- 08-IP Multicast Configuration Guide
- 01-Multicast Overview
- 02-Multicast routing and forwarding configuration
- 03-IGMP configuration
- 04-PIM configuration
- 05-MSDP configuration
- 06-Multicast VPN configuration
- 07-IPv6 multicast routing and forwarding configuration
- 08-MLD configuration
- 09-IPv6 PIM configuration
| 00-Preface | 83.27 KB |
Preface
This configuration guide covers Layer 3 IPv4 multicast protocols and Layer 3 IPv6 multicast protocols.
· Audience.
Audience
· Network planners.
· Network administrators working with the routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Obtaining documentation
To access the most up-to-date H3C product documentation, go to the H3C website at
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
Documentation feedback
We appreciate your comments.
