07-ACL and QoS Command Reference
HomeSupportSwitchesS5130 SeriesReference GuidesCommand ReferencesH3C S5130-HI Command References-R1118P02[R1122]-6W10207-ACL and QoS Command Reference
02-QoS commands
02-QoS commands 294.22 KB
QoS policy commands· 1
Traffic class commands· 1
display traffic classifier 1
if-match· 2
traffic classifier 6
Traffic behavior commands· 7
accounting· 7
car 8
display traffic behavior 9
filter 11
nest top-most 11
redirect 12
remark customer-vlan-id· 13
remark dot1p· 13
remark drop-precedence· 14
remark dscp· 15
remark ip-precedence· 16
remark local-precedence· 17
remark qos-local-id· 17
remark service-vlan-id· 18
traffic behavior 18
QoS policy commands· 19
classifier behavior 19
control-plane· 20
display qos policy· 20
display qos policy control-plane· 21
display qos policy control-plane pre-defined· 22
display qos policy global 24
display qos policy interface· 25
display qos vlan-policy· 26
qos apply policy (interface view, control plane view) 28
qos apply policy (user profile view) 28
qos apply policy global 29
qos policy· 30
qos vlan-policy· 30
reset qos policy control-plane· 31
reset qos policy global 31
reset qos vlan-policy· 32
Priority mapping commands· 33
Priority map commands· 33
display qos map-table· 33
import 34
qos map-table· 34
Port priority commands· 35
qos priority· 35
Priority trust mode commands· 36
display qos trust interface· 36
qos trust 36
GTS and rate limit commands· 38
GTS commands· 38
display qos gts interface· 38
qos gts· 38
Rate limit commands· 39
display qos lr interface· 39
qos lr 40
Congestion management commands· 41
SP commands· 41
display qos queue sp interface· 41
qos sp· 41
WRR commands· 42
display qos queue wrr interface· 42
qos wrr 43
qos wrr { byte-count | weight } 44
qos wrr group sp· 45
WFQ commands· 46
display qos queue wfq interface· 46
qos bandwidth queue· 47
qos wfq· 47
qos wfq { byte-count | weight } 48
qos wfq group sp· 49
Queue scheduling profile commands· 50
bandwidth· 50
display qos qmprofile configuration· 51
display qos qmprofile interface· 52
qos apply qmprofile· 52
qos qmprofile· 53
queue· 54
Queue-based accounting commands· 55
display qos queue-statistics interface outbound· 55
Congestion avoidance commands· 57
WRED commands· 57
display qos wred interface· 57
display qos wred table· 57
qos wred apply· 58
qos wred table· 59
queue· 60
queue ecn· 61
queue weighting-constant 61
Global CAR commands· 63
car name· 63
display qos car name· 64
qos car 65
reset qos car name· 67
QoS policy commands
Use display traffic classifier to display traffic classes.
user-defined: Specifies user-defined traffic classes.
classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays traffic classes on all IRF member devices.
# Display all user-defined traffic classes.
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 2 (ID 101)
     Operator: AND
     Rule(s) :
      If-match protocol ipv6
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
Classifier
Traffic class name and its match criteria.
Operator
Match operator you set for the traffic class. If the operator is AND, the traffic class matches the packets that match all its match criteria. If the operator is OR, the traffic class matches the packets that match any of its match criteria.
Rule(s)
Match criteria.
if-match
Use if-match to define a match criterion.
Use undo if-match to delete a match criterion.
if-match match-criteria
undo if-match match-criteria
No match criterion is configured.
Traffic class view
match-criteria: Specifies a match criterion. Table 2 shows the available match criteria.
Table 2 Available match criteria
Option
acl [ ipv6 ] { acl-number | name acl-name }
Matches an ACL.
The acl-number argument has the following value ranges:
·     2000 to 3999 for IPv4 ACLs.
·     2000 to 3999 for IPv6 ACLs.
·     4000 to 4999 for Ethernet frame header ACLs.
The acl-name argument is a case-insensitive string of 1 to 63 characters, which must start with an English letter. To avoid confusion, make sure the argument is not all.
any
Matches all packets.
control-plane protocol protocol-name&<1-8>
Matches control plane protocols.
The protocol-name&<1-8> argument specifies a space-separated list of up to eight system-defined control plane protocols. For available system-defined control plane protocols, see Table 3.
control-plane protocol-group protocol-group-name
Matches a control plane protocol group.
The protocol-group-name argument can be critical, important, management, monitor, normal, or redirect.
customer-dot1p dot1p-value&<1-8>
Matches 802.1p priority values in inner VLAN tags of double-tagged packets.
The dot1p-value&<1-8> argument specifies a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7.
customer-vlan-id vlan-id-list
Matches VLAN IDs in inner VLAN tags of double-tagged packets.
The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
destination-mac mac-address
Matches a destination MAC address.
dscp dscp-value&<1-8>
Matches DSCP values.
The dscp-value&<1-8> argument specifies a space-separated list of up to eight DSCP values. The value range for the dscp-value argument is 0 to 63 or keywords shown in Table 5.
ip-precedence ip-precedence-value&<1-8>
Matches IP precedence values.
The ip-precedence-value&<1-8> argument specifies a space-separated list of up to eight IP precedence values. The value range for the ip-precedence-value argument is 0 to 7.
Matches a protocol.
The protocol-name argument can be ip or ipv6.
qos-local-id local-id-value
Matches a local QoS ID in the range of 1 to 4095. The switch supports local QoS IDs in the range of 1 to 3999.
service-dot1p dot1p-value&<1-8>
Matches 802.1p priority values in outer VLAN tags.
service-vlan-id vlan-id-list
Matches VLAN IDs in outer VLAN tags.
source-mac mac-address
Matches a source MAC address.
Table 3 Available system-defined control plane protocols
Protocol
arp
ARP packets
arp-snooping
ARP snooping packets
bgp
BGP packets
bgp4+
IPv6 BGP packets
dhcp
DHCP packets
dhcp-snooping
DHCP snooping packets
dhcp6
IPv6 DHCP packets
dldp
DLDP packets
dot1x
802.1X packets
mvrp
MVRP packets (including GVRP packets)
http
HTTP packets
https
HTTPS packets
icmp
ICMP packets
icmp6
ICMPv6 packets
igmp
IGMP packets
ip-option
IPv4 packets with the Options field
ipv6-option
IPv6 packets with the Options field
isis
IS-IS packets
lacp
LACP packets
lldp
LLDP packets
ospf-multicast
OSPF multicast packets
ospf-unicast
OSPF unicast packets
ospf3-multicast
OSPFv3 multicast packets
ospf3-unicast
OSPFv3 unicast packets
ssh
SSH packets
stp
STP packets
telnet
Telnet packets
vrrp
VRRP packets
vrrp6
IPv6 VRRP packets
If a traffic class in a QoS policy includes the customer-vlan-id match criterion, the QoS policy can be applied only to interfaces.
If a traffic class includes both the control-plane protocol or control-plane protocol-group criterion and other criteria, the QoS policy that contains the traffic class cannot be applied correctly.
If any traffic class in a QoS policy includes the control-plane protocol or control-plane protocol-group match criterion, the QoS policy can be applied only to a control plane.
For single-tagged packets, you can use the service-vlan-id criterion to match them.
To configure multiple values for a match criterion, perform the following tasks:
1.     Set the logical operator to OR.
2.     Configure multiple if-match commands for the match criterion.
For the customer-vlan-id and service-vlan-id match criteria, you can configure multiple values in one if-match command when the logical operator is OR or AND.
To delete multiple values configured in one if-match command, make sure the values specified in the undo if-match command are the same as the configured values. The order of the values can be different.
When you configure ACL-based match criteria for a traffic class, follow these restrictions and guidelines:
·     If the ACL used as a match criterion does not exist, the QoS policy that uses the traffic class cannot be applied correctly.
·     You can add two if-match statements that use the same ACL as the match criterion. In one statement, specify the ACL by its name. In the other statement, specify the ACL by its number.
·     If the configured logical operator is AND for the traffic class, the actual logical operator for the rules in an ACL is OR.
# Define a match criterion for traffic class class1 to match the packets with a destination MAC address of 0050-ba27-bed3.
# Define a match criterion for traffic class class2 to match the packets with a source MAC address of 0050-ba27-bed2.
# Define a match criterion for traffic class class1 to match double-tagged packets with 802.1p priority 3 in inner VLAN tags.
# Define a match criterion for traffic class class1 to match the packets with 802.1p priority 5 in outer VLAN tags.
[Sysname-classifier-class1] if-match service-dot1p 5
# Define a match criterion for traffic class class1 to match the advanced ACL 3101.
# Define a match criterion for traffic class class1 to match the ACL named flow.
# Define a match criterion for traffic class class1 to match the advanced IPv6 ACL 3101.
# Define a match criterion for traffic class class1 to match the IPv6 ACL named flow.
# Define a match criterion for traffic class class1 to match all packets.
# Define a match criterion for traffic class class1 to match the packets with a DSCP value of 1, 6, or 9.
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1
[Sysname-classifier-class1] if-match dscp 6
[Sysname-classifier-class1] if-match dscp 9
# Define a match criterion for traffic class class1 to match the packets with an IP precedence value of 1 or 6.
[Sysname-classifier-class1] if-match ip-precedence 1
[Sysname-classifier-class1] if-match ip-precedence 6
# Define a match criterion for traffic class class1 to match IP packets.
# Define a match criterion for traffic class class1 to match double-tagged packets with VLAN ID 1, 6, or 9 in inner VLAN tags.
# Define a match criterion for traffic class class1 to match the packets with VLAN ID 2, 7, or 10 in outer VLAN tags.
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# Define a match criterion for traffic class class1 to match the packets with a local QoS ID of 3.
[Sysname-classifier-class1] if-match qos-local-id 3
# Define a match criterion for traffic class class1 to match ARP protocol packets.
[Sysname-classifier-class1] if-match control-plane protocol arp
# Define a match criterion for traffic class class1 to match packets of the protocols in protocol group normal.
[Sysname-classifier-class1] if-match control-plane protocol-group normal
traffic classifier
Use traffic classifier to create a traffic class and enter traffic class view.
Use undo traffic classifier to delete a traffic class.
No traffic class exists.
classifier-name: Specifies the name of the traffic class to be created, a case-sensitive string of 1 to 31 characters.
operator: Sets the operator to logic AND (the default) or OR for the traffic class.
and: Specifies the logic AND operator. The traffic class matches the packets that match all its criteria.
or: Specifies the logic OR operator. The traffic class matches the packets that match any of its criteria.
# Create a traffic class named class1.
accounting
Use accounting to configure a traffic accounting action in a traffic behavior.
Use undo accounting to delete the action.
accounting { byte | packet }
undo accounting
No traffic accounting action is configured.
Traffic behavior view
byte: Counts traffic in bytes.
packet: Counts traffic in packets.
A QoS policy that contains an accounting action cannot be applied globally.
# Configure a traffic accounting action in traffic behavior database to count traffic in bytes.
[Sysname-behavior-database] accounting byte
car
Use car to configure a CAR action in a traffic behavior.
Use undo car to delete the action.
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] * [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] * [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
undo car
No CAR action is configured.
cir committed-information-rate: Specifies the committed information rate (CIR) in kbps, which specifies an average traffic rate. The value range for the committed-information-rate argument is 8 and 160000000 in multiples of 8.
cbs committed-burst-size: Specifies the committed burst size (CBS) in bytes. The value range for the committed-burst-size argument is 512 and 256000000 in multiples of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the excess burst size (EBS) in bytes. The value range for the excess-burst-size argument is 0 and 256000000 in multiples of 512, and the default value is 512.
pir peak-information-rate: Specifies the peak information rate (PIR) in kbps. The value range for the peak-information-rate argument is 8 and 160000000 in multiples of 8.
green action: Specifies the action to take on packets that conform to the CIR. The default setting is pass.
red action: Specifies the action to take on packets that conforms to neither CIR nor PIR. The default setting is discard.
yellow action: Action to take on packets that conform to the PIR but not to the CIR. The default setting is pass.
action: Sets the action to take on the packet:
·     discard: Drops the packet.
·     pass: Permits the packet to pass through.
·     remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
·     remark-dscp-pass new-dscp: Sets the DSCP value of the packet to new-dscp and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63.
·     remark-lp-pass new-local-precedence: Sets the local precedence value of the packet to new-local-precedence and permits the packet to pass through. The new-local-precedence argument is in the range of 0 to 7.
hierarchy-car hierarchy-car-name: Specifies a hierarchical CAR action to be used by its name.
mode: Specifies the collaborating mode of the hierarchical CAR action and the common CAR action:
·     and: AND mode, the default mode in which the traffic rate of a flow is limited by both the common CAR applied to it and the total traffic rate defined with hierarchical CAR. For example, use common CAR actions to limit the rates of both Internet access flow 1 and flow 2 to 128 kbps, and use a hierarchical CAR action to limit their total traffic rate to 192 kbps. When flow 1 is not present, flow 2 can access the Internet at the maximum rate, 128 kbps. If both flows are present, each flow cannot exceed its own rate limit, and the total rate cannot exceed 192 kbps.
·     or: OR mode, in which a flow can pass through at the rate equal to the common CAR applied to it or a higher rate if the total traffic rate of all flows does not exceed the hierarchical CAR. For example, use common CAR actions to limit the rates of both video flow 1 and flow 2 to 128 kbps, and then use a hierarchical CAR action to limit their total traffic rate to 512 kbps. As long as the rate of flow 1 does not exceed 128 kbps, flow 2 can pass at a rate up to 384 kbps.
To use two rates for traffic policing, configure the car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the car command without the pir peak-information-rate option.
A QoS policy that uses the traffic behavior can be applied in either the inbound direction or outbound direction of an interface.
If you configure the car command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure a CAR action in traffic behavior database as follows:
·     Set the CIR to 200 kbps, CBS to 51200 bytes, and EBS to 0.
·     Transmit the conforming packets, and mark the excess packets with DSCP value 0 and transmit them.
[Sysname-behavior-database] car cir 200 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
Use display traffic behavior to display traffic behaviors.
user-defined: Specifies user-defined traffic behaviors.
behavior-name: Specifies a traffic behavior by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic behavior, this command displays all traffic behaviors.
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays traffic behaviors on all IRF member devices.
# Display all user-defined traffic behaviors.
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 128 (kbps), CBS 8192 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
    Behavior: 2 (ID 101)
      Accounting enable: Packet
      Filter enable: Permit
      Marking:
        Remark dot1p 4
      Redirecting:
        Redirect to the CPU
    Behavior: 3 (ID 102)
      -none-
Behavior
Name and contents of a traffic behavior.
Marking
Information about priority marking.
Remark dscp
Action of setting the DSCP value for packets.
Information about the CAR action.
CIR
CIR in kbps, which specifies the average traffic rate.
CBS
CBS in bytes, which specifies the amount of bursty traffic allowed at a time.
EBS
EBS in bytes, which specifies the amount of traffic exceeding the CBS when two token buckets are used.
Green action
Action to take on green packets.
Yellow action
Action to take on yellow packets.
Red action
Action to take on red packets.
Accounting enable
Traffic accounting action.
Filter enable
Traffic filtering action.
none
No other traffic behavior is configured.
filter
Use filter to configure a traffic filtering action in a traffic behavior.
Use undo filter to delete the action.
filter { deny | permit }
undo filter
No traffic filtering action is configured.
deny: Drops packets.
permit: Transmits packets.
# Configure a traffic filtering action as deny in traffic behavior database.
nest top-most
Use nest top-most to configure a VLAN tag adding action in a traffic behavior.
Use undo nest top-most to delete the action.
nest top-most vlan vlan-id
undo nest top-most
No VLAN tag adding action is configured.
vlan-id vlan-id: Specifies the VLAN ID to be added, in the range of 1 to 4094.
If a QoS policy contains a VLAN tag adding action, apply it only to the incoming traffic of an interface.
If the traffic behavior already contains a VLAN tag adding action, the new one overwrites the old one.
# Configure traffic behavior b1 to add VLAN tag 123.
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
redirect
Use redirect to configure a traffic redirecting action in a traffic behavior.
Use undo redirect to delete the action.
redirect { cpu | interface interface-type interface-number }
undo redirect { cpu | interface interface-type interface-number }
No traffic redirecting action is configured.
cpu: Redirects traffic to the CPU.
interface: Redirects traffic to an interface.
Redirecting traffic to the CPU and redirecting traffic to an interface are mutually exclusive with each other in the same traffic behavior. The most recently configured redirecting action takes effect.
# Configure redirecting traffic to GigabitEthernet 1/0/1 in traffic behavior database.
[Sysname-behavior-database] redirect interface GigabitEthernet 1/0/1
·     classifier behavior
·     qos policy
·     traffic behavior
Use remark customer-vlan-id to configure a CVLAN marking action in a traffic behavior.
Use undo remark customer-vlan-id to delete the action.
No CVLAN marking action is configured.
vlan-id: Specifies a CVLAN ID in the range of 1 to 4094.
# Configure traffic behavior b1 to mark matching packets with CVLAN 111.
[Sysname-behavior-b1] remark customer-vlan-id 111
remark dot1p
Use remark dot1p to configure an 802.1p priority marking action or an inner-to-outer tag priority copying action in a traffic behavior.
Use undo remark dot1p to delete the action.
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
No 802.1p priority marking action or inner-to-outer tag priority copying action is configured.
green: Specifies green packets.
red: Specifies red packets.
yellow: Specifies yellow packets.
dot1p-value: Specifies the 802.1p priority to be marked for packets, in the range of 0 to 7.
customer-dot1p-trust: Copies the 802.1p priority value in the inner VLAN tag to the outer VLAN tag after the QoS policy is applied to an interface.
The remark dot1p dot1p-value and remark dot1p customer-dot1p-trust commands are mutually exclusive. The most recent configuration of them takes effect.
The remark dot1p customer-dot1p-trust command does not take effect on single-tagged packets.
# Configure traffic behavior database to mark matching traffic with 802.1p priority 2.
[Sysname-behavior-database] remark dot1p 2
# Configure an inner-to-outer tag priority copying action in traffic behavior database.
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
Use remark drop-precedence to configure a drop priority marking action in a traffic behavior.
Use undo remark drop-precedence to delete the action.
remark drop-precedence drop-precedence-value
No drop priority marking action is configured.
drop-precedence-value: Specifies the drop priority to be marked for packets. This argument is in the range of 0 to 2.
The command applies only to incoming traffic.
# Configure traffic behavior database to mark matching traffic with drop priority 2.
[Sysname-behavior-database] remark drop-precedence 2
remark dscp
Use remark dscp to configure a DSCP marking action in a traffic behavior.
Use undo remark dscp to delete the action.
undo [ green | red | yellow ] remark dscp
No DSCP marking action is configured.
dscp-value: Specifies a DSCP value, which can be a number from 0 to 63 or a keyword in Table 5.
Table 5 DSCP keywords and values
Keyword
DSCP value (binary)
DSCP value (decimal)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
# Configure traffic behavior database to mark matching traffic with DSCP 6.
Use remark ip-precedence to configure an IP precedence marking action in a traffic behavior.
Use undo remark ip-precedence to delete the action.
remark ip-precedence ip-precedence-value
No IP precedence marking action is configured.
ip-precedence-value: Specifies the IP precedence value to be marked for packets, in the range of 0 to 7.
# Set the IP precedence to 6 for packets.
[Sysname-behavior-database] remark ip-precedence 6
Use remark local-precedence to configure a local precedence marking action in a traffic behavior.
Use undo remark local-precedence to delete the action.
remark [ green | red | yellow ] local-precedence local-precedence-value
undo remark [ green | red | yellow ] local-precedence
No local precedence marking action is configured.
local-precedence-value: Specifies the local precedence to be marked for packets, in the range of 0 to 7.
# Configure traffic behavior database to mark matching traffic with local precedence 2.
remark qos-local-id
Use remark qos-local-id to configure a local QoS ID marking action in a traffic behavior.
Use undo remark qos-local-id to delete the action.
remark qos-local-id local-id-value
No local QoS ID marking action is configured.
local-id-value: Specifies the local QoS ID to be marked for packets. The value range for this argument is 1 to 4095. The switch supports local QoS IDs in the range of 1 to 3999.
Marking local QoS IDs combines different traffic classes into one new class, which is indicated by a local QoS ID. You can configure a traffic behavior for this new class to implement two levels of actions on a traffic class.
Marking local QoS IDs applies only to incoming traffic.
# Configure the action of marking packets with local QoS ID 2.
[Sysname-behavior-database] remark qos-local-id 2
Use remark service-vlan-id to configure an SVLAN marking action in a traffic behavior.
Use undo remark service-vlan-id to delete the action.
No SVLAN marking action is configured.
vlan-id: Specifies an SVLAN ID in the range of 1 to 4094.
# Configure traffic behavior b1 to mark matching packets with SVLAN 222.
[Sysname-behavior-b1] remark service-vlan-id 222
traffic behavior
Use traffic behavior to create a traffic behavior and enter traffic behavior view.
Use undo traffic behavior to delete a traffic behavior.
No traffic behavior exists.
behavior-name: Specifies the name of the traffic behavior to be created, a case-sensitive string of 1 to 31 characters.
# Create a traffic behavior named behavior1.
[Sysname-behavior-behavior1]
QoS policy commands
classifier behavior
Use classifier behavior to associate a traffic behavior with a traffic class in a QoS policy.
Use undo classifier to remove a traffic class from the QoS policy.
classifier classifier-name behavior behavior-name [ insert-before before-classifier-name ]
No traffic behavior is associated with a traffic class.
QoS policy view
insert-before before-classifier-name: Inserts the new traffic class before an existing traffic class in the QoS policy. The before-classifier-name argument specifies an existing traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the insert-before before-classifier-name option, the new traffic class is placed at the end of the QoS policy.
A traffic class can be associated with only one traffic behavior in a QoS policy.
If the specified traffic class or traffic behavior does not exist, the system defines a null traffic class or traffic behavior.
You cannot change the position of an existing traffic class in a QoS policy.
# Associate traffic class database with traffic behavior test in QoS policy user1.
[Sysname] qos policy user1
# Associate traffic class database with traffic behavior test in QoS policy user1, and insert traffic class database before an existing traffic class named class-a.
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
qos policy
control-plane
Use control-plane to enter control plane view.
# Enter control plane view of IRF member device 1.
[Sysname] control-plane slot 1
[Sysname-cp-slot1]
display qos policy
Use display qos policy to display QoS policies.
user-defined: Specifies user-defined QoS policies.
policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a QoS policy, this command displays all user-defined QoS policies.
classifier classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays QoS policies on all IRF member devices.
# Display all user-defined QoS policies.
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
     Behavior: 2
      Marking:
        Remark dot1p 4
     Behavior: 3
      -none-
Use display qos policy control-plane to display the QoS policy applied to a control plane.
# Display the QoS policy applied to the control plane of IRF member device 1.
<Sysname> display qos policy control-plane slot 1
Control plane
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
        Red packets   : 0 (Packets) 0 (Bytes)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
Table 6 Command output
Direction
Inbound direction on the control plane.
Green packets
Statistics about green packets.
Red packets
Statistics about red packets.
For the description of other fields, see Table 1 and Table 4.
Use display qos policy control-plane pre-defined to display the predefined QoS policy applied to a control plane.
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays predefined QoS policies applied to control planes on all IRF member devices.
# Display the predefined QoS policy applied to the control plane of IRF member device 1.
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
  Protocol          Priority   Bandwidth (kbps)   Group
  IS-IS             33         512                critical
  VRRP              35         768                important
  OSPF Multicast    32         256                critical
  OSPF Unicast      32         256                critical
  IGMP              19         256                important
  OSPFv3 Unicast    32         256                critical
  OSPFv3 Multicast  32         256                critical
  VRRPv6            35         768                important
  ARP               8          256                normal
  DHCP Snooping     17         256                redirect
  DHCP              15         256                normal
  802.1x            9          128                important
  STP               37         256                critical
  LACP              34         64                 critical
  MVRP              11         256                critical
  BGP               27         256                critical
  ICMP              9          640                monitor
  IPOPTION          20         64                 normal
  BGPv6             26         256                critical
  IPOPTIONv6        13         64                 normal
  LLDP              25         128                important
  DLDP              24         64                 critical
  TELNET            10         1280               management
  SSH               10         1280               management
  HTTP              10         64                 management
  HTTPS             10         64                 management
  ARP Snooping      10         256                redirect
  ICMPv6            1          512                monitor
  DHCPv6            12         256                normal
Table 7 Command output
Contents of the predefined control plane QoS policy.
Protocol
System-defined control plane protocol.
Group
Control plane protocol group.
Use display qos policy global to display QoS policies applied globally.
inbound: Specifies the QoS policy applied globally in the inbound direction.
outbound: Specifies the QoS policy applied globally in the outbound direction.
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays QoS policies globally applied on the master device.
If you do not specify a direction, this command displays both inbound and outbound global QoS policies.
# Display the QoS policy applied globally in the inbound direction.
<Sysname> display qos policy global inbound
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dot1p 4
Table 8 Command output
Direction
Direction (inbound or outbound ) in which the QoS policy is applied.
Green packets
Red packets
Use display qos policy interface to display QoS policies applied to interfaces.
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ]
inbound: Specifies QoS policies applied in the inbound direction.
outbound: Specifies QoS policies applied in the outbound direction.
If you do not specify a direction, this command displays QoS policies applied in the inbound direction and QoS policies applied in the outbound direction.
# Display the QoS policy applied to the incoming traffic of GigabitEthernet 1/0/1.
<Sysname> display qos policy interface GigabitEthernet 1/0/1 inbound
Interface: GigabitEthernet 1/0/1
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) : If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action: pass
        Yellow action: pass
        Red action: discard
        Green packets: 0 (Packets)
        Red packets: 0 (Packets)
   Classifier: 2
     Operator: AND
     Rule(s) : If-match protocol ipv6
     Behavior: 2
      Accounting Enable:
        0 (Packets)
      Filter Enable: Permit
      Marking:
        Remark dot1p 1
Table 9 Command output
Direction
Direction in which the QoS policy is applied to the interface.
Green packets
Traffic statistics for green packets.
Red packets
Traffic statistics for red packets.
Use display qos vlan-policy to display QoS policies applied to VLANs.
name policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters.
vlan vlan-id: Specifies a VLAN by its ID.
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays QoS policies applied to VLANs on the master device.
# Display QoS policies applied to VLAN 2.
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: Outbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action: pass
        Yellow action: pass
        Red action: discard
        Green packets: 0(Packets)
        Red packets: 0(Packets)
   Classifier: 2
     Operator: AND
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dot1p 1
   Classifier: 3
     Operator: AND
     Rule(s) : -none-
     Behavior: 3
      -none-
Table 10 Command output
Direction
Direction in which the QoS policy is applied for the VLAN.
Green packets
Red packets
Use qos apply policy to apply a QoS policy.
Use undo qos apply policy to remove an applied QoS policy.
undo qos apply policy policy-name { inbound | outbound }
No QoS policy is applied to an interface or control plane.
Layer 2 Ethernet interface view, Layer 3 Ethernet interface view, control plane view
inbound: Applies the QoS policy to the incoming traffic of an interface or control plane.
outbound: Applies the QoS policy to the outgoing traffic of an interface.
# Apply QoS policy USER1 to the outgoing traffic of GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos apply policy USER1 outbound
# Apply QoS policy aaa to the incoming traffic of the control plane of IRF member device 3.
[Sysname] control-plane slot 3
[Sysname-cp-slot3] qos apply policy aaa inbound
Use qos apply policy to apply a QoS policy to a user profile.
No QoS policy is applied to a user profile.
User profile view
inbound: Applies the QoS policy to the incoming traffic (traffic sent by online users) of a user profile.
outbound: Applies the QoS policy to the outgoing traffic (traffic received by online users) of a user profile.
Deleting a user profile also removes QoS policies applied to it.
The QoS policy applied to a user profile takes effect only after the QoS policy is successfully issued to the driver.
# Apply QoS policy test to the outgoing traffic of user profile user.
[Sysname] user-profile user
[Sysname-user-profile-user] qos apply policy test outbound
Use qos apply policy global to apply a QoS policy globally.
Use undo qos apply policy global to remove a globally applied QoS policy.
undo qos apply policy policy-name global { inbound | outbound }
No QoS policy is applied globally.
inbound: Applies the QoS policy in the inbound direction.
outbound: Applies the QoS policy in the outbound direction.
A QoS policy globally applied takes effect on all incoming or outgoing traffic, depending on the direction in which the QoS policy is applied.
# Apply QoS policy user1 globally in the inbound direction.
[Sysname] qos apply policy user1 global inbound
qos policy
Use qos policy to create a QoS policy and enter QoS policy view.
Use undo qos policy to delete a QoS policy.
qos policy policy-name
undo qos policy policy-name
No QoS policy exists.
policy-name: Specifies the name of the QoS policy to be created, a case-sensitive string of 1 to 31 characters.
To delete a QoS policy that has been applied to an object, you must first remove it from the object.
# Create a QoS policy named user1.
·     qos apply policy
·     qos apply policy global
·     qos vlan-policy
qos vlan-policy
Use qos vlan-policy to apply a QoS policy to the specified VLANs.
Use undo qos vlan-policy to remove a QoS policy from the specified VLANs.
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
No QoS policy is applied to a VLAN.
vlan-id-list: Specifies a space-separated list of up to eight VLAN IDs or a VLAN ID range in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
inbound: Applies the QoS policy to incoming packets.
outbound: Applies the QoS policy to outgoing packets.
# Apply QoS policy test to the incoming traffic of VLAN 200, VLAN 300, VLAN 400, and VLAN 500.
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
Use reset qos policy control-plane to clear statistics for the QoS policy applied to a control plane.
# Clear statistics for the QoS policy applied to the control plane of IRF member device 3.
<Sysname> reset qos policy control-plane slot 3
Use reset qos policy global to clear statistics for QoS policies applied globally.
inbound: Specifies the QoS policy applied in the inbound direction.
outbound: Specifies the QoS policy applied in the outbound direction.
If you do not specify a direction, this command clears statistics for the QoS policy applied in the inbound direction and the QoS policy applied in the outbound direction.
# Clear statistics for the QoS policy applied globally in the inbound direction.
<Sysname> reset qos policy global inbound
Use reset qos vlan-policy to clear statistics for QoS policies applied to VLANs.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
If you do not specify a direction, this command clears statistics for QoS policies applied in the inbound direction and QoS policies applied in the outbound direction.
# Clear statistics for QoS policies applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
Use display qos map-table to display the configuration of priority maps.
display qos map-table [ dot1p-dp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp ]
The switch provides the following types of priority maps.
Table 11 Priority maps
Priority mapping
dot1p-dp
802.1p-drop priority map.
dot1p-lp
802.1p-local priority map.
dscp-dot1p
DSCP-802.1p priority map.
dscp-dp
DSCP-drop priority map.
dscp-dscp
DSCP-DSCP priority map.
If you do not specify a priority map, this command displays the configuration of all priority maps.
# Display the configuration of the 802.1p-local priority map.
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
Table 12 Command output
MAP-TABLE NAME
Name of the priority map.
TYPE
Type of the priority map.
IMPORT
Input values of the priority map.
EXPORT
Output values of the priority map.
import
Use import to configure mappings for a priority map.
Use undo import to restore the specified or all mappings to the default for a priority map.
The default priority maps are used. For more information, see ACL and QoS Configuration Guide.
Priority map view
import-value-list: Specifies a list of input values.
export-value: Specifies the output value.
all: Restores all mappings in the priority map to the default.
# Configure the 802.1p-local priority map to map 802.1p priority values 4 and 5 to local precedence 1.
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
qos map-table
Use qos map-table to enter the specified priority map view.
qos map-table { dot1p-dp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp }
For the description of the keywords, see Table 11.
# Enter the 802.1p-local priority map view.
·     display qos map-table
·     import
qos priority
Use qos priority to change the port priority of an interface.
Use undo qos priority to restore the default.
qos priority priority-value
undo qos priority
The port priority is 0.
priority-value: Specifies the port priority value in the range of 0 to 7.
# Set the port priority to 2 for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet 1/0/1] qos priority 2
Use display qos trust interface to display priority trust mode and port priority information on an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays priority trust mode and port priority information of all interfaces.
# Display the priority trust mode and port priority information of GigabitEthernet 1/0/1.
<Sysname> display qos trust interface GigabitEthernet 1/0/1
 Port priority information
  Port priority: 0
  Port priority trust type: none
Table 13 Command output
Interface type and interface number.
Port priority
Port priority set for the interface.
Priority trust mode on the interface: dot1p, dscp, or none. If the trust mode is none, the port priority is used for priority mapping.
qos trust
Use qos trust to configure the priority trust mode for an interface.
Use undo qos trust to restore the default.
qos trust { dot1p | dscp }
undo qos trust
An interface does not trust any packet priority.
dot1p: Uses the 802.1p priority in incoming packets for priority mapping.
dscp: Uses the DSCP value in incoming packets for priority mapping.
# Set the trusted packet priority type to 802.1p priority on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos trust dot1p
GTS commands
Use display qos gts interface to display generic traffic shaping (GTS) configuration of interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the GTS configuration of all interfaces.
# Display the GTS configuration of all interfaces.
 Rule: If-match queue 1
 Rule: If-match queue 2
  CIR 256 (kbps), CBS 16384 (Bytes)
Table 14 Command output
Rule
Match criteria.
CIR
CBS
qos gts
Use qos gts to set GTS parameters for a queue on an interface.
Use undo qos gts to delete the GTS configuration of a queue on an interface.
undo qos gts queue queue-id
No GTS parameters are set for a queue on an interface.
queue queue-id: Specifies a queue by its ID in the range of 0 to 7.
cir committed-information-rate: Specifies the CIR in kbps. The value range for the committed-information-rate argument is 8 to 1048576 for GE interfaces, 8 to 10485760 for 10-GE interfaces, and 8 to 20971520 for 20-GE interfaces. The values must be integral multiples of 8.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for the committed-burst-size argument is 512 and 16777216 in multiples of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. If the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512.
# Shape the packets in queue 1 on GigabitEthernet 1/0/1. The GTS parameters are as follows: CIR is 6400 kbps and CBS is 51200 bytes.
[Sysname-GigabitEthernet1/0/1] qos gts queue 1 cir 6400 cbs 51200
Rate limit commands
Use display qos lr interface to display the rate limit configuration of interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the rate limit configuration of all interfaces.
# Display the rate limit configuration of all interfaces.
 Direction: Outbound
  CIR 12800 (kbps), CBS 800256 (Bytes)
 Direction: Outbound
  CIR 25600 (kbps), CBS 1600000 (Bytes)
Table 15 Command output
Direction
Direction to which the rate limit configuration is applied: inbound or outbound.
CIR
CBS
qos lr
Use qos lr to configure rate limiting on an interface.
Use undo qos lr to delete the rate limiting configuration on an interface.
undo qos lr { inbound | outbound }
Rate limiting is not configured on an interface.
inbound: Limits the rate of incoming packets on the interface.
outbound: Limits the rate of outgoing packets on the interface.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for the committed-burst-size argument is 512 and 134217728 in multiples of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. If the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512.
# Limit the rate of outgoing packets on GigabitEthernet 1/0/1, with CIR 25600 kbps and CBS 512000 bytes.
[Sysname-GigabitEthernet1/0/1] qos lr outbound cir 25600 cbs 512000
SP commands
Use display qos queue sp interface to display the SP queuing configuration of interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the SP queuing configuration of all interfaces.
# Display the SP queuing configuration of GigabitEthernet 1/0/1.
<Sysname> display qos queue sp interface GigabitEthernet 1/0/1
 Output queue: Strict Priority queuing
Table 16 Command output
Output queue
Type of the current output queue.
qos sp
Use qos sp to enable SP queuing on an interface.
Use undo qos sp to restore the default.
qos sp
undo qos sp
An interface uses the WRR queuing algorithm.
# Enable SP queuing on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos sp
WRR commands
Use display qos queue wrr interface to display the WRR queuing configuration of interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRR queuing configuration of all interfaces.
# Display the WRR queuing configuration of GigabitEthernet 1/0/1.
<Sysname> display qos queue wrr interface GigabitEthernet 1/0/1
 Output queue: Weighted Round Robin queuing
 Queue ID        Group           Byte-count
 be              1               1
 af1             1               2
 af2             1               3
 af3             1               4
 af4             1               5
 ef              1               9
 cs6             1               13
 cs7             1               15
Table 17 Command output
Output queue
Queue ID
ID of a queue.
Group
Number of the group a queue is assigned to. By default, all queues belong to group 1.
Weight
Packet-based queue scheduling weight of a queue. N/A is displayed for a queue that uses the SP queue scheduling algorithm.
qos wrr
Use qos wrr to enable WRR queuing and specify the weight type for an interface.
Use undo qos wrr to disable WRR queuing and restore the default queue scheduling algorithm for an interface.
undo qos wrr { byte-count | weight }
An interface uses the byte-count WRR queuing algorithm, and queues 0 through 7 have weights of 1, 2, 3, 4, 5, 9, 13, and 15, respectively.
byte-count: Allocates bandwidth to queues in terms of bytes.
weight: Allocates bandwidth to queues in terms of packets.
You must use the qos wrr command to enable WRR queuing before you can configure WRR queuing parameters for a queue on an interface.
# Enable weight-based WRR queuing on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wrr weight
# Enable byte-count WRR queuing on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wrr byte-count
Use qos wrr { byte-count | weight } to configure the WRR queuing parameters for a queue on an interface.
Use undo qos wrr to restore the default WRR queuing parameters of a queue on an interface.
qos wrr queue-id group 1 { byte-count | weight } schedule-value
undo qos wrr queue-id
An interface uses the byte-count WRR queuing algorithm, and queues 0 through 7 are in WRR group, with their weights of 1, 2, 3, 4, 5, 9, 13, and 15, respectively.
queue-id: Specifies a queue by its ID.
group 1: Specifies WRR group 1. Only one WRR group is supported.
schedule-value: Specifies a scheduling weight, in the range of 1 to 15.
The queue-id argument can be either a number or a keyword. Table 18 shows the number-keyword map.
Table 18 The number-keyword map for the queue-id argument
Number
Keyword
0
be
1
af1
2
af2
3
af3
4
af4
5
ef
6
cs6
7
cs7
# Enable byte-count WRR queuing on GigabitEthernet 1/0/1, and assign queues 0 and 1 (with the scheduling weights 10 and 5, respectively) to WRR group 1.
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group 1 byte-count 10
[Sysname-GigabitEthernet1/0/1] qos wrr 1 group 1 byte-count 5
·     display qos queue wrr interface
·     qos wrr
qos wrr group sp
Use qos wrr group sp to assign a queue to the SP group.
Use undo qos wrr group sp to restore the default.
qos wrr queue-id group sp
An interface uses the byte-count WRR queuing algorithm, and all the queues are in WRR group 1.
queue-id: Specifies a queue by its ID. The value is an integer in the range of 0 to 7 or a keyword listed in Table 18.
sp: Assigns a queue to the SP group, which uses the SP queue scheduling algorithm.
You must use the qos wrr command to enable WRR queuing before you can configure this command on an interface.
Queues in the SP group are scheduled with SP. The SP group has higher scheduling priority than the WRR group.
# Enable packet-based WRR queuing on GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group sp
·     qos wrr
WFQ commands
Use display qos queue wfq interface to display the WFQ configuration of interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WFQ configuration of all interfaces.
# Display the WFQ configuration of GigabitEthernet 1/0/1.
<Sysname> display qos queue wfq interface GigabitEthernet 1/0/1
 Output queue: Hardware Weighted Fair Queuing
 Queue ID        Group           Byte-count      Min-Bandwidth
 be              1               1               64
 af1             1               1               64
 af2             1               1               64
 af3             1               1               64
 af4             1               1               64
 ef              1               1               64
 cs6             1               1               64
 cs7             1               1               64
Table 19 Command output
Output queue
Queue ID
ID of a queue.
Group
Number of the WFQ group that holds the queue. This number is fixed at 1.
Byte-count
Byte-count scheduling weight of the queue.
Min-Bandwidth
Minimum guaranteed bandwidth.
qos bandwidth queue
Use qos bandwidth queue to set the minimum guaranteed bandwidth for a queue on an interface.
Use undo qos bandwidth queue to restore the default.
undo qos bandwidth queue queue-id
The minimum guaranteed bandwidth is 64 kbps.
min bandwidth-value: Specifies the minimum guaranteed bandwidth in kbps. The value range for the bandwidth-value argument is 8 to 1000000 for GE interfaces, 8 to 10000000 for 10-GE interfaces, and 8 to 20000000 for 20-GE interfaces.
You must use the qos wfq command to enable WFQ before you can configure this command on an interface.
# Set the minimum guaranteed bandwidth to 100 kbps for queue 0 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wfq weight
[Sysname-GigabitEthernet1/0/1] qos bandwidth queue 0 min 100
qos wfq
qos wfq
Use qos wfq to enable WFQ and specify the WFQ weight type on an interface.
Use undo qos wfq to disable WFQ and restore the default queuing algorithm on an interface.
undo qos wfq { byte-count | weight }
An interface uses the byte-count WRR queuing algorithm, and all the queues are in the WRR group.
You must use the qos wfq command to enable WFQ before you can configure WFQ queuing parameters for a queue on an interface.
# Enable weight-based WFQ on GigabitEthernet 1/0/1.
# Enable byte-count WFQ on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wfq byte-count
Use qos wfq { byte-count | weight } to assign a queue to a WFQ group with a certain scheduling weight.
Use undo qos wfq to restore the default.
qos wfq queue-id group 1 { byte-count | weight } schedule-value
undo qos wfq queue-id
When WFQ queuing is used on an interface, all the queues are in WFQ group and have a weight of 1.
schedule-value: Specifies a scheduling weight for the specified queue, in the range of 1 to 15.
You must use the qos wfq command to enable WFQ before you configure this command.
# Enable byte-count WFQ queuing on GigabitEthernet 1/0/1, and assign queues 0 and 1 (with the scheduling weights 10 and 5, respectively) to WFQ group 1.
[Sysname-GigabitEthernet1/0/1] qos wfq 0 group 1 byte-count 10
[Sysname-GigabitEthernet1/0/1] qos wfq 1 group 1 byte-count 5
·     display qos queue wfq interface
·     qos bandwidth queue
·     qos wfq
qos wfq group sp
Use qos wfq group sp to assign a queue to the SP group.
Use undo qos wfq group sp to restore the default.
qos wfq queue-id group sp
When WFQ queuing is used on an interface, all queues are in WFQ group 1.
With this SP+WFQ queuing method, the system schedules traffic as follows:
1.     The system schedules the traffic conforming to the minimum guaranteed bandwidth in each WFQ group and schedules the traffic of the two WFQ groups in the ratio of 1:1 in a round robin manner.
2.     The system uses SP to schedule queues in the SP group.
3.     If there is remaining bandwidth, the system schedules the traffic of queues in each WFQ group based on their weights.
# Enable weight-based WFQ on GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-GigabitEthernet1/0/1] qos wfq 0 group sp
·     qos wfq
bandwidth
Use bandwidth to set the minimum guaranteed bandwidth for a WFQ queue.
undo bandwidth queue queue-id
The minimum guaranteed bandwidth of a WFQ queue is 64 kbps.
Queue scheduling profile view
queue-id: Specifies a queue by its ID. The value can be an integer in the range of 0 to 7 or a keyword listed in Table 18.
min bandwidth-value: Specifies the minimum guaranteed bandwidth in the range of 8 to 100000000 kbps.
You must configure a queue as a WFQ queue before you can set the minimum guaranteed bandwidth for the queue.
The minimum guaranteed bandwidth is the minimum bandwidth guaranteed for a WFQ queue when the interface is congested.
# Set the minimum guaranteed bandwidth to 100 kbps for queue 0 in queue scheduling profile myprofile.
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 0 wfq group 1 weight 1
[Sysname-qmprofile-myprofile] bandwidth queue 0 min 100
·     display qos qmprofile interface
·     qos qmprofile
·     queue
Use display qos qmprofile configuration to display the configuration of queue scheduling profiles.
profile-name: Specifies a queue scheduling profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a queue scheduling profile, this command displays the configuration of all queue scheduling profiles.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays the configuration of queue scheduling profiles on the master device.
# Display the configuration of queue scheduling profile myprofile.
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
Queue ID    Type    Group    Schedule-unit    Schedule-value    Bandwidth
 be          WFQ     1        weight           1                  64
 af1         WFQ     1        weight           1                  64
 af2         WFQ     1        weight           1                  1000
 af3         SP      N/A      N/A              N/A                N/A
 af4         SP      N/A      N/A              N/A                N/A
 ef          SP      N/A      N/A              N/A                N/A
 cs6         SP      N/A      N/A              N/A                N/A
 cs7         SP      N/A      N/A              N/A                N/A
Table 20 Command output
Queue scheduling profile name.
Queue scheduling type:
·     SP.
·     WRR.
·     WFQ.
Group
Priority group to which the queue belongs.
N/A indicates that this field is ignored.
Schedule unit
Scheduling unit:
·     weight or byte-count for WRR and WFQ.
·     N/A for SP.
Schedule value
This field indicates:
·     Number of packets for the weight scheduling unit.
·     Number of bytes for the byte-count scheduling unit.
Bandwidth
Minimum guaranteed bandwidth for the queue.
Use display qos qmprofile interface to display queue scheduling profiles applied to interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queue scheduling profiles applied to all interfaces.
# Display the queue scheduling profile applied to GigabitEthernet 1/0/1.
<Sysname> display qos qmprofile interface GigabitEthernet 1/0/1
Table 21 Command output
Interface name.
Name of the queue scheduling profile applied to the interface.
qos apply qmprofile
Use qos apply qmprofile to apply a queue scheduling profile to the outbound direction of an interface.
Use undo qos apply qmprofile to remove an applied queue scheduling profile from an interface.
No queue scheduling profile is applied to an interface.
You can apply only one queue scheduling profile to an interface.
# Apply queue scheduling profile myprofile to the outbound direction of GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos apply qmprofile myprofile
qos qmprofile
Use qos qmprofile to create a queue scheduling profile and enter queue scheduling profile view.
Use undo qos qmprofile to delete a user-defined queue scheduling profile.
qos qmprofile profile-name
undo qos qmprofile profile-name
No user-defined queue scheduling profile exists.
profile-name: Specifies the name of the queue scheduling profile, a case-sensitive string of 1 to 31 characters.
To delete a queue scheduling profile already applied to an interface, first remove it from the interface.
# Create a queue scheduling profile named myprofile and enter queue scheduling profile view.
·     queue
queue
Use queue to configure scheduling parameters for a queue.
Use undo queue to restore the default.
queue queue-id { sp | wfq group 1 { byte-count | weight } schedule-value | wrr group 1 { byte-count | weight } schedule-value }
undo queue queue-id
A queue uses SP queuing.
sp: Enables SP for the queue.
wfq: Enables WFQ for the queue.
wrr: Enables WRR for the queue.
schedule-value: Specifies the number of bytes or packets sent each time, in the range of 1 to 15.
# Create a queue scheduling profile named myprofile, and configure queue 0 to use SP.
[Sysname-qmprofile-myprofile] queue 0 sp
# Create a queue scheduling profile named myprofile. Configure queue 1 to meet the following requirements:
·     The WRR queuing is used.
·     The number of packets sent each time is 10.
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 10
·     qos qmprofile
Queue-based accounting commands
display qos queue-statistics interface outbound
Use display qos queue-statistics interface outbound to display queue-based outgoing traffic statistics for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the outgoing traffic statistics for all interfaces.
# Display queue-based outgoing traffic statistics for GigabitEthernet 1/0/1.
<Sysname> display qos queue-statistics interface GigabitEthernet 1/0/1 outbound
 Direction: outbound
 Forwarded: 1087 packets, 98466 bytes
 Dropped: 0 packets, 0 bytes
 Queue 0
  Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
  Current queue length: 0 packets
 Queue 1
 Queue 2
 Queue 3
 Queue 4
 Queue 5
 Queue 6
 Queue 7
  Forwarded: 1087 packets, 98466 bytes, 0 pps, 0 bps
Table 22 Command output
Interface for which queue-based traffic statistics are displayed.
Direction
Direction of traffic for which statistics are collected.
Forwarded
Forwarded traffic statistics for the interface in packets, bytes, pps, and bps.
Dropped
Dropped traffic statistics for the interface in packets and bytes.
Queue 7
Statistics for a queue:
·     Forwarded traffic in packets, bytes, pps, and bps.
·     Dropped traffic in packets and bytes.
·     Current number of packets in the queue.
Congestion avoidance commands
WRED commands
display qos wred interface
Use display qos wred interface to display the WRED configuration for an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRED configuration and statistics for all interfaces.
# Display the WRED configuration for all interfaces.
<Sysname> display qos wred interface
 Current WRED configuration:
 Applied WRED table name: 1
Table 23 Command output
display qos wred table
Use display qos wred table to display the configuration of WRED tables.
name table-name: Specifies a WRED table by its name. If you do not specify a WRED table, this command displays the configuration of all WRED tables.
slot slot-number: Specifies an IRF member device by its member ID (slot-number). If you do not specify an IRF member device, this command displays the configuration of WRED tables on the master device.
# Display the configuration of WRED table 1.
<Sysname> display qos wred table name 1
Table name: 1
Table type: Queue based WRED
QID   gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent  ECN
0     100   1000  10     100   1000  10     100   1000  10     9         N
1     100   1000  10     100   1000  10     100   1000  10     9         N
2     100   1000  10     100   1000  10     100   1000  10     9         N
3     100   1000  10     100   1000  10     100   1000  10     9         N
4     100   1000  10     100   1000  10     100   1000  10     9         N
5     100   1000  10     100   1000  10     100   1000  10     9         N
6     100   1000  10     100   1000  10     100   1000  10     9         N
7     100   1000  10     100   1000  10     100   1000  10     9         N
Table 24 Command output
QID
Queue ID.
gmin
Lower limit for green packets.
gmax
Upper limit for green packets.
gprob
Drop probability for green packets.
ymin
Lower limit for yellow packets.
ymax
Upper limit for yellow packets.
yprob
Drop probability for yellow packets.
rmin
Lower limit for red packets.
rmax
Upper limit for red packets.
rprob
Drop probability for red packets.
exponent
Exponent for average queue length calculation.
ECN
Indicates whether ECN is enabled for the queue:
·     Y—Enabled.
·     N—Disabled.
qos wred apply
Use qos wred apply to apply a WRED table to an interface.
Use undo qos wred apply to restore the default.
qos wred apply [ table-name ]
undo qos wred apply
No WRED table is applied to an interface, and the tail drop mode is used on an interface.
If you do not specify a WRED table, this command applies the default WRED table to the interface.
# Apply queue-based WRED table table1 to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wred apply table1
·     display qos wred interface
·     display qos wred table
·     qos wred table
qos wred table
Use qos wred table to create a WRED table and enter WRED table view.
Use undo qos wred table to delete a WRED table.
undo qos wred queue table table-name
No WRED table exists.
queue: Creates a queue-based WRED table, which drops packets based on the queue when congestion occurs.
table table-name: Specifies a name for the WRED table.
You cannot delete a WRED table in use. To delete it, first remove it from the specified interface.
# Create a queue-based WRED table named queue-table1.
[Sysname-wred-table-queue-table1]
queue
Use queue to configure the drop-related parameters for a queue in the queue-based WRED table.
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-id | all }
After a WRED table is created, the lower limit is 100, the upper limit is 1000, and the drop probability is 10%.
WRED table view
drop-level drop-level: Specifies a drop level. This argument is a consideration for dropping packets. The value 0 corresponds to green packets, the value 1 corresponds to yellow packets, and the value 2 corresponds to red packets. If you do not specify a drop level, the subsequent configuration takes effect on the packets in the queue regardless of the drop level.
low limit low-limit: Specifies the lower limit for the average queue length, in the range of 0 to 16000.
high-limit high-limit: Specifies the upper limit for the average queue length. The high-limit argument is in the range of 0 to 16000 and must be greater than the low-limit argument.
discard-probability discard-prob: Specifies the drop probability in percentage, in the range of 0 to 100.
When the average queue size is smaller than the lower limit, no packet is dropped. When the average queue size is between the lower limit and the upper limit, packets are dropped based on the user-configured drop probability. When the average queue size exceeds the upper limit, subsequent packets are dropped.
# In queue-based WRED table queue-table1, configure drop-related parameters for packets in queue 1 as follows:
·     The drop level is 1.
·     The lower limit for the average queue length is 10.
·     The upper limit for the average queue length is 20.
·     The drop probability is 30%.
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
·     qos wred table
queue ecn
Use queue ecn to enable ECN for a queue.
Use undo queue ecn to restore the default.
queue queue-id ecn
undo queue queue-id ecn
ECN is not enabled on any queue.
WRED table view
When both the receiver and sender support ECN, the device can notify the peer end of the congestion status by identifying and setting the ECN flag. ECN avoids deteriorating congestion.
# In WRED table queue-table1, enable ECN for queue 1.
[Sysname-wred-table-queue-table1] queue 1 ecn
·     qos wred table
queue weighting-constant
Use queue weighting-constant to specify an exponent for average queue length calculation for a queue.
Use undo queue weighting-constant to restore the default.
queue queue-id weighting-constant exponent
undo queue queue-id weighting-constant
The exponent for average queue length calculation is 9.
WRED table view
weighting-constant exponent: Specifies the WRED exponent for average queue length calculation, in the range of 0 to 15.
The bigger the exponent is, the less sensitive the average queue size is to real-time queue size changes. The average queue size is calculated using the formula: average queue size = previous average queue size × (1-2-n) + current queue size × 2-n, where n can be set with the qos wred weighting-constant command.
# In WRED table queue-table1, set the exponent for average queue length calculation to 12 for queue 1.
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
·     qos wred table
Global CAR commands
car name
Use car name to use an aggregate CAR action in a traffic behavior.
Use car name hierarchy-car to use a hierarchical CAR action in a traffic behavior.
Use undo car to remove an aggregate or hierarchical CAR action from a traffic behavior.
car name agg-car-name [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
undo car
No aggregate or hierarchical CAR action exists in a traffic behavior.
Traffic behavior view
agg-car-name: Specifies the name of the aggregate CAR action to be used. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
hierarchy-car-name: Specifies the name of the hierarchical CAR action to be used. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
mode: Specifies a collaborating mode between the hierarchical CAR action and the aggregate CAR action, which can be AND (the default) or OR. If you do not specify a collaborating mode, the AND mode applies.
·     and: AND mode, in which the traffic rate of a flow is limited by both the aggregate CAR applied to it and the total traffic rate defined with hierarchical CAR. For example, use aggregate CAR actions to limit the rates of both Internet access flow 1 and flow 2 to 128 kbps, and use a hierarchical CAR action to limit their total traffic rate to 192 kbps. When flow 1 is not present, flow 2 can access the Internet at the maximum rate, 128 kbps. If both flows are present, each flow cannot exceed its own rate limit, and the total rate cannot exceed 192 kbps.
·     or: OR mode, in which a flow can pass through at the rate equal to the aggregate CAR applied to it or a higher rate if the total traffic rate of all flows does not exceed the hierarchical CAR. For example, use aggregate CAR actions to limit the rates of both video flow 1 and flow 2 to 128 kbps, and then use a hierarchical CAR action to limit their total traffic rate to 512 kbps. As long as the rate of flow 1 does not exceed 128 kbps, flow 2 can pass at a rate as high as 384 kbps.
# Use aggregate CAR action aggcar-1 in traffic behavior be1.
# Configure traffic behavior be1 to use aggregate CAR action aggcar-1 and hierarchical CAR action hcar, with the collaborating mode as or.
[Sysname-behavior-be1] car name aggcar-1 hierarchy-car hcar mode or
·     display qos car name
·     display traffic behavior user-defined
Use display qos car name to display the configuration and statistics for a global CAR action.
car-name: Specifies a global CAR action by its name, a case-sensitive string of 1 to 31 characters. The name must start with a letter. If you do not specify a global CAR action, this command displays the configuration and statistics for all global CAR actions, including aggregate CAR actions and hierarchical CAR actions.
# Display the configuration and statistics for all global CAR actions.
<Sysname> display qos car name
  Mode: aggregative
   CIR 128 (kbps), CBS 2048 (Bytes), PIR 256 (kbps), EBS 16384 (Bytes)
   Green action  : pass
  Slot 0:
   Green packets : 0 (Packets), 0 (Bytes)
   Yellow packets: 0 (Packets), 0 (Bytes)
   Red packets   : 0 (Packets), 0 (Bytes)
  Slot 1:
  Slot 2:
   Apply failed
  Mode: hierarchy
   CIR 256 (kbps), CBS: 4096 (Bytes), PIR: 512 (kbps), EBS 32256 (Bytes)
   Green action  : pass
  Slot 0:
  Slot 1:
   Apply failed
  Slot 2:
Table 25 Command output
Name
Name of the global CAR action.
Mode
Type of the CAR action:
·     aggregative—Aggregate CAR.
·     hierarchy—Hierarchical CAR.
CIR  CBS  PIR  EBS
Parameters for the CAR action.
Green action
Action to take on green packets:
·     discard—Drops the packets.
·     pass—Permits the packets to pass through.
Yellow action
Action to take on yellow packets:
Red action
Action to take on red packets:
Green packet
Yellow packet
Statistics about yellow packets.
Red packet
qos car
Use qos car aggregative to configure an aggregate CAR action.
Use qos car hierarchy to configure a hierarchical CAR action.
Use undo qos car to delete an aggregate CAR action or a hierarchical CAR action.
qos car car-name { aggregative | hierarchy } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name { aggregative | hierarchy } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
No aggregate or hierarchical CAR action is configured.
car-name: Specifies the name of the global CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
aggregative: Specifies the global CAR action as an aggregate CAR action.
hierarchy: Specifies the global CAR action as a hierarchical CAR action.
cir committed-information-rate: Specifies the CIR in kbps, which specifies an average traffic rate. The value range for committed-information-rate is 8 to 160000000, and the values must be integral multiples of 8.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-information-rate is 512 to 256000000, and the values must be integral multiples of 512. The default CBS is 62.5 x committed-information-rate. If the default CBS is not a multiple of 512, the system rounds it up to the nearest multiple of 512. The default CBS cannot be greater than 256000000.
ebs excess-burst-size: Specifies the EBS in bytes. The default EBS is 0. The value range is 0 to 256000000, and the values must be integral multiples of 512.
pir peak-information-rate: Specifies the PIR in kbps. The value range is 8 to 160000000, and the values must be integral multiples of 8.
green action: Specifies the action to take on packets that conform to CIR. The default setting is pass. Hierarchical CAR does not support this option.
red action: Specifies the action to take on the packet that conforms to neither CIR nor PIR. The default setting is discard. Hierarchical CAR does not support this option.
yellow action: Specifies the action to take on packets that conform to PIR but not to CIR. The default setting is pass. Hierarchical CAR does not support this option.
action: Action to take on packets:
·     discard: Drops the packet.
·     pass: Permits the packet to pass through.
·     remark-dot1p-pass new-cos: Remarks the packet with a new 802.1p priority value and permits the packet to pass through. The value range for new-cos is 0 to 7.
·     remark-dscp-pass new-dscp: Remarks the packet with a new DSCP value and permits the packet to pass through. The value range for new-dscp is 0 to 63.
·     remark-lp-pass new-precedence: Remarks the packet with a new IP precedence and permits the packet to pass through. The value range for new-precedence is 0 to 7.
To use two rates for global CAR, configure the qos car command with the pir peak-information-rate option. To use one rate for global CAR, configure the qos car command without the pir peak-information-rate option.
An aggregate CAR action takes effect only after it is applied to an interface or used in a QoS policy.
A hierarchical CAR action takes effect only after it is used in a QoS policy.
# Configure aggregate CAR action aggcar-1, where CIR is 256, CBS is 2048, and red packets are dropped.
[Sysname] qos car aggcar-1 aggregative cir 256 cbs 2048 red discard
# Configure hierarchical CAR action h-car, where CIR is 512 and CBS is 102400.
[Sysname] qos car h-car hierarchy cir 512 cbs 102400
reset qos car name
Use reset qos car name to clear statistics for global CAR actions.
car-name: Specifies a global CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify a global CAR action, this command clears the statistics for all global CAR actions, including aggregate CAR actions and hierarchical CAR actions.
# Clear statistics for global CAR action aggcar-1.
<Sysname> reset qos car name aggcar-1
