07-ACL and QoS Command Reference
HomeSupportSwitchesS5130 SeriesReference GuidesCommand ReferencesH3C S5130-HI Command References-R1118P02[R1122]-6W10207-ACL and QoS Command Reference
01-ACL commands
01-ACL commands 164.02 KB
ACL commands
acl
Use acl to create an ACL, and enter its view. If the ACL has been created, you directly enter its view.
Use undo acl to delete the specified or all ACLs.
acl [ ipv6 ] number acl-number [ name acl-name ] [ match-order { auto | config } ]
undo acl [ ipv6 ] { all | name acl-name | number acl-number }
No ACL exists.
ipv6: Specifies IPv6 ACLs.
number acl-number: Specifies the number of an ACL. The following are available value ranges:
·     2000 to 2999 for basic ACLs.
·     3000 to 3999 for advanced ACLs.
·     4000 to 4999 for Ethernet frame header ACLs. You cannot create an Ethernet frame header ACL if the ipv6 keyword is specified.
name acl-name: Assigns a name to the ACL for easy identification. The acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
match-order: Sets the order in which ACL rules are compared against packets.
·     auto: Compares ACL rules in depth-first order. The depth-first order varies by ACL category. For more information, see ACL and QoS Configuration Guide.
·     config: Compares ACL rules in ascending order of rule ID. The rule with a smaller ID has higher priority. If you do not specify a match order, the config-order applies by default.
all: Specifies all ACLs.
·     If the ipv6 keyword is not specified, all ACLs refer to all IPv4 basic, IPv4 advanced, and Ethernet frame header ACLs.
·     If the ipv6 keyword is specified, all ACLs refer to all IPv6 basic and IPv6 advanced ACLs.
You can assign a name to an ACL only when you create it. After an ACL is created with a name, you cannot rename it or remove its name.
You can change the match order only for ACLs that do not contain any rules.
# Create IPv4 basic ACL 2000, and enter its view.
[Sysname] acl number 2000
[Sysname-acl-basic-2000]
# Create IPv4 basic ACL 2001 with the name flow, and enter its view.
[Sysname] acl number 2001 name flow
[Sysname-acl-basic-2001-flow]
display acl
acl copy
Use acl copy to create an ACL by copying an ACL that already exists.
acl [ ipv6 ] copy { source-acl-number | name source-acl-name } to { dest-acl-number | name dest-acl-name }
source-acl-number: Specifies an existing source ACL by its number. The following are available value ranges:
·     4000 to 4999 for Ethernet frame header ACLs. You cannot specify an Ethernet frame header ACL if the ipv6 keyword is specified.
name source-acl-name: Specifies an existing source ACL by its name. The source-acl-name argument is a case-insensitive string of 1 to 63 characters.
dest-acl-number: Assigns a unique number to the ACL you are creating. This number must be from the same ACL category as the source ACL. If you do not specify an ACL number, the system automatically picks the smallest number from all available numbers in the same ACL category as the source ACL. The following are available value ranges:
name dest-acl-name: Assigns a unique name to the ACL you are creating. The dest-acl-name is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all. If you do not specify an ACL name, the system does not name the ACL.
The new ACL has the same properties and content as the source ACL, but not the same ACL number and name.
# Create IPv4 basic ACL 2002 by copying IPv4 basic ACL 2001.
[Sysname] acl copy 2001 to 2002
acl logging interval
Use acl logging interval to set the interval for generating and outputting packet filtering logs. The log information includes the number of matching packets and the matched ACL rules.
Use undo acl logging interval to restore the default.
acl [ ipv6 ] logging interval interval
undo acl [ ipv6 ] logging interval
The interval is 0. No packet filtering logs are generated.
interval: Specifies the interval in minutes at which packet filtering logs are generated and output. It must be a multiple of 5 and in the range of 0 to 1440. To disable generating packet filtering logs, assign 0 to the argument.
The system collects packet filtering logs only for IPv4 basic, IPv4 advanced, IPv6 basic, and IPv6 advanced ACL rules that have the logging keyword.
·     When the ipv6 keyword is not specified, this command sets the interval for generating and outputting IPv4 packet filtering logs.
·     When the ipv6 keyword is specified, this command sets the interval for generating and outputting IPv6 packet filtering logs.
# Enable the device to generate and output IPv4 packet filtering logs at 10-minute intervals.
[Sysname] acl logging interval 10
·     rule (IPv4 advanced ACL view)
·     rule (IPv4 basic ACL view)
·     rule (IPv6 advanced ACL view)
·     rule (IPv6 basic ACL view)
acl name
Use acl name to enter the view of an ACL that has a name.
acl [ ipv6 ] name acl-name
acl-name: Specifies the name of an ACL, a case-insensitive string of 1 to 63 characters. It must start with an English letter. The ACL must already exist. For a basic ACL or advanced ACL, if you do not specify the ipv6 keyword, this option specifies the name of an IPv4 basic ACL or advanced ACL. If you specify the ipv6 keyword, this option specifies the name of an IPv6 basic ACL or advanced ACL.
# Enter the view of IPv4 basic ACL flow, which already exists.
[Sysname] acl name flow
# Enter the view of IPv6 basic ACL flow, which already exists.
[Sysname] acl ipv6 name flow
[Sysname-acl6-basic-2001-flow]
acl
description
Use description to configure a description for an ACL.
Use undo description to delete an ACL description.
An ACL has no description.
IPv4/IPv6 basic ACL view
IPv4/IPv6 advanced ACL view
Ethernet frame header ACL view
text: Configures a description for the ACL, a case-sensitive string of 1 to 127 characters.
# Configure a description for IPv4 basic ACL 2000.
[Sysname-acl-basic-2000] description This is an IPv4 basic ACL.
display acl
display acl
Use display acl to display configuration and match statistics for ACLs.
display acl [ ipv6 ] { acl-number | all | name acl-name }
acl-number: Specifies an ACL by its number. The following are available value ranges:
all: Displays information about all IPv4 basic, IPv4 advanced, and Ethernet frame header ACLs if you do not specify the ipv6 keyword, or displays information about all IPv6 basic and IPv6 advanced ACLs if you specify the ipv6 keyword.
name acl-name: Specifies an ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter.
This command displays ACL rules in config or depth-first order, whichever is configured.
# Display configuration and match statistics for IPv4 basic ACL 2001.
<Sysname> display acl 2001
Basic ACL  2001, named flow, 1 rule, match-order is auto,
ACL's step is 5
 rule 5 permit source 1.1.1.1 0
 rule 5 comment This rule is used on GigabitEthernet 1/0/1.
Basic ACL  2001
Category and number of the ACL. The following field information is about IPv4 basic ACL 2000.
named flow
The name of the ACL is flow. If the ACL is not named, this field displays -none-.
1 rule
The ACL contains one rule.
match-order is auto
The match order for the ACL is auto, which sorts ACL rules in depth-first order. This field is not present when the match order is config.
Description of this ACL.
ACL's step is 5
The rule numbering step is 5.
Content of rule 5.
Comment of ACL rule 5.
display packet-filter
Use display packet-filter to display whether an ACL has been successfully applied to an interface for packet filtering.
display packet-filter { interface [ interface-type interface-number ] [ inbound | outbound ] | interface vlan-interface vlan-interface-number  [ inbound | outbound ] [ slot slot-number ] }
interface [ interface-type interface-number ]: Specifies an interface by its type and number. VLAN interfaces are not supported. If you do not specify an interface, this command displays ACL application information on all interfaces except VLAN interfaces for packet filtering.
interface vlan-interface vlan-interface-number: Specifies a VLAN interface by its number.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
slot slot-number: Specifies an IRF member device. The slot-number argument represents the member ID of the IRF member device. If you do not specify an IRF member device, this command displays ACL application information for packet filtering on the master device.
If neither the inbound keyword nor the outbound keyword is specified, this command displays the ACL application information for both inbound and outbound packet filtering.
# Display ACL application information for inbound packet filtering on interface GigabitEthernet 1/0/1.
<Sysname> display packet-filter interface gigabitethernet 1/0/1 inbound
In-bound policy:
  ACL 2001, Hardware-count
  ACL6 2002
  IPv4 default action: Deny
  IPv6 default action: Deny
Interface to which the ACL applies.
In-bound policy
ACL used for filtering incoming traffic.
Out-bound policy
ACL used for filtering outgoing traffic.
ACL 2001
IPv4 basic ACL 2001 has been successfully applied.
Hardware-count
Successfully enables counting ACL rule matches.
IPv4 default action
Packet filter default action for packets that do not match any IPv4 ACLs. This field is displayed only when the default action is deny.
IPv6 default action
Packet filter default action for packets that do not match any IPv6 ACLs. This field is displayed only when the default action is deny.
MAC default action
Packet filter default action for packets that do not match any Ethernet frame header ACLs. This field is displayed only when the default action is deny.
display packet-filter statistics
Use display packet-filter statistics to display match statistics of ACLs for packet filtering.
display packet-filter statistics interface interface-type interface-number  { inbound | outbound } [ [ ipv6 ] { acl-number | name acl-name } ] [ brief ]
interface interface-type interface-number: Displays the statistics of an interface specified by its type and number.
inbound: Displays the statistics in the inbound direction.
outbound: Displays the statistics in the outbound direction.
brief: Displays brief statistics.
If neither acl-number nor name acl-name is specified, this command displays match statistics of all ACLs for packet filtering.
# Display match statistics of all ACLs for inbound packet filtering on GigabitEthernet 1/0/1.
<Sysname> display packet-filter statistics interface gigabitethernet 1/0/1 inbound
 In-bound policy:
   From 2011-06-04 10:25:21 to 2011-06-04 10:35:57
   rule 0 permit source 2.2.2.2 0
   Totally 0 packets permitted, 0 packets denied
   Totally 0% permitted, 0% denied
In-bound policy
Out-bound policy
ACL 2001
Hardware-count
Start time and end time of the statistics.
Number of packets permitted and denied by the ACL.
Ratios of permitted and denied packets to all packets.
IPv4 default action
IPv6 default action
MAC default action
reset packet-filter statistics
display packet-filter statistics sum
Use display packet-filter statistics sum to display accumulated packet filtering ACL statistics.
display packet-filter statistics sum { inbound | outbound } [ ipv6 ] { acl-number | name acl-name } [ brief ]
brief: Displays brief accumulated packet filtering ACL statistics.
# Display accumulated packet filtering ACL statistics of IPv4 basic ACL 2001 for incoming packets.
<Sysname> display packet-filter statistics sum inbound 2001
Sum:
 In-bound policy:
  ACL 2001
   rule 0 permit source 2.2.2.2 0 (2 packets)
   Totally 2 packets permitted, 0 packets denied
   Totally 100% permitted, 0% denied
Sum
Accumulated packet filtering ACL statistics.
In-bound policy
Accumulated ACL statistics used for filtering incoming traffic.
Out-bound policy
Accumulated ACL statistics used for filtering outgoing traffic.
ACL 2001
Accumulated ACL statistics used for IPv4 basic ACL 2001.
2 packets
Two packets matched the rule.
This field is not displayed when no packets matched the rule.
display packet-filter verbose
Use display packet-filter verbose to display application details of ACLs for packet filtering.
display packet-filter verbose interface interface-type interface-number { inbound | outbound } [ [ ipv6 ] { acl-number | name acl-name } ] [ slot slot-number ]
slot slot-number: Specifies an IRF member device. The slot-number argument represents the ID of the IRF member device. If you do not specify an IRF member device, this command displays ACL application details for packet filtering on the master device.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, this command displays ACL application details for packet filtering on the master device.
If neither acl-number nor name acl-name is specified, this command displays application details of all ACLs for packet filtering.
# Display application details of all ACLs for inbound packet filtering on GigabitEthernet 1/0/1.
<Sysname> display packet-filter verbose interface gigabitethernet 1/0/1 inbound
 In-bound policy:
   rule 0 permit
  ACL6 2000, Hardware-count
   rule 0 permit
  ACL 4000, Hardware-count
  MAC default action: Deny
Table 5 Command output
In-bound policy
Out-bound policy
ACL 2001
Hardware-count
IPv4 default action
IPv6 default action
MAC default action
display qos-acl resource
Use display qos-acl resource to display QoS and ACL resource usage.
display qos-acl resource [ slot slot-number ]
slot slot-number: Specifies an IRF member device. The slot-number argument represents the member ID of the IRF member device. If you do not specify an IRF member device, this command displays QoS and ACL resource usage on all member devices.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option on an IRF fabric, this command displays QoS and ACL resource usage on all member devices.
# Display QoS and ACL resource usage.
<Sysname> display qos-acl resource
Interfaces: GE1/0/1 to GE1/0/48, XGE1/0/49 to XGE1/0/52
 Type             Total      Reserved   Configured Remaining  Usage
 VFP ACL          2048       512        0          1536       25%
 IFP ACL          4096       1024       0          3072       25%
 IFP Meter        2048       512        0          1536       25%
 IFP Counter      2048       256        0          1792       12%
 EFP ACL          1024       0          0          1024       0%
 EFP Meter        512        0          0          512        0%
 EFP Counter      512        0          0          512        0%
Table 6 Command output
Interfaces
Interface range for the resource.
Resource type:
·     VFP ACL—ACL rules for local QoS ID remarking before Layer 2 forwarding.
·     IFP ACL—ACL rules applied to inbound traffic.
·     IFP Meter—Traffic policing rules for inbound traffic.
·     IFP Counter—Traffic counting rules for inbound traffic.
·     EFP Meter—Traffic policing rules for outbound traffic.
·     EFP Counter—Traffic counting rules for outbound traffic.
Total
Total number of resource.
Reserved
Number of reserved resource.
Configured
Number of resource that has been applied.
Remaining
Number of resource that you can apply.
Usage
Configured and reserved resources as a percentage of total resources. If the percentage is not an integer, this field displays the integer part. For example, if the actual usage is 50.8%, this field displays 50%.
packet-filter
Use packet-filter to apply an ACL to an interface to filter packets.
Use undo packet-filter to remove an ACL from an interface.
packet-filter [ ipv6 ] { acl-number | name acl-name } { inbound | outbound } [ hardware-count ]
undo packet-filter [ ipv6 ] { acl-number | name acl-name } { inbound | outbound }
An interface does not filter packets.
Layer 2 Ethernet interface view, Layer 3 Ethernet interface view, VLAN interface view
inbound: Filters incoming packets.
outbound: Filters outgoing packets.
hardware-count: Enables counting ACL rule matches performed in hardware. This keyword enables match counting for all rules in an ACL, and the counting keyword in the rule command enables match counting specific to rules. If the hardware-count keyword is not specified, rule matches for the ACL are not counted.
# Apply IPv4 basic ACL 2001 to filter incoming traffic on GigabitEthernet 1/0/1, and enable counting ACL rule matches performed in hardware.
[Sysname-GigabitEthernet1/0/1] packet-filter 2001 inbound hardware-count
·     display packet-filter
·     display packet-filter statistics
·     display packet-filter verbose
packet-filter default deny
Use packet-filter default deny to set the packet filtering default action to deny. The packet filter denies packets that do not match any ACL rule.
Use undo packet-filter default deny to restore the default.
The packet filter permits packets that do not match any ACL rule.
The packet filter applies the default action to all ACL applications for packet filtering. The default action appears in the display command output for packet filtering.
# Set the packet filter default action to deny.
[Sysname] packet-filter default deny
packet-filter filter
Use packet-filter filter to specify the applicable scope of packet filtering on a VLAN interface.
Use undo packet-filter filter to restore the default.
packet-filter filter [ route | all ]
The packet filtering filters packets forwarded at Layer 3 by a VLAN interface.
VLAN interface view
route: Filters packets forwarded at Layer 3 by the VLAN interface.
all: Filters all packets, including packets forwarded at Layer 3 by the VLAN interface and packets forwarded at Layer 2 by the physical ports associated with the VLAN interface.
# Configure the packet filtering on VLAN-interface 2 to filter packets forwarded at Layer 3.
[Sysname-Vlan-interface2] packet-filter filter route
reset acl counter
Use reset acl counter to clear statistics for ACLs.
reset acl counter [ ipv6 ] { acl-number | all | name acl-name }
all: Clears statistics for all IPv4 basic, IPv4 advanced, and Ethernet frame header ACLs if you do not specify the ipv6 keyword, or clears statistics for all IPv6 basic and IPv6 advanced ACLs if you specify the ipv6 keyword.
name acl-name: Clears statistics of an ACL specified by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter.
# Clear statistics for IPv4 basic ACL 2001.
display acl
Use reset packet-filter statistics to clear the match statistics (including the accumulated statistics) of ACLs for packet filtering.
reset packet-filter statistics interface [ interface-type interface-number ] { inbound | outbound } [ [ ipv6 ] { acl-number | name acl-name } ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command clears packet filtering ACL statistics on all interfaces.
If neither acl-number nor name acl-name is specified, this command clears the match statistics of all ACLs for packet filtering.
# Clear IPv4 basic ACL 2001 statistics for inbound packet filtering of interface GigabitEthernet 1/0/1.
<Sysname> reset packet-filter statistics interface gigabitethernet 1/0/1 inbound 2001
·     display packet-filter statistics sum
rule (Ethernet frame header ACL view)
Use rule to create or modify an Ethernet frame header ACL rule.
Use undo rule to delete an Ethernet frame header ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } [ cos vlan-pri | counting | dest-mac dest-address dest-mask | { lsap lsap-type lsap-type-mask | type protocol-type protocol-type-mask } | source-mac source-address source-mask | time-range time-range-name ] *
undo rule rule-id [ counting | time-range ] *
An Ethernet frame header ACL does not contain any rule.
rule-id: Specifies a rule ID in the range of 0 to 65534. If you do not specify a rule ID when creating an ACL rule, the system automatically assigns it a rule ID. This rule ID is the nearest higher multiple of the numbering step to the current highest rule ID, starting from 0. For example, if the rule numbering step is 5 and the current highest rule ID is 28, the rule is numbered 30.
deny: Denies matching packets to pass.
permit: Allows matching packets to pass.
cos vlan-pri: Matches an 802.1p priority. The vlan-pri argument can be a number in the range of 0 to 7, or in words, best-effort (0), background (1), spare (2), excellent-effort (3), controlled-load (4), video (5), voice (6), or network-management (7).
counting: Counts the number of times the Ethernet frame header ACL rule has been matched. The counting keyword enables match counting specific to rules, and the hardware-count keyword in the packet-filter command enables match counting for all rules in an ACL. If the counting keyword is not specified, matches for the rule are not counted.
dest-mac dest-address dest-mask: Matches a destination MAC address range. The dest-address and dest-mask arguments represent a destination MAC address and mask in the H-H-H format.
lsap lsap-type lsap-type-mask: Matches the DSAP and SSAP fields in LLC encapsulation. The lsap-type argument is a 16-bit hexadecimal number that represents the encapsulation format. The lsap-type-mask argument is a 16-bit hexadecimal number that represents the LSAP mask.
type protocol-type protocol-type-mask: Matches one or more protocols in the Ethernet frame header. The protocol-type argument is a 16-bit hexadecimal number that represents a protocol type in Ethernet_II and Ethernet_SNAP frames. The protocol-type-mask argument is a 16-bit hexadecimal number that represents a protocol type mask.
source-mac source-address source-mask: Matches a source MAC address range. The source-address argument represents a source MAC address, and the sour-mask argument represents a mask in the H-H-H format.
time-range time-range-name: Specifies a time range for the rule. The time-range-name argument is a case-insensitive string of 1 to 32 characters. It must start with an English letter. If the time range is not configured, the system creates the rule. However, the rule using the time range can take effect only after you configure the timer range. For more information about time range, see ACL and QoS Configuration Guide.
Rules within an ACL must use unique IDs. When you create a new rule, assign it an ID that is not in use. You can modify an existing rule by creating a new rule with the same ID. The system modifies the existing rule by adding new attributes from the new rule to the existing rule.
Within an ACL, the permit or deny statement of each rule must be unique. If the ACL rule you are creating or modifying has the same deny or permit statement as another rule in the ACL, the rule will not be created or modified.
When an Ethernet frame header ACL with the lsap keyword specified is used for QoS traffic classification or packet filtering, the lsap-type argument must be AAAA and the lsap-type-mask argument must be FFFF. Otherwise, the ACL cannot be applied successfully.
You can edit ACL rules only when the match order is config.
The undo rule command deletes the entire rule if you do not specify any optional parameters. It deletes the specified attributes if you specify optional parameters.
Use the display acl all command to view the rules in Ethernet frame header, IPv4 advanced, and IPv4 basic ACLs.
# Create a rule in Ethernet frame header ACL 4000 to permit ARP packets and deny RARP packets.
[Sysname] acl number 4000
[Sysname-acl-ethernetframe-4000] rule permit type 0806 ffff
[Sysname-acl-ethernetframe-4000] rule deny type 8035 ffff
·     acl
·     display acl
·     step
·     time-range
Use rule to create or modify an IPv4 advanced ACL rule.
Use undo rule to delete an entire IPv4 advanced ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { dest-address dest-wildcard | any } | destination-port operator port1 [ port2 ] | { dscp dscp | { precedence precedence | tos tos } * } | fragment | icmp-type { icmp-type [ icmp-code ] | icmp-message } | logging | source { source-address source-wildcard | any } | source-port operator port1 [ port2 ] | time-range time-range-name ] *
undo rule rule-id [ { { ack | fin | psh | rst | syn | urg } * | established } | counting | destination | destination-port | { dscp | { precedence | tos } * } | fragment | icmp-type | logging | source | source-port | time-range ] *
An IPv4 advanced ACL does not contain any rule.
protocol: Specifies a protocol number in the range of 0 to 255, or specifies a protocol by its name, gre (47), icmp (1), igmp (2), ip, ipinip (4), ospf (89), tcp (6), or udp (17). The ip keyword specifies all protocols. Table 7 describes the parameters that you can specify regardless of the value for the protocol argument.
Table 7 Match criteria and other rule information for IPv4 advanced ACL rules
Function
Specifies a source address.
The source-address source-wildcard arguments represent a source IP address and wildcard mask in dotted decimal notation. An all-zero wildcard specifies a host address.
The any keyword specifies any source IP address.
Specifies a destination address.
The dest-address dest-wildcard arguments represent a destination IP address and wildcard mask in dotted decimal notation. An all-zero wildcard specifies a host address.
The any keyword represents any destination IP address.
counting
Counts the number of times the IPv4 advanced ACL rule has been matched.
Specifies an IP precedence value.
The precedence argument can be a number in the range of 0 to 7, or in words, routine (0), priority (1), immediate (2), flash (3), flash-override (4), critical (5), internet (6), or network (7).
tos tos
Specifies a ToS preference.
The tos argument can be a number in the range of 0 to 15, or in words, max-reliability (2), max-throughput (4), min-delay (8), min-monetary-cost (1), or normal (0).
dscp dscp
Specifies a DSCP priority.
The dscp argument can be a number in the range of 0 to 63, or in words, af11 (10), af12 (12), af13 (14), af21 (18), af22 (20), af23 (22), af31 (26), af32 (28), af33 (30), af41 (34), af42 (36), af43 (38), cs1 (8), cs2 (16), cs3 (24), cs4 (32), cs5 (40), cs6 (48), cs7 (56), default (0), or ef (46).
fragment
Applies the rule only to non-first fragments.
If you do not specify this keyword, the rule applies to all fragments and non-fragments.
logging
Logs matching packets.
This feature requires that the module (for example, packet filtering) that uses the ACL supports logging.
If the protocol argument is tcp (6) or udp (7), set the parameters shown in Table 8.
Table 8 TCP/UDP-specific parameters for IPv4 advanced ACL rules
Function
Specifies one or more UDP or TCP source ports.
The operator argument can be lt (lower than), gt (greater than), eq (equal to), neq (not equal to), or range (inclusive range).
The port1 and port2 arguments are TCP or UDP port numbers in the range of 0 to 65535. port2 is needed only when the operator argument is range.
TCP port numbers can be represented as: chargen (19), bgp (179), cmd (514), daytime (13), discard (9), domain (53), echo (7), exec (512), finger (79), ftp (21), ftp-data (20), gopher (70), hostname (101), irc (194), klogin (543), kshell (544), login (513), lpd (515), nntp (119), pop2 (109), pop3 (110), smtp (25), sunrpc (111), tacacs (49), talk (517), telnet (23), time (37), uucp (540), whois (43), and www (80).
UDP port numbers can be represented as: biff (512), bootpc (68), bootps (67), discard (9), dns (53), dnsix (90), echo (7), mobilip-ag (434), mobilip-mn (435), nameserver (42), netbios-dgm (138), netbios-ns (137), netbios-ssn (139), ntp (123), rip (520), snmp (161), snmptrap (162), sunrpc (111), syslog (514), tacacs-ds (65), talk (517), tftp (69), time (37), who (513), and xdmcp (177).
Specifies one or more UDP or TCP destination ports.
Specifies one or more TCP flags including ACK, FIN, PSH, RST, SYN, and URG.
Parameters specific to TCP.
The value for each argument can be 0 (flag bit not set) or 1 (flag bit set).
The TCP flags in a rule are ANDed. For example, a rule configured with ack 0 psh 1 matches packets that have the ACK flag bit not set and the PSH flag bit set.
established
Specifies the flags for indicating the established status of a TCP connection.
Parameter specific to TCP.
The rule matches TCP connection packets with the ACK or RST flag bit set.
If the protocol argument is icmp (1), set the parameters shown in Table 9.
Table 9 ICMP-specific parameters for IPv4 advanced ACL rules
Function
icmp-type { icmp-type icmp-code | icmp-message }
Specifies the ICMP message type and code.
The icmp-type argument is in the range of 0 to 255.
The icmp-code argument is in the range of 0 to 255.
The icmp-message argument specifies a message name. Supported ICMP message names and their corresponding type and code values are listed in Table 10.
Table 10 ICMP message names supported in IPv4 advanced ACL rules
ICMP message name
ICMP message type
ICMP message code
echo
8
0
echo-reply
0
0
fragmentneed-DFset
3
4
host-redirect
5
1
host-tos-redirect
5
3
host-unreachable
3
1
information-reply
16
0
information-request
15
0
net-redirect
5
0
net-tos-redirect
5
2
net-unreachable
3
0
parameter-problem
12
0
port-unreachable
3
3
protocol-unreachable
3
2
reassembly-timeout
11
1
source-quench
4
0
source-route-failed
3
5
timestamp-reply
14
0
timestamp-request
13
0
ttl-exceeded
11
0
If an ACL is for QoS traffic classification or packet filtering, do not specify neq for the operator argument.
# Create an IPv4 advanced ACL rule to permit TCP packets with the destination port 80 from 129.9.0.0/16 to 202.38.160.0/24.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 destination-port eq 80
# Create IPv4 advanced ACL rules to permit all IP packets but the ICMP packets destined for 192.168.1.0/24.
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule deny icmp destination 192.168.1.0 0.0.0.255
[Sysname-acl-adv-3001] rule permit ip
# Create IPv4 advanced ACL rules to permit inbound and outbound FTP packets.
[Sysname] acl number 3002
[Sysname-acl-adv-3002] rule permit tcp source-port eq ftp
[Sysname-acl-adv-3002] rule permit tcp source-port eq ftp-data
[Sysname-acl-adv-3002] rule permit tcp destination-port eq ftp
[Sysname-acl-adv-3002] rule permit tcp destination-port eq ftp-data
# Create IPv4 advanced ACL rules to permit inbound and outbound SNMP and SNMP trap packets.
[Sysname] acl number 3003
[Sysname-acl-adv-3003] rule permit udp source-port eq snmp
[Sysname-acl-adv-3003] rule permit udp source-port eq snmptrap
[Sysname-acl-adv-3003] rule permit udp destination-port eq snmp
[Sysname-acl-adv-3003] rule permit udp destination-port eq snmptrap
·     acl
·     acl logging interval
·     display acl
·     step
·     time-range
Use rule to create or modify an IPv4 basic ACL rule.
Use undo rule to delete an entire IPv4 basic ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } [ counting | fragment | logging | source { source-address source-wildcard | any } | time-range time-range-name ] *
undo rule rule-id [ counting | fragment | logging | source | time-range ] *
An IPv4 basic ACL does not contain any rule.
IPv4 basic ACL view
counting: Counts the number of times the IPv4 basic ACL rule has been matched. The counting keyword enables match counting specific to rules, and the hardware-count keyword in the packet-filter command enables match counting for all rules in an ACL. If the counting keyword is not specified, matches for the rule are not counted.
fragment: Applies the rule only to non-first fragments. If you do not specify this keyword, the rule applies to both fragments and non-fragments.
logging: Logs matching packets. This feature is available only when the application module (for example, packet filtering) that uses the ACL supports logging.
source { source-address source-wildcard | any }: Matches a source address. The source-address source-wildcard arguments represent a source IP address and wildcard mask in dotted decimal notation. A wildcard mask of zeros specifies a host address. The any keyword represents any source IP address.
# Create a rule in IPv4 basic ACL 2000 to deny the packets from any source IP segment but 10.0.0.0/8, 172.17.0.0/16, or 192.168.1.0/24.
[Sysname-acl-basic-2000] rule permit source 10.0.0.0 0.255.255.255
[Sysname-acl-basic-2000] rule permit source 172.17.0.0 0.0.255.255
[Sysname-acl-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-basic-2000] rule deny source any
·     acl
·     display acl
·     step
·     time-range
Use rule to create or modify an IPv6 advanced ACL rule.
Use undo rule to delete an entire IPv6 advanced ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { dest-address dest-prefix | dest-address/dest-prefix | any } | destination-port operator port1 [ port2 ] | dscp dscp | flow-label flow-label-value | fragment | icmp6-type { icmp6-type icmp6-code | icmp6-message } | logging | routing [ type routing-type ] | hop-by-hop [ type hop-type ] | source { source-address source-prefix | source-address/source-prefix | any } | source-port operator port1 [ port2 ] | time-range time-range-name ] *
undo rule rule-id [ { { ack | fin | psh | rst | syn | urg } * | established } | counting | destination | destination-port | dscp | flow-label | fragment | icmp6-type | logging | routing | hop-by-hop | source | source-port | time-range ] *
An IPv6 advanced ACL does not contain any rule.
protocol: Specifies a protocol number in the range of 0 to 255, or specifies a protocol by its name, gre (47), icmpv6 (58), ipv6, ipv6-ah (51), ipv6-esp (50), ospf (89), tcp (6), or udp (17). The ipv6 keyword specifies all protocols.
You can set the protocol argument to one of the values in Table 11 to match packets with the corresponding IPv6 extended header.
Table 11 Protocol values of IPv6 extended headers
Value of the protocol argument
0
Hop-by-Hop Options Header.
43
Routing Header.
44
Fragment Header.
50
Encapsulating Security Payload Header.
51
Authentication Header.
60
Destination Options Header.
Table 12 describes the parameters that you can specify regardless of the value for the protocol argument.
Table 12 Match criteria and other rule information for IPv6 advanced ACL rules
Function
Specifies a source IPv6 address.
The source-address and source-prefix arguments represent an IPv6 source address, and prefix length in the range of 1 to 128.
The any keyword represents any IPv6 source address.
Specifies a destination IPv6 address.
The dest-address and dest-prefix arguments represent a destination IPv6 address, and prefix length in the range of 1 to 128.
The any keyword specifies any IPv6 destination address.
counting
Counts the number of times the IPv6 advanced ACL rule has been matched.
The counting keyword enables match counting specific to rules, and the hardware-count keyword in the packet-filter ipv6 command enables match counting for all rules in an ACL. If the counting keyword is not specified, matches for the rule are not counted.
dscp dscp
Specifies a DSCP preference.
Specifies a flow label value in an IPv6 packet header.
The flow-label-value argument is in the range of 0 to 1048575.
fragment
logging
Specifies an IPv6 routing header type.
routing-type: Value of the IPv6 routing header type, in the range of 0 to 255.
If you specify the type routing-type option, the rule applies to the specified type of IPv6 routing header. Otherwise, the rule applies to all types of IPv6 routing header.
Specifies an IPv6 Hop-by-Hop Options header type.
hop-type: Value of the IPv6 Hop-by-Hop Options header type, in the range of 0 to 255.
If you specify the type hop-type option, the rule applies to the specified type of IPv6 Hop-by-Hop Options header. Otherwise, the rule applies to all types of IPv6 Hop-by-Hop Options header.
If the protocol argument is tcp (6) or udp (17), set the parameters shown in Table 13.
Table 13 TCP/UDP-specific parameters for IPv6 advanced ACL rules
Function
Specifies one or more TCP flags, including ACK, FIN, PSH, RST, SYN, and URG.
established
If the protocol argument is icmpv6 (58), set the parameters shown in Table 14.
Table 14 ICMPv6-specific parameters for IPv6 advanced ACL rules
Function
Specifies the ICMPv6 message type and code.
The icmp6-type argument is in the range of 0 to 255.
The icmp6-code argument is in the range of 0 to 255.
The icmp6-message argument specifies a message name. Supported ICMP message names and their corresponding type and code values are listed in Table 15.
Table 15 ICMPv6 message names supported in IPv6 advanced ACL rules
ICMPv6 message name
ICMPv6 message type
ICMPv6 message code
echo-reply
129
0
echo-request
128
0
err-Header-field
4
0
frag-time-exceeded
3
1
hop-limit-exceeded
3
0
host-admin-prohib
1
1
host-unreachable
1
3
neighbor-advertisement
136
0
neighbor-solicitation
135
0
network-unreachable
1
0
packet-too-big
2
0
port-unreachable
1
4
redirect
137
0
router-advertisement
134
0
router-solicitation
133
0
unknown-ipv6-opt
4
2
unknown-next-hdr
4
1
If an ACL is for QoS traffic classification or packet filtering:
·     Do not specify the fragment keyword.
·     Do not specify neq for the operator argument.
·     Do not specify the routing, hop-by-hop, or flow-label keyword if the ACL is for outbound application.
·     Do not specify ipv6-ah for the protocol argument, nor set its value to 0, 43, 44, 51, or 60, if the ACL is for outbound application.
If an ACL is to match information in the IPv6 packet payload, it can only match packets with one extension header. It cannot match packets with two or more extension headers or with the Encapsulating Security Payload Header.
Use the display acl ipv6 all command to view the rules in IPv6 advanced and basic ACLs.
# Create an IPv6 advanced ACL rule to permit TCP packets with the destination port 80 from 2030:5060::/64 to FE80:5060::/96.
[Sysname-acl6-adv-3000] rule permit tcp source 2030:5060::/64 destination fe80:5060::/96 destination-port eq 80
# Create IPv6 advanced ACL rules to permit all IPv6 packets but the ICMPv6 packets destined for FE80:5060:1001::/48.
[Sysname] acl ipv6 number 3001
[Sysname-acl6-adv-3001] rule deny icmpv6 destination fe80:5060:1001:: 48
[Sysname-acl6-adv-3001] rule permit ipv6
# Create IPv6 advanced ACL rules to permit inbound and outbound FTP packets.
[Sysname] acl ipv6 number 3002
[Sysname-acl6-adv-3002] rule permit tcp source-port eq ftp
[Sysname-acl6-adv-3002] rule permit tcp source-port eq ftp-data
[Sysname-acl6-adv-3002] rule permit tcp destination-port eq ftp
[Sysname-acl6-adv-3002] rule permit tcp destination-port eq ftp-data
# Create IPv6 advanced ACL rules to permit inbound and outbound SNMP and SNMP trap packets.
[Sysname] acl ipv6 number 3003
[Sysname-acl6-adv-3003] rule permit udp source-port eq snmp
[Sysname-acl6-adv-3003] rule permit udp source-port eq snmptrap
[Sysname-acl6-adv-3003] rule permit udp destination-port eq snmp
[Sysname-acl6-adv-3003] rule permit udp destination-port eq snmptrap
# Create IPv6 advanced ACL 3004, and configure two rules: one permits packets with the Hop-by-Hop Options header type as 5, and the other one denies packets with other Hop-by-Hop Options header types.
[Sysname] acl ipv6 number 3004
[Sysname-acl6-adv-3004] rule permit ipv6 hop-by-hop type 5
[Sysname-acl6-adv-3004] rule deny ipv6 hop-by-hop
·     acl
·     display acl
·     step
·     time-range
Use rule to create or modify an IPv6 basic ACL rule.
Use undo rule to delete an entire IPv6 basic ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } [ counting | fragment | logging | routing [ type routing-type ] | source { source-address source-prefix | source-address/source-prefix | any } | time-range time-range-name ] *
undo rule rule-id [ counting | fragment | logging | routing | source | time-range ] *
An IPv6 basic ACL does not contain any rule.
IPv6 basic ACL view
counting: Counts the number of times the IPv6 basic ACL rule has been matched. The counting keyword enables match counting specific to rules, and the hardware-count keyword in the packet-filter ipv6 command enables match counting for all rules in an ACL. If the counting keyword is not specified, matches for the rule are not counted.
routing [ type routing-type ]: Applies the rule to the specified type of routing header or all types of routing header. The routing-type argument specifies the value of the routing header type, which is in the range of 0 to 255. If you specify the type routing-type option, the rule applies to the specified type of routing header. Otherwise, the rule applies to any type of routing header.
source { source-address source-prefix | source-address/source-prefix | any }: Matches a source IP address. The ipv6-address and prefix-length arguments represent a source IPv6 address and address prefix length in the range of 1 to 128. The any keyword represents any IPv6 source address.
·     Do not specify the routing keyword if the ACL is for outbound application.
# Create an IPv6 basic ACL rule to deny the packets from any source IP segment but 1001::/16, 3124:1123::/32, or FE80:5060:1001::/48.
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000] rule permit source 1001:: 16
[Sysname-acl6-basic-2000] rule permit source 3124:1123:: 32
[Sysname-acl6-basic-2000] rule permit source fe80:5060:1001:: 48
[Sysname-acl6-basic-2000] rule deny source any
·     acl
·     display acl
·     step
·     time-range
rule comment
Use rule comment to add a comment about an existing ACL rule or edit its comment to make the rule easy to understand.
Use undo rule comment to delete an ACL rule comment.
rule rule-id comment text
undo rule rule-id comment
An ACL rule does not have a comment.
rule-id: Specifies an ACL rule ID in the range of 0 to 65534. The ACL rule must already exist.
text: Specifies a comment about the ACL rule, a case-sensitive string of 1 to 127 characters.
# Create a rule for IPv4 basic ACL 2000, and add a comment about the rule.
[Sysname-acl-basic-2000] rule 0 deny source 1.1.1.1 0
[Sysname-acl-basic-2000] rule 0 comment This rule is used for telnet.
display acl
step
Use step to set a rule numbering step for an ACL.
Use undo step to restore the default.
step step-value
undo step
The rule numbering step for an ACL is five.
step-value: ACL rule numbering step in the range of 1 to 20.
The rule numbering step sets the increment by which the system numbers rules automatically. For example, the default ACL rule numbering step is 5. If you do not assign IDs to rules you are creating, they are numbered 0, 5, 10, 15, and so on. The wider the numbering step, the more rules you can insert between two rules. Whenever the step changes, the rules are renumbered, starting from 0. For example, if there are five rules numbered 5, 10, 13, 15, and 20, changing the step from 5 to 2 causes the rules to be renumbered 0, 2, 4, 6, and 8.
# Set the rule numbering step to 2 for IPv4 basic ACL 2000.
[Sysname-acl-basic-2000] step 2
display acl
