- 07 IP Multicast Command Reference
- 01-IGMP snooping commands
- 02-PIM snooping commands
- 03-Multicast VLAN commands
- 04-Multicast routing and forwarding commands
- 05-IGMP commands
- 06-PIM commands
- 07-MSDP commands
- 08-Multicast VPN commands
- 09-MLD snooping commands
- 10-IPv6 PIM snooping commands
- 11-IPv6 multicast VLAN commands
- 12-IPv6 multicast routing and forwarding commands
- 13-MLD commands
- 14-IPv6 PIM commands
07-MSDP commands | 119.81 KB |
MSDP commands
cache-sa-enable
Use cache-sa-enable to enable the SA message cache mechanism to cache the (S, G) entries contained in SA messages.
Use undo cache-sa-enable to disable the SA message cache mechanism.
cache-sa-enable
The SA message cache mechanism is enabled, and the device caches the (S, G) entries contained in received SA messages.
MSDP view
# Enable the SA message cache mechanism on the public network, so that the device caches the (S, G) entries contained in the received SA messages.
[Sysname] msdp
[Sysname-msdp] cache-sa-enable
display msdp sa-cache
display msdp sa-count
display msdp brief
Use display msdp brief to display brief information about MSDP peers.
display msdp [ vpn-instance vpn-instance-name ] brief [ state { connect | disabled | established | listen | shutdown } ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays brief information about MSDP peers on the public network.
state: Specifies a state. If you do not specify this keyword, the command displays brief information about MSDP peers in all states.
connect: Specifies the connecting state.
disabled: Specifies the connection failure state.
established: Specifies the session state.
listen: Specifies the listening state.
shutdown: Specifies the shutdown state.
# Display brief information about MSDP peers in all states on the public network.
<Sysname> display msdp brief
Configured Established Listen Connect Shutdown Disabled
1 1 0 0 0 0
Peer address State Up/Down time AS SA count Reset count
20.20.20.20 Established 00:00:13 100 0 0
Configured |
Number of MSDP peers that have been configured. |
Established |
Number of MSDP peers in established state. |
Listen |
Number of MSDP peers in listening state. |
Connect |
Number of MSDP peers in connecting state. |
Shutdown |
Number of MSDP peers in shutdown state. |
Disabled |
Number of MSDP peers in connection failure state. |
Peer address |
MSDP peer address. |
State |
MSDP peer status: · Established—A session has been established and the MSDP peer is in session. · Listen—A session has been established and the local device acts as the server in listening state. · Connect—A session is not established and the local device acts as a client in connecting state. · Shutdown—The session has been torn down. · Down—The connection failed. |
Up/Down time |
Length of time since the MSDP peering connection was established or torn down. |
AS |
Number of the AS where the MSDP peer is located. If the system could not obtain the AS number, this field displays a question mark (?). |
SA count |
Number of (S, G) entries in the SA cache. |
Reset count |
MSDP peering connection reset times. |
display msdp non-stop-routing status
Use display msdp non-stop-routing status to display MSDP NSR status information.
# Display MSDP NSR status information.
<Sysname> display msdp non-stop-routing status
MSDP NSR status: Ready
Location of preferred standby process: Slot 1
TCP NSR status: Ready
MSDP NSR status |
MSDP NSR status: · Ready—MSDP NSR has backed up MSDP peer and remote source information from the active process to standby processes. In this state, MSDP NSR can ensure continuous routing when an active/standby process switchover occurs. · Not ready—MSDP NSR is backing up MSDP peer and remote multicast source information from the active process to the standby process. If an active/standby process switchover occurs in this state, traffic is interrupted. · Not configured—MSDP NSR is disabled. |
Location of preferred standby process |
(In standalone mode.) ID of the slot where the preferred standby process resides. (In IRF mode.) Chassis ID and slot ID where the preferred standby process resides. |
TCP NSR status |
TCP NSR status: · Ready—TCP NSR has backed up TCP connection information from the active process to standby processes. · Not ready—TCP NSR is backing up TCP connection information from the active process to standby processes. |
display msdp peer-status
Use display msdp peer-status to display detailed status information for MSDP peers.
display msdp [ vpn-instance vpn-instance-name ] peer-status [ peer-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays detailed status information for MSDP peers on the public network.
peer-address: Specifies an MSDP peer by its address. If you do not specify an MSDP peer, this command displays detailed status information for all MSDP peers.
# Display detailed status information for MSDP peer 20.20.20.20 on the public network.
<Sysname> display msdp peer-status 20.20.20.20
MSDP peer 20.20.20.20; AS 100
Description:
Information about connection status:
State: Disabled
Up/down time: 14:41:08
Resets: 0
Connection interface: LoopBack0 (20.20.20.30)
Received/sent messages: 867/867
Discarded input messages: 0
Discarded output messages: 0
Elapsed time since last connection or counters clear: 14:42:40
Mesh group peer joined: momo
Last disconnect reason: Hold timer expired with truncated message
Truncated packet: 5 bytes in buffer, type: 1, length: 20, without packet time: 75s
Information about (Source, Group)-based SA filtering policy:
Import policy: None
Export policy: None
Information about SA-Requests:
Policy to accept SA-Requests: None
Sending SA-Requests status: Disable
Minimum TTL to forward SA with encapsulated data: 0
SAs learned from this peer: 0, SA cache maximum for the peer: 4294967295
Input queue size: 0, Output queue size: 0
Counters for MSDP messages:
RPF check failure: 0
Incoming/outgoing SA: 0/0
Incoming/outgoing SA-Request: 0/0
Incoming/outgoing SA-Response: 0/0
Incoming/outgoing Keepalive: 867/867
Incoming/outgoing Notification: 0/0
Incoming/outgoing Traceroutes in progress: 0/0
Incoming/outgoing Traceroute reply: 0/0
Incoming/outgoing Unknown: 0/0
Incoming/outgoing data packet: 0/0
MSDP peer |
AS |
State |
MSDP peer status: · Established—A session has been established and the MSDP peer is in session. · Listen—A session has been established and the local device acts as the server in listening state. · Connect—A session is not established and the local device acts as a client in connecting state. · Shutdown—The session has been torn down. · Disabled—The connection failed. |
Up/Down time |
Resets |
Connection interface |
Interface and IP address used for setting up a TCP connection with the remote MSDP peer. |
Received/sent messages |
Number of SA messages sent and received through this connection. |
Discarded input messages |
Number of discarded incoming messages. |
Discarded output messages |
Number of discarded outgoing messages. |
Elapsed time since last connection or counters clear |
Elapsed time since the MSDP peer information was last cleared. |
Mesh group peer joined |
Mesh group that the MSDP peer has joined. This field is not displayed if the MSDP peer does not join a mesh group. |
Last disconnect reason |
Reason why last MSDP peering connection was torn down. If the connection is not terminated, this field does not display a value. · Hold timer expired without message—Hold timer expires and the receiving cache has no messages. · Hold timer expired with truncated message—Hold timer expires and messages in the receiving buffer are not intact. ¡ bytes in buffer—Size of data in the receiving buffer when the connection was terminated. ¡ type—Type of packets in the receiving buffer when the connection was terminated. ¡ length—Length of packets in the receiving buffer when the connection was terminated. If the packet is too small in size, this field cannot be resolved and is not displayed. ¡ without packet time—Length of time since packets were last processed. · Remote peer has been closed—The MSDP peering connection has been torn down. · TCP ERROR/HUP event received—Error/hup event received by the TCP socket when the MSDP peer sent messages. · Illegal message received—The MSDP peer received illegal messages. · Notification received—The MSDP peer received notification messages. · Reset command executed—The user executed the reset msdp peer command. · Shutdown command executed—The user executed the shutdown command. · Interface downed—The MSDP peer received the interface down event when connecting to the remote MSDP peer. |
Information about (Source, Group)-based SA filtering policy |
SA message filtering list information: · Import policy—Filter list for receiving SA messages from the specified MSDP peer. · Export policy—Filter list for forwarding SA messages from the specified MSDP peer. |
Information about SA-Requests |
SA request information: · Policy to accept SA request messages—Filtering rule for receiving or forwarding SA request messages from the specified MSDP peer. If SA request messages are not filtered, this field displays None. · Sending SA requests status—Whether the MSDP peer is enabled to send an SA request message to the designated MSDP peer after receiving a new join message. |
Minimum TTL to forward SA with encapsulated data |
Lower TTL threshold for the multicast packets encapsulated in SA messages. |
SAs learned from this peer |
Number of cached (S, G) entries learned from the specified MSDP peer. |
SA-cache maximum for the peer |
Maximum number of (S, G) entries learned from the specified MSDP peer that the device can cache. |
Input queue size |
Data size cached in the input queue. |
Output queue size |
Data size cached in the output queue. |
Counters for MSDP message |
MSDP peer statistics: · RPF check failure—Number of SA messages discarded because of RPF check failure. · Incoming/outgoing SA—Number of received and sent SA messages. · Incoming/outgoing SA-Request—Number of received and sent SA requests. · Incoming/outgoing SA-Response—Number of received and sent SA responses. · Incoming/outgoing Keepalive—Number of received and sent keepalive messages. · Incoming/outgoing Notification—Number of received and sent notification messages. · Incoming/outgoing Traceroutes in progress—Number of received and sent traceroute-in-progress messages. · Incoming/outgoing Traceroute reply—Number of received and sent traceroute replies. · Incoming/outgoing Unknown—Number of received and sent unknown messages. · Incoming/outgoing data packet—Number of received and sent SA messages encapsulated with multicast data. |
Use display msdp sa-cache to display (S, G) entries in the SA cache.
display msdp [ vpn-instance vpn-instance-name ] sa-cache [ group-address | source-address | as-number ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays (S, G) entries in the SA cache on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays (S, G) entries in the SA cache for all multicast groups.
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays (S, G) entries in the SA cache for all sources.
as-number: Specifies an AS number in the range of 1 to 4294967295. If you do not specify an AS number, this command displays (S, G) entries in the SA cache for all ASs.
For this command to display output, you must first execute the cache-sa-enable command before you execute this command.
# Display (S, G) entries in the SA cache on the public network.
<Sysname> display msdp sa-cache
Total Source-Active Cache - 5 entries
Matched 5 entries
Source Group Origin RP Pro AS Uptime Expires
10.10.1.2 225.0.0.1 10.10.10.10 BGP 100 00:00:11 00:05:49
10.10.1.2 225.0.0.2 10.10.10.10 BGP 100 00:00:11 00:05:49
10.10.1.2 225.0.0.3 10.10.10.10 BGP 100 00:00:11 00:05:49
10.10.1.2 225.0.0.4 10.10.10.10 BGP 100 00:00:11 00:05:49
10.10.1.2 225.0.0.5 10.10.10.10 BGP 100 00:00:11 00:05:49
Total Source-Active Cache |
Total number of multicast sources in the SA cache. |
Matched |
Total number of (S, G) entries that match a multicast sources. |
Source |
Multicast source address. |
Group |
Multicast group address. |
Origin RP |
Address of the RP that generated the (S, G) entry. |
Pro |
Type of protocol from which the AS number of the origin RP originates. If the system could not obtain the AS number, this field displays a question mark (?). |
AS |
AS number of the origin RP. If the system could not obtain the AS number, this field displays a question mark (?). |
Uptime |
Length of time for which the cached (S, G) entry has existed. |
Expires |
Length of time in which the cached (S, G) entry will expire. |
cache-sa-enable
Use display msdp sa-count to display the number of (S, G) entries in the SA cache.
display msdp [ vpn-instance vpn-instance-name ] sa-count [ as-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays the number of (S, G) entries in the SA cache on the public network.
as-number: Specifies an AS number in the range of 1 to 4294967295. If you do not specify an AS number, this command displays the number of (S, G) entries in the SA cache for all ASs.
# Display the number of (S, G) entries in the SA cache on the public network.
<Sysname> display msdp sa-count
(S, G) entries statistics, counted by peer
Peer address SA count
10.10.10.10 5
(S, G) entries statistics, counted by AS
AS Source count Group count
? 3 3
5 (S, G) entries in total
Table 5 Command output
(S, G) entries statistics, counted by peer |
Number of (S, G) entries on an MSDP peer basis. |
Peer address |
Address of the MSDP peer that sent SA messages. |
SA count |
Number of (S, G) entries from the MSDP peer. |
(S, G) entries statistics, counted by AS |
Number of cached (S, G) entries on an AS basis. |
AS |
AS number. If the system could not obtain the AS number, this field displays a question mark (?). |
Source count |
Number of multicast sources in the AS. |
Group count |
Number of multicast groups in the AS. |
(S, G) entries in total |
Total number of (S, G) entries. |
cache-sa-enable
dscp
Use dscp to set the DSCP value for outgoing MSDP protocol packets.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value is 48 for outgoing MSDP protocol packets.
MSDP view
dscp-value: Specifies a DSCP value in the range of 0 to 63.
The DSCP value is carried in the ToS field of an IP packet to determine the transmission priority of the packet. A greater DSCP value represents a higher priority.
# Set the DSCP value to 63 for outgoing MSDP protocol packets.
[Sysname] msdp
[Sysname-msdp] dscp 63
encap-data-enable
Use encap-data-enable to enable multicast data encapsulation in SA messages.
Use undo encap-data-enable to restore the default.
encap-data-enable
An SA message contains only (S, G) entries. Multicast data is not encapsulated in an SA message.
MSDP view
# Enable multicast data encapsulation in SA messages on the public network.
[Sysname] msdp
[Sysname-msdp] encap-data-enable
import-source
Use import-source to configure an SA message creation policy.
Use undo import-source to restore the default.
import-source [ acl ipv4-acl-number ]
undo import-source
When an SA message is created, all the (S, G) entries within the domain are advertised in the SA message.
MSDP view
ipv4-acl-number: Specifies an IPv4 basic or advanced ACL number in the range of 2000 to 3999. If you specify an ACL, this command advertises only the (S, G) entries that the ACL permits. This command does not advertise (S, G) entries when one of the following conditions exists:
· You do not specify an ACL.
· The specified ACL does not exist.
· The specified ACL does not have valid rules.
This command controls the creation of SA messages. To control forwarding or acceptance of SA messages, use the peer sa-policy command.
When you configure a rule in the IPv4 ACL, follow these restrictions and guidelines:
· For the rule to take effect, do not specify the vpn-instance vpn-instance option.
· In a basic ACL, the source source-address source-wildcard option specifies a multicast group address.
· In an advanced ACL, the source source-address source-wildcard option specifies a multicast source address. The destination dest-address dest-wildcard option specifies a multicast group address.
· Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
If you configure this command multiple times, the most recent configuration takes effect.
# Configure an SA creation policy to advertise only (10.10.0.0/16, 225.1.0.0/16) entries in SA messages on the public network.
[Sysname] acl advanced 3101
[Sysname-acl-ipv4-adv-3101] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname-acl-ipv4-adv-3101] quit
[Sysname] msdp
[Sysname-msdp] import-source acl 3101
peer sa-policy
msdp
Use msdp to enable MSDP and enter MSDP view.
Use undo msdp to disable MSDP and delete the configurations in MSDP view.
undo msdp [ vpn-instance vpn-instance-name ]
MSDP is disabled.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command applies to the public network.
This command takes effect only when IP multicast routing is enabled on the public network or for the VPN instance to which the device belongs.
# Enable IP multicast routing on the public network. Then, enable MSDP on the public network and enter MSDP view.
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname] msdp
[Sysname-msdp]
multicast routing
Use msdp non-stop-routing to enable MSDP NSR.
Use undo msdp non-stop-routing to disable MSDP NSR.
This command enables MSDP to back up protocol state information and data, such as MSDP peer and remote multicast source information, from the active process to standby processes. A standby process seamlessly takes over when the active process fails. Use this feature to avoid forwarding interruption for MSDP when an active/standby switchover occurs.
# Enable MSDP NSR.
[Sysname] msdp non-stop-routing
originating-rp
Use originating-rp to configure the originating RP of SA messages.
Use undo originating-rp to restore the default.
originating-rp interface-type interface-number
undo originating-rp
SA messages are originated by real RPs.
MSDP view
# Configure VLAN-interface 100 as the originating RP of SA messages on the public network.
[Sysname] msdp
[Sysname-msdp] originating-rp vlan-interface 100
peer
Use peer to specify an MSDP peer.
Use undo peer to remove an MSDP peer.
peer peer-address connect-interface interface-type interface-number
undo peer peer-address
No MSDP peers exist.
MSDP view
peer-address: Specifies an MSDP peer by its IP address.
connect-interface interface-type interface-number: Specifies an interface by its type and number. The local device uses the primary IP address of the specified interface to establish a TCP connection with the remote MSDP peer.
You must execute this command before you use any other peer commands.
# Specify the router with IP address 125.10.7.6 as an MSDP peer and VLAN-interface 100 as the local connection port on the public network.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 connect-interface vlan-interface 100
peer description
Use peer description to configure a description for an MSDP peer.
Use undo peer description to delete the description for an MSDP peer.
peer peer-address description text
undo peer peer-address description
No description exists.
MSDP view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure the description CustomerA for the MSDP peer with IP address 125.10.7.6 on the public network.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 description CustomerA
peer mesh-group
Use peer mesh-group to assign an MSDP peer to a mesh group.
Use undo peer mesh-group to remove an MSDP peer from a mesh group.
peer peer-address mesh-group name
undo peer peer-address mesh-group
An MSDP peer does not belong to a mesh group.
MSDP view
name: Specifies a mesh group, a case-sensitive string of 1 to 32 characters. A mesh group name must not contain spaces.
# Assign the MSDP peer with IP address 125.10.7.6 to mesh group Group1 on the public network.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 mesh-group Group1
peer minimum-ttl
Use peer minimum-ttl to set the lower TTL threshold for multicast data packets to be encapsulated in SA messages.
Use undo peer minimum-ttl to restore the default.
peer peer-address minimum-ttl ttl-value
undo peer peer-address minimum-ttl
The lower TTL threshold is 0 for multicast data packets to be encapsulated in SA messages.
MSDP view
ttl-value: Specifies the lower TTL threshold in the range of 0 to 255.
# Set the lower TTL threshold to 10 for multicast data packets to be encapsulated in SA messages and forwarded to MSDP peer 110.10.10.1 on the public network.
[Sysname] msdp
[Sysname-msdp] peer 110.10.10.1 minimum-ttl 10
peer password
Use peer password to configure the device to perform MD5 authentication when establishing a TCP connection with an MSDP peer.
Use undo peer password to configure the device not to perform MD5 authentication when establishing a TCP connection with an MSDP peer.
peer peer-address password { cipher | simple } string
undo peer peer-address password
The device does not perform MD5 authentication when establishing a TCP connection with an MSDP peer.
MSDP view
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 33 to 137 characters. Its encrypted form is a case-sensitive string of 1 to 80 characters.
For the TCP connection to be successfully established, you must configure the same key for MD5 authentication on both MSDP peers.
# Configure the router to perform MD5 authentication when establishing a TCP connection with MSDP peer 10.1.100.1 and set the key to aabbcc in plaintext on the public network.
[Sysname] msdp
[Sysname-msdp] peer 10.1.100.1 password simple aabbcc
peer request-sa-enable
Use peer request-sa-enable to enable the device to send an SA request message to an MSDP peer after receiving a new join message.
Use undo peer request-sa-enable to disable the device from sending an SA request message to an MSDP peer.
peer peer-address request-sa-enable
undo peer peer-address request-sa-enable
After receiving a new join message, the device does not send an SA request message to MSDP peers. Instead, it waits for an SA message.
MSDP view
For the device to send out SA request messages, you must disable the SA message cache mechanism before you execute this command.
# Disable the SA message cache mechanism on the public network.
[Sysname] msdp
[Sysname-msdp] undo cache-sa-enable
# Enable the device to send an SA request message to MSDP peer 125.10.7.6 after it receives a new join message.
[Sysname-msdp] peer 125.10.7.6 request-sa-enable
cache-sa-enable
peer sa-cache-maximum
Use peer sa-cache-maximum to set the maximum number of (S, G) entries in the SA cache learned from an MSDP peer.
Use undo peer sa-cache-maximum to restore the default.
peer peer-address sa-cache-maximum sa-limit
undo peer peer-address sa-cache-maximum
The device can cache a maximum of 4294967295 (S, G) entries learned from an MSDP peer.
MSDP view
sa-limit: Specifies the maximum number of (S, G) entries in the SA cache, in the range of 1 to 4294967295.
# Set the maximum number to 100 for (S, G) entries in the SA cache learned from MSDP peer 125.10.7.6 on the public network.
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 sa-cache-maximum 100
display msdp brief
peer sa-policy
Use peer sa-policy to configure an SA incoming or outgoing policy for an MSDP peer.
Use undo peer sa-policy to delete the SA incoming or outgoing policy for an MSDP peer.
peer peer-address sa-policy { export | import } [ acl ipv4-acl-number ]
undo peer peer-address sa-policy { export | import }
No SA incoming or outgoing policy exists, and all SA messages from an MSDP peer are accepted or forwarded.
MSDP view
export: Specifies the outgoing direction.
import: Specifies the incoming direction.
ipv4-acl-number: Specifies an IPv4 advanced ACL number in the range of 3000 to 3999. If you specify an ACL, the device accepts and forwards only SA messages that the ACL permits. The device discards all SA messages when one of the following conditions exists:
This command filters SA messages from a specified MSDP peer to control the acceptance or forwarding of SA messages. To control the creation of SA messages, use the import-source command.
When you configure a rule in the IPv4 advanced ACL, follow these restrictions and guidelines:
· The source source-address source-wildcard option specifies a multicast source address.
· The destination dest-address dest-wildcard option specifies a multicast group address.
# Configure an SA outgoing policy to forward only SA messages that ACL 3100 permits to MSDP peer 125.10.7.6 on the public network.
[Sysname] acl advanced 3100
[Sysname-acl-ipv4-adv-3100] rule permit ip source 170.15.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname-acl-ipv4-adv-3100] quit
[Sysname] msdp
[Sysname-msdp] peer 125.10.7.6 sa-policy export acl 3100
import-source
peer sa-request-policy
Use peer sa-request-policy to configure an SA request policy for an MSDP peer.
Use undo peer sa-request-policy to delete the SA request policy for an MSDP peer.
peer peer-address sa-request-policy [ acl ipv4-acl-number ]
undo peer peer-address sa-request-policy
No SA request policy exists, and all SA request messages from an MSDP peer are accepted.
MSDP view
ipv4-acl-number: Specifies an IPv4 basic ACL number in the range of 2000 to 2999. If you specify an ACL, the device accepts only SA requests that the ACL permits. The device discards all SA requests when one of the following conditions exists:
When you configure a rule in the IPv4 basic ACL, follow these restrictions and guidelines:
· The source source-address source-wildcard option specifies a multicast group address.
# Configure an SA request policy on the public network. Then, the device accepts only SA requests that are from MSDP peer 175.58.6.5 and for multicast groups in the range 225.1.1.0/24.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 225.1.1.0 0.0.0.255
[Sysname] msdp
[Sysname-msdp] peer 175.58.6.5 sa-request-policy acl 2001
reset msdp peer
Use reset msdp peer to reset the TCP connection with an MSDP peer and clear statistics for the MSDP peer.
reset msdp [ vpn-instance vpn-instance-name ] peer [ peer-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command resets the TCP connection with the specified MSDP peer and clears statistics for the MSDP peer on the public network.
peer-address: Specifies an MSDP peer by its IP address. If you do not specify an MSDP peer, this command resets the TCP connections with all MSDP peers and clears statistics for all MSDP peers.
# Reset the TCP connection with MSDP peer 125.10.7.6 and clear all statistics for the MSDP peer on the public network.
<Sysname> reset msdp peer 125.10.7.6
reset msdp sa-cache
Use reset msdp sa-cache to clear (S, G) entries in the SA cache.
reset msdp [ vpn-instance vpn-instance-name ] sa-cache [ group-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears (S, G) entries in the SA cache on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command clears (S, G) entries for all multicast groups in the SA cache.
# Clear (S, G) entries for multicast group 225.5.4.3 in the SA cache on the public network.
<Sysname> reset msdp sa-cache 225.5.4.3
cache-sa-enable
reset msdp statistics
Use reset msdp statistics to clear statistics for an MSDP peer without resetting the TCP connection with the MSDP peer.
reset msdp [ vpn-instance vpn-instance-name ] statistics [ peer-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears statistics for the specified MSDP peer without resetting the TCP connection with the MSDP peer on the public network.
peer-address: Specifies an MSDP peer by its IP address. If you do not specify an MSDP peer, this command clears statistics for all MSDP peers without resetting the TCP connection with all MSDP peers.
# Clear statistics for MSDP peer 125.10.7.6 without resetting the TCP connection with the peer on the public network.
<Sysname> reset msdp statistics 125.10.7.6
shutdown (MSDP view)
Use shutdown to tear down the connection with an MSDP peer.
Use undo shutdown to re-establish the connection with an MSDP peer.
shutdown peer-address
undo shutdown peer-address
The connection with an MSDP peer is active.
MSDP view
# Tear down the connection with the MSDP peer 125.10.7.6 on the public network.
[Sysname] msdp
[Sysname-msdp] shutdown 125.10.7.6
display msdp brief
static-rpf-peer
Use static-rpf-peer to configure a static RPF peer.
Use undo static-rpf-peer to remove a static RPF peer.
static-rpf-peer peer-address [ rp-policy ip-prefix-name ]
undo static-rpf-peer peer-address
No static RPF peers exist.
MSDP view
rp-policy ip-prefix-name: Specifies a filtering policy based on RP addresses in SA messages by its name, a case-sensitive string of 1 to 63 characters. If you specify a filtering policy, the device does not perform RPF checks on SA messages permitted by the policy. If you do not specify a filtering policy, the device performs RPF checks on all SA messages.
This feature exempts SA messages forwarded by the static RPF peer from RPF checks.
# Specify 130.10.7.6 as the static RPF peer to exempt SA messages originated by RPs on subnet 130.10.0.0/16 from RPF checks on the public network.
[Sysname] ip prefix-list list1 permit 130.10.0.0 16 greater-equal 16 less-equal 32
[Sysname] msdp
[Sysname-msdp] peer 130.10.7.6 connect-interface vlan-interface 100
[Sysname-msdp] static-rpf-peer 130.10.7.6 rp-policy list1
ip prefix-list
timer keepalive
Use timer keepalive to set the keepalive timer and the peer hold timer for MSDP sessions.
Use undo timer keepalive to restore the default.
timer keepalive keepalive holdtime
The keepalive timer is 60 seconds, and the peer hold timer is 75 seconds.
MSDP view
keepalive: Specifies a keepalive timer in the range of 1 to 21845 seconds.
holdtime: Specifies a peer hold timer in the range of 1 to 65535 seconds.
MSDP peers periodically send keepalive messages to each other to keep a session alive. When a session is established, an MSDP peer sends a keepalive message to its peer and starts a keepalive timer and a peer hold timer. When the keepalive timer expires, the MSDP peer sends a new keepalive message. If the MSDP peer receives an MSDP message from its peer before the peer hold timer expires, it resets the peer hold timer. If the MSDP peer does not receive an MSDP message when the hold timer expires, the MSDP peer closes the session.
When you configure this command, follow these guidelines:
No mechanism is available for MSDP peers to negotiate the two values. You must set the same keepalive timer and the peer hold timer for the MSDP peers of a session.
The keepalive timer must be less than the peer hold timer.
This command takes effect on the established MSDP session.
# Set the keepalive timer to 60 seconds and the peer hold timer to 180 seconds for MSDP sessions on the public network.
[Sysname] msdp
[Sysname-msdp] timer keepalive 60 180
timer retry
Use timer retry to set the MSDP connection retry interval.
Use undo timer retry to restore the default.
timer retry interval
undo timer retry
The MSDP connection retry interval is 30 seconds.
MSDP view
interval: Specifies an MSDP connection retry interval in the range of 1 to 60 seconds.
# Set the MSDP connection retry interval to 60 seconds on the public network.
[Sysname] msdp
[Sysname-msdp] timer retry 60
