- 07-IP Multicast Configuration Guide
- 01-Multicast Overview
- 02-IGMP snooping configuration
- 03-PIM snooping configuration
- 04-Multicast VLAN configuration
- 05-Multicast routing and forwarding configuration
- 06-IGMP configuration
- 07-PIM configuration
- 08-MSDP configuration
- 09-Multicast VPN configuration
- 10-MLD snooping configuration
- 11-IPv6 PIM snooping configuration
- 12-IPv6 multicast VLAN configuration
- 13-IPv6 multicast routing and forwarding configuration
- 14-MLD configuration
- 15-IPv6 PIM configuration
10-MLD snooping configuration | 385.33 KB |
MLD snooping configuration task list
MLD snooping configuration task list for VLANs
MLD snooping configuration task list for VSIs
Enabling the MLD snooping feature
Configuring basic MLD snooping features
Specifying an MLD snooping version
Setting the maximum number of MLD snooping forwarding entries
Configuring static IPv6 multicast MAC address entries
Setting the MLD last listener query interval
Configuring MLD snooping port features
Setting aging timers for dynamic ports
Configuring a port as a simulated member host
Enabling fast-leave processing
Disabling a port from becoming a dynamic router port
Configuring the MLD snooping querier
Enabling the MLD snooping querier
Enabling MLD snooping querier election
Configuring parameters for MLD general queries and responses
Enabling the device to send MLD general queries upon a path change
Enabling MLD snooping proxying
Configuring parameters for MLD messages
Configuring source IPv6 addresses for MLD messages
Setting the 802.1p priority for MLD messages
Configuring MLD snooping policies
Configuring an IPv6 multicast group policy
Enabling IPv6 multicast source port filtering
Enabling dropping unknown IPv6 multicast data
Enabling MLD report suppression
Setting the maximum number of IPv6 multicast groups on a port
Enabling IPv6 multicast group replacement
Setting the DSCP value for outgoing MLD protocol packets
Displaying and maintaining MLD snooping
MLD snooping configuration examples
IPv6 group policy and simulated joining configuration example (for VLANs)
Static port configuration example (for VLANs)
MLD snooping querier configuration example (for VLANs)
MLD snooping proxying configuration example (for VLANs)
MLD snooping configuration example (for VXLANs)
Overview
As shown in Figure 1, when MLD snooping is not enabled, the Layer 2 switch floods IPv6 multicast packets to all hosts in a VLAN or VSI. When MLD snooping is enabled, the Layer 2 switch forwards multicast packets of known IPv6 multicast groups to only the receivers.
Figure 1 Multicast packet transmission processes without and with MLD snooping
MLD snooping ports
As shown in Figure 2, MLD snooping runs on Switch A and Switch B, and Host A and Host C are receiver hosts in an IPv6 multicast group. MLD snooping ports are divided into member ports and router ports.
Router ports
On an MLD snooping Layer 2 device, the ports toward Layer 3 multicast devices are called router ports. In Figure 2, GigabitEthernet 1/0/1 of Switch A and GigabitEthernet 1/0/1 of Switch B are router ports.
Router ports contain the following types:
· Dynamic router port—When a port receives an MLD general query whose source address is not 0::0 or receives an IPv6 PIM hello message, the port is added into the dynamic router port list. At the same time, an aging timer is started for the port. If the port receives either of the messages before the timer expires, the timer is reset. If the port does not receive either of the messages when the timer expires, the port is removed from the dynamic router port list.
· Static router port—When a port is statically configured as a router port, it is added into the static router port list. The static router port does not age out, and it can be deleted only manually.
Do not confuse the "router port" in MLD snooping with the "routed interface" commonly known as the "Layer 3 interface." The router port in MLD snooping is a Layer 2 interface.
Member ports
On an MLD snooping Layer 2 device, the ports toward receiver hosts are called member ports. In Figure 2, GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3 of Switch A and GigabitEthernet 1/0/2 of Switch B are member ports.
Member ports contain the following types:
· Dynamic member port—When a port receives an MLD report, it is added to the associated dynamic MLD snooping forwarding entry as an outgoing interface. At the same time, an aging timer is started for the port. If the port receives an MLD report before the timer expires, the timer is reset. If the port does not receive an MLD report when the timer expires, the port is removed from the associated dynamic forwarding entry.
· Static member port—When a port is statically configured as a member port, it is added to the associated static MLD snooping forwarding entry as an outgoing interface. The static member port does not age out, and it can be deleted only manually.
Unless otherwise specified, router ports and member ports in this document include both static and dynamic router ports and member ports.
How MLD snooping works
The ports in this section are dynamic ports. For information about how to configure and remove static ports, see "Configuring static ports."
General query
The MLD querier periodically sends MLD general queries to all hosts and routers on the local subnet to check for the existence of IPv6 multicast group members.
After receiving an MLD general query, the Layer 2 device forwards the query to all ports in the VLAN or VSI except the receiving port. The Layer 2 device also performs one of the following actions:
· If the receiving port is a dynamic router port in the dynamic router port list, the Layer 2 device restarts the aging timer for the router port.
· If the receiving port does not exist in the dynamic router port list, the Layer 2 device adds the port to the dynamic router port list. It also starts an aging timer for the port.
MLD report
A host sends an MLD report to the MLD querier for the following purposes:
· Responds to queries if the host is an IPv6 multicast group member.
· Applies for an IPv6 multicast group membership.
After receiving an MLD report from a host, the Layer 2 device forwards the report through all the router ports in the VLAN or VSI. It also resolves the IPv6 address of the reported IPv6 multicast group, and looks up the forwarding table for a matching entry as follows:
· If no match is found, the Layer 2 device creates a forwarding entry for the group with the receiving port an outgoing interface. It also marks the receiving port as a dynamic member port and starts an aging timer for the port.
· If a match is found but the matching forwarding entry does not contain the receiving port, the Layer 2 device adds the receiving port to the outgoing interface list. It also marks the port as a dynamic member port to the forwarding entry and starts an aging timer for the port.
· If a match is found and the matching forwarding entry contains the receiving port, the Layer 2 device restarts the aging timer for the port.
In an application with an IPv6 multicast group policy configured on an MLD snooping-enabled Layer 2 device, when a user requests a multicast program, the user's host initiates an MLD report. After receiving this report message, the Layer 2 device resolves the IPv6 multicast group address in the report and performs ACL filtering on the report. If the report passes ACL filtering, the Layer 2 device creates an MLD snooping forwarding entry for the group with the receiving port as an outgoing interface. If the report does not pass ACL filtering, the Layer 2 device drops this report message, in which case, the IPv6 multicast data for the IPv6 multicast group is not sent to this port, and the user cannot retrieve the program.
A Layer 2 device does not forward an MLD report through a non-router port because of the host MLD report suppression mechanism. For more information about the MLD report suppression mechanism, see "Configuring MLD."
Done message
When a host leaves an IPv6 multicast group, the host sends an MLD done message to the Layer 3 devices. When the Layer 2 device receives the MLD done message on a dynamic member port, the Layer 2 device first examines whether a forwarding entry matches the IPv6 multicast group address in the message.
· If no match is found, the Layer 2 device discards the MLD done message.
· If a match is found but the receiving port is not an outgoing interface in the forwarding entry, the Layer 2 device discards the MLD done message.
· If a match is found and the receiving port is not the only outgoing interface in the forwarding entry, the Layer 2 device performs the following actions:
¡ Discards the MLD done message.
¡ Sends an MLD multicast-address-specific query to identify whether the group has active listeners attached to the receiving port.
¡ Sets the aging timer for the receiving port to twice the MLD last listener query interval.
· If a match is found and the receiving port is the only outgoing interface in the forwarding entry, the Layer 2 device performs the following actions:
¡ Forwards the MLD done message to all router ports in the VLAN or VSI.
After receiving the MLD done message on a port, the MLD querier resolves the IPv6 multicast group address in the message. Then, it sends an MLD multicast-address-specific query to the IPv6 multicast group through the receiving port.
After receiving the MLD multicast-address-specific query, the Layer 2 device forwards the query through all router ports and member ports of the group in the VLAN or VSI. Then, it waits for the responding MLD report from the directly connected hosts. For the dynamic member port that received the done message, the Layer 2 device also performs one of the following actions:
· If the port receives an MLD report before the aging timer expires, the Layer 2 device resets the aging timer for the port.
· If the port does not receive any MLD report messages when the aging timer expires, the Layer 2 device removes the port from the forwarding entry for the IPv6 multicast group.
As shown in Figure 3, to reduce the number of MLD reports and done messages received by the upstream device, you can enable MLD snooping proxying on the edge device. The edge device then acts as a host to send MLD reports and done messages to Router A.
An edge device enabled with MLD snooping proxying does not support the host MLD report suppression mechanism. For more information about the MLD report suppression mechanism, see "Configuring MLD."
Figure 3 MLD snooping proxying
The MLD snooping proxy device processes different MLD messages as follows:
· General query.
After receiving an MLD general query, the device forwards the query to all ports in the VLAN or VSI except the receiving port. The device also generates an MLD report based on the local membership information and sends the report to all router ports.
· Multicast-address-specific query or multicast-address-and-source-specific query.
After receiving an MLD multicast-address-specific query or multicast-address-and-source-specific query, the device forwards the query to all router ports in the VLAN or VSI except the receiving port. If the forwarding entry has a member port, the device sends a response to all router ports in the VLAN or VSI.
· Report.
After receiving an MLD report from a host, the device looks up the forwarding table for a matching entry as follows:
¡ If a match is found and the matching forwarding entry contains the receiving port, the device resets the aging timer for the port.
¡ If a match is found but the matching forwarding entry does not contain the receiving port, the device adds the receiving port to the outgoing interface list. It also marks the receiving port as a dynamic member port and starts an aging timer for the port.
¡ If no match is found, the device creates a forwarding entry with the receiving port as an outgoing interface. It also marks the receiving port as a dynamic member port and starts an aging timer for the port. Then it sends the report to all router ports.
· Done message.
After receiving an MLD done message on a port, the device sends an MLD multicast-address-specific query through the receiving port. The device sends the MLD done message to all router ports only when the last member port is removed from the forwarding entry.
Protocols and standards
RFC 4541, Considerations for Internet Group Management Protocol (IGMP) and Multicast Listener Discovery (MLD) Snooping Switches
When you configure MLD snooping, follow these restrictions and guidelines:
· If you change the VPN instance bound to the VLAN interface of a VLAN, Layer 2 IPv6 multicast traffic in the VLAN is interrupted. To allow new MLD snooping forwarding entries to be created, execute the reset mld-snooping group command.
· For MLD reports received from secondary VLANs, the relevant MLD snooping forwarding entries are maintained by the primary VLAN. Therefore, you need to enable MLD snooping only for the primary VLAN. The configuration made in secondary VLANs will not take effect. For more information about primary VLANs and secondary VLANs, see Layer 2—LAN Switching Configuration Guide.
· The MLD snooping configurations made on Layer 2 aggregate interfaces do not interfere with the configurations made on member ports. In addition, the configurations made on Layer 2 aggregate interfaces do not take part in aggregation calculations. The configuration made on a member port of the aggregate group takes effect after the port leaves the aggregate group.
You can configure MLD snooping for VLANs or VSIs.
Tasks at a glance |
(Required.) Enabling the MLD snooping feature |
(Required.) Enabling MLD snooping |
(Optional.) Configuring basic MLD snooping features: · Specifying an MLD snooping version · Setting the maximum number of MLD snooping forwarding entries |
(Optional.) Setting aging timers for dynamic ports |
(Optional.) Configuring the MLD snooping querier: · Enabling the MLD snooping querier · Enabling MLD snooping querier election · Configuring parameters for MLD general queries and responses · Enabling the device to send MLD general queries upon a path change |
(Optional.) Enabling MLD snooping proxying |
(Optional.) Configuring parameters for MLD messages: |
(Optional.) Configuring MLD snooping policies: |
(Optional.) Setting the DSCP value for outgoing MLD protocol packets |
You must enable the MLD snooping feature before you configure other MLD snooping features.
To enable the MLD snooping feature:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable the MLD snooping feature and enter MLD-snooping view. |
mld-snooping |
By default, the MLD snooping feature is disabled. |
When you enable MLD snooping, follow these restrictions and guidelines:
· You must enable the MLD snooping feature by using the mld-snooping command before you enable MLD snooping globally or for a VLAN or VSI.
· MLD snooping configuration made in VLAN or VSI view takes effect only on the member ports in that VLAN or VSI.
· You can enable MLD snooping for multiple VLANs by using the enable vlan command in MLD-snooping view or for a VLAN by using the mld-snooping enable command in VLAN view. The configuration in MLD-snooping view has the same priority as the configuration in VLAN view, and the most recent configuration takes effect.
· To configure other MLD snooping features for VLANs or VSIs, you must enable MLD snooping for the VLANs or VSIs even though MLD snooping is globally enabled. The MLD snooping configuration for specific VLANs or VSIs takes priority over the global MLD snooping configuration.
Enabling MLD snooping globally
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the MLD snooping feature globally and enter MLD-snooping view. |
mld-snooping |
3. Enable MLD snooping globally. |
global-enable |
By default, MLD snooping is disabled globally. |
Enabling MLD snooping for multiple VLANs
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
3. Enable MLD snooping for multiple VLANs. |
enable vlan vlan-list |
By default, the status of MLD snooping for a VLAN is consistent with the global MLD snooping status. |
Enabling MLD snooping for a VLAN or VSI
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
3. Return to system view. |
quit |
N/A |
4. Enter VLAN view or VSI view. |
· Enter VLAN view: · Enter VSI view: |
N/A |
5. Enable MLD snooping for the VLAN or VSI. |
mld-snooping enable |
By default, the status of MLD snooping for a VLAN or VSI is consistent with the global MLD snooping status. |
6. (Optional.) Disable MLD snooping for the VLAN or VSI. |
mld-snooping disable |
Before you configure basic MLD snooping features, complete the following tasks:
· Configure VLANs or VSIs.
· Determine the MLD snooping version.
· Determine the maximum number of MLD snooping forwarding entries.
· Determine the MLD last listener query interval.
Different MLD snooping versions can process different versions of MLD messages:
· MLDv1 snooping can process MLDv1 messages and MLDv2 queries, but it floods MLDv2 reports in the VLAN instead of processing them.
· MLDv2 snooping can process MLDv1 and MLDv2 messages.
If you change MLDv2 snooping to MLDv1 snooping, the system performs the following actions:
· Clears all MLD snooping forwarding entries that are dynamically created.
· Keeps static MLDv2 snooping forwarding entries (*, G).
· Clears static MLDv2 snooping forwarding entries (S, G), which will be restored when MLD snooping is switched back to MLDv2 snooping.
For more information about static MLD snooping forwarding entries, see "Configuring static ports."
You can specify the version for the specified VLANs in MLD-snooping view, for a VSI in VSI view, or for a VLAN in VLAN view. For a VLAN, the configuration in VLAN view has the same priority as the configuration in MLD-snooping view, and the most recent configuration takes effect.
Specifying an MLD snooping version in MLD-snooping view
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter MLD-snooping view. |
mld-snooping |
N/A |
3. Specify an MLD snooping version for the specified VLANs. |
version version-number vlan vlan-list |
The default setting is 1. |
Specifying an MLD snooping version in VLAN view
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter VLAN view or VSI view. |
N/A |
3. Specify an MLD snooping version for the VLAN or VSI. |
mld-snooping version version-number |
You can modify the maximum number of MLD snooping forwarding entries, including dynamic entries and static entries. When the number of forwarding entries on the device reaches the upper limit, the device does not automatically remove any existing entries. To allow new entries to be created, remove some entries manually.
To set the maximum number of MLD snooping forwarding entries:
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
N/A |
3. Set the maximum number of MLD snooping forwarding entries. |
entry-limit limit |
The default setting is 4294967295. |
In Layer 2 IPv6 multicast, IPv6 multicast MAC address entries can be dynamically created through Layer 2 multicast protocols (such as MLD snooping). You can also manually configure static IPv6 multicast MAC address entries by binding IPv6 multicast MAC addresses and ports to control the destination ports of the IPv6 multicast data.
When you configure a static IPv6 multicast MAC address entry, follow these restrictions and guidelines:
· You do not need to enable IPv6 multicast routing before this configuration.
· You must specify an unused multicast MAC address for a static IPv6 multicast MAC address entry. A multicast MAC address is a MAC address in which the least significant bit of the most significant octet is 1.
· You can configure an IPv6 static multicast MAC address entry for multiple interfaces in system view, or for the current interface in interface view.
Configuring a static IPv6 multicast MAC address entry in system view
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure a static IPv6 multicast MAC address entry. |
mac-address multicast mac-address interface interface-list vlan vlan-id |
By default, no static IPv6 multicast MAC address entries exist. |
Configuring a static IPv6 multicast MAC address entry in interface view
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter Layer 2 Ethernet interface or Layer 2 aggregate interface view. |
N/A |
3. Configure a static IPv6 multicast MAC address entry. |
mac-address multicast mac-address vlan vlan-id |
By default, no static multicast MAC address entries exist. |
A receiver host starts a report delay timer for an IPv6 multicast group when it receives an MLD multicast-address-specific query for the group. This timer is set to a random value in the range of 0 to the maximum response time advertised in the query. When the timer value decreases to 0, the host sends an MLD report to the group.
The MLD last listener query interval defines the maximum response time advertised in MLD multicast-address-specific queries. Set an appropriate value for the MLD last listener query interval to speed up hosts' responses to MLD multicast-address-specific queries and avoid MLD report traffic bursts.
When you set the MLD last listener query interval, follow these restrictions and guidelines:
· The Layer 2 device does not send an MLD multicast-address-specific query if it receives an MLD done message from a port enabled with fast-leave processing.
· You can set the MLD last listener query interval globally for all VLANs and VSIs in MLD-snooping view, for a VSI in VSI view, or for a VLAN in VLAN view. For a VSI, the VSI-specific configuration takes priority over the global configuration. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
Setting the MLD last listener query interval globally
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
N/A |
3. Set the MLD last listener query interval globally. |
last-listener-query-interval interval |
The default setting is 1 second. |
Setting the MLD last listener query interval in a VLAN or VSI
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the MLD last listener query interval in the VLAN or VSI. |
mld-snooping last-listener-query-interval interval |
Before you configure MLD snooping port features, complete the following tasks:
· Enable MLD snooping for the VLAN or VSI.
· Determine the aging timer for dynamic router ports.
· Determine the aging timer for dynamic member ports.
· Determine the addresses of the IPv6 multicast group and IPv6 multicast source.
When you set aging timers for dynamic ports, follow these restrictions and guidelines:
· If the memberships of IPv6 multicast groups frequently change, set a relatively small value for the aging timer of the dynamic member ports. If the memberships of IPv6 multicast groups rarely change, you can set a relatively large value.
· If a dynamic router port receives an IPv6 PIMv2 hello message, the aging timer for the port is specified by the hello message. In this case, the mld-snooping router-aging-time command does not take effect on the port.
· MLD multicast-address-specific queries originated by the Layer 2 device trigger the adjustment of aging timers of dynamic member ports. If a dynamic member port receives such a query, its aging timer is set to twice the MLD last listener query interval. For more information about setting the MLD last listener query interval on the Layer 2 device, see "Setting the MLD last listener query interval."
· You can set the timers globally for all VLANs and VSIs in MLD-snooping view, for a VSI in VSI view, or for a VLAN in VLAN view. For a VSI, the VSI-specific configuration takes priority over the global configuration. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
Setting the aging timers for dynamic ports globally
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
N/A |
3. Set the aging timer for dynamic router ports globally. |
router-aging-time seconds |
The default setting is 260 seconds. |
4. Set the aging timer for dynamic member ports globally. |
host-aging-time seconds |
Setting the aging timers for dynamic ports in a VLAN or VSI
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the aging timer for dynamic router ports in the VLAN or VSI. |
mld-snooping router-aging-time seconds |
4. Set the aging timer for dynamic member ports in the VLAN or VSI. |
mld-snooping host-aging-time seconds |
You can configure the following types of static ports:
· Static member port—When you configure a port as a static member port for an IPv6 multicast group, all hosts attached to the port will receive IPv6 multicast data for the group.
The static member port does not respond to MLD queries. When you complete or cancel this configuration, the port does not send an unsolicited report or done message.
· Static router port—When you configure a port as a static router port for an IPv6 multicast group, all IPv6 multicast data for the group received on the port will be forwarded.
To configure a port as a static port:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view. |
N/A |
3. Configure the port as a static port. |
· Configure the port as a static member port: · Configure the port as a static router port: |
By default, a port is not a static member port or a static router port. |
When a port is configured as a simulated member host, it is equivalent to an independent host in the following ways:
· It sends an unsolicited MLD report when you complete the configuration.
· It responds to MLD general queries with MLD reports.
· It sends an MLD done message when you remove the configuration.
The version of MLD running on the simulated member host is the same as the version of MLD snooping running on the port. The port ages out in the same ways as a dynamic member port.
To configure a port as a simulated member host:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the port as a simulated member host. |
mld-snooping host-join ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id |
By default, the port is not a simulated member host. |
This feature enables the device to immediately remove a port from the forwarding entry for an IPv6 multicast group when the port receives a done message.
When you enable fast-leave processing, follow these restrictions and guidelines:
· Do not enable fast-leave processing on a port that has multiple receiver hosts attached in a VLAN. If you do so, the remaining receivers cannot receive IPv6 multicast data for a group after a receiver leaves that group.
· You can enable fast-leave processing globally for all ports in MLD-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
Enabling fast-leave processing globally
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
N/A |
3. Enable fast-leave processing globally. |
fast-leave [ vlan vlan-list ] |
By default, fast-leave processing is disabled globally. |
Enabling fast-leave processing on a port
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable fast-leave processing on the port. |
mld-snooping fast-leave [ vlan vlan-list ] |
By default, fast-leave processing is disabled on a port. |
A receiver host might send MLD general queries or IPv6 PIM hello messages for testing purposes. On the Layer 2 device, the port that receives either of the messages becomes a dynamic router port. Before the aging timer for the port expires, the following problems might occur:
· All IPv6 multicast data for the VLAN to which the port belongs flows to the port. Then, the port forwards the data to attached receiver hosts. The receiver hosts will receive IPv6 multicast data that it does not expect.
· The port forwards the MLD general queries or IPv6 PIM hello messages to its upstream multicast routers. These messages might affect the multicast routing protocol state (such as the MLD querier or DR election) on the multicast routers. This might further cause network interruption.
To solve these problems, you can disable the router port from becoming a dynamic router port when receiving either of the messages. This also improves network security and the control over receiver hosts.
To disable a port from becoming a dynamic router port:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Disable the port from becoming a dynamic router port. |
mld-snooping router-port-deny [ vlan vlan-list ] |
By default, a port is allowed to become a dynamic router port. This configuration does not affect the static router port configuration. |
This section describes how to configure the MLD snooping querier.
Configuration prerequisites
Before you configure the MLD snooping querier, complete the following tasks:
· Determine the MLD general query interval.
· Determine the maximum response time for MLD general queries.
This feature enables the device to periodically send MLD general queries to establish and maintain multicast forwarding entries at the data link Layer. You can configure an MLD snooping querier on a network without Layer 3 multicast devices.
When you enable the MLD snooping querier, follow these restrictions and guidelines:
· Do not enable the MLD snooping querier on an IPv6 multicast network that runs MLD. An MLD snooping querier does not participate in MLD querier elections. However, it might affect MLD querier elections if it sends MLD general queries with a low source IPv6 address.
· On a VXLAN network, the MLD snooping querier in a VSI does not include VLAN tags in MLD general queries. As a best practice, do not enable the MLD snooping querier in a VSI if the VSI uses the Ethernet access mode. For more information about the Ethernet access mode, see VXLAN Configuration Guide.
Configuration procedure
To enable the MLD snooping querier for a VLAN or VSI:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable the MLD snooping querier for the VLAN or VSI. |
mld-snooping querier |
By default, the MLD snooping querier is disabled for a VLAN or VSI. |
To avoid traffic interruption caused by the failure of a single querier in a VLAN or VSI, configure multiple queriers in the VLAN or VSI and enable querier election. When the elected querier fails, the device starts a new querier election to ensure multicast forwarding. The mechanism for MLD snooping querier election is the same as that for MLD querier election. For more information about MLD querier election, see "Configuring MLD."
Before you enable MLD snooping querier election, you must complete the following tasks:
· Enable the MLD snooping querier for a VLAN or VSI. For more information about enabling the MLD snooping querier, see "Enabling the MLD snooping querier."
· Configure the source IPv6 address for MLD general queries as an IPv6 address different from :: and the local querier IPv6 address. An MLD snooping querier performs querier election only if the source IPv6 address of a received MLD general query is not :: or its own IPv6 address.
· Make sure the candidate MLD snooping queriers run the same MLD snooping version. To specify the MLD snooping version, use the mld-snooping version command.
To enable MLD snooping querier election for a VLAN or VSI:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable MLD snooping querier election. |
mld-snooping querier-election |
By default, MLD snooping querier election is disabled. |
CAUTION: To avoid mistakenly deleting IPv6 multicast group members, make sure the MLD general query interval is greater than the maximum response time for MLD general queries. |
You can modify the MLD general query interval for a VLAN based on the actual network conditions.
A receiver host starts a report delay timer for each IPv6 multicast group that it has joined when it receives an MLD general query. This timer is set to a random value in the range of 0 to the maximum response time advertised in the query. When the timer value decreases to 0, the host sends an MLD report to the corresponding IPv6 multicast group.
Set an appropriate value for the maximum response time for MLD general queries to speed up hosts' responses to MLD general queries and avoid MLD report traffic bursts.
You can set the maximum response time for MLD general queries globally for all VLANs and VSIs in MLD-snooping view, for a VSI in VSI view, or for a VLAN in VLAN view. For a VSI, the VSI-specific configuration takes priority over the global configuration. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
Configuring parameters for MLD general queries and responses globally
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
N/A |
3. Set the maximum response time for MLD general queries. |
max-response-time seconds |
The default setting is 10 seconds. |
Configuring parameters for MLD general queries and responses in a VLAN or VSI
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the MLD general query interval in the VLAN or VSI. |
mld-snooping query-interval interval |
The default setting is 125 seconds. |
4. Set the maximum response time for MLD general queries in the VLAN or VSI. |
mld-snooping max-response-time seconds |
Perform this task to enable the device to immediately send an MLD general query to all ports in the affected VLAN or VSI when a path changes. This feature ensures that the device can update the member port information in IPv6 multicast forwarding entries and switch IPv6 multicast traffic to the new path promptly.
Perform this task on the MLD snooping querier in a network of which the topology frequently changes.
To enable the device to send MLD general queries upon a path change:
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
N/A |
3. Enable the device to send MLD general queries upon a path change. |
send-query enable |
By default, the device does not send MLD general queries upon a path change. |
Before you enable MLD snooping proxying for a VLAN or VSI, enable MLD snooping for the VLAN or VSI.
To enable MLD snooping proxying:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable MLD snooping proxying for the VLAN or VSI. |
mld-snooping proxy enable |
By default, MLD snooping proxying is disabled for a VLAN or VSI. |
This section describes how to configure parameters for MLD messages.
Before you configure parameters for MLD messages, complete the following tasks:
· Determine the source IPv6 address of MLD general queries.
· Determine the source IPv6 address of MLD multicast-address-specific queries.
· Determine the source IPv6 address of MLD reports.
· Determine the source IPv6 address of MLD done messages.
· Determine the 802.1p priority of MLD messages.
You can change the source IPv6 address of the MLD queries sent by an MLD snooping querier. This configuration might affect MLD querier election within the subnet.
You can also change the source IPv6 address of MLD reports or done messages sent by a simulated member host or an MLD snooping proxy.
Configuring the source IPv6 address for MLD messages in a VLAN
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter VLAN view. |
vlan vlan-id |
N/A |
3. Configure the source IPv6 address for MLD general queries. |
mld-snooping general-query source-ip ipv6-address |
By default, the source IPv6 address of MLD general queries is the IPv6 link-local address of the current VLAN interface. If the current VLAN interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001. |
4. Configure the source IPv6 address for MLD multicast-address-specific queries. |
mld-snooping special-query source-ip ipv6-address |
By default, the source IPv6 address of MLD multicast-address-specific queries is one of the following: · The source address of MLD general queries if the MLD snooping querier of the VLAN has received MLD general queries. · The IPv6 link-local address of the current VLAN interface if the MLD snooping querier does not receive an MLD general query. · FE80::02FF:FFFF:FE00:0001 if the MLD snooping querier does not receive an MLD general query and the current VLAN interface does not have an IPv6 link-local address. |
5. Configure the source IPv6 address for MLD reports. |
mld-snooping report source-ip ipv6-address |
By default, the source IPv6 address of MLD reports is the IPv6 link-local address of the current VLAN interface. If the current VLAN interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001. |
6. Configure the source IPv6 address for MLD done messages. |
mld-snooping done source-ip ipv6-address |
By default, the source IPv6 address of MLD done messages is the IPv6 link-local address of the current VLAN interface. If the current VLAN interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001. |
Configuring the source IPv6 address for MLD messages in a VSI
Step |
Command |
Remarks |
system-view |
N/A |
vsi vsi-name |
N/A |
By default, the source IPv6 address of MLD general queries is the IPv6 link-local address of the gateway interface for a VSI. If the gateway interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001. |
By default, the source IPv6 address of MLD multicast-address-specific queries is one of the following: · The source address of MLD general queries if the MLD snooping querier of the VSI has received MLD general queries. · IPv6 link-local address of the gateway interface for the VSI if the MLD snooping querier does not receive an MLD general query. · FE80::02FF:FFFF:FE00:0001 if the gateway interface does not have an IPv6 link-local address. |
By default, the source IPv6 address of MLD reports is the IPv6 link-local address of the gateway interface for a VSI. If the gateway interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001. |
6. Configure the source IPv6 address for MLD dones. |
By default, the source IPv6 address of MLD dones is the IPv6 link-local address of the gateway interface for a VSI. If the gateway interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001. |
When congestion occurs on outgoing ports of the Layer 2 device, it forwards MLD messages in their 802.1p priority order, from highest to lowest. You can assign a higher 802.1p priority to MLD messages that are created or forwarded by the device.
You can configure the 802.1p priority of MLD messages for all VLANs in MLD-snooping view or for a VLAN in VLAN view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
Setting the 802.1p priority for MLD messages globally
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
N/A |
3. Set the 802.1p priority for MLD messages globally. |
dot1p-priority priority |
By default, the global 802.1p priority is 6 for MLD messages. |
Setting the 802.1p priority for MLD messages in a VLAN
Step |
Command |
Remarks |
system-view |
N/A |
vlan vlan-id |
N/A |
3. Set the 802.1p priority for MLD messages in the VLAN. |
mld-snooping dot1p-priority priority |
By default, the 802.1p priority is 6 for MLD messages in a VLAN. |
Before you configure MLD snooping policies, complete the following tasks:
· Determine the ACL used by the IPv6 multicast group policy.
· Determine the maximum number of IPv6 multicast groups that a port can join.
This feature enables the device to filter MLD reports by using an ACL that specifies the IPv6 multicast groups and the optional sources. It is used to control the IPv6 multicast groups that receiver hosts can join.
When you configure an IPv6 multicast group policy, follow these restrictions and guidelines:
· This configuration takes effect on the IPv6 multicast groups that ports join dynamically.
· You can configure an IPv6 multicast group policy globally for all ports in MLD-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
Configuring an IPv6 multicast group policy globally
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
N/A |
3. Configure an IPv6 multicast group policy globally. |
group-policy ipv6-acl-number [ vlan vlan-list ] |
By default, no IPv6 multicast group policies exist. Hosts can join any IPv6 multicast groups. |
Configuring an IPv6 multicast group policy on a port
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure an IPv6 multicast group policy on the port. |
mld-snooping group-policy ipv6-acl-number [ vlan vlan-list ] |
By default, no IPv6 multicast group policies exist on a port. Hosts attached to the port can join any IPv6 multicast groups. |
This feature enables the device to discard all IPv6 multicast data packets and to accept IPv6 multicast protocol packets. You can enable this feature on ports that connect to only IPv6 multicast receivers.
You can enable multicast source port filtering for the specified ports in MLD-snooping view or for a port in interface view. For a port, the configuration in interface view has the same priority as the configuration in MLD-snooping view, and the most recent configuration takes effect.
Enabling IPv6 multicast source port filtering in MLD-snooping view
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
N/A |
3. Enable IPv6 multicast source port filtering globally. |
source-deny port interface-list |
By default, IPv6 multicast source port filtering is disabled globally. |
Enabling IPv6 multicast source port filtering in interface view
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter Layer 2 Ethernet interface view. |
N/A |
3. Enable IPv6 multicast source port filtering on the port. |
mld-snooping source-deny |
By default, IPv6 multicast source port filtering is disabled on the port. |
This feature enables the device to drop all unknown IPv6 multicast data. Unknown IPv6 multicast data refers to IPv6 multicast data for which no forwarding entries exist in the MLD snooping forwarding table.
If you do not enable this feature, the unknown IPv6 multicast data is flooded in the VLAN to which the data belongs.
When you enable dropping unknown IPv6 multicast data, follow these restrictions and guidelines:
· You can enable this feature globally for all VLANs in MLD-snooping view, for a VSI in VSI view, or for a VLAN in VLAN view.
· The configuration made in MLD-snooping view takes effect only on all VLANs. It does not take effect on VSIs.
· The drop-unknown and mld-snooping drop-unknown commands are mutually exclusive. You cannot configure them on the same device.
· The device still forwards unknown IPv6 multicast data to router ports (excluding the incoming port) in a VLAN or VSI even though this feature is enabled.
· If the outgoing ports of the IPv6 multicast forwarding entry for a Layer 3 IPv6 multicast packet are in the same VLAN, enable dropping unknown IPv6 multicast data for the VLAN as a best practice. This restriction prevents the device from flooding the Layer 3 IPv6 multicast packet in the VLAN.
Enabling dropping unknown IPv6 multicast data globally
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
N/A |
3. Enable dropping unknown IPv6 multicast data globally. |
drop-unknown |
By default, dropping unknown IPv6 multicast data is disabled, and unknown IPv6 multicast data is flooded. |
Enabling dropping unknown IPv6 multicast data in a VLAN or VSI
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable dropping unknown IPv6 multicast data for the VLAN or VSI. |
mld-snooping drop-unknown |
This feature enables the Layer 2 device to forward only the first MLD report for an IPv6 multicast group to its directly connected Layer 3 device. Other reports for the same group in the same query interval are discarded. Use this feature to reduce the multicast traffic.
To enable MLD report suppression:
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
N/A |
3. Enable MLD report suppression. |
report-aggregation |
By default, MLD report suppression is enabled. |
You can set the maximum number of IPv6 multicast groups on a port to regulate the port traffic.
When you set the maximum number of IPv6 multicast groups on a port, follow these restrictions and guidelines:
· This feature takes effect only on the IPv6 multicast groups that the port joins dynamically.
· If the number of IPv6 multicast groups on a port exceeds the limit, the system removes all the forwarding entries related to that port. In this case, the receiver hosts attached to that port can join IPv6 multicast groups again before the number of IPv6 multicast groups on the port reaches the limit. When the number of IPv6 multicast groups on the port reaches the limit, the port automatically drops MLD reports for new IPv6 multicast groups.
To set the maximum number of IPv6 multicast groups on a port:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the maximum number of IPv6 multicast groups on the port. |
mld-snooping group-limit limit [ vlan vlan-list ] |
By default, no limit is placed on the maximum number of IPv6 multicast groups on a port. |
When IPv6 multicast group replacement is enabled, the port does not drop MLD reports for new groups if the number of multicast groups on the port reaches the upper limit. Instead, the port leaves an IPv6 multicast group that has the lowest IPv6 address and joins the new group contained in the MLD report. The IPv6 multicast group replacement feature is typically used in the channel switching application.
When you enable IPv6 multicast group replacement, follow these restrictions and guidelines:
· This feature takes effect only on the multicast groups that the port joins dynamically.
· This feature does not take effect if the following conditions exist:
¡ The number of the MLD snooping forwarding entries on the device reaches the upper limit.
¡ The IPv6 multicast group that the port newly joins is not included in the multicast group list maintained by the device.
· You can enable this feature globally for all ports in MLD-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
Enabling IPv6 multicast group replacement globally
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
N/A |
3. Enable IPv6 multicast group replacement globally. |
overflow-replace [ vlan vlan-list ] |
By default, IPv6 multicast group replacement is disabled globally. |
Enabling IPv6 multicast group replacement on a port
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable IPv6 multicast group replacement on the port. |
mld-snooping overflow-replace [ vlan vlan-list ] |
By default, IPv6 multicast group replacement is disabled on a port. |
Enabling host tracking
This feature enables the device to record information about member hosts that are receiving IPv6 multicast data. The information includes IPv6 addresses of the hosts, length of time elapsed since the hosts joined IPv6 multicast groups, and remaining timeout time for the hosts. This feature facilitates monitoring and managing member hosts.
Enabling host tracking globally
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
N/A |
3. Enable host tracking globally. |
host-tracking |
By default, host tracking is disabled globally. |
Enabling host tracking in a VLAN
Step |
Command |
Remarks |
system-view |
N/A |
vlan vlan-id |
N/A |
3. Enable host tracking for the VLAN. |
mld-snooping host-tracking |
By default, host tracking is disabled for a VLAN. |
The DSCP value determines the packet transmission priority. A greater DSCP value represents a higher priority.
To set the DSCP value for outgoing MLD protocol packets:
Step |
Command |
Remarks |
system-view |
N/A |
mld-snooping |
N/A |
3. Set the DSCP value for outgoing MLD protocol packets. |
dscp dscp-value |
By default, the DSCP value is 48 in outgoing MLD protocol packets. |
Command |
(In standalone mode.) Display Layer 2 IPv6 multicast fast forwarding entries. |
display ipv6 l2-multicast fast-forwarding cache [ vlan vlan-id ] [ ipv6-source-address | ipv6-group-address ] * [ slot slot-number ] |
(In IRF mode.) Display Layer 2 IPv6 multicast fast forwarding entries. |
display ipv6 l2-multicast fast-forwarding cache [ vlan vlan-id ] [ ipv6-source-address | ipv6-group-address ] * [ chassis chassis-number slot slot-number ] |
(In standalone mode.) Display information about Layer 2 IPv6 multicast groups. |
display ipv6 l2-multicast ip [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ] |
(In IRF mode.) Display information about Layer 2 IPv6 multicast groups. |
display ipv6 l2-multicast ip [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number ] |
(In standalone mode.) Display Layer 2 IPv6 multicast group entries. |
display ipv6 l2-multicast ip forwarding [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ] |
(In IRF mode.) Display Layer 2 IPv6 multicast group entries. |
display ipv6 l2-multicast ip forwarding [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number ] |
(In standalone mode.) Display information about Layer 2 IPv6 MAC multicast groups. |
display ipv6 l2-multicast mac [ mac-address ] [ vlan vlan-id ] [ slot slot-number ] |
(In IRF mode.) Display information about Layer 2 IPv6 MAC multicast groups. |
display ipv6 l2-multicast mac [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number ] |
(In standalone mode.) Display Layer 2 IPv6 MAC multicast group entries. |
display ipv6 l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ] |
(In IRF mode.) Display Layer 2 IPv6 MAC multicast group entries. |
display ipv6 l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number ] |
Display static IPv6 multicast MAC address entries. |
display mac-address [ mac-address [ vlan vlan-id ] | [ multicast ] [ vlan vlan-id | vsi vsi-name ] [ count ] ] |
Display MLD snooping status. |
display mld-snooping [ global | vlan vlan-id | vsi vsi-name ] |
(In standalone mode.) Display dynamic MLD snooping group entries. |
display mld-snooping group [ ipv6-group-address | ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ interface interface-type interface-number | [ verbose ] [ slot slot-number ] ] |
(In IRF mode.) Display dynamic MLD snooping group entries. |
display mld-snooping group [ ipv6-group-address | ipv6-source-address ] * [ vlan vlan-id | vsi vsi-name ] [ interface interface-type interface-number | [ verbose ] [ chassis chassis-number slot slot-number ] ] |
(In standalone mode.) Display host tracking information. |
display mld-snooping host-tracking vlan vlan-id group ipv6-group-address [ source ipv6-source-address ] [ slot slot-number ] |
(In IRF mode.) Display host tracking information. |
display mld-snooping host-tracking vlan vlan-id group ipv6-group-address [ source ipv6-source-address ] [ chassis chassis-number slot slot-number ] |
(In standalone mode.) Display dynamic router port information. |
display mld-snooping router-port [ vlan vlan-id | vsi vsi-name ] [ verbose ] [ slot slot-number ] |
(In IRF mode.) Display dynamic router port information. |
display mld-snooping router-port [ vlan vlan-id | vsi vsi-name ] [ verbose ] [ chassis chassis-number slot slot-number ] |
(In standalone mode.) Display static MLD snooping group entries. |
display mld-snooping static-group [ ipv6-group-address | ipv6-source-address ] * [ vlan vlan-id ] [ verbose ] [ slot slot-number ] |
(In IRF mode.) Display static MLD snooping group entries. |
display mld-snooping static-group [ ipv6-group-address | ipv6-source-address ] * [ vlan vlan-id ] [ verbose ] [ chassis chassis-number slot slot-number ] |
(In standalone mode.) Display static router port information. |
display mld-snooping static-router-port [ vlan vlan-id ] [ verbose ] [ slot slot-number ] |
(In IRF mode.) Display static router port information. |
display mld-snooping static-router-port [ vlan vlan-id ] [ verbose ] [ chassis chassis-number slot slot-number ] |
Display statistics for the MLD messages and IPv6 PIM hello messages learned through MLD snooping. |
display mld-snooping statistics |
(In standalone mode.) Clear Layer 2 IPv6 multicast fast forwarding entries. |
reset ipv6 l2-multicast fast-forwarding cache [ vlan vlan-id ] { { ipv6-source-address | ipv6-group-address } * | all } [ slot slot-number ] |
(In IRF mode.) Clear Layer 2 IPv6 multicast fast forwarding entries. |
reset ipv6 l2-multicast fast-forwarding cache [ vlan vlan-id ] { { ipv6-source-address | ipv6-group-address } * | all } [ chassis chassis-number slot slot-number ] |
Clear dynamic MLD snooping group entries. |
reset mld-snooping group { ipv6-group-address [ ipv6-source-address ] | all } [ vlan vlan-id | vsi vsi-name ] |
Clear dynamic router port information. |
reset mld-snooping router-port { all | vlan vlan-id | vsi vsi-name } |
Clear statistics for MLD messages and IPv6 PIM hello messages learned through MLD snooping. |
reset mld-snooping statistics |
Network requirements
As shown in Figure 4, Router A runs MLDv1 and acts as the MLD querier, and Switch A runs MLDv1 snooping.
Configure the group policy and simulate joining to meet the following requirements:
· Host A and Host B receive only the IPv6 multicast data addressed to the IPv6 multicast group FF1E::101. IPv6 multicast data can be forwarded through GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 of Switch A uninterruptedly, even though Host A and Host B fail to receive the multicast data.
· Switch A will drop unknown IPv6 multicast data instead of flooding it in VLAN 100.
1. Assign an IPv6 address and prefix length to each interface, as shown in Figure 4. (Details not shown.)
2. Configure Router A:
# Enable IPv6 multicast routing.
[RouterA-mrib6] quit
# Enable MLD on GigabitEthernet 1/0/1.
[RouterA-GigabitEthernet1/0/1] mld enable
# Enable IPv6 PIM-DM on GigabitEthernet 1/0/2.
[RouterA-GigabitEthernet1/0/2] ipv6 pim dm
3. Configure Switch A:
# Enable MLD snooping globally.
[SwitchA] mld-snooping
[SwitchA-mld-snooping] quit
# Create VLAN 100, and assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4 to the VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/4
# Enable MLD snooping, and enable dropping IPv6 unknown multicast data for VLAN 100.
[SwitchA-vlan100] mld-snooping drop-unknown
[SwitchA-vlan100] quit
# Configure an IPv6 multicast group policy so that hosts in VLAN 100 can join only IPv6 multicast group FF1E::101.
[SwitchA] acl ipv6 basic 2001
[SwitchA-acl-ipv6-basic-2001] rule permit source ff1e::101 128
[SwitchA-acl-ipv6-basic-2001] quit
[SwitchA–mld-snooping] group-policy 2001 vlan 100
[SwitchA–mld-snooping] quit
# Configure GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 as simulated member hosts to join IPv6 multicast group FF1E::101.
[SwitchA] interface gigabitethernet 1/0/3
[SwitchA-GigabitEthernet1/0/3] mld-snooping host-join ff1e::101 vlan 100
[SwitchA-GigabitEthernet1/0/3] quit
[SwitchA] interface gigabitethernet 1/0/4
[SwitchA-GigabitEthernet1/0/4] mld-snooping host-join ff1e::101 vlan 100
[SwitchA-GigabitEthernet1/0/4] quit
# Send MLD reports from Host A and Host B to join IPv6 multicast groups FF1E::101 and FF1E::202. (Details not shown.)
# Display dynamic MLD snooping group entries for VLAN 100 on Switch A.
[SwitchA] display mld-snooping group vlan 100
Total 1 entries.
VLAN 100: Total 1 entries.
(::, FF1E::101)
Host slots (0 in total):
Host ports (2 in total):
GE1/0/3 (00:03:23)
GE1/0/4 (00:04:10)
· Host A and Host B have joined IPv6 multicast group FF1E::101 through the member ports GigabitEthernet 1/0/4 and GigabitEthernet 1/0/3 on Switch A, respectively.
· Host A and Host B have failed to join IPv6 multicast group FF1E::202.
As shown in Figure 5:
· Router A runs MLDv1 and acts as the MLD querier. Switch A, Switch B, and Switch C run MLDv1 snooping.
· Host A and Host C are permanent receivers of IPv6 multicast group FF1E::101.
Configure static ports to meet the following requirements:
· To enhance the reliability of IPv6 multicast traffic transmission, configure GigabitEthernet 1/0/3 and GigabitEthernet 1/0/5 on Switch C as static member ports for IPv6 multicast group FF1E::101.
· Suppose the STP runs on the network. To avoid data loops, the forwarding path from Switch A to Switch C is blocked. IPv6 multicast data flows to the receivers attached to Switch C only along the path of Switch A—Switch B—Switch C. When this path is blocked, a minimum of one MLD query-response cycle must be completed before IPv6 multicast data flows to the receivers along the path of Switch A—Switch C. In this case, the multicast delivery is interrupted during the process. For more information about the STP, see Layer 2—LAN Switching Configuration Guide.
Configure GigabitEthernet 1/0/3 on Switch A as a static router port. Then, IPv6 multicast data can flow to the receivers nearly uninterrupted along the path of Switch A—Switch C when the path of Switch A—Switch B—Switch C is blocked.
1. Assign an IPv6 address and prefix length to each interface, as shown in Figure 5. (Details not shown.)
# Create VLAN 100, and assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to the VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/3
# Enable MLD snooping for VLAN 100.
# Configure GigabitEthernet 1/0/3 as a static router port.
[SwitchA-GigabitEthernet1/0/3] mld-snooping static-router-port vlan 100
4. Configure Switch B:
[SwitchB] mld-snooping
[SwitchB-mld-snooping] quit
# Create VLAN 100, and assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to the VLAN.
[SwitchB] vlan 100
[SwitchB-vlan100] port gigabitethernet 1/0/1 gigabitethernet 1/0/2
[SwitchB-vlan100] mld-snooping enable
[SwitchB-vlan100] quit
5. Configure Switch C:
[SwitchC] mld-snooping
[SwitchC-mld-snooping] quit
# Create VLAN 100, and assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/5 to the VLAN.
[SwitchC] vlan 100
[SwitchC-vlan100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/5
[SwitchC-vlan100] mld-snooping enable
[SwitchC-vlan100] quit
# Configure GigabitEthernet 1/0/3 and GigabitEthernet 1/0/5 as static member ports for IPv6 multicast group FF1E::101.
[SwitchC] interface gigabitethernet 1/0/3
[SwitchC-GigabitEthernet1/0/3] mld-snooping static-group ff1e::101 vlan 100
[SwitchC-GigabitEthernet1/0/3] quit
[SwitchC] interface gigabitethernet 1/0/5
[SwitchC-GigabitEthernet1/0/5] mld-snooping static-group ff1e::101 vlan 100
[SwitchC-GigabitEthernet1/0/5] quit
# Display static router port information for VLAN 100 on Switch A.
[SwitchA] display mld-snooping static-router-port vlan 100
VLAN 100:
Router slots (0 in total):
Router ports (1 in total):
GE1/0/3
The output shows that GigabitEthernet 1/0/3 on Switch A has become a static router port.
# Display static MLD snooping group entries in VLAN 100 on Switch C.
[SwitchC] display mld-snooping static-group vlan 100
Total 1 entries).
VLAN 100: Total 1 entries).
(::, FF1E::101)
GE1/0/3
GE1/0/5
The output shows that GigabitEthernet 1/0/3 and GigabitEthernet 1/0/5 on Switch C have become static member ports of IPv6 multicast group FF1E::101.
As shown in Figure 6:
· The network is a Layer 2-only network.
· Source 1 and Source 2 send multicast data to IPv6 multicast groups FF1E::101 and FF1E::102, respectively.
· Host A and Host C are receivers of IPv6 multicast group FF1E::101, and Host B and Host D are receivers of IPv6 multicast group FF1E::102.
· All host receivers run MLDv1 and all switches run MLDv1 snooping. Switch A (which is close to the multicast sources) acts as the MLD snooping querier.
To prevent the switches from flooding unknown IPv6 packets in the VLAN, enable all the switches to drop unknown IPv6 multicast packets.
1. Configure Switch A:
[SwitchA] vlan 100
# Enable MLD snooping, and enable dropping unknown IPv6 multicast data for VLAN 100.
# Configure Switch A as the MLD snooping querier.
[SwitchA-vlan100] MLD-snooping querier
2. Configure Switch B:
[SwitchB] vlan 100
[SwitchB-vlan100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/4
[SwitchB-vlan100] mld-snooping drop-unknown
3. Configure Switch C:
[SwitchC] vlan 100
[SwitchC-vlan100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[SwitchC-vlan100] mld-snooping drop-unknown
4. Configure Switch D:
<SwitchD> system-view
[SwitchD] mld-snooping
[SwitchD-mld-snooping] quit
[SwitchD] vlan 100
[SwitchD-vlan100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/2
[SwitchD-vlan100] mld-snooping enable
[SwitchD-vlan100] mld-snooping drop-unknown
[SwitchD-vlan100] quit
# Display statistics for MLD messages and IPv6 PIM hello messages learned through MLD snooping on Switch B.
[SwitchB] display mld-snooping statistics
Received MLD general queries: 3
Received MLDv1 specific queries: 0
Received MLDv1 reports: 12
Received MLD dones: 0
Sent MLDv1 specific queries: 0
Received MLDv2 reports: 0
Received MLDv2 reports with right and wrong records: 0
Received MLDv2 specific queries: 0
Received MLDv2 specific sg queries: 0
Sent MLDv2 specific queries: 0
Sent MLDv2 specific sg queries: 0
Received IPv6 PIM hello: 0
Received error MLD messages: 0
The output shows that all switches except Switch A can receive the MLD general queries after Switch A acts as the MLD snooping querier.
MLD snooping proxying configuration example (for VLANs)
As shown in Figure 7, Router A runs MLDv1 and acts as the MLD querier. Switch A runs MLDv1 snooping. Configure MLD snooping proxying so that Switch A can perform the following operations:
· Forward MLD reports and done messages to Router A.
· Respond to MLD queries sent by Router A and forward the queries to downstream hosts.
1. Assign an IPv6 address and subnet mask to each interface, as shown in Figure 7. (Details not shown.)
# Enable MLD and IPv6 PIM-DM on GigabitEthernet 1/0/1.
[RouterA-GigabitEthernet1/0/1] ipv6 pim dm
[SwitchA] vlan 100
# Enable MLD snooping and MLD snooping proxying for the VLAN.
[SwitchA-vlan100] mld-snooping proxy enable
# Send MLD reports from Host A and Host B to join IPv6 multicast group FF1E::101. (Details not shown.)
# Display MLD snooping group membership information on Switch A.
Total 1 entries.
(::, FF1E::101)
GE1/0/3 (00:04:09)
GE1/0/4 (00:03:06)
# Display MLD group membership information on Router A.
[RouterA] display mld group
MLD groups in total: 1
GigabitEthernet1/0/1(2001::1):
MLD groups reported in total: 1
Group address: FF1E::101
Last reporter: FE80::2FF:FFFF:FE00:1
Uptime: 00:00:31
Expires: 00:03:48
# Send an MLD done message from Host A to leave IPv6 multicast group FF1E::101. (Details not shown.)
Total 1 entries.
(::, FF1E::101)
Host ports (1 in total):
GE1/0/3 (00:01:23)
MLD snooping configuration example (for VXLANs)
As shown in Figure 8:
· VXLAN 10 provides Layer 2 connectivity for VM 1, VM 2, and VM 3 across the network sites.
· VXLAN 10 uses the unicast mode for flood traffic.
Configure MLD snooping on the switches to implement IPv6 Layer 2 multicast forwarding and reduce the burden of replicating known multicast traffic for VTEPs in VXLAN 10.
Device |
IP address |
Device |
IP address |
Switch A |
Vlan-int11 |
11.1.1.1/24 |
Switch C |
Vlan-int13 |
13.1.1.3/24 |
Switch A |
Loop0 |
1.1.1.1/32 |
Switch C |
Loop0 |
3.3.3.3/32 |
Switch B |
Vlan-int12 |
12.1.1.2/24 |
Switch D |
Vlan-int11 |
11.1.1.4/24 |
Switch B |
Loop0 |
2.2.2.2/32 |
Switch D |
Vlan-int12 |
12.1.1.4/24 |
Switch D |
Vlan-int13 |
13.1.1.4/24 |
1. Assign an IP address and subnet mask to each interface on the transport network, as shown in Table 1. (Details not shown.)
2. Configure OSPF on all the switches in the transport network. (Details not shown.)
# Enable L2VPN.
[SwitchA] l2vpn enable
# Create a VSI named vpna, and create VXLAN 10.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] vxlan 10
[SwitchA-vsi-vpna] quit
[SwitchA -mld-snooping] quit
# Enable MLD snooping and dropping unknown IPv6 multicast data packets for VSI vpna.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] mld-snooping enable
[SwitchA-vsi-vpna] mld-snooping drop-unknown
# Assign an IP address to Loopback 0. This address will be used as the source address of the VXLAN tunnels to Switch B and Switch C.
[SwitchA-Loopback0] ip address 1.1.1.1 255.255.255.255
[SwitchA-Loopback0] quit
# Create a VXLAN tunnel to Switch B.
¡ The tunnel interface name is Tunnel 1.
¡ The source address and destination address of the tunnel interface are 1.1.1.1 and 2.2.2.2, respectively.
[SwitchA-Tunnel1] quit
# Create a VXLAN tunnel to Switch C.
¡ The tunnel interface name is Tunnel 2.
¡ The source address and destination address of the tunnel interface are 1.1.1.1 and 3.3.3.3, respectively.
[SwitchA] interface tunnel 2 mode vxlan
[SwitchA-Tunnel2] source 1.1.1.1
[SwitchA-Tunnel2] destination 3.3.3.3
[SwitchA-Tunnel2] quit
# Assign Tunnel 1 and Tunnel 2 to VXLAN 10.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna-vxlan-10] tunnel 1
[SwitchA-vsi-vpna-vxlan-10] tunnel 2
# Configure GigabitEthernet 1/0/1 as a trunk port and assign it to VLAN 2.
[SwitchA-GigabitEthernet1/0/1] port link-type trunk
[SwitchA-GigabitEthernet1/0/1] port trunk permit vlan 2
# On GigabitEthernet 1/0/1, create Ethernet service instance 1000 to match VLAN 2.
[SwitchA-GigabitEthernet1/0/1] service-instance 1000
[SwitchA-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
# Map Ethernet service instance 1000 to VSI vpna.
[SwitchA-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchA-GigabitEthernet1/0/1-srv1000] quit
[SwitchA-GigabitEthernet1/0/1] quit
# Enable L2VPN.
[SwitchB] l2vpn enable
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] vxlan 10
[SwitchB-vsi-vpna] quit
[SwitchB -mld-snooping] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] mld-snooping enable
[SwitchB-vsi-vpna] mld-snooping drop-unknown
# Assign an IP address to Loopback 0. This address will be used as the source address of the VXLAN tunnels to Switch A and Switch C.
[SwitchB-Loopback0] ip address 2.2.2.2 255.255.255.255
[SwitchB-Loopback0] quit
# Create a VXLAN tunnel to Switch A.
¡ The source address and destination address of the tunnel interface are 2.2.2.2 and 1.1.1.1, respectively.
[SwitchB] interface tunnel 2 mode vxlan
[SwitchB-Tunnel2] source 2.2.2.2
[SwitchB-Tunnel2] destination 1.1.1.1
[SwitchB-Tunnel2] quit
¡ The tunnel interface name is Tunnel 3.
¡ The source address and destination address of the tunnel interface are 2.2.2.2 and 3.3.3.3, respectively.
[SwitchB] interface tunnel 3 mode vxlan
[SwitchB-Tunnel3] source 2.2.2.2
[SwitchB-Tunnel3] destination 3.3.3.3
[SwitchB-Tunnel3] quit
# Assign Tunnel 2 and Tunnel 3 to VXLAN 10.
[SwitchB] vsi vpna
[SwitchB-vsi-vpna-vxlan-10] tunnel 2
[SwitchB-vsi-vpna-vxlan-10] tunnel 3
[SwitchB-GigabitEthernet1/0/1] port link-type trunk
[SwitchB-GigabitEthernet1/0/1] port trunk permit vlan 2
[SwitchB-GigabitEthernet1/0/1] service-instance 1000
[SwitchB-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
[SwitchB-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchB-GigabitEthernet1/0/1-srv1000] quit
# Enable L2VPN.
[SwitchC] l2vpn enable
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] vxlan 10
[SwitchC-vsi-vpna] quit
# Enable MLD snooping for VSI vpna.
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] mld-snooping enable
# Enable dropping unknown IPv6 multicast data packets for VSI vpna.
[SwitchC-vsi-vpna] mld-snooping drop-unknown
# Specify FE80::3 as the source IPv6 address of MLD general queries in VSI vpna.
[SwitchC-vsi-vpna] mld-snooping general-query source-ip fe80::3
# Enable the MLD snooping querier for VSI vpna.
[SwitchC-vsi-vpna] mld-snooping querier
# Assign an IP address to Loopback 0. This address will be used as the source address of the VXLAN tunnels to Switch A and Switch B.
[SwitchC-Loopback0] ip address 3.3.3.3 255.255.255.255
[SwitchC-Loopback0] quit
¡ The source address and destination address of the tunnel interface are 3.3.3.3 and 1.1.1.1, respectively.
[SwitchC] interface tunnel 1 mode vxlan
[SwitchC-Tunnel1] source 3.3.3.3
[SwitchC-Tunnel1] destination 1.1.1.1
[SwitchC-Tunnel1] quit
¡ The source address and destination address of the tunnel interface are 3.3.3.3 and 2.2.2.2, respectively.
[SwitchC] interface tunnel 3 mode vxlan
[SwitchC-Tunnel3] source 3.3.3.3
[SwitchC-Tunnel3] destination 2.2.2.2
[SwitchC-Tunnel3] quit
# Assign Tunnel 1 and Tunnel 3 to VXLAN 10.
[SwitchC] vsi vpna
[SwitchC-vsi-vpna-vxlan-10] tunnel 1
[SwitchC-vsi-vpna-vxlan-10] tunnel 3
[SwitchC] interface gigabitethernet 1/0/1
[SwitchC-GigabitEthernet1/0/1] port link-type trunk
[SwitchC-GigabitEthernet1/0/1] port trunk permit vlan 2
# On GigabitEthernet 1/0/1, create Ethernet service instance 1000 to map VLAN 2.
[SwitchC-GigabitEthernet1/0/1] service-instance 1000
[SwitchC-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
[SwitchC-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchC-GigabitEthernet1/0/1-srv1000] quit
[SwitchC-GigabitEthernet1/0/1] quit
# Display dynamic router port information for VSI vpna on Switch A.
[SwitchA] display mld-snooping router-port vsi vpna
VSI vpna:
NPW (VXLAN ID 10 Link ID 0X5000001) (00:04:17)
# Display dynamic router port information for VSI vpna on Switch B.
[SwitchB] display mld-snooping router-port vsi vpna
VSI vpna:
NPW (VXLAN ID 10 Link ID 0X5000001) (00:04:07)
Troubleshooting MLD snooping
Layer 2 multicast forwarding cannot function
Symptom
Layer 2 multicast forwarding cannot function through MLD snooping.
Solution
To resolve the problem:
1. Use the display mld-snooping command to display MLD snooping status.
2. If MLD snooping is not enabled, use the mld-snooping command in system view to enable MLD snooping globally. Then, use the mld-snooping enable command in VLAN view or VSI view to enable MLD snooping for the VLAN or VSI.
3. If MLD snooping is enabled globally but not enabled for the VLAN or VSI, use the mld-snooping enable command in VLAN view or VSI view to enable MLD snooping for the VLAN or VSI.
4. If the problem persists, contact H3C Support.
IPv6 multicast group policy does not work
Symptom
Hosts can receive IPv6 multicast data for IPv6 multicast groups that are not permitted by the IPv6 multicast group policy.
Solution
1. Use the display acl ipv6 command to verify that the configured IPv6 ACL meets the IPv6 multicast group policy requirements.
2. Use the display this command in MLD-snooping view or in interface view to verify that the correct IPv6 multicast group policy has been applied. If the applied policy is not correct, use the group-policy or mld-snooping group-policy command to apply the correct IPv6 multicast group policy.
3. Use the display mld-snooping command to verify that dropping unknown IPv6 multicast data is enabled. If it is not, use the drop-unknown or mld-snooping drop-unknown command to enable dropping unknown IPv6 multicast data.
