02-Virtual Technologies Configuration Guide
HomeSupportResource CenterRoutersH3C SR6600-X Router SeriesH3C SR6600-X Router SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C SR6600 SR6600-X Routers Configuration Guides-R7607-6W10002-Virtual Technologies Configuration Guide
01-IRF configuration
01-IRF configuration 409.09 KB
Setting up an IRF fabric· 1
Overview· 1
Network topology· 2
Basic concepts· 2
Configuration synchronization· 5
Loop elimination mechanism·· 5
Master election· 5
Multi-active handling procedure· 6
MAD mechanisms· 6
Hardware compatibility· 9
General restrictions and configuration guidelines· 9
IRF fabric size· 9
Software requirements· 10
MPU requirements· 10
IRF physical interface requirements· 10
Connecting IRF ports· 11
MDC configuration restrictions· 11
Configuration backup· 11
Setup and configuration task list 11
Planning the IRF fabric setup· 12
Preconfiguring IRF member devices in standalone mode· 13
Assigning a member ID to each IRF member device· 13
Specifying a priority for each member device· 13
Binding physical interfaces to IRF ports· 13
Saving configuration to the next-startup configuration file· 14
Connecting IRF physical interfaces· 14
Setting the operating mode to IRF mode· 15
Accessing the IRF fabric· 15
Configuring MAD·· 16
Configuring LACP MAD·· 16
Configuring BFD MAD·· 17
Excluding a service interface from the shutdown action upon detection of multi-active collision· 18
Recovering an IRF fabric· 19
Configuring IRF member devices in IRF mode· 20
Bulk-configuring basic IRF settings for a device in IRF mode· 20
Changing the member ID of a device· 21
Changing the priority of a member device· 21
Adding physical interfaces to an IRF port 22
Enabling IRF auto-merge· 23
Configuring a member device description· 24
Configuring IRF link load sharing mode· 24
Configuring IRF bridge MAC persistence· 25
Enabling software auto-update for software image synchronization· 25
Setting the IRF link down report delay· 26
Displaying and maintaining an IRF fabric· 27
IRF configuration examples· 27
LACP MAD-enabled IRF configuration example· 27
BFD MAD-enabled IRF configuration example· 30
Configuration example for restoring standalone mode· 32
Overview
The Intelligent Resilient Framework (IRF) technology virtualizes multiple physical devices at the same layer into one virtual fabric to provide data center class availability and scalability. IRF virtualization technology offers processing power, interaction, unified management, and uninterrupted maintenance of multiple devices.
Figure 1 shows an IRF fabric that has two devices, which appear as a single node to the upper-layer and lower-layer devices.
Figure 1 IRF application scenario
IRF provides the following benefits:
·     Simplified topology and easy management—An IRF fabric appears as one node and is accessible at a single IP address on the network. You can use this IP address to log in at any member device to manage all the members of the IRF fabric. In addition, you do not need to run the spanning tree feature among the IRF members.
·     1:N redundancy—In an IRF fabric, one member acts as the master to manage and control the entire IRF fabric. All the other members process services while backing up the master. When the master fails, all the other member devices elect a new master from among them to take over without interrupting services.
·     IRF link aggregation—You can assign several physical links between neighboring members to their IRF ports to create a load-balanced aggregate IRF connection with redundancy.
·     Multichassis link aggregation—You can use the Ethernet link aggregation feature to aggregate the physical links between the IRF fabric and its upstream or downstream devices across the IRF members.
·     Network scalability and resiliency—Processing capacity of an IRF fabric equals the total processing capacities of all the members. You can increase ports, network bandwidth, and processing capacity of an IRF fabric simply by adding member devices without changing the network topology.
As shown in Figure 2, Device A and Device B form a two-chassis IRF fabric. The fabric has four MPUs (one active and three standbys), and two times the number of interface modules that a single device provides. The IRF fabric manages the physical and software resources of Device A and Device B in a centralized manner.
Figure 2 Two-chassis IRF fabric implementation schematic diagram
Network topology
An IRF fabric can use a daisy-chain topology. For information about connecting IRF member devices, see "Connecting IRF physical interfaces."
Basic concepts
Operating mode
The device operates in one of the following modes:
·     Standalone mode—The device cannot form an IRF fabric with other devices.
·     IRF mode—The device can form an IRF fabric with other devices.
IRF member roles
IRF uses two member roles: master and standby (called subordinate throughout the documentation).
When devices form an IRF fabric, they elect a master to manage and control the IRF fabric, and all the other devices back up the master. When the master device fails, the other devices automatically elect a new master. For more information about master election, see "Master election."
IRF member ID
An IRF fabric uses member IDs to uniquely identify and manage its members. This member ID information is included as the first part of interface numbers and file paths to uniquely identify interfaces and files in an IRF fabric. Two devices cannot form an IRF fabric if they use the same member ID. A device cannot join an IRF fabric if its member ID has been used in the fabric.
For example, after you assign a device with a member ID of 2 to an IRF fabric, the name of interface GigabitEthernet 2/1/1 changes to GigabitEthernet 2/2/1/1. The file path changes from slot1#flash:/test.cfg to chassis2#slot1#flash:/test.cfg.
By default, the standby MPU of a device is automatically assigned the same ID as the active MPU.
MPU roles
Each IRF member device has one or two MPUs. The following are MPU roles:
Role
Master MPU
Active MPU of the master device. It is also called the global active MPU. You configure and manage the entire IRF fabric at the CLI of the global active MPU.
Active MPU
Active MPU on each member device. An active MPU performs the following operations:
·     Manages the local device, including synchronizing configuration with the local standby MPU, processing protocol packets, and creating and maintaining route entries.
·     Processes IRF-related events, such as master election and topology collection.
Standby MPU
For the master MPU, all other MPUs are standby MPUs, including active MPUs on subordinate devices.
If a member device has two MPUs, the MPU backing up the local active MPU is the local standby MPU from the perspective of the member device.
IRF port
An IRF port is a logical interface that connects IRF member devices. Every IRF-capable device has two IRF ports.
In standalone mode, the IRF ports are named IRF-port 1 and IRF-port 2.
In IRF mode, the IRF ports are named IRF-port n/1 and IRF-port n/2, where n is the member ID of the device. The two IRF ports are referred to as IRF-port 1 and IRF-port 2 in this book.
To use an IRF port, you must bind a minimum of one physical interface to it. The physical interfaces assigned to an IRF port automatically form an aggregate IRF link. An IRF port goes down when all its IRF physical interfaces are down.
IRF physical interfaces connect IRF member devices and must be bound to an IRF port. They forward traffic between member devices, including IRF protocol packets and data packets that must travel across IRF member devices.
For more information about physical interfaces that can be used for IRF links, see "IRF physical interface requirements."
MAD
An IRF link failure causes an IRF fabric to split in two IRF fabrics operating with the same Layer 3 settings, including the same IP address. To avoid IP address collision and network problems, IRF uses multi-active detection (MAD) mechanisms to detect the presence of multiple identical IRF fabrics, handle collisions, and recover from faults.
IRF domain ID
One IRF fabric forms one IRF domain. IRF uses IRF domain IDs to uniquely identify IRF fabrics and prevent IRF fabrics from interfering with one another.
As shown in Figure 3, IRF fabric 1 contains Device A and Device B, and IRF fabric 2 contains Device C and Device D. Both fabrics use the LACP aggregate links between them for MAD. When a member device receives an extended LACPDU for MAD, it checks the domain ID to see whether the packet is from the local IRF fabric. Then, the device can handle the packet correctly.
Figure 3 A network that contains two IRF domains
IRF split
IRF split occurs when an IRF fabric breaks up into multiple IRF fabrics because of IRF link failures, as shown in Figure 4. The split IRF fabrics operate with the same IP address. IRF split causes routing and forwarding problems on the network. To quickly detect a multi-active collision, configure a minimum of one MAD mechanism (see "Configuring MAD").
Figure 4 IRF split
IRF merge
IRF merge occurs when two split IRF fabrics reunite or when two independent IRF fabrics are united, as shown in Figure 5.
Figure 5 IRF merge
Member priority
Member priority determines the possibility of a member device to be elected the master. A member with higher priority is more likely to be elected the master.
IRF uses a strict running-configuration synchronization mechanism. In an IRF fabric, all devices obtain and run the running configuration of the master. Configuration changes are automatically propagated from the master to the remaining devices. The configuration files of these devices are retained, but the files do not take effect. The devices use their own startup configuration files only after they are removed from the IRF fabric.
For more information about configuration management, see Fundamentals Configuration Guide.
Loop control protocols such as the spanning tree feature cannot be configured on IRF physical interfaces. However, IRF has its own mechanism to eliminate loops. Before an IRF member device forwards a packet, it identifies whether loops exist on the forwarding path based on the source and destination physical interfaces and the IRF topology. If a loop exists, the device discards the packet on the source interface of the looped path. This loop elimination mechanism will drop a large number of broadcast packets on the IRF physical interfaces. To reduce SNMP notifications of packet drops when you use SNMP tools, do not monitor packet forwarding on the IRF physical interfaces.
Master election
Master election occurs each time the IRF fabric topology changes in the following situations:
·     The IRF fabric is established.
·     The master device fails or is removed.
·     The IRF fabric splits.
·     Independent IRF fabrics merge.
Master election does not occur when split IRF fabrics merge. The member devices in the Recovery-state IRF fabrics reboot to join the active IRF fabric as subordinate devices. The master device of the active IRF fabric is the master of the merged IRF fabric.
Master election selects a master in descending order:
1.     Current master, even if a new member has higher priority.
When an IRF fabric is being formed, all members consider themselves as the master. This rule is skipped.
2.     Member with higher priority.
3.     Member with the longest system uptime.
Two members are considered to start up at the same time if the difference between their startup times is equal to or less than 10 minutes. For these members, the next tiebreaker applies.
4.     Member with the lowest CPU MAC address.
For the setup of a new IRF fabric, the subordinate devices must reboot to complete the setup after the master election.
For an IRF merge, devices must reboot if they are in the IRF fabric that fails the master election. The reboot can be performed automatically or manually.
The multi-active handling procedure includes detection, collision handling, and failure recovery.
Detection
MAD identifies each IRF fabric with a domain ID and an active ID (the member ID of the master). If multiple active IDs are detected in a domain, MAD determines that an IRF collision or split has occurred.
For more information about the MAD mechanisms and their application scenarios, see "MAD mechanisms."
Collision handling
When MAD detects a multi-active collision, it sets all IRF fabrics except one to the Recovery state. The fabric that is not placed in Recovery state can continue to forward traffic. The Recovery-state IRF fabrics are inactive and cannot forward traffic.
LACP MAD and BFD MAD use the following process to handle a multi-active collision:
1.     Compare the number of members in each fabric.
2.     Set all fabrics to the Recovery state except the one that has the most members.
3.     Compare the member IDs of the masters if all IRF fabrics have the same number of members.
4.     Set all fabrics to the Recovery state except the one that has the lowest numbered master.
5.     Shut down all service interfaces in the Recovery-state fabrics except for the following service interfaces:
¡     IRF physical interfaces.
¡     Service interfaces specified by using the mad exclude interface command.
Failure recovery
To merge two split IRF fabrics, first repair the failed IRF link and remove the IRF link failure.
·     If the IRF fabric in Recovery state fails before the failure is recovered, repair the failed IRF fabric and the failed IRF link.
·     If the active IRF fabric fails before the failure is recovered, enable the inactive IRF fabric to take over the active IRF fabric. Then, repair the failed IRF fabric and the failed IRF link.
MAD mechanisms
IRF provides MAD mechanisms by extending LACP and BFD.
You must configure a minimum of one MAD mechanism on an IRF fabric.
Table 1 compares the MAD mechanisms and their application scenarios.
Table 1 Comparison of MAD mechanisms
MAD mechanism
Advantages
Disadvantages
Application scenario
LACP MAD
·     Detection speed is fast.
·     Does not require MAD-dedicated physical links or Layer 3 interfaces.
Requires an intermediate device that supports extended LACP for MAD.
Link aggregation is used between the IRF fabric and its upstream or downstream device.
For information about LACP, see Layer 2—LAN Switching Configuration Guide.
BFD MAD
·     No intermediate device is required.
·     Intermediate device, if used, can come from any vendor.
·     Requires MAD dedicated physical links and Layer 3 interfaces, which cannot be used for transmitting user traffic.
·     If no intermediate device is used, any two IRF members must have a BFD MAD link to each other.
·     If an intermediate device is used, every IRF member must have a BFD MAD link to the intermediate device.
·     No special requirements for network scenarios.
·     If no intermediate device is used, this mechanism is only suitable for IRF fabrics that have a small number of members that are geographically close to one another.
For information about BFD, see High Availability Configuration Guide.
LACP MAD
As shown in Figure 6, LACP MAD has the following requirements:
·     Every IRF member must have a link with an intermediate device.
·     All the links form a dynamic link aggregation group.
·     The intermediate device must be a device that supports extended LACP for MAD.
The IRF member devices send extended LACPDUs that convey a domain ID and an active ID. The intermediate device transparently forwards the extended LACPDUs received from one member device to all the other member devices.
·     If the domain IDs and active IDs sent by all the member devices are the same, the IRF fabric is integrated.
·     If the extended LACPDUs convey the same domain ID but different active IDs, a split has occurred. LACP MAD handles this situation as described in "Collision handling."
Figure 6 LACP MAD scenario
BFD MAD
IMPORTANT
IMPORTANT:
BFD MAD is supported only on the default MDC.
BFD MAD can work with or without an intermediate device. Figure 7 shows a typical BFD MAD application scenario.
To use BFD MAD:
·     Set up dedicated BFD MAD link between each pair of IRF members or between each IRF member and the intermediate device. Do not use the BFD MAD links for any other purposes.
·     Create a Layer 3 aggregate interface for BFD MAD, and assign a MAD IP address to each member on the aggregate interface.
The MAD IP addresses identify the member devices and must belong to the same subnet.
·     Assign the ports connected by BFD MAD links to the Layer 3 aggregation group.
On the intermediate device (if any), create a VLAN and assign the ports on BFD MAD links to the VLAN. Do not assign the ports to an aggregate interface.
With BFD MAD, the master attempts to establish BFD sessions with other member devices by using its MAD IP address as the source IP address.
·     If the IRF fabric is integrated, only the MAD IP address of the master takes effect. The master cannot establish a BFD session with any other member. If you execute the display bfd session command, the state of the BFD sessions is Down.
·     When the IRF fabric splits, the IP addresses of the masters in the split IRF fabrics take effect. The masters can establish a BFD session. If you execute the display bfd session command, the state of the BFD session between the two devices is Up.
Figure 7 BFD MAD scenario
When you set up an IRF fabric, follow these hardware restrictions and guidelines:
·     The SR6604, SR6608, and SR6616 routers can form an IRF fabric with each other. The routers cannot form an IRF fabric with any other devices.
·     The SR6604-X, SR6608-X, and SR6616-X routers can form an IRF fabric with each other. The routers cannot form an IRF fabric with any other devices.
For a successful IRF setup, follow the restrictions and guidelines in this section and the setup procedure in "Setup and configuration task list."
IRF fabric size
An IRF fabric of this series routers can contain a maximum of two chassis.
All IRF member devices must run the same software image version. Make sure the software auto-update feature is enabled on all member devices.
MPU requirements
Every IRF member must have a minimum of one MPU.
IRF physical interface location
On SR6604, SR6608, SR6616, SR6604-X, SR6608-X, or SR6616-X routers, follow these guidelines when you select IRF physical interfaces:
·     You can use physical interfaces from the modules in Table 2 for IRF links on a member device.
Table 2 Candidate IRF physical interfaces
Module
SR6604/SR6608/SR6616:
FIP-240
The two GE ports.
FIP-300
The 12 GE ports.
FIP-310
The four GE ports and the two 10GBASE-R/W ports.
SAP-20GE2XP
The four GE ports with the highest port numbers and the two SFP+ fiber ports.
SAP-28GE
The 12 GE ports with the highest port numbers.
SR6604-X/SR6608-X/SR6616-X:
SAP-4EXP
The four 10GBASE-R/W ports.
FIP-240
The two GE ports.
FIP-300
The 12 GE ports.
FIP-310
SAP-20GE2XP
The four GE ports with the highest port numbers and the two 10GBASE-R/W ports.
SAP-28GE
·     The ports on the SAP-4EXP module can only be used as IRF physical interfaces.
·     If you use ports on the SAP-4EXP module for IRF links on one device, you cannot use ports on other modules as IRF physical interfaces on the neighboring member device. If you do not use ports on the SAP-4EXP module for IRF links on one device, you cannot use ports on the SAP-4EXP module as IRF physical interfaces on the neighboring member device.
·     If the device contains a FIP-600 module, you can use only the physical interfaces on the SAP-4EXP module for IRF links.
·     All IRF physical interfaces bound to an IRF port must belong to the same service module and operate at the same rate. The two ends of an IRF link must also operate at the same rate.
Selecting transceiver modules and cables
When you select transceiver modules and cables, follow these restrictions and guidelines:
·     Use straight-through or crossover copper Ethernet cables to connect copper Ethernet ports for a short-distance connection.
·     Use DAC cables to connect fiber Ethernet ports for a short-distance connection.
·     Use transceiver modules and fibers to connect fiber Ethernet ports for a long-distance connection.
·     The transceiver modules at the two ends of an IRF link must be the same type. For more information about transceiver modules, see the device installation guide.
When you connect two neighboring IRF members, follow these restrictions and guidelines:
·     You must connect the physical interfaces of IRF-port 1 on one member to the physical interfaces of IRF-port 2 on the other.
·     Do not connect physical interfaces of both IRF ports on one member device to the physical interfaces of both IRF ports on the other device.
If the IRF fabric splits, do not change the MDC settings on any IRF member devices before they reunite.
Except for the commands in Table 3, all IRF commands are available only on the default MDC.
Table 3 IRF commands available on both default and non-default MDCs
Command category
Commands
Display commands
display irf link
MAD commands
mad enable
For more information about MDCs, see "Configuring MDCs."
As a best practice, back up the next-startup configuration file on a device before adding the device to an IRF fabric as a subordinate.
A subordinate device's next-startup configuration file might be overwritten if the master and the subordinate use the same file name for their next-startup configuration files. You can use the backup file to restore the original configuration after removing the subordinate from the IRF fabric.
To set up and configure an IRF fabric:
Tasks at a glance
Remarks
1.     (Required.) Planning the IRF fabric setup
N/A
2.     (Required.) Preconfiguring IRF member devices in standalone mode:
¡     Assigning a member ID to each IRF member device
¡     Specifying a priority for each member device
¡     Binding physical interfaces to IRF ports
You can configure member IDs, member priority, and IRF port bindings in standalone or IRF mode.
As a best practice, perform these tasks in standalone mode to reduce the number of reboots.
3.     (Required.) Saving configuration to the next-startup configuration file
N/A
4.     (Required.) Connecting IRF physical interfaces
N/A
5.     (Required.) Setting the operating mode to IRF mode
N/A
6.     (Required.) Accessing the IRF fabric
N/A
7.     (Required.) Configuring MAD:
¡     Configuring LACP MAD
¡     Configuring BFD MAD
¡     Excluding a service interface from the shutdown action upon detection of multi-active collision
¡     Recovering an IRF fabric
Perform the following optional tasks depending on the network environment:
·     Excluding a service interface from the shutdown action upon detection of multi-active collision.
·     Recovering an IRF fabric.
8.     (Optional.) Configuring IRF member devices in IRF mode:
¡     Bulk-configuring basic IRF settings for a device in IRF mode
¡     Changing the member ID of a device
¡     Changing the priority of a member device
¡     Adding physical interfaces to an IRF port
¡     Enabling IRF auto-merge
¡     Configuring a member device description
¡     Configuring IRF link load sharing mode
¡     Configuring IRF bridge MAC persistence
¡     Enabling software auto-update for software image synchronization
¡     Setting the IRF link down report delay
Adding physical interfaces to an IRF port is required if you did not configure IRF port bindings in standalone mode.
CAUTION CAUTION:
Changing member IDs in an IRF fabric can void member ID-related configuration and cause unexpected problems. Make sure you understand the impact on your live network before you change member IDs.
Consider the following items when you plan an IRF fabric:
·     Hardware compatibility and restrictions.
·     IRF fabric size.
·     Master device.
·     IRF physical interfaces.
·     Member ID and priority assignment scheme.
·     Fabric topology and cabling scheme.
For more information about hardware and cabling, see the device installation guide.
Perform the preconfiguration tasks on every IRF member device. These settings take effect on each member device after their operating mode changes to IRF.
Assign a unique IRF member ID to a device before changing the device's operating mode to IRF.
The member ID assigned to the device is saved in both active and standby MPUs. The standby MPU might store a different member ID than the active MPU after an MPU replacement. For consistency, the system updates the member ID in the active MPU automatically to the standby MPU when the difference is detected.
To assign a member ID to the device in standalone mode:
Step
Remarks
N/A
2.     Assign an IRF member ID to the device.
irf member member-id
The default member ID is 1.
IRF member priority represents the possibility for a device to be elected the master in an IRF fabric. The higher the priority, the higher the possibility.
To specify a priority for the device in standalone mode:
Step
Remarks
N/A
2.     Specify a priority for the device.
irf priority priority
The default IRF member priority is 1.
To establish an IRF connection between two devices, you must bind a minimum of one physical interface to IRF-port 1 on one device and to IRF-port 2 on the other.
When you bind physical interfaces to IRF ports, follow these restrictions and guidelines:
·     You must configure IRF physical interfaces as Layer 2 interfaces. Layer 3 interfaces cannot be bound to IRF ports. To configure a physical interface as a Layer 2 interface, use the port link-mode bridge command. For more information about this command, see Interface Configuration Guide.
·     In standalone mode, IRF port binding operations do not affect the current configuration of a physical interface. However, when the operating mode changes to IRF mode, the default configuration is restored on the physical interface. You can execute only the combo enable { copper | fiber }, description, and shutdown commands on an IRF physical interface. For more information about these commands, see Interface Command Reference.
Configuration procedure
To bind physical interfaces to IRF ports:
Step
Remarks
N/A
2.     Enter IRF port view.
irf-port irf-port-number
N/A
3.     Bind a physical interface to the IRF port.
port group interface interface-type interface-number [ mode enhanced ]
By default, no physical interfaces are bound to an IRF port.
Repeat this step to assign multiple physical interfaces to the IRF port.
An IRF physical interface operates in enhanced mode after the IRF binding takes effect, regardless of whether you have specified the mode enhanced keywords.
Save the running configuration before converting to the IRF mode. The mode change requires a reboot, which causes all unsaved settings to be lost.
Perform the following task in any view:
Save the running configuration to the next-startup configuration file.
save [ safely ] [ backup | main ] [ force ]
When you connect two neighboring IRF members, connect the physical interfaces of IRF-port 1 on one member to the physical interfaces of IRF-port 2 on the other (see Figure 8).
Figure 8 Connecting IRF physical interfaces
Connect the devices into a daisy-chain topology.
Figure 9 Daisy-chain topology
By default, the device operates in standalone mode. To assign the device to an IRF fabric, you must change its operating mode to IRF mode.
To set the operating mode of a device to IRF mode:
Step
Remarks
1.     (Optional.) Verify that a unique IRF member ID has been assigned to the device.
display irf configuration
Check the MemberID field.
2.     Enter system view.
N/A
3.     Set the operating mode to IRF mode.
chassis convert mode irf
The default operating mode is standalone mode.
After you change the operating mode, the device automatically reboots for the change to take effect.
During the reboot, you may choose to have the system automatically convert the startup configuration file. Automatic configuration conversion prevents slot- or interface-related settings from becoming invalid. For example, the system adds member ID information to interface numbers and file paths in IRF mode.
To restore the standalone mode, use the undo chassis convert mode command.
TIP
TIP:
IRF generates packets on a device in IRF mode even if the device does not form an IRF fabric with any other devices. To conserve system resources, set a device to standalone mode after removing it from an IRF fabric.
The IRF fabric appears as one device after it is formed. You configure and manage all IRF members at the CLI of the global active MPU. All settings you have made are automatically propagated to the IRF members.
The following methods are available for accessing an IRF fabric:
·     Local login—Log in through the console port of any MPU.
·     Remote login—Log in at a Layer 3 interface on any member device by using methods including Telnet, Web, and SNMP.
When you log in to an IRF fabric, you are placed at the CLI of the global active MPU, regardless of at which member device you are logged in.
For more information, see login configuration in Fundamentals Configuration Guide.
Configuring MAD
When you configure MAD, follow these restrictions and guidelines:
·     You must configure a minimum of one MAD mechanism on an IRF fabric.
·     If LACP MAD runs between two IRF fabrics, assign each fabric a unique IRF domain ID. (For BFD MAD, this task is optional.)
·     An IRF fabric has only one IRF domain ID.
¡     You can change the IRF domain ID by using the irf domain or mad enable command. The IRF domain IDs configured by using the commands overwrite each other.
¡     In an MDC environment, if you change the IRF domain ID in one MDC, the IRF domain IDs in all other MDCs change automatically. The irf domain command is available only on the default MDC. The mad enable command is available on any MDCs.
·     To prevent a service interface from being shut down when the IRF fabric transits to the Recovery state, use the mad exclude interface command. To bring up service interfaces in a Recovery-state IRF fabric, use the mad restore command instead of the undo shutdown command. The mad restore command activates the Recovery-state IRF fabric.
When you use LACP MAD, follow these guidelines:
·     If the intermediate device is also an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection.
·     Use dynamic link aggregation mode. MAD is LACP dependent. Even though LACP MAD can be configured on both static and dynamic aggregate interfaces, it takes effect only on dynamic aggregate interfaces.
·     Configure link aggregation settings on the intermediate device.
To configure LACP MAD:
Step
Remarks
N/A
2.     Assign a domain ID to the IRF fabric.
irf domain domain-id
The default IRF domain ID is 0.
3.     Create a Layer 3 aggregate interface and enter Layer 3 aggregate interface view.
Perform this step also on the intermediate device.
4.     Configure the aggregation group to operate in dynamic aggregation mode.
link-aggregation mode dynamic
By default, an aggregation group operates in static aggregation mode.
5.     Enable LACP MAD.
mad enable
By default, LACP MAD is disabled.
6.     Return to system view.
N/A
7.     Enter Ethernet interface view or interface range view.
·     Enter interface range view:
¡     Method 1:
interface range { interface-type interface-number [ to interface-type interface-number ] } &<1-5>
¡     Method 2:
interface range name name [ interface { interface-type interface-number [ to interface-type interface-number ] } &<1-5> ]
·     Enter Ethernet interface view:
To assign a range of ports to the aggregation group, enter interface range view.
To assign one port to the aggregation group, enter Ethernet interface view.
8.     Assign the Ethernet port or the range of Ethernet ports to the specified aggregation group.
Multichassis link aggregation is allowed.
Also perform this step on the intermediate device.
Configuring BFD MAD
When you use BFD MAD, follow these restrictions and guidelines:
Category
BFD MAD-enabled Layer 3 aggregate interface
Make sure the IRF fabrics on the network use different aggregate interfaces for BFD MAD.
BFD MAD VLAN
On the intermediate device (if any), assign the ports on the BFD MAD links to the same VLAN. Do not assign the ports to an aggregate interface.
BFD MAD-enabled Layer 3 aggregate interface and feature compatibility
Configure only the mad bfd enable and mad ip address commands on the BFD MAD-enabled interface. If you configure other features, both BFD MAD and other features on the interface might run incorrectly.
MAD IP address
·     To avoid problems, only use the mad ip address command to configure IP addresses on the BFD MAD-enabled interface. Do not configure an IP address by using the ip address command or configure a VRRP virtual address on the BFD MAD-enabled interface.
·     Make sure all the MAD IP addresses are on the same subnet.
To configure BFD MAD:
Step
Remarks
N/A
2.     (Optional.) Assign a domain ID to the IRF fabric.
By default, the domain ID of an IRF fabric is 0.
3.     Create a Layer 3 aggregate interface for BFD MAD.
N/A
4.     Return to system view.
N/A
5.     Enter interface view or interface range view.
¡     Method 1:
¡     Method 2:
·     Enter interface view:
To assign a range of ports to the aggregation group for the aggregate interface, enter interface range view.
To assign one port to the aggregation group for the aggregate interface, enter Ethernet interface view.
6.     Assign the port or the range of ports to the aggregation group for the aggregate interface.
Make sure the group number is identical to the aggregate interface number.
7.     Return to system view.
N/A
8.     Enter Layer 3 aggregate interface view.
N/A
9.     Enable BFD MAD.
mad bfd enable
By default, BFD MAD is disabled.
10.     Assign a MAD IP address to a member device on the Layer 3 aggregate interface.
mad ip address ip-address { mask | mask-length } member member-id
By default, no MAD IP addresses are configured on aggregate interfaces.
Repeat this step to assign a MAD IP address to each member device on the aggregate interface.
By default, all service interfaces except for the IRF physical interfaces shut down automatically when the IRF fabric transits to the Recovery state.
You can exclude a service interface from the shutdown action for management or other special purposes. For example:
·     Exclude a port from the shutdown action so you can Telnet to the port for managing the device.
·     Exclude a VLAN interface and its Layer 2 ports from the shutdown action so you can log in through the VLAN interface.
When you configure this feature, follow these restrictions and guidelines:
·     If the Layer 2 ports of a VLAN interface are distributed on multiple member devices, the exclusion operation might introduce IP collision risks. The VLAN interface might be up on both active and inactive IRF fabrics.
·     Do not exclude the aggregate interfaces used for MAD and their member ports from the shutdown action.
To configure a service interface to not shut down when the IRF fabric transits to the Recovery state:
Step
Remarks
N/A
2.     Configure a service interface to not shut down when the IRF fabric transits to the Recovery state.
mad exclude interface interface-type interface-number
By default, all service interfaces on a Recovery-state IRF fabric are shut down, except for the IRF physical interfaces.
After the failed IRF link between two split IRF fabrics is recovered, log in to the inactive IRF fabric, and use the reboot command to reboot all its member devices. If the irf auto-merge enable command has been configured, the inactive IRF member devices automatically reboot after the failed link is recovered. After these member devices join the active IRF fabric as subordinate devices, the IRF merge is complete, as shown in Figure 10. The service interfaces that have been shut down by MAD automatically restore their original state.
Figure 10 Recovering the IRF fabric
If the active IRF fabric fails before the IRF link is recovered (see Figure 11), use the mad restore command on the inactive IRF fabric to recover the inactive IRF fabric. This command also brings up all service interfaces that were shut down by MAD. After the IRF link is repaired, merge the two parts into a unified IRF fabric.
Figure 11 Active IRF fabric fails before the IRF link is recovered
To manually recover an inactive IRF fabric:
Step
2.     Recover the inactive IRF fabric.
mad restore
You can perform the tasks in this section or configure features in all other configuration guides for an IRF fabric from the master's CLI.
IMPORTANT
IMPORTANT:
The device reboots immediately after you specify a new member ID for it. Make sure you are aware of the impact on the network.
Use the easy IRF feature to bulk-configure basic IRF settings for a device in IRF mode, including the member ID, domain ID, priority, and IRF port bindings.
The easy IRF feature provides the following configuration methods:
·     Interactive method—Enter the easy-irf command without parameters. The system will guide you to set the parameters step by step.
·     Non-interactive method—Enter the easy-irf command with parameters.
As a best practice, use the interactive method if you are new to IRF.
When you specify IRF physical interfaces for an IRF port, you must follow the IRF port binding restrictions in "IRF physical interface requirements."
If you specify IRF physical interfaces by using the interactive method, you must also follow these restrictions and guidelines:
·     Do not enter spaces between the interface type and interface number.
·     Use a comma (,) to separate two physical interfaces. No spaces are allowed between interfaces.
To bulk-configure basic IRF settings for a device in IRF mode:
Step
Remarks
N/A
2.     Bulk-configure basic IRF settings for the device.
easy-irf [ member member-id [ renumber new-member-id ] domain domain-id [ priority priority ] [ irf-port1 interface-list1 ] [ irf-port2 interface-list2 ] ]
Make sure the new member ID is unique in the IRF fabric to which the device will be added.
If you execute this command multiple times, the following settings take effect:
·     The most recent settings for the member ID, domain ID, and priority.
·     IRF port bindings added through executions of the command.
To remove an IRF physical interface from an IRF port, you must use the undo port group interface command in IRF port view.
CAUTION
CAUTION:
In IRF mode, an IRF member ID change can invalidate member ID-related settings and cause data loss. Make sure you fully understand its impact on your live network.
The new member ID takes effect at reboot. After the device reboots, the settings on all member ID-related physical resources (including common physical service interfaces) are removed, regardless of whether you have saved the configuration.
To change the member ID of a member device:
Step
Remarks
N/A
2.     Change the member ID of a member device.
irf member member-id renumber new-member-id
By default, the device uses the member ID that is set in standalone mode.
3.     Save the running configuration.
save [ safely ] [ force ]
N/A
4.     Reboot the member device.
reboot chassis chassis-number [ force ]
The chassis-number must be the same as the member-id specified in the irf member member-id renumber new-member-id command.
You can change the priority of a member device so it can be elected the master in the next master election.
A change to member priority can affect the master re-election result. However, it does not cause an immediate master re-election.
To change the priority of a member device:
Step
Remarks
N/A
2.     Specify a priority for a member of an IRF fabric.
irf member member-id priority priority
In IRF mode, you can add physical interfaces to an IRF port without traffic interruption on the IRF port.
When you perform this task, follow the IRF physical interface restrictions and configuration guidelines in these sections:
·     IRF physical interface requirements.
·     Binding physical interfaces to IRF ports.
To configure IRF ports:
Step
Remarks
N/A
2.     Enter Ethernet interface view or interface range view.
¡     Method 1:
¡     Method 2:
To shut down a range of IRF physical interfaces, enter interface range view.
To shut down one IRF physical interface, enter its interface view.
3.     Shut down the physical interfaces.
shutdown
If you cannot shut down a physical interface, follow the system instruction to shut down its peer interface.
N/A
5.     Enter IRF port view.
irf-port member-id/irf-port-number
N/A
6.     Bind each physical interface to the IRF port.
N/A
8.     Enter Ethernet interface view or interface range view.
¡     Method 1:
¡     Method 2:
N/A
9.     Bring up the physical interfaces.
N/A
10.     Return to system view.
N/A
11.     Save the running configuration.
save
Activating IRF port settings causes IRF merge and reboot. To avoid data loss, save the running configuration to the startup configuration file before you perform the operation.
12.     Activate the configuration on the IRF port.
irf-port-configuration active
After this step is performed, the state of the IRF port changes to UP. The member devices elect a master, and the subordinate device reboots automatically.
After the IRF fabric is formed, you can add physical interfaces to an IRF port (in UP state) without repeating this step.
When two IRF fabrics merge, you must reboot the member devices in the IRF fabric that fails in the master election. The auto-merge feature enables the IRF fabric to automatically reboot all its member devices to complete the merge.
If this feature is disabled, you must manually reboot the devices in the IRF fabric that fails the master election to complete the merge.
To enable IRF auto-merge:
Step
Remarks
N/A
2.     Enable IRF auto-merge.
By default, this feature is enabled.
Step
Remarks
N/A
2.     Configure a description for a member device.
irf member member-id description text
By default, no member device description is configured.
On an IRF port, traffic is balanced across its physical links.
You can configure the IRF ports to distribute traffic based on any combination of the following criteria:
·     IP addresses.
·     MAC addresses.
·     Incoming ports.
The system displays an error message if a criteria combination is not supported.
To configure IRF link load sharing mode for all IRF ports:
Step
Remarks
N/A
2.     Configure IRF link load sharing mode for all IRF ports.
irf-port global load-sharing mode { destination-ip | destination-mac | ingress-port | source-ip | source-mac } *
The following are the default criteria for distributing different types of packets across IRF links:
·     TCP/UDP packets—Source and destination TCP/UDP port numbers.
·     Non-TCP/-UDP IP packets—Source and destination IP addresses.
By default, an IRF fabric uses the bridge MAC address of the master device as its bridge MAC address. Layer 2 protocols, such as LACP, use this bridge MAC address to identify the IRF fabric. On a switched LAN, the bridge MAC address must be unique.
To avoid duplicate bridge MAC addresses, an IRF fabric can change its bridge MAC address automatically after the address owner leaves. However, the change causes temporary traffic disruption.
Depending on the network condition, enable the IRF fabric to retain or change its bridge MAC address after the address owner leaves. Available options include:
·     irf mac-address persistent timer—Bridge MAC address of the IRF fabric is retained for 6 minutes after the address owner leaves. If the address owner does not return before the timer expires, the IRF fabric uses the bridge MAC address of the current master as its bridge MAC address. This option avoids unnecessary bridge MAC address changes caused by device reboot, transient link failure, or purposeful link disconnection.
·     irf mac-address persistent always—Bridge MAC address of the IRF fabric does not change after the address owner leaves.
·     undo irf mac-address persistent—Bridge MAC address of the current master replaces the original IRF bridge MAC address as soon as the owner of the original address leaves.
When IRF fabrics merge, IRF ignores the IRF bridge MAC address and checks the bridge MAC address of each member device in the IRF fabrics. IRF merge fails if any two member devices have the same bridge MAC address.
If the IRF fabric has cross-member aggregate links, do not use the undo irf mac-address persistent command.
To configure the IRF bridge MAC persistence setting:
Step
Remarks
N/A
2.     Configure IRF bridge MAC persistence.
·     Retain the bridge MAC address permanently even if the address owner has left the fabric:
·     Retain the bridge MAC address for 6 minutes after the address owner leaves the fabric:
·     Change the bridge MAC address as soon as the address owner leaves the fabric:
By default, the IRF bridge MAC address does not change after the address owner leaves the IRF fabric.
IMPORTANT
IMPORTANT:
To ensure a successful software auto-update in a multi-user environment, prevent anyone from rebooting or swapping member devices or MPUs during the auto-update process. To inform administrators of the auto-update status, configure the information center to output the status messages to configuration terminals (see Network Management and Monitoring Configuration Guide).
The software auto-update feature automatically propagates the software images of the global active MPU to all other MPUs in the IRF fabric.
To join an IRF fabric, an MPU must use the same software images as the global active MPU in the fabric.
When you add an MPU to the IRF fabric, software auto-update compares the startup software images of the MPU with the current software images of the IRF global active MPU. If the two sets of images are different, the MPU automatically performs the following operations:
1.     Downloads the current software images of the global active MPU.
2.     Sets the downloaded images as the main startup software images.
3.     Reboots with the new software images to rejoin the IRF fabric.
You must manually update the new MPU with the software images running on the IRF fabric when software auto-update is disabled.
To synchronize software from the active MPU to the standby MPU in standalone mode, use the undo version check ignore and version auto-update enable commands. For more information about these commands, see Fundamentals Configuration Guide.
Configuration prerequisites
Make sure the MPU you are adding to the IRF fabric has sufficient storage space for the new software images.
If sufficient storage space is not available, the system automatically deletes the current software images of the new MPU. If the reclaimed space is still insufficient, the MPU cannot complete the auto-update. You must reboot the device that holds the MPU, and then access the BootWare menus to delete files.
To enable software image synchronization:
Step
Remarks
N/A
2.     Enable software auto-update.
irf auto-update enable
By default, software auto-update is enabled.
To prevent frequent IRF splits and merges during link flapping, configure the IRF ports to delay reporting link down events.
An IRF port does not report a link down event to the IRF fabric immediately after its link changes from up to down. If the IRF link state is still down when the delay is reached, the port reports the change to the IRF fabric.
IRF ports do not delay link up events. They report the link up event immediately after the IRF link comes up.
To set the IRF link down report delay:
Step
Remarks
N/A
2.     Set the IRF link down report delay.
irf link-delay interval
By default, the delay is 1000 milliseconds.
If the BFD feature is used in the IRF fabric, make sure the delay interval is shorter than the BFD session lifetime. For more information about BFD, see High Availability Configuration Guide.
Display information about all IRF members.
display irf
Display the IRF fabric topology.
display irf topology
Display IRF link information.
display irf link
Display IRF configuration.
Display the load sharing mode for IRF links.
display irf-port load-sharing mode
Display MAD configuration.
display mad [ verbose ]
This section provides IRF configuration examples for IRF fabrics that use different MAD mechanisms.
Network requirements
As shown in Figure 12, use Device A and Device B to set up a two-chassis IRF fabric.
Configure LACP MAD on the multichassis aggregation to Device C, an H3C device that supports extended LACP.
Figure 12 Network diagram
IMPORTANT
IMPORTANT:
Between two neighboring IRF members, IRF links must be bound to IRF-port 1 on one member and to IRF-port 2 on the other.
1.     Configure Device A:
# Assign member ID 1 to Device A, and bind Ten-GigabitEthernet 3/0/1 to IRF-port 2.
[Sysname] irf member 1
[Sysname] irf-port 2
[Sysname-irf-port2] port group interface ten-gigabitethernet 3/0/1
[Sysname-irf-port2] quit
# Save the configuration.
[Sysname] quit
<Sysname> save
# Enable IRF mode.
[Sysname] chassis convert mode irf
The device will switch to IRF mode and reboot.
You are recommended to save the current running configuration and specify the configuration file for the next startup. Continue? [Y/N]:y
Do you want to convert the content of the next startup configuration file flash:/startup.cfg to make it available in IRF mode? [Y/N]:y
Now rebooting, please wait...
Device A forms a single-chassis IRF fabric after it reboots.
2.     Configure Device B:
# Assign member ID 2 to Device B, and bind Ten-GigabitEthernet 3/0/1 to IRF-port 1.
[Sysname] irf member 2
[Sysname] irf-port 1
[Sysname-irf-port1] port group interface ten-gigabitethernet 3/0/1
[Sysname-irf-port1] quit
[Sysname] quit
<Sysname> save
# Connect the two devices as shown in Figure 12.
# Enable IRF mode on Device B.
Device B and Device A form an IRF fabric after Device B reboots.
3.     Configure LACP MAD:
# Assign domain ID 1 to the IRF fabric.
[Sysname] irf domain 1
# Create a dynamic aggregate interface and enable LACP MAD.
[Sysname] interface route-aggregation 2
[Sysname-Route-Aggregation2] link-aggregation mode dynamic
[Sysname-Route-Aggregation2] mad enable
 [Current domain is: 1]:
 The assigned  domain ID is: 1
 MAD LACP only enable on dynamic aggregation interface.
[Sysname-Route-Aggregation2] quit
# Assign GigabitEthernet 1/4/0/2 and GigabitEthernet 2/4/0/2 to the aggregate interface.
[Sysname] interface gigabitethernet 1/4/0/2
[Sysname-GigabitEthernet1/4/0/2] port link-aggregation group 2
[Sysname-GigabitEthernet1/4/0/2] quit
[Sysname] interface gigabitethernet 2/4/0/2
[Sysname-GigabitEthernet2/4/0/2] port link-aggregation group 2
4.     Configure Device C as the intermediate device:
CAUTION
CAUTION:
If the intermediate device is also an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
# Create a dynamic aggregate interface.
# Assign GigabitEthernet 4/0/1 and GigabitEthernet 4/0/2 to the aggregate interface.
[Sysname] interface gigabitethernet 4/0/1
[Sysname-GigabitEthernet4/0/1] port link-aggregation group 2
[Sysname-GigabitEthernet4/0/1] quit
[Sysname] interface gigabitethernet 4/0/2
[Sysname-GigabitEthernet4/0/2] port link-aggregation group 2
As shown in Figure 13, set up an IRF fabric at the core layer of the network.
Configure BFD MAD on the IRF fabric and set up BFD MAD links between the member devices.
Figure 13 Network diagram
[Sysname] quit
<Sysname> save
# Enable IRF mode.
[Sysname] quit
<Sysname> save
# Connect the two devices as shown in Figure 13.
Device B and Device A form an IRF after Device B reboots.
3.     Configure BFD MAD:
# Create Route Aggregation 1.
[Sysname-Route-Aggregation1] quit
# Add GigabitEthernet 1/4/0/1 and GigabitEthernet 2/4/0/1 to the aggregation group.
[Sysname] interface gigabitethernet 1/4/0/1
[Sysname-GigabitEthernet1/4/0/1] port link-aggregation group 1
[Sysname-GigabitEthernet1/4/0/1] quit
[Sysname] interface gigabitethernet 2/4/0/1
[Sysname-GigabitEthernet2/4/0/1] port link-aggregation group 1
[Sysname-GigabitEthernet2/4/0/1] quit
# Assign a MAD IP address to each member device on the aggregate interface.
[Sysname-Route-Aggregation1] mad bfd enable
[Sysname-Route-Aggregation1] mad ip address 192.168.2.1 24 member 1
[Sysname-Route-Aggregation1] mad ip address 192.168.2.2 24 member 2
Break the IRF fabric in Figure 14, and change the operating mode of Device A and Device B from IRF to standalone.
Figure 14 Network diagram
1.     Identify the master.
<IRF> display irf
MemberID    Slot  Role   Priority   CPU-Mac         Description
 *+1        0     Master  1         00e0-fc0a-15e0  DeviceA
   1        1     Standby 1         00e0-fc0f-8c02  DeviceA
   2        0     Standby 1         00e0-fc0f-15e1  DeviceB
   2        1     Standby 1         00e0-fc0f-15e2  DeviceB
 The Bridge MAC of the IRF is: 000f-e26a-58ed
 Auto upgrade                : no
 Mac persistent              : always
 Domain ID                   : 0
The output shows that Device A is the master.
2.     Shut down IRF physical interfaces to disconnect all IRF links. In this example, shut down Ten-GigabitEthernet 1/3/0/1.
<IRF> system-view
[IRF] interface ten-gigabitethernet 1/3/0/1
[IRF-Ten-GigabitEthernet1/3/0/1] shutdown
[IRF-Ten-GigabitEthernet1/3/0/1] quit
3.     Save the configuration.
[IRF] save
 Validating file. Please wait.....................................
 The current configuration is saved to the active main board successfully.
 Configuration is saved to device successfully.
4.     Change the operating mode of Device A to standalone.
[IRF] undo chassis convert mode
The device will switch to stand-alone mode and reboot.
Do you want to convert the content of the next startup configuration file flash:/startup.cfg to make it available in stand-alone mode? [Y/N]:y
Device A automatically reboots to complete the operating mode change.
5.     Log in to Device B and change its operating mode to standalone.
<IRF> system-view
Device B automatically reboots to complete the operating mode change.
  • Become a Partner
  • Partner Resources
