01-VXLAN commands | 255.73 KB |
ac statistics enable (VLAN view)
display ipv6 nd suppression vsi
display l2vpn service-instance
l2vpn mac-address software-learning enable
selective-flooding mac-address
statistics enable (Ethernet service instance view)
vxlan invalid-vlan-tag discard
vxlan tunnel mac-learning disable·
arp distributed-gateway dynamic-entry synchronize
display interface vsi-interface
ipv6 nd distributed-gateway dynamic-entry synchronize
vxlan tunnel arp-learning disable
vxlan tunnel nd-learning disable·
ovsdb server bootstrap ca-certificate
VXLAN commands
Basic VXLAN commands
Use ac statistics enable to enable packet statistics for Ethernet service instances of a VLAN.
Use undo ac statistics enable to disable packet statistics for Ethernet service instances of a VLAN.
The packet statistics feature is disabled for Ethernet service instances of a VLAN.
VLAN view
This command enables packet statistics for the Ethernet service instances automatically created for VLAN-based VXLAN assignment.
Before you enable this feature, you must use the vxlan vlan-based command to enable VLAN-based VXLAN assignment.
# Map VLAN 10 to VXLAN 100, and enable packet statistics for Ethernet service instances of VLAN 10.
[Sysname] vxlan vlan-based
[Sysname] vlan 10
[Sysname-vlan10] vxlan vni 100
[Sysname-vlan10] ac statistics enable
reset l2vpn statistics ac
vxlan vlan-based
arp suppression enable
Use arp suppression enable to enable ARP flood suppression.
Use undo arp suppression enable to disable ARP flood suppression.
ARP flood suppression is disabled.
VSI view
ARP flood suppression reduces ARP request broadcasts by enabling the VTEP to reply to ARP requests on behalf of VMs.
This feature snoops ARP packets to populate the ARP flood suppression table with local and remote MAC addresses. If an ARP request has a matching entry, the VTEP replies to the request on behalf of the VM. If no match is found, the VTEP floods the request to both local and remote sites.
# Enable ARP flood suppression for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression enable
display arp suppression vsi
reset arp suppression vsi
description
Use description to configure a description for a VSI.
A VSI does not have a description.
VSI view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
display l2vpn vsi
Use display arp suppression vsi to display ARP flood suppression entries.
In standalone mode:
display arp suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
In IRF mode:
display arp suppression vsi [ name vsi-name ] [ chassis chassis-number slot slot-number ] [ count ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays entries for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays entries on the global active MPU. (In IRF mode.)
count: Displays the number of ARP flood suppression entries that match the command.
# Display ARP flood suppression entries.
<Sysname> display arp suppression vsi
IP address MAC address Vsi name Link ID Aging
1.1.1.2 000f-e201-0101 vsi1 0x70000 14
1.1.1.3 000f-e201-0202 vsi1 0x80000 18
1.1.1.4 000f-e201-0203 vsi2 0x90000 10
# Display the number of ARP flood suppression entries.
<Sysname> display arp suppression vsi count
Total entries: 3
Link ID |
Link ID that uniquely identifies an AC or a VXLAN tunnel on a VSI. |
Aging |
Remaining lifetime (in minutes) of the ARP flood suppression entry. When the timer expires, the entry is deleted. |
display igmp host group
Use display igmp host group to display information about the multicast groups that contain IGMP host-enabled interfaces.
display igmp host group [ group-address | interface interface-type interface-number ] [ verbose ]
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays information about all multicast groups.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays multicast group information for all interfaces.
verbose: Displays detailed multicast group information. If you do not specify this keyword, the command displays brief multicast group information.
For the VXLAN multicast source interface of a multicast-mode VXLAN to join its VXLAN multicast group, enable the IGMP host feature on the interface. The VXLAN multicast source interface provides the source IP address for multicast VXLAN packets.
Use this command to verify the following information:
· Multicast group information for VXLANs.
· Group membership status of VXLAN multicast source interfaces.
# Display brief information about all multicast groups that contain IGMP host-enabled interfaces.
<Sysname> display igmp host group
IGMP host groups in total: 2
Vlan-interface10(1.1.1.20):
Group address Member state Expires
225.1.1.1 Idle Off
225.1.1.2 Idle Off
# Display detailed information about all multicast groups that contain IGMP host-enabled interfaces.
<Sysname> display igmp host group verbose
Group: 225.1.1.1
Group mode: Exclude
Member state: Idle
Expires: Off
Source list (sources in total: 0):
Group: 225.1.1.2
Group mode: Exclude
Member state: Idle
Expires: Off
IGMP host groups in total |
Total number of multicast groups that contain IGMP host-enabled interfaces. |
Vlan-interface10(1.1.1.20) |
Name and IP address of the IGMP host-enabled interface. |
Total number of multicast groups on the interface. |
Group address/Group |
Address of the multicast group. |
Member state |
Member state: · Delay—The interface has joined the multicast group, and it has started the delay timer for sending IGMP reports. · Idle—The interface has joined the multicast group, but it has not started the delay timer for sending IGMP reports. The delay timer is not user configurable. |
Expires |
Remaining delay time for the interface to send an IGMP report. This field displays Off if the delay timer is disabled. |
Group mode |
Multicast source filtering mode: · Include. · Exclude. |
Source list |
Multicast sources of the multicast group. |
sources in total |
Total number of multicast sources. |
NOTE: For more information about the command output, see IGMP in IP Multicast Configuration Guide. |
igmp host enable
Use display ipv6 nd suppression vsi to display ND flood suppression entries.
In standalone mode:
display ipv6 nd suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
In IRF mode:
display ipv6 nd suppression vsi [ name vsi-name ] [ chassis chassis-number slot slot-number ] [ count ]
count: Displays the number of ND flood suppression entries that match the command.
# Display ND flood suppression entries.
<Sysname> display ipv6 nd suppression vsi
IPv6 address MAC address VSI name Link ID Aging (min)
1000::2 000f-e201-0101 vsi1 0x70000 5
1000::3 000f-e201-0202 vsi1 0x80000 5
1000::4 000f-e201-0203 vsi2 0x90000 5
# Display the number of ND flood suppression entries.
<Sysname> display ipv6 nd suppression vsi count
Total entries: 3
Link ID |
Aging (min) |
Remaining lifetime (in minutes) of the ND flood suppression entry. When the timer expires, the entry is deleted. |
ipv6 nd suppression enable
reset ipv6 nd suppression vsi
display l2vpn mac-address
Use display l2vpn mac-address to display MAC address entries for VSIs.
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count | verbose ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC address entries for all VSIs.
dynamic: Specifies dynamic MAC address entries learned in the data plane. If you do not specify this keyword, the command displays all MAC address entries, including:
· Dynamic remote- and local-MAC entries.
· Remote-MAC entries advertised through BGP EVPN.
· Manually added static remote- and local-MAC entries.
· Remote-MAC entries issued through OpenFlow.
· Remote-MAC entries issued through OVSDB.
count: Displays the number of MAC address entries.
verbose: Displays detailed information about MAC address entries.
If you do not specify the count or verbose keyword, this command displays brief information about MAC address entries.
# Display brief information about MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address
MAC Address State VSI Name Link ID/Name Aging
0000-0000-000b Static vpn1 Tunnel10 NotAging
0000-0000-000c Dynamic vpn1 Tunnel60 Aging
0000-0000-000d Dynamic vpn1 Tunnel99 Aging
--- 3 mac address(es) found ---
# Display the total number of MAC address entries in all VSIs.
<Sysname> display l2vpn mac-address count
State |
Entry state: · Dynamic—Local- or remote-MAC entry dynamically learned in the data plane. · Static—Static local- and remote-MAC entry. · EVPN—Remote-MAC entry advertised through BGP EVPN. · OpenFlow—Remote-MAC entry issued by a remote controller through OpenFlow. · OVSDB—Remote-MAC entry issued by a remote controller through OVSDB. |
Link ID/Name |
For a local MAC address, this field displays the name of the interface that hosts the Ethernet service instance for the MAC address. For a remote MAC address, this field displays the tunnel interface name. |
Aging |
Entry aging state: · Aging. · NotAging. |
# Display detailed information about MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address verbose
MAC Address : 0000-0000-000b
VSI Name : vpn1
VXLAN ID : 123
Interface : XGE1/0/1
Link ID : 1
State : Dynamic
Aging : Aging
Table 5 Command output
Link ID |
State |
Entry state: · Dynamic—Local- or remote-MAC entry dynamically learned in the data plane. · Static—Static local- or remote-MAC entry. · EVPN—Remote-MAC entry advertised through BGP EVPN. · OpenFlow—Remote-MAC entry issued by a remote controller through OpenFlow. · OVSDB—Remote-MAC entry issued by a remote controller through OVSDB. |
Aging |
reset l2vpn mac-address
Use display l2vpn service-instance to display information about Ethernet service instances.
interface interface-type interface-number: Specifies a Layer 2 Ethernet interface or Layer 2 aggregate interface by its interface type and number. If you do not specify an interface, this command displays Ethernet service instance information for all Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays information about all Ethernet service instances on the specified Layer 2 Ethernet interface or Layer 2 aggregate interface.
verbose: Displays detailed information about Ethernet service instances. If you do not specify this keyword, the command displays brief information about Ethernet service instances.
# Display brief information about all Ethernet service instances.
<Sysname> display l2vpn service-instance
Total number of service-instances: 4, 4 up, 0 down
Total number of ACs: 2, 2 up, 0 down
Interface SrvID Owner LinkID State Type
XGE1/0/1 3 vsi12 1 Up VSI
XGE1/0/1 4 vsi13 1 Up VSI
Table 6 Command output
Total number of ACs |
Total number of attachment circuits (ACs) and the number of ACs in each state (up or down). |
Name of a Layer 2 Ethernet interface or Layer 2 aggregate interface. |
SrvID |
Ethernet service instance ID. |
Owner |
VSI name. This field is empty if an Ethernet service instance is not mapped to any VSI. |
LinkID |
Ethernet service instance's link ID on the VSI. |
State |
Ethernet service instance state: · Up. · Down. |
Type |
L2VPN type of the Ethernet service instance: · VSI. · VPWS. |
# Display detailed information about all Ethernet service instances on Ten-GigabitEthernet 1/0/1.
<Sysname> display l2vpn service-instance interface ten-gigabitethernet 1/0/1 verbose
Interface: XGE1/0/1
Service Instance: 1
Type : Manual
Encapsulation : s-vid 16
Bandwidth : Unlimited
VSI Name : vsi10
Link ID : 1
State : Up
Statistics : Enabled
Input Statistics:
Octets :0
Packets :0
Output Statistics:
Octets :0
Packets :0
Table 7 Command output
Service Instance |
Type |
Type and traffic match mode of the Ethernet service instance: · Dynamic (MAC-based)—Dynamic Ethernet service instance in MAC-based traffic match mode. · Dynamic (VLAN-based)—Dynamic Ethernet service instance in VLAN-based traffic match mode. This mode is not supported in the current software version. · Manual—Static Ethernet service instance in VLAN-based traffic match mode. |
Encapsulation |
Frame match criterion of the Ethernet service instance. If the Ethernet service instance does not contain a frame match criterion, the command does not display this field. |
Bandwidth |
Bandwidth limit in kbps. If no bandwidth limit is set for the Ethernet service instance, Unlimited is displayed. |
Link ID |
State |
Statistics |
Packet statistics state: · Enabled—The packet statistics feature is enabled for the Ethernet service instance. · Disabled—The packet statistics feature is disabled for the Ethernet service instance. |
Input Statistics |
Incoming traffic statistics: · Octets—Number of incoming bytes. · Packets—Number of incoming packets. |
Output Statistics |
Outgoing traffic statistics: · Octets—Number of outgoing bytes. · Packets—Number of outgoing packets. |
service-instance
display l2vpn vsi
Use display l2vpn vsi to display information about VSIs.
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about all VSIs.
verbose: Displays detailed information about VSIs. If you do not specify this keyword, the command displays brief information about VSIs.
# Display brief information about all VSIs.
<Sysname> display l2vpn vsi
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name VSI Index MTU State
vpna 0 1500 Up
Table 8 Command output
MTU |
MTU on the VSI. |
State |
VSI state: · Up—The VSI is up. · Down—The VSI is down. · Admin down—The VSI has been manually shut down by using the shutdown command. |
# Display detailed information about all VSIs.
<Sysname> display l2vpn vsi verbose
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : -
Broadcast Restrain : -
Multicast Restrain : -
Unknown Unicast Restrain: -
MAC Learning : Enabled
MAC Table Limit : -
MAC Learning rate : -
Drop Unknown : -
Flooding : Enabled
Input statistics:
Octets : 0
Packets : 0
Errors : 0
Discards : 0
Output statistics:
Octets : 0
Packets : 0
Errors : 0
Discards : 0
Gateway Interface : VSI-interface 100
VXLAN ID : 10
Tunnels:
Tunnel Name Link ID State Type Flood proxy
Tunnel1 0x5000001 Up Manual Disabled
Tunnel2 0x5000002 Up Manual Disabled
MTunnel0 0x6002710 Up Auto Disabled
ACs:
AC Link ID State Type
XGE1/0/1 srv1000 0 Up Manual
Table 9 Command output
VSI Description |
Description of the VSI. If the VSI does not have a description, the command does not display this field. |
VSI State |
VSI state: · Up—The VSI is up. · Down—The VSI is down. · Administratively down—The VSI has been manually shut down by using the shutdown command. |
MTU |
MTU on the VSI. |
Bandwidth |
Bandwidth limit in kbps. This field is not supported in the current software version. |
Broadcast Restrain |
Broadcast restraint bandwidth (in kbps). This field is not supported in the current software version. |
Multicast Restrain |
Multicast restraint bandwidth (in kbps). This field is not supported in the current software version. |
Unknown Unicast Restrain |
Unknown unicast restraint bandwidth (in kbps). This field is not supported in the current software version. |
MAC Learning |
State of the MAC learning feature. |
MAC Table Limit |
Maximum number of MAC address entries on the VSI. This field is not supported in the current software version. |
Drop Unknown |
Action on source MAC-unknown frames received after the maximum number of MAC entries is reached. This field is not supported in the current software version. |
Flooding |
State of the VSI's flooding feature: · Enabled—Flooding is enabled on the VSI. · Disabled—Flooding is disabled on the VSI. |
Statistics |
Packet statistics state: · Enabled—The packet statistics feature is enabled for the VSI. · Disabled—The packet statistics feature is disabled for the VSI. |
Input statistics |
Incoming traffic statistics: · Octets—Number of incoming bytes. · Packets—Number of incoming packets. · Errors—Number of error packets. · Discards—Number of discarded packets. The device does not support the Errors and Discards fields. |
Output statistics |
Outgoing traffic statistics: · Octets—Number of outgoing bytes. · Packets—Number of outgoing packets. · Errors—Number of error packets. · Discards—Number of discarded packets. The device does not support the Errors and Discards fields. |
Gateway Interface |
VSI interface name. |
State |
Tunnel state: · Up—The tunnel is operating correctly. · Defect—The tunnel interface is up, but BFD cannot detect the remote VTEP. · Down—The tunnel interface is down. |
Type |
Tunnel assignment method: · Auto—The tunnel was automatically assigned to the VXLAN: ? For an EVPN network, VXLAN tunnels are automatically assigned to VXLANs. ? For a multicast-mode VXLAN, the tunnel (MTunnel) was automatically created and assigned to the VXLAN to transmit flood traffic. · Manual—The tunnel was manually assigned to the VXLAN. |
Flood proxy |
Flood proxy state. This field is not supported in the current software version. |
ACs |
ACs that are bound to the VSI. |
Link ID |
AC's link ID on the VSI. |
State |
AC state: · Up. · Down. |
Type |
display vxlan tunnel
Use display vxlan tunnel to display VXLAN tunnel information for VXLANs.
display vxlan tunnel [ vxlan-id vxlan-id ]
vxlan-id: Specifies a VXLAN ID in the range of 0 to 16777215. If you do not specify a VXLAN, this command displays VXLAN tunnel information for all VXLANs.
# Display VXLAN tunnel information for all VXLANs.
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
VXLAN ID: 10, VSI name: vpna, Total tunnels: 3 (3 up, 0 down, 0 defect, 0 blocked)
Tunnel name Link ID State Type Flood proxy
# Display VXLAN tunnel information for VXLAN 10.
<Sysname> display vxlan tunnel vxlan-id 10
Table 10 Command output
Link ID |
Tunnel's link ID in the VXLAN. |
State |
Tunnel state: · Up—The tunnel is operating correctly. · Blocked—The tunnel is a backup tunnel. Its tunnel interface is up, but the tunnel is blocked because the primary tunnel is operating correctly. · Defect—The tunnel interface is up, but BFD cannot detect the remote VTEP. · Down—The tunnel interface is down. |
Type |
Flood proxy |
tunnel
vxlan
encapsulation
Use encapsulation to configure a frame match criterion for an Ethernet service instance.
Use undo encapsulation to restore the default.
encapsulation s-vid { vlan-id | vlan-id-list } [ only-tagged ]
encapsulation s-vid { vlan-id | vlan-id-list } c-vid { vlan-id-list | all }
encapsulation c-vid { vlan-id | vlan-id-list }
encapsulation { default | tagged | untagged }
undo encapsulation
An Ethernet service instance does not contain a frame match criterion.
s-vid: Matches frames that are tagged with the specified outer 802.1Q VLAN IDs.
c-vid: Matches frames that are tagged with the specified inner 802.1Q VLAN IDs.
vlan-id: Specifies an 802.1Q VLAN ID in the range of 1 to 4094.
vlan-id-list: Specifies a space-separated list of up to eight VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094.
only-tagged: Matches tagged frames. If the outer 802.1Q VLAN is not the PVID, the matching result does not differ, whether or not you specify the only-tagged keyword. If the outer 802.1Q VLAN is the PVID, the matching result depends on whether or not the only-tagged keyword is specified.
· To match only PVID-tagged frames, specify the only-tagged keyword.
· To match both untagged frames and PVID-tagged frames, do not specify the only-tagged keyword.
all: Specifies all 802.1Q VLAN IDs.
default: Matches frames that do not match any other Ethernet service instance on the interface. On an interface, you can configure this criterion only in one Ethernet service instance. The Ethernet service instance matches any frames if it is the only instance on the interface.
tagged: Matches any frames that have an 802.1Q VLAN tag.
untagged: Matches any frames that do not have an 802.1Q VLAN tag.
The frame match criteria of Ethernet service instances cannot overlap on an interface.
When you configure frame match criteria on different Ethernet service instances on an interface, follow these restrictions and guidelines:
· The matching VLAN ID ranges of two Ethernet service instances cannot overlap.
· The criterion specified by the tagged keyword is mutually exclusive with the criterion specified by the s-vid or c-vid keyword.
· An Ethernet service instance cannot work correctly if the following conditions exist:
? The Ethernet service instance has a frame match criterion specified by the c-vid keyword.
? All of the following commands are used on the Ethernet service instances on the interface:
- encapsulation s-vid vlan-id-list [ only-tagged ]
- encapsulation s-vid vlan-id-list c-vid { vlan-id-list | all }
- encapsulation c-vid vlan-id-list
An Ethernet service instance can contain only one frame match criterion. To change the frame match criterion, first execute the undo encapsulation command to remove the original criterion. When you remove the frame match criterion in an Ethernet service instance, the mapping between the service instance and the VSI is removed automatically.
# Configure Ethernet service instance 1 on Ten-GigabitEthernet 1/0/1 to match frames that have an outer 802.1Q VLAN ID of 111.
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 1
[Sysname-Ten-GigabitEthernet1/0/1-srv1] encapsulation s-vid 111
flooding disable
Use flooding disable to disable flooding for a VSI.
Use undo flooding disable to enable flooding for a VSI.
flooding disable { all | { broadcast | unknown-multicast | unknown-unicast } * } [ all-direction | dci ]
Flooding is enabled for a VSI.
VSI view
all: Specifies broadcast, unknown unicast, and unknown multicast traffic.
broadcast: Specifies broadcast traffic.
unknown-multicast: Specifies unknown multicast traffic.
unknown-unicast: Specifies unknown unicast traffic.
all-direction: Disables flooding traffic received from an AC or VXLAN tunnel interface to any other ACs and VXLAN tunnel interfaces of the same VSI. If you do not specify this keyword, the command only disables flooding traffic received from ACs to VXLAN tunnel interfaces of the VSI.
dci: Disables flooding only to VXLAN-DCI tunnel interfaces. If you do not specify this keyword, the command disables flooding to both VXLAN tunnel interfaces and VXLAN-DCI tunnel interfaces.
By default, the device floods broadcast, unknown unicast, and unknown multicast frames received from the local site to the following interfaces in the frame's VXLAN:
· All site-facing interfaces except for the incoming interface.
· All VXLAN tunnel interfaces.
When receiving broadcast, unknown unicast, and unknown multicast frames on VXLAN tunnel interfaces, the device floods the frames to all site-facing interfaces in the frames' VXLAN.
To confine a kind of flood traffic, use this command to disable flooding for that kind of flood traffic on the VSI bound to the VXLAN.
If VXLAN-DCI is configured, flood traffic is also sent out of VXLAN-DCI tunnel interfaces. To confine flood traffic to the site-facing interfaces and VXLAN tunnels within a data center, you can specify the dci keyword to disable flooding only to VXLAN-DCI tunnel interfaces.
The all-direction keyword disables flooding traffic received from an AC or VXLAN tunnel interface to any other ACs and VXLAN tunnel interfaces of the same VSI. If VXLAN-DCI is configured, this keyword also disables flooding between VXLAN tunnel interfaces and VXLAN-DCI tunnel interfaces.
# Disable flooding of local broadcast traffic to remote sites for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] flooding disable broadcast
group
Use group to assign a VXLAN a multicast group address for flood traffic, and specify a source IP address for multicast VXLAN packets.
Use undo group to restore the default.
group group-address source source-address
undo group group-address source source-address
A VXLAN uses unicast mode (head-end replication) for flood traffic. No multicast group address or source IP address is specified for multicast VXLAN packets.
VXLAN view
group-address: Specifies a multicast address in the range of 224.0.1.0 to 239.255.255.255.
source source-address: Specifies a source IP address for multicast VXLAN packets.
To reduce traffic sent to the transport network, use multicast mode if the network has dense flood traffic or many VTEPs.
The multicast mode supports the following multicast methods:
· PIM—VTEPs and transport network devices run PIM to generate multicast forwarding entries. On a VTEP, you can use the IP address of a loopback interface as the source IP address for multicast VXLAN packets. If the VTEP has multiple transport-facing interfaces, PIM dynamically selects the outgoing interfaces for multicast VXLAN packets.
· IGMP host—VTEPs and transport network devices run PIM and IGMP to generate multicast forwarding entries.
? Transport-facing interfaces of VTEPs act as IGMP hosts.
? Transport network devices connected to a VTEP run IGMP.
? All transport network devices run PIM.
On a VTEP, you must use the IP address of the transport-facing interface as the source IP address for multicast VXLAN packets. If the VTEP has multiple transport-facing interfaces, multicast VXLAN packets are sent to the transport network through the interface that provides the source IP address for multicast VXLAN packets.
VTEPs in a multicast-mode VXLAN can use different multicast methods.
To forward multicast traffic correctly, you must use the source IP address of an up VXLAN tunnel as the source IP address for multicast VXLAN packets.
For multicast-mode VXLANs, transport network devices must maintain multicast group and forwarding information. To reduce the multicast forwarding entries maintained by transport network devices, assign a multicast group address to multiple VXLANs. The VTEP separates traffic between VXLANs by VXLAN IDs.
NOTE: For VXLANs that use the same multicast group address, you must configure the same source IP address for their multicast VXLAN packets. |
If you execute the group command multiple times for a VXLAN, the most recent configuration takes effect.
[Sysname] vsi aaa
[Sysname-vsi-aaa] vxlan 100
[Sysname-vsi-aaa-vxlan-100] group 233.1.1.1 source 2.1.1.1
igmp host enable
pim dm (IP Multicast Command Reference)
pim sm (IP Multicast Command Reference)
igmp host enable
Use igmp host enable to enable the IGMP host feature on an interface.
Use undo igmp host enable to disable the IGMP host feature on an interface.
igmp host enable
The IGMP host feature is disabled on an interface.
Interface view
You must configure an interface as an IGMP host if its IP address is the source IP address of multicast VXLAN packets. The IGMP host feature enables the interface to send IGMP reports in response to IGMP queries before it can receive traffic from a multicast group.
For this command to take effect, you must use the multicast routing command to enable IP multicast routing.
# Enable IP multicast routing, and then enable the IGMP host feature on VLAN-interface 10.
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname-Vlan-interface10] igmp host enable
group
multicast routing (IP Multicast Command Reference)
Use ipv6 nd suppression enable to enable ND flood suppression.
Use undo ipv6 nd suppression enable to disable ND flood suppression.
ND flood suppression is disabled.
VSI view
ND flood suppression reduces ND request multicasts by enabling the VTEP to reply to ND requests on behalf of user terminals.
This feature snoops ND packets to populate the ND flood suppression table with local and remote MAC addresses. If an ND request has a matching entry, the VTEP replies to the request on behalf of the user terminal. If no match is found, the VTEP floods the request to both local and remote sites.
# Enable ND flood suppression for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] ipv6 nd suppression enable
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
You must enable L2VPN before you can configure L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
Use l2vpn mac-address software-learning enable to enable software-based MAC learning on an interface.
Use undo l2vpn mac-address software-learning enable to disable software-based MAC learning on an interface.
Hardware-based MAC learning is used.
This command is applicable to SDN networks.
To reduce broadcast traffic in an SDN network, the controller synchronizes the MAC addresses that each VTEP learns among all VTEPs. On a VTEP, an interface can learn MAC addresses in hardware or software.
· In hardware-based learning mode, the software periodically obtains new MAC addresses from the hardware and advertises the MAC addresses to the controller.
· In software-based learning mode, the software instantly issues new MAC addresses to the hardware and the controller as soon as they are learned.
Software-based MAC learning shortens the interval at which the VTEP advertises MAC address reachability information to the controller. However, this mode is resource intensive. When you use this mode, you must fully understand its impact on the device performance.
# Enable software-based MAC learning on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] l2vpn mac-address software-learning enable
mac-address static vsi
Use mac-address static vsi to add a static MAC address entry for a VXLAN VSI.
Use undo mac-address static vsi to remove a static MAC address entry for a VXLAN VSI.
mac-address static mac-address interface tunnel tunnel-number vsi vsi-name
undo mac-address static [ mac-address ] [ interface tunnel tunnel-number ] vsi vsi-name
VXLAN VSIs do not have static MAC address entries.
mac-address: Specifies a MAC address in H-H-H format. Do not specify a multicast MAC address or an all-zeros MAC address. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001.
interface tunnel tunnel-number: Specifies a VXLAN or VXLAN-DCI tunnel interface by its tunnel interface number. The specified tunnel interface must already exist. This option applies to remote MAC addresses.
A remote MAC address is the MAC address of a VM in a remote site. Remote MAC entries include manually added MAC entries, dynamically learned MAC entries, and MAC entries advertised through BGP EVPN.
When you add a remote MAC address entry, make sure the VSI's VXLAN has been specified on the VXLAN or VXLAN-DCI tunnel.
The undo mac-address static vsi vsi-name command removes all static MAC address entries for a VSI.
# Add MAC address 000f-e201-0101 to VSI vsi1. Specify Tunnel-interface 1 as the outgoing interface.
[Sysname] mac-address static 000f-e201-0101 interface tunnel 1 vsi vsi1
mac-based ac
Use mac-based ac to enable MAC-based traffic match mode for dynamic Ethernet service instances on an interface.
Use undo mac-based ac to disable MAC-based traffic match mode for dynamic Ethernet service instances on an interface.
mac-based ac
undo mac-based ac
MAC-based traffic match mode is disabled for dynamic Ethernet service instances.
The 802.1X or MAC authentication feature can use the authorization VSI, the guest VSI, the Auth-Fail VSI, and the critical VSI to control the access of users to network resources. When assigning a user to a VSI, 802.1X or MAC authentication sends the VXLAN feature the VSI information and the user's access information, including access interface, VLAN, and MAC address. Then the VXLAN feature creates a dynamic Ethernet service instance for the user and maps it to the VSI.
A dynamic Ethernet service instance supports the MAC-based mode which matches frames by source MAC address.
To use MAC-based traffic match mode for dynamic Ethernet service instances, you must enable MAC authentication or 802.1X authentication that uses MAC-based access control.
This command takes effect only on dynamic Ethernet service instances. Static Ethernet service instances created by using the service-instance command match traffic only by the VLAN IDs specified by using the encapsulation command.
You cannot change the traffic match mode when dynamic Ethernet service instances already exist on an interface.
# Enable MAC-based traffic match mode for dynamic Ethernet service instances on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] mac-based ac
reserved vxlan
Use reserved vxlan to specify a reserved VXLAN.
Use undo reserved vxlan to restore the default.
reserved vxlan vxlan-id
undo reserved vxlan
No VXLAN has been reserved.
You can specify only one reserved VXLAN on the VTEP. The reserved VXLAN cannot be the VXLAN created on any VSI.
The reserved VXLAN ID cannot be the same as the remote VXLAN ID specified by using the mapping vni command.
# Specify VXLAN 10000 as the reserved VXLAN.
[Sysname] reserved vxlan 10000
mapping vni (EVPN Command Reference)
Use reset arp suppression vsi to clear ARP flood suppression entries on VSIs.
reset arp suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ARP flood suppression entries on all VSIs.
# Clear ARP flood suppression entries on all VSIs.
<Sysname> reset arp suppression vsi
This command will delete all entries. Continue? [Y/N]:y
Use reset ipv6 nd suppression vsi to clear ND flood suppression entries on VSIs.
reset ipv6 nd suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ND flood suppression entries on all VSIs.
# Clear ND flood suppression entries on all VSIs.
<Sysname> reset ipv6 nd suppression vsi
Use reset l2vpn mac-address to clear dynamic MAC address entries on VSIs.
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears all dynamic MAC address entries on all VSIs.
Use this command when the number of dynamic MAC address entries reaches the limit or the device learns incorrect MAC addresses.
# Clear the dynamic MAC address entries on VSI vpn1.
<Sysname> reset l2vpn mac-address vsi vpn1
display l2vpn mac-address vsi
Use reset l2vpn statistics ac to clear packet statistics on ACs.
reset l2vpn statistics ac [ interface interface-type interface-number service-instance instance-id ]
service-instance instance-id: Specifies an Ethernet service instance ID in the range of 1 to 4096.
If you do not specify any parameters, this command clears packet statistics on all ACs.
# Clear packet statistics for Ethernet service instance 1 on Ten-GigabitEthernet 1/0/1.
<Sysname> reset l2vpn statistics ac interface ten-gigabitethernet 1/0/1 service-instance 1
display l2vpn service-instance verbose
reset l2vpn statistics vsi
Use reset l2vpn statistics vsi to clear packet statistics on VSIs.
reset l2vpn statistics vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears packet statistics on all VSIs.
# Clear packet statistics on all VSIs.
<Sysname> reset l2vpn statistics vsi
statistics enable (VSI view)
rewrite inbound tag
Use rewrite inbound tag to configure the VLAN tag processing rule for incoming traffic.
Use undo rewrite inbound tag to restore the default.
rewrite inbound tag { nest { c-vid vlan-id | s-vid vlan-id [ c-vid vlan-id ] } | remark { { 1-to-1 | 2-to-1 } { c-vid vlan-id | s-vid vlan-id } | { 1-to-2 | 2-to-2 } s-vid vlan-id c-vid vlan-id } | strip { c-vid | s-vid [ c-vid ] } } [ symmetric ]
VLAN tags of incoming traffic are not processed.
nest: Adds VLAN tags.
c-vid: Specifies an inner VLAN tag.
s-vid: Specifies an outer VLAN tag.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
remark: Maps VLAN tags.
1-to-1: Performs one-to-one mapping to replace one VLAN tag of packets with the specified VLAN tag.
2-to-1: Performs two-to-one mapping to replace the outer and inner VLAN tags of double tagged packets with the specified VLAN tag.
1-to-2: Performs one-to-two mapping to replace the VLAN tag of single tagged packets with the specified outer and inner VLAN tags.
2-to-2: Performs two-to-two mapping to replace the outer and inner VLAN tags of double tagged packets with the specified outer and inner VLAN tags.
strip: Removes VLAN tags.
symmetric: Applies the reverse VLAN tag processing rule to outgoing traffic.
For this command to take effect, follow these restrictions and guidelines:
· Do not use this command on a VXLAN IP gateway. This command and VXLAN IP gateway configuration are mutually exclusive.
· You must configure a match criterion by using the encapsulation command, and specify Ethernet access mode by using the xconnect vsi command.
If the rewrite inbound tag command and a QoS policy are both used, this command takes effect prior to the QoS policy. The QoS policy takes effect on the traffic that has been processed by using the rewrite inbound tag command.
When you configure a nest rule for incoming traffic, follow these restrictions and guidelines:
· VXLAN supports a maximum of two VLAN tags.
? To add an outer VLAN tag for untagged or single-tagged frames, configure a nest s-vid vlan-id rule. To add one VLAN tag for untagged frames, you must use a nest s-vid vlan-id rule instead of a nest c-vid vlan-id rule.
? To insert an inner VLAN tag in a single-tagged frame, configure a nest c-vid vlan-id rule. If the encapsulation { default | tagged } frame match criterion is used, the 802.1p priority in the added inner VLAN tag is set to 0. If the symmetric keyword is specified, the device does not strip the inner tag of the returned outgoing traffic.
? To add two VLAN tags to untagged frames, configure a nest s-vid vlan-id c-vid vlan-id rule. You cannot add two tags to tagged frames.
· If the nest rule specifies an outer VLAN (s-vid vlan-id) and the symmetric keyword, you must add the site-facing interface to the specified outer VLAN.
When you configure a re-mark rule for incoming traffic, follow these restrictions and guidelines:
· The VLAN tag of a single-tagged frame is processed as the outer VLAN tag. To perform one-to-one mapping for a single-tagged frame, configure a remark 1-to-1 s-vid vlan-id rule.
· If you use a remark 2-to-1 c-vid vlan-id rule with the encapsulation { default | tagged } criterion, the 802.1p priority in the new inner VLAN tag is copied from the original outer VLAN tag.
· If you use a remark 1-to-2 s-vid vlan-id c-vid vlan-id rule with the encapsulation { default | tagged } criterion, the 802.1p priority in the new inner VLAN tag is set to 0.
· If you use the symmetric keyword in the re-mark rule, follow these restrictions and guidelines:
? If you specify an outer VLAN tag in the rule, you must configure the frame match criterion to match outer VLAN tags.
? If both outer and inner VLAN tags are specified in the rule, you must configure the frame match criterion to match both outer and inner VLAN tags.
? If a remark 1-to-1 c-vid vlan-id rule is configured, the device does not perform reverse one-to-one VLAN mapping for the returned outgoing traffic.
When you configure a strip rule for incoming traffic, follow these restrictions and guidelines:
· The VLAN tag of a single-tagged frame is processed as the outer VLAN tag. To remove its VLAN tag, configure the strip s-vid rule.
· If the strip rule contains the symmetric keyword, the following restrictions apply:
? If the rule strips the outer VLAN tag, you must configure the frame match criterion to match outer VLAN tags.
? If the rule strips both inner and outer VLAN tags, you must configure the frame match criterion to match both outer and inner VLAN tags.
? The device does not add the VLAN tag that was removed in the inbound direction for the returned outgoing traffic.
· If the encapsulation { default | tagged } frame match criterion is used, do not configure the strip s-vid rule. This rule cannot take effect on the matching frames.
To modify the VLAN tag processing rule for incoming traffic, you must first delete the existing rule by using the undo rewrite inbound tag command.
# Configure Ethernet service instance 1 on Ten-GigabitEthernet 1/0/1 to replace outer VLAN tag 10 with outer VLAN tag 100 for incoming traffic.
[Sysname-Ten-GigabitEthernet1/0/1-srv1] encapsulation s-vid 10
[Sysname-Ten-GigabitEthernet1/0/1-srv1] rewrite inbound tag remark 1-to-1 s-vid 100
rewrite outbound tag
Use rewrite outbound tag to configure the VLAN tag processing rule for outgoing traffic.
Use undo rewrite outbound tag to restore the default.
rewrite outbound tag { nest { c-vid vlan-id | s-vid vlan-id [ c-vid vlan-id ] } | remark { { 1-to-1 | 2-to-1 } { c-vid vlan-id | s-vid vlan-id } | { 1-to-2 | 2-to-2 } s-vid vlan-id c-vid vlan-id } | strip { c-vid | s-vid [ c-vid ] } }
VLAN tags of outgoing traffic are not processed.
This command is mutually exclusive with the symmetric keyword in the rewrite inbound tag command. To use this command, you must make sure the symmetric keyword is not specified in the VLAN tag processing rule for incoming traffic.
· You must specify Ethernet access mode by using the xconnect vsi command.
If the rewrite outbound tag command and a QoS policy are both used, this command takes effect prior to the QoS policy. The QoS policy takes effect on the traffic that has been processed by using the rewrite outbound tag command.
When you configure a nest rule for outgoing traffic, follow these restrictions and guidelines:
· You can configure a nest rule only for untagged packets.
· To add one tag to untagged frames, you can use either a nest s-vid rule or nest c-vid rule.
· If an outer VLAN (s-vid vlan-id) is specified, you must add the site-facing interface to the specified outer VLAN.
You cannot use the following rules for untagged or tagged frames:
· Re-mark rules that use one-to-one VLAN mapping for inner VLAN tag replacement (remark 1-to-1 c-vid vlan-id).
· The inner VLAN strip rule (strip c-vid).
To modify the VLAN tag processing rule for outgoing traffic, you must first delete the existing rule by using the undo rewrite outbound tag command.
# Configure Ethernet service instance 1 on Ten-GigabitEthernet 1/0/1 to replace outer VLAN tag 10 with outer VLAN tag 100 for incoming traffic and to remove the outer VLAN tags for outgoing traffic.
[Sysname-Ten-GigabitEthernet1/0/1-srv1] rewrite outbound tag strip s-vid
Use selective-flooding mac-address to enable selective flood for a MAC address.
Use undo selective-flooding mac-address to disable selective flood for a MAC address.
selective-flooding mac-address mac-address
undo selective-flooding mac-address mac-address
Selective flood is disabled for all MAC addresses.
VSI view
mac-address: Specifies a MAC address. The MAC address cannot be all Fs.
This command excludes a remote unicast or multicast MAC address from the remote flood suppression done by using the flooding disable command. The VTEP will flood the frames destined for the specified MAC address to remote sites when floods are confined to the local site.
# Enable selective flood for 000f-e201-0101 on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] selective-flooding mac-address 000f-e201-0101
flooding disable
service-instance
Use service-instance to create an Ethernet service instance and enter its view, or enter the view of an existing Ethernet service instance.
Use undo service-instance to delete an Ethernet service instance.
undo service-instance instance-id
No Ethernet service instances exist.
# On Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/1, create Ethernet service instance 1 and enter Ethernet service instance view.
shutdown
Use shutdown to shut down a VSI.
Use undo shutdown to bring up a VSI.
shutdown
VSIs are up.
VSI view
Use this command to temporarily disable a VSI to provide Layer 2 switching services. The shutdown action does not change settings on the VSI. You can continue to configure the VSI. After you bring up the VSI again, the VSI provides services based on the latest settings.
# Shut down VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
display l2vpn vsi
Use statistics enable to enable packet statistics for an Ethernet service instance.
Use undo statistics enable to disable packet statistics for an Ethernet service instance.
statistics enable
The packet statistics feature is disabled for an Ethernet service instance.
For this command to take effect, you must configure a frame match criterion for the Ethernet service instance and map it to a VSI. If you modify the frame match criterion or VSI mapping, packet statistics of the instance is cleared.
# Enable packet statistics for Ethernet service instance 200 on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 200
[Sysname-Ten-GigabitEthernet1/0/1-srv200] statistics enable
Related command
Use statistics enable to enable packet statistics for a VSI.
Use undo statistics enable to disable packet statistics for a VSI.
statistics enable
The packet statistics feature is disabled for a VSI.
VSI view
# Enable packet statistics for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] statistics enable
tunnel
Use tunnel to assign VXLAN tunnels to a VXLAN.
Use undo tunnel to remove VXLAN tunnels from a VXLAN.
tunnel { tunnel-number [ backup-tunnel tunnel-number | relay-agent ipoe ] | all }
undo tunnel { tunnel-number | all }
A VXLAN does not contain VXLAN tunnels.
VXLAN view
tunnel-number: Specifies a tunnel interface number. The value range for this argument is 1 to 4096. The tunnel must be a VXLAN tunnel.
backup-tunnel tunnel-number: Specifies a backup tunnel by its tunnel interface number. The value range for the tunnel-number argument is 1 to 4095. The tunnel must be a VXLAN tunnel.
relay-agent: Enables relay agent for the tunnel to transmit IPoE packets to the remote VTEP. If you do not specify this keyword, relay agent is disabled on the tunnel.
ipoe: Enables IPoE relay agent.
all: Specifies all VXLAN tunnels.
This command assigns a VXLAN tunnel to a VXLAN to provide Layer 2 connectivity for the VXLAN between two sites. In unicast mode, the system floods unknown unicast, multicast, and broadcast traffic to each tunnel in the VXLAN.
You can assign multiple VXLAN tunnels to a VXLAN, and configure a VXLAN tunnel to trunk multiple VXLANs.
To assign a pair of primary and backup VXLAN tunnels to the VXLAN, specify the backup-tunnel tunnel-number option. When the primary VXLAN tunnel is operating correctly, the backup VXLAN tunnel does not forward traffic. When the primary VXLAN tunnel goes down, traffic is switched to the backup VXLAN tunnel.
If you enable IPoE relay agent on a VXLAN tunnel, the device uses this tunnel to send IPoE packets received from the associated VXLAN to the remote VTEP. Typically, relay agent is used on DPs in the forwarding-control separation solution. For a DP to send control traffic (IPoE packets) to a CP, you must enable IPoE relay agent on the VXLAN tunnel between the DP and the CP.
If you assign VXLAN tunnels to a VXLAN one by one, you cannot remove all the VXLAN tunnels by using the undo tunnel all command.
If you assign all VXLAN tunnels to a VXLAN by using the tunnel all command, you cannot remove the VXLAN tunnels one by one. You can only use the undo tunnel all command to remove all the VXLAN tunnels.
As a best practice, use the tunnel all command only when batch VXLAN tunnel assignment is necessary.
# Assign VXLAN tunnels 1 and 2 to VXLAN 10000.
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
[Sysname-vsi-vpna-vxlan-10000] tunnel 2
tunnel bfd enable
Use tunnel bfd enable to enable BFD on a VXLAN tunnel interface.
Use undo tunnel bfd enable to disable BFD on a VXLAN tunnel interface.
tunnel bfd enable destination-mac mac-address
BFD is disabled on a VXLAN tunnel interface.
VXLAN tunnel interface view
destination-mac mac-address: Specifies a destination MAC address in H-H-H format for BFD control packets. The MAC address must be a remote VTEP address. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001.
Enable BFD on both ends of a VXLAN tunnel for quick link connectivity detection. The VTEPs periodically send BFD single-hop control packets to each other through the VXLAN tunnel. A VTEP sets the tunnel state to Defect if it has not received control packets from the remote end for 5 seconds. In this situation, the tunnel interface state is still Up. The tunnel state will change from Defect to Up if the VTEP can receive BFD control packets again.
For BFD sessions to come up, you must reserve a VXLAN by using the reserved vxlan command.
# Enable BFD on VXLAN tunnel interface Tunnel 9, and specify 1-1-1 as the destination MAC address for BFD control packets.
[Sysname] interface tunnel 9 mode vxlan
[Sysname-Tunnel9] tunnel bfd enable destination-mac 1-1-1
tunnel global source-address
Use tunnel global source-address to specify a global source address for VXLAN tunnels.
Use undo tunnel global source-address to restore the default.
tunnel global source-address ip-address
No global source address is specified for VXLAN tunnels.
ip-address: Specifies an IP address.
IMPORTANT: For correct VXLAN deployment and VTEP management, do not manually specify tunnel-specific source addresses for VXLAN tunnels if OVSDB is used. |
A VXLAN tunnel uses the global source address if you do not specify a source interface or source address for the tunnel.
The global source address takes effect only on VXLAN tunnels (VXLAN-DCI tunnels not included).
# Specify 1.1.1.1 as the global source address for VXLAN tunnels.
[Sysname] tunnel global source-address 1.1.1.1
vsi
Use vsi to create a VSI and enter its view, or enter the view of an existing VSI.
Use undo vsi to delete a VSI.
vsi vsi-name
undo vsi vsi-name
No VSIs exist.
A VSI acts as a virtual switch to provide Layer 2 switching services for a VXLAN on a VTEP. A VSI has all functions of a physical Ethernet switch, including source MAC address learning, MAC address aging, and flooding.
A VSI can provide services only for one VXLAN.
# Create VSI vxlan10 and enter VSI view.
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
display l2vpn vsi
vxlan
Use vxlan to create a VXLAN and enter its view, or enter the view of an existing VXLAN.
Use undo vxlan to restore the default.
vxlan vxlan-id
undo vxlan
No VXLANs exist.
VSI view
You can create only one VXLAN for a VSI. The VXLAN ID for each VSI must be unique.
# Create VXLAN 10000 for VSI vpna and enter VXLAN view.
[Sysname] vsi vpna
vsi
Use vxlan invalid-vlan-tag discard to enable the device to drop the VXLAN packets that have 802.1Q VLAN tags in the inner Ethernet header.
Use undo vxlan invalid-vlan-tag discard to restore the default.
The device does not check whether a VXLAN packet has 802.1Q VLAN tags in the inner Ethernet header.
If a remote VTEP uses the Ethernet access mode, its VXLAN packets might contain 802.1Q VLAN tags. To prevent the local VTEP from dropping the VXLAN packets, do not execute the vxlan invalid-vlan-tag discard command on the local VTEP.
To configure the access mode, use the xconnect vsi command.
# Enable the device to drop VXLAN packets that have 802.1Q VLAN tags.
[Sysname] vxlan invalid-vlan-tag discard
xconnect vsi
vxlan local-mac report
Use vxlan local-mac report to enable local-MAC logging.
Use undo vxlan local-mac report to disable local-MAC logging.
Local-MAC logging is disabled.
When the local-MAC logging feature is enabled, the VXLAN module immediately sends a log message with its local MAC addresses to the information center. When a local MAC address is added or removed, a log message is also sent to the information center to report the local-MAC change.
With the information center, you can set log message filtering and output rules, including output destinations. For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
# Enable local-MAC logging.
[Sysname] vxlan local-mac report
Use vxlan tunnel mac-learning disable to disable remote-MAC address learning.
Use undo vxlan tunnel mac-learning disable to enable remote-MAC address learning.
Remote-MAC address learning is enabled.
When network attacks occur, use this command to prevent the device from learning incorrect remote MAC addresses in the data plane.
# Disable remote-MAC address learning.
[Sysname] vxlan tunnel mac-learning disable
vxlan udp-port
Use vxlan udp-port to set the destination UDP port number for VXLAN packets.
Use undo vxlan udp-port to restore the default.
vxlan udp-port port-number
undo vxlan udp-port
The destination UDP port number is 4789 for VXLAN packets.
port-number: Specifies a UDP port number in the range of 1 to 65535. As a best practice, specify a port number in the range of 1024 to 65535 to avoid conflict with well-known ports.
You must configure the same destination UDP port number on all VTEPs in a VXLAN.
# Set the destination UDP port number to 6666 for VXLAN packets.
[Sysname] vxlan udp-port 6666
vxlan vlan-based
Use vxlan vlan-based to enable VLAN-based VXLAN assignment.
Use undo vxlan vlan-based to disable VLAN-based VXLAN assignment.
vxlan vlan-based
VLAN-based VXLAN assignment is disabled.
You can assign customer traffic to a VXLAN by using one of the following methods:
· Ethernet service instance-to-VSI mapping—This method uses the frame match criterion of an Ethernet service instance to match a list of VLANs on a site-facing Layer 2 interface. The VTEP assigns customer traffic to a VXLAN by mapping the Ethernet service instance to a VSI.
· VLAN-based VXLAN assignment—This method maps a VLAN to a VXLAN. When a VLAN is mapped to a VXLAN and VLAN-based VXLAN assignment is enabled, the device automatically performs the following operations:
a. Creates an Ethernet service instance that uses the VLAN ID as its instance ID on each interface in the VLAN. The matching outer VLAN ID of the Ethernet service instances is the VLAN ID.
b. Maps the Ethernet service instances to the VSI of the VXLAN.
Do not configure both Ethernet service instance-to-VSI mapping and VLAN-based VXLAN assignment.
# Enable VLAN-based VXLAN assignment.
vxlan vni
Use vxlan vni to map a VLAN to a VXLAN.
Use undo vxlan vni to remove the VXLAN mapping for a VLAN.
vxlan vni vxlan-id
undo vxlan vni
A VLAN is not mapped to a VXLAN.
VLAN view
Before you map VLANs to VXLANs, enable VLAN-based VXLAN assignment by using the vxlan vlan-based command.
You cannot map VLAN 1 to any VXLAN. Do not map a VLAN to the L3 VXLAN ID of EVPN.
If you map a VLAN to a nonexistent VXLAN, the configuration takes effect after the VXLAN is created.
# Map VLAN 10 to VXLAN 100.
[Sysname] vlan 10
vxlan vlan-based
xconnect vsi
Use xconnect vsi to map an AC to a VSI.
Use undo xconnect vsi to restore the default.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-3> ]
undo xconnect vsi
An AC is not mapped to any VSI.
vsi-name: Specifies the VSI name, a case-sensitive string of 1 to 31 characters.
access-mode: Specifies an access mode. The default access mode is VLAN.
ethernet: Specifies the Ethernet access mode.
vlan: Specifies the VLAN access mode.
track track-entry-number&<1-3>: Specifies a space-separated list of up to three track entry numbers in the range of 1 to 1024. The AC is up only if a minimum of one associated track entry is in positive state.
To monitor the status of an AC, associate it with track entries.
To configure this command for an Ethernet service instance, you must first use the encapsulation command to add a frame match criterion to the service instance.
For traffic that matches the Ethernet service instance, the system uses the VSI's MAC address table to make a forwarding decision.
The access mode determines how a VTEP processes the 802.1Q VLAN tags in the inner Ethernet frames assigned to the VSI.
· VLAN access mode—The VTEP processes 802.1Q VLAN tags of Ethernet frames as follows:
? If the Ethernet service instance uses the encapsulation untagged criterion, Ethernet frames received from or sent to the local site does not contain 802.1Q VLAN tags.
- The VTEP directly forwards untagged Ethernet frames received from the local site.
- The VTEP does not add 802.1Q VLAN tags to Ethernet frames when forwarding them to the local site.
? If the Ethernet service instance uses any other criterion except encapsulation default, Ethernet frames received from or sent to the local site must contain 802.1Q VLAN tags.
- For an Ethernet frame received from the local site, the VTEP removes all its 802.1Q VLAN tags before forwarding the frame.
- For an Ethernet frame destined for the local site, the VTEP adds 802.1Q VLAN tags to the frame before forwarding the frame.
? The Ethernet service instance cannot use the encapsulation default criterion if VLAN access mode is used.
In VLAN access mode, VXLAN packets sent between VXLAN sites do not contain 802.1Q VLAN tags. VXLAN can provide Layer 2 connectivity for different 802.1Q VLANs between sites. You can use different 802.1Q VLANs to provide the same service in different sites.
· Ethernet access mode—The VTEP does not process the 802.1Q VLAN tags of Ethernet frames received from or sent to the local site.
? For an Ethernet frame received from the local site, the VTEP forwards the frame with the 802.1Q VLAN tags intact.
? For an Ethernet frame destined for the local site, the VTEP forwards the frame without adding 802.1Q VLAN tags.
In Ethernet access mode, VXLAN packets sent between VXLAN sites contain 802.1Q VLAN tags. VXLAN cannot provide Layer 2 connectivity for different 802.1Q VLANs between sites. You must use the same 802.1Q VLAN to provide the same service between sites.
# On Ten-GigabitEthernet 1/0/1, configure Ethernet service instance 200 to match frames with an outer 802.1Q VLAN tag of 200, and map the instance to VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname-Ten-GigabitEthernet1/0/1-srv200] encapsulation s-vid 200
[Sysname-Ten-GigabitEthernet1/0/1-srv200] xconnect vsi vpn1
encapsulation
vsi
VXLAN IP gateway commands
arp distributed-gateway dynamic-entry synchronize
Use arp distributed-gateway dynamic-entry synchronize to enable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
Use undo arp distributed-gateway dynamic-entry synchronize to disable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
Dynamic ARP entry synchronization is disabled for distributed VXLAN IP gateways.
When local proxy ARP is enabled on distributed VXLAN IP gateways, each gateway learns ARP information independently. A gateway does not forward ARP packets destined for its local VSI interfaces to other gateways. For distributed VXLAN IP gateways to have the same ARP entries, you must enable dynamic ARP entry synchronization.
A controller or the EVPN feature can also synchronize ARP entries among distributed VXLAN IP gateways. When you use a controller or the EVPN feature, do not enable dynamic ARP entry synchronization.
# Enable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
[Sysname] arp distributed-gateway dynamic-entry synchronize
distributed-gateway local
local-proxy-arp enable (Layer 3—IP Services Command Reference)
arp send-rate
Use arp send-rate to set an ARP packet sending rate limit for a VSI interface.
Use undo arp send-rate to remove the ARP packet sending rate limit for a VSI interface.
arp send-rate pps
undo arp send-rate
The ARP packet sending rate is not limited for a VSI interface.
VSI interface view
pps: Specifies a rate limit in the range of 1 to 500 pps.
VMs have limited capacity to process packets. To prevent packet processing from degrading VM performance, limit the ARP packet sending rate of the VSI interface for VMs. The VTEP will drop excess ARP packets if the rate limit is exceeded.
# Set the ARP packet sending rate limit to 50 pps for VSI-interface 1.
<Sysname> system
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] arp send-rate 50
default
Use default to restore the default settings for a VSI interface.
default
VSI interface view
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions.
To resolve this problem:
1. Use the display this command in interface view to identify these commands.
2. Use their undo forms or follow the command reference to restore their default settings.
3. If the restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for VSI-interface 100.
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] default
This command will restore the default settings. Continue? [Y/N]:y
description
Use description to configure the description of a VSI interface.
The description of a VSI interface is interface-name plus Interface (for example, Vsi-interface100 Interface).
VSI interface view
# Configure the description as gateway for VXLAN 10 for VSI-interface 100.
[Sysname-Vsi-interface100] description gateway for VXLAN 10
display interface vsi-interface
Use display interface vsi-interface to display information about VSI interfaces.
display interface [ vsi-interface [ vsi-interface-id ] ] [ brief [ description | down ] ]
vsi-interface [ vsi-interface-id ]: Specifies VSI interfaces. If you specify a VSI interface, this command displays information about the specified interface. If you specify only the vsi-interface keyword, this command displays information about all VSI interfaces. If you do not specify the vsi-interface [ vsi-interface-id ] option, this command displays information about all interfaces. Make sure the specified VSI interfaces have been created on the device.
brief: Display brief interface information. If you do not specify this keyword, the command displays detailed interface information.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays interfaces that are physically down as well as the down reason. If you do not specify this keyword, the command does not filter output by physical interface state.
# Display information about VSI-interface 100.
<Sysname> display interface vsi-interface 100
Vsi-interface100
Current state: UP
Line protocol state: UP
Description: Vsi-interface100 Interface
Bandwidth: 1000000 kbps
IP packet frame type: Ethernet II, hardware address: 0011-2200-0102
IPv6 packet frame type: Ethernet II, hardware address: 0011-2200-0102
Table 11 Command output
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down. · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface: · UP—The data link layer protocol is up. · UP(spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. · DOWN—The data link layer protocol is down. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface. |
Maximum transmission unit |
MTU of the interface. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Internet address |
IP address of the interface. The primary attribute indicates that the address is the primary IP address. |
IP packet frame type |
IPv4 packet framing format. |
hardware address |
MAC address. |
IPv6 packet frame type |
IPv6 packet framing format. |
Physical |
Physical type of the interface, which is fixed at Unknown. |
baudrate |
Interface baudrate in kbps. |
Last clearing of counters |
Last time when interface statistics are cleared. The current software version does not support clearing VSI interface statistics. |
Last 300 seconds input rate |
Average input rate for the last 300 seconds. |
Last 300 seconds output rate |
Average output rate for the last 300 seconds. |
Input: 0 packets, 0 bytes, 0 drops |
Incoming traffic statistics on the interface: · Number of incoming packets. · Number of incoming bytes. · Number of dropped incoming packets. |
Output: 0 packets, 0 bytes, 0 drops |
Outgoing traffic statistics on the interface: · Number of outgoing packets. · Number of outgoing bytes. · Number of dropped outgoing packets. |
# Display brief information about all VSI interfaces.
<Sysname> display interface vsi-interface brief
Protocol: (s) - spoofing
Vsi100 DOWN DOWN --
# Display brief information and complete description for VSI-interface 100.
<Sysname> display interface vsi-interface 100 brief description
Vsi100 UP UP 1.1.1.1 VSI-interface100
# Displays interfaces that are physically down and the down reason.
Interface Link Cause
Vsi100 DOWN Administratively
Vsi200 DOWN Administratively
Table 12 Command output
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · UP (s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. · DOWN—The data link layer protocol of the interface is down. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Cause |
Cause for the physical link state of an interface to be DOWN: · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Not connected—The interface is not mapped to any VSI, or the mapped VSI does not have any AC or VXLAN tunnel. |
Use distributed-gateway local to specify a VSI interface as a distributed gateway to provide services for the local site.
Use undo distributed-gateway local to restore the default.
A VSI interface is not a distributed gateway.
VSI interface view
If a VXLAN uses distributed gateway services, you must assign the same IP address to the VXLAN's VSI interfaces on different VTEPs. To avoid IP address conflicts, you must specify the VSI interface on each VTEP as a distributed gateway.
# Specify VSI-interface 100 as a distributed gateway.
[Sysname-Vsi-interface100] distributed-gateway local
gateway subnet
Use gateway subnet to assign a subnet to a VSI.
Use undo gateway subnet to remove a subnet from a VSI.
gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
undo gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
No subnet is assigned to a VSI.
VSI view
ipv4-address: Specifies an IPv4 subnet address in dotted-decimal notation.
wildcard-mask: Specifies a wildcard mask in dotted decimal notation. In contrast to a network mask, the 0 bits in a wildcard mask represent "do care" bits, and the 1 bits represent "don't care" bits. If the "do care" bits in a packet's IP address are identical to the "do care" bits in the specified subnet address, the packet is assigned to the VSI. All "don't care" bits are ignored. The 0s and 1s in a wildcard mask can be noncontiguous. For example, 0.255.0.255 is a valid wildcard mask.
ipv6-address prefix-length: Specifies an IPv6 subnet address and the address prefix length in the range of 1 to 128.
You must configure this command on VSIs that share a gateway interface. This command enables the VSI interface to identify the VSI of a packet.
You can assign a maximum of eight IPv4 and IPv6 subnets to a VSI.
You must specify a gateway interface for a VSI before you can assign subnets to the VSI. If you remove the gateway interface from the VSI, the VSI's subnet settings are automatically deleted.
For VSIs that share a gateway interface, the subnets must be unique.
# Assign subnet 100.0.10.0/24 to VSI vxlan.
[Sysname] vsi vxlan
[Sysname-vsi-vxlan] gateway subnet 100.0.10.0 0.0.0.255
gateway vsi-interface
Use gateway vsi-interface to specify a gateway interface for a VSI.
Use undo gateway vsi-interface to restore the default.
gateway vsi-interface vsi-interface-id
No gateway interface is specified for a VSI.
VSI view
vsi-interface-id: Specifies a VSI interface by its number. The value range for this argument is 0 to 4094.
When you delete a VSI interface by using the undo interface vsi-interface command, the gateway interface setting of the VSI interface is also deleted.
A VSI can have only one gateway interface. Multiple VSIs can share a gateway interface.
# Specify VSI-interface 100 as the gateway interface for VSI vpna.
[Sysname] vsi vpna
[Sysname-vsi-vpna] gateway vsi-interface 100
Use interface vsi-interface to create a VSI interface and enter its view, or enter the view of an existing VSI interface.
Use undo interface vsi-interface to delete a VSI interface.
interface vsi-interface vsi-interface-id
undo interface vsi-interface vsi-interface-id
No VSI interfaces exist.
vsi-interface-id: Specifies a VSI interface number. The value range for this argument is 0 to 4094.
# Create VSI-interface 100 and enter VSI interface view.
ipv6 nd distributed-gateway dynamic-entry synchronize
Use ipv6 nd distributed-gateway dynamic-entry synchronize to enable dynamic ND entry synchronization for distributed VXLAN IP gateways.
Use undo ipv6 nd distributed-gateway dynamic-entry synchronize to disable dynamic ND entry synchronization for distributed VXLAN IP gateways.
Dynamic ND entry synchronization is disabled for distributed VXLAN IP gateways.
When local ND proxy is enabled on distributed VXLAN IP gateways, each gateway learns ND information independently. A gateway does not forward ND packets destined for its local VSI interfaces to other gateways. For distributed VXLAN IP gateways to have the same ND entries, you must enable dynamic ND entry synchronization.
A controller or the EVPN feature can also synchronize ND entries among distributed VXLAN IP gateways. When you use a controller or the EVPN feature, do not enable dynamic ND entry synchronization.
# Enable dynamic ND entry synchronization for distributed VXLAN IP gateways.
[Sysname] ipv6 nd distributed-gateway dynamic-entry synchronize
local-proxy-nd enable (Layer 3—IP Services Command Reference)
mac-address
Use mac-address to assign a MAC address to a VSI interface.
Use undo mac-address to restore the default.
undo mac-address
The MAC address of VSI interfaces is the bridge MAC address + 1.
VSI interface view
# Assign MAC address 0001-0001-0001 to VSI-interface 100.
[Sysname-Vsi-interface100] mac-address 1-1-1
mtu
Use mtu to set the MTU for a VSI interface.
mtu size
undo mtu
The default MTU of a VSI interface is 1444 bytes.
VSI interface view
size: Specifies an MTU value in the range of 46 to 1560 bytes.
# Set the MTU to 1430 bytes for VSI-interface 100.
[Sysname-Vsi-interface100] mtu 1430
shutdown
Use shutdown to shut down a VSI interface.
Use undo shutdown to bring up a VSI interface.
shutdown
A VSI interface is up.
VSI interface view
# Shut down VSI-interface 100.
[Sysname-Vsi-interface100] shutdown
vtep group member local
Use vtep group member local to assign the local VTEP to a VTEP group.
Use undo vtep group member local to remove the local VTEP from a VTEP group.
vtep group group-ip member local member-ip
undo vtep group group-ip member local
A VTEP is not assigned to any VTEP group.
group-ip: Specifies a VTEP group by its group IP address. The IP address must already exist on the local VTEP.
member-ip: Specifies the member VTEP IP address for the local VTEP. The IP address must already exist on the local VTEP.
Member VTEPs in a VTEP group cannot use the group IP address or share an IP address.
# Assign the local VTEP to VTEP group 1.1.1.1, and specify 2.2.2.2 as the member VTEP IP address of the local VTEP.
[Sysname] vtep group 1.1.1.1 member local 2.2.2.2
vtep group member remote
Use vtep group member remote to specify a VTEP group and its member VTEPs.
Use undo vtep group member remote to remove a VTEP group and its member VTEPs.
vtep group group-ip member remote member-ip&<1-8>
undo vtep group group-ip member remote
No VTEP group is specified.
member-ip&<1-8>: Specifies a space-separated list of up to eight member VTEP IP addresses.
# Specify VTEP group 1.1.1.1 and its member VTEPs at 2.2.2.2, 3.3.3.3, and 4.4.4.4.
[Sysname] vtep group 1.1.1.1 member remote 2.2.2.2 3.3.3.3 4.4.4.4
vxlan tunnel arp-learning disable
Use vxlan tunnel arp-learning disable to disable remote ARP learning for VXLANs.
Use undo vxlan tunnel arp-learning disable to enable remote ARP learning for VXLANs.
Remote ARP learning is enabled for VXLANs.
By default, the device learns ARP information of remote VMs from packets received on VXLAN tunnel interfaces. To save resources on VTEPs in an SDN transport network, you can temporarily disable remote ARP learning when the controller and VTEPs are synchronizing entries. After the entry synchronization is completed, use the undo vxlan tunnel arp-learning disable command to enable remote ARP learning.
As a best practice, disable remote ARP learning for VXLANs only when the controller and VTEPs are synchronizing entries.
# Disable remote ARP learning for VXLANs.
<Sysname> system
[Sysname] vxlan tunnel arp-learning disable
vxlan tunnel nd-learning disable
Use vxlan tunnel nd-learning disable to disable remote ND learning for VXLANs.
Use undo vxlan tunnel nd-learning disable to enable remote ND learning for VXLANs.
Remote ND learning is enabled for VXLANs.
By default, the device learns ND information of remote VMs from packets received on VXLAN tunnel interfaces. To save resources on VTEPs in an SDN transport network, you can temporarily disable remote ND learning when the controller and VTEPs are synchronizing entries. After the entry synchronization is completed, use the undo vxlan tunnel nd-learning disable command to enable remote ND learning.
As a best practice, disable remote ND learning for VXLANs only when the controller and VTEPs are synchronizing entries.
# Disable remote ND learning for VXLANs.
<Sysname> system
[Sysname] vxlan tunnel nd-learning disable
OVSDB commands
ovsdb server bootstrap ca-certificate
Use ovsdb server bootstrap ca-certificate to specify a CA certificate file for establishing OVSDB SSL connections.
Use undo ovsdb server bootstrap ca-certificate to restore the default.
ovsdb server bootstrap ca-certificate ca-filename
SSL uses the CA certificate file in the PKI domain.
ca-filename: Specifies the CA certificate file name, a case-insensitive string. The file name cannot contain the slot string, and the file must be stored on the active MPU.
For the specified certificate to take effect, you must execute the ovsdb server enable command to enable the OVSDB server. You must disable and then re-enable the OVSDB server if it has been enabled.
If the specified CA certificate file does not exist, the device obtains a self-signed certificate from the controller. The obtained file uses the name specified for the ca-filename argument.
# Specify CA certificate file ca-new for establishing OVSDB SSL connections.
[Sysname] ovsdb server bootstrap ca-certificate ca-new
ovsdb server enable
ovsdb server pki domain
ovsdb server pssl
ovsdb server ssl
ovsdb server enable
Use ovsdb server enable to enable the OVSDB server.
Use undo ovsdb server enable to disable the OVSDB server.
ovsdb server enable
The OVSDB server is disabled.
To obtain configuration data from controllers, you must enable the OVSDB server.
Before you enable the OVSDB server, you must establish an OVSDB SSL or TCP connection with a minimum of one controller.
# Enable the OVSDB server.
Use ovsdb server pki domain to specify a PKI domain for establishing OVSDB SSL connections.
Use undo ovsdb bootstrap server pki domain to restore the default.
ovsdb server pki domain domain-name
undo ovsdb server pki domain
No PKI domain is specified for establishing OVSDB SSL connections.
domain-name: Specifies a PKI domain name, a case-sensitive string of 1 to 31 characters. The PKI domain must already exist and contain a complete certificate and key.
To communicate with controllers through SSL, you must specify a PKI domain.
For the specified PKI domain to take effect, you must execute the ovsdb server enable command to enable the OVSDB server. You must disable and then re-enable the OVSDB server if it has been enabled.
For more information about PKI domains, see PKI in Security Configuration Guide.
# Specify PKI domain ovsdb_test for establishing OVSDB SSL connections.
[Sysname] ovsdb server pki domain ovsdb_test
ovsdb server enable
ovsdb server pssl
ovsdb server ssl
ovsdb server pssl
Use ovsdb server pssl to enable the device to listen for OVSDB SSL connection requests.
Use undo ovsdb server pssl to restore the default.
ovsdb server pssl [ port port-number ]
The device does not listen for OVSDB SSL connection requests.
port port-number: Specifies a port to listen for OVSDB SSL connection requests. The value range for the port-number argument is 1 to 65535. If you do not specify a port, the device uses the port number 6640.
Before you use this command, you must specify a PKI domain for SSL.
You can specify only one port to listen for OVSDB SSL connection requests. If you execute this command multiple times, the most recent configuration takes effect.
For the specified port setting to take effect, you must execute the ovsdb server enable command to enable the OVSDB server. You must disable and then re-enable the OVSDB server if it has been enabled.
# Enable the device to listen for OVSDB SSL connection requests on port 6640.
[Sysname] ovsdb server pssl
ovsdb server enable
ovsdb server ssl
ovsdb server ptcp
Use ovsdb server ptcp to enable the device to listen for OVSDB TCP connection requests.
Use undo ovsdb server ptcp to restore the default.
ovsdb server ptcp [ port port-number ]
The device does not listen for OVSDB TCP connection requests.
port-number: Specifies a port to listen for OVSDB TCP connection requests. The value range for the port-number argument is 1 to 65535. If you do not specify a port, the device uses the port number 6640.
You can specify only one port to listen for OVSDB TCP connection requests. If you execute this command multiple times, the most recent configuration takes effect.
# Enable the device to listen for OVSDB TCP connection requests on port 6640.
[Sysname] ovsdb server ptcp
ovsdb server enable
ovsdb server tcp
ovsdb server ssl
Use ovsdb server ssl to set up an active OVSDB SSL connection to a controller.
Use undo ovsdb server ssl to remove an OVSDB SSL connection from a controller.
ovsdb server ssl ip ip-address port port-number
undo ovsdb server ssl ip ip-address port port-number
The device does not have active OVSDB SSL connections to a controller.
ip ip-address: Specifies the destination IP address for the SSL connection.
port port-number: Specifies the destination port for the SSL connection. The value range for the port-number argument is 1 to 65535.
The device can have a maximum of eight active SSL connections.
To establish the connection, you must execute the ovsdb server enable command. You must disable and then re-enable the OVSDB server if it has been enabled.
# Set up an active SSL connection to port 6632 at 192.168.12.2.
[Sysname] ovsdb server ssl ip 192.168.12.2 port 6632
ovsdb server enable
ovsdb server pssl
ovsdb server tcp
Use ovsdb server tcp to set up an active OVSDB TCP connection to a controller.
Use undo ovsdb server tcp to remove an OVSDB TCP connection.
ovsdb server tcp ip ip-address port port-number
undo ovsdb server tcp ip ip-address port port-number
The device does not have active OVSDB TCP connections.
ip ip-address: Specifies the destination IP address for the TCP connection.
port port-number: Specifies the destination port for the TCP connection. The value range for the port-number argument is 1 to 65535.
The device can have a maximum of eight active OVSDB TCP connections.
# Set up an active OVSDB TCP connection to port 6632 at 192.168.12.2.
[Sysname] ovsdb server tcp ip 192.168.12.2 port 6632
ovsdb server enable
ovsdb server ptcp
vtep access port
Use vtep access port to specify a site-facing interface as a VTEP access port.
Use undo vtep access port to restore the default.
vtep access port
An interface is not a VTEP access port.
For controllers to manage a site-facing interface, you must specify the interface as a VTEP access port.
# Specify Ten-GigabitEthernet 1/0/1 as a VTEP access port.
[Sysname-Ten-GigabitEthernet1/0/1] vtep access port
vtep enable
Use vtep enable to enable the OVSDB VTEP service.
Use undo vtep enable to disable the OVSDB VTEP service.
vtep enable
undo vtep enable
The OVSDB VTEP service is disabled.
# Enable the OVSDB VTEP service.
[Sysname] vtep enable
