03-MPLS QoS commands | 31.64 KB |
MPLS QoS commands
if-match mpls-exp
Use if-match mpls-exp to define a criterion to match the EXP field in the first MPLS label.
Use undo if-match mpls-exp to delete the match criterion.
if-match [ not ] mpls-exp exp-value&<1-8>
undo if-match [ not ] mpls-exp exp-value&<1-8>
No criterion is defined to match the EXP field in the first MPLS label.
Traffic class view
not: Matches packets not conforming to the specified criterion.
exp-value&<1-8>: Specifies a space-separated list of up to eight EXP values. The value range for the exp-value argument is 0 to 7. If the same EXP value is specified multiple times, the system considers them as one. If a packet matches one of the defined MPLS EXP values, it matches the if-match clause.
# In traffic behavior database, define a criterion to match packets with EXP value 3 or 4 in the first MPLS label.
[Sysname] traffic classifier database
[Sysname-classifier-database] if-match mpls-exp 3 4
remark mpls-exp
Use remark mpls-exp to configure an action of marking the EXP value in the first label in a traffic behavior.
Use undo remark mpls-exp to delete the action.
remark [ green | red | yellow ] mpls-exp exp-value
undo remark [ green | red | yellow ] mpls-exp
No action of marking the EXP value in the first label is configured in a traffic behavior.
Traffic behavior view
green: Specifies green packets.
red: Specifies red packets.
yellow: Specifies yellow packets.
exp-value: Specifies an EXP value in the range of 0 to 7.
This command takes effect only when the QoS policy is applied to the outbound direction.
If you do not specify a color, this command marks the EXP value for packets of all colors.
# In traffic behavior database, set the EXP value in the first label to 0 for MPLS packets.
[Sysname-behavior-database] remark mpls-exp 0
