07-ACL and QoS Command Reference
HomeSupportSwitchesS5130 SeriesReference GuidesCommand ReferencesH3C S5130-HI Command References-R1118P02[R1122]-6W10207-ACL and QoS Command Reference
04-Data buffer commands
04-Data buffer commands 54.18 KB
Inappropriate data buffer changes can cause system problems. Before manually changing data buffer settings, make sure you understand its impact on your device. If the system requires large buffer spaces, H3C recommends that you use the burst-mode enable command. The burst-mode enable command and the buffer apply command are mutually exclusive. If you have configured the data buffer by using one command, you must execute the undo form of the command before using the other command.
buffer apply
Use buffer apply to apply manually configured data buffer settings.
Use undo buffer apply to cancel the application.
buffer apply
undo buffer apply
After applying manually configured data buffer settings, you cannot directly modify the applied settings. To modify them, you must cancel the application, reconfigure data buffer settings, and reapply the new settings.
# Apply manually configured data buffer settings.
[Sysname] buffer apply
buffer queue guaranteed
Use buffer queue guaranteed to set the fixed-area ratio for a queue.
Use undo buffer queue guaranteed to restore the default.
buffer egress [ slot slot-number ] cell queue queue-id guaranteed ratio ratio-value
undo buffer egress [ slot slot-number ] cell queue queue-id guaranteed
The fixed-area ratio for a queue is 12.5%, but the default value in the display buffer queue command output is 12%.
egress: Specifies the egress buffer.
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command applies to all IRF member devices.
cell: Specifies cell resources.
queue-id: Specifies a queue by its ID in the range of 0 to 7.
ratio ratio-value: Specifies the fixed-area ratio in percentage.
The fixed-area space for a queue cannot be used by other queues. It is also called the minimum guaranteed buffer.
The sum of fixed-area ratios configured for queues cannot be greater than or equal to 100%. Queues 5, 6, and 7 must have available fixed-area space.
After you set the fixed-area ratios for some queues, the other queues each are assigned an equal share of the remaining part of the fixed area. The display buffer queue command displays the preceding whole number for each assignment result. Therefore, the sum of the ratios for all queues might be less than 100%.
# Configure queue 0 to use 15% fixed-area space of cell resources in the egress buffer of IRF member device 2.
[Sysname] buffer egress slot 2 cell queue 0 guaranteed ratio 15
buffer queue shared
Use buffer queue shared to set the maximum shared-area ratio for a queue.
Use undo buffer queue shared to restore the default.
buffer egress [ slot slot-number ] cell queue queue-id shared ratio ratio-value
undo buffer egress [ slot slot-number ] cell queue queue-id shared
The maximum shared-area ratio for a queue is 33%.
ratio ratio-value: Specifies the maximum shared-area ratio in percentage.
By default, all queues have an equal share of the shared area. You can set the shared-area ratio for a queue. The unconfigured queues use the default setting. The shared-area ratio for each queue is finally determined by the chip based on your configuration and the number of packets to be sent.
For the maximum shared-area ratio for a queue, the percentage values 0 to 100 are divided into 10 ranges. Table 1 shows the effective values that correspond to the configured values of ratio-value.
Table 1 Mapping between configured values of ratio-value and effective values
Configured value of ratio-value
Effective value
0 to 1
1
2 to 3
3
4 to 7
6
8 to 16
11
17 to 29
20
30 to 42
33
43 to 60
50
61 to 76
67
77 to 86
80
87 to 100
89
# Configure queue 0 to use up to 5% shared-area space of cell resources in the egress buffer of IRF member device 2.
[Sysname] buffer egress slot 2 cell queue 0 shared ratio 5
buffer total-shared
Use buffer total-shared to set the total shared-area ratio.
Use undo buffer total-shared to restore the default.
buffer egress [ slot slot-number ] cell total-shared ratio ratio-value
undo buffer egress [ slot slot-number ] cell total-shared
The total shared-area ratio is 97% of the buffer.
ratio ratio-value: Specifies the ratio of the shared area in percentage.
After you set the total shared-area ratio, the remaining buffer space is automatically assigned to the fixed area.
# Configure the shared area to use 65% space of cell resources in the egress buffer of IRF member device 2.
[Sysname] buffer egress slot 2 cell total-shared ratio 65
burst-mode enable
Use burst-mode enable to enable the Burst feature.
Use undo burst-mode enable to disable the Burst feature.
burst-mode enable
The Burst feature is disabled.
The Burst feature is especially useful for reducing packet losses under the following circumstances:
·     Traffic enters a device from a high-speed interface and goes out of a low-speed interface.
·     Traffic enters a device from multiple same-rate interfaces and goes out of an interface with the same rate.
The Burst feature takes effect only on known unicast packets.
# Enable the Burst feature.
[Sysname] burst-mode enable
display buffer
Use display buffer to display buffer size settings.
display buffer [ slot slot-number ] [ queue [ queue-id ] ]
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays buffer size settings for all IRF member devices.
queue queue-id: Specifies a queue by its ID in the range of 0 to 7.
If you do not specify the queue keyword, this command displays the total shared-area ratio.
If you specify the queue keyword, this command displays the fixed-area ratio and shared-area ratio for all queues.
If you specify a queue, this command displays the fixed-area size and shared-area size for the specified queue.
# Display the total shared-area ratio.
<Sysname> display buffer
Slot  Type    Eg(Total-shared)
1     cell    25
          Eg: Size of the sending buffer
Total-shared: Size of the shared buffer for all ports
        Unit: Ratio
# Display the fixed-area ratio and shared-area ratio for each queue.
<Sysname> display buffer queue
Slot  Queue        Type    Eg(Guaranteed , Shared)
2     0            cell    20 , 33
2     1            cell    14 , 33
2     2-7          cell    11 , 33
  Guaranteed: Size of the minimum guaranteed buffer per queue
      Shared: Size of the maximum shared buffer per queue
        Unit: Ratio
Slot
ID of an IRF member device.
Resource type. The device supports only cell resources.
Queue
Queue ID in the range of 0 to 7.
Eg
Egress buffer.
(Total-shared)
Total shared-area size.
·     Guaranteed—Fixed-area ratio for a queue.
·     Shared—Shared-area ratio for a queue.
The default fixed-area ratio for a queue is 12.5%, but the default value in the display buffer queue command output is 12%.
Unit
Unit for configuring the data buffer. The device supports only ratio.
display buffer usage
Use display buffer usage to display buffer usage.
display buffer usage [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays buffer usage for all IRF member devices.
# Display data buffer usage.
<Sysname> display buffer usage
Egress total-shared cell buffer usage on slot 1
Total:    3872 KB
Used:       0 KB
Free:    3872 KB
                              5sec    1min    5min
Block 1                         0%      0%      0%
GigabitEthernet1/0/1            0%      0%      0%
GigabitEthernet1/0/2            0%      0%      0%
GigabitEthernet1/0/3            0%      0%      0%
GigabitEthernet1/0/4            0%      0%      0%
GigabitEthernet1/0/5            0%      0%      0%
GigabitEthernet1/0/6            0%      0%      0%
GigabitEthernet1/0/7            0%      0%      0%
GigabitEthernet1/0/8            0%      0%      0%
GigabitEthernet1/0/9            0%      0%      0%
GigabitEthernet1/0/10           0%      0%      0%
GigabitEthernet1/0/11           0%      0%      0%
GigabitEthernet1/0/12           0%      0%      0%
GigabitEthernet1/0/13           0%      0%      0%
GigabitEthernet1/0/14           0%      0%      0%
GigabitEthernet1/0/15           0%      0%      0%
GigabitEthernet1/0/16           0%      0%      0%
GigabitEthernet1/0/17           0%      0%      0%
GigabitEthernet1/0/18           0%      0%      0%
GigabitEthernet1/0/19           0%      0%      0%
GigabitEthernet1/0/20           0%      0%      0%
GigabitEthernet1/0/21           0%      0%      0%
GigabitEthernet1/0/22           0%      0%      0%
GigabitEthernet1/0/23           0%      0%      0%
GigabitEthernet1/0/24           0%      0%      0%
GigabitEthernet1/0/25           0%      0%      0%
GigabitEthernet1/0/26           0%      0%      0%
GigabitEthernet1/0/27           0%      0%      0%
GigabitEthernet1/0/28           0%      0%      0%
GigabitEthernet1/0/29           0%      0%      0%
GigabitEthernet1/0/30           0%      0%      0%
GigabitEthernet1/0/31           0%      0%      0%
GigabitEthernet1/0/32           0%      0%      0%
GigabitEthernet1/0/33           0%      0%      0%
GigabitEthernet1/0/34           0%      0%      0%
GigabitEthernet1/0/35           0%      0%      0%
GigabitEthernet1/0/36           0%      0%      0%
GigabitEthernet1/0/37           0%      0%      0%
GigabitEthernet1/0/38           0%      0%      0%
GigabitEthernet1/0/39           0%      0%      0%
GigabitEthernet1/0/40           0%      0%      0%
GigabitEthernet1/0/41           0%      0%      0%
GigabitEthernet1/0/42           0%      0%      0%
GigabitEthernet1/0/43           0%      0%      0%
GigabitEthernet1/0/44           0%      0%      0%
GigabitEthernet1/0/45           0%      0%      0%
GigabitEthernet1/0/46           0%      0%      0%
GigabitEthernet1/0/47           0%      0%      0%
GigabitEthernet1/0/48           0%      0%      0%
Ten-GigabitEthernet1/0/49       0%      0%      0%
Ten-GigabitEthernet1/0/50       0%      0%      0%
Ten-GigabitEthernet1/0/51       0%      0%      0%
Ten-GigabitEthernet1/0/52       0%      0%      0%
Usage of the shared area of cell resources on an IRF member device.
Total
Total size of the data buffer.
Used
Size of used data buffer.
Free
Size of free data buffer.
Block 1
Block where the port resides. The block where the ports on the front panel of the device reside is fixed to Block 1.
5sec
Percentage of the buffer that the port uses for the last 5 seconds.
1min
Percentage of the buffer that the port uses for the last 1 minute.
5min
Percentage of the buffer that the port uses for the last 5 minutes.
