09-MPLS Configration Guide
HomeSupportResource CenterRoutersH3C SR6600-X Router SeriesH3C SR6600-X Router SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C SR6600 SR6600-X Routers Configuration Guides-R7607-6W10009-MPLS Configration Guide
10-VPLS configuration
10-VPLS configuration 503.10 KB
Configuring VPLS
Overview
Virtual Private LAN Service (VPLS) delivers a point-to-multipoint L2VPN service over an MPLS or IP backbone. The provider backbone emulates a switch to connect all geographically dispersed sites of each customer network. The backbone is transparent to the customer sites. The sites can communicate with each other as if they were on the same LAN.
Basic VPLS architecture
Figure 1 Basic VPLS architecture
As shown in Figure 1, the VPLS architecture mainly includes the following components:
·     CE—A customer edge device is directly connected to the service provider network.
·     PE—A provider edge device connects one or more CEs to the service provider network. A PE implements VPN access by mapping and forwarding packets between private networks and public network tunnels. A PE can be a UPE or NPE in a hierarchical VPLS.
·     AC—An attachment circuit, physical or virtual, connects a CE and a PE, such as an Ethernet link or a VLAN.
·     PW—A pseudowire is a bidirectional virtual connection between two PEs. An MPLS PW consists of two unidirectional MPLS LSPs in opposite directions.
·     Tunnel—A tunnel can be an LSP tunnel, an MPLS TE tunnel, or a GRE tunnel. It carries one or more PWs over an IP/MPLS backbone. If a PW is carried on an LSP or MPLS TE tunnel, each packet on the PW contains two labels. The inner label is the PW label, which identifies the PW and ensures that the packet is forwarded to the correct VSI. The outer label is the public LSP or MPLS TE tunnel label, which ensures that the packet is correctly forwarded to the remote PE.
·     VPLS instance—A customer network might contain multiple geographically dispersed sites (such as site 1 and site 3 in Figure 1.) The service provider uses VPLS to connect all the sites to create a single Layer 2 VPN, which is referred to as a VPLS instance. Sites in different VPLS instances cannot communicate with each other at Layer 2.
·     VSI—A virtual switch instance provides Layer 2 switching services for a VPLS instance on a PE. A VSI acts as a virtual switch that has all the functions of a conventional Ethernet switch, including source MAC address learning, MAC address aging, and flooding. VPLS uses VSIs to forward Layer 2 data packets in VPLS instances.
VPLS implementation
Creating a PW
PEs use PWs to forward packets among VPN sites. PWs include static PWs, LDP PWs, BGP PWs, and BGP auto-discovery LDP PWs.
·     Static PW
To create a static PW, specify the address of the remote PE, the incoming label, and the outgoing label.
·     LDP PW
To create an LDP PW, specify the address of the remote PE, and use LDP to advertise the PW-label binding to the remote PE. After the two PEs receive the PW-label binding from each other, they establish an LDP PW. The FEC type in the LDP message is PWid FEC Element that includes the PW ID field (FEC 128). The PW ID identifies the PW bound to the PW label.
·     BGP PW
To create a BGP PW, configure BGP to advertise label block information to the remote PE. After the two PEs receive label block information from each other, they use the label block information to calculate the incoming and outgoing labels and create the BGP PW. A PE also uses the received label block information to automatically find the remote PE.
·     BGP auto-discovery LDP PW
To create a BGP auto-discovery LDP PW, configure BGP to automatically find the remote PE, and use LDP to advertise the PW-label binding to the remote PE. After the two PEs receive the PW-label binding from each other, they establish a BGP auto-discovery LDP PW.
The information advertised by BGP includes the ID (for example, LSR ID) and VPLS ID of the advertising PE. The receiving PE compares the received VPLS ID with its own VPLS ID. If the two VPLS IDs are identical, the two PEs use LDP to establish a PW. If not, the PEs do not establish a PW. The FEC type in the LDP message is Generalized PWid FEC Element (FEC 129), which contains the VPLS ID, Source Attachment Individual Identifier (SAII), and Target Attachment Individual Identifier (TAII). The SAII is the LSR ID of the advertising PE. The TAII identifies the remote PE and is advertised by the remote PE. VPLS ID+SAII+TAII uniquely identifies a PW in a VPLS instance.
MAC address learning, aging, and withdrawal
VPLS provides reachability through source MAC learning. A PE maintains a MAC address table for each VSI.
As shown in Figure 2, a PE learns source MAC addresses in the following ways:
·     Learning the source MAC addresses of directly connected sites.
If the source MAC address of a packet from a CE does not exist in the MAC address table, the PE learns the source MAC address of the AC connected to the CE.
·     Learning the source MAC addresses of remote sites connected through PWs.
A VSI regards a PW as a logical Ethernet interface. If the source MAC address of a packet from a PW does not exist in the MAC address table, the PE learns the source MAC address on the PW of the VSI.
Figure 2 Source MAC address learning on a PE
The MAC address table uses an aging timer for each dynamic MAC address entry. If no packet is received from a MAC address before the aging timer expires, VPLS deletes the MAC address.
When an AC or a PW goes down, the PE deletes MAC addresses on the AC or PW. Then it sends an LDP address withdrawal message to notify all other PEs in the VPLS instance to delete those MAC addresses.
Unicast traffic forwarding and flooding
After a PE receives a unicast packet from an AC, the PE searches the MAC address table of the VSI bound to the AC for packet forwarding.
·     If a match is found, the PE forwards the packet according to the matching entry. If the outgoing interface in the entry is a PW, the PE inserts the PW label to the packet, and adds the public tunnel header to the packet. It then forwards the packet to the remote PE over the PW. If the outgoing interface in the entry is a local interface, the PE directly forwards the packet to the local interface.
·     If no match is found, the PE floods the packet to all other ACs and PWs in the VSI.
After a PE receives a unicast packet from a PW, the PE searches the MAC address table of the VSI bound to the PW for packet forwarding.
·     If a match is found, the PE forwards the packet through the outgoing interface in the matching entry.
·     If no match is found, the PE floods the packet to all ACs in the VSI.
Multicast and broadcast traffic forwarding and flooding
After a PE receives a multicast or broadcast packet from an AC, the PE floods the packet to all other ACs and the PWs in the VSI bound to the AC.
After a PE receives a multicast or broadcast packet from a PW, the PE floods the packet to all ACs in the VSI bound to the PW.
PW full mesh and split horizon
A Layer 2 network requires a loop prevention protocol such as STP to avoid loops. However, a loop prevention protocol on PEs brings management and maintenance difficulties. Therefore, VPLS uses the following methods to prevent loops:
·     Full mesh—Every two PEs in a VPLS instance must establish a PW. The PWs form a full mesh among PEs in the VPLS instance.
·     Split horizon—A PE does not forward packets received from a PW to any other PWs in the same VSI but only forwards those packets to ACs.
H-VPLS
VPLS requires a full mesh of PWs among all PEs in a VPLS instance. In a large-scale network, however, a full mesh of PWs causes very high PW signaling overhead and brings difficulties for network management and expansion. Hierarchical VPLS (H-VPLS) reduces the number of PWs by dividing a VPLS network into a backbone domain and edge domains.
Only static PWs and LDP PWs support H-VPLS.
In H-VPLS:
·     An edge domain provides access for a user network to the backbone domain.
·     The Network Provider Edge (NPE) devices are fully meshed in the backbone domain. A PW between NPEs is referred to as an N-PW.
·     A User facing-Provider Edge (UPE) device only establishes a PW with the neighboring NPE. A PW between a UPE and an NPE is referred to as a U-PW.
H-VPLS access modes
H-VPLS supports the following access modes: MPLS access and Ethernet access.
Figure 3 H-VPLS using MPLS access
As shown in Figure 3, the edge domain is an MPLS network. The UPE creates a U-PW with NPE 1. The UPE does not create PWs to any remote PEs. After receiving a packet from a CE, the UPE adds the label assigned to the U-PW into the packet and forwards the packet to NPE 1 through a public tunnel. NPE 1 maps the packet to the VSI that corresponds to the PW label, and searches the MAC address table of the VSI to forward the packet.
A U-PW created on the NPE must have split horizon disabled because the NPE needs to forward packets between U-PW and N-PW.
Figure 4 H-VPLS using Ethernet access
As shown in Figure 4, the edge domain is an Ethernet network. The UPE and NPE 1 establish a point-to-point Ethernet QinQ connection in between. After the UPE receives a packet from a CE, it adds an outer VLAN tag into the packet and forwards the packet to NPE 1. NPE 1 regards the outer VLAN tag as the service provider VLAN tag. It maps the packet to the VSI that corresponds to the VLAN tag and then searches the MAC address table of the VSI to forward the packet.
UPE dual homing and PW redundancy
To provide U-PW redundancy for a UPE, you can connect the UPE to two NPEs. Even if a U-PW fails, all customer sites connected to the UPE maintain the connectivity.
In the H-VPLS using MPLS access as shown in Figure 5, the UPE is connected to two NPEs through primary and backup U-PWs. The UPE uses the primary U-PW to forward traffic. When the primary U-PW fails, the UPE uses the backup U-PW to forward traffic.
Figure 5 UPE dual homing and redundancy in H-VPLS using MPLS access
The backup U-PW is used in the following scenarios:
·     The primary U-PW goes down because the tunnel that carries the primary U-PW is deleted or a fault detection mechanism such as BFD detects a tunnel failure.
·     The primary U-PW is deleted by the control plane. For example, the LDP session on the primary U-PW link is down, causing the primary U-PW to be deleted.
·     BFD detects a failure of the primary U-PW.
·     A primary and backup U-PW switchover is triggered by a command.
Hub-spoke networking
The hub-spoke network model has one hub site and multiple spoke sites. The spoke sites cannot directly communicate with each other. Traffic between spoke sites must travel through the hub site, so the hub site can implement centralized traffic management.
Only static PWs and LDP PWs support the hub-spoke network model.
Figure 6 Hub-spoke model of VPLS
As shown in Figure 6:
·     The CE in the hub site is called a hub-CE.
·     The PE connected to the hub site is called a hub-PE.
·     A CE in a spoke site is called a spoke-CE.
·     A PE connected to a spoke site is called a spoke-PE.
·     A link (AC or PW) towards the hub site is called a hub link. You must specify one and only one hub link in a VSI.
·     A link (AC or PW) towards a spoke site is called a spoke link.
In the hub-spoke VPLS network, a PE performs MAC address learning and forwarding as follows:
·     After receiving a packet from a spoke link, the PE performs MAC address learning and forwards the packet to the hub link.
·     After receiving a packet from the hub link, the PE does not learn the MAC address. Instead, it searches the MAC address table to forward the packet to a spoke link.
VPLS configuration task list
To configure a VPLS network, perform the following tasks:
·     Configure an IGP to ensure IP connectivity within the backbone.
·     Configure basic MPLS, GRE, MPLS TE, or LDP to establish public tunnels on the backbone network.
·     Configure VPLS on PEs. For example, configure a VSI, establish a PW, and associate an AC and a VSI.
This chapter describes only VPLS configurations on a PE. For information about other configurations, see relevant configuration guides.
To configure VPLS on a PE, perform the following tasks:
Tasks at a glance
Remarks
(Required.) Enabling L2VPN
N/A
(Required.) Configuring an AC
N/A
(Required.) Configuring a VSI
N/A
Configuring a PW:
·     (Optional.) Configuring a PW class
·     (Required.) Choose either of the following tasks to configure a PW:
¡     Configuring a static PW
¡     Configuring an LDP PW
¡     Configuring a BGP PW
¡     Configuring a BGP auto-discovery LDP PW
Choose a PW configuration method depending on the VPLS implementation.
(Required.) Binding an AC to a VSI
In an H-VPLS using MPLS access, do not perform this task on the access NPEs of the UPEs.
(Optional.) Configuring UPE dual homing:
·     Configuring static PW redundancy
·     Configuring LDP PW redundancy
N/A
(Required.) Configuring MAC address learning
N/A
(Optional.) Enabling SNMP notifications for L2VPN PW
N/A
Enabling L2VPN
Before you enable L2VPN, perform the following tasks:
·     Configure an LSR ID for the PE with the mpls lsr-id command.
·     Enable MPLS with the mpls enable command on the backbone interface of the PE.
To enable L2VPN:
Step
Remarks
N/A
2.     Enable L2VPN.
l2vpn enable
By default, L2VPN is disabled.
Configuring an AC
An AC can be one of the following types on a PE:
·     Layer 3 Ethernet interface—Transparently forwards received packets to the bound VSI.
·     Layer 3 Ethernet subinterface—Forwards received packets to the bound VSI. In this mode, VLANs are unique on a per-interface basis rather than on a per-device basis.
When VLANs are globally unique, packets with the same VLAN ID are forwarded by the same VSI regardless of the receiving interfaces. If VLANs are unique on a per interface basis, packets with the same VLAN ID from different interfaces can be forwarded by different VSIs.
Configuring a Layer 3 interface
To create a Layer 2 link between a PE and a CE, configure the Layer 3 interface that connects the PE to the CE.
The Layer 3 interface can be a Layer 3 Ethernet interface (including physical Layer 3 Ethernet interface and VE-L2VPN interface) or Layer 3 Ethernet subinterface.
For more information about Ethernet interfaces, see Interface Configuration Guide. For more information about VE-L2VPN interfaces, see "Configuring L2VPN access to L3VPN or IP backbone."
Configuring a VSI
Step
Remarks
N/A
2.     Create a VSI and enter VSI view.
vsi vsi-name [ hub-spoke ]
By default, no VSIs exist.
If you specify the hub-spoke keyword for a VSI, the VSI supports the hub-spoke network model.
3.     (Optional.) Configure a description for the VSI.
By default, no description is configured for a VSI.
4.     (Optional.) Set the default PW ID for the VSI.
default-pw-id default-pw-id
By default, no default PW ID is configured for the VSI.
5.     Set an MTU for the VSI.
mtu size
By default, the MTU of a VSI is 1500 bytes.
6.     (Optional.) Enable the VSI.
By default, a VSI is enabled.
Configuring a PW
In a PW class, you can configure PW attributes such as the PW data encapsulation type, and whether to enable control word. To simplify PW configuration, you can configure PWs with the same attributes by referencing the same PW class.
To configure a PW class:
Step
Remarks
N/A
2.     Create a PW class and enter PW class view.
pw-class class-name
By default, no PW classes exist.
3.     (Optional.) Enable control word.
control-word enable
By default, control word is disabled.
4.     (Optional.) Specify the PW data encapsulation type.
pw-type { ethernet | vlan }
By default, the PW data encapsulation type is VLAN.
Step
Remarks
N/A
2.     Enter VSI view.
N/A
3.     Specify static signaling for PWs, and enter VSI static view.
pwsignaling static
By default, no PW signaling protocol is specified.
4.     Configure a static PW, and enter VSI static PW view.
peer ip-address [ pw-id pw-id ] in-label label-value out-label label-value [ hub | no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] *
By default, no static PWs exist.
If both the default PW ID in the default-pw-id command and a PW ID in the peer command are configured, the PW ID in the peer command is used. If only the default PW ID is configured, the default PW ID is used. If no default PW ID is configured, you must provide a PW ID in the peer command.
If a VSI is enabled with the hub-spoke capability (the hub-spoke keyword in the vsi command), PWs in the VSI are spoke links by default. You can use the hub keyword in this command to specify the static PW as the hub link in the VSI.
You must specify the no-split-horizon keyword to disable split horizon when you configure an NPE to establish a U-PW with a UPE.
5.     Set the expected bandwidth for the PW.
bandwidth bandwidth-value
By default, the expected bandwidth is 10000000 kbps.
Before you configure an LDP PW, enable global and interface MPLS LDP on the PE. For information about MPLS LDP configuration, see "Configuring LDP."
To configure an LDP PW:
Step
Remarks
N/A
2.     Enter VSI view.
N/A
3.     Specify LDP signaling for PWs, and enter VSI LDP signaling view.
pwsignaling ldp
4.     Configure an LDP PW, and enter VSI LDP PW view.
peer ip-address [ pw-id pw-id ] [ hub | no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] *
By default, no LDP PWs exist.
If a VSI is enabled with the hub-spoke capability (the hub-spoke keyword in the vsi command), PWs in the VSI are spoke links by default. You can use the hub keyword in this command to specify the LDP PW as the hub link in the VSI.
To configure a BGP PW, perform the following configurations on PEs:
·     Configure BGP to advertise VPLS label block information.
·     Create a BGP PW.
Configuring BGP to advertise VPLS label block information
Step
Remarks
N/A
2.     Enable BGP instance and enter BGP instance view.
By default, BGP is disabled.
3.     Configure the remote PE as a BGP peer.
peer { group-name | ip-address [ mask-length ] } as-number as-number
By default, no BGP peers exist.
4.     Create the BGP L2VPN address family and enter BGP L2VPN address family view.
address-family l2vpn
By default, no BGP L2VPN address family exists.
5.     Enable BGP to exchange L2VPN information with the specified peer or peer group.
By default, BGP cannot exchange L2VPN information with any peer or peer group.
6.     Enable BGP to exchange label block information with the specified peer or peer group.
peer { group-name | ip-address [ mask-length ] } signaling
By default, BGP can exchange label block information with a BGP L2VPN peer or peer group.
7.     (Optional.) Permit the local AS number to appear in routes from the specified peer or peer group and specify the appearance times.
By default, the local AS number is not allowed in routes from a peer or peer group.
8.     (Optional.) Enable route target-based filtering of incoming BGP L2VPN information.
policy vpn-target
By default, route target-based filtering of incoming BGP L2VPN information is enabled.
9.     (Optional.) Configure the router as an RR and specify a peer or peer group as its client.
By default, no RR or client is configured.
10.     (Optional.) Enable L2VPN information reflection between clients.
reflect between-clients
By default, L2VPN information reflection is enabled between clients.
11.     (Optional.) Configure the cluster ID of the RR.
By default, an RR uses its own router ID as the cluster ID.
12.     (Optional.) Configure the filtering of reflected L2VPN information.
By default, the RR does not filter reflected L2VPN information.
13.     (Optional.) Return to user view.
return
N/A
14.     (Optional.) Soft-reset L2VPN BGP sessions.
refresh bgp [ instance instance-name ] { ip-address [ mask-length ] | all | external | group group-name | internal } { export | import } l2vpn
N/A
15.     (Optional.) Reset L2VPN BGP sessions.
reset bgp [ instance instance-name ] { as-number | ip-address [ mask-length ] | all | external | group group-name | internal } l2vpn
N/A
For more information about the peer as-number, peer enable, peer allow-as-loop, peer reflect-client, reflect between-clients, reflector cluster-id, refresh bgp l2vpn, and reset bgp l2vpn commands, see Layer 3—IP Routing Command Reference.
Creating a BGP PW
Step
Remarks
N/A
2.     Enter VSI view.
N/A
3.     Configure the VSI to automatically discover neighbors through BGP and enter auto-discovery VSI view.
auto-discovery bgp
By default, a VSI does not automatically discover neighbors through BGP.
4.     Configure an RD for the auto-discovery VSI.
By default, no RD is configured for the auto-discovery VSI.
5.     Configure route targets for the auto-discovery VSI.
By default, no route targets are configured for the auto-discovery VSI.
6.     (Optional.) Specify a PW class for the auto-discovery VSI.
pw-class class-name
By default, no PW class is specified.
7.     (Optional.) Specify a tunnel policy for the auto-discovery VSI.
By default, no tunnel policy is specified.
8.     Use BGP to create a PW to an automatically discovered remote PE and enter auto-discovery VSI BGP signaling view.
signaling-protocol bgp
By default, no signaling protocol is specified.
9.     Create a local site.
site site-id [ range range-value ] [ default-offset default-offset ]
By default, no local sites exist.
Before you perform this configuration, enable MPLS LDP on interfaces and globally. For more information, see "Configuring LDP."
To configure a BGP auto-discovery LDP PW, perform the following configurations on PEs:
·     Configure BGP to advertise VPLS PE information.
·     Use LDP to create a PW.
Configuring BGP to advertise VPLS PE information
Step
Remarks
N/A
5.     Enable BGP to exchange VPLS PE information with the specified peer or peer group.
By default, BGP cannot exchange VPLS PE information with a peer or peer group.
6.     Enable BGP to exchange VPLS PE information with the specified peer or peer group.
peer { group-name | ip-address [ mask-length ] } auto-discovery [ non-standard ]
By default, BGP can exchange VPLS PE information with a BGP L2VPN peer or peer group by using RFC 6074 MP_REACH_NLRI.
policy vpn-target
return
N/A
N/A
N/A
Creating a BGP auto-discovery LDP PW
Step
Remarks
N/A
2.     Enter VSI view.
N/A
auto-discovery bgp
pw-class class-name
8.     Use LDP to create a PW to an automatically discovered remote PE and enter auto-discovery VSI LDP signaling view.
signaling-protocol ldp
9.     Configure a VPLS ID for the VSI.
vpls-id vpls-id
By default, no VPLS ID is configured.
This task is mutually exclusive from Ethernet link aggregation. If a Layer 3 Ethernet interface has been added to a link aggregation group, you cannot bind the Layer 3 interface to a VSI, and vice versa.
When you bind an AC to a VSI, you can associate Track with the AC. Then, the AC is up only when one or more of the associated track entries are positive.
Associating Track with an AC helps detecting AC failure. For example, when an AC is a VE-L2VPN interface, the interface will not go down upon a link failure because the interface is a virtual interface. To resolve the problem, you can associate Track with the AC to detect failures on the link that connects the PE-agg to the L3VPN or IP backbone. When a failure occurs on the link, the VE-L2VPN interface is set to down. Consequently, the PW bound to the AC goes down. If the PW has a backup PW, traffic can be switched to the backup PW. For more information about VE-L2VPN interfaces and L2VPN access to L3VPN or IP backbone, see "Configuring L2VPN access to L3VPN or IP backbone."
Binding a Layer 3 interface to a VSI
After you bind a Layer 3 interface to a VSI, packets received from the Layer 3 interface are forwarded based on the MAC address table of the VSI.
To bind a Layer 3 interface to a VSI:
Step
Remarks
N/A
2.     Enter Layer 3 interface view.
N/A
3.     Bind the interface to a VSI.
xconnect vsi vsi-name [ hub ] [ track track-entry-number&<1-3> ]
By default, an interface is not bound to any VSI.
If the hub-spoke capability is enabled for a VSI, an AC in the VSI is a spoke link by default. You can use the hub keyword to specify the AC as a hub link.
This task includes the following configurations:
·     Create a backup PW for the primary PW.
·     Specify whether to switch traffic from the backup PW to the primary PW when the primary PW recovers, and set the wait time for the switchover.
·     Perform a manual PW switchover.
Step
Remarks
N/A
2.     Enter VSI view.
N/A
pwsignaling static
By default, no PW signaling protocol is specified for the VSI.
4.     (Optional.) Specify the switchover mode and set the wait time for the switchover.
revertive { wtr wtr-time | never }
By default, the switchover mode is revertive and the switchover wait time is 0 seconds.
5.     Configure a static PW and enter VSI static PW view.
peer ip-address [ pw-id pw-id ] [ in-label label-value out-label label-value ] [ hub | no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] *
6.     Configure a backup static PW and enter VSI static backup PW view.
backup-peer ip-address [ pw-id pw-id ] in-label label-value out-label label-value [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
By default, no backup static PW exists.
If both the default PW ID in the default-pw-id command and a PW ID in the backup-peer command are configured, the PW ID in the backup-peer command is used. If only the default PW ID is configured, the default PW ID is used. If no default PW ID is configured, you must provide a PW ID in the backup-peer command.
7.     Return to user view.
return
N/A
8.     Manually switch traffic of the specified PW to its backup PW.
l2vpn switchover peer ip-address pw-id pw-id
N/A
Step
Remarks
N/A
2.     Enter VSI view.
N/A
pwsignaling ldp
5.     Configure an LDP PW and enter VSI LDP PW view.
6.     Configure a backup LDP PW and enter VSI LDP backup PW view.
backup-peer ip-address [ pw-id pw-id ] [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
By default, no backup LDP PW exists.
return
N/A
N/A
Step
Remarks
N/A
2.     Enter VSI view.
N/A
3.     Enable MAC address learning for the VSI.
mac-learning enable
By default, MAC address learning is enabled for a VSI.
4.     Set the maximum number of MAC addresses that the VSI can learn.
mac-table limit mac-limit
By default, the number of MAC addresses that a VSI can learn is not limited.
This feature enables L2VPN to generate SNMP notifications when PW deletions, PW switchovers, or PW status changes occur. For L2VPN event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
To enable SNMP notifications for L2VPN PW:
Step
Remarks
N/A
2.     Enable SNMP notifications for L2VPN PW.
snmp-agent trap enable l2vpn [ pw-delete | pw-switch | pw-up-down ] *
By default, SNMP notifications for L2VPN PW are disabled.
Displaying and maintaining VPLS
Display LDP PW label information.
display l2vpn ldp [ peer ip-address [ pw-id pw-id | vpls-id vpls-id ] | vsi vsi-name ] [ verbose ]
Display L2VPN forwarding information (in standalone mode).
display l2vpn forwarding { ac | pw } [ vsi vsi-name ] [ slot slot-number ] [ verbose ]
Display L2VPN forwarding information (in IRF mode).
display l2vpn forwarding { ac | pw } [ vsi vsi-name ] [ chassis chassis-number slot slot-number ] [ verbose ]
Display MAC address table information for one or all VSIs.
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count ]
Display L2VPN information for Layer 3 interfaces bound to VSIs.
display l2vpn interface [ vsi vsi-name | interface-type interface-number ] [ verbose ]
Display L2VPN PW information.
display l2vpn pw [ vsi vsi-name ] [ protocol { bgp | ldp | static } ] [ verbose ]
Display PW class information.
display l2vpn pw-class [ class-name ] [ verbose ]
Display VSI information.
display l2vpn vsi [ name vsi-name ] [ verbose ]
Display information about automatically discovered VPLS PEs.
display l2vpn auto-discovery [ peer ip-address ] [ vsi vsi-name ]
Display VPLS label block information.
display l2vpn bgp [ instance instance-name ] [ peer ip-address | local ] [ vsi vsi-name ] [ verbose ]
Display BGP L2VPN peer group information.
display bgp [ instance instance-name ] group l2vpn [ group-name group-name ]
Display VPLS PE information discovered by BGP.
display bgp [ instance instance-name ] l2vpn auto-discovery [ peer ip-address { advertised | received } [ statistics ] | route-distinguisher route-distinguisher [ pe-address ip-address [ advertise-info ] ] | statistics ]
Display VPLS label block information discovered by BGP.
display bgp [ instance instance-name ] l2vpn signaling [ peer ip-address { advertised | received } [ statistics ] | route-distinguisher route-distinguisher [ site-id site-id [ label-offset label-offset [ advertise-info ] ] ] | statistics ]
Display BGP L2VPN peer information.
display bgp [ instance instance-name ] peer l2vpn [ ip-address mask-length | group-name group-name log-info | ip-address { log-info | verbose } | verbose ]
Display BGP L2VPN update group information.
display bgp [ instance instance-name ] update-group l2vpn [ ip-address ]
Clear MAC address entries for one or all VSIs.
reset l2vpn mac-address [ vsi vsi-name ]
reset bgp { as-number | ip-address [ mask-length ] | all | external | group group-name | internal } l2vpn
For more information about the display bgp group l2vpn, display bgp peer l2vpn, display bgp update-group l2vpn, and reset bgp l2vpn commands, see Layer 3—IP Routing Command Reference.
VPLS configuration examples
Static PW configuration example
Network requirements
CEs are connected to the PEs through Layer 3 Ethernet interfaces (GigabitEthernet 2/1/1).
Configure a VSI on each PE, and establish static PWs between the PEs to interconnect the CEs.
Figure 7 Network diagram
Configuration procedure
·     Configure basic MPLS on each PE: configure LSR ID, enable LDP, run IGP (OSPF in this example) to establish LSPs.
·     Establish static PWs: enable L2VPN, create static PWs, and specify labels.
1.     Configure PE 1:
# Configure an LSR ID.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 1.1.1.9
# Enable L2VPN.
[PE1] l2vpn enable
# Enable global LDP.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure GigabitEthernet 2/1/2 (the interface connected to PE 2), and enable LDP on the interface.
[PE1] interface gigabitethernet 2/1/2
[PE1-GigabitEthernet2/1/2] ip address 20.1.1.1 24
[PE1-GigabitEthernet2/1/2] mpls enable
[PE1-GigabitEthernet2/1/2] mpls ldp enable
[PE1-GigabitEthernet2/1/2] quit
# Configure GigabitEthernet 2/1/3 (the interface connected to PE 3), and enable LDP on the interface.
[PE1] interface gigabitethernet 2/1/3
[PE1-GigabitEthernet2/1/3] ip address 30.1.1.1 24
[PE1-GigabitEthernet2/1/3] mpls enable
[PE1-GigabitEthernet2/1/3] mpls ldp enable
[PE1-GigabitEthernet2/1/3] quit
# Configure OSPF for LDP to create LSPs.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# Create a VSI, specify the peer PEs, and establish static PWs to the peer PEs.
[PE1] vsi svc
[PE1-vsi-svc] pwsignaling static
[PE1-vsi-svc-static] peer 2.2.2.9 pw-id 3 in-label 100 out-label 100
[PE1-vsi-svc-static-2.2.2.9-3] quit
[PE1-vsi-svc-static] peer 3.3.3.9 pw-id 3 in-label 200 out-label 200
[PE1-vsi-svc-static-3.3.3.9-3] quit
[PE1-vsi-svc-static] quit
[PE1-vsi-svc] quit
# Bind Layer 3 Ethernet interface GigabitEthernet 2/1/1 to VSI svc.
[PE1] interface gigabitethernet 2/1/1
[PE1-GigabitEthernet2/1/1] xconnect vsi svc
[PE1-GigabitEthernet2/1/1] quit
2.     Configure PE 2:
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 2.2.2.9
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
# Configure GigabitEthernet 2/1/2 (the interface connected to PE 1), and enable LDP on the interface.
[PE2] interface gigabitethernet 2/1/2
[PE2-GigabitEthernet2/1/2] ip address 20.1.1.2 24
[PE2-GigabitEthernet2/1/2] mpls enable
[PE2-GigabitEthernet2/1/2] mpls ldp enable
[PE2-GigabitEthernet2/1/2] quit
[PE2] interface gigabitethernet 2/1/3
[PE2-GigabitEthernet2/1/3] ip address 40.1.1.2 24
[PE2-GigabitEthernet2/1/3] mpls enable
[PE2-GigabitEthernet2/1/3] mpls ldp enable
[PE2-GigabitEthernet2/1/3] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[PE2-ospf-1] quit
[PE2] vsi svc
[PE2-vsi-svc] pwsignaling static
[PE2-vsi-svc-static] peer 1.1.1.9 pw-id 3 in-label 100 out-label 100
[PE2-vsi-svc-static-1.1.1.9-3] quit
[PE2-vsi-svc-static] peer 3.3.3.9 pw-id 3 in-label 300 out-label 300
[PE2-vsi-svc-static-3.3.3.9-3] quit
[PE2-vsi-svc-static] quit
[PE2-vsi-svc] quit
[PE2] interface gigabitethernet 2/1/1
[PE2-GigabitEthernet2/1/1] xconnect vsi svc
[PE2-GigabitEthernet2/1/1] quit
3.     Configure PE 3:
<PE3> system-view
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 3.3.3.9 32
[PE3-LoopBack0] quit
[PE3] mpls lsr-id 3.3.3.9
# Enable L2VPN.
[PE3] l2vpn enable
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] interface gigabitethernet 2/1/2
[PE3-GigabitEthernet2/1/2] ip address 30.1.1.3 24
[PE3-GigabitEthernet2/1/2] mpls enable
[PE3-GigabitEthernet2/1/2] mpls ldp enable
[PE3-GigabitEthernet2/1/2] quit
# Configure GigabitEthernet 2/1/3 (the interface connected to PE 2), and enable LDP on the interface.
[PE3] interface gigabitethernet 2/1/3
[PE3-GigabitEthernet2/1/3] ip address 40.1.1.3 24
[PE3-GigabitEthernet2/1/3] mpls enable
[PE3-GigabitEthernet2/1/3] mpls ldp enable
[PE3-GigabitEthernet2/1/3] quit
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE3-ospf-1] quit
[PE3] vsi svc
[PE3-vsi-svc] pwsignaling static
[PE3-vsi-svc-static] peer 1.1.1.9 pw-id 3 in-label 200 out-label 200
[PE3-vsi-svc-static-1.1.1.9-3] quit
[PE3-vsi-svc-static] peer 2.2.2.9 pw-id 3 in-label 300 out-label 300
[PE3-vsi-svc-static-2.2.2.9-3] quit
[PE3-vsi-svc-static] quit
[PE3-vsi-svc] quit
[PE3] interface gigabitethernet 2/1/1
[PE3-GigabitEthernet2/1/1] xconnect vsi svc
[PE3-GigabitEthernet2/1/1] quit
# Verify that two static PWs in up state have been established on PE 1.
[PE1] display l2vpn pw verbose
VSI Name: svc
  Peer: 2.2.2.9          PW ID: 3
    Signaling Protocol  : Static
    Link ID             : 8          PW State : Up
    In Label            : 100        Out Label: 100
    MTU                 : 1500
    PW Attributes       : Main
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x160000001
    Tunnel NHLFE IDs    : 1027
  Peer: 3.3.3.9          PW ID: 3
    Link ID             : 9          PW State : Up
    In Label            : 200        Out Label: 200
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x260000002
    Tunnel NHLFE IDs    : 1028
LDP PW configuration example
Configure a VSI on each PE, and establish LDP PWs between the PEs to interconnect the CEs.
Figure 8 Network diagram
1.     Configure an IGP and public tunnels on each PE. (Details not shown.)
2.     Configure PE 1:
# Configure basic MPLS.
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] quit
# Enable L2VPN.
[PE1] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to PE 2 and PE 3.
[PE1] vsi aaa
[PE1-vsi-aaa] pwsignaling ldp
[PE1-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[PE1-vsi-aaa-ldp-2.2.2.9-500] quit
[PE1-vsi-aaa-ldp] peer 3.3.3.9 pw-id 500
[PE1-vsi-aaa-ldp-3.3.3.9-500] quit
[PE1-vsi-aaa-ldp] quit
[PE1-vsi-aaa] quit
# Bind Layer 3 Ethernet interface GigabitEthernet 2/1/1 to VSI aaa.
[PE1-GigabitEthernet2/1/1] xconnect vsi aaa
3.     Configure PE 2:
<PE2> system-view
[PE2] mpls ldp
[PE2-ldp] quit
# Enable L2VPN.
[PE2] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to PE 1 and PE 3.
[PE2] vsi aaa
[PE2-vsi-aaa] pwsignaling ldp
[PE2-vsi-aaa-ldp] peer 1.1.1.9 pw-id 500
[PE2-vsi-aaa-ldp-1.1.1.9-500] quit
[PE2-vsi-aaa-ldp] peer 3.3.3.9 pw-id 500
[PE2-vsi-aaa-ldp-3.3.3.9-500] quit
[PE2-vsi-aaa-ldp] quit
[PE2-vsi-aaa] quit
[PE2-GigabitEthernet2/1/1] xconnect vsi aaa
4.     Configure PE 3:
<PE3> system-view
[PE3] mpls ldp
[PE3-ldp] quit
# Enable L2VPN.
[PE3] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to PE 1 and PE 2.
[PE3] vsi aaa
[PE3-vsi-aaa] pwsignaling ldp
[PE3-vsi-aaa-ldp] peer 1.1.1.9 pw-id 500
[PE3-vsi-aaa-ldp-1.1.1.9-500] quit
[PE3-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[PE3-vsi-aaa-ldp-2.2.2.9-500] quit
[PE3-vsi-aaa-ldp] quit
[PE3-vsi-aaa] quit
[PE3-GigabitEthernet2/1/1] xconnect vsi aaa
# Verify that two LDP PWs in up state have been established on PE 1.
VSI Name: aaa
  Peer: 2.2.2.9          PW ID: 500
    Signaling Protocol  : LDP
    In Label            : 1279       Out Label: 1279
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x260000000
  Peer: 3.3.3.9          PW ID: 500
    In Label            : 1278       Out Label: 1277
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x360000001
    Tunnel NHLFE IDs    : 1029
BGP PW configuration example
Configure a VSI on each PE, and establish BGP PWs between the PEs to interconnect CEs.
Figure 9 Network diagram
2.     Configure PE 1:
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] quit
# Establish IBGP connections to PE 2 and PE 3, and use BGP to advertise VPLS label block information.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.9 as-number 100
[PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-default] address-family l2vpn
[PE1-bgp-default-l2vpn] peer 2.2.2.9 enable
[PE1-bgp-default-l2vpn] peer 3.3.3.9 enable
[PE1-bgp-default-l2vpn] quit
[PE1-bgp-default] quit
# Enable L2VPN.
[PE1] l2vpn enable
# Configure VSI aaa to use BGP to establish BGP PWs to PE 2 and PE 3.
[PE1] vsi aaa
[PE1-vsi-aaa] auto-discovery bgp
[PE1-vsi-aaa-auto] route-distinguisher 1:1
[PE1-vsi-aaa-auto] vpn-target 1:1
[PE1-vsi-aaa-auto] signaling-protocol bgp
[PE1-vsi-aaa-auto-bgp] site 1 range 10 default-offset 0
[PE1-vsi-aaa-auto-bgp] quit
[PE1-vsi-aaa-auto] quit
[PE1-vsi-aaa] quit
3.     Configure PE 2:
<PE2> system-view
[PE2] mpls ldp
[PE2-ldp] quit
# Establish IBGP connections to PE 1 and PE 3, and use BGP to advertise VPLS label block information.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default] peer 3.3.3.9 as-number 100
[PE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[PE2-bgp-default] address-family l2vpn
[PE2-bgp-default-l2vpn] peer 1.1.1.9 enable
[PE2-bgp-default-l2vpn] peer 3.3.3.9 enable
[PE2-bgp-default-l2vpn] quit
[PE2-bgp-default] quit
# Enable L2VPN.
[PE2] l2vpn enable
# Configure VSI aaa to use BGP to establish BGP PWs to PE 1 and PE 3.
[PE2] vsi aaa
[PE2-vsi-aaa] auto-discovery bgp
[PE2-vsi-aaa-auto] route-distinguisher 1:1
[PE2-vsi-aaa-auto] vpn-target 1:1
[PE2-vsi-aaa-auto] signaling-protocol bgp
[PE2-vsi-aaa-auto-bgp] site 2 range 10 default-offset 0
[PE2-vsi-aaa-auto-bgp] quit
[PE2-vsi-aaa-auto] quit
[PE2-vsi-aaa] quit
4.     Configure PE 3:
<PE3> system-view
[PE3] mpls ldp
[PE3-ldp] quit
# Establish IBGP connections to PE 1 and PE 2, and use BGP to advertise VPLS label block information.
[PE3] bgp 100
[PE3-bgp-default] peer 1.1.1.9 as-number 100
[PE3-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE3-bgp-default] peer 2.2.2.9 as-number 100
[PE3-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE3-bgp-default] address-family l2vpn
[PE3-bgp-default-l2vpn] peer 1.1.1.9 enable
[PE3-bgp-default-l2vpn] peer 2.2.2.9 enable
[PE3-bgp-default-l2vpn] quit
[PE3-bgp-default] quit
# Enable L2VPN.
[PE3] l2vpn enable
# Configure VSI aaa to use BGP to establish BGP PWs to PE 1 and PE 2.
[PE3] vsi aaa
[PE3-vsi-aaa] auto-discovery bgp
[PE3-vsi-aaa-auto] route-distinguisher 1:1
[PE3-vsi-aaa-auto] vpn-target 1:1
[PE3-vsi-aaa-auto] signaling-protocol bgp
[PE3-vsi-aaa-auto-bgp] site 3 range 10 default-offset 0
[PE3-vsi-aaa-auto-bgp] quit
[PE3-vsi-aaa-auto] quit
[PE3-vsi-aaa] quit
# Verify that two BGP PWs in up state have been established on PE 1.
VSI Name: aaa
  Peer: 2.2.2.9          Remote Site: 2
    Signaling Protocol  : BGP
    In Label            : 1295       Out Label: 1025
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x800000160000001
  Peer: 3.3.3.9          Remote Site: 3
    Link ID             : 10         PW State : Up
    In Label            : 1296       Out Label: 1025
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x800000060000000
    Tunnel NHLFE IDs    : 1026
# Display VPLS label block information received from PE 2 and PE 3 on PE 1.
[PE1] display l2vpn bgp verbose
VSI Name: aaa
 Remote Site ID     : 2
 Offset             : 0
 RD                 : 1:1
 PW State           : Up
 Encapsulation      : BGP-VPLS
 MTU                : 1500
 Nexthop            : 2.2.2.9
 Local VC Label     : 1295
 Remote VC Label    : 1025
 Link ID            : 9
 Local Label Block  : 1293/10/0
 Remote Label Block : 1024/10/0
 Export Route Target: 1:1
 Remote Site ID     : 3
 Offset             : 0
 RD                 : 1:1
 PW State           : Up
 MTU                : 1500
 Nexthop            : 3.3.3.9
 Local VC Label     : 1296
 Link ID            : 10
BGP auto-discovery LDP PW configuration example
Configure a VSI on each PE. Use BGP to discover remote PEs and use LDP to create PWs among PEs so CEs in different sites of VPN 1 can communicate with each other.
Figure 10 Network diagram
2.     Configure PE 1:
<PE1> system-view
[PE1] mpls ldp
[PE1-ldp] quit
# Establish IBGP connections to PE 1 and PE 2, and use BGP to advertise VPLS PE information.
[PE1] bgp 100
# Enable L2VPN.
[PE1] l2vpn enable
# Configure VSI aaa to use BGP to discover remote PEs and use LDP to establish LDP PWs to PE 2 and PE 3.
[PE1] vsi aaa
[PE1-vsi-aaa-auto] signaling-protocol ldp
[PE1-vsi-aaa-auto-ldp] vpls-id 100:100
[PE1-vsi-aaa-auto-ldp] quit
[PE1-vsi-aaa] quit
3.     Configure PE 2:
<PE2> system-view
[PE2] mpls ldp
[PE2-ldp] quit
# Establish IBGP connections to PE 1 and PE 3, and use BGP to advertise VPLS PE information.
[PE2] bgp 100
# Enable L2VPN.
[PE2] l2vpn enable
# Configure VSI aaa to use BGP to discover remote PEs and use LDP to establish LDP PWs to PE 1 and PE 3.
[PE2] vsi aaa
[PE2-vsi-aaa-auto] signaling-protocol ldp
[PE2-vsi-aaa-auto-ldp] vpls-id 100:100
[PE2-vsi-aaa-auto-ldp] quit
[PE2-vsi-aaa] quit
4.     Configure PE 3:
<PE3> system-view
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] bgp 100
# Enable L2VPN.
[PE3] l2vpn enable
# Configure VSI aaa to use BGP to discover remote PEs and use LDP to establish LDP PWs to PE 1 and PE 2.
[PE3] vsi aaa
[PE3-vsi-aaa-auto] signaling-protocol ldp
[PE3-vsi-aaa-auto-ldp] vpls-id 100:100
[PE3-vsi-aaa-auto-ldp] quit
[PE3-vsi-aaa] quit
# Verify that two PWs in up state have been established on PE 1.
VSI Name: aaa
  Peer: 2.2.2.9          VPLS ID: 100:100
    In Label            : 1555       Out Label: 1555
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
  Peer: 3.3.3.9          VPLS ID: 100:100
    In Label            : 1554       Out Label: 1416
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel NHLFE IDs    : 1030
# Display LDP PW label information on PE 1.
[PE1] display l2vpn ldp verbose
  VSI Name: aaa
  PW State: Up
  PW Status Communication: Notification method
  PW ID FEC (Local/Remote):
    Local AII   : (1.1.1.9, 2.2.2.9)
    Remote AII  : (2.2.2.9, 1.1.1.9)
    PW Type     : Ethernet/Ethernet
    Group ID    : 0/0
    Label       : 1555/1555
    Control Word: Disabled/Disabled
    VCCV CV Type: -/-
    VCCV CC Type: -/-
    MTU         : 1500/1500
    PW Status   : PW forwarding/PW forwarding
  VSI Name: aaa
  PW State: Up
    Local AII   : (1.1.1.9, 3.3.3.9)
    Remote AII  : (3.3.3.9, 1.1.1.9)
    Group ID    : 0/0
    Label       : 1554/1416
    VCCV CV Type: -/-
    VCCV CC Type: -/-
    MTU         : 1500/1500
H-VPLS using MPLS access configuration example
Configure an H-VPLS network using MPLS access to avoid full-mesh PW configuration. The H-VPLS uses LDP as the PW signaling protocol.
Figure 11 Network diagram
2.     Configure UPE:
<UPE> system-view
[UPE] interface loopback 0
[UPE-LoopBack0] ip address 1.1.1.9 32
[UPE-LoopBack0] quit
[UPE] mpls lsr-id 1.1.1.9
[UPE] mpls ldp
[UPE-ldp] quit
# Enable L2VPN.
[UPE] l2vpn enable
# Configure VSI aaa to use LDP to establish a U-PW to NPE 1.
[UPE] vsi aaa
[UPE-vsi-aaa] pwsignaling ldp
[UPE-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[UPE-vsi-aaa-ldp-2.2.2.9-500] quit
[UPE-vsi-aaa-ldp] quit
[UPE-vsi-aaa] quit
[UPE] interface gigabitethernet 2/1/1
[UPE-GigabitEthernet2/1/1] xconnect vsi aaa
[UPE-GigabitEthernet2/1/1] quit
3.     Configure NPE 1:
<NPE1> system-view
[NPE1] interface loopback 0
[NPE1-LoopBack0] ip address 2.2.2.9 32
[NPE1-LoopBack0] quit
[NPE1] mpls lsr-id 2.2.2.9
[NPE1] mpls ldp
[NPE1–ldp] quit
# Enable L2VPN.
[NPE1] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, establish a U-PW to the UPE, and establish N-PWs to NPE 2 and NPE 3.
[NPE1] vsi aaa
[NPE1-vsi-aaa] pwsignaling ldp
[NPE1-vsi-aaa-ldp] peer 1.1.1.9 pw-id 500 no-split-horizon
[NPE1-vsi-aaa-ldp-1.1.1.9-500] quit
[NPE1-vsi-aaa-ldp] peer 3.3.3.9 pw-id 500
[NPE1-vsi-aaa-ldp-3.3.3.9-500] quit
[NPE1-vsi-aaa-ldp] peer 4.4.4.9 pw-id 500
[NPE1-vsi-aaa-ldp-4.4.4.9-500] quit
[NPE1-vsi-aaa-ldp] quit
[NPE1-vsi-aaa] quit
4.     Configure NPE 2:
<NPE2> system-view
[NPE2] interface loopback 0
[NPE2-LoopBack0] ip address 3.3.3.9 32
[NPE2-LoopBack0] quit
[NPE2] mpls lsr-id 3.3.3.9
[NPE2] mpls ldp
[NPE2–ldp] quit
# Enable L2VPN.
[NPE2] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish N-PWs to NPE 1 and NPE 3.
[NPE2] vsi aaa
[NPE2-vsi-aaa] pwsignal ldp
[NPE2-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[NPE2-vsi-aaa-ldp-2.2.2.9-500] quit
[NPE2-vsi-aaa-ldp] peer 4.4.4.9 pw-id 500
[NPE2-vsi-aaa-ldp-4.4.4.9-500] quit
[NPE2-vsi-aaa-ldp] quit
[NPE2-vsi-aaa] quit
[NPE2] interface gigabitethernet 2/1/1
[NPE2-GigabitEthernet2/1/1] xconnect vsi aaa
[NPE2-GigabitEthernet2/1/1] quit
5.     Configure NPE 3:
<NPE3> system-view
[NPE3] interface loopback 0
[NPE3-LoopBack0] ip address 4.4.4.9 32
[NPE3-LoopBack0] quit
[NPE3] mpls lsr-id 4.4.4.9
[NPE3] mpls ldp
[NPE3–ldp] quit
# Enable L2VPN.
[NPE3] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish N-PWs to NPE 1 and NPE 2.
[NPE3] vsi aaa
[NPE3-vsi-aaa] pwsignal ldp
[NPE3-vsi-aaa-ldp] peer 2.2.2.9 pw-id 500
[NPE3-vsi-aaa-ldp-2.2.2.9-500] quit
[NPE3-vsi-aaa-ldp] peer 3.3.3.9 pw-id 500
[NPE3-vsi-aaa-ldp-3.3.3.9-500] quit
[NPE3-vsi-aaa-ldp] quit
[NPE3-vsi-aaa] quit
[NPE3] interface gigabitethernet 2/1/1
[NPE3-GigabitEthernet2/1/1] xconnect vsi aaa
[NPE3-GigabitEthernet2/1/1] quit
# Verify that PWs in up state have been established on each PE.
[UPE] display l2vpn pw verbose
VSI Name: aaa
    In Label            : 1277       Out Label: 1277
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x460000000
[NPE1] display l2vpn pw verbose
VSI Name: aaa
  Peer: 1.1.1.9          PW ID: 500
    MTU                 : 1500
    PW Attributes       : Main, No-split-horizon
    VCCV CC             : -
    VCCV BFD            : -
    In Label            : 1276       Out Label: 1275
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x560000001
    Tunnel NHLFE IDs    : 1031
  Peer: 4.4.4.9          PW ID: 500
    In Label            : 1278       Out Label: 1279
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x570000001
    Tunnel NHLFE IDs    : 1032
[NPE2] display l2vpn pw verbose
VSI Name: aaa
    In Label            : 1275       Out Label: 1276
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x660000000
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x670000000
[NPE3] display l2vpn pw verbose
VSI Name: aaa
    In Label            : 1279       Out Label: 1278
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
H-VPLS UPE dual homing configuration example
To improve reliability of the H-VPLS network, the UPE establishes a U-PW with NPE 1 and NPE 2. The U-PW between UPE and NPE 1 is the primary PW and that between UPE and NPE 2 is the backup PW. The backup PW works only when the primary PW fails.
Figure 12 Network diagram
2.     Configure UPE:
<UPE> system-view
[UPE-LoopBack0] ip address 1.1.1.1 32
[UPE] mpls lsr-id 1.1.1.1
[UPE] mpls ldp
[UPE-ldp] quit
# Enable L2VPN.
[UPE] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish the primary PW to NPE 1 and the backup PW to NPE 2.
[UPE] vsi aaa
[UPE-vsi-aaa-ldp] peer 2.2.2.2 pw-id 500
[UPE-vsi-aaa-ldp-2.2.2.2-500] backup-peer 3.3.3.3 pw-id 500
[UPE-vsi-aaa-ldp-3.3.3.3-500-backup] quit
[UPE-vsi-aaa-ldp-2.2.2.2-500] quit
[UPE-vsi-aaa] quit
# Bind the CE 1-facing Layer 3 Ethernet interface GigabitEthernet 2/1/1 to VSI aaa.
# Bind the CE 2-facing Layer 3 Ethernet interface GigabitEthernet 2/1/2 to VSI aaa.
[UPE] interface gigabitethernet 2/1/2
[UPE-GigabitEthernet2/1/2] xconnect vsi aaa
[UPE-GigabitEthernet2/1/2] quit
3.     Configure NPE 1:
<NPE1> system-view
[NPE1-LoopBack0] ip address 2.2.2.2 32
[NPE1] mpls lsr-id 2.2.2.2
[NPE1] mpls ldp
[NPE1–ldp] quit
# Enable L2VPN.
[NPE1] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to UPE, NPE 2, and NPE 3.
[NPE1] vsi aaa
[NPE1-vsi-aaa-ldp] peer 1.1.1.1 pw-id 500 no-split-horizon
[NPE1-vsi-aaa-ldp-1.1.1.1-500] quit
[NPE1-vsi-aaa-ldp] peer 3.3.3.3 pw-id 500
[NPE1-vsi-aaa-ldp-3.3.3.3-500] quit
[NPE1-vsi-aaa-ldp] peer 4.4.4.4 pw-id 500
[NPE1-vsi-aaa-ldp-4.4.4.4-500] quit
[NPE1-vsi-aaa] quit
4.     Configure NPE 2:
<NPE2> system-view
[NPE2-LoopBack0] ip address 3.3.3.3 32
[NPE2] mpls lsr-id 3.3.3.3
[NPE2] mpls ldp
[NPE2–ldp] quit
# Enable L2VPN.
[NPE2] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to UPE, NPE 1, and NPE 3.
[NPE2] vsi aaa
[NPE2-vsi-aaa] pwsignaling ldp
[NPE2-vsi-aaa-ldp] peer 1.1.1.1 pw-id 500 no-split-horizon
[NPE2-vsi-aaa-ldp-1.1.1.1-500] quit
[NPE2-vsi-aaa-ldp] peer 2.2.2.2 pw-id 500
[NPE2-vsi-aaa-ldp-2.2.2.2-500] quit
[NPE2-vsi-aaa-ldp] peer 4.4.4.4 pw-id 500
[NPE2-vsi-aaa-ldp-4.4.4.4-500] quit
[NPE2-vsi-aaa] quit
5.     Configure NPE 3:
<NPE3> system-view
[NPE3-LoopBack0] ip address 4.4.4.4 32
[NPE3] mpls lsr-id 4.4.4.4
[NPE3] mpls ldp
[NPE3–ldp] quit
# Enable L2VPN.
[NPE3] l2vpn enable
# Configure VSI aaa that uses LDP as the PW signaling protocol, and establish PWs to NPE 1 and NPE 2.
[NPE3] vsi aaa
[NPE3-vsi-aaa] pwsignaling ldp
[NPE3-vsi-aaa-ldp] peer 2.2.2.2 pw-id 500
[NPE3-vsi-aaa-ldp-2.2.2.2-500] quit
[NPE3-vsi-aaa-ldp] peer 3.3.3.3 pw-id 500
[NPE3-vsi-aaa-ldp-3.3.3.3-500] quit
[NPE3-vsi-aaa] quit
VSI Name: aaa
  Peer: 2.2.2.2          PW ID: 500
    In Label            : 1151       Out Label: 1279
    Wait to Restore Time: 0 sec
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
  Peer: 3.3.3.3          PW ID: 500
    Link ID             : 8          PW State : Blocked
    In Label            : 1150       Out Label: 1279
    MTU                 : 1500
    PW Attributes       : Backup
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x360000003
    Tunnel NHLFE IDs    : 1025
VSI Name: aaa
  Peer: 1.1.1.1          PW ID: 500
    In Label            : 1279       Out Label: 1151
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x60000000
    In Label            : 1280       Out Label: 1290
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x160000005
  Peer: 4.4.4.4          PW ID: 500
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
VSI Name: aaa
    In Label            : 1279       Out Label: 1150
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    In Label            : 1290       Out Label: 1280
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x160000008
    In Label            : 1278       Out Label: 1278
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
VSI Name: aaa
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
  • Become a Partner
  • Partner Resources
