SFTP server on the device, a client can log in to the device through SFTP.
When acting as an SFTP server, the device does not support SFTP connections initiated by SSH1 clients.
To enable the SFTP server:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the SFTP server. |
sftp server enable |
By default, the SFTP server is disabled. |
After you enable the SCP server on the device, a client can log in to the device through SCP.
When acting as an SCP server, the device does not support SCP connections initiated by SSH1 clients.
To enable the SCP server:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the SCP server. |
scp server enable |
By default, the SCP server is disabled. |
After you enable NETCONF over SSH on the device, a client can perform NETCONF operations on the device through a NETCONF-over-SSH connection.
When acting as a server in the NETCONF-over-SSH connection, the device does not support connection requests initiated by SSH1 clients.
To enable NETCONF over SSH:
Step |
Command |
Remark |
system-view |
N/A |
2. Enable NETCONF over SSH. |
netconf ssh server enable |
By default, NETCONF over SSH is disabled. For more information about NETCONF over SSH commands, see Network Management and Monitoring Command Reference. |
Depending on the SSH application, an SSH client can be an Stelnet client, SFTP client, SCP client, or NETCONF-over-SSH client.
Only Stelnet and NETCONF-over-SSH clients require the user line configuration. The user line configuration takes effect on the clients at the next login.
To configure the user lines for Stelnet and NETCONF-over-SSH clients:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter VTY user line view. |
line vty number [ ending-number ] |
N/A |
3. Set the login authentication mode to scheme. |
authentication-mode scheme |
By default, the authentication mode is password. For more information about this command, see Fundamentals Command Reference. |
In publickey authentication, the server compares the SSH username and the client's host public key received from the client with the locally saved SSH username and the client's host public key. If they are the same, the server checks the digital signature that the client sends. The client generates the digital signature by using the private key that is paired with the client's host public key.
For publickey authentication, password-publickey authentication, or any authentication, you must perform the following tasks:
1. Configure the client's DSA, ECDSA, or RSA host public key on the server.
As a best practice, configure no more than 20 SSH client's host public keys on an SSH server.
2. Specify the associated host private key on the client to generate the digital signature.
If the device acts as an SSH client, specify the public key algorithm on the client. The algorithm determines the associated host private key for generating the digital signature.
You can enter the content of a client's host public key or import the client's host public key from the public key file. Import the client's host public key as a best practice.
Entering a client's host public key
Before you enter the client's host public key, you must use the display public-key local public command on the client to obtain the client's host public key.
To enter a client's host public key:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter public key view. |
public-key peer keyname |
N/A |
3. Configure a client's host public key. |
Enter the content of the client's host public key |
The host public key must be in the DER encoding format without being converted. When you enter the content of a client's host public key, you can use spaces and carriage returns between characters. When you save the host public key, spaces and carriage returns are removed automatically. For more information, see "Managing public keys." |
4. Return to system view. |
peer-public-key end |
N/A |
Importing a client's host public key from the public key file
Before you import the host public key, upload the client's public key file (in binary) to the server, for example, through FTP or TFTP. During the import process, the server automatically converts the host public key in the public key file to a string in PKCS format.
To import a client's host public key from the public key file:
Step |
Command |
system-view |
2. Import a client's public key from the public key file. |
public-key peer keyname import sshkey filename |
Configure an SSH user and a local user depending on the authentication method.
· If the authentication method is publickey, you must create an SSH user and a local user on the SSH server. The two users must have the same username, so that the SSH user can be assigned the correct working directory and user role.
· If the authentication method is password, you must perform one of the following tasks:
¡ For local authentication, configure a local user on the SSH server.
¡ For remote authentication, configure an SSH user on a remote authentication server, for example, a RADIUS server.
You do not need to create an SSH user by using the ssh user command. However, if you want to display all SSH users, including the password-only SSH users, for centralized management, you can use this command to create them. If such an SSH user has been created, make sure you have specified the correct service type and authentication method.
· If the authentication method is keyboard-interactive, password-publickey, or any, you must create an SSH user on the SSH server and perform one of the following tasks:
In either case, the local user or the SSH user configured on the remote authentication server must have the same username as the SSH user.
For information about configuring local users and remote authentication, see "Configuring AAA."
When you configure an SSH user, follow these restrictions and guidelines:
· An SSH server supports up to 1024 SSH users.
· For an SFTP or SCP user, the working directory depends on the authentication method.
¡ If the authentication method is publickey or password-publickey, the working directory is specified by the authorization-attribute command in the associated local user view.
¡ If the authentication method is keyboard-interactive or password, the working directory is authorized by AAA.
· For an SSH user, the user role also depends on the authentication method.
¡ If the authentication method is publickey or password-publickey, the user role is specified by the authorization-attribute command in the associated local user view.
¡ If the authentication method is keyboard-interactive or password, the user role is authorized by AAA.
· If you change the authentication parameters for a logged-in SSH user, the change takes effect on the user at the next login.
· For all authentication methods except keyboard-interactive authentication and password authentication, you must specify a client's host public key or digital certificate.
¡ For a client that sends the user's public key information directly to the server, specify the client's host public key on the server. The specified public key must already exist. For more information about public keys, see "Configuring a client's host public key."
¡ For a client that sends the user's public key information to the server through a digital certificate, specify the PKI domain on the server. This PKI domain verifies the client's digital certificate. For successful verification, the specified PKI domain must have the correct CA certificate. To specify the PKI domain, use the ssh user or ssh server pki-domain command. For more information about configuring a PKI domain, see "Configuring PKI."
· When the device operates as an SSH server in FIPS mode, the device does not support the authentication method of any or publickey.
To configure an SSH user, and specify the service type and authentication method:
Step |
Command |
system-view |
2. Create an SSH user, and specify the service type and authentication method. |
In non-FIPS mode: ·
In FIPS mode: |
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the SSH server to support SSH1 clients. |
ssh server compatible-ssh1x enable |
By default, the SSH server does not support SSH1 clients. This command is not available in FIPS mode. |
3. Enable SSH algorithm renegotiation and key re-exchange. |
ssh server key-re-exchange enable [ interval interval ] |
By default, SSH algorithm renegotiation and key re-exchange are disabled. This command is not available in FIPS mode. This command takes effect only on new SSH connections that are established after this command is configured, and it does not affect existing SSH connections. |
4. Set the minimum interval for updating the RSA server key pair. |
ssh server rekey-interval interval |
By default, the RSA server key pair is not updated. This command takes effect only on SSH1 users. This command is not available in FIPS mode. |
5. Set the SSH user authentication timeout timer. |
ssh server authentication-timeout time-out-value |
The default setting is 60 seconds. If a user does not finish the authentication when the timeout timer expires, the connection cannot be established. |
6. Set the maximum number of SSH authentication attempts. |
ssh server authentication-retries retries |
The default setting is 3. If the authentication method is any, the total number of publickey authentication attempts and password authentication attempts cannot exceed the upper limit. |
7. Specify an SSL login control ACL to control SSH user connections. |
Control IPv4 SSH user connections: ·
Control IPv6 SSH user connections: |
By default, no ACLs are specified and all SSH users can initiate SSH connections to the server. |
8. Enable logging for SSH logins that are denied by the SSL login control ACL. |
ssh server acl-deny-log enable |
By default, logging is disabled for logins that are denied by the SSH login control ACL. This command enables SSH to send a log message to the information center when an SSH login from an IP address was denied by the SSH login control ACL. The denied login IP address is contained in the log message. |
9. Set the DSCP value in the packets that the SSH server sends to the SSH clients. |
Set the DSCP value in IPv4 packets: ·
Set the DSCP value in IPv6 packets: |
The default setting is 48. The DSCP value of a packet defines the priority of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority. |
10. Set the SFTP connection idle timeout timer. |
sftp server idle-timeout time-out-value |
The default setting is 10 minutes. When the idle timeout timer expires, the system automatically tears the connection down. |
11. Set the maximum number of concurrent online SSH users. |
aaa session-limit ssh max-sessions |
The default setting is 32. When the number of online SSH users reaches the upper limit, the system denies new SSH connection requests. Changing the upper limit does not affect online SSH users. |
The PKI domain specified for the SSH server has the following functions:
· The SSH server uses the PKI domain to send its certificate to the client in the key exchange stage.
· The SSH server uses the PKI domain to authenticate the client's certificate if no PKI domain is specified for the client authentication by using the ssh user command.
To specify a PKI domain for the SSH server:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify a PKI domain for the SSH server. |
ssh server pki-domain domain-name |
By default, no PKI domain is specified for the SSH server. |
The default port of SSH service is 22. Perform this task to specify another port for the SSH service.
If you modify the SSH port number when the SSH server is enabled, the SSH service is restarted and all SSH connections are terminated after the modification. SSH users must reconnect to the SSH server to access the server.
If you set the SSH port to a well-known port number, the service that uses the well-known port number might fail to start. Well-known port numbers are in the range of 1 to 1024.
To specify the SSH service port:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify a port for the SSH service. |
ssh server port port-number |
By default, the SSH port is 22. |
The system supports simultaneous operations of multiple SSH users on the device. To remove or avoid the affection of an SSH user's operations on the administrator, the administrator can release the connection of the SSH user.
To release SSH connections:
Task |
Command |
Remarks |
Release SSH connections. |
free ssh { username username | user-ip { ip-address | ipv6 ipv6-address } [ port port-number ] | user-pid pid-number } |
Execute this command in user view. |
Tasks at a glance |
Remarks |
Only required when the Stelnet server uses the authentication method publickey, password-publickey, or any. |
(Optional.) Specifying the source IP address for outgoing SSH packets |
N/A |
(Required.) Establishing a connection to an Stelnet server |
N/A |
(Optional.) Deleting server public keys saved in the public key file on the Stelnet client |
N/A |
(Optional.) Establishing a connection to an Stelnet server based on Suite B |
N/A |
Generate local key pairs on the Stelnet client when the Stelnet server uses the authentication method publickey, password-publickey, or any.
When you generate local key pairs on an Stelnet client, follow these restrictions and guidelines:
· The Stelnet client operating in FIPS mode supports only ECDSA and RSA key pairs.
· The key modulus length must be less than 2048 bits when you generate a DSA key pair.
To generate local key pairs on the Stelnet client:
Step |
Command |
Remarks |
system-view |
N/A |
By default, no local key pairs exist on an Stelnet client. |
After you specify the source IP address for outgoing SSH packets on an SSH client, the client uses the specified IP address to communicate with the SSH server.
As a best practice, specify the IP address of the loopback interface as the source address of SSH packets for the following purposes:
· Ensuring the communication between the Stelnet client and the Stelnet server.
· Improving the manageability of Stelnet clients in authentication service.
To specify the source IP address for outgoing SSH packets:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify the source address for outgoing SSH packets. |
Specify the source IPv4 address for SSH
packets: ·
Specify the source IPv6 address for SSH
packets: |
By default, the source IP address for SSH packets is not configured. For outgoing IPv4 SSH packets, the device uses the primary IPv4 address of the output interface in the matching route as the source address of the packets. For outgoing IPv6 SSH packets, the device automatically selects an IPv6 address as the source address of the packets in compliance with RFC 3484. |
When you try to access an Stelnet server, the device must use the server's host public key to authenticate the server. If the server's host public key is not configured on the device, the device will notify you to confirm whether to continue with the access.
· If you choose to continue, the device accesses the server and downloads the server's host public key.
· If you choose to not continue, the connection cannot be established.
As a best practice, configure the server's host public key on the device in an insecure network.
The client cannot establish connections to both IPv4 and IPv6 Stelnet servers.
To establish a connection to an IPv4 Stelnet server:
Task |
Command |
Remarks |
Establish a connection to an IPv4 Stelnet server. |
In non-FIPS mode: ·
In FIPS mode: |
Available in user view. |
To establish a connection to an IPv6 Stelnet server:
Task |
Command |
Remarks |
Establish a connection to an IPv6 Stelnet server. |
In non-FIPS mode: ·
In FIPS mode: |
When the Stelnet client switches to FIPS mode but the locally saved server public key does not comply with FIPS, the client cannot connect to the server. To connect to the server, delete the server public key saved on the client and make sure a FIPS-compliant public key has been generated on the server.
To delete server public keys saved in the public key file on the Stelnet client:
Step |
Command |
system-view |
2. Delete server public keys saved in the public key file on the Stelnet client. |
delete ssh client server-public-key [ server-ip ip-address ] |
Task |
Command |
Remarks |
Establish a connection to an Stelnet server based on Suite B. |
server based on Suite B: ·
server based on Suite B: |
Available in user view. The client cannot establish connections to both IPv4 and IPv6 Stelnet servers. |
Tasks at a glance |
Remarks |
Only required when the SFTP server uses the authentication method publickey, password-publickey, or any. |
(Optional.) Specifying the source IP address for outgoing SFTP packets |
N/A |
(Required.) Establishing a connection to an SFTP server |
N/A |
(Optional.) Deleting server public keys saved in the public key file on the SFTP client |
N/A |
(Optional.) Establishing a connection to an SFTP server based on Suite B |
N/A |
(Optional.) Working with SFTP directories |
N/A |
(Optional.) Working with SFTP files |
N/A |
(Optional.) Displaying help information |
N/A |
(Optional.) Terminating the connection with the SFTP server |
N/A |
Generate local key pairs on the SFTP client when the SFTP server uses the authentication method publickey, password-publickey, or any.
When you generate local key pairs on an SFTP client, follow these restrictions and guidelines:
· The SFTP client operating in FIPS mode supports only ECDSA and RSA key pairs.
To generate local key pairs on the SFTP client:
Step |
Command |
Remarks |
system-view |
N/A |
By default, no local key pairs exist on an SFTP client. |
After you specify the source IP address for outgoing SFTP packets on an SFTP client, the client uses the specified IP address to communicate with the SFTP server.
As a best practice, specify the IP address of the loopback interface as the source address of SFTP packets for the following purposes:
· Ensuring the communication between the SFTP client and the SFTP server.
· Improving the manageability of SFTP clients in authentication service.
To specify the source IP address for outgoing SFTP packets:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify the source address for outgoing SFTP packets. |
Specify the source IPv4 address for outgoing SFTP
packets: ·
Specify the source IPv6 address for outgoing SFTP
packets: |
By default, the source IP address for SFTP packets is not configured. For outgoing IPv4 SFTP packets, the device uses the primary IPv4 address of the output interface in the matching route as the source address of the packets. For outgoing IPv6 SFTP packets, the device automatically selects an IPv6 address as the source address of the packets in compliance with RFC 3484. |
When you try to access an SFTP server, the device must use the server's host public key to authenticate the server. If the server's host public key is not configured on the device, the device will notify you to confirm whether to continue with the access.
After the connection is established, you are in SFTP client view of the server and can perform file or directory operations.
The client cannot establish connections to both IPv4 and IPv6 SFTP servers.
To establish a connection to an IPv4 SFTP server:
Task |
Command |
Remarks |
Establish a connection to an IPv4 SFTP server. |
In non-FIPS mode: ·
In FIPS mode: |
To establish a connection to an IPv6 SFTP server:
Task |
Command |
Remarks |
Establish a connection to an IPv6 SFTP server. |
In non-FIPS mode: ·
In FIPS mode: |
When the SFTP client switches to FIPS mode but the locally saved server public key does not comply with FIPS, the client cannot connect to the server. To connect to the server, delete the server public key saved on the client and make sure a FIPS-compliant public key has been generated on the server.
To delete server public keys saved in the public key file on the SFTP client:
Step |
Command |
system-view |
2. Delete server public keys saved in the public key file on the SFTP client. |
To establish a connection to an SFTP server based on Suite B:
Task |
Command |
Remarks |
Establish a connection to an SFTP server based on Suite B. |
based on Suite B: ·
based on Suite B: |
Available in user view. The client cannot establish connections to both IPv4 and IPv6 SFTP servers. |
Task |
Command |
Remarks |
Change the working directory on the SFTP server. |
cd [ remote-path ] |
Available in SFTP client view. |
Return to the upper-level directory. |
cdup |
Display the current working directory on the SFTP server. |
pwd |
Display files under a directory. |
· dir [ -a | -l ] [ remote-path ] · ls [ -a | -l ] [ remote-path ] |
Available in SFTP client view. The dir command has the same function as the ls command. |
Change the name of a directory on the SFTP server. |
rename oldname newname |
Create a new directory on the SFTP server. |
mkdir remote-path |
Delete one or more directories from the SFTP server. |
rmdir remote-path |
Task |
Command |
Remarks |
Change the name of a file on the SFTP server. |
rename old-name new-name |
Download a file from the SFTP server and save it locally. |
get remote-file [ local-file ] |
Upload a local file to the SFTP server. |
put local-file [ remote-file ] |
· delete remote-file · remove remote-file |
Available in SFTP client view. The delete command has the same function as the remove command. |
Task |
Command |
Remarks |
Display the help information of SFTP client commands. |
· help · ? |
Task |
Command |
Remarks |
Terminate the connection with the SFTP server and return to user view. |
· bye · exit · quit |
Available in SFTP client view. These three commands have the same function. |
Tasks at a glance |
Remarks |
Only required when the SCP server uses the authentication method publickey, password-publickey, or any. |
(Optional.) Specifying the source IP address for outgoing SCP packets |
N/A |
(Required.) Establishing a connection to an SCP server |
N/A |
(Optional.) Deleting server public keys saved in the public key file on the SCP client |
N/A |
(Optional.) Establishing a connection to an SCP server based on Suite B |
N/A |
Generate local key pairs on the SCP client when the SCP server uses the authentication method publickey, password-publickey, or any.
When you generate local key pairs on an SCP client, follow these restrictions and guidelines:
· The SCP client operating in FIPS mode supports only ECDSA and RSA key pairs.
To generate local key pairs on the SCP client:
Step |
Command |
Remarks |
system-view |
N/A |
By default, no local key pairs exist on an SCP client. |
After you specify the source IP address for outgoing SCP packets on an SCP client, the client uses the specified IP address to communicate with the SCP server.
As a best practice, specify the IP address of a loopback interface as the source address of SCP packets for the following purposes:
· Ensuring the communication between the SCP client and the SCP server.
· Improving the manageability of SCP clients in authentication service.
To specify the source IP address for outgoing SCP packets:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify the source address for outgoing SCP packets. |
Specify the source IPv4 address for outgoing SCP
packets: ·
Specify the source IPv6 address for outgoing SCP
packets: |
By default, the source IP address for SCP packets is not configured. For outgoing IPv4 SCP packets, an SCP client uses the primary IPv4 address of the output interface in the matching routing entry as the source address of the packets. For outgoing IPv6 SCP packets, an SCP client automatically selects an IPv6 address as the source address of the packets in compliance with RFC 3484. |
When you try to access an SCP server, the device must use the server's host public key to authenticate the server. If the server's host public key is not configured on the device, the device will notify you to confirm whether to continue with the access.
The client cannot establish connections to both IPv4 and IPv6 SCP servers.
To establish a connection to an IPv4 SCP server:
Task |
Command |
Remarks |
Connect to an IPv4 SCP server, and transfer files with the server. |
In non-FIPS mode: ·
In FIPS mode: |
To establish a connection to an IPv6 SCP server:
Task |
Command |
Remarks |
Connect to an IPv6 SCP server, and transfer files with the server. |
In non-FIPS mode: ·
In FIPS mode: |
When the SCP client switches to FIPS mode but the locally saved server public key does not comply with FIPS, the client cannot connect to the server. To connect to the server, delete the server public key saved on the client and make sure a FIPS-compliant public key has been generated on the server.
To delete server public keys saved in the public key file on the SCP client:
Step |
Command |
system-view |
2. Delete server public keys saved in the public key file on the SCP client. |
Task |
Command |
Remarks |
Establish a connection to an SCP server based on Suite B. |
Establish a connection to an IPv4 SCP server
based on Suite B: ·
Establish a connection to an IPv6 SCP server
based on Suite B: |
Available in user view. The client cannot establish connections to both IPv4 and IPv6 SCP servers. |
Perform this task to specify the following types of algorithms that the SSH2 client and server use for algorithm negotiation during the Stelnet, SFTP, or SCP session establishment:
· Key exchange algorithms.
· Public key algorithms.
· Encryption algorithms.
· MAC algorithms.
If you specify algorithms, SSH2 uses only the specified algorithms for algorithm negotiation. The client uses the specified algorithms to initiate the negotiation, and the server uses the matching algorithms to negotiate with the client.
If multiple algorithms of the same type are specified, the algorithm specified earlier has a higher priority during negotiation. The specified SSH2 algorithms do not affect SSH1 sessions.
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify key exchange algorithms for SSH2. |
In non-FIPS mode: ·
In FIPS mode: |
In non-FIPS mode: ·
In FIPS mode: |
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify public key algorithms for SSH2. |
In non-FIPS mode: ·
In FIPS mode: |
In non-FIPS mode: ·
In FIPS mode: |
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify encryption algorithms for SSH2. |
In non-FIPS mode: ·
In FIPS mode: |
In non-FIPS mode: ·
In FIPS mode: |
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify MAC algorithms for SSH2. |
In non-FIPS mode: ·
In FIPS mode: |
In non-FIPS mode: ·
In FIPS mode: |
Task |
Command |
Display the public keys of the local key pairs. |
display public-key local { dsa | ecdsa | rsa } public [ name publickey-name ] |
Display information about peer public keys. |
display public-key peer [ brief | name publickey-name ] |
Display the source IP address configuration of the SCP client. |
display scp client source |
Display the source IP address configuration of the SFTP client. |
display sftp client source |
Display server public key information saved in the public key file on the SSH client |
display ssh client server-public-key [ server-ip ip-address ] |
Display the source IP address configuration of for the Stelnet client. |
display ssh client source |
Display SSH server status or sessions. |
display ssh server { session | status } |
Display SSH user information on the SSH server. |
display ssh user-information [ username ] |
Display algorithms used by SSH2 in the algorithm negotiation stage. |
display ssh2 algorithm |
Unless otherwise noted, devices in the configuration examples operate in non-FIPS mode.
When the device acts as an Stelnet server operating in FIPS mode, only ECDSA and RSA key pairs are supported. Do not generate a DSA key pair on the Stelnet server.
Network requirements
As shown in Figure 1:
· The switch acts as the Stelnet server and uses password authentication.
· The username and password of the client are saved on the switch.
Establish an Stelnet connection between the host and the switch, so you can log in to the switch to configure and manage the switch.
1. Configure the Stelnet server:
# Generate RSA key pairs.
<Switch> system-view
[Switch] public-key local create rsa
The range of public key modulus is (512 ~ 2048).
If the key modulus is greater than 512, it will take a few minutes.
Press CTRL+C to abort.
Generating Keys...
# Generate a DSA key pair.
[Switch] public-key local create dsa
Generating Keys...
# Generate an ECDSA key pair.
[Switch] public-key local create ecdsa secp256r1
Generating Keys...
# Enable the Stelnet server.
[Switch] ssh server enable
# Assign an IP address to VLAN-interface 2. The Stelnet client uses this address as the destination for SSH connection.
[Switch-Vlan-interface2] ip address 192.168.1.40 255.255.255.0
[Switch-Vlan-interface2] quit
# Set the authentication mode to AAA for user lines.
[Switch] line vty 0 63
[Switch-line-vty0-63] authentication-mode scheme
[Switch-line-vty0-63] quit
# Create a local device management user named client001.
[Switch] local-user client001 class manage
# Set the password to aabbcc in plain text for local user client001.
[Switch-luser-manage-client001] password simple aabbcc
# Authorize local user client001 to use the SSH service.
[Switch-luser-manage-client001] service-type ssh
# Assign the network-admin user role to local user client001.
[Switch-luser-manage-client001] authorization-attribute user-role network-admin
[Switch-luser-manage-client001] quit
# Create an SSH user named client001. Specify the service type as stelnet and the authentication method as password for the user.
[Switch] ssh user client001 service-type stelnet authentication-type password
2. Establish a connection to the Stelnet server:
There are different types of Stelnet client software, such as PuTTY and OpenSSH. This example uses an Stelnet client that runs PuTTY version 0.58.
To establish a connection to the Stelnet server:
a. Launch PuTTY.exe to enter the interface shown in Figure 2.
b. In the Host Name (or IP address) field, enter the IP address 192.168.1.40 of the Stelnet server.
Figure 2 Specifying the host name (or IP address)
c. Click Open to connect to the server.
If the connection is successfully established, the system notifies you to enter the username and password. After entering the username (client001 in this example) and password (aabbcc in this example), you can enter the CLI of the server.
As shown in Figure 3, the switch acts as the Stelnet server, and it uses publickey authentication and the RSA public key algorithm.
In the server configuration, the client's host public key is required. Use the client software to generate RSA key pairs on the client before configuring the Stelnet server.
The configuration procedure is as follows:
1. Generate RSA key pairs on the Stelnet client:
a. Run PuTTYGen.exe on the client, select SSH-2 RSA and click Generate.
Figure 4 Generating a key pair on the client
b. Continue moving the mouse during the key generating process, but do not place the mouse over the green progress bar shown in Figure 5. Otherwise, the progress bar stops moving and the key pair generating progress stops.
c. After the key pair is generated, click Save public key to save the public key.
A file saving window appears.
Figure 6 Saving a key pair on the client
d. Enter a file name (key.pub in this example), and click Save.
e. On the page shown in Figure 6, click Save private key to save the private key.
A confirmation dialog box appears.
f. Click Yes.
g. Enter a file name (private.ppk in this example), and click Save.
h. Transmit the public key file to the server through FTP or TFTP. (Details not shown.)
2. Configure the Stelnet server:
Generating Keys...
Generating Keys...
Generating Keys...
# Assign an IP address to VLAN-interface 2. The Stelnet client uses this IP address as the destination for SSH connection.
# Import the client's public key from the public key file key.pub and name it switchkey.
[Switch] public-key peer switchkey import sshkey key.pub
# Create an SSH user named client002. Specify the authentication method as publickey for the user, and assign the public key switchkey to the user.
[Switch] ssh user client002 service-type stelnet authentication-type publickey assign publickey switchkey
# Create a local device management user named client002.
[Switch] local-user client002 class manage
# Authorize local user client002 to use the SSH service.
[Switch-luser-manage-client002] service-type ssh
# Assign the network-admin user role to local user client002.
[Switch-luser-manage-client002] authorization-attribute user-role network-admin
[Switch-luser-manage-client002] quit
3. Specify the private key file and establish a connection to the Stelnet server:
a. Launch PuTTY.exe on the Stelnet client to enter the interface shown in Figure 7.
b. In the Host Name (or IP address) field, enter the IP address of the Stelnet server 192.168.1.40.
Figure 7 Specifying the host name (or IP address)
c. Select Connection > SSH from the navigation tree.
The window shown in Figure 8 appears.
d. Specify the Preferred SSH protocol version as 2.
Figure 8 Specifying the preferred SSH version
e. Select Connection > SSH > Auth from the navigation tree.
The window shown in Figure 9 appears.
f. Click Browse… to bring up the file selection window, navigate to the private key file (private.ppk in this example), and click OK.
Figure 9 Specifying the private key file
g. Click Open to connect to the server.
If the connection is successfully established, the system notifies you to enter the username. After entering the username (client002), you can enter the CLI of the server.
As shown in Figure 10:
· Switch B acts as the Stelnet server and uses password authentication.
· The username and password of the client are saved on Switch B.
Establish an Stelnet connection between Switch A and Switch B, so you can log in to Switch B to configure and manage Switch B.
[SwitchB] public-key local create rsa
Generating Keys...
[SwitchB] public-key local create dsa
Generating Keys...
[SwitchB] public-key local create ecdsa secp256r1
Generating Keys...
[SwitchB] ssh server enable
# Assign an IP address to VLAN-interface 2. The Stelnet client uses this address as the destination address of the SSH connection.
[SwitchB-Vlan-interface2] ip address 192.168.1.40 255.255.255.0
[SwitchB] line vty 0 63
[SwitchB-line-vty0-63] authentication-mode scheme
[SwitchB-line-vty0-63] quit
[SwitchB] local-user client001 class manage
[SwitchB-luser-manage-client001] password simple aabbcc
[SwitchB-luser-manage-client001] service-type ssh
[SwitchB-luser-manage-client001] authorization-attribute user-role network-admin
[SwitchB-luser-manage-client001] quit
[SwitchB] ssh user client001 service-type stelnet authentication-type password
[SwitchA-Vlan-interface2] ip address 192.168.1.56 255.255.255.0
[SwitchA] quit
Before establishing a connection to the server, you can configure the server's host public key on the client to authenticate the server.
¡ To configure the server's host public key on the client, perform the following tasks:
# Use the display public-key local dsa public command on the server to display the server's host public key. (Details not shown.)
# Enter public key view of the client and copy the host public key of the server to the client.
[SwitchA] public-key peer key1
Enter public key view. Return to system view with "peer-public-key end" command.
[SwitchA-pkey-public-key-key1]308201B73082012C06072A8648CE3804013082011F0281810
0D757262C4584C44C211F18BD96E5F0
[SwitchA-pkey-public-key-key1]61C4F0A423F7FE6B6B85B34CEF72CE14A0D3A5222FE08CECE
65BE6C265854889DC1EDBD13EC8B274
[SwitchA-pkey-public-key-key1]DA9F75BA26CCB987723602787E922BA84421F22C3C89CB9B0
6FD60FE01941DDD77FE6B12893DA76E
[SwitchA-pkey-public-key-key1]EBC1D128D97F0678D7722B5341C8506F358214B16A2FAC4B3
68950387811C7DA33021500C773218C
[SwitchA-pkey-public-key-key1]737EC8EE993B4F2DED30F48EDACE915F0281810082269009E
14EC474BAF2932E69D3B1F18517AD95
[SwitchA-pkey-public-key-key1]94184CCDFCEAE96EC4D5EF93133E84B47093C52B20CD35D02
492B3959EC6499625BC4FA5082E22C5
[SwitchA-pkey-public-key-key1]B374E16DD00132CE71B020217091AC717B612391C76C1FB2E
88317C1BD8171D41ECB83E210C03CC9
[SwitchA-pkey-public-key-key1]B32E810561C21621C73D6DAAC028F4B1585DA7F42519718CC
9B09EEF0381840002818000AF995917
[SwitchA-pkey-public-key-key1]E1E570A3F6B1C2411948B3B4FFA256699B3BF871221CC9C5D
F257523777D033BEE77FC378145F2AD
[SwitchA-pkey-public-key-key1]D716D7DB9FCABB4ADBF6FB4FDB0CA25C761B308EF53009F71
01F7C62621216D5A572C379A32AC290
[SwitchA-pkey-public-key-key1]E55B394A217DA38B65B77F0185C8DB8095522D1EF044B465E
8716261214A5A3B493E866991113B2D
[SwitchA-pkey-public-key-key1]485348
[SwitchA-pkey-public-key-key1] peer-public-key end
[SwitchA] quit
# Establish an SSH connection to the server, and specify the host public key of the server.
<SwitchA> ssh2 192.168.1.40 public-key key1
Username: client001
Connecting to 192.168.1.40 port 22.
[email protected]'s password:
Enter a character ~ and a dot to abort.
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
<SwitchB>
After you enter the correct password, you successfully log in to Switch B.
¡ If the client does not have the server's host public key, the system will notify you to confirm the further access when you access the server. Select Yes to access the server and download the server's host public key.
Username: client001
The server is not authenticated. Continue? [Y/N]:y
Do you want to save the server public key? [Y/N]:y
<SwitchB>
After you enter the correct password, you can access Switch B successfully. At the next connection attempt, the client authenticates the server by using the saved server's host public key on the client.
As shown in Figure 11, Switch B acts as the Stelnet server, and it uses publickey authentication and the DSA public key algorithm.
In the server configuration, the client's host public key is required. Generate a DSA key pair on the client before configuring the Stelnet server.
1. Configure the Stelnet client:
[SwitchA] public-key local create dsa
Generating Keys...
# Export the DSA host public key to a public key file named key.pub.
[SwitchA] public-key local export dsa ssh2 key.pub
[SwitchA] quit
# Transmit the public key file key.pub to the server through FTP or TFTP. (Details not shown.)
Generating Keys...
Generating Keys...
Generating Keys...
# Assign an IP address to VLAN-interface 2. The Stelnet client uses this address as the destination address for SSH connection.
# Import the peer public key from the public key file key.pub, and name it switchkey.
[SwitchB] public-key peer switchkey import sshkey key.pub
# Create an SSH user named client002. Specify the authentication method as publickey for the user. Assign the public key switchkey to the user.
[SwitchB] ssh user client002 service-type stelnet authentication-type publickey assign publickey switchkey
[SwitchB] local-user client002 class manage
[SwitchB-luser-manage-client002] service-type ssh
[SwitchB-luser-manage-client002] authorization-attribute user-role network-admin
[SwitchB-luser-manage-client002] quit
3. Establish an SSH connection to the Stelnet server 192.168.1.40.
<SwitchA> ssh2 192.168.1.40 identity-key dsa
Username: client002
Do you want to save the server public key? [Y/N]:n
<SwitchB>
Select Yes to access the server and download the server's host public key. At the next connection attempt, the client authenticates the server by using the saved server's host public key on the client.
As shown in Figure 12, Switch A acts as an Stelnet client (SSH2). Switch B acts as the Stelnet server (SSH2), and it uses publickey authentication.
Configure Switch A to establish an Stelnet connection to Switch B based on the 128-bit Suite B algorithms. After the connection is established, you can log in to Switch B as a network-admin to configure and manage Switch B.
1. Generate the client's certificate and the server's certificate. (Details not shown.)
You must first configure the certificates of the server and the client because they are required for identity authentication between the two parties.
In this example, the server's certificate file is ssh-server-ecdsa256.p12 and the client's certificate file is ssh-client-ecdsa256.p12.
2. Configure the Stelnet client:
NOTE: You can modify the pkix version of the client software OpenSSH to support Suite B. This example uses an H3C switch as an Stelnet Suite B client. |
# Upload the server's certificate file ssh-server-ecdsa256.p12 and the client's certificate file ssh-client-ecdsa256.p12 to the Stelnet client through FTP or TFTP. (Details not shown.)
# Create a PKI domain named server256 for verifying the server's certificate and enter its view.
[SwitchA] pki domain server256
# Disable CRL checking.
[SwitchA-pki-domain-server256] undo crl check enable
[SwitchA-pki-domain-server256] quit
# Import local certificate file ssh-server-ecdsa256.p12 to PKI domain server256.
[SwitchA] pki import domain server256 p12 local filename ssh-server-ecdsa256.p12
The system is going to save the key pair. You must specify a key pair name, which is a case-insensitive string of 1 to 64 characters. Valid characters include a to z, A to Z, 0 to 9, and hyphens (-).
Please enter the key pair name[default name: server256]:
# Display information about local certificates in PKI domain server256.
[SwitchA] display pki certificate domain server256 local
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 3 (0x3)
Signature Algorithm: ecdsa-with-SHA256
Issuer: C=CN, ST=Beijing, L=Beijing, O=H3C, OU=Software, CN=SuiteB CA
Validity
Not Before: Aug 21 08:39:51 2015 GMT
Not After : Aug 20 08:39:51 2016 GMT
Subject: C=CN, ST=Beijing, O=H3C, OU=Software, CN=SSH Server secp256
Subject Public Key Info:
Public Key Algorithm: id-ecPublicKey
Public-Key: (256 bit)
pub:
04:a2:b4:b4:66:1e:3b:d5:50:50:0e:55:19:8d:52:
6d:47:8c:3d:3d:96:75:88:2f:9a:ba:a2:a7:f9:ef:
0a:a9:20:b7:b6:6a:90:0e:f8:c6:de:15:a2:23:81:
3c:9e:a2:b7:83:87:b9:ad:28:c8:2a:5e:58:11:8e:
c7:61:4a:52:51
ASN1 OID: prime256v1
NIST CURVE: P-256
X509v3 extensions:
X509v3 Basic Constraints:
CA:FALSE
Netscape Comment:
OpenSSL Generated Certificate
X509v3 Subject Key Identifier:
08:C1:F1:AA:97:45:19:6A:DA:4A:F2:87:A1:1A:E8:30:BD:31:30:D7
X509v3 Authority Key Identifier:
keyid:5A:BE:85:49:16:E5:EB:33:80:25:EB:D8:91:50:B4:E6:3E:4F:B8:22
30:65:02:31:00:a9:16:e9:c1:76:f0:32:fc:4b:f9:8f:b6:7f:
31:a0:9f:de:a7:cc:33:29:27:2c:71:2e:f9:0d:74:cb:25:c9:
00:d2:52:18:7f:58:3f:cc:7e:8b:d3:42:65:00:cb:63:f8:02:
30:01:a2:f6:a1:51:04:1c:61:78:f6:6b:7e:f9:f9:42:8d:7c:
a7:bb:47:7c:2a:85:67:0d:81:12:0b:02:98:bc:06:1f:c1:3c:
9b:c2:1b:4c:44:38:5a:14:b2:48:63:02:2b
# Create a PKI domain named client256 for the client's certificate and enter its view.
[SwitchA] pki domain client256
[SwitchA-pki-domain-client256] undo crl check enable
[SwitchA-pki-domain-client256] quit
# Import local certificate file ssh-client-ecdsa256.p12 to PKI domain client256.
[SwitchA] pki import domain client256 p12 local filename ssh-client-ecdsa256.p12
Please enter the key pair name[default name: client256]:
# Display information about local certificates in PKI domain client256.
[SwitchA] display pki certificate domain client256 local
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 4 (0x4)
Validity
Not Before: Aug 21 08:41:09 2015 GMT
Not After : Aug 20 08:41:09 2016 GMT
Subject: C=CN, ST=Beijing, O=H3C, OU=Software, CN=SSH Client secp256
pub:
04:da:e2:26:45:87:7a:63:20:e7:ca:7f:82:19:f5:
96:88:3e:25:46:f8:2f:9a:4c:70:61:35:db:e4:39:
b8:38:c4:60:4a:65:28:49:14:32:3c:cc:6d:cd:34:
29:83:84:74:a7:2d:0e:75:1c:c2:52:58:1e:22:16:
12:d0:b4:8a:92
NIST CURVE: P-256
X509v3 extensions:
CA:FALSE
Netscape Comment:
1A:61:60:4D:76:40:B8:BA:5D:A1:3C:60:BC:57:98:35:20:79:80:FC
30:66:02:31:00:9a:6d:fd:7d:ab:ae:54:9a:81:71:e6:bb:ad:
5a:2e:dc:1d:b3:8a:bf:ce:ee:71:4e:8f:d9:93:7f:a3:48:a1:
5c:17:cb:22:fa:8f:b3:e5:76:89:06:9f:96:47:dc:34:87:02:
31:00:e3:af:2a:8f:d6:8d:1f:3a:2b:ae:2f:97:b3:52:63:b6:
18:67:70:2c:93:2a:41:c0:e7:fa:93:20:09:4d:f4:bf:d0:11:
66:0f:48:56:01:1e:c3:be:37:4e:49:19:cf:c6
3. Configure the Stelnet server:
# Upload the server's certificate file ssh-server-ecdsa256.p12 and the client's certificate file ssh-client-ecdsa256.p12 to the Stelnet server through FTP or TFTP. (Details not shown.)
# Create a PKI domain named client256 for verifying the client's certificate and import the file of the client's certificate to this domain. (Details not shown.)
# Create a PKI domain named server256 for the server's certificate and import the file of the server's certificate to this domain. (Details not shown.)
# Specify Suite B algorithms for algorithm negotiation.
[SwitchB] ssh2 algorithm key-exchange ecdh-sha2-nistp256
[SwitchB] ssh2 algorithm cipher aes128-gcm
[SwitchB] ssh2 algorithm public-key x509v3-ecdsa-sha2-nistp256 x509v3-ecdsa-sha2-nistp384
# Specify server256 as the PKI domain of the server's certificate.
[SwitchB] ssh server pki-domain server256
[SwitchB] line vty 0 15
[SwitchB-line-vty0-15] authentication-mode scheme
[SwitchB-line-vty0-15] quit
# Create a local device management user named client001. Authorize the user to use the SSH service and assign the network-admin user role to the user.
# Create an SSH user named client001. Specify the publickey authentication method for the user and specify client256 as the PKI domain for verifying the client's certificate.
[Switch] ssh user client001 service-type stelnet authentication-type publickey assign pki-domain client256
4. Establish an SSH connection to the Stelnet server based on the 128-bit Suite B algorithms:
# Establish an SSH connection to the server at 192.168.1.40.
<SwitchA> ssh2 192.168.1.40 suite-b 128-bit pki-domain client256 server-pki-domain server256
Username: client001
<SwitchB>
SFTP configuration examples
When the device acts as an SFTP server operating in FIPS mode, only ECDSA and RSA key pairs are supported. Do not generate a DSA key pair on the SFTP server.
As shown in Figure 13:
· The switch acts as the SFTP server and uses password authentication.
Establish an SFTP connection between the host and the switch, so you can log in to the switch to manage and transfer files.
1. Configure the SFTP server:
Generating Keys...
Generating Keys...
Generating Keys...
# Enable the SFTP server.
[Switch] sftp server enable
# Assign an IP address to VLAN-interface 2. The client uses this address as the destination for SSH connection.
[Switch-Vlan-interface2] ip address 192.168.1.45 255.255.255.0
# Set the password to aabbcc in plain text for local user client002.
[Switch-luser-manage-client002] password simple aabbcc
# Assign the network-admin user role and working directory flash:/ to local user client002.
[Switch-luser-manage-client002] authorization-attribute user-role network-admin work-directory flash:/
# Create an SSH user named client002. Specify the authentication method as password and service type as sftp for the user.
[Switch] ssh user client002 service-type sftp authentication-type password
2. Establish a connection between the SFTP client and the SFTP server:
The device supports different types of SFTP client software. This example uses an SFTP client that runs PSFTP of PuTTy version 0.58.
NOTE: PSFTP supports only password authentication. |
To establish a connection to the SFTP server:
a. Run the psftp.exe to launch the client interface shown in Figure 14, and enter the following command:
open 192.168.1.45
b. Enter username client002 and password aabbcc as prompted to log in to the SFTP server.
Figure 14 SFTP client interface
Publickey authentication enabled SFTP client configuration example
As shown in Figure 15, Switch B acts as the SFTP server, and it uses publickey authentication and the RSA public key algorithm.
Establish an SFTP connection between Switch A and Switch B, so you can log in to Switch B to manage and transfer files.
In the server configuration, the client's host public key is required. Generate RSA key pairs on the client before configuring the SFTP server.
1. Configure the SFTP client:
[SwitchA-Vlan-interface2] ip address 192.168.0.2 255.255.255.0
[SwitchA] public-key local create rsa
Generating Keys...
# Export the host public key to a public key file named pubkey.
[SwitchA] public-key local export rsa ssh2 pubkey
[SwitchA] quit
# Transmit the public key file pubkey to the server through FTP or TFTP. (Details not shown.)
2. Configure the SFTP server:
Generating Keys...
Generating Keys...
Generating Keys...
[SwitchB] sftp server enable
# Assign an IP address to VLAN-interface 2. The SSH client uses this address as the destination for SSH connection.
[SwitchB-Vlan-interface2] ip address 192.168.0.1 255.255.255.0
# Import the peer public key from the public key file pubkey, and name it switchkey.
[SwitchB] public-key peer switchkey import sshkey pubkey
# Create an SSH user named client001. Specify the service type as sftp and the authentication method as publickey for the user. Assign the public key switchkey to the user.
[SwitchB] ssh user client001 service-type sftp authentication-type publickey assign publickey switchkey
# Assign the network-admin user role and working directory flash:/ to local user client001.
[SwitchB-luser-manage-client001] authorization-attribute user-role network-admin work-directory flash:/
3. Establish a connection to the SFTP server:
# Establish a connection to the SFTP server and enter SFTP client view.
<SwitchA> sftp 192.168.0.1 identity-key rsa
Username: client001
Connecting to 192.168.0.1 port 22.
sftp>
# Display files under the current directory of the server, delete file z, and verify the result.
sftp> dir -l
-rwxrwxrwx 1 noone nogroup 1759 Aug 23 06:52 config.cfg
-rwxrwxrwx 1 noone nogroup 225 Aug 24 08:01 pubkey2
-rwxrwxrwx 1 noone nogroup 283 Aug 24 07:39 pubkey
drwxrwxrwx 1 noone nogroup 0 Sep 01 06:22 new
-rwxrwxrwx 1 noone nogroup 225 Sep 01 06:55 pub
-rwxrwxrwx 1 noone nogroup 0 Sep 01 08:00 z
sftp> delete z
Removing /z
sftp> dir -l
# Add a directory named new1 and verify the result.
sftp> mkdir new1
sftp> dir -l
drwxrwxrwx 1 noone nogroup 0 Sep 02 06:30 new1
# Change the name of directory new1 to new2 and verify the result.
sftp> rename new1 new2
sftp> dir -l
drwxrwxrwx 1 noone nogroup 0 Sep 02 06:33 new2
# Download file pubkey2 from the server and save it as a local file named public.
sftp> get pubkey2 public
Fetching / pubkey2 to public
/pubkey2 100% 225 1.4KB/s 00:00
# Upload the local file pu to the server, save it as puk, and verify the result.
sftp> put pu puk
Uploading pu to / puk
sftp> dir -l
-rwxrwxrwx 1 noone nogroup 283 Sep 02 06:35 pub
-rwxrwxrwx 1 noone nogroup 283 Sep 02 06:36 puk
sftp>
# Exit SFTP client view.
sftp> quit
<SwitchA>
SFTP configuration example based on 192-bit Suite B algorithms
As shown in Figure 16, Switch A acts as an SFTP client (SSH2). Switch B acts as the SFTP server (SSH2), and it uses publickey authentication.
Configure Switch A to establish an SFTP connection to Switch B based on the 192-bit Suite B algorithms. After the connection is established, you can log in to Switch B as a network-admin to manage and transfer files.
In this example, the server's certificate file is ssh-server-ecdsa384.p12 and the client's certificate file is ssh-client-ecdsa384.p12.
2. Configure the SFTP client:
NOTE: You can modify the pkix version of the client software OpenSSH to support Suite B. This example uses an H3C switch as an SFTP client. |
# Upload the server's certificate file ssh-server-ecdsa384.p12 and the client's certificate file ssh-client-ecdsa384.p12 to the SFTP client through FTP or TFTP. (Details not shown.)
# Create a PKI domain named server384 for verifying the server's certificate and enter its view.
[SwitchA] pki domain server384
[SwitchA-pki-domain-server384] undo crl check enable
[SwitchA-pki-domain-server384] quit
# Import local certificate file ssh-server-ecdsa384.p12 to PKI domain server384.
[SwitchA] pki import domain server384 p12 local filename ssh-server-ecdsa384.p12
Please enter the key pair name[default name: server384]:
# Display information about local certificates in PKI domain server384.
[SwitchA] display pki certificate domain server384 local
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 1 (0x1)
Signature Algorithm: ecdsa-with-SHA384
Validity
Not Before: Aug 20 10:08:41 2015 GMT
Not After : Aug 19 10:08:41 2016 GMT
Subject: C=CN, ST=Beijing, O=H3C, OU=Software, CN=ssh server
Public-Key: (384 bit)
pub:
04:4a:33:e5:99:8d:49:45:a7:a3:24:7b:32:6a:ed:
b6:36:e1:4d:cc:8c:05:22:f4:3a:7c:5d:b7:be:d1:
e6:9e:f0:ce:95:39:ca:fd:a0:86:cd:54:ab:49:60:
10:be:67:9f:90:3a:18:e2:7d:d9:5f:72:27:09:e7:
bf:7e:64:0a:59:bb:b3:7d:ae:88:14:94:45:b9:34:
d2:f3:93:e1:ba:b4:50:15:eb:e5:45:24:31:10:c7:
07:01:f9:dc:a5:6f:81
ASN1 OID: secp384r1
NIST CURVE: P-384
X509v3 extensions:
CA:FALSE
Netscape Comment:
10:16:64:2C:DA:C1:D1:29:CD:C0:74:40:A9:70:BD:62:8A:BB:F4:D5
30:65:02:31:00:80:50:7a:4f:c5:cd:6a:c3:57:13:7f:e9:da:
c1:72:7f:45:30:17:c2:a7:d3:ec:73:3d:5f:4d:e3:96:f6:a3:
33:fb:e4:b9:ff:47:f1:af:9d:e3:03:d2:24:53:40:09:5b:02:
30:45:d1:bf:51:fd:da:22:11:90:03:f9:d4:05:ec:d6:7c:41:
fc:9d:a1:fd:5b:8c:73:f8:b6:4c:c3:41:f7:c6:7f:2f:05:2d:
37:f8:52:52:26:99:28:97:ac:6e:f9:c7:01
# Create a PKI domain named client384 for the client's certificate and enter its view.
[SwitchA] pki domain client384
#Disable CRL checking.
[SwitchA-pki-domain-client384] undo crl check enable
[SwitchA-pki-domain-client384] quit
# Import local certificate file ssh-client-ecdsa384.p12 to PKI domain client384.
[SwitchA] pki import domain client384 p12 local filename ssh-client-ecdsa384.p12
Please enter the key pair name[default name: client384]:
# Display information about local certificates in PKI domain client384.
[SwitchA]display pki certificate domain client384 local
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 2 (0x2)
Validity
Not Before: Aug 20 10:10:59 2015 GMT
Not After : Aug 19 10:10:59 2016 GMT
Subject: C=CN, ST=Beijing, O=H3C, OU=Software, CN=ssh client
pub:
04:85:7c:8b:f4:7a:36:bf:74:f6:7c:72:f9:08:69:
d0:b9:ac:89:98:17:c9:fc:89:94:43:da:9a:a6:89:
41:d3:72:24:9b:9a:29:a8:d1:ba:b4:e5:77:ba:fc:
df:ae:c6:dd:46:72:ab:bc:d1:7f:18:7d:54:88:f6:
b4:06:54:7e:e7:4d:49:b4:07:dc:30:54:4b:b6:5b:
01:10:51:6b:0c:6d:a3:b1:4b:c9:d9:6c:d6:be:13:
91:70:31:2a:92:00:76
ASN1 OID: secp384r1
NIST CURVE: P-384
X509v3 extensions:
CA:FALSE
Netscape Comment:
BD:5F:8E:4F:7B:FE:74:03:5A:D1:94:DB:CA:A7:82:D6:F7:78:A1:B0
30:66:02:31:00:d2:06:fa:2c:0b:0d:f0:81:90:01:c3:3d:bf:
97:b3:79:d8:25:a0:e2:0e:ed:00:c9:48:3e:c9:71:43:c9:b4:
2a:a6:0a:27:80:9e:d4:0f:f2:db:db:5b:40:b1:a9:0a:e4:02:
31:00:ee:00:e1:07:c0:2f:12:3f:88:ea:fe:19:05:ef:56:ca:
33:71:75:5e:11:c9:a6:51:4b:3e:7c:eb:2a:4d:87:2b:71:7c:
30:64:fe:14:ce:06:d5:0a:e2:cf:9a:69:19:ff
[SwitchA] quit
3. Configure the SFTP server:
# Upload the server's certificate file ssh-server-ecdsa384.p12 and the client's certificate file ssh-client-ecdsa384.p12 to the SFTP server through FTP or TFTP. (Details not shown.)
# Create a PKI domain named client384 for verifying the client's certificate and import the file of the client's certificate to this domain. (Details not shown.)
# Create a PKI domain named server384 for the server's certificate and import the file of the server's certificate to this domain. (Details not shown.)
[SwitchB] ssh2 algorithm key-exchange ecdh-sha2-nistp384
[SwitchB] ssh2 algorithm cipher aes256-gcm
[SwitchB] ssh2 algorithm public-key x509v3-ecdsa-sha2-nistp384
# Specify server384 as the PKI domain of the server's certificate.
[SwitchB] ssh server pki-domain server384
# Create a local device management user named client001. Authorize the user to use the SSH service and assign the network-admin user role to the user.# Create a local device management user named client001. Authorize the user to use the SSH service and assign the network-admin user role to the user.
# Create an SSH user named client001. Specify the publickey authentication method for the user and specify client384 as the PKI domain for verifying the client's certificate.
[Switch] ssh user client001 service-type sftp authentication-type publickey assign pki-domain client384
4. Establish an SFTP connection to the SFTP server based on the 192-bit Suite B algorithms:
# Establish an SFTP connection to the server at 192.168.0.1.
<SwitchA> sftp 192.168.0.1 suite-b 192-bit pki-domain client384 server-pki-domain server384
Username: client001
sftp>
SCP configuration examples
When the device acts as an SCP server and is operating in FIPS mode, only ECDSA and RSA key pairs are supported. Do not generate a DSA key pair on the SCP server.
SCP configuration example with password authentication
As shown in Figure 17:
· Switch B uses the password authentication method.
· The client 's username and password are saved on Switch B.
Establish an SCP connection between Switch A and Switch B, so you can log in to Switch B to transfer files.
1. Configure the SCP server:
Generating Keys...
Generating Keys...
Generating Keys...
# Enable the SCP server.
[SwitchB] scp server enable
# Configure an IP address for VLAN-interface 2. The client uses this address as the destination for SCP connection.
# Create an SSH user named client001. Specify the service type as scp and the authentication method as password for the user.
[SwitchB] ssh user client001 service-type scp authentication-type password
2. Configure an IP address for VLAN-interface 2 on the SCP client.
[SwitchA] quit
3. Connect to the SCP server, download file remote.bin from the server, and save it as a local file named local.bin.
<SwitchA> scp 192.168.0.1 get remote.bin local.bin
Username: client001
[email protected]’s password:
remote.bin 100% 2875 2.8KB/s 00:00
SCP configuration example based on Suite B algorithms
As shown in Figure 18, Switch A acts as an SCP client (SSH2). Switch B acts as the SCP server (SSH2), and it uses publickey authentication.
Configure Switch A to establish an SCP connection to Switch B based on the Suite B algorithms. After the connection is established, you can log in to Switch B as a network-admin to transfer files.
1. Generate the client's certificates and the server's certificates. (Details not shown.)
In this example, the server's certificate files are ssh-server-ecdsa256.p12 and ssh-server-ecdsa384.p12. The client's certificate files are ssh-client-ecdsa256.p12 and ssh-client-ecdsa384.p12.
2. Configure the SCP client:
NOTE: You can modify the pkix version of the client software OpenSSH to support Suite B. This example uses an H3C switch as an SCP client. |
# Upload the server's certificate files (ssh-server-ecdsa256.p12 and ssh-server-ecdsa384.p12) and the client's certificate files (ssh-client-ecdsa256.p12 and ssh-client-ecdsa384.p12) to the SCP client through FTP or TFTP. (Details not shown.)
# Create a PKI domain named server256 for verifying the server's certificate ecdsa256 and enter its view.
Certificate:
Data:
Version: 3 (0x2)
Validity
pub:
c7:61:4a:52:51
NIST CURVE: P-256
X509v3 extensions:
CA:FALSE
Netscape Comment:
# Create a PKI domain named client256 for the client's certificate ecdsa256 and enter its view.
Certificate:
Data:
Version: 3 (0x2)
Validity
pub:
12:d0:b4:8a:92
NIST CURVE: P-256
X509v3 extensions:
CA:FALSE
Netscape Comment:
# Create a PKI domain named server384 for verifying the server's certificate ecdsa384 and enter its view.
Certificate:
Data:
Version: 3 (0x2)
Validity
pub:
ASN1 OID: secp384r1
NIST CURVE: P-384
X509v3 extensions:
CA:FALSE
Netscape Comment:
# Create a PKI domain named client384 for the client's certificate ecdsa384 and enter its view.
[SwitchA] display pki certificate domain client384 local
Certificate:
Data:
Version: 3 (0x2)
Validity
pub:
ASN1 OID: secp384r1
NIST CURVE: P-384
X509v3 extensions:
CA:FALSE
Netscape Comment:
3. Configure the SCP server:
# Upload the server's certificate files (ssh-server-ecdsa256.p12 and ssh-server-ecdsa384.p12) and the client's certificate files (ssh-client-ecdsa256.p12 and ssh-client-ecdsa384.p12) to the SCP server through FTP or TFTP. (Details not shown.)
# Create a PKI domain named client256 for verifying the client's certificate ecdsa256 and import the file of this certificate to this domain. Create a PKI domain named server256 for the server's certificate ecdsa256 and import the file of this certificate to this domain. (Details not shown.)
# Create a PKI domain named client384 for verifying the client's certificate ecdsa384 and import the file of this certificate to this domain. Create a PKI domain named server384 for the server's certificate ecdsa384 and import the file of this certificate to this domain. (Details not shown.)
[SwitchB] ssh2 algorithm key-exchange ecdh-sha2-nistp256 ecdh-sha2-nistp384
[SwitchB] ssh2 algorithm cipher aes128-gcm aes256-gcm
# Create a local device management user named client002. Authorize the user to use the SSH service and assign the network-admin user role to the user.
4. Establish an SCP connection to the SCP server:
¡ Based on the 128-bit Suite B algorithms:
[SwitchB]ssh server pki-domain server256
# Create an SSH user client001. Specify the publickey authentication method for the user and specify client256 as the PKI domain for verifying the client's certificate.
[Switch] ssh user client001 service-type scp authentication-type publickey assign pki-domain client256
# Establish an SCP connection to the SCP server at 192.168.0.1 based on the 128-bit Suite B algorithms.
<SwitchA> scp 192.168.0.1 get src.cfg suite-b 128-bit pki-domain client256 server-pki
-domain server256
Username: client001
src.cfg 100% 4814 4.7KB/s 00:00
<SwitchA>
¡ Based on the 192-bit Suite B algorithms:
# Create an SSH user client002. Specify the publickey authentication method for the user and specify client384 as the PKI domain for verifying the client's certificate.
[Switch] ssh user client002 service-type scp authentication-type publickey assign pki-domain client384
# Establish an SCP connection to the SCP server at 192.168.0.1 based on the 192-bit Suite B algorithms.
<SwitchA> scp 192.168.0.1 get src.cfg suite-b 192-bit pki-domain client384 server-pki
-domain server384
Username: client002
<SwitchA>
NETCONF over SSH configuration example with password authentication
Unless otherwise noted, devices in the configuration examples are in non-FIPS mode.
When the device acts as a NETCONF-over-SSH server operating in FIPS mode, only ECDSA and RSA key pairs are supported. Do not generate a DSA key pair on the NETCONF-over-SSH server.
As shown in Figure 19:
· The switch uses local password authentication.
· The client's username and password are saved on the switch.
Establish a NETCONF-over-SSH connection between the host and the switch, so that you can log in to the switch to perform NETCONF operations.
Configuration procedure
Generating Keys...
Generating Keys...
Generating Keys...
# Enable NETCONF over SSH.
[Switch] netconf ssh server enable
# Configure an IP address for VLAN-interface 2. The client uses this address as the destination for NETCONF-over-SSH connection.
# Create an SSH user named client001. Specify the service type as NETCONF and the authentication method as password for the user.
[Switch] ssh user client001 service-type netconf authentication-type password
# Verify that you can perform NETCONF operations after logging in to the switch. (Details not shown.)
